# # ChangeLog for / in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/05/24 04:23:42 Sun, 10 Mar 2013 01:27:22 GMT Chris Johns [25e43e1] * tools/4.11/gcc/microblaze/rtems-gcc-microblaze-ldscript-1.diff (added) Microblaze gcc-4.7.2 patch from Joel. Fri, 08 Mar 2013 07:44:32 GMT Chris Johns [df78032] * tools/4.11/newlib/mips/newlib-2.0.0-mips-memcpy-20130107.diff (added) * tools/4.11/newlib/mips/newlib-2.0.0-mips-memcpy-20130219.diff (added) MIPS memcpy fixes. ... Wed, 06 Mar 2013 15:25:00 GMT Gedare Bloom [6d5bfb0] * ChangeLog (deleted) * README (deleted) * specbuilder/sb-build (deleted) * specbuilder/sb-crossgcc (deleted) * specbuilder/sb-setup (deleted) * specbuilder/sb-specdump (deleted) * specbuilder/sb-status (deleted) * specbuilder/sb-versions (deleted) * specbuilder/specbuilder/.gitignore (deleted) * specbuilder/specbuilder/build.py (deleted) * specbuilder/specbuilder/config.sub (deleted) * specbuilder/specbuilder/crossgcc.py (deleted) * specbuilder/specbuilder/darwin.py (deleted) * specbuilder/specbuilder/defaults.py (deleted) * specbuilder/specbuilder/error.py (deleted) * specbuilder/specbuilder/execute.py (deleted) * specbuilder/specbuilder/freebsd.py (deleted) * specbuilder/specbuilder/linux.py (deleted) * specbuilder/specbuilder/log.py (deleted) * specbuilder/specbuilder/perl.prov (deleted) * specbuilder/specbuilder/perl.req (deleted) * specbuilder/specbuilder/rtems.py (deleted) * specbuilder/specbuilder/setup.py (deleted) * specbuilder/specbuilder/spec.py (deleted) * specbuilder/specbuilder/status.py (deleted) * specbuilder/specbuilder/version.py (deleted) * specbuilder/specbuilder/windows.py (deleted) Clean up. Remove all files to prepare repo for a new life. ... Thu, 06 Sep 2012 04:09:49 GMT Chris Johns [7234c70] * ChangeLog (modified) * specbuilder/specbuilder/.gitignore (moved) Move .cvsignore to .gitignore. Update ChangeLog. Sat, 04 Aug 2012 12:29:24 GMT Chris Johns [68c9b8a] * specbuilder/sb-build (modified) * specbuilder/sb-crossgcc (modified) * specbuilder/sb-setup (modified) * specbuilder/sb-specdump (modified) * specbuilder/sb-status (modified) * specbuilder/sb-versions (modified) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/crossgcc.py (modified) * specbuilder/specbuilder/darwin.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/error.py (modified) * specbuilder/specbuilder/execute.py (modified) * specbuilder/specbuilder/freebsd.py (modified) * specbuilder/specbuilder/linux.py (modified) * specbuilder/specbuilder/log.py (modified) * specbuilder/specbuilder/rtems.py (modified) * specbuilder/specbuilder/setup.py (modified) * specbuilder/specbuilder/spec.py (modified) * specbuilder/specbuilder/status.py (modified) * specbuilder/specbuilder/version.py (modified) * specbuilder/specbuilder/windows.py (modified) Remove CVS Id and update the copyright year. Sat, 04 Aug 2012 12:17:50 GMT Chris Johns [5a44122] * specbuilder/specbuilder/spec.py (modified) Comments clean up. Sat, 04 Aug 2012 12:17:33 GMT Chris Johns [e801762] * specbuilder/specbuilder/setup.py (modified) Use the crossrpms repo and not the RTEMS source. Sat, 04 Aug 2012 12:17:05 GMT Chris Johns [db789e3] * specbuilder/specbuilder/perl.prov (modified) Clean up. Sat, 04 Aug 2012 12:16:48 GMT Chris Johns [f51e691] * specbuilder/specbuilder/darwin.py (modified) Do not build with zlib. Tue, 06 Dec 2011 23:44:37 GMT Chris Johns [6b88114] * specbuilder/specbuilder/freebsd.py (modified) Add /usr/local to the host cflags on FreeBSD. Tue, 06 Dec 2011 06:37:57 GMT Chris Johns [8548cd7] * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/freebsd.py (modified) Add a hack to work around make not being a macro in the spec files. Mon, 05 Dec 2011 20:53:17 GMT Chris Johns [594f41f] * specbuilder/specbuilder/freebsd.py (modified) * specbuilder/specbuilder/setup.py (modified) Fix the host verison in FreeBSD. Allow the top of the src to crossrpms. Mon, 05 Dec 2011 11:32:44 GMT Chris Johns [a2bc901] * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/freebsd.py (added) Add FreeBSD support. Thu, 09 Jun 2011 05:59:32 GMT Chris Johns [a86cd82] * ChangeLog (modified) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/crossgcc.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/linux.py (modified) * specbuilder/specbuilder/spec.py (modified) 2011-06-09 Chris Johns * ... Tue, 22 Feb 2011 03:46:44 GMT Chris Johns [faa8181] * ChangeLog (modified) * specbuilder/sb-versions (added) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/crossgcc.py (modified) * specbuilder/specbuilder/darwin.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/setup.py (modified) * specbuilder/specbuilder/spec.py (modified) * specbuilder/specbuilder/version.py (added) * specbuilder/specbuilder/windows.py (added) 2011-02-22 Chris Johns * ... Tue, 31 Aug 2010 00:58:45 GMT Chris Johns [31d4e80] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/linux.py (added) 2010-08-31 Chris Johns * ... Sat, 28 Aug 2010 23:01:20 GMT Chris Johns [9eb5c92] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) 2010-08-29 Chris Johns * ... Fri, 13 Aug 2010 04:40:44 GMT Chris Johns [f1a0bde] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/rtems.py (modified) * specbuilder/specbuilder/setup.py (modified) 2010-08-13 Chris Johns * ... Thu, 12 Aug 2010 22:40:57 GMT Chris Johns [0b29e44] * ChangeLog (modified) * specbuilder/specbuilder/setup.py (modified) 2010-08-13 Chris Johns * ... Thu, 12 Aug 2010 21:09:55 GMT Chris Johns [120137a] * ChangeLog (modified) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/darwin.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/rtems.py (added) * specbuilder/specbuilder/setup.py (modified) 2010-08-13 Chris Johns * ... Mon, 09 Aug 2010 04:50:30 GMT Chris Johns [dc2ed4f] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/perl.prov (added) * specbuilder/specbuilder/perl.req (added) * specbuilder/specbuilder/setup.py (modified) * specbuilder/specbuilder/spec.py (modified) 2010-08-09 Chris Johns * ... Mon, 09 Aug 2010 01:29:43 GMT Chris Johns [7231f49] * ChangeLog (added) * specbuilder/sb-build (added) * specbuilder/sb-crossgcc (added) * specbuilder/sb-setup (added) * specbuilder/sb-specdump (added) * specbuilder/sb-status (added) * specbuilder/specbuilder/.cvsignore (added) * specbuilder/specbuilder/build.py (added) * specbuilder/specbuilder/config.sub (added) * specbuilder/specbuilder/crossgcc.py (added) * specbuilder/specbuilder/darwin.py (added) * specbuilder/specbuilder/defaults.py (added) * specbuilder/specbuilder/error.py (added) * specbuilder/specbuilder/execute.py (added) * specbuilder/specbuilder/log.py (added) * specbuilder/specbuilder/setup.py (added) * specbuilder/specbuilder/spec.py (added) * specbuilder/specbuilder/status.py (added) 2010-08-09 Chris Johns * ... Mon, 09 Aug 2010 01:04:21 GMT Chris Johns [2dc8560] This commit was generated by cvs2svn to compensate for changes in r2, ... Mon, 09 Aug 2010 01:04:21 GMT Chris Johns [78c9ac0] * README (added) Create RTEMS Tools.
