# # ChangeLog for source-builder in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/06/24 07:32:39 Tue, 20 May 2014 11:55:51 GMT Chris Johns [467cace] * source-builder/sb/bootstrap.py (modified) sb: Clean up the bootstrap error handling. Wed, 14 May 2014 22:49:34 GMT Chris Johns [65d9457] * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Move error report generation to the build phase. Generate a ... Wed, 14 May 2014 06:43:40 GMT Chris Johns [83586f7] * source-builder/sb/build.py (modified) sb: Fix the formatting string. Tue, 13 May 2014 13:26:09 GMT Chris Johns [9a15c40] * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-binutils-patches.cfg (deleted) * rtems/config/rtems-gcc-patches.cfg (deleted) * rtems/config/rtems-gdb-patches.cfg (deleted) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-6.8-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (added) * source-builder/sb/version.py (modified) sb: Implement %source and %patch to manage source and patches. ... Fri, 02 May 2014 23:56:28 GMT Chris Johns [24473fa] * source-builder/config/gcc-4.9-1.cfg (added) config: Add gcc-4.9.0 configuration support. Thu, 08 May 2014 03:24:00 GMT Chris Johns [5850ac9] * source-builder/sb/freebsd.py (modified) sb: Fix the testing commit for FreeBSD. Used this to test error ... Thu, 08 May 2014 02:58:14 GMT Chris Johns [74da24c] * source-builder/sb/build.py (modified) * source-builder/sb/ereport.py (added) * source-builder/sb/freebsd.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Generate an error report on an error. Generate an error report ... Sun, 04 May 2014 06:22:46 GMT Chris Johns [2a6acc7] * source-builder/defaults.mc (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/netbsd.py (modified) config: Fix the host and build options for Canadian cross builds. ... Mon, 28 Apr 2014 08:51:59 GMT Chris Johns [527515c] * source-builder/sb/freebsd.py (modified) sb:Use cc and c++ on FreeBSD 10 and higher. Thu, 10 Apr 2014 08:26:42 GMT Chris Johns [a14171f] * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/netbsd.py (modified) * source-builder/sb/windows.py (modified) sb: Add _host_os_version to all supported hosts. Tue, 08 Apr 2014 06:16:50 GMT Chris Johns [ecda605] * source-builder/pkg-config (modified) * source-builder/sb/pkgconfig.py (modified) sb: Fix pkg-config to handle quoted libraries. Tue, 08 Apr 2014 05:11:00 GMT Chris Johns [f3b5490] * bare/config/devel/libiconv-1.14-1.cfg (added) * bare/config/devel/qemu-git-1.cfg (modified) * bare/config/devel/qemu.bset (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (added) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/mingw32-pkg-config (added) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) config,sb: Qemu build updates for FreeBSD and the start of MinG32. ... Wed, 26 Mar 2014 06:13:25 GMT Chris Johns [8c19df2] * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/options.py (modified) sb: Fix git to clean before updating. Wed, 26 Mar 2014 06:12:43 GMT Chris Johns [b77019a] * source-builder/config/gdb-7-1.cfg (modified) config: Build without zlib due to errors in psim. Wed, 26 Mar 2014 06:12:05 GMT Chris Johns [ed8a66a] * rtems/config/snapshots/gcc-4.8-branch.mc (added) * source-builder/config/gcc-common-1.cfg (modified) config: Add support for gcc-4.8-branch testing. Fri, 14 Feb 2014 02:27:36 GMT Chris Johns [0f064ba] * source-builder/config/qemu-1-1.cfg (modified) config: Do not build in trace support. Fri, 14 Feb 2014 02:26:11 GMT Chris Johns [9797bd1] * source-builder/pkg-config (modified) * source-builder/sb/imports/argparse.py (added) * source-builder/sb/pkgconfig.py (modified) sb: Clean up using argparse. It is not available on CentOS. Include ... Thu, 13 Feb 2014 05:01:03 GMT Chris Johns [d9e3dae] * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) config: Set the LD/DYLD temporary path for configure and make. Both ... Wed, 12 Feb 2014 04:26:07 GMT Chris Johns [587aa5f] * source-builder/sb/download.py (modified) sb: Add patchworks support via the pw://... URL. Wed, 12 Feb 2014 02:13:28 GMT Chris Johns [faa3583] * source-builder/sb/pkgconfig.py (modified) sb: Fixed from Fedora testing. Wed, 12 Feb 2014 02:09:56 GMT Chris Johns [6ff0672] * source-builder/config/glib-2-1.cfg (modified) config: Set build top for pkg-config. Wed, 12 Feb 2014 02:08:07 GMT Chris Johns [7c04790] * source-builder/config/qemu-1-1.cfg (modified) config: Disable werror because recent glibs have warnings. Tue, 11 Feb 2014 03:06:45 GMT Chris Johns [c5b5493] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * source-builder/sb/config.py (modified) config: Change pkgconfig to check. Add the extra actions: ccflags, ... Tue, 11 Feb 2014 03:06:07 GMT Chris Johns [55e52f4] * source-builder/sb/pkgconfig.py (modified) sb: Do not scan for libraries by default. Tue, 11 Feb 2014 03:05:16 GMT Chris Johns [ee93200] * source-builder/pkg-config (modified) sb: Check for empty flags and only add when a str. Mon, 10 Feb 2014 23:40:32 GMT Chris Johns [dcea9e0] * source-builder/sb/darwin.py (modified) sb: Remove the extra path. Use the default. Mon, 10 Feb 2014 23:38:33 GMT Chris Johns [f27f7c4] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) config: Update qemu to build on FreeBSD. Update configuration to ... Mon, 10 Feb 2014 23:18:35 GMT Chris Johns [c4fefde] * source-builder/bin/pkg-config (deleted) * source-builder/defaults.mc (modified) * source-builder/pkg-config (added) * source-builder/sb/config.py (modified) * source-builder/sb/pkgconfig.py (added) sb: Add pkg-config support. Add a pkg-config look alike command so ... Tue, 04 Feb 2014 07:38:18 GMT Chris Johns [56e8d80] * bare/config/devel/autoconf-internal-2.69-1.cfg (added) * bare/config/devel/autotools-base.bset (added) * bare/config/devel/autotools-internal.bset (added) * bare/config/devel/autotools.bset (added) * bare/config/devel/dtc.bset (added) * bare/config/devel/gettext-0.18.3.1-1.cfg (added) * bare/config/devel/glib-2.39.3-1.cfg (added) * bare/config/devel/libffi-3.0.13-1.cfg (added) * bare/config/devel/libtool-2.4.2-1.cfg (added) * bare/config/devel/pixman-0.32.4-1.cfg (added) * bare/config/devel/qemu-git-1.cfg (added) * bare/config/devel/qemu.bset (added) * source-builder/bin/pkg-config (added) * source-builder/config/gettext-0-1.cfg (added) * source-builder/config/glib-2-1.cfg (added) * source-builder/config/libffi-3-1.cfg (added) * source-builder/config/libtool-2-1.cfg (added) * source-builder/config/pixman-0-1.cfg (added) * source-builder/config/qemu-1-1.cfg (added) * source-builder/defaults.mc (modified) config: Add support to build qemu. Qemu requires gettext, glib, ... Tue, 04 Feb 2014 07:35:33 GMT Chris Johns [edf60aa] * source-builder/sb/path.py (modified) sb: Do not assume the src is valid. Tue, 04 Feb 2014 07:23:08 GMT Chris Johns [53b918e] * source-builder/sb/download.py (modified) sb: Fix downloader url parsing and add submodule git support. Split ... Tue, 04 Feb 2014 07:22:03 GMT Chris Johns [5601b9c] * source-builder/sb/git.py (modified) sb: Add submodule support to the git support. Tue, 04 Feb 2014 07:20:40 GMT Chris Johns [7c30130] * source-builder/sb/darwin.py (modified) darwin: Default to cc and c++ for Mavrick. Tue, 04 Feb 2014 07:19:19 GMT Chris Johns [00693f9] * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) config: Default _internal_autotools_path to nil when not an internal ... Thu, 30 Jan 2014 03:04:42 GMT Chris Johns [04aadb6] * source-builder/sb/check.py (modified) Check the user's PATH environment variable. Tue, 07 Jan 2014 11:30:41 GMT Chris Johns [1e7eb16] * source-builder/defaults.mc (modified) Fix the link path for GDB expat test. If doing a Cxc add the ld ... Mon, 06 Jan 2014 23:04:49 GMT Nick Withers [b7a13ab] * source-builder/sb/freebsd.py (modified) FreeBSD 10 and above no longer have /usr/bin/cvs - allow it to be ... Sat, 14 Dec 2013 01:15:14 GMT Chris Johns [8225925] * source-builder/sb/bootstrap.py (modified) Use the --jobs option. Sun, 10 Nov 2013 01:30:23 GMT Chris Johns [46dcbfc] * source-builder/sb/bootstrap.py (modified) Catch the OSError on the process failing. Sat, 09 Nov 2013 22:55:37 GMT Chris Johns [ce0f7a1] * source-builder/sb/setbuilder.py (modified) Add the host to the build set tar file name if no target. If ... Fri, 25 Oct 2013 23:12:15 GMT Chris Johns [4a59eb9] * source-builder/defaults.mc (modified) Split FLAGS into CFLAGS and LDFLAGS. The clang compiler on MacOS ... Fri, 25 Oct 2013 23:11:30 GMT Chris Johns [3bc9e31] * source-builder/sb/darwin.py (modified) Search any path for CVS on Darwin (MacOS). Tue, 10 Sep 2013 06:19:20 GMT Chris Johns [b8b0f44] * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) config: Use ${build_top} to change dir to parent. On NetBSD with ... Tue, 10 Sep 2013 06:18:52 GMT Chris Johns [ef58e21] * source-builder/sb/netbsd.py (modified) sb: Add include/lib paths for /usr/pkg to NetBSD. Thu, 05 Sep 2013 06:32:50 GMT Chris Johns [b843e62] * source-builder/sb/setbuilder.py (modified) sb: Do no install with a Cxc build. Tue, 03 Sep 2013 22:45:04 GMT Chris Johns [2802080] * source-builder/sb/setbuilder.py (modified) sb: Do not create a build set tar file on error. If creating build ... Mon, 02 Sep 2013 22:50:06 GMT Chris Johns [7a691b8] * source-builder/sb/config.py (modified) sb: Fix the config _parse args. Mon, 02 Sep 2013 22:30:26 GMT Chris Johns [845e92f] * source-builder/sb/config.py (modified) sb: Fix nesting if statements. Nesting if statements did not ... Mon, 02 Sep 2013 22:29:36 GMT Chris Johns [72f89c5] * source-builder/sb/reports.py (modified) * source-builder/sb/rtemsconfig.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Output the new info message. With the set builder add nesting ... Mon, 02 Sep 2013 21:59:38 GMT Chris Johns [348e498] * source-builder/sb/options.py (modified) sb: Add options log_info. Provide a log_info method for the options ... Sat, 31 Aug 2013 22:25:56 GMT Ivan Temp [a4937d8] * source-builder/sb/netbsd.py (added) * source-builder/sb/options.py (modified) sb: Add NetBSD support. Tue, 27 Aug 2013 02:21:14 GMT Chris Johns [d4fa101] * source-builder/sb/path.py (modified) sb: Fixed the errors as found by Gedare. Mon, 26 Aug 2013 21:48:10 GMT Chris Johns [5e536f8] * source-builder/sb/path.py (modified) sb: Import log for the copytree warnings. Mon, 26 Aug 2013 21:47:44 GMT Chris Johns [2f4bd55] * source-builder/config/gcc-common-1.cfg (modified) config: Fix the empty case of extra gcc options. Thu, 22 Aug 2013 03:24:14 GMT Chris Johns [f4e9035] * source-builder/config/gcc-common-1.cfg (modified) config: Fix the use of the extra options. Thu, 22 Aug 2013 01:38:44 GMT Chris Johns [85007c3] * source-builder/sb/path.py (modified) sb: Fix copy_tree coping links on Linux Overwriting symlinks did ... Thu, 22 Aug 2013 01:38:10 GMT Chris Johns [75aa2db] * source-builder/config/gcc-common-1.cfg (modified) config: Add support for extra GCC configure options. Thu, 15 Aug 2013 02:20:29 GMT Chris Johns [869b8a6] * source-builder/sb/path.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Fix the copy tree. Python's distutil's copy tree code maintains ... Wed, 14 Aug 2013 04:06:30 GMT Chris Johns [27d6ea0] * rtems/config/4.11/rtems-avr.bset (modified) * source-builder/config/gcc-common-1.cfg (modified) config: Add support for iconv encodings. Turn off iconv support for ... Wed, 14 Aug 2013 03:56:24 GMT Chris Johns [76d4899] * source-builder/config/checks.cfg (modified) config: Control languages from the command line --with/--without ... Wed, 14 Aug 2013 03:55:33 GMT Chris Johns [6201a0dd] * source-builder/defaults.mc (modified) config: Add the iconv encodings to the defaults. Thu, 08 Aug 2013 01:43:52 GMT Chris Johns [ff0fc8e] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * source-builder/config/versions.cfg (modified) config: Check the path for a valid autoconf. Sun, 21 Jul 2013 00:22:03 GMT Chris Johns [01b2815] * source-builder/sb/setbuilder.py (modified) SB: Fix internal build and mailing. Output errors to the log. Sat, 20 Jul 2013 22:55:11 GMT Chris Johns [6d32fe7] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) CONFIG: PR 2127 - Build fails on Linux. Fix shell tests where '==' ... Tue, 16 Jul 2013 00:02:41 GMT Chris Johns [ebf8a1f] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools-base.bset (added) * rtems/config/4.11/rtems-autotools-internal.bset (added) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-autoconf-2.69-1.cfg (added) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (added) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/versions.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/setbuilder.py (modified) Automtically build the Autotools to bootstrap RTEMS. This changes ... Sat, 13 Jul 2013 23:11:21 GMT Chris Johns [2626dba] * source-builder/config/dtc-1-1.cfg (modified) * source-builder/defaults.mc (modified) Fix the Cxc build configuration for the DTC tool. Mon, 17 Jun 2013 00:09:24 GMT Chris Johns [80d5fde] * source-builder/sb/freebsd.py (modified) Remove /usr/local from build flags. They cause problems with BFD etc. Mon, 03 Jun 2013 07:28:00 GMT Dhananjay Balan [54a2a5f] * source-builder/sb/linux.py (modified) distro_ver fails on Non-LSB distros. Mon, 20 May 2013 07:19:47 GMT Chris Johns [d925ea3] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) Align the 4.8 and 4.5 configurations with the gcc-common. Fri, 17 May 2013 02:52:22 GMT Chris Johns [54d1426] * source-builder/sb/options.py (modified) Clean the paths passed as args. Thu, 16 May 2013 05:34:00 GMT Chris Johns [b83b596] * source-builder/sb/linux.py (modified) Fix the core detection on Linux. Wed, 15 May 2013 03:23:41 GMT Chris Johns [1b40c77] * source-builder/sb/check.py (modified) Make outputing errors optional. Wed, 15 May 2013 02:15:14 GMT Chris Johns [db65c6a] * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/windows.py (modified) Support Canadian cross builds on FreeBSD (and other hosts). Set up ... Tue, 14 May 2013 01:12:54 GMT Chris Johns [8a1e7a0] * source-builder/sb/setbuilder.py (modified) Add better error messages. Tue, 14 May 2013 01:08:02 GMT Chris Johns [1a56a07] * bare/config/devel/autoconf-2.68-1.cfg (moved) * bare/config/devel/autoconf-2.69-1.cfg (moved) * bare/config/devel/autoconf-internal-2.68-1.cfg (moved) * bare/config/devel/automake-1.12-1.cfg (moved) * bare/config/devel/automake-1.12.2-1.cfg (moved) * bare/config/devel/automake-internal-1.12-1.cfg (moved) * bare/config/devel/binutils-2.22-1.cfg (moved) * bare/config/devel/dtc-1.2.0.cfg (moved) * bare/config/devel/expat-2.1.0-1.cfg (moved) * bare/config/devel/gcc-4.6-newlib-1.20-1.cfg (moved) * bare/config/devel/gcc-4.7-newlib-1.20-1.cfg (moved) * bare/config/devel/libusb-1.0.9-1.cfg (moved) * bare/config/devel/m4-1.4.16-1.cfg (moved) * bare/config/devel/texane-stlink-1.cfg (moved) * bare/config/gnu-tools-4.6.bset (moved) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * source-builder/defaults.mc (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/options.py (modified) Add bare/config and move the source-builder/config to it. Rework ... Mon, 13 May 2013 04:47:14 GMT Chris Johns [04f447f] * source-builder/sb/setbuilder.py (modified) Show a trace message on copy when with --dry-run. Mon, 13 May 2013 04:46:30 GMT Chris Johns [ca047f1e] * source-builder/sb/path.py (modified) Better error message on rmdir failure. Mon, 13 May 2013 04:44:49 GMT Chris Johns [5237f1cc] * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/options.py (modified) Fix support for Windows (MinGW) native builds using MSYS. Fix paths ... Mon, 13 May 2013 02:22:18 GMT Chris Johns [e226605] * source-builder/sb-rtems-config (added) * source-builder/sb/rtemsconfig.mk (added) * source-builder/sb/rtemsconfig.py (added) Add an RTEMS config wrapper around Makefile.inc. This is an ... Fri, 10 May 2013 08:13:38 GMT Chris Johns [e191ce8] * source-builder/sb/bootstrap.py (modified) Match output with the bootstrap script. Fri, 10 May 2013 01:10:40 GMT Chris Johns [8ee8460] * source-builder/sb/bootstrap.py (modified) Add check_output if on Python 2.6, ie CentOS. Tue, 07 May 2013 23:55:33 GMT Chris Johns [c8c60e5] * source-builder/sb/freebsd.py (modified) Add svn in /usr/local for FreeBSD. Wed, 01 May 2013 00:42:08 GMT Chris Johns [df56f7e] * source-builder/sb/setbuilder.py (modified) Improve the email reporter. Wed, 01 May 2013 00:08:36 GMT Chris Johns [c914e1d] * source-builder/sb/log.py (modified) * source-builder/sb/setbuilder.py (modified) Add tail support to the log. Email the log tail in a failure. Tue, 30 Apr 2013 22:34:09 GMT Chris Johns [3c69de0] * source-builder/sb/windows.py (modified) Add the missing Windows versions or MinGW. Tue, 30 Apr 2013 20:29:12 GMT Chris Johns [84924e4] * source-builder/sb/bootstrap.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/reports.py (modified) Fix the open calls to use a host path. Tue, 30 Apr 2013 19:30:22 GMT Chris Johns [2edd4c9] * source-builder/sb/options.py (modified) Produce a better error message if the host support code does not load. Tue, 30 Apr 2013 19:17:11 GMT Chris Johns [a128418] * source-builder/sb/linux.py (modified) Use float for version number such as CentOS 6.3. Tue, 30 Apr 2013 07:55:33 GMT Chris Johns [9815f5f] * source-builder/defaults.mc (modified) CVS is required. The newlib version is based on cvs for 4.11. Tue, 30 Apr 2013 07:27:40 GMT Chris Johns [cb5fc2c] * source-builder/sb/linux.py (modified) The dist version is index 1 not 2. Tue, 30 Apr 2013 07:23:18 GMT Chris Johns [49c668c] * source-builder/sb/linux.py (modified) Fix the dist_ver bug. Covert the string to an int. Tue, 30 Apr 2013 05:01:30 GMT Chris Johns [a48a478] * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gdb-7.6-1.cfg (added) * source-builder/config/gcc-4.8-1.cfg (modified) Updated 4.11 tool versions. Tue, 30 Apr 2013 03:22:28 GMT Chris Johns [fbb39e7] * source-builder/sb/options.py (modified) Add options help. Tue, 30 Apr 2013 01:20:54 GMT Chris Johns [97a685f] * source-builder/defaults.mc (modified) * source-builder/sb/git.py (modified) * source-builder/sb/mailer.py (added) * source-builder/sb/setbuilder.py (modified) Add mail support to mail reports. Tue, 30 Apr 2013 01:19:09 GMT Chris Johns [dfdc129] * source-builder/sb/options.py (modified) Add user private macro loading. Tue, 30 Apr 2013 01:18:46 GMT Chris Johns [1c44f1c] * source-builder/sb/macros.py (modified) Add a get value call for macros. Sun, 28 Apr 2013 23:01:14 GMT Chris Johns [adf0946] * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) Report from the setbuilder's build config. Refactor the reporter to ... Sun, 28 Apr 2013 22:59:53 GMT Chris Johns [8837860] * source-builder/sb/config.py (modified) Add a function to return the config file name. Sun, 28 Apr 2013 22:58:01 GMT Chris Johns [0ed876c] * source-builder/sb/download.py (modified) Do not run any download type functions if performing a dry-run. Sun, 28 Apr 2013 06:10:02 GMT Chris Johns [055e490] * source-builder/sb/reports.py (modified) Fix the report command. Only output if an outname is given.
