# # ChangeLog for source-builder/sb/windows.py in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/05/24 00:31:08 Sat, 07 Feb 2015 06:58:17 GMT Chris Johns [d4eb08f] * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/ereport.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/path.py (modified) * source-builder/sb/windows.py (modified) Windows native build fixes. The testing of building on Windows is ... Thu, 10 Apr 2014 08:26:42 GMT Chris Johns [a14171f] * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/netbsd.py (modified) * source-builder/sb/windows.py (modified) sb: Add _host_os_version to all supported hosts. Wed, 15 May 2013 02:15:14 GMT Chris Johns [db65c6a] * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/windows.py (modified) Support Canadian cross builds on FreeBSD (and other hosts). Set up ... Tue, 30 Apr 2013 22:34:09 GMT Chris Johns [3c69de0] * source-builder/sb/windows.py (modified) Add the missing Windows versions or MinGW. Thu, 04 Apr 2013 00:26:41 GMT Chris Johns [69e5938] * source-builder/sb/windows.py (modified) Remove smp_mflags. Defaults adds this now. Wed, 03 Apr 2013 03:31:41 GMT Chris Johns [0add2ea] * source-builder/sb/build.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/defaults.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/windows.py (modified) PR 2108, PR 2109. Add --jobs and --always-clean. Refactor the ... Mon, 01 Apr 2013 04:19:56 GMT Chris Johns [4f26bdb] * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/autoconf-2.69-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/checks.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/dtc-1.2.0.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/defaults.py (modified) * source-builder/sb/execute.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/windows.py (modified) Add Canadian Cross support. Add support to build MinGW tools using ... Sun, 03 Mar 2013 02:24:19 GMT Chris Johns [d7e4900] * source-builder/sb/defaults.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/git.py (added) * source-builder/sb/reports.py (modified) * source-builder/sb/windows.py (modified) Add support for GIT. The git module allows basic access to git. ... Wed, 27 Feb 2013 05:04:04 GMT Chris Johns [9262cd4] * source-builder/sb/windows.py (modified) Update the Windows location of new tools. Mon, 05 Nov 2012 23:09:40 GMT Chris Johns [c80560d] * source-builder/.gitignore (moved) * source-builder/config/autoconf-2-1.cfg (moved) * source-builder/config/autoconf-2.68-1.cfg (moved) * source-builder/config/autoconf-2.69-1.cfg (moved) * source-builder/config/autoconf-internal-2.68-1.cfg (moved) * source-builder/config/automake-1-1.cfg (moved) * source-builder/config/automake-1.12-1.cfg (moved) * source-builder/config/automake-internal-1.12-1.cfg (moved) * source-builder/config/base.cfg (moved) * source-builder/config/binutils-2-1.cfg (moved) * source-builder/config/binutils-2.22-1.cfg (moved) * source-builder/config/checks.cfg (moved) * source-builder/config/expat-2-1.cfg (moved) * source-builder/config/expat-2.1.0-1.cfg (moved) * source-builder/config/gcc-4.4-1.cfg (moved) * source-builder/config/gcc-4.6-1.cfg (moved) * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (moved) * source-builder/config/gdb-7-1.cfg (moved) * source-builder/config/gdb-7.5-1.cfg (moved) * source-builder/config/gnu-tools-4.6.bset (moved) * source-builder/config/libusb-1-1.cfg (moved) * source-builder/config/libusb-1.0.9-1.cfg (moved) * source-builder/config/m4-1-1.cfg (moved) * source-builder/config/m4-1.4.16-1.cfg (moved) * source-builder/config/texane-stlink-1.cfg (moved) * source-builder/doc/.gitignore (moved) * source-builder/doc/images/icons/README (moved) * source-builder/doc/images/icons/callouts/1.png (moved) * source-builder/doc/images/icons/callouts/10.png (moved) * source-builder/doc/images/icons/callouts/11.png (moved) * source-builder/doc/images/icons/callouts/12.png (moved) * source-builder/doc/images/icons/callouts/13.png (moved) * source-builder/doc/images/icons/callouts/14.png (moved) * source-builder/doc/images/icons/callouts/15.png (moved) * source-builder/doc/images/icons/callouts/2.png (moved) * source-builder/doc/images/icons/callouts/3.png (moved) * source-builder/doc/images/icons/callouts/4.png (moved) * source-builder/doc/images/icons/callouts/5.png (moved) * source-builder/doc/images/icons/callouts/6.png (moved) * source-builder/doc/images/icons/callouts/7.png (moved) * source-builder/doc/images/icons/callouts/8.png (moved) * source-builder/doc/images/icons/callouts/9.png (moved) * source-builder/doc/images/icons/caution.png (moved) * source-builder/doc/images/icons/example.png (moved) * source-builder/doc/images/icons/home.png (moved) * source-builder/doc/images/icons/important.png (moved) * source-builder/doc/images/icons/next.png (moved) * source-builder/doc/images/icons/note.png (moved) * source-builder/doc/images/icons/prev.png (moved) * source-builder/doc/images/icons/tip.png (moved) * source-builder/doc/images/icons/up.png (moved) * source-builder/doc/images/icons/warning.png (moved) * source-builder/doc/images/rtemswhitebg.jpg (moved) * source-builder/doc/source-builder.txt (moved) * source-builder/doc/wscript (moved) * source-builder/patches/texane-stlink-3494c11-1.diff (moved) * source-builder/patches/texane-stlink-3494c11-2.diff (moved) * source-builder/sb-builder (moved) * source-builder/sb-check (moved) * source-builder/sb-set-builder (moved) * source-builder/sb/build.py (moved) * source-builder/sb/check.py (moved) * source-builder/sb/config.py (moved) * source-builder/sb/darwin.py (moved) * source-builder/sb/defaults.py (moved) * source-builder/sb/error.py (moved) * source-builder/sb/execute.py (moved) * source-builder/sb/freebsd.py (moved) * source-builder/sb/linux.py (moved) * source-builder/sb/log.py (moved) * source-builder/sb/path.py (moved) * source-builder/sb/setbuilder.py (moved) * source-builder/sb/windows.py (moved) Move into the source-builder tree.
