# # ChangeLog for source-builder/sb/path.py in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/18/24 22:46:41 Tue, 27 Aug 2013 02:21:14 GMT Chris Johns [d4fa101] * source-builder/sb/path.py (modified) sb: Fixed the errors as found by Gedare. Mon, 26 Aug 2013 21:48:10 GMT Chris Johns [5e536f8] * source-builder/sb/path.py (modified) sb: Import log for the copytree warnings. Thu, 22 Aug 2013 01:38:44 GMT Chris Johns [85007c3] * source-builder/sb/path.py (modified) sb: Fix copy_tree coping links on Linux Overwriting symlinks did ... Thu, 15 Aug 2013 02:20:29 GMT Chris Johns [869b8a6] * source-builder/sb/path.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Fix the copy tree. Python's distutil's copy tree code maintains ... Mon, 13 May 2013 04:46:30 GMT Chris Johns [ca047f1e] * source-builder/sb/path.py (modified) Better error message on rmdir failure. Mon, 15 Apr 2013 01:15:01 GMT Chris Johns [255e032] * source-builder/sb/options.py (modified) * source-builder/sb/path.py (modified) PR 2115 - Fix checking when the path does not fully exist. Mon, 15 Apr 2013 00:05:23 GMT Chris Johns [9994530] * source-builder/sb/options.py (modified) * source-builder/sb/path.py (modified) * source-builder/sb/setbuilder.py (modified) PR 2115 - Check prefix path write access before starting to build. ... Sat, 13 Apr 2013 00:30:07 GMT Chris Johns [06dad0a] * source-builder/sb/path.py (modified) Make exists support lists. Add a path expander call. Wed, 27 Feb 2013 05:04:29 GMT Chris Johns [bc71066] * source-builder/sb/build.py (modified) * source-builder/sb/path.py (modified) Fix host paths on Windows. Fri, 22 Feb 2013 03:44:51 GMT Chris Johns [ee47d72] * source-builder/sb/build.py (modified) * source-builder/sb/path.py (modified) * source-builder/sb/setbuilder.py (modified) Create tar directory when making build set tar files. Move the ... Thu, 14 Feb 2013 07:00:06 GMT Chris Johns [73e8afb] * source-builder/sb/path.py (modified) If the path is empty do prepend a dirsep. Mon, 05 Nov 2012 23:09:40 GMT Chris Johns [c80560d] * source-builder/.gitignore (moved) * source-builder/config/autoconf-2-1.cfg (moved) * source-builder/config/autoconf-2.68-1.cfg (moved) * source-builder/config/autoconf-2.69-1.cfg (moved) * source-builder/config/autoconf-internal-2.68-1.cfg (moved) * source-builder/config/automake-1-1.cfg (moved) * source-builder/config/automake-1.12-1.cfg (moved) * source-builder/config/automake-internal-1.12-1.cfg (moved) * source-builder/config/base.cfg (moved) * source-builder/config/binutils-2-1.cfg (moved) * source-builder/config/binutils-2.22-1.cfg (moved) * source-builder/config/checks.cfg (moved) * source-builder/config/expat-2-1.cfg (moved) * source-builder/config/expat-2.1.0-1.cfg (moved) * source-builder/config/gcc-4.4-1.cfg (moved) * source-builder/config/gcc-4.6-1.cfg (moved) * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (moved) * source-builder/config/gdb-7-1.cfg (moved) * source-builder/config/gdb-7.5-1.cfg (moved) * source-builder/config/gnu-tools-4.6.bset (moved) * source-builder/config/libusb-1-1.cfg (moved) * source-builder/config/libusb-1.0.9-1.cfg (moved) * source-builder/config/m4-1-1.cfg (moved) * source-builder/config/m4-1.4.16-1.cfg (moved) * source-builder/config/texane-stlink-1.cfg (moved) * source-builder/doc/.gitignore (moved) * source-builder/doc/images/icons/README (moved) * source-builder/doc/images/icons/callouts/1.png (moved) * source-builder/doc/images/icons/callouts/10.png (moved) * source-builder/doc/images/icons/callouts/11.png (moved) * source-builder/doc/images/icons/callouts/12.png (moved) * source-builder/doc/images/icons/callouts/13.png (moved) * source-builder/doc/images/icons/callouts/14.png (moved) * source-builder/doc/images/icons/callouts/15.png (moved) * source-builder/doc/images/icons/callouts/2.png (moved) * source-builder/doc/images/icons/callouts/3.png (moved) * source-builder/doc/images/icons/callouts/4.png (moved) * source-builder/doc/images/icons/callouts/5.png (moved) * source-builder/doc/images/icons/callouts/6.png (moved) * source-builder/doc/images/icons/callouts/7.png (moved) * source-builder/doc/images/icons/callouts/8.png (moved) * source-builder/doc/images/icons/callouts/9.png (moved) * source-builder/doc/images/icons/caution.png (moved) * source-builder/doc/images/icons/example.png (moved) * source-builder/doc/images/icons/home.png (moved) * source-builder/doc/images/icons/important.png (moved) * source-builder/doc/images/icons/next.png (moved) * source-builder/doc/images/icons/note.png (moved) * source-builder/doc/images/icons/prev.png (moved) * source-builder/doc/images/icons/tip.png (moved) * source-builder/doc/images/icons/up.png (moved) * source-builder/doc/images/icons/warning.png (moved) * source-builder/doc/images/rtemswhitebg.jpg (moved) * source-builder/doc/source-builder.txt (moved) * source-builder/doc/wscript (moved) * source-builder/patches/texane-stlink-3494c11-1.diff (moved) * source-builder/patches/texane-stlink-3494c11-2.diff (moved) * source-builder/sb-builder (moved) * source-builder/sb-check (moved) * source-builder/sb-set-builder (moved) * source-builder/sb/build.py (moved) * source-builder/sb/check.py (moved) * source-builder/sb/config.py (moved) * source-builder/sb/darwin.py (moved) * source-builder/sb/defaults.py (moved) * source-builder/sb/error.py (moved) * source-builder/sb/execute.py (moved) * source-builder/sb/freebsd.py (moved) * source-builder/sb/linux.py (moved) * source-builder/sb/log.py (moved) * source-builder/sb/path.py (moved) * source-builder/sb/setbuilder.py (moved) * source-builder/sb/windows.py (moved) Move into the source-builder tree.
