# # ChangeLog for source-builder/sb/download.py in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/17/24 16:19:29 Fri, 11 Dec 2015 05:21:09 GMT Chris Johns [e8ed687] * source-builder/sb/download.py (modified) Generate an error if there is no hash when released. Tue, 16 Jun 2015 10:57:06 GMT Chris Johns [5b5d6bf] * source-builder/sb/download.py (modified) * source-builder/sb/path.py (modified) sb: Fix the downloader file:// URL to copy the file to the local path. Mon, 30 Mar 2015 03:30:56 GMT Chris Johns [bd16849] * source-builder/sb/download.py (modified) sb: Update the downloader for 2.7.8 and earlier without a context. Sun, 29 Mar 2015 04:35:00 GMT Chris Johns [3237c8e] * source-builder/sb/download.py (modified) sb: Provide an unverified SSL context to the URL. The RTEMS servers ... Tue, 17 Mar 2015 21:21:34 GMT Chris Johns [b0f9e30] * rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) Add merge to the git and download modules to merge after a fetch. ... Tue, 17 Feb 2015 23:15:31 GMT Chris Johns [d755065] * source-builder/sb/download.py (modified) * source-builder/sb/options.py (modified) Add options support for --with/--without processing. Add --with- ... Sat, 07 Feb 2015 06:58:17 GMT Chris Johns [d4eb08f] * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/ereport.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/path.py (modified) * source-builder/sb/windows.py (modified) Windows native build fixes. The testing of building on Windows is ... Fri, 29 Aug 2014 03:14:14 GMT Chris Johns [d790668] * doc/source-builder.txt (modified) * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) sb: Add support for the standard git protocols for the %source ... Thu, 28 Aug 2014 17:14:05 GMT Hesham ALMatary [e7a6292] * source-builder/sb/download.py (modified) Fix bug of uncompressing zip files. This patch uses __unzip macro ... Tue, 12 Aug 2014 02:59:22 GMT Chris Johns [d3629a9] * source-builder/sb/build.py (modified) * source-builder/sb/download.py (modified) sb: Fix sources related bugs. Updates the sources module introduced ... Sat, 09 Aug 2014 13:49:29 GMT Chris Johns [4934771] * source-builder/sb/download.py (modified) * source-builder/sb/sources.py (modified) sb: Add support to get sources and hashses. Mon, 04 Aug 2014 08:09:30 GMT Chris Johns [910081d] * source-builder/sb/download.py (modified) sb: Fix using hashlib's algorithms on python earlier than 2.7. Tue, 29 Jul 2014 06:35:43 GMT Chris Johns [a083b52] * bare/config/devel/expat-2.1.0-1.cfg (modified) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (modified) * rtems/config/net/ntp-4.2.6p5-1.cfg (modified) * rtems/config/tools/rtems-autoconf-2.69-1.cfg (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7.1-1.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (modified) Add checksum support for downloaded files. File download by http, ... Tue, 29 Jul 2014 00:04:55 GMT Chris Johns [c49e500] * source-builder/sb/download.py (modified) * source-builder/sb/log.py (modified) sb: Add visual feedback for http type downloads. Fri, 25 Jul 2014 11:43:50 GMT Chris Johns [fa87409] * source-builder/sb/download.py (modified) sb: Fix error handling. Tue, 13 May 2014 13:26:09 GMT Chris Johns [9a15c40] * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-binutils-patches.cfg (deleted) * rtems/config/rtems-gcc-patches.cfg (deleted) * rtems/config/rtems-gdb-patches.cfg (deleted) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-6.8-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (added) * source-builder/sb/version.py (modified) sb: Implement %source and %patch to manage source and patches. ... Wed, 26 Mar 2014 06:13:25 GMT Chris Johns [8c19df2] * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/options.py (modified) sb: Fix git to clean before updating. Wed, 12 Feb 2014 04:26:07 GMT Chris Johns [587aa5f] * source-builder/sb/download.py (modified) sb: Add patchworks support via the pw://... URL. Tue, 04 Feb 2014 07:23:08 GMT Chris Johns [53b918e] * source-builder/sb/download.py (modified) sb: Fix downloader url parsing and add submodule git support. Split ... Sun, 28 Apr 2013 22:58:01 GMT Chris Johns [0ed876c] * source-builder/sb/download.py (modified) Do not run any download type functions if performing a dry-run. Thu, 25 Apr 2013 05:06:20 GMT Chris Johns [c65b9eb] * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/snapshots/gdb-7.6-branch.mc (modified) * source-builder/sb/download.py (modified) Change the CVS download path to include the module and tag/date. Mon, 22 Apr 2013 12:28:27 GMT Chris Johns [f077b2b] * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (added) * source-builder/sb/build.py (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/download.py (modified) Fixes for CVS to work. Add RTEMS build for sparc/sis. Sun, 21 Apr 2013 11:43:17 GMT Chris Johns [5f44fcd] * source-builder/sb/cvs.py (modified) * source-builder/sb/download.py (modified) Fix CVS downloads. Sun, 21 Apr 2013 08:37:02 GMT Chris Johns [5142bec] * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/execute.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) Refactor the logging support. Sat, 20 Apr 2013 11:51:10 GMT Chris Johns [29a300a] * source-builder/sb/download.py (modified) Fix the ZIP label. Sat, 20 Apr 2013 11:47:28 GMT Chris Johns [4ce931b] * rtems/config/snapshots/gcc-4.7-branch.mc (modified) * rtems/config/snapshots/newlib-head.mc (added) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/download.py (modified) Add CVS download support. These changes complete the CVS download ... Tue, 16 Apr 2013 04:57:27 GMT Chris Johns [f8bdb41] * source-builder/sb/download.py (modified) Minor clean up. Tue, 16 Apr 2013 04:25:34 GMT Chris Johns [649a64c] * source-builder/config/checks.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/download.py (added) * source-builder/sb/git.py (modified) Add download git support. Add support to use a git cloned repo as ...
