# # ChangeLog for source-builder/sb/build.py in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/28/24 12:28:32 Sat, 13 Apr 2013 08:29:30 GMT Chris Johns [0565e1f] * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/macros.py (modified) Add support for snapshot testing. User macro files passed on the ... Sat, 13 Apr 2013 00:41:40 GMT Chris Johns [7ed2835] * source-builder/sb/build.py (modified) Hack in sources and print the macros when tracing. Tue, 09 Apr 2013 03:51:43 GMT Chris Johns [cb12e48] * source-builder/defaults.mc (added) * source-builder/sb-defaults (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/macros.py (added) * source-builder/sb/options.py (moved) * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) Refactor defaults, macros and options. To support building ... Thu, 04 Apr 2013 22:17:47 GMT Chris Johns [efb6688] * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/version.py (added) Support a common verion number for all commands. Wed, 03 Apr 2013 03:31:41 GMT Chris Johns [0add2ea] * source-builder/sb/build.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/defaults.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/windows.py (modified) PR 2108, PR 2109. Add --jobs and --always-clean. Refactor the ... Mon, 01 Apr 2013 04:19:56 GMT Chris Johns [4f26bdb] * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/autoconf-2.69-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/checks.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/dtc-1.2.0.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/defaults.py (modified) * source-builder/sb/execute.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/windows.py (modified) Add Canadian Cross support. Add support to build MinGW tools using ... Fri, 15 Mar 2013 04:26:51 GMT Chris Johns [aa4f8f6] * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) Generate a better error message. Use the package name in the ... Sun, 10 Mar 2013 03:50:55 GMT Chris Johns [ce5e991] * source-builder/sb/build.py (modified) Store downloaded patches in %{_patchdir}. Mon, 04 Mar 2013 07:03:19 GMT Chris Johns [54d76bb] * source-builder/sb/build.py (modified) Provide the main package as a function. Sun, 03 Mar 2013 23:14:57 GMT Chris Johns [0759d98] * source-builder/sb/build.py (modified) * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) Move find_configs to build and fix. Install reports to 'rtems-source- ... Sat, 02 Mar 2013 05:06:59 GMT Chris Johns [a18e76b] * source-builder/sb/build.py (modified) If %setup -c then always create and change into the directory. Thu, 28 Feb 2013 23:01:11 GMT Chris Johns [7618a74c] * source-builder/sb/build.py (modified) Fix %setup now the scripts have been cleaned up. Thu, 28 Feb 2013 05:36:37 GMT Chris Johns [60f70d6] * source-builder/sb/build.py (modified) Fix the %setup error messages. Wed, 27 Feb 2013 05:04:29 GMT Chris Johns [bc71066] * source-builder/sb/build.py (modified) * source-builder/sb/path.py (modified) Fix host paths on Windows. Fri, 22 Feb 2013 23:09:40 GMT Chris Johns [de8f4bf] * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/setbuilder.py (modified) Rename Source Builder to RTEMS Source Builder. Fri, 22 Feb 2013 03:44:51 GMT Chris Johns [ee47d72] * source-builder/sb/build.py (modified) * source-builder/sb/path.py (modified) * source-builder/sb/setbuilder.py (modified) Create tar directory when making build set tar files. Move the ... Thu, 21 Feb 2013 08:03:09 GMT Chris Johns [cafbcc6] * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) Support directly installing. By default the Source Builder now ... Wed, 20 Feb 2013 23:16:52 GMT Chris Johns [1b7e392] * source-builder/sb/build.py (modified) Make the shell cmd path relative on error. Wed, 20 Feb 2013 23:07:04 GMT Chris Johns [e5aa27f0] * source-builder/sb/build.py (modified) * source-builder/sb/defaults.py (modified) Make sources directory if it does not exist. Remove the need to add ... Wed, 20 Feb 2013 03:48:54 GMT Chris Johns [b112284] * source-builder/sb/build.py (modified) Use a relative path for the download notice message. Tue, 19 Feb 2013 08:00:56 GMT Chris Johns [fba1136] * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) Build Sets can reference other build sets. A build set can invoke ... Sun, 17 Feb 2013 00:50:02 GMT Chris Johns [8d7624e] * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) Clean _tmproot. Move config listing to the setbuilder module. Add ... Thu, 14 Feb 2013 07:00:38 GMT Chris Johns [e908afb] * source-builder/sb/build.py (modified) Listing options now handle nested directories. Fri, 01 Feb 2013 01:35:59 GMT Chris Johns [bd8fef3] * source-builder/sb/build.py (modified) Improve mkdir and rmdir. Testing on various hosts shows a few ... Fri, 09 Nov 2012 04:40:06 GMT Chris Johns [e40c4de] * source-builder/sb/build.py (modified) Fix the parsing of the paths for patches. Mon, 05 Nov 2012 23:09:40 GMT Chris Johns [c80560d] * source-builder/.gitignore (moved) * source-builder/config/autoconf-2-1.cfg (moved) * source-builder/config/autoconf-2.68-1.cfg (moved) * source-builder/config/autoconf-2.69-1.cfg (moved) * source-builder/config/autoconf-internal-2.68-1.cfg (moved) * source-builder/config/automake-1-1.cfg (moved) * source-builder/config/automake-1.12-1.cfg (moved) * source-builder/config/automake-internal-1.12-1.cfg (moved) * source-builder/config/base.cfg (moved) * source-builder/config/binutils-2-1.cfg (moved) * source-builder/config/binutils-2.22-1.cfg (moved) * source-builder/config/checks.cfg (moved) * source-builder/config/expat-2-1.cfg (moved) * source-builder/config/expat-2.1.0-1.cfg (moved) * source-builder/config/gcc-4.4-1.cfg (moved) * source-builder/config/gcc-4.6-1.cfg (moved) * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (moved) * source-builder/config/gdb-7-1.cfg (moved) * source-builder/config/gdb-7.5-1.cfg (moved) * source-builder/config/gnu-tools-4.6.bset (moved) * source-builder/config/libusb-1-1.cfg (moved) * source-builder/config/libusb-1.0.9-1.cfg (moved) * source-builder/config/m4-1-1.cfg (moved) * source-builder/config/m4-1.4.16-1.cfg (moved) * source-builder/config/texane-stlink-1.cfg (moved) * source-builder/doc/.gitignore (moved) * source-builder/doc/images/icons/README (moved) * source-builder/doc/images/icons/callouts/1.png (moved) * source-builder/doc/images/icons/callouts/10.png (moved) * source-builder/doc/images/icons/callouts/11.png (moved) * source-builder/doc/images/icons/callouts/12.png (moved) * source-builder/doc/images/icons/callouts/13.png (moved) * source-builder/doc/images/icons/callouts/14.png (moved) * source-builder/doc/images/icons/callouts/15.png (moved) * source-builder/doc/images/icons/callouts/2.png (moved) * source-builder/doc/images/icons/callouts/3.png (moved) * source-builder/doc/images/icons/callouts/4.png (moved) * source-builder/doc/images/icons/callouts/5.png (moved) * source-builder/doc/images/icons/callouts/6.png (moved) * source-builder/doc/images/icons/callouts/7.png (moved) * source-builder/doc/images/icons/callouts/8.png (moved) * source-builder/doc/images/icons/callouts/9.png (moved) * source-builder/doc/images/icons/caution.png (moved) * source-builder/doc/images/icons/example.png (moved) * source-builder/doc/images/icons/home.png (moved) * source-builder/doc/images/icons/important.png (moved) * source-builder/doc/images/icons/next.png (moved) * source-builder/doc/images/icons/note.png (moved) * source-builder/doc/images/icons/prev.png (moved) * source-builder/doc/images/icons/tip.png (moved) * source-builder/doc/images/icons/up.png (moved) * source-builder/doc/images/icons/warning.png (moved) * source-builder/doc/images/rtemswhitebg.jpg (moved) * source-builder/doc/source-builder.txt (moved) * source-builder/doc/wscript (moved) * source-builder/patches/texane-stlink-3494c11-1.diff (moved) * source-builder/patches/texane-stlink-3494c11-2.diff (moved) * source-builder/sb-builder (moved) * source-builder/sb-check (moved) * source-builder/sb-set-builder (moved) * source-builder/sb/build.py (moved) * source-builder/sb/check.py (moved) * source-builder/sb/config.py (moved) * source-builder/sb/darwin.py (moved) * source-builder/sb/defaults.py (moved) * source-builder/sb/error.py (moved) * source-builder/sb/execute.py (moved) * source-builder/sb/freebsd.py (moved) * source-builder/sb/linux.py (moved) * source-builder/sb/log.py (moved) * source-builder/sb/path.py (moved) * source-builder/sb/setbuilder.py (moved) * source-builder/sb/windows.py (moved) Move into the source-builder tree.
