# # ChangeLog for source-builder/config in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 06/16/24 02:37:25 Tue, 16 Apr 2013 04:25:34 GMT Chris Johns [649a64c] * source-builder/config/checks.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/download.py (added) * source-builder/sb/git.py (modified) Add download git support. Add support to use a git cloned repo as ... Mon, 15 Apr 2013 03:26:36 GMT Chris Johns [b8ee74d] * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/config.py (modified) Add a %testing section to the configuration files. Mon, 15 Apr 2013 01:45:00 GMT Chris Johns [ff91af2] * source-builder/config/gdb-7-1.cfg (modified) * source-builder/defaults.mc (modified) Add _forced_static to the default. This is used in the ... Sat, 13 Apr 2013 00:42:04 GMT Chris Johns [9384fba] * source-builder/config/gcc-4.7-1.cfg (modified) Add setecting a snapshot package. Wed, 10 Apr 2013 06:07:21 GMT Chris Johns [7e48e8f] * source-builder/config/gdb-7-1.cfg (modified) Make the expat library static to make relocatable. Mon, 08 Apr 2013 23:25:56 GMT Chris Johns [530a938] * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (modified) * source-builder/config/gcc-4.7-newlib-1.20-1.cfg (modified) Add the GCC version message. Tue, 02 Apr 2013 09:53:32 GMT Chris Johns [8dedfc7] * source-builder/config/gcc-4.8-1.cfg (modified) PR 2106. Fixed the include name. Mon, 01 Apr 2013 23:17:57 GMT Chris Johns [2b069dc] * source-builder/config/gcc-common-1.cfg (modified) Merge back in the multi-patch support to the gcc common configuration. Mon, 01 Apr 2013 04:19:56 GMT Chris Johns [4f26bdb] * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/autoconf-2.69-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/checks.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/dtc-1.2.0.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/defaults.py (modified) * source-builder/sb/execute.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/windows.py (modified) Add Canadian Cross support. Add support to build MinGW tools using ... Mon, 18 Mar 2013 14:00:01 GMT Dhananjay Balan [97c4323] * source-builder/config/versions.cfg (added) Add version configuration Fri, 15 Mar 2013 04:33:59 GMT Chris Johns [3643c48] * rtems/config/4.9/rtems-i386.bset (added) * rtems/config/4.9/rtems-sparc.bset (added) * rtems/config/rtems-4.9-base.bset (added) * rtems/config/tools/rtems-binutils-2.19.1-1.cfg (added) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (added) * rtems/config/tools/rtems-gdb-6.8-1.cfg (added) * source-builder/config/gcc-4.3-1.cfg (added) * source-builder/config/gdb-6-1.cfg (added) Add RTEMS 4.9 support for i386 and SPARC. Fri, 15 Mar 2013 04:28:11 GMT Chris Johns [e39d5e2] * source-builder/config/gcc-4.7-1.cfg (modified) Allow a build set to provide the source0 path. Mon, 11 Mar 2013 22:22:40 GMT Chris Johns [ce4759e] * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) Add build set patch option support. Mon, 11 Mar 2013 22:22:01 GMT Chris Johns [a420a64] * source-builder/config/gcc-4.7-1.cfg (modified) Fix the patch opts logic typo. Mon, 11 Mar 2013 02:55:56 GMT Chris Johns [3bab09c] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/rtems-gcc-patches.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) Add support for build set patch options. Remove the hard coded ... Fri, 08 Mar 2013 21:12:47 GMT Chris Johns [8301afa] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (added) * source-builder/config/gcc-4.5-1.cfg (added) Switch LM32 to gcc-4.5.3. This is the reported known working tool ... Tue, 05 Mar 2013 08:43:43 GMT Chris Johns [0606a65] * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/sb/setbuilder.py (modified) Clean path when building autoconf and automake. Autoconf hard codes ... Mon, 04 Mar 2013 07:02:49 GMT Chris Johns [9867b1c] * source-builder/config/gcc-4.7-1.cfg (modified) Update the summary to include version number of parts. Mon, 04 Mar 2013 07:02:06 GMT Chris Johns [71329cd] * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) Fix conditional logic. Thu, 28 Feb 2013 05:37:27 GMT Chris Johns [bcae849] * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/texane-stlink-1.cfg (modified) Cleanup the %setup flags Sun, 24 Feb 2013 07:17:27 GMT Chris Johns [d5fa35c] * source-builder/config/automake-1.12.2-1.cfg (added) RTEMS uses 1.12.2. Wed, 20 Feb 2013 05:39:41 GMT Chris Johns [4f5321f] * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/sb/defaults.py (modified) Fix support for GCC being build as C++. Wed, 20 Feb 2013 03:46:51 GMT Chris Johns [a32dcbd] * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (added) * rtems/config/unstable/4.11/rtems-arm.bset (added) * source-builder/config/gcc-4.8-1.cfg (added) Add unstable. Add a tree of unstable configurations to track recent ... Wed, 20 Feb 2013 00:18:10 GMT Chris Johns [9f04b64] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/patches/gcc-4.7-arm-to-eabi-20120511.diff (added) * source-builder/config/gcc-4.7-1.cfg (modified) Architecture arm-rtems4.11 uses EABI. Switch the arm-rtems4.11 to ... Sun, 17 Feb 2013 00:49:41 GMT Chris Johns [ebc505c] * source-builder/config/expat-2-1.cfg (modified) Clean up the configure command for expat. Thu, 14 Feb 2013 05:14:38 GMT Chris Johns [b1202fc] * rtems/config/4.11/rtems-moxie.bset (modified) * source-builder/config/dtc-1-1.cfg (added) * source-builder/config/dtc-1.2.0.cfg (added) Moxie GDB DTC support added The Moxie GDB simulator uses the DTC ... Thu, 14 Feb 2013 01:32:03 GMT Chris Johns [87fc7e0] * rtems/config/4.11/rtems-moxie.bset (added) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/patches/binutils-2.22-rtems4.11-moxie-20130214.diff (added) * rtems/patches/gdb-7.5.1-rtems4.11-moxie-20130214.diff (added) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) Add Moxie support. Binutils and the compiler build how-ever gdb ... Wed, 13 Feb 2013 00:30:47 GMT Chris Johns [d963553b] * rtems/config/4.11/rtems-arm.bset (moved) * rtems/config/4.11/rtems-avr.bset (added) * rtems/config/4.11/rtems-bfin.bset (added) * rtems/config/4.11/rtems-h8300.bset (added) * rtems/config/4.11/rtems-m32c.bset (added) * rtems/config/4.11/rtems-m32r.bset (added) * rtems/config/4.11/rtems-m68k.bset (added) * rtems/config/4.11/rtems-mips.bset (added) * rtems/config/4.11/rtems-nios2.bset (moved) * rtems/config/4.11/rtems-sparc.bset (moved) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (moved) * rtems/config/tools/rtems-binutils-2.22-1.cfg (moved) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (moved) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (moved) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (moved) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (moved) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (moved) * rtems/config/tools/rtems-gdb-7.5-1.cfg (moved) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (moved) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (moved) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (moved) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (moved) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/sb/config.py (modified) * source-builder/sb/defaults.py (modified) Restructure RTEMS Config Files Add arch build files. This allows ... Tue, 12 Feb 2013 03:12:40 GMT Chris Johns [aa46b9c] * rtems/config/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) Fixes to the NIOS2 build on FreeBSD. Tue, 12 Feb 2013 00:46:29 GMT Chris Johns [0328944] * rtems/config/rtems-nios2-4.11.bset (added) * rtems/config/rtems-nios2-binutils-2.20-1.cfg (added) * rtems/config/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (added) * rtems/config/rtems-nios2-gdb-7.0-1.cfg (added) * rtems/patches/nios2-binutils-2.20-rtems-20110703.diff (added) * rtems/patches/nios2-gcc-4.1-rtems-20110818.diff (added) * rtems/patches/nios2-newlib-1.19.0-rtems-20110720.diff (added) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) NIOS2 Tools based on Altera's 4.11 tool set. Add support for ... Thu, 07 Feb 2013 23:06:16 GMT Chris Johns [6a2003e] * rtems/config/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) Add support to turn on the "obsolete" arm-rtems4.11 target. This ... Fri, 01 Feb 2013 01:39:04 GMT Chris Johns [bc97729] * source-builder/config/binutils-2-1.cfg (modified) Optionally enable deterministic archives. Fri, 01 Feb 2013 01:38:26 GMT Chris Johns [3142708] * source-builder/config/gnu-tools-4.6.bset (modified) Build the expat library. Fri, 30 Nov 2012 06:13:18 GMT Chris Johns [d34a0a9] * rtems/config/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (added) * rtems/config/rtems-gdb-7.5.1-1.cfg (added) * rtems/config/rtems-tools-4.11-unstable.bset (added) * rtems/patches/gcc-4.7.2-rtems4.11-20121026.diff (added) * source-builder/config/gcc-4.7-1.cfg (added) * source-builder/config/gcc-4.7-newlib-1.20-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) Add rtems-4.11 support for 4.7.2. Wed, 14 Nov 2012 02:45:52 GMT Chris Johns [0a48c8a] * source-builder/config/gdb-7-1.cfg (modified) Remove the _bindir from the path as it breaks on MacOS with python ... Wed, 14 Nov 2012 02:45:01 GMT Chris Johns [40bab3f] * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (modified) Use GMP 5.0.5 and so avoid the flex/m4 issue on Linux. Fri, 09 Nov 2012 05:42:41 GMT Chris Johns [08f489f] * source-builder/config/texane-stlink-1.cfg (modified) Fix the install point in the STLink configuration. Fri, 09 Nov 2012 04:39:39 GMT Chris Johns [ab18d1a] * source-builder/config/texane-stlink-1.cfg (modified) Version 2 of the patch has --pipe support. Mon, 05 Nov 2012 23:09:40 GMT Chris Johns [c80560d] * source-builder/.gitignore (moved) * source-builder/config/autoconf-2-1.cfg (moved) * source-builder/config/autoconf-2.68-1.cfg (moved) * source-builder/config/autoconf-2.69-1.cfg (moved) * source-builder/config/autoconf-internal-2.68-1.cfg (moved) * source-builder/config/automake-1-1.cfg (moved) * source-builder/config/automake-1.12-1.cfg (moved) * source-builder/config/automake-internal-1.12-1.cfg (moved) * source-builder/config/base.cfg (moved) * source-builder/config/binutils-2-1.cfg (moved) * source-builder/config/binutils-2.22-1.cfg (moved) * source-builder/config/checks.cfg (moved) * source-builder/config/expat-2-1.cfg (moved) * source-builder/config/expat-2.1.0-1.cfg (moved) * source-builder/config/gcc-4.4-1.cfg (moved) * source-builder/config/gcc-4.6-1.cfg (moved) * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (moved) * source-builder/config/gdb-7-1.cfg (moved) * source-builder/config/gdb-7.5-1.cfg (moved) * source-builder/config/gnu-tools-4.6.bset (moved) * source-builder/config/libusb-1-1.cfg (moved) * source-builder/config/libusb-1.0.9-1.cfg (moved) * source-builder/config/m4-1-1.cfg (moved) * source-builder/config/m4-1.4.16-1.cfg (moved) * source-builder/config/texane-stlink-1.cfg (moved) * source-builder/doc/.gitignore (moved) * source-builder/doc/images/icons/README (moved) * source-builder/doc/images/icons/callouts/1.png (moved) * source-builder/doc/images/icons/callouts/10.png (moved) * source-builder/doc/images/icons/callouts/11.png (moved) * source-builder/doc/images/icons/callouts/12.png (moved) * source-builder/doc/images/icons/callouts/13.png (moved) * source-builder/doc/images/icons/callouts/14.png (moved) * source-builder/doc/images/icons/callouts/15.png (moved) * source-builder/doc/images/icons/callouts/2.png (moved) * source-builder/doc/images/icons/callouts/3.png (moved) * source-builder/doc/images/icons/callouts/4.png (moved) * source-builder/doc/images/icons/callouts/5.png (moved) * source-builder/doc/images/icons/callouts/6.png (moved) * source-builder/doc/images/icons/callouts/7.png (moved) * source-builder/doc/images/icons/callouts/8.png (moved) * source-builder/doc/images/icons/callouts/9.png (moved) * source-builder/doc/images/icons/caution.png (moved) * source-builder/doc/images/icons/example.png (moved) * source-builder/doc/images/icons/home.png (moved) * source-builder/doc/images/icons/important.png (moved) * source-builder/doc/images/icons/next.png (moved) * source-builder/doc/images/icons/note.png (moved) * source-builder/doc/images/icons/prev.png (moved) * source-builder/doc/images/icons/tip.png (moved) * source-builder/doc/images/icons/up.png (moved) * source-builder/doc/images/icons/warning.png (moved) * source-builder/doc/images/rtemswhitebg.jpg (moved) * source-builder/doc/source-builder.txt (moved) * source-builder/doc/wscript (moved) * source-builder/patches/texane-stlink-3494c11-1.diff (moved) * source-builder/patches/texane-stlink-3494c11-2.diff (moved) * source-builder/sb-builder (moved) * source-builder/sb-check (moved) * source-builder/sb-set-builder (moved) * source-builder/sb/build.py (moved) * source-builder/sb/check.py (moved) * source-builder/sb/config.py (moved) * source-builder/sb/darwin.py (moved) * source-builder/sb/defaults.py (moved) * source-builder/sb/error.py (moved) * source-builder/sb/execute.py (moved) * source-builder/sb/freebsd.py (moved) * source-builder/sb/linux.py (moved) * source-builder/sb/log.py (moved) * source-builder/sb/path.py (moved) * source-builder/sb/setbuilder.py (moved) * source-builder/sb/windows.py (moved) Move into the source-builder tree.
