# # ChangeLog for rtems in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/27/24 17:14:18 Sun, 15 Sep 2019 22:21:29 GMT Chris Johns [5f8841d] * rtems/config/tools/rtems-gcc-9.2.0-newlib-6661a67.cfg (modified) darwin: Update gcc-9.2.0-newlib-6661a67 to include sed and darwin patches Tue, 10 Sep 2019 10:51:58 GMT Sebastian Huber [2ac9bc9] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5: Update RTEMS tools Fix rtems-record-lttng issue on macOS. Tue, 10 Sep 2019 09:09:07 GMT Sebastian Huber [0340c8a] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5: Update RTEMS tools Fix rtems-record-lttng issues on Windows. ... Mon, 09 Sep 2019 11:07:38 GMT Sebastian Huber [7ca09f6] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 29 Aug 2019 23:12:23 GMT Chris Johns [b45df48] * rtems/config/5/bsps/xilinx_zynq_zedboard.bset (added) 5/bsps: Add xilinx_zynq_zedboard BSP Thu, 29 Aug 2019 23:12:16 GMT Chris Johns [8debbd3] * rtems/config/5/bsps/raspberrypi2.bset (added) 5/bsps: Add raspberrypi2 BSP Thu, 29 Aug 2019 03:30:54 GMT Chris Johns [1c5e45c] * rtems/config/rtems-bsp.cfg (modified) rtems/bsps: Add machine flags to the linker flags. - Some packages ... Tue, 27 Aug 2019 11:40:05 GMT Chris Johns [2e37160] * rtems/config/tools/rtems-libbsd-5.cfg (modified) 5/libbsd: Update to the head of master Tue, 27 Aug 2019 11:29:55 GMT Chris Johns [6bfb9c1] * rtems/config/tools/rtems-kernel-5.cfg (modified) 5/kernel: Update to the head of master Tue, 27 Aug 2019 11:29:35 GMT Chris Johns [6f9be2d] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/tools: Update to the head of master Tue, 27 Aug 2019 04:06:02 GMT Chris Johns [cdd5aef] * rtems/config/5/bsps/beagleboneblack.bset (modified) * source-builder/sb/setbuilder.py (modified) sb: Send only one mail when building a BSP - Add support to email a ... Mon, 26 Aug 2019 05:09:07 GMT Sebastian Huber [d7f11a7] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 21 Aug 2019 07:24:51 GMT Jiri Gaisler [a0fff47] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-sparc.bset (modified) * rtems/config/tools/rtems-gdb-8.3-1.cfg (added) Add gdb-8.3 as default debugger * Minor update from 8.2.1 ... Mon, 12 Aug 2019 11:03:52 GMT Sebastian Huber [5a0dba7] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-9.2.0-newlib-6661a67.cfg (added) 5: Update to GCC 9.2.0 release Thu, 08 Aug 2019 20:20:39 GMT Jiri Gaisler [abc5401] * rtems/config/tools/rtems-gdb-8.2.1-1.cfg (modified) Disable built-in sis in gdb. * Avoid building problems on ... Fri, 09 Aug 2019 06:43:38 GMT Sebastian Huber [187344d] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 02 Aug 2019 17:26:07 GMT Joel Sherrill [29fab05] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-9.1.0-newlib-6661a67.cfg (added) * rtems/config/tools/rtems-gcc-fb371a33fa6-newlib-6661a67.cfg (added) Update Newlib to pick up ndbm addition (newlib=6661a67) Wed, 31 Jul 2019 05:06:05 GMT Sebastian Huber [be90fb8] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 25 Jul 2019 05:51:24 GMT Sebastian Huber [639eed3] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 25 Jul 2019 05:48:10 GMT Sebastian Huber [f79e33f3] * rtems/config/6/rtems-base.bset (modified) 6: Fix install root Wed, 24 Jul 2019 14:06:39 GMT Sebastian Huber [0e59b48] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 23 Jul 2019 11:47:53 GMT Chris Johns [5eb4282] * bare/config/devel/sis-2-1.cfg (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-sparc.bset (modified) * source-builder/config/sis-2-1.cfg (modified) devel/sis: Fix building the SIS on FreeBSD - Update to SIS 2.17 ... Sun, 14 Jul 2019 05:11:46 GMT Chris Johns [831ae05] * rtems/config/5/bsps/beagleboneblack.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/rtems-bsp.cfg (modified) * rtems/config/tools/rtems-kernel-5.cfg (modified) * rtems/config/tools/rtems-kernel-common.cfg (modified) * source-builder/config/libpng-1.cfg (modified) * source-builder/config/libtiff-1.cfg (modified) * source-builder/config/lwip-1.cfg (modified) * source-builder/config/microwindows-1.cfg (modified) * source-builder/config/nxlib-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/setbuilder.py (modified) rtems/bsp: Build packages for the beagle BSP. Closes #3769 Sun, 14 Jul 2019 04:03:06 GMT Chris Johns [b1c2cb4] * rtems/config/5/rtems-libbsd.bset (modified) * rtems/config/rtems-bsp.cfg (modified) * rtems/config/tools/rtems-libbsd-common.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/shell.py (added) sb/setbuilder: Support staging of build set build before installing. ... Thu, 11 Jul 2019 22:25:15 GMT Chris Johns [8db33fb] * rtems/config/5/bsps/beagleboneblack.bset (added) * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-kernel.bset (added) * rtems/config/5/rtems-libbsd.bset (added) * rtems/config/rtems-base.bset (modified) * rtems/config/rtems-bsp.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-5.cfg (modified) * rtems/config/tools/rtems-kernel-common.cfg (added) * rtems/config/tools/rtems-libbsd-5.cfg (added) * rtems/config/tools/rtems-libbsd-common.cfg (added) * rtems/config/tools/rtems-tools-common-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) rtems: Add kernel, libbsd and BSP building as packages. Sat, 06 Jul 2019 09:20:09 GMT Chris Johns [c799e04] * rtems/config/5/rtems-packages.bset (added) * rtems/config/databases/sqlite-3.8.8.1-1.cfg (modified) * rtems/config/ftp/curl-7.65.1-1.cfg (added) * rtems/config/ftp/curl.bset (added) * rtems/config/graphics/freetype-2.4.10-1.cfg (modified) * rtems/config/graphics/graphics-all.bset (modified) * rtems/config/graphics/libjpeg-9a-1.cfg (modified) * rtems/config/graphics/libpng-1.6.37-1.cfg (added) * rtems/config/graphics/libpng.bset (modified) * rtems/config/graphics/libtiff-4.0.10-1.cfg (added) * rtems/config/graphics/libtiff-4.0.6-1.cfg (modified) * rtems/config/graphics/libtiff.bset (modified) * rtems/config/graphics/microwindows-0.93-dev-1.cfg (modified) * rtems/config/graphics/t1lib-5.1.2-1.cfg (modified) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (modified) * rtems/config/net/lwip-1-1.cfg (modified) * rtems/config/net/ntp-4.2.6p5-1.cfg (modified) * rtems/config/net/protobuf-2.6.1-1.cfg (modified) * rtems/config/rtems-bsp.cfg (modified) * source-builder/config/curl-1.cfg (added) * source-builder/config/libpng-1.cfg (modified) * source-builder/config/libtiff-1.cfg (modified) * source-builder/config/lwip-1.cfg (modified) * source-builder/config/microwindows-1.cfg (modified) * source-builder/config/net-snmp-5-1.cfg (modified) * source-builder/config/t1lib-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/options.py (modified) * source-builder/sb/rtems-build-dep (modified) * source-builder/sb/setbuilder.py (modified) 5/packages: Add curl and update all packages with RTEMS 5 and LibBSD ... Wed, 17 Jul 2019 11:46:02 GMT Sebastian Huber [bcfb210] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 10 Jul 2019 06:58:12 GMT Sebastian Huber [18d4d29] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 01 Jul 2019 06:50:46 GMT Sebastian Huber [15ef359] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 26 Jun 2019 07:55:37 GMT Sebastian Huber [af4d435] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 25 Jun 2019 01:37:10 GMT Chris Johns [c149b7f] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/rtems-tools: Update RTEMS tools. Wed, 19 Jun 2019 08:40:46 GMT Sebastian Huber [e8f1820] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 14 Jun 2019 21:43:43 GMT Jiri Gaisler [9e8e023] * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-sparc.bset (modified) Build standalone sis for SPARC and RISC-V targets Thu, 13 Jun 2019 09:10:52 GMT Sebastian Huber [2198d6b] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 12 Jun 2019 00:14:13 GMT Chris Johns [bb1a9b8] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/rtems-tools: Update RTEMS tools. Wed, 05 Jun 2019 09:02:52 GMT Sebastian Huber [e047d64] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-9.1.0-newlib-5c2a3661c.cfg (added) * rtems/config/tools/rtems-gcc-fb371a33fa6-newlib-5c2a3661c.cfg (added) 5: Update Newlib Pick up FreeBSD compatiblity changes. Wed, 05 Jun 2019 05:35:00 GMT Sebastian Huber [e59abc9] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 03 Jun 2019 08:53:57 GMT Sebastian Huber [e809de5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 31 May 2019 08:14:03 GMT Sebastian Huber [1db8e0c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 23 May 2019 06:10:11 GMT Sebastian Huber [3faa5ab] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 16 May 2019 08:51:28 GMT Sebastian Huber [c1431be] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 14 May 2019 05:41:21 GMT Sebastian Huber [7a80d6c] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-9.1.0-newlib-1d35a003f.cfg (added) 5: Update GCC 9 baseline to GCC 9.1.0 release Tue, 14 May 2019 05:27:11 GMT Sebastian Huber [72271f6] * rtems/config/5/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-fb371a33fa6-newlib-1d35a003f.cfg (added) 5: Update GCC 7 baseline Pick up ARM multilib changes to address ... Mon, 06 May 2019 06:59:58 GMT Sebastian Huber [c80ab5b] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Sun, 05 May 2019 04:02:18 GMT Chris Johns [8e5a201] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/rtems-tools: Update RTEMS tools Fri, 12 Apr 2019 07:26:40 GMT Sebastian Huber [780a2cf] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 02 Apr 2019 09:25:59 GMT Sebastian Huber [9a3e12e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 26 Mar 2019 06:09:20 GMT Sebastian Huber [cbbbc30] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 14 Mar 2019 18:19:28 GMT Sebastian Huber [9c825f0] * rtems/config/5/rtems-x86_64.bset (modified) 5: Use GCC 9 for x86_64 This should fix BSP build issues due to ... Thu, 07 Mar 2019 13:31:18 GMT Sebastian Huber [e0aec65] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 Feb 2019 12:36:44 GMT Sebastian Huber [2e65068] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Sun, 03 Mar 2019 09:07:49 GMT Jiri Gaisler [67a51a4] * rtems/config/tools/rtems-gdb-8.2.1-1.cfg (modified) gdb: update to sis 2.13 Tue, 19 Feb 2019 09:09:36 GMT Sebastian Huber [3824139] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg (added) * rtems/config/tools/rtems-gcc-89338f04ee3-newlib-1d35a003f.cfg (added) 5: Update Newlib Pick up register_t changes. Sat, 09 Feb 2019 17:46:04 GMT Chris Johns [7223bef] * rtems/config/tools/rtems-gcc-7.4.0-newlib-3e24fbf6f.cfg (modified) rtems/5: Add the required MacOS APFS workround for building libstdc++. Fri, 08 Feb 2019 09:22:51 GMT Sebastian Huber [ee40e0b] * rtems/config/tools/rtems-gdb-8.2.1-1.cfg (modified) 5: Add GDB SIS patch Update #3460. Thu, 07 Feb 2019 06:56:06 GMT Sebastian Huber [c3faacf] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-89338f04ee3-newlib-3e24fbf6f.cfg (added) 5: Update or1k and riscv Newlib Tue, 05 Feb 2019 09:29:44 GMT Sebastian Huber [c41b9d0] * rtems/config/5/rtems-or1k.bset (modified) 5: Use GDB 8.2.1 for or1k Tue, 05 Feb 2019 04:23:53 GMT Chris Johns [a273a7c] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-sparc.bset (modified) * rtems/config/tools/rtems-gdb-8.2.1-1.cfg (added) rtems/5: Update to gdb-8.2.1 with Jiri's SIS and RISCV patches. Mon, 04 Feb 2019 07:37:54 GMT Sebastian Huber [f75cf6d] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-sparc.bset (modified) * rtems/config/tools/rtems-binutils-2.32.cfg (added) 5: Update to Binutils 2.32 Fri, 01 Feb 2019 09:49:26 GMT Sebastian Huber [6eab3c9] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-sparc.bset (modified) * rtems/config/tools/rtems-gcc-4c0c3d1029e79b6709b43fed8c5a5944f245516d-newlib-3e24fbf6f.cfg (added) * rtems/config/tools/rtems-gcc-7.4.0-newlib-3e24fbf6f.cfg (added) 5: Update Newlib Pick up scandir() fixes. Sat, 26 Jan 2019 10:27:15 GMT Jiri Gaisler [a9142bc] * rtems/config/5/rtems-sparc.bset (modified) * rtems/config/tools/rtems-gdb-ce73f310150418a9a1625ab60a527d959096a9e2.cfg (modified) * rtems/config/tools/rtems-tools-5-1.cfg (modified) gdb: add RISC-V and code coverage support to sis Mon, 28 Jan 2019 12:09:43 GMT Sebastian Huber [c5ebf98] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-89338f04ee3-newlib-3b2133317.cfg (added) 5: Update riscv and or1k GCC/Newlib Reduce Git hash length to fix ... Fri, 25 Jan 2019 09:04:51 GMT Sebastian Huber [376edee] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 23 Jan 2019 12:41:30 GMT Sebastian Huber [f07504d] * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-6-1.cfg (modified) * source-builder/config/gcc-7-1.cfg (modified) * source-builder/config/gcc-7.2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/defaults.mc (modified) Use HTTPS instead of FTP FTP is an outdated protocol and blocked by ... Tue, 22 Jan 2019 06:18:21 GMT Chris Johns [34a9932] * rtems/config/rtems-version.bset (modified) * source-builder/sb/options.py (modified) sb: Fix the RTEMS options after strict option checking was added. Fri, 18 Jan 2019 09:00:34 GMT Sebastian Huber [0bb29a3] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Pick up a fix for Ada. Thu, 17 Jan 2019 14:31:34 GMT Sebastian Huber [1dfc4dd] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Use short Git hashes to avoid ... Wed, 16 Jan 2019 08:42:28 GMT Sebastian Huber [8b0e78a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 10 Jan 2019 08:40:47 GMT Sebastian Huber [f101ea1] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 03 Jan 2019 12:59:15 GMT Sebastian Huber [40ae056] * rtems/config/6/rtems-aarch64.bset (added) * rtems/config/6/rtems-all.bset (added) * rtems/config/6/rtems-arm.bset (added) * rtems/config/6/rtems-autotools-base.bset (added) * rtems/config/6/rtems-autotools-internal.bset (added) * rtems/config/6/rtems-autotools.bset (added) * rtems/config/6/rtems-base.bset (added) * rtems/config/6/rtems-bfin.bset (added) * rtems/config/6/rtems-default.bset (added) * rtems/config/6/rtems-epiphany.bset (added) * rtems/config/6/rtems-i386.bset (added) * rtems/config/6/rtems-lm32.bset (added) * rtems/config/6/rtems-m68k.bset (added) * rtems/config/6/rtems-microblaze.bset (added) * rtems/config/6/rtems-mips.bset (added) * rtems/config/6/rtems-moxie.bset (added) * rtems/config/6/rtems-nios2.bset (added) * rtems/config/6/rtems-or1k.bset (added) * rtems/config/6/rtems-powerpc.bset (added) * rtems/config/6/rtems-riscv.bset (added) * rtems/config/6/rtems-sh.bset (added) * rtems/config/6/rtems-sparc.bset (added) * rtems/config/6/rtems-sparc64.bset (added) * rtems/config/6/rtems-v850.bset (added) * rtems/config/6/rtems-x86_64.bset (added) * rtems/config/tools/rtems-binutils-head.cfg (added) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (added) * rtems/config/tools/rtems-gdb-head.cfg (added) * rtems/config/tools/rtems-mipstx39-gdb-head.cfg (added) 6: Add unstable RTEMS 6 tool chain Wed, 19 Dec 2018 11:26:01 GMT Christian Mauderer [2fac55d] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/rtems-tools: Update RTEMS tools Picks up the new waf in ... Fri, 21 Dec 2018 06:51:39 GMT Sebastian Huber [78dc8cd] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4c0c3d1029e79b6709b43fed8c5a5944f245516d-newlib-dc6e94551f09d3a983afd571478d63a09d6f66fa.cfg (added) * rtems/config/tools/rtems-gcc-7.4.0-newlib-dc6e94551f09d3a983afd571478d63a09d6f66fa.cfg (added) 5: Update Newlib Pick up FreeBSD compatibility improvements. ... Mon, 17 Dec 2018 06:23:22 GMT Jiri Gaisler [96673d7] * rtems/config/tools/rtems-gdb-8.0.1-1.cfg (modified) 5: Add SMP support to SIS Update #3460. Tue, 11 Dec 2018 13:17:09 GMT Sebastian Huber [f80abf0] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4c0c3d1029e79b6709b43fed8c5a5944f245516d-newlib-df6915f029ac9acd2b479ea898388cbd7dda4974.cfg (added) * rtems/config/tools/rtems-gcc-7.4.0-newlib-df6915f029ac9acd2b479ea898388cbd7dda4974.cfg (added) 5: Update Newlib Pick up updates from FreeBSD. ... Thu, 13 Dec 2018 10:33:47 GMT Sebastian Huber [258129e] * rtems/config/5/rtems-x86_64.bset (modified) 5: Fix x86_64 GCC 7.4.0 build Update #3384. Tue, 11 Dec 2018 07:38:49 GMT Sebastian Huber [b4e80fb] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-gcc-7.4.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg (added) 5: Update GCC 7.3.0 to 7.4.0 Update #3384. Thu, 29 Nov 2018 00:08:41 GMT Chris Johns [c1d56b4] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/rtems-tools: Bump the version to pick up the Windows fixes. Sat, 17 Nov 2018 01:44:27 GMT Chris Johns [77a0075] * rtems/config/tools/rtems-tools-5-1.cfg (modified) tools-5-1.cfg: Bump to latest - Fix efltools on ARM 64bit - Fixes ... Mon, 12 Nov 2018 23:30:38 GMT Joel Sherrill [384ff19] * rtems/config/tools/rtems-gdb-8.0.1-1.cfg (modified) rtems-gdb-8.0.1-1.cfg: Correct previous commit. Updates #3576. Mon, 12 Nov 2018 06:32:20 GMT Sebastian Huber [8241563] * rtems/config/5/rtems-or1k.bset (modified) 5: Use latest Binutils and GCC for or1k Update #3602. Mon, 12 Nov 2018 06:31:46 GMT Sebastian Huber [40c4642] * rtems/config/5/rtems-riscv.bset (modified) 5: Build GDB earlier for riscv Be in line with default targets. Mon, 12 Nov 2018 06:26:38 GMT Sebastian Huber [55aff90] * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4c0c3d1029e79b6709b43fed8c5a5944f245516d-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg (added) 5: Use latest GCC for riscv This is a preparation to update or1k to ... Mon, 12 Nov 2018 06:17:58 GMT Sebastian Huber [c5ad16a] * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-binutils-417e50dbcfd4b8dd699f48df5ac9b9a733fd80e2.cfg (added) 5: Use latest Binutils for riscv This is a preparation to update ... Mon, 12 Nov 2018 06:08:50 GMT Sebastian Huber [d665fdb] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5: Update RTEMS tools Pick up m32c removal. Update #3599. Wed, 24 Oct 2018 21:20:05 GMT Joel Sherrill [84a94f7] * rtems/config/tools/rtems-gdb-8.0.1-1.cfg (modified) * source-builder/sb/windows.py (modified) rtems-gdb-8.0.1-1.cfg: Add Cygwin patch for ncurses not termcap ... Fri, 09 Nov 2018 07:42:15 GMT Sebastian Huber [25a5f24] * rtems/config/5/rtems-all.bset (modified) * rtems/config/5/rtems-m32c.bset (deleted) * rtems/config/5/rtems-tier-3.bset (modified) m32c: Remove this build set Update #3599. Thu, 08 Nov 2018 13:09:59 GMT Sebastian Huber [30da0c7] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg (added) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg (added) * rtems/config/tools/rtems-gcc-7.3.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg (added) 5: Update Newlib Fix v850 target issue related to the new ... Mon, 05 Nov 2018 07:15:22 GMT Sebastian Huber [9955b1a] * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b.cfg (modified) * rtems/config/tools/rtems-gcc-7.3.0-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b.cfg (modified) * source-builder/config/gcc-9.cfg (added) 5: Use in-tree ISL libraries for GCC Close #3577. Mon, 22 Oct 2018 00:59:10 GMT Chris Johns [96c414c] * bare/config/devel/texane-stlink-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-tools-common-1.cfg (modified) * rtems/config/tools/rtems-tools-git-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/freetype-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-common-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (modified) * source-builder/config/libjpeg-1.cfg (modified) * source-builder/config/libpng-1.cfg (modified) * source-builder/config/libtiff-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/lwip-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/microwindows-1.cfg (modified) * source-builder/config/net-snmp-5-1.cfg (modified) * source-builder/config/ntp-4-1.cfg (modified) * source-builder/config/nxlib-1.cfg (modified) * source-builder/config/or1ksim-1-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/protobuf-2-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/config/spike-1-1.cfg (modified) * source-builder/config/sqlite-3-1.cfg (modified) * source-builder/config/t1lib-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) windows: Remove BuildRoot from all configs, add a short tmp path. ... Wed, 24 Oct 2018 12:03:54 GMT Sebastian Huber [f07d2b6] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b.cfg (added) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b.cfg (added) * rtems/config/tools/rtems-gcc-7.3.0-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b.cfg (added) 5: Update Newlib Fix posix_memalign() attributes. Use ... Tue, 23 Oct 2018 17:01:47 GMT Joel Sherrill [1e9075a] * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-5835688440fb0b23fe991a04c7e2df54ded87657.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-5835688440fb0b23fe991a04c7e2df54ded87657.cfg (added) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-5835688440fb0b23fe991a04c7e2df54ded87657.cfg (added) Bump epiphany, m32c, or1k, and riscv to latest newlib. Mon, 22 Oct 2018 16:30:20 GMT Joel Sherrill [818f396] * rtems/config/5/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-7.3.0-newlib-5835688440fb0b23fe991a04c7e2df54ded87657.cfg (added) Update newlib to 5835688440fb0b23fe991a04c7e2df54ded87657 Sun, 14 Oct 2018 22:04:37 GMT Joel Sherrill [8992d20] * rtems/config/tools/rtems-tools-5-1.cfg (modified) rtems-tools-5-1.cfg: Bump to latest closes #3401, #3402, #3424. Fri, 12 Oct 2018 17:44:48 GMT Chris Johns [1e5a261] * rtems/config/5/rtems-default.bset (modified) rtems-5: Move GDB to as early in the build as possible. This should ... Sun, 07 Oct 2018 03:29:22 GMT Chris Johns [7bb268b] * rtems/config/tools/rtems-gcc-7.3.0-newlib-d13c84eb07e35984bf7a974cd786a6cdac29e6b9.cfg (modified) darwin: Work around symlink issues on Darwin with APFS building ... Thu, 11 Oct 2018 13:35:50 GMT Sebastian Huber [35c533f] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-103b055035fea328f8bc7826801760fb1c055683.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-103b055035fea328f8bc7826801760fb1c055683.cfg (added) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-103b055035fea328f8bc7826801760fb1c055683.cfg (added) * rtems/config/tools/rtems-gcc-7.3.0-newlib-103b055035fea328f8bc7826801760fb1c055683.cfg (added) 5: Update Newlib Pick up POSIX header file changes and improved ... Mon, 27 Aug 2018 05:54:36 GMT Sebastian Huber [0230202] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-d13c84eb07e35984bf7a974cd786a6cdac29e6b9.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-d13c84eb07e35984bf7a974cd786a6cdac29e6b9.cfg (added) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-d13c84eb07e35984bf7a974cd786a6cdac29e6b9.cfg (added) * rtems/config/tools/rtems-gcc-7.3.0-newlib-d13c84eb07e35984bf7a974cd786a6cdac29e6b9.cfg (added) 5: Update Newlib Pick up POSIX header file changes for an upcomming ... Mon, 20 Aug 2018 12:06:13 GMT Sebastian Huber [79c83cd] * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-3bc64b88c391bb9f27fdbf38703fef949828987a.cfg (added) 5: Update Newlib for RISC-V Use the latest Newlib to fix the GCC ... Tue, 07 Aug 2018 05:06:01 GMT Sebastian Huber [01600ac] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5: Update tools for RISC-V BSP builder support Update #3433. Fri, 03 Aug 2018 05:07:28 GMT Sebastian Huber [8f74240] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-3.0.0.20180802.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-3.0.0.20180802.cfg (added) * rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-3.0.0.20180802.cfg (added) * rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.20180802.cfg (added) 5: Update Newlib It includes a fix for bug in the ctype support, ...
