# # ChangeLog for rtems/config in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/24/24 06:19:16 Mon, 22 Apr 2013 12:28:27 GMT Chris Johns [f077b2b] * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (added) * source-builder/sb/build.py (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/download.py (modified) Fixes for CVS to work. Add RTEMS build for sparc/sis. Sat, 20 Apr 2013 11:47:28 GMT Chris Johns [4ce931b] * rtems/config/snapshots/gcc-4.7-branch.mc (modified) * rtems/config/snapshots/newlib-head.mc (added) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/download.py (modified) Add CVS download support. These changes complete the CVS download ... Tue, 16 Apr 2013 04:44:54 GMT Chris Johns [1bab165] * rtems/config/snapshots/gcc-4.7-branch.mc (added) * rtems/config/snapshots/gcc-4.7.3-rc.mc (added) Add snapshot macros files. To use: ... Mon, 15 Apr 2013 07:01:30 GMT Chris Johns [b022691] * rtems/config/4.11/rtems-m32c.bset (modified) Override the target build flags. Sun, 14 Apr 2013 22:30:25 GMT Chris Johns [cc2c48b] * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (modified) Switch to the regenerated gcc-4.7.3 patch. Sun, 14 Apr 2013 08:08:10 GMT Chris Johns [3e86a96] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (added) Update RTEMS 4.11 to GCC 4.7.3. All build sets for RTEMS 4.11 that ... Fri, 05 Apr 2013 03:24:33 GMT Chris Johns [3760113] * rtems/config/4.11/rtems-arm.bset (modified) Update to the patch Joel merged. Tue, 02 Apr 2013 21:43:36 GMT Chris Johns [8130026] * rtems/config/4.11/rtems-arm.bset (modified) Add the 32bit host fix for EABI. Tue, 02 Apr 2013 10:07:15 GMT Chris Johns [df1a0d6] * rtems/config/unstable/4.11/rtems-arm.bset (modified) * rtems/config/unstable/4.11/rtems-avr.bset (modified) * rtems/config/unstable/4.11/rtems-bfin.bset (modified) * rtems/config/unstable/4.11/rtems-h8300.bset (modified) * rtems/config/unstable/4.11/rtems-i386.bset (modified) * rtems/config/unstable/4.11/rtems-lm32.bset (modified) * rtems/config/unstable/4.11/rtems-m32c.bset (modified) * rtems/config/unstable/4.11/rtems-m32r.bset (modified) * rtems/config/unstable/4.11/rtems-m68k.bset (modified) * rtems/config/unstable/4.11/rtems-microblaze.bset (modified) * rtems/config/unstable/4.11/rtems-mips.bset (modified) * rtems/config/unstable/4.11/rtems-moxie.bset (modified) * rtems/config/unstable/4.11/rtems-powerpc.bset (modified) * rtems/config/unstable/4.11/rtems-sh.bset (modified) * rtems/config/unstable/4.11/rtems-sparc.bset (modified) * rtems/config/unstable/4.11/rtems-sparc64.bset (modified) * rtems/config/unstable/4.11/rtems-v850.bset (modified) PR 2105. Changed the unstable build sets to use rtems_arch. Mon, 01 Apr 2013 04:19:56 GMT Chris Johns [4f26bdb] * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/autoconf-2.69-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/checks.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/dtc-1.2.0.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/defaults.py (modified) * source-builder/sb/execute.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/windows.py (modified) Add Canadian Cross support. Add support to build MinGW tools using ... Thu, 21 Mar 2013 11:52:10 GMT Chris Johns [aabe4e7] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (modified) Use ftp.rtems.org and not www.rtems.org. Thu, 21 Mar 2013 11:45:15 GMT Chris Johns [a8a3af2] * rtems/config/4.9/rtems-arm.bset (modified) * rtems/config/4.9/rtems-i386.bset (modified) * rtems/config/4.9/rtems-m68k.bset (modified) * rtems/config/4.9/rtems-mips.bset (modified) * rtems/config/4.9/rtems-powerpc.bset (modified) * rtems/config/4.9/rtems-sparc.bset (modified) * rtems/config/tools/rtems-kernel-4.9.6-1.cfg (added) Build RTEMS 4.9.6. Thu, 21 Mar 2013 04:47:27 GMT Chris Johns [02711d6] * rtems/config/4.9/rtems-all.bset (modified) * rtems/config/4.9/rtems-arm.bset (added) * rtems/config/4.9/rtems-mips.bset (added) * rtems/config/4.9/rtems-powerpc.bset (added) Add more RTEMS 4.9 architectures. Wed, 20 Mar 2013 06:28:42 GMT Chris Johns [d19391d] * rtems/config/4.10/rtems-bfin.bset (modified) Patch to fix bfin simulator. Wed, 20 Mar 2013 05:04:13 GMT Chris Johns [2a37e1a] * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) Add RTEMS patch support. Tue, 19 Mar 2013 22:46:56 GMT Chris Johns [fcf7889] * rtems/config/4.10/#rtems-avr.bset# (deleted) * rtems/config/4.10/.#rtems-avr.bset (deleted) Remove files added in error. Tue, 19 Mar 2013 22:46:42 GMT Chris Johns [0eb48e1] * rtems/config/4.10/rtems-avr.bset (modified) Minor clean up. Tue, 19 Mar 2013 22:43:12 GMT Chris Johns [aa8e600] * rtems/config/rtems-4.11-base.bset (modified) * rtems/config/rtems-4.9-base.bset (modified) Use the common base set definitions. Tue, 19 Mar 2013 22:41:23 GMT Chris Johns [e3aa355] * rtems/config/4.10/#rtems-avr.bset# (added) * rtems/config/4.10/.#rtems-avr.bset (added) * rtems/config/4.10/rtems-all.bset (added) * rtems/config/4.10/rtems-arm.bset (added) * rtems/config/4.10/rtems-autotools.bset (added) * rtems/config/4.10/rtems-avr.bset (added) * rtems/config/4.10/rtems-bfin.bset (added) * rtems/config/4.10/rtems-h8300.bset (added) * rtems/config/4.10/rtems-i386.bset (added) * rtems/config/4.10/rtems-lm32.bset (added) * rtems/config/4.10/rtems-m32c.bset (added) * rtems/config/4.10/rtems-m32r.bset (added) * rtems/config/4.10/rtems-m68k.bset (added) * rtems/config/4.10/rtems-mips.bset (added) * rtems/config/4.10/rtems-nios2.bset (added) * rtems/config/4.10/rtems-powerpc.bset (added) * rtems/config/4.10/rtems-sh.bset (added) * rtems/config/4.10/rtems-sparc.bset (added) * rtems/config/rtems-4.10-base.bset (added) * rtems/config/rtems-base.bset (added) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (added) * rtems/config/tools/rtems-kernel-4.10.2.cfg (added) Add support for RTEMS 4.10. This change adds support for RTEMS 4.10 ... Tue, 19 Mar 2013 03:28:40 GMT Dhananjay Balan [5439e8f] * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) GCC 4.7.2 is incompatible with Texinfo 5 Sat, 16 Mar 2013 00:03:19 GMT Chris Johns [896a832] * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) Use GMP 5.0.5 with MPFR 2.4.2 on gcc-4.3.2. Fri, 15 Mar 2013 21:18:29 GMT Chris Johns [0e25807] * rtems/config/4.9/rtems-all.bset (added) * rtems/config/4.9/rtems-autotools.bset (added) * rtems/config/4.9/rtems-m68k.bset (added) Add all, m68k and autotools build sets. Fri, 15 Mar 2013 04:33:59 GMT Chris Johns [3643c48] * rtems/config/4.9/rtems-i386.bset (added) * rtems/config/4.9/rtems-sparc.bset (added) * rtems/config/rtems-4.9-base.bset (added) * rtems/config/tools/rtems-binutils-2.19.1-1.cfg (added) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (added) * rtems/config/tools/rtems-gdb-6.8-1.cfg (added) * source-builder/config/gcc-4.3-1.cfg (added) * source-builder/config/gdb-6-1.cfg (added) Add RTEMS 4.9 support for i386 and SPARC. Tue, 12 Mar 2013 23:50:10 GMT Chris Johns [1efc3f7] * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (modified) Add missing RTEMS patches to binutils-2.23.1. Tue, 12 Mar 2013 10:54:31 GMT Chris Johns [087dd50] * rtems/config/4.11/rtems-lm32.bset (modified) Fix the binutils version change. Tue, 12 Mar 2013 10:54:05 GMT Chris Johns [e7f98ee] * rtems/config/4.11/rtems-arm.bset (modified) Fix the patch path. Tue, 12 Mar 2013 09:15:39 GMT Chris Johns [1f9e551] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) Switch to binutils-2.23.1. Tue, 12 Mar 2013 09:09:22 GMT Chris Johns [a57d9f0] * rtems/config/tools/rtems-microblaze-gcc-4.7.2-newlib-2.0.0-1.cfg (deleted) * rtems/config/tools/rtems-mips-gcc-4.7.2-newlib-2.0.0-1.cfg (deleted) * rtems/config/tools/rtems-moxie-gdb-7.5.1-1.cfg (deleted) Remove arch configurations as build sets are used. Tue, 12 Mar 2013 09:08:17 GMT Chris Johns [530b9c0] * rtems/config/4.11/rtems-arm.bset (modified) Use the latest GCC 4.7 ARM to EABI patch from Sebastian. Tue, 12 Mar 2013 08:02:45 GMT Chris Johns [2034d38] * rtems/config/4.11/rtems-powerpc.bset (modified) Move the PowerPC to %{rtems_arch}. It was missed. Tue, 12 Mar 2013 07:58:15 GMT Chris Johns [b3bc4cf] * rtems/config/4.11/rtems-all.bset (modified) LM32 is fixed. Tue, 12 Mar 2013 07:31:24 GMT Chris Johns [19efefa] * rtems/config/4.11/rtems-lm32.bset (modified) Disable SMP (--no-smp) for LM32. Tue, 12 Mar 2013 07:30:43 GMT Chris Johns [f40e52d] * rtems/config/rtems-4.11-base.bset (modified) Include git info in the gcc version message. Tue, 12 Mar 2013 05:50:53 GMT Chris Johns [a77083a] * rtems/config/4.11/rtems-moxie.bset (modified) Move the moxie gdb patches into the build set. Tue, 12 Mar 2013 04:44:55 GMT Chris Johns [c01a36b] * rtems/config/4.11/rtems-moxie.bset (modified) Fix the moxie binutils patch name. Mon, 11 Mar 2013 11:39:10 GMT Chris Johns [4f67f78] * rtems/config/4.11/rtems-microblaze.bset (modified) Fix the patch path. Mon, 11 Mar 2013 06:15:04 GMT Chris Johns [3c5f4ec] * rtems/config/4.11/rtems-arm.bset (modified) Use the updated ARM EABI patch for gcc-4.7.2. Mon, 11 Mar 2013 02:55:56 GMT Chris Johns [3bab09c] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/rtems-gcc-patches.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) Add support for build set patch options. Remove the hard coded ... Mon, 11 Mar 2013 00:10:42 GMT Chris Johns [d007f05] * rtems/config/rtems-4.11-base.bset (modified) Fix the base URL for the RTEMS git web interface. Sun, 10 Mar 2013 23:58:40 GMT Chris Johns [48e1cd4] * rtems/.gitignore (modified) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-4.11-base.bset (modified) * rtems/config/rtems-binutils-patches.cfg (added) * rtems/config/rtems-gcc-patches.cfg (added) * rtems/config/rtems-gdb-patches.cfg (added) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/patches/binutils-2.20.1-rtems4.10-20100826.diff (deleted) * rtems/patches/binutils-2.22-rtems4.11-20120427.diff (deleted) * rtems/patches/binutils-2.22-rtems4.11-moxie-20130214.diff (deleted) * rtems/patches/gcc-4.5.3-strsignal-1.diff (deleted) * rtems/patches/gcc-4.7-arm-to-eabi-20120511.diff (deleted) * rtems/patches/gcc-4.7.2-rtems4.11-20121026.diff (deleted) * rtems/patches/gcc-core-4.4.7-rtems4.10-20120314.diff (deleted) * rtems/patches/gcc-core-4.6.3-rtems4.11-20120303.diff (deleted) * rtems/patches/gcc-g++-4.4.7-rtems4.10-20120314.diff (deleted) * rtems/patches/gdb-7.3.1-rtems4.10-20120918.diff (deleted) * rtems/patches/gdb-7.5-rtems4.11-20121003.diff (deleted) * rtems/patches/gdb-7.5.1-rtems4.11-moxie-20130214.diff (deleted) * rtems/patches/newlib-1.18.0-rtems4.10-20110518.diff (deleted) * rtems/patches/newlib-1.20.0-rtems4.11-20121011.diff (deleted) * rtems/patches/newlib-2.0.0-mips-memcpy-20130107.diff (deleted) * rtems/patches/newlib-2.0.0-mips-memcpy-20130219.diff (deleted) * rtems/patches/nios2-binutils-2.20-rtems-20110703.diff (deleted) * rtems/patches/nios2-gcc-4.1-rtems-20110818.diff (deleted) * rtems/patches/nios2-newlib-1.19.0-rtems-20110720.diff (deleted) Move all patches to the rtems-tools.git repo. All patches are now ... Sun, 10 Mar 2013 03:53:08 GMT Chris Johns [3e1a845] * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/tools/rtems-microblaze-gcc-4.7.2-newlib-2.0.0-1.cfg (added) Microblaze support for ldscript patch. Sun, 10 Mar 2013 03:52:04 GMT Chris Johns [fdc8e0c] * rtems/config/tools/rtems-mips-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) Fix comments. Fri, 08 Mar 2013 23:48:36 GMT Chris Johns [98e7a7b] * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/patches/gcc-4.5.3-strsignal-1.diff (added) Patch to fix strsignal for the LM32 gcc-4.5.3. Fri, 08 Mar 2013 21:12:47 GMT Chris Johns [8301afa] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (added) * source-builder/config/gcc-4.5-1.cfg (added) Switch LM32 to gcc-4.5.3. This is the reported known working tool ... Fri, 08 Mar 2013 08:10:33 GMT Chris Johns [876f07d] * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/tools/rtems-mips-gcc-4.7.2-newlib-2.0.0-1.cfg (added) * rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg (modified) * rtems/patches/newlib-2.0.0-mips-memcpy-20130107.diff (added) * rtems/patches/newlib-2.0.0-mips-memcpy-20130219.diff (added) MIPS Newlib 2.0.0 patches. Add the STX39 simulator. There are a ... Fri, 08 Mar 2013 08:05:48 GMT Chris Johns [48bfd7b] * rtems/config/rtems-4.11-base.bset (modified) Include RSB in the version string to help id the tools. Fri, 08 Mar 2013 03:23:54 GMT Chris Johns [5ec7fb8] * rtems/config/4.11/rtems-autotools.bset (modified) Set a suitable package for the autotools. Fri, 08 Mar 2013 03:02:26 GMT Chris Johns [ef7c093] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) Change to newlib 2.0.0. Move the stable to newlib 2.0.0 by default ... Fri, 08 Mar 2013 03:00:45 GMT Chris Johns [f17665e] * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg (added) * rtems/config/tools/rtems-moxie-gdb-7.5.1-1.cfg (added) Add MIPS STX39 and Moxie specific GDB builds. The MIPS STX39 is a ... Tue, 05 Mar 2013 03:30:31 GMT Chris Johns [b521098] * rtems/config/4.11/rtems-all.bset (modified) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) Clean up the per target C/C++ handling. Mon, 04 Mar 2013 23:31:55 GMT Chris Johns [6f36333] * rtems/config/unstable/4.11/rtems-avr.bset (modified) * rtems/config/unstable/4.11/rtems-bfin.bset (modified) * rtems/config/unstable/4.11/rtems-h8300.bset (modified) * rtems/config/unstable/4.11/rtems-i386.bset (added) * rtems/config/unstable/4.11/rtems-lm32.bset (added) * rtems/config/unstable/4.11/rtems-m32c.bset (modified) * rtems/config/unstable/4.11/rtems-m32r.bset (modified) * rtems/config/unstable/4.11/rtems-m68k.bset (modified) * rtems/config/unstable/4.11/rtems-microblaze.bset (modified) * rtems/config/unstable/4.11/rtems-mips.bset (modified) * rtems/config/unstable/4.11/rtems-moxie.bset (modified) * rtems/config/unstable/4.11/rtems-powerpc.bset (modified) * rtems/config/unstable/4.11/rtems-sh.bset (modified) * rtems/config/unstable/4.11/rtems-sparc.bset (modified) * rtems/config/unstable/4.11/rtems-sparc64.bset (added) * rtems/config/unstable/4.11/rtems-v850.bset (added) Add missing unstable targets. Fix comments. Mon, 04 Mar 2013 23:15:10 GMT Chris Johns [65d1425] * rtems/config/4.11/rtems-all.bset (modified) Add the missing targets to the 'all' build. Mon, 04 Mar 2013 21:47:18 GMT Chris Johns [2754e99] * rtems/config/4.11/rtems-i386.bset (added) * rtems/config/4.11/rtems-lm32.bset (added) * rtems/config/4.11/rtems-sparc64.bset (added) * rtems/config/4.11/rtems-v850.bset (added) Add missing targets. Mon, 04 Mar 2013 07:01:44 GMT Chris Johns [735cd20] * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) Unstable 4.11 is using gcc 4.8-20130303 Sun, 03 Mar 2013 22:44:57 GMT Chris Johns [43c3d0a] * rtems/config/4.11/rtems-all.bset (modified) Add autotools to the all build set. Sun, 24 Feb 2013 07:43:14 GMT Chris Johns [77c68e8] * rtems/config/4.11/rtems-autotools.bset (added) Add an RTEMS 4.11 autotools build set. Wed, 20 Feb 2013 03:56:38 GMT Chris Johns [879c68a] * rtems/config/unstable/4.11/rtems-all.bset (added) * rtems/config/unstable/4.11/rtems-avr.bset (added) * rtems/config/unstable/4.11/rtems-bfin.bset (added) * rtems/config/unstable/4.11/rtems-h8300.bset (added) * rtems/config/unstable/4.11/rtems-m32c.bset (added) * rtems/config/unstable/4.11/rtems-m32r.bset (added) * rtems/config/unstable/4.11/rtems-m68k.bset (added) * rtems/config/unstable/4.11/rtems-microblaze.bset (added) * rtems/config/unstable/4.11/rtems-mips.bset (added) * rtems/config/unstable/4.11/rtems-moxie.bset (added) * rtems/config/unstable/4.11/rtems-powerpc.bset (added) * rtems/config/unstable/4.11/rtems-sh.bset (added) * rtems/config/unstable/4.11/rtems-sparc.bset (added) Add remaining unstable archs. Wed, 20 Feb 2013 03:55:14 GMT Chris Johns [9348933] * rtems/config/4.11/rtems-all.bset (modified) Fix the path to the build sets. Wed, 20 Feb 2013 03:46:51 GMT Chris Johns [a32dcbd] * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (added) * rtems/config/unstable/4.11/rtems-arm.bset (added) * source-builder/config/gcc-4.8-1.cfg (added) Add unstable. Add a tree of unstable configurations to track recent ... Wed, 20 Feb 2013 00:18:10 GMT Chris Johns [9f04b64] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/patches/gcc-4.7-arm-to-eabi-20120511.diff (added) * source-builder/config/gcc-4.7-1.cfg (modified) Architecture arm-rtems4.11 uses EABI. Switch the arm-rtems4.11 to ... Tue, 19 Feb 2013 09:08:01 GMT Chris Johns [2fd402d] * rtems/config/4.11/rtems-all.bset (modified) Add the remaining archs to the all build set. Tue, 19 Feb 2013 08:03:04 GMT Chris Johns [f6814ff] * rtems/config/4.11/rtems-all.bset (added) An RTEMS Tool All build set. Thu, 14 Feb 2013 06:06:08 GMT Chris Johns [7e3c903] * rtems/config/rtems-tools-4.10.bset (deleted) * rtems/config/rtems-tools-4.11-unstable.bset (deleted) * rtems/config/rtems-tools-4.11.bset (deleted) Remove the old single tools build set for all archs. Thu, 14 Feb 2013 05:14:38 GMT Chris Johns [b1202fc] * rtems/config/4.11/rtems-moxie.bset (modified) * source-builder/config/dtc-1-1.cfg (added) * source-builder/config/dtc-1.2.0.cfg (added) Moxie GDB DTC support added The Moxie GDB simulator uses the DTC ... Thu, 14 Feb 2013 02:29:10 GMT Chris Johns [a25a19d] * rtems/config/4.11/rtems-microblaze.bset (added) Add Microblaze. Thu, 14 Feb 2013 01:32:03 GMT Chris Johns [87fc7e0] * rtems/config/4.11/rtems-moxie.bset (added) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/patches/binutils-2.22-rtems4.11-moxie-20130214.diff (added) * rtems/patches/gdb-7.5.1-rtems4.11-moxie-20130214.diff (added) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) Add Moxie support. Binutils and the compiler build how-ever gdb ... Wed, 13 Feb 2013 09:13:46 GMT Chris Johns [b991b35] * rtems/config/4.11/rtems-powerpc.bset (added) * rtems/config/4.11/rtems-sh.bset (added) Add remaining archs to 4.11. Wed, 13 Feb 2013 04:50:36 GMT Chris Johns [458b11b] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) Always build the expat package. Wed, 13 Feb 2013 00:30:47 GMT Chris Johns [d963553b] * rtems/config/4.11/rtems-arm.bset (moved) * rtems/config/4.11/rtems-avr.bset (added) * rtems/config/4.11/rtems-bfin.bset (added) * rtems/config/4.11/rtems-h8300.bset (added) * rtems/config/4.11/rtems-m32c.bset (added) * rtems/config/4.11/rtems-m32r.bset (added) * rtems/config/4.11/rtems-m68k.bset (added) * rtems/config/4.11/rtems-mips.bset (added) * rtems/config/4.11/rtems-nios2.bset (moved) * rtems/config/4.11/rtems-sparc.bset (moved) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (moved) * rtems/config/tools/rtems-binutils-2.22-1.cfg (moved) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (moved) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (moved) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (moved) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (moved) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (moved) * rtems/config/tools/rtems-gdb-7.5-1.cfg (moved) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (moved) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (moved) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (moved) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (moved) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/sb/config.py (modified) * source-builder/sb/defaults.py (modified) Restructure RTEMS Config Files Add arch build files. This allows ... Tue, 12 Feb 2013 03:12:40 GMT Chris Johns [aa46b9c] * rtems/config/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) Fixes to the NIOS2 build on FreeBSD. Tue, 12 Feb 2013 00:46:29 GMT Chris Johns [0328944] * rtems/config/rtems-nios2-4.11.bset (added) * rtems/config/rtems-nios2-binutils-2.20-1.cfg (added) * rtems/config/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (added) * rtems/config/rtems-nios2-gdb-7.0-1.cfg (added) * rtems/patches/nios2-binutils-2.20-rtems-20110703.diff (added) * rtems/patches/nios2-gcc-4.1-rtems-20110818.diff (added) * rtems/patches/nios2-newlib-1.19.0-rtems-20110720.diff (added) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) NIOS2 Tools based on Altera's 4.11 tool set. Add support for ... Sat, 09 Feb 2013 08:07:37 GMT Chris Johns [2f72d35] * rtems/config/rtems-4.11-base.bset (added) * rtems/config/rtems-arm-4.11.bset (added) * rtems/config/rtems-sparc-4.11.bset (added) * source-builder/sb/defaults.py (modified) * source-builder/sb/setbuilder.py (modified) Add per arch build sets using %include. Add per arch build sets as ... Thu, 07 Feb 2013 23:06:16 GMT Chris Johns [6a2003e] * rtems/config/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) Add support to turn on the "obsolete" arm-rtems4.11 target. This ... Fri, 01 Feb 2013 01:41:13 GMT Chris Johns [ad77f90] * rtems/config/rtems-binutils-2.23.1-1.cfg (added) Binutils 2.23.1. Fri, 01 Feb 2013 01:40:43 GMT Chris Johns [51c5a57] * rtems/config/rtems-tools-4.11-unstable.bset (modified) Build binutils 2.23.1 for unstable. Fri, 30 Nov 2012 06:13:18 GMT Chris Johns [d34a0a9] * rtems/config/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (added) * rtems/config/rtems-gdb-7.5.1-1.cfg (added) * rtems/config/rtems-tools-4.11-unstable.bset (added) * rtems/patches/gcc-4.7.2-rtems4.11-20121026.diff (added) * source-builder/config/gcc-4.7-1.cfg (added) * source-builder/config/gcc-4.7-newlib-1.20-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) Add rtems-4.11 support for 4.7.2. Thu, 08 Nov 2012 20:11:12 GMT Chris Johns [f02d3f9] * rtems/build-4.11-targets.sh (modified) * rtems/config/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) Same failures as gcc-4.4.7 plus lm32 does not build. Thu, 08 Nov 2012 20:09:51 GMT Chris Johns [0bf00e2] * rtems/build-4.11-targets.sh (added) * rtems/config/rtems-binutils-2.22-1.cfg (added) * rtems/config/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (added) * rtems/config/rtems-gdb-7.5-1.cfg (added) * rtems/config/rtems-tools-4.11.bset (added) * rtems/patches/binutils-2.22-rtems4.11-20120427.diff (added) * rtems/patches/gcc-core-4.6.3-rtems4.11-20120303.diff (added) * rtems/patches/gdb-7.5-rtems4.11-20121003.diff (added) * rtems/patches/newlib-1.20.0-rtems4.11-20121011.diff (added) Add rtems-4.11 support using gcc 4.6.3. Tue, 06 Nov 2012 18:10:39 GMT Chris Johns [7760706] * rtems/config/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) Disable C++ on M32C. Fix target to _target bug. Tue, 06 Nov 2012 17:35:17 GMT Chris Johns [62f77ac6] * rtems/config/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) Disable C++ for AVR. Mon, 05 Nov 2012 22:08:28 GMT Chris Johns [384ebe7] * rtems/config/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) Ubuntu needs GMP 5.0.5 to work around a flex/m4 bug in GMP. Mon, 05 Nov 2012 14:01:11 GMT Chris Johns [010f47c] * rtems/config/rtems-binutils-2.20.1-1.cfg (moved) * rtems/config/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (moved) * rtems/config/rtems-gdb-7.3.1-1.cfg (moved) * rtems/config/rtems-tools-4.10.bset (moved) Move the configuration files into the config directory.
