# # ChangeLog for rtems/config in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/28/24 21:34:56 Sat, 01 Nov 2014 03:48:10 GMT Ben Gras [1587711] * rtems/config/tools/rtems-tools-4.11-1.cfg (modified) update rtems-tools Fri, 31 Oct 2014 04:33:08 GMT Chris Johns [619675f] * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) rtems4.11: Forgot to make the change to 4.9.2. Fri, 31 Oct 2014 04:02:07 GMT Chris Johns [1b11d05] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-or1k.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-tools.bset (added) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-binutils-git-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.1-newlib-git-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg (added) * rtems/config/tools/rtems-tools-1.cfg (added) * rtems/config/tools/rtems-tools-4.11-1.cfg (added) * rtems/config/tools/rtems-tools-git-1.cfg (added) rtems4.11: Upgrade to gcc-4.9.2. Build rtems-tools and install. ... Fri, 24 Oct 2014 22:00:52 GMT Joel Sherrill [4830e23] * rtems/config/4.11/graphics/libjpeg.bset (added) * rtems/config/graphics/libjpeg-9a-1.cfg (added) * source-builder/config/libjpeg-1.cfg (added) rtems-4.11: Add libjpeg Tue, 07 Oct 2014 09:50:43 GMT Chris Johns [7c8c1d1] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-or1k.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-git-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg (added) rtems-4.11: Switch to newlib's git repo. Sat, 20 Sep 2014 00:10:45 GMT Chris Johns [bc51abf] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) rtems: Fix type in RTEMS kernel build. Reported by Marco Hoefle ... Sat, 23 Aug 2014 13:24:05 GMT Chris Johns [f022f82] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) rtems-4.11: Use the internal autoconf build. Sat, 23 Aug 2014 13:19:25 GMT Chris Johns [cd93d89] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) rtems-4.11: Fix the broken RTEMS build on 4.11. Thu, 21 Aug 2014 12:40:47 GMT Chris Johns [257d1e4] * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/sb/config.py (modified) rtems-4.11: Fix building the SPARC simulator. Add support for ... Wed, 20 Aug 2014 05:00:41 GMT Chris Johns [05cea12] * bare/config/devel/automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (modified) rtems-4.11: Newlib 19-Aug-2014. Add the hash for automake. Tue, 19 Aug 2014 11:40:20 GMT Chris Johns [9ff6dad] * rtems/config/tools/rtems-autoconf-2.69-1.cfg (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) rtems: Remove the duplicate hashes from the config. Wed, 13 Aug 2014 20:39:06 GMT Chris Johns [1c3547f] * bare/config/devel/autoconf-2.69-1.cfg (modified) * bare/config/devel/automake-1.12.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.10.2.cfg (modified) rtems-4.10: Add checksums. Tue, 05 Aug 2014 22:54:33 GMT Chris Johns [aaa015e] * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * source-builder/config/gdb-7-1.cfg (modified) rtems-4.11: Do not build GDB sim on MinGW32 for some targets. They ... Thu, 31 Jul 2014 03:34:48 GMT Chris Johns [7c46699] * rtems/config/4.11/rtems-microblaze.bset (modified) rtems-4.11: Use gcc-4.9.1 for Microblaze. Microblaze does not build ... Wed, 30 Jul 2014 02:33:43 GMT Chris Johns [7ea4534] * rtems/config/4.11/rtems-all.bset (modified) rtems4.11: Add rtems-or1k to rtems-all. Wed, 30 Jul 2014 02:32:05 GMT Chris Johns [65f9bce] * rtems/config/4.11/rtems-or1k.bset (modified) config: Format changes. Tue, 29 Jul 2014 09:25:40 GMT Hesham ALMatary [a69c400] * rtems/config/4.11/rtems-or1k.bset (modified) Refer to newlib-cvs and gcc.4.8.3, and add hashes for patches. 1- ... Tue, 29 Jul 2014 06:35:43 GMT Chris Johns [a083b52] * bare/config/devel/expat-2.1.0-1.cfg (modified) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (modified) * rtems/config/net/ntp-4.2.6p5-1.cfg (modified) * rtems/config/tools/rtems-autoconf-2.69-1.cfg (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7.1-1.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (modified) Add checksum support for downloaded files. File download by http, ... Tue, 29 Jul 2014 00:04:01 GMT Chris Johns [4837350] * rtems/config/4.11/rtems-nios2.bset (modified) rtems4.11: Change the NIO2 to the 4.9.1. Uses patch ... Mon, 28 Jul 2014 23:41:13 GMT Chris Johns [4e502f0] * rtems/config/4.11/rtems-arm.bset (modified) rtems4.11: Add support for Cortex-M4 and Cortex-R based chips. ... Sat, 26 Jul 2014 00:44:45 GMT Chris Johns [fdb2b9e] * rtems/config/rtems-bsp.cfg (modified) * source-builder/config/ntp-4-1.cfg (modified) rtems-bsp: Install 3rd party packages under a BSP. Provide the ... Fri, 25 Jul 2014 04:55:14 GMT Chris Johns [114ef08] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-or1k.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gdb-7.7.1-1.cfg (added) RTEMS 4.11 Update to gcc-4.8.3 with Newlib CVS 26-Jul-2014. ... Mon, 23 Jun 2014 00:58:56 GMT Chris Johns [df65d66] * rtems/config/4.11/net-mgmt/net-snmp.bset (added) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (added) * source-builder/config/net-snmp-5-1.cfg (added) config: Add net-snmp package for RTEMS. Sun, 15 Jun 2014 09:57:11 GMT Chris Johns [a5e37e6] * rtems/config/rtems-bsp.cfg (modified) config: Fix the broken rtems-bsp.cfg. Sun, 15 Jun 2014 09:34:38 GMT Chris Johns [912596d] * rtems/config/rtems-bsp.cfg (modified) config: Use the prefix as the tools path if no --with-tools. To use ... Sun, 15 Jun 2014 05:40:34 GMT Chris Johns [0ffee19] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/libiconv-1.14-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/texane-stlink-1.cfg (modified) * rtems/config/4.11/net/ntp.bset (added) * rtems/config/net/ntp-4.2.6p5-1.cfg (added) * rtems/config/rtems-base.bset (modified) * rtems/config/rtems-bsp.cfg (added) * rtems/config/rtems-urls.bset (added) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/ntp-4-1.cfg (added) * source-builder/defaults.mc (modified) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) sb: Add support for building RTEMS 3rd party packages. Remove the ... Mon, 26 May 2014 01:40:22 GMT Hesham ALMatary [3a0e561] * rtems/config/4.11/rtems-or1k.bset (added) * source-builder/config/gdb-7-1.cfg (modified) Add support for building rtems-or1k tool-chain - fixed ... Sun, 01 Jun 2014 07:58:55 GMT Chris Johns [396db46] * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) config: Update the NIOS2 configuration for the new %source command. Mon, 19 May 2014 02:50:54 GMT Chris Johns [b09fde0] * rtems/config/4.11/rtems-sparc.bset (modified) 4.11/sparc: Update the gdb-7.7 SIS output patch. Tue, 13 May 2014 13:26:09 GMT Chris Johns [9a15c40] * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-binutils-patches.cfg (deleted) * rtems/config/rtems-gcc-patches.cfg (deleted) * rtems/config/rtems-gdb-patches.cfg (deleted) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-6.8-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (added) * source-builder/sb/version.py (modified) sb: Implement %source and %patch to manage source and patches. ... Fri, 09 May 2014 01:20:38 GMT Chris Johns [e074e75] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (added) 4.11/rtems-lm32: Use gcc-4.9.0 and fix gdb simulator build on ... Fri, 02 May 2014 10:48:49 GMT Chris Johns [3adcfbf] * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) rtems/4.11: Fix _host_os for building on FreeBSD. It needs to be ... Thu, 01 May 2014 05:38:09 GMT Chris Johns [43252be] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg (added) config: Update to gdb-7.7 for a range of archs. Update lm32, m32c, ... Mon, 28 Apr 2014 06:53:33 GMT Chris Johns [491d6b9] * rtems/config/4.11/rtems-sparc.bset (modified) 4.11/rtems: Sparc port change to gdb-7.7. Mon, 28 Apr 2014 02:18:00 GMT Chris Johns [6fe63b3] * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) config: Remove the POSIX thread model patch. Switch back the RTEMS ... Wed, 16 Apr 2014 18:05:09 GMT Joel Sherrill [d812ad5] * rtems/config/4.11/rtems-m32c.bset (modified) 4.11/rtems-m32c.bset: Enable building gcc again Wed, 16 Apr 2014 04:03:35 GMT Chris Johns [9d61bc9] * rtems/config/4.11/rtems-moxie.bset (modified) rtems/4.11: moxie switch to gdb-7.7. Remove the binutils patches as ... Wed, 16 Apr 2014 03:57:44 GMT Chris Johns [3c514b2] * rtems/config/4.11/rtems-i386.bset (modified) rtems/4.11: i386 switch to gdb-7.7. Thu, 10 Apr 2014 08:27:17 GMT Chris Johns [6b7b22a] * bare/config/devel/libiconv-1.14-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) config: Use _host_os for conditional checks. Thu, 10 Apr 2014 08:23:26 GMT Chris Johns [9ea19cf] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) config: Update to gdb-7.7. for arm, avr, bfin, h8300. Thu, 10 Apr 2014 08:22:23 GMT Chris Johns [7a6d42e] * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) config: Fix for sim common code on Mavrick. Wed, 09 Apr 2014 05:07:54 GMT Chris Johns [8ac8ebf] * bare/config/devel/gdb-7.7-1.cfg (added) * rtems/config/tools/rtems-gdb-7.7-1.cfg (added) config: Add gdb-7.7 support. Wed, 09 Apr 2014 05:07:29 GMT Chris Johns [a1bba9d] * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) config: Make FreeBSD 10 port patch specific to FreeBSD. Wed, 26 Mar 2014 06:12:05 GMT Chris Johns [ed8a66a] * rtems/config/snapshots/gcc-4.8-branch.mc (added) * source-builder/config/gcc-common-1.cfg (modified) config: Add support for gcc-4.8-branch testing. Thu, 20 Mar 2014 20:47:14 GMT Joel Sherrill [40d25dc] * rtems/config/4.11/rtems-v850.bset (modified) 4.11/rtems-v850.bset: Add gcc 4.8.2 patch Thu, 20 Mar 2014 00:06:10 GMT Chris Johns [9b1ae21] * doc/source-builder.txt (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) freebsd: Add support for FreeBSD 10.0. GDB did not build out of the ... Tue, 04 Feb 2014 07:18:21 GMT Chris Johns [d9c1a48] * rtems/config/rtems-base.bset (modified) rtems/gcc: Clean up the RSB version message. Tue, 21 Jan 2014 03:09:47 GMT Chris Johns [2be445d] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (added) 4.11/lm32: Fix the move to newlib 2.1.0. Tue, 21 Jan 2014 01:03:30 GMT Chris Johns [53141b4] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (added) 4.11: Move to the released newlib-2.1.0. Sat, 18 Jan 2014 06:29:39 GMT Chris Johns [16e469a] * rtems/config/4.11/rtems-sparc.bset (modified) 4.11/sparc/gdb: Use SIS patch to fix gdb outout and run fail. Wed, 18 Dec 2013 16:10:47 GMT Alan Cudmore [44e82d8] * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) Removed check for texinfo 5.x. Binutils 2.24 and gcc 4.8.2 build with ... Sat, 14 Dec 2013 01:21:27 GMT Chris Johns [69dca93] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (added) Update to binutils 2.24, gcc 4.8.2, newlib 11-Dec-2013 and gdb 7.6.2. ... Sun, 15 Sep 2013 22:25:42 GMT Chris Johns [0dd3013] * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) rtems: Newlib version CVS 15-Sept-2013 Fri, 06 Sep 2013 05:56:59 GMT Chris Johns [f4a8a42] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) rtems: Revert gdb to gdb-7.6 as gdb-7.6.1 fails. Mon, 02 Sep 2013 23:20:17 GMT Chris Johns [169619c] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) config: Disable building RTEMS by default. To build use --with-rtems. Mon, 02 Sep 2013 22:33:08 GMT Chris Johns [18b01e8] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (added) config: Update RTEMS to gdb-7.6.1. Thu, 22 Aug 2013 01:41:10 GMT Chris Johns [51a669f] * rtems/config/4.11/rtems-m32c.bset (modified) config: Disable ICONV support for the m32c. Wed, 21 Aug 2013 02:36:08 GMT Chris Johns [407f7ff] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) config: Fix the without_rtems macro. Wed, 14 Aug 2013 04:06:30 GMT Chris Johns [27d6ea0] * rtems/config/4.11/rtems-avr.bset (modified) * source-builder/config/gcc-common-1.cfg (modified) config: Add support for iconv encodings. Turn off iconv support for ... Wed, 14 Aug 2013 04:05:57 GMT Chris Johns [5118d73] * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) config: Change to use the GCC POSIX thread model. Wed, 14 Aug 2013 04:04:53 GMT Chris Johns [b830445] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) config: Support --without-rtems to not build RTEMS. The default is ... Thu, 08 Aug 2013 01:45:12 GMT Chris Johns [9e9162b] * rtems/config/4.11/rtems-all.bset (modified) config: Do not build autotools when building 4.11/rtems-all. Thu, 08 Aug 2013 01:43:52 GMT Chris Johns [ff0fc8e] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * source-builder/config/versions.cfg (modified) config: Check the path for a valid autoconf. Tue, 23 Jul 2013 12:19:34 GMT Chris Johns [9c150cf] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) config: PR 2134 - Return the missing =. Sat, 20 Jul 2013 22:55:11 GMT Chris Johns [6d32fe7] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) CONFIG: PR 2127 - Build fails on Linux. Fix shell tests where '==' ... Tue, 16 Jul 2013 00:02:41 GMT Chris Johns [ebf8a1f] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools-base.bset (added) * rtems/config/4.11/rtems-autotools-internal.bset (added) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-autoconf-2.69-1.cfg (added) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (added) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/versions.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/setbuilder.py (modified) Automtically build the Autotools to bootstrap RTEMS. This changes ... Tue, 16 Jul 2013 00:01:19 GMT Chris Johns [c2effc1] * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) Move newlib to 14-Jul-2013. Build with Sebastian's pending upstream ... Wed, 19 Jun 2013 04:41:58 GMT Chris Johns [a06414c] * rtems/config/4.11/rtems-avr.bset (modified) Use target flags that lets the AVR tools build. Wed, 19 Jun 2013 04:37:48 GMT Chris Johns [9e0f6af] * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) Update the NIOS tools to support Cxc. Thu, 06 Jun 2013 05:13:18 GMT Chris Johns [8113b76] * rtems/config/4.11/rtems-m32c.bset (modified) m32c: As per GCC PR 50928 use -O0 to build libgcc. Fri, 31 May 2013 23:38:54 GMT Chris Johns [c36107a] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (added) gcc: RTEMS 4.11 uses 4.8.1 release. Fri, 31 May 2013 23:20:12 GMT Chris Johns [699a5e58] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Reset the CVS repo each run to remove any applied patches. Fri, 31 May 2013 22:49:27 GMT Chris Johns [47d7a552] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) newlib: Move to 31-May-2013. Fix the stack_t patcher. Fri, 31 May 2013 02:56:28 GMT Chris Johns [6bf5b3f] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Add Joel's stack_t patch. Fri, 31 May 2013 02:56:08 GMT Chris Johns [07aee95] * rtems/config/4.11/rtems-powerpc.bset (modified) Patch merged upstream. Wed, 22 May 2013 06:00:07 GMT Yin Yan [347e182] * rtems/config/4.10/rtems-arm.bset (modified) * rtems/config/4.10/rtems-autotools.bset (modified) * rtems/config/4.10/rtems-avr.bset (modified) * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.10/rtems-h8300.bset (modified) * rtems/config/4.10/rtems-i386.bset (modified) * rtems/config/4.10/rtems-lm32.bset (modified) * rtems/config/4.10/rtems-m32c.bset (modified) * rtems/config/4.10/rtems-m32r.bset (modified) * rtems/config/4.10/rtems-m68k.bset (modified) * rtems/config/4.10/rtems-mips.bset (modified) * rtems/config/4.10/rtems-nios2.bset (modified) * rtems/config/4.10/rtems-powerpc.bset (modified) * rtems/config/4.10/rtems-sh.bset (modified) * rtems/config/4.10/rtems-sparc.bset (modified) * rtems/config/4.9/rtems-arm.bset (modified) * rtems/config/4.9/rtems-autotools.bset (modified) * rtems/config/4.9/rtems-i386.bset (modified) * rtems/config/4.9/rtems-m68k.bset (modified) * rtems/config/4.9/rtems-mips.bset (modified) * rtems/config/4.9/rtems-powerpc.bset (modified) * rtems/config/4.9/rtems-sparc.bset (modified) * rtems/config/tools/rtems-kernel-4.10.2.cfg (modified) * rtems/config/tools/rtems-kernel-4.9.6-1.cfg (modified) fix the problems for the set build of 4.9 and 4.10 1. "expat-2.1.0-1 ... Wed, 22 May 2013 06:51:27 GMT Amar Takhar [54c7330] * rtems/config/4.11/rtems-powerpc.bset (modified) Add newlib-remove-machine-powerpc-times_c.diff to powerpc build. Mon, 20 May 2013 07:19:47 GMT Chris Johns [d925ea3] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) Align the 4.8 and 4.5 configurations with the gcc-common. Sat, 18 May 2013 00:56:02 GMT Amar Takhar [06c0200] * rtems/config/4.11/rtems-moxie.bset (modified) Fix prepend /moxie/ to path location. Fixes downloading. Sat, 18 May 2013 00:55:28 GMT Amar Takhar [7142b8f] * rtems/config/rtems-base.bset (modified) Remove .git in rtem-tools repo after repo name cleanup. This fixes ... Thu, 16 May 2013 23:56:30 GMT Cynthia Rempel [5172f31] * rtems/config/4.11/rtems-autotools.bset (modified) Update the buildset to use automake-1.12.6, which is required by ... Thu, 16 May 2013 08:19:54 GMT Amar Takhar [a08fcae] * rtems/config/4.11/rtems-moxie.bset (modified) Add moxie patch, this fixes the build. Wed, 15 May 2013 03:23:08 GMT Chris Johns [53027a9] * rtems/config/4.11/rtems-moxie.bset (modified) Moxie GDB patch has been merged upstream. Tue, 14 May 2013 01:08:02 GMT Chris Johns [1a56a07] * bare/config/devel/autoconf-2.68-1.cfg (moved) * bare/config/devel/autoconf-2.69-1.cfg (moved) * bare/config/devel/autoconf-internal-2.68-1.cfg (moved) * bare/config/devel/automake-1.12-1.cfg (moved) * bare/config/devel/automake-1.12.2-1.cfg (moved) * bare/config/devel/automake-internal-1.12-1.cfg (moved) * bare/config/devel/binutils-2.22-1.cfg (moved) * bare/config/devel/dtc-1.2.0.cfg (moved) * bare/config/devel/expat-2.1.0-1.cfg (moved) * bare/config/devel/gcc-4.6-newlib-1.20-1.cfg (moved) * bare/config/devel/gcc-4.7-newlib-1.20-1.cfg (moved) * bare/config/devel/libusb-1.0.9-1.cfg (moved) * bare/config/devel/m4-1.4.16-1.cfg (moved) * bare/config/devel/texane-stlink-1.cfg (moved) * bare/config/gnu-tools-4.6.bset (moved) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * source-builder/defaults.mc (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/options.py (modified) Add bare/config and move the source-builder/config to it. Rework ... Mon, 13 May 2013 04:48:31 GMT Chris Johns [df9c081] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Newlib CVS: 13-May-2013. Pick up the atexit changes. Thu, 09 May 2013 22:33:44 GMT Chris Johns [dd8534a] * rtems/config/4.11/rtems-mips.bset (modified) MIPS patches in newlib head and we are using that. Tue, 07 May 2013 23:56:59 GMT Chris Johns [bc19332] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Newlib 8-May-2013: Include Sebastian's atexit changes. Tue, 07 May 2013 23:56:16 GMT Chris Johns [0e358bf] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) By default hard reset the RTEMS repo on a build. Fri, 03 May 2013 00:39:30 GMT Chris Johns [a6d6d31] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Forgot to remove the master branch from the URL. Fri, 03 May 2013 00:08:06 GMT Chris Johns [6159bfd] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Reset the repo before the pull it avoid any local changes effecting ... Thu, 02 May 2013 21:53:41 GMT Chris Johns [cd3d3ae] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Move to the gcc-4.8 branch until 4.8.1 comes out. Tue, 30 Apr 2013 05:09:13 GMT Chris Johns [1aade53] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg (added) rtems-4.11: binutils 2.23.2, gcc-4.8.0, newlib-cvs-30-April-2013, gdb-7.6 Tue, 30 Apr 2013 05:01:30 GMT Chris Johns [a48a478] * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gdb-7.6-1.cfg (added) * source-builder/config/gcc-4.8-1.cfg (modified) Updated 4.11 tool versions. Mon, 29 Apr 2013 22:19:15 GMT Joel Sherrill [c931fbe] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) rtems/config/4.11/rtems-*.bset: Add gdb based BSPs for testing Also ... Mon, 29 Apr 2013 00:23:06 GMT Chris Johns [699a51c5] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) Fix the C++ tools detection bug. Sun, 28 Apr 2013 22:57:17 GMT Chris Johns [a702d9f] * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) Remove the .cfg. Not needed. Sun, 28 Apr 2013 22:52:24 GMT Chris Johns [c4c8a12] * rtems/config/4.11/rtems-arm.bset (modified) The BSP list is comma seperated. Sun, 28 Apr 2013 07:49:34 GMT Chris Johns [41219dc] * rtems/config/4.11/rtems-arm.bset (modified) Remove the lm3s3749 BSP because it does not build with head ... Sun, 28 Apr 2013 02:54:47 GMT Chris Johns [b3b8dd3] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) Always build RTEMS. Sun, 28 Apr 2013 02:54:00 GMT Chris Johns [c12323f] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) Undefine rtems_bsp is set to all. Configure without bsps means all.
