@114ef08
07/25/14 04:55:14 |
Chris Johns |
RTEMS 4.11 Update to gcc-4.8.3 with Newlib CVS 26-Jul-2014.
Refactor …
4.104.114.95
@396db46
06/01/14 07:58:55 |
Chris Johns |
config: Update the NIOS2 configuration for the new %source command.
4.104.114.95
@9a15c40
05/13/14 13:26:09 |
Chris Johns |
sb: Implement %source and %patch to manage source and patches.
Remove …
4.104.114.95
@e074e75
05/09/14 01:20:38 |
Chris Johns |
4.11/rtems-lm32: Use gcc-4.9.0 and fix gdb simulator build on Windows. …
4.104.114.95
@3adcfbf
05/02/14 10:48:49 |
Chris Johns |
rtems/4.11: Fix _host_os for building on FreeBSD. It needs to be _build_os.
4.104.114.95
@43252be
05/01/14 05:38:09 |
Chris Johns |
config: Update to gdb-7.7 for a range of archs.
Update lm32, m32c, …
4.104.114.95
@6fe63b3
04/28/14 02:18:00 |
Chris Johns |
config: Remove the POSIX thread model patch.
Switch back the RTEMS …
4.104.114.95
@6b7b22a
04/10/14 08:27:17 |
Chris Johns |
config: Use _host_os for conditional checks.
4.104.114.95
@7a6d42e
04/10/14 08:22:23 |
Chris Johns |
config: Fix for sim common code on Mavrick.
4.104.114.95
@8ac8ebf
04/09/14 05:07:54 |
Chris Johns |
config: Add gdb-7.7 support.
4.104.114.95
@a1bba9d
04/09/14 05:07:29 |
Chris Johns |
config: Make FreeBSD 10 port patch specific to FreeBSD.
4.104.114.95
@9b1ae21
03/20/14 00:06:10 |
Chris Johns |
freebsd: Add support for FreeBSD 10.0.
GDB did not build out of the …
4.104.114.95
@2be445d
01/21/14 03:09:47 |
Chris Johns |
4.11/lm32: Fix the move to newlib 2.1.0.
4.104.114.95
@53141b4
01/21/14 01:03:30 |
Chris Johns |
4.11: Move to the released newlib-2.1.0.
4.104.114.95
@44e82d8
12/18/13 16:10:47 |
alan.cudmore |
Removed check for texinfo 5.x. Binutils 2.24 and gcc 4.8.2 build with …
4.104.114.95
@69dca93
12/14/13 01:21:27 |
Chris Johns |
Update to binutils 2.24, gcc 4.8.2, newlib 11-Dec-2013 and gdb 7.6.2.
4.104.114.95
@0dd3013
09/15/13 22:25:42 |
Chris Johns |
rtems: Newlib version CVS 15-Sept-2013
4.104.114.95
@169619c
09/02/13 23:20:17 |
Chris Johns |
config: Disable building RTEMS by default.
To build use --with-rtems.
4.104.114.95
@18b01e8
09/02/13 22:33:08 |
Chris Johns |
config: Update RTEMS to gdb-7.6.1.
4.104.114.95
@407f7ff
08/21/13 02:36:08 |
Chris Johns |
config: Fix the without_rtems macro.
4.104.114.95
@5118d73
08/14/13 04:05:57 |
Chris Johns |
config: Change to use the GCC POSIX thread model.
4.104.114.95
@b830445
08/14/13 04:04:53 |
Chris Johns |
config: Support --without-rtems to not build RTEMS.
The default is to …
4.104.114.95
@ff0fc8e
08/08/13 01:43:52 |
Chris Johns |
config: Check the path for a valid autoconf.
4.104.114.95
@9c150cf
07/23/13 12:19:34 |
Chris Johns |
config: PR 2134 - Return the missing =.
4.104.114.95
@6d32fe7
07/20/13 22:55:11 |
Chris Johns |
CONFIG: PR 2127 - Build fails on Linux.
Fix shell tests where '==' …
4.104.114.95
@ebf8a1f
07/16/13 00:02:41 |
Chris Johns |
Automtically build the Autotools to bootstrap RTEMS.
This changes …
4.104.114.95
@c2effc1
07/16/13 00:01:19 |
Chris Johns |
Move newlib to 14-Jul-2013.
Build with Sebastian's pending upstream …
4.104.114.95
@9e0f6af
06/19/13 04:37:48 |
Chris Johns |
Update the NIOS tools to support Cxc.
4.104.114.95
@c36107a
05/31/13 23:38:54 |
Chris Johns |
gcc: RTEMS 4.11 uses 4.8.1 release.
4.104.114.95
@699a5e58
05/31/13 23:20:12 |
Chris Johns |
Reset the CVS repo each run to remove any applied patches.
4.104.114.95
@47d7a552
05/31/13 22:49:27 |
Chris Johns |
newlib: Move to 31-May-2013. Fix the stack_t patcher.
4.104.114.95
@6bf5b3f
05/31/13 02:56:28 |
Chris Johns |
Add Joel's stack_t patch.
4.104.114.95
@347e182
05/22/13 06:00:07 |
yinyan |
fix the problems for the set build of 4.9 and 4.10 1. "expat-2.1.0-1 …
4.104.114.95
@d925ea3
05/20/13 07:19:47 |
Chris Johns |
Align the 4.8 and 4.5 configurations with the gcc-common.
4.104.114.95
@df9c081
05/13/13 04:48:31 |
Chris Johns |
Newlib CVS: 13-May-2013. Pick up the atexit changes.
4.104.114.95
@bc19332
05/07/13 23:56:59 |
Chris Johns |
Newlib 8-May-2013: Include Sebastian's atexit changes.
4.104.114.95
@0e358bf
05/07/13 23:56:16 |
Chris Johns |
By default hard reset the RTEMS repo on a build.
4.104.114.95
@a6d6d31
05/03/13 00:39:30 |
Chris Johns |
Forgot to remove the master branch from the URL.
4.104.114.95
@6159bfd
05/03/13 00:08:06 |
Chris Johns |
Reset the repo before the pull it avoid any local changes effecting things.
4.104.114.95
@cd3d3ae
05/02/13 21:53:41 |
Chris Johns |
Move to the gcc-4.8 branch until 4.8.1 comes out.
4.104.114.95
@1aade53
04/30/13 05:09:13 |
Chris Johns |
rtems-4.11: binutils 2.23.2, gcc-4.8.0, newlib-cvs-30-April-2013, gdb-7.6
4.104.114.95
@a48a478
04/30/13 05:01:30 |
Chris Johns |
Updated 4.11 tool versions.
4.104.114.95
@699a51c5
04/29/13 00:23:06 |
Chris Johns |
Fix the C++ tools detection bug.
4.104.114.95
@c12323f
04/28/13 02:54:00 |
Chris Johns |
Undefine rtems_bsp is set to all. Configure without bsps means all.
4.104.114.95
@3ff992b
04/27/13 10:34:47 |
Chris Johns |
Disable C++ if not built. Use the faster bootstrap.
4.104.114.95
@ccaa68e
04/27/13 10:28:19 |
Chris Johns |
Disable selects for the NIOS due to the specific versions needed.
4.104.114.95
@86b2b4f
04/23/13 06:03:25 |
Chris Johns |
Add support to check for a valid autoconf for RTEMS.
4.104.114.95
@f077b2b
04/22/13 12:28:27 |
Chris Johns |
Fixes for CVS to work. Add RTEMS build for sparc/sis.
4.104.114.95
@cc2c48b
04/14/13 22:30:25 |
Chris Johns |
Switch to the regenerated gcc-4.7.3 patch.
4.104.114.95
@3e86a96
04/14/13 08:08:10 |
Chris Johns |
Update RTEMS 4.11 to GCC 4.7.3.
All build sets for RTEMS 4.11 that …
4.104.114.95
@4f26bdb
04/01/13 04:19:56 |
Chris Johns |
Add Canadian Cross support.
Add support to build MinGW tools using …
4.104.114.95
@aabe4e7
03/21/13 11:52:10 |
Chris Johns |
Use ftp.rtems.org and not www.rtems.org.
4.104.114.95
@a8a3af2
03/21/13 11:45:15 |
Chris Johns |
Build RTEMS 4.9.6.
4.104.114.95
@2a37e1a
03/20/13 05:04:13 |
Chris Johns |
Add RTEMS patch support.
4.104.114.95
@e3aa355
03/19/13 22:41:23 |
Chris Johns |
Add support for RTEMS 4.10.
This change adds support for RTEMS 4.10 …
4.104.114.95
@5439e8f
03/19/13 03:28:40 |
mb.dhananjay |
GCC 4.7.2 is incompatible with Texinfo 5
4.104.114.95
@896a832
03/16/13 00:03:19 |
Chris Johns |
Use GMP 5.0.5 with MPFR 2.4.2 on gcc-4.3.2.
4.104.114.95
@3643c48
03/15/13 04:33:59 |
Chris Johns |
Add RTEMS 4.9 support for i386 and SPARC.
4.104.114.95
@1efc3f7
03/12/13 23:50:10 |
Chris Johns |
Add missing RTEMS patches to binutils-2.23.1.
4.104.114.95
@a57d9f0
03/12/13 09:09:22 |
Chris Johns |
Remove arch configurations as build sets are used.
4.104.114.95
@48e1cd4
03/10/13 23:58:40 |
Chris Johns |
Move all patches to the rtems-tools.git repo.
All patches are now …
4.104.114.95
@3e1a845
03/10/13 03:53:08 |
Chris Johns |
Microblaze support for ldscript patch.
4.104.114.95
@fdc8e0c
03/10/13 03:52:04 |
Chris Johns |
Fix comments.
4.104.114.95
@98e7a7b
03/08/13 23:48:36 |
Chris Johns |
Patch to fix strsignal for the LM32 gcc-4.5.3.
4.104.114.95
@8301afa
03/08/13 21:12:47 |
Chris Johns |
Switch LM32 to gcc-4.5.3.
This is the reported known working tool set …
4.104.114.95
@876f07d
03/08/13 08:10:33 |
Chris Johns |
MIPS Newlib 2.0.0 patches. Add the STX39 simulator.
There are a …
4.104.114.95
@f17665e
03/08/13 03:00:45 |
Chris Johns |
Add MIPS STX39 and Moxie specific GDB builds.
The MIPS STX39 is a …
4.104.114.95
@b521098
03/05/13 03:30:31 |
Chris Johns |
Clean up the per target C/C++ handling.
4.104.114.95
@735cd20
03/04/13 07:01:44 |
Chris Johns |
Unstable 4.11 is using gcc 4.8-20130303
4.104.114.95
@a32dcbd
02/20/13 03:46:51 |
Chris Johns |
Add unstable.
Add a tree of unstable configurations to track recent …
4.104.114.95
@87fc7e0
02/14/13 01:32:03 |
Chris Johns |
Add Moxie support.
Binutils and the compiler build how-ever gdb needs …
4.104.114.95
@d963553b
02/13/13 00:30:47 |
Chris Johns |
Restructure RTEMS Config Files
Add arch build files. This allows …
4.104.114.95
