# # ChangeLog for rtems/config/tools in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 03/29/24 00:35:38 Wed, 06 Jun 2018 07:49:29 GMT Sebastian Huber [8ef0d73] * rtems/config/5/rtems-riscv32.bset (modified) * rtems/config/5/rtems-riscv64.bset (modified) * rtems/config/tools/rtems-gdb-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg (added) 5: Add GDB for RISC-V Mainline GDB support for RISC-V is not yet in ... Wed, 06 Jun 2018 07:45:44 GMT Sebastian Huber [f432e19] * rtems/config/5/rtems-riscv32.bset (modified) * rtems/config/5/rtems-riscv64.bset (modified) * rtems/config/tools/rtems-binutils-773ff7907c05313aebbcd5e8319e5b869ac4f792.cfg (added) 5: Update RISC-V Binutils This includes the following bug fix: ... Fri, 04 May 2018 01:36:53 GMT Chris Johns [aa798b5] * rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg (modified) Revert "x86_64/gcc: Add gcc patch for LIB_SPEC (rtems.h in gcc)" ... Fri, 06 Apr 2018 22:24:45 GMT Amaan Cheval [8e76390] * rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg (modified) x86_64/gcc: Add gcc patch for LIB_SPEC (rtems.h in gcc) Adds ... Mon, 23 Apr 2018 08:01:36 GMT Chris Johns [10d3aaf] * rtems/config/tools/rtems-tools-5-1.cfg (modified) rtems-tools: Update to pick up the --enable-rtems-debug fix. Tue, 17 Apr 2018 08:20:08 GMT Sebastian Huber [50593d4] * rtems/config/tools/rtems-tools-5-1.cfg (modified) * rtems/config/tools/rtems-tools-common-1.cfg (modified) 5: Use a specific RTEMS tools version Download via cgit archive. ... Wed, 31 Jan 2018 08:29:14 GMT Sebastian Huber [703532c] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv32.bset (modified) * rtems/config/5/rtems-riscv64.bset (modified) * rtems/config/tools/rtems-binutils-2.30.cfg (moved) * rtems/config/tools/rtems-gcc-4.8.3-newlib-3.0.0.cfg (moved) * rtems/config/tools/rtems-gcc-4.9.3-newlib-3.0.0.cfg (moved) * rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg (moved) 5: Add versions to file names Mon, 29 Jan 2018 06:23:54 GMT Sebastian Huber [6d9c77c] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv32.bset (modified) * rtems/config/5/rtems-riscv64.bset (modified) * rtems/config/tools/rtems-binutils.cfg (added) 5: Update to Binutils 2.30 Fri, 26 Jan 2018 06:46:29 GMT Sebastian Huber [d7fd320] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv32.bset (modified) * rtems/config/5/rtems-riscv64.bset (modified) * rtems/config/tools/rtems-gcc-m32c.cfg (added) * rtems/config/tools/rtems-gcc-or1k.cfg (added) * rtems/config/tools/rtems-gcc.cfg (added) 5: Update to Newlib 3.0.0 and GCC 7.3 Epiphany target can now use ... Tue, 19 Dec 2017 08:38:44 GMT Sebastian Huber [f3b1700] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (modified) 5: Update SPARC chip errata workarounds Update #3242. Mon, 04 Dec 2017 07:03:00 GMT Sebastian Huber [7034d65] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (modified) 5: Ada: Fix more POSIX types Update #3256. Fri, 01 Dec 2017 11:07:29 GMT Sebastian Huber [d60799b] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (modified) 5: Ada: Fix some POSIX types Close #3256. Thu, 30 Nov 2017 08:37:11 GMT Sebastian Huber [ffbd5e9] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (modified) 5: Add SPARC chip errata workarounds Close #3242. Fri, 10 Nov 2017 09:09:15 GMT Sebastian Huber [8b30eb3] * rtems/config/5/rtems-mips.bset (modified) * rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg (added) 5: Update to special MIPS GDB to 8.0.1 Fri, 10 Nov 2017 08:54:19 GMT Sebastian Huber [831bc7e] * rtems/config/tools/rtems-gdb-7.8.1-1.cfg (modified) 5: Avoid rtems-tools for epiphany GDB Close #3226. Fri, 10 Nov 2017 08:34:12 GMT Sebastian Huber [ebe0053] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gdb-7.11-2.cfg (added) 5: Use custome GDB 7.11 without for or1k Do not include aarch64 and ... Fri, 10 Nov 2017 07:31:58 GMT Sebastian Huber [33f1deb] * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) 5: Use ticket attachment for automake patch Update #2616. Wed, 08 Nov 2017 08:52:12 GMT Sebastian Huber [c6b890c] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (modified) 5: Add Newlib patches Update #3185. Close #3189. Wed, 08 Nov 2017 08:31:58 GMT Sebastian Huber [637061c] * rtems/config/4.12/rtems-all.bset (deleted) * rtems/config/4.12/rtems-tier-3.bset (deleted) * rtems/config/5/rtems-aarch64.bset (moved) * rtems/config/5/rtems-all.bset (added) * rtems/config/5/rtems-arm.bset (moved) * rtems/config/5/rtems-autotools-base.bset (moved) * rtems/config/5/rtems-autotools-internal.bset (moved) * rtems/config/5/rtems-autotools.bset (moved) * rtems/config/5/rtems-bfin.bset (moved) * rtems/config/5/rtems-default.bset (moved) * rtems/config/5/rtems-epiphany.bset (moved) * rtems/config/5/rtems-i386.bset (moved) * rtems/config/5/rtems-lm32.bset (moved) * rtems/config/5/rtems-m32c.bset (moved) * rtems/config/5/rtems-m68k.bset (moved) * rtems/config/5/rtems-microblaze.bset (moved) * rtems/config/5/rtems-mips.bset (moved) * rtems/config/5/rtems-moxie.bset (moved) * rtems/config/5/rtems-nios2.bset (moved) * rtems/config/5/rtems-or1k.bset (moved) * rtems/config/5/rtems-powerpc.bset (moved) * rtems/config/5/rtems-riscv32.bset (moved) * rtems/config/5/rtems-riscv64.bset (moved) * rtems/config/5/rtems-sh.bset (moved) * rtems/config/5/rtems-sparc.bset (moved) * rtems/config/5/rtems-sparc64.bset (moved) * rtems/config/5/rtems-tier-1.bset (moved) * rtems/config/5/rtems-tier-2.bset (moved) * rtems/config/5/rtems-tier-3.bset (added) * rtems/config/5/rtems-tier-4.bset (moved) * rtems/config/5/rtems-tools.bset (moved) * rtems/config/5/rtems-v850.bset (moved) * rtems/config/5/rtems-x86_64.bset (moved) * rtems/config/rtems-version.bset (modified) * rtems/config/tools/rtems-kernel-5.cfg (moved) * rtems/config/tools/rtems-tools-5-1.cfg (moved) Change RTEMS version from 4.12 to 5 Update #3220. Mon, 23 Oct 2017 16:17:21 GMT Joel Sherrill [5295cb8a] * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) rtems-gdb-7.11-1.cfg: Correct sha512sum on gdb-7.11-sis- ... Thu, 12 Oct 2017 02:47:23 GMT Chris Johns [d94bd01] * bare/config/devel/autoconf-2.69-1.cfg (modified) * bare/config/devel/automake-1.12.6-1.cfg (modified) * bare/config/devel/dtc-1.4.1-1.cfg (modified) * bare/config/devel/expat-2.1.0-1.cfg (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.8.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.9-1.cfg (modified) 4.12: Update all MD5 hashes to SHA256. Closes #2536. Wed, 11 Oct 2017 12:07:23 GMT Joel Sherrill [c4b6bf0] * rtems/config/tools/rtems-binutils-2.29-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) Enable 64-bit BFD support. Needed on 32bit hosts Closes #3157. Thu, 05 Oct 2017 06:19:41 GMT Sebastian Huber [76d9db3] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-riscv32.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (added) 4.12: Update to Newlib 2.5.0.20170922 The time_t is now a 64-bit ... Sat, 09 Sep 2017 22:58:34 GMT Chris Johns [e6d0a8b] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) mips: Use the FreeBSD fix for Darwin MIP tools build. Closes 3127. Fri, 08 Sep 2017 11:41:00 GMT Sebastian Huber [c395d96] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gdb-8.0.1-1.cfg (added) 4.12: Update to GDB 8.0.1 Fri, 25 Aug 2017 12:35:05 GMT Sebastian Huber [4f364ef] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) 4.12: Change clock_t to 64-bit Update #2135. Update #3111. Tue, 22 Aug 2017 14:10:38 GMT Sebastian Huber [7e3ff84] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) 4.12: Fix 64-bit PowerPC support of GCC 7.2 Update #3082. Tue, 22 Aug 2017 13:07:37 GMT Sebastian Huber [beda114] * rtems/config/4.12/rtems-riscv32.bset (added) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) 4.12: Add basic RISC-V tool chain GDB is not included. This ... Tue, 22 Aug 2017 05:23:23 GMT Sebastian Huber [630e658c] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (added) * source-builder/config/gcc-7.2-1.cfg (added) 4.12: Update to GCC 7.2 Tue, 22 Aug 2017 05:05:00 GMT Sebastian Huber [0a18a8f] * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg (added) 4.12: Update to Newlib 2.5.0.20170818 Mon, 21 Aug 2017 07:24:23 GMT Chris Johns [bb004cd] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg (added) Update to the newlib snapshot 20170818. Thu, 10 Aug 2017 08:02:51 GMT Sebastian Huber [7208ab6] * rtems/config/tools/rtems-binutils-2.29-1.cfg (modified) 4.12: Fix for Binutils PR21884 See ... Tue, 08 Aug 2017 10:44:16 GMT Chris Johns [826e526] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) 4.12/gcc-4.8.3 Fix building with a newer version of gcc. Updates #2990. Tue, 08 Aug 2017 10:25:23 GMT Chris Johns [71c76d0] * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) gcc: Disable makeinfo cause newer versions do not build gcc-4.8 docs. ... Tue, 08 Aug 2017 05:24:05 GMT Sebastian Huber [2064f90] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg (added) 4.12: Update to Newlib 2.5.0.20170720 Mon, 31 Jul 2017 12:21:05 GMT Sebastian Huber [295c197] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) 4.12: Fix SIS patch URL Mon, 31 Jul 2017 12:15:22 GMT Jiri Gaisler [6efd9757] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) RSB: Update gdb-7.12 config to pull in latest sis patches Please ... Thu, 27 Jul 2017 11:36:33 GMT Sebastian Huber [1ceafe5] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-binutils-2.29-1.cfg (added) 4.12: Update to Binutils 2.29 Update #3082. Fri, 21 Jul 2017 16:08:07 GMT Jiri Gaisler [6347c47] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) Update gdb-7.12 config to pull in latest sis patches. This ... Mon, 17 Jul 2017 06:30:36 GMT Sebastian Huber [e2952bb] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Add LEON3FT store-store errata workaround Close #3057. Wed, 12 Jul 2017 06:14:44 GMT Sebastian Huber [8397320] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Fix bitset(9) Update #3059. Mon, 10 Jul 2017 06:15:46 GMT Sebastian Huber [fd03ba4] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Fix and update bitset(9) Update #3059. Fri, 30 Jun 2017 12:56:32 GMT Sebastian Huber [5ede1c7] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Enable global stdio streams Update #3012. Mon, 26 Jun 2017 06:13:01 GMT Sebastian Huber [78f44be] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170623 Fri, 23 Jun 2017 05:33:06 GMT Sebastian Huber [21a9010] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) Fix GDB 7.12 build on Darwin Close #3052. Tue, 20 Jun 2017 11:25:57 GMT Sebastian Huber [34a3103] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (modified) Fix GCC 7.1 for m68k https://gcc.gnu.org/bugzilla/show_bug.cgi?id=80970 Tue, 13 Jun 2017 06:24:14 GMT Sebastian Huber [0ba8934] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg (modified) Fix for GCC 6 while building with GCC 7+ Mon, 12 Jun 2017 07:23:21 GMT Sebastian Huber [c336dc9] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (modified) 4.12: Add SMP support for Ada of GCC 7.1 Close #2289. Mon, 12 Jun 2017 06:56:44 GMT Sebastian Huber [a197dd9] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (modified) 4.12: Add Newlib patch for Update #2833. Mon, 12 Jun 2017 11:08:39 GMT Sebastian Huber [20bc1ec] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) Fix for GDB 7.12 while building with GCC 7+ Fri, 02 Jun 2017 09:17:41 GMT Sebastian Huber [6987fa5] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170519 Add POSIX header file ... Fri, 02 Jun 2017 08:40:15 GMT Sebastian Huber [b198c46] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (modified) Use default prerequisites for GCC 7.1 Use prerequisites as defined ... Tue, 06 Jun 2017 04:46:43 GMT Sebastian Huber [94083b0] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (modified) * source-builder/config/gcc-7-1.cfg (added) Add GCC 7 base configuration Wed, 31 May 2017 10:24:49 GMT Chris Johns [9b79c7b] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-powerpc.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (modified) Fixes to get a clean build with gcc-7.1.0/binutils-2.28. - SH has ... Fri, 12 May 2017 16:46:31 GMT Joel Sherrill [68d2cdd] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.28-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (added) Update tools to gcc 7.1.0 and binutils 2.28 Thu, 18 May 2017 05:15:19 GMT Chris Johns [5feef65] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) 4.12/powerpc/gdb: Fix building the simulator on FreeBSD. Thu, 18 May 2017 05:14:21 GMT Chris Johns [7ebd0e9] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg (modified) 4.12/mips: Fix building on FreeBSD. Thu, 13 Apr 2017 07:50:31 GMT Chris Johns [2074bd1] * rtems/config/tools/rtems-tools-common-1.cfg (modified) rtems-tools: Start a build with a distclean to clean away an old ... Tue, 11 Apr 2017 12:12:13 GMT Chris Johns [4141cca] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) Fix rtems-tools and rtems-kernel builds when released and with a ... Mon, 10 Apr 2017 07:30:06 GMT Chris Johns [44ebcc5] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) Fix the tools and kernel source URL when released to use `sources`. ... Tue, 04 Apr 2017 11:56:41 GMT Sebastian Huber [8e6ba2c] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg (modified) 4.12: Add Newlib patches for libbsd update Mon, 27 Mar 2017 06:20:00 GMT Chris Johns [b64b38e] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.12: Fix the patch URL. Mon, 27 Mar 2017 06:12:25 GMT Sebastian Huber [aa3d0fe] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170323 Sun, 26 Mar 2017 03:47:55 GMT Chris Johns [b47a811] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.11/arm: Fix the path to the sqrt patch. Use the upstream patch ... Thu, 23 Mar 2017 07:28:24 GMT Sebastian Huber [4e5b7fd] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.12: ARM: Optimize IEEE-754 sqrt implementation Update #2948. Thu, 02 Mar 2017 07:49:22 GMT Sebastian Huber [10d9e2d] * rtems/config/hash.cfg (deleted) * rtems/config/rtems-base.bset (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-2.cfg (deleted) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-2.cfg (deleted) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.12: Do not use a global hash file Tue, 07 Mar 2017 21:40:56 GMT Chris Johns [c6d162b] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) gdb: Fix building on FreeBSD 11.0 Add FreeBSD upstream patches to ... Wed, 01 Mar 2017 06:30:37 GMT Sebastian Huber [4c5eb89] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/hash.cfg (added) * rtems/config/rtems-base.bset (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-2.cfg (added) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-2.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170228 Tue, 17 Jan 2017 23:45:42 GMT Joel Sherrill [08f7099] * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0-1.cfg (added) 4.12/rtems-m32c.bset: Update to use newlib 2.5.0 Fri, 23 Dec 2016 08:13:51 GMT Sebastian Huber [e8bc7de] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0-1.cfg (added) Newlib and GCC update for RTEMS 4.12 Tue, 15 Nov 2016 00:02:29 GMT Joel Sherrill [1c68dbb] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) gdb-7.12-1: Fetch patch from rtems-tools Tue, 15 Nov 2016 00:02:22 GMT Joel Sherrill [1d61c3a] * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) gdb-7.11-1: Fetch patch from rtems-tools Mon, 14 Nov 2016 14:15:45 GMT Joel Sherrill [c10a803] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) gdb-7.12-1: Add support for leon2/leon3 to sis Mon, 14 Nov 2016 14:15:36 GMT Joel Sherrill [16fd45d] * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) gdb-7.11-1: Add support for leon2/leon3 to sis Mon, 14 Nov 2016 23:57:46 GMT Joel Sherrill [9c50131] * rtems/config/tools/rtems-binutils-2.27-1.cfg (modified) binutils-2.27-1: Fetch patch from rtems-tools Mon, 14 Nov 2016 23:57:32 GMT Joel Sherrill [a51bfa1] * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) binutils-2.26-1: Fetch patch from rtems-tools Mon, 14 Nov 2016 01:34:06 GMT Jiri Gaisler [00fe8f7] * rtems/config/tools/rtems-binutils-2.27-1.cfg (modified) binutils-2.27-1: Add patch for unaligned reloc on SPARC updates #2802. Mon, 14 Nov 2016 01:32:32 GMT Jiri Gaisler [623c8e7] * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) binutils-2.26-1: Add patch for unaligned reloc on SPARC closes #2802. Sun, 13 Nov 2016 20:00:22 GMT Joel Sherrill [2a39795] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gdb-7.12-1.cfg (added) * rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg (modified) rtems-default.bset: Update to gdb 7.12 Clean up comments in ... Thu, 10 Nov 2016 18:01:09 GMT Joel Sherrill [453fefe] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg (added) rtems-default.bset: Update to gcc-6-20161110 and newlib 2.4.0.20161025 Fri, 02 Sep 2016 03:25:48 GMT Joel Sherrill [74cecb8] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.27-1.cfg (added) rtems-default.bset: Update to binutils 2.27 Tue, 06 Sep 2016 06:40:34 GMT Chris Johns [7cdf319] * rtems/config/tools/rtems-kernel-4.12.cfg (modified) Fix comments. Mon, 13 Jun 2016 05:44:40 GMT Sebastian Huber [c476de6] * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0.20160527-1.cfg (added) 4.12/rtems-epiphany.bset: Use Newlib 2.4.0.20160527 Tue, 07 Jun 2016 22:49:53 GMT Hesham Almatary [04bff17] * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0.20160527-1.cfg (added) 4.12/rtems-or1k.bset: Use Newlib 2.4.0.20160527 Sun, 12 Jun 2016 18:51:10 GMT Jan Sommer [cd9258f] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg (added) 4.12/rtems-default.bset: Use GCC 6-20160609 This fixes an issue ... Wed, 08 Jun 2016 14:04:52 GMT Sebastian Huber [5ff2c0a] * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0.20160527-1.cfg (added) 4.12/rtems-m32c.bset: Use Newlib 2.4.0.20160527 Mon, 30 May 2016 13:07:41 GMT Sebastian Huber [3da4d0e] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg (added) 4.12/rtems-default.bset: Use GCC 6-20160526 In addition use Newlib ... Mon, 18 Apr 2016 10:47:31 GMT Sebastian Huber [8bcc58b] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg (added) 4.12/rtems-default.bset: Use GCC 6.0.1-RC-20160415 Fri, 15 Apr 2016 01:49:50 GMT Chris Johns [c139715] * rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg (modified) 4.12: Add the newlib patch to get the updated ctr0.o. Sat, 09 Apr 2016 15:55:16 GMT Joel Sherrill [30783e3] * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg (added) 4.12/rtems-or1k.bset: Update newlib to 2.4.0 Sun, 10 Apr 2016 18:57:59 GMT Joel Sherrill [3343562] * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg (added) 4.12/rtems-m32c.bset: Update to newlib 2.4.0 Sun, 10 Apr 2016 18:46:52 GMT Joel Sherrill [74bb278] * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg (added) 4.12/rtems-epiphany.bset: Update to newlib 2.4.0 Sun, 03 Apr 2016 19:10:46 GMT Joel Sherrill [21650e5] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg (added) 4.12/rtems-default.bset: Update to gcc 6.20160327 and newlib-2.4.0 Thu, 17 Mar 2016 23:50:59 GMT Chris Johns [07eef42] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (deleted) * rtems/config/tools/rtems-kernel-4.12.cfg (added) 4.12/rtems-kernel: Add default support to build a kernel if asked too. Thu, 17 Mar 2016 23:49:55 GMT Chris Johns [a102424] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) rtems/kernel: Move the --with-rtems logic in the common file. Wed, 16 Mar 2016 04:51:24 GMT Chris Johns [08aa888] * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) 4.12/gdb-7.11: Add ERC32 patches to fix the simulator. Updates #2644. Tue, 15 Mar 2016 02:25:39 GMT Chris Johns [276fdc4] * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) rtems/4.12: Add hash to gdb-7.11. Mon, 14 Mar 2016 07:20:21 GMT Chris Johns [b290154] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) rtems-kernel: Fix the --with-rtems/--without-rtems support when ... Mon, 14 Mar 2016 05:23:19 GMT Chris Johns [6e490ae] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) * source-builder/sb/download.py (modified) sb: Update download to check the config file for release URL control. ... Mon, 14 Mar 2016 04:12:41 GMT Chris Johns [703c854] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gdb-7.11-1.cfg (added) 4.12: Update GDB to gdb-7.11.
