# # ChangeLog for rtems/config/tools/rtems-kernel-6.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/05/24 05:02:28 Wed, 21 Sep 2022 03:55:22 GMT Chris Johns [ba4539b] * rtems/config/tools/rtems-kernel-6.cfg (modified) rtems/kernel: Update to the latest - Addition of the Polarfire ... Thu, 01 Sep 2022 05:41:21 GMT Chris Johns [29b944b] * rtems/config/tools/rtems-kernel-6.cfg (modified) rtems/kernel: Update to the latest kernel - Update hash file extension Tue, 12 Oct 2021 19:01:44 GMT Ryan Long [def9347] * rtems/config/tools/rtems-kernel-6.cfg (modified) * rtems/config/tools/rtems-kernel-common.cfg (modified) * source-builder/sb/rtems-kernel-config-check (added) rtems-kernel: Implement kernel recipe using waf Closes #4145 Thu, 13 Aug 2020 01:44:23 GMT Chris Johns [40af487d] * rtems/config/5/bsps/atsamv.bset (deleted) * rtems/config/5/bsps/imx7.bset (deleted) * rtems/config/5/bsps/qoriq_e500.bset (deleted) * rtems/config/5/bsps/qoriq_e6500_32.bset (deleted) * rtems/config/5/bsps/qoriq_e6500_64.bset (deleted) * rtems/config/5/rtems-aarch64.bset (deleted) * rtems/config/5/rtems-all.bset (deleted) * rtems/config/5/rtems-arm.bset (deleted) * rtems/config/5/rtems-autotools-base.bset (deleted) * rtems/config/5/rtems-autotools-internal.bset (deleted) * rtems/config/5/rtems-autotools.bset (deleted) * rtems/config/5/rtems-bfin.bset (deleted) * rtems/config/5/rtems-default.bset (deleted) * rtems/config/5/rtems-epiphany.bset (deleted) * rtems/config/5/rtems-i386.bset (deleted) * rtems/config/5/rtems-lm32.bset (deleted) * rtems/config/5/rtems-m68k.bset (deleted) * rtems/config/5/rtems-microblaze.bset (deleted) * rtems/config/5/rtems-mips.bset (deleted) * rtems/config/5/rtems-moxie.bset (deleted) * rtems/config/5/rtems-nios2.bset (deleted) * rtems/config/5/rtems-or1k.bset (deleted) * rtems/config/5/rtems-powerpc.bset (deleted) * rtems/config/5/rtems-riscv.bset (deleted) * rtems/config/5/rtems-sh.bset (deleted) * rtems/config/5/rtems-sparc.bset (deleted) * rtems/config/5/rtems-sparc64.bset (deleted) * rtems/config/5/rtems-tier-1.bset (deleted) * rtems/config/5/rtems-tier-2.bset (deleted) * rtems/config/5/rtems-tier-3.bset (deleted) * rtems/config/5/rtems-tier-4.bset (deleted) * rtems/config/5/rtems-v850.bset (deleted) * rtems/config/5/rtems-x86_64.bset (deleted) * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-kernel.bset (moved) * rtems/config/6/rtems-libbsd.bset (moved) * rtems/config/6/rtems-llvm.bset (moved) * rtems/config/6/rtems-packages.bset (moved) * rtems/config/6/rtems-tools.bset (moved) * rtems/config/bsps/atsamv.bset (added) * rtems/config/bsps/beagleboneblack.bset (moved) * rtems/config/bsps/erc32.bset (moved) * rtems/config/bsps/gr712rc.bset (moved) * rtems/config/bsps/gr740.bset (moved) * rtems/config/bsps/imx7.bset (added) * rtems/config/bsps/pc.bset (moved) * rtems/config/bsps/qoriq_e500.bset (added) * rtems/config/bsps/qoriq_e6500_32.bset (added) * rtems/config/bsps/qoriq_e6500_64.bset (added) * rtems/config/bsps/raspberrypi2.bset (moved) * rtems/config/bsps/xilinx_zynq_zc702.bset (moved) * rtems/config/bsps/xilinx_zynq_zc706.bset (moved) * rtems/config/bsps/xilinx_zynq_zedboard.bset (moved) * rtems/config/ftp/curl.bset (modified) * rtems/config/net-mgmt/net-snmp.bset (modified) * rtems/config/tools/rtems-kernel-5.cfg (deleted) * rtems/config/tools/rtems-kernel-6.cfg (added) * rtems/config/tools/rtems-kernel-common.cfg (modified) * rtems/config/tools/rtems-libbsd-6.cfg (moved) Move 5 build sets to 6 - Move 5/bsps/* to bsps/* - Update package ...
