# # ChangeLog for rtems/config/tools/rtems-gdb-7.8.2-1.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/20/24 12:38:29 Thu, 12 Mar 2015 06:44:38 GMT Chris Johns [7f7d388] * rtems/config/tools/rtems-gdb-7.8.2-1.cfg (modified) Add gdb-7.8.2 hash. Fri, 06 Feb 2015 23:43:31 GMT Chris Johns [81ccf41] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gdb-7.8.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.8.2-1.cfg (added) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/gdb-7.8.1-1.cfg (deleted) Update all 4.11 archs to newlib-2.2.0-1 and gdb-7.8.2 where possible. ...
