# # ChangeLog for rtems/config/tools/rtems-gcc-head-newlib-head.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 06/16/24 02:43:23 Mon, 06 May 2019 06:59:58 GMT Sebastian Huber [c80ab5b] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 12 Apr 2019 07:26:40 GMT Sebastian Huber [780a2cf] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 02 Apr 2019 09:25:59 GMT Sebastian Huber [9a3e12e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 26 Mar 2019 06:09:20 GMT Sebastian Huber [cbbbc30] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 Mar 2019 13:31:18 GMT Sebastian Huber [e0aec65] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 Feb 2019 12:36:44 GMT Sebastian Huber [2e65068] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 25 Jan 2019 09:04:51 GMT Sebastian Huber [376edee] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 18 Jan 2019 09:00:34 GMT Sebastian Huber [0bb29a3] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Pick up a fix for Ada. Thu, 17 Jan 2019 14:31:34 GMT Sebastian Huber [1dfc4dd] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Use short Git hashes to avoid ... Wed, 16 Jan 2019 08:42:28 GMT Sebastian Huber [8b0e78a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 10 Jan 2019 08:40:47 GMT Sebastian Huber [f101ea1] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 03 Jan 2019 12:59:15 GMT Sebastian Huber [40ae056] * rtems/config/6/rtems-aarch64.bset (added) * rtems/config/6/rtems-all.bset (added) * rtems/config/6/rtems-arm.bset (added) * rtems/config/6/rtems-autotools-base.bset (added) * rtems/config/6/rtems-autotools-internal.bset (added) * rtems/config/6/rtems-autotools.bset (added) * rtems/config/6/rtems-base.bset (added) * rtems/config/6/rtems-bfin.bset (added) * rtems/config/6/rtems-default.bset (added) * rtems/config/6/rtems-epiphany.bset (added) * rtems/config/6/rtems-i386.bset (added) * rtems/config/6/rtems-lm32.bset (added) * rtems/config/6/rtems-m68k.bset (added) * rtems/config/6/rtems-microblaze.bset (added) * rtems/config/6/rtems-mips.bset (added) * rtems/config/6/rtems-moxie.bset (added) * rtems/config/6/rtems-nios2.bset (added) * rtems/config/6/rtems-or1k.bset (added) * rtems/config/6/rtems-powerpc.bset (added) * rtems/config/6/rtems-riscv.bset (added) * rtems/config/6/rtems-sh.bset (added) * rtems/config/6/rtems-sparc.bset (added) * rtems/config/6/rtems-sparc64.bset (added) * rtems/config/6/rtems-v850.bset (added) * rtems/config/6/rtems-x86_64.bset (added) * rtems/config/tools/rtems-binutils-head.cfg (added) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (added) * rtems/config/tools/rtems-gdb-head.cfg (added) * rtems/config/tools/rtems-mipstx39-gdb-head.cfg (added) 6: Add unstable RTEMS 6 tool chain
