# # ChangeLog for rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/15/24 15:38:28 Wed, 23 Jan 2019 12:41:30 GMT Sebastian Huber [f07504d] * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-6-1.cfg (modified) * source-builder/config/gcc-7-1.cfg (modified) * source-builder/config/gcc-7.2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/defaults.mc (modified) Use HTTPS instead of FTP FTP is an outdated protocol and blocked by ... Mon, 30 May 2016 13:07:41 GMT Sebastian Huber [3da4d0e] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg (added) 4.12/rtems-default.bset: Use GCC 6-20160526 In addition use Newlib ...
