# # ChangeLog for rtems/config/tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/31/24 10:29:32 Mon, 06 Jul 2015 13:40:32 GMT Sebastian Huber [8a7660c] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg (added) rtems4.11: Use GCC 4.9.3
