# # ChangeLog for rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/15/24 19:21:27 Tue, 27 Jan 2015 01:36:53 GMT Chris Johns [7c7eb86] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg (added) Change to using newlib snapshot release 2.2.0-1 and gdb 7.8.1.
