# # ChangeLog for rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/21/24 06:22:44 Tue, 13 May 2014 13:26:09 GMT Chris Johns [9a15c40] * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-binutils-patches.cfg (deleted) * rtems/config/rtems-gcc-patches.cfg (deleted) * rtems/config/rtems-gdb-patches.cfg (deleted) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-6.8-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (added) * source-builder/sb/version.py (modified) sb: Implement %source and %patch to manage source and patches. ... Tue, 21 Jan 2014 03:09:47 GMT Chris Johns [2be445d] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (added) 4.11/lm32: Fix the move to newlib 2.1.0.
