# # ChangeLog for rtems/config/tools/rtems-binutils-head.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/01/24 22:41:50 Thu, 10 Nov 2022 15:22:47 GMT Sebastian Huber [94a5f52] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Fri, 04 Nov 2022 11:10:08 GMT Sebastian Huber [f6907014] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Fri, 14 Oct 2022 09:32:06 GMT Sebastian Huber [e24641b] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Close #4741. Thu, 08 Sep 2022 07:10:46 GMT Sebastian Huber [ec69635] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Fri, 01 Jul 2022 12:40:53 GMT Sebastian Huber [a4608ce] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Mon, 09 May 2022 05:54:56 GMT Sebastian Huber [c166f28] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Tue, 03 May 2022 06:21:31 GMT Sebastian Huber [5866194] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Wed, 27 Apr 2022 13:30:20 GMT Sebastian Huber [a53d2c9] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Wed, 27 Apr 2022 06:24:25 GMT Sebastian Huber [eca88d9] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Tue, 22 Mar 2022 19:02:31 GMT Sebastian Huber [53cb27c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GCC, and GDB Fri, 25 Feb 2022 06:49:16 GMT Sebastian Huber [4cdec14] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Wed, 13 Oct 2021 14:31:06 GMT Ryan Long [e04fddc] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.37.cfg (added) * rtems/config/tools/rtems-binutils-head.cfg (modified) rtems-binutils: Update to 2.37 and update head Update to binutils ... Fri, 21 May 2021 16:24:10 GMT Joel Sherrill [774b5fc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) rtems-binutils-head.cfg, rtems-gdb-head.cfg: Bump to 3b2bef8 Fri, 09 Apr 2021 12:48:00 GMT Sebastian Huber [4e256fc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Tue, 16 Mar 2021 06:38:16 GMT Sebastian Huber [62363ba] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Tue, 09 Mar 2021 19:03:32 GMT Sebastian Huber [47d540e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Mon, 08 Mar 2021 10:52:48 GMT Sebastian Huber [56cba3c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 05 Mar 2021 06:16:07 GMT Sebastian Huber [102cb1e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 05 Feb 2021 06:49:46 GMT Sebastian Huber [61dcade] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Mon, 25 Jan 2021 09:45:30 GMT Sebastian Huber [c20cba7] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 22 Jan 2021 12:36:56 GMT Sebastian Huber [6a0be2a] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.36.cfg (added) * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (added) 6: Use release branches for Binutils/GDB Thu, 21 Jan 2021 09:07:21 GMT Sebastian Huber [65abc3e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 20 Jan 2021 05:20:46 GMT Sebastian Huber [7117899] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Sun, 17 Jan 2021 18:48:19 GMT Sebastian Huber [9c39684] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Thu, 14 Jan 2021 17:06:51 GMT Sebastian Huber [295f9e9] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 13 Jan 2021 09:51:49 GMT Sebastian Huber [3d30eca] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 04 Jan 2021 05:31:53 GMT Sebastian Huber [dd54653] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 21 Dec 2020 16:12:31 GMT Sebastian Huber [d3dc0bc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 21 Dec 2020 06:13:08 GMT Sebastian Huber [1af2038] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 02 Nov 2020 06:11:59 GMT Sebastian Huber [3d88829] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 28 Oct 2020 15:03:16 GMT Sebastian Huber [4c5af1f] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 26 Oct 2020 13:34:19 GMT Sebastian Huber [5f4fd63] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 12 Oct 2020 05:41:43 GMT Sebastian Huber [5237fdab] * rtems/config/6/rtems-i386.bset (modified) * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Fri, 18 Sep 2020 18:54:26 GMT Sebastian Huber [7595c3a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Fri, 04 Sep 2020 18:01:07 GMT Sebastian Huber [47f32b8] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 31 Aug 2020 10:11:55 GMT Sebastian Huber [2674290] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 29 Jul 2020 15:13:14 GMT Sebastian Huber [cc107b5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 29 Jul 2020 05:11:50 GMT Sebastian Huber [658af8f] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Fri, 03 Jul 2020 19:12:33 GMT Sebastian Huber [5ab61d2] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 29 Jun 2020 07:22:09 GMT Sebastian Huber [eb9c232] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 10 Jun 2020 06:45:47 GMT Sebastian Huber [cbae90a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 05 Jun 2020 08:00:27 GMT Sebastian Huber [fc3a57c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 02 Jun 2020 08:41:55 GMT Sebastian Huber [850d9b5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 May 2020 05:12:45 GMT Sebastian Huber [3bd11fd] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 28 Apr 2020 07:14:36 GMT Sebastian Huber [2f8bd58] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 17 Apr 2020 11:10:36 GMT Sebastian Huber [485eec6] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 06 Apr 2020 05:31:04 GMT Sebastian Huber [ad90540] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 23 Mar 2020 05:50:41 GMT Sebastian Huber [cc29f67] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 17 Mar 2020 06:50:32 GMT Sebastian Huber [96cdedc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 04 Feb 2020 12:02:46 GMT Sebastian Huber [f81b0a5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 02 Jan 2020 11:45:45 GMT Sebastian Huber [2fe8c3a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 20 Dec 2019 11:11:32 GMT Sebastian Huber [5701190] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 04 Dec 2019 08:03:01 GMT Sebastian Huber [c11d142] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 04 Nov 2019 06:08:12 GMT Sebastian Huber [9a1cf9a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 17 Oct 2019 13:32:35 GMT Sebastian Huber [6424fe0] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 02 Oct 2019 07:34:29 GMT Sebastian Huber [4a6f476] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 25 Sep 2019 07:15:06 GMT Sebastian Huber [abbcc5d] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 18 Sep 2019 05:59:15 GMT Sebastian Huber [129e576] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 09 Sep 2019 11:07:38 GMT Sebastian Huber [7ca09f6] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 26 Aug 2019 05:09:07 GMT Sebastian Huber [d7f11a7] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 09 Aug 2019 06:43:38 GMT Sebastian Huber [187344d] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 31 Jul 2019 05:06:05 GMT Sebastian Huber [be90fb8] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 25 Jul 2019 05:51:24 GMT Sebastian Huber [639eed3] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 24 Jul 2019 14:06:39 GMT Sebastian Huber [0e59b48] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 17 Jul 2019 11:46:02 GMT Sebastian Huber [bcfb210] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 10 Jul 2019 06:58:12 GMT Sebastian Huber [18d4d29] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 01 Jul 2019 06:50:46 GMT Sebastian Huber [15ef359] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 26 Jun 2019 07:55:37 GMT Sebastian Huber [af4d435] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 19 Jun 2019 08:40:46 GMT Sebastian Huber [e8f1820] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 13 Jun 2019 09:10:52 GMT Sebastian Huber [2198d6b] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 05 Jun 2019 05:35:00 GMT Sebastian Huber [e59abc9] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 03 Jun 2019 08:53:57 GMT Sebastian Huber [e809de5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 31 May 2019 08:14:03 GMT Sebastian Huber [1db8e0c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 23 May 2019 06:10:11 GMT Sebastian Huber [3faa5ab] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 16 May 2019 08:51:28 GMT Sebastian Huber [c1431be] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Mon, 06 May 2019 06:59:58 GMT Sebastian Huber [c80ab5b] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 12 Apr 2019 07:26:40 GMT Sebastian Huber [780a2cf] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 02 Apr 2019 09:25:59 GMT Sebastian Huber [9a3e12e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 26 Mar 2019 06:09:20 GMT Sebastian Huber [cbbbc30] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 Mar 2019 13:31:18 GMT Sebastian Huber [e0aec65] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 Feb 2019 12:36:44 GMT Sebastian Huber [2e65068] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 25 Jan 2019 09:04:51 GMT Sebastian Huber [376edee] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 18 Jan 2019 09:00:34 GMT Sebastian Huber [0bb29a3] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Pick up a fix for Ada. Thu, 17 Jan 2019 14:31:34 GMT Sebastian Huber [1dfc4dd] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Use short Git hashes to avoid ... Wed, 16 Jan 2019 08:42:28 GMT Sebastian Huber [8b0e78a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 10 Jan 2019 08:40:47 GMT Sebastian Huber [f101ea1] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 03 Jan 2019 12:59:15 GMT Sebastian Huber [40ae056] * rtems/config/6/rtems-aarch64.bset (added) * rtems/config/6/rtems-all.bset (added) * rtems/config/6/rtems-arm.bset (added) * rtems/config/6/rtems-autotools-base.bset (added) * rtems/config/6/rtems-autotools-internal.bset (added) * rtems/config/6/rtems-autotools.bset (added) * rtems/config/6/rtems-base.bset (added) * rtems/config/6/rtems-bfin.bset (added) * rtems/config/6/rtems-default.bset (added) * rtems/config/6/rtems-epiphany.bset (added) * rtems/config/6/rtems-i386.bset (added) * rtems/config/6/rtems-lm32.bset (added) * rtems/config/6/rtems-m68k.bset (added) * rtems/config/6/rtems-microblaze.bset (added) * rtems/config/6/rtems-mips.bset (added) * rtems/config/6/rtems-moxie.bset (added) * rtems/config/6/rtems-nios2.bset (added) * rtems/config/6/rtems-or1k.bset (added) * rtems/config/6/rtems-powerpc.bset (added) * rtems/config/6/rtems-riscv.bset (added) * rtems/config/6/rtems-sh.bset (added) * rtems/config/6/rtems-sparc.bset (added) * rtems/config/6/rtems-sparc64.bset (added) * rtems/config/6/rtems-v850.bset (added) * rtems/config/6/rtems-x86_64.bset (added) * rtems/config/tools/rtems-binutils-head.cfg (added) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (added) * rtems/config/tools/rtems-gdb-head.cfg (added) * rtems/config/tools/rtems-mipstx39-gdb-head.cfg (added) 6: Add unstable RTEMS 6 tool chain
