# # ChangeLog for rtems/config/tools/rtems-binutils-2.26-1.cfg in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/20/24 10:30:19 Thu, 12 Oct 2017 02:47:23 GMT Chris Johns [d94bd01] * bare/config/devel/autoconf-2.69-1.cfg (modified) * bare/config/devel/automake-1.12.6-1.cfg (modified) * bare/config/devel/dtc-1.4.1-1.cfg (modified) * bare/config/devel/expat-2.1.0-1.cfg (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.8.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.9-1.cfg (modified) 4.12: Update all MD5 hashes to SHA256. Closes #2536. Mon, 14 Nov 2016 23:57:32 GMT Joel Sherrill [a51bfa1] * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) binutils-2.26-1: Fetch patch from rtems-tools Mon, 14 Nov 2016 01:32:32 GMT Jiri Gaisler [623c8e7] * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) binutils-2.26-1: Add patch for unaligned reloc on SPARC closes #2802. Mon, 29 Feb 2016 06:53:57 GMT Chris Johns [f337f5b5] * rtems/config/4.12/rtems-aarch64.bset (added) * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-x86_64.bset (added) * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) * rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg (added) * rtems/config/tools/rtems-gdb-7.9-1.cfg (modified) 4.12: Add aarch64 and x86_64 support. Thu, 28 Jan 2016 07:24:12 GMT Sebastian Huber [e0693f7] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.26-1.cfg (added) Update RTEMS 4.12 build set Use Binutils 2.26.
