# # ChangeLog for rtems/config/rtems-urls.bset in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/25/24 14:15:56 Thu, 10 Mar 2016 05:19:58 GMT Chris Johns [d3fa158] * rtems/config/rtems-urls.bset (modified) * source-builder/defaults.mc (modified) * source-builder/sb/download.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/options.py (modified) sb: Add a download option --with-release-url/--without-release-url. ... Sun, 28 Feb 2016 22:28:37 GMT Chris Johns [4b0baed] * rtems/config/rtems-urls.bset (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) config: Patch automake-1.12.6 to remove warning on newer perl ... Thu, 10 Dec 2015 05:54:40 GMT Chris Johns [40e4222] * rtems/config/rtems-urls.bset (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.10.2.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * rtems/config/tools/rtems-kernel-4.9.6-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) * rtems/config/tools/rtems-tools-4.11-1.cfg (modified) * rtems/config/tools/rtems-tools-common-1.cfg (added) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/options.py (modified) Support released downloading of the RTEMS Tools and RTEMS Kernel. ... Fri, 27 Mar 2015 23:00:26 GMT Chris Johns [da801b0] * rtems/config/rtems-urls.bset (modified) rtems: Change the base URL for RTEMS git to https to avoid the redirects. Sun, 15 Jun 2014 05:40:34 GMT Chris Johns [0ffee19] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/libiconv-1.14-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/texane-stlink-1.cfg (modified) * rtems/config/4.11/net/ntp.bset (added) * rtems/config/net/ntp-4.2.6p5-1.cfg (added) * rtems/config/rtems-base.bset (modified) * rtems/config/rtems-bsp.cfg (added) * rtems/config/rtems-urls.bset (added) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/ntp-4-1.cfg (added) * source-builder/defaults.mc (modified) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) sb: Add support for building RTEMS 3rd party packages. Remove the ...
