# # ChangeLog for rtems/config/4.12/rtems-or1k.bset in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 06/15/24 21:04:49 Sat, 09 Apr 2016 15:55:16 GMT Joel Sherrill [30783e3] * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg (added) 4.12/rtems-or1k.bset: Update newlib to 2.4.0 Sun, 20 Mar 2016 15:55:42 GMT Stefan Wallentowitz [eac749b] * rtems/config/4.12/rtems-or1k.bset (modified) Bump OpenRISC versions Bump the OpenRISC toolchain to newer ... Fri, 06 Nov 2015 15:18:20 GMT Sebastian Huber [7164e61] * rtems/config/4.12/rtems-all.bset (added) * rtems/config/4.12/rtems-arm.bset (added) * rtems/config/4.12/rtems-autotools-base.bset (added) * rtems/config/4.12/rtems-autotools-internal.bset (added) * rtems/config/4.12/rtems-autotools.bset (added) * rtems/config/4.12/rtems-bfin.bset (added) * rtems/config/4.12/rtems-default.bset (added) * rtems/config/4.12/rtems-epiphany.bset (added) * rtems/config/4.12/rtems-i386.bset (added) * rtems/config/4.12/rtems-lm32.bset (added) * rtems/config/4.12/rtems-m32c.bset (added) * rtems/config/4.12/rtems-m68k.bset (added) * rtems/config/4.12/rtems-microblaze.bset (added) * rtems/config/4.12/rtems-mips.bset (added) * rtems/config/4.12/rtems-moxie.bset (added) * rtems/config/4.12/rtems-nios2.bset (added) * rtems/config/4.12/rtems-or1k.bset (added) * rtems/config/4.12/rtems-powerpc.bset (added) * rtems/config/4.12/rtems-sh.bset (added) * rtems/config/4.12/rtems-sparc.bset (added) * rtems/config/4.12/rtems-sparc64.bset (added) * rtems/config/4.12/rtems-v850.bset (added) * rtems/config/rtems-4.12-base.bset (added) * rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg (added) * rtems/config/tools/rtems-tools-4.12-1.cfg (added) * source-builder/config/gcc-6-1.cfg (added) Add RTEMS 4.12 build set
