# # ChangeLog for rtems/.gitignore in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/23/24 14:40:06 Tue, 08 Dec 2015 01:53:30 GMT Chris Johns [fb4ba79] * rtems/.gitignore (modified) Ignore generated XML files. Fri, 23 Jan 2015 03:33:19 GMT Chris Johns [8a7428c] * rtems/.gitignore (modified) * rtems/config/4.11/net/protobuf.bset (added) * rtems/config/net/protobuf-2.6.1-1.cfg (added) * source-builder/config/protobuf-2-1.cfg (added) Add Google Protocol Buffers as a 3prd party package for RTEMS. ... Tue, 12 Aug 2014 02:22:30 GMT Chris Johns [8db5212] * rtems/.gitignore (modified) * source-builder/sb/reports.py (modified) * source-builder/sb/sources.py (modified) sb: Complete support for INI file reporting. The INI file format ... Tue, 16 Jul 2013 00:00:13 GMT Chris Johns [bfee78b] * rtems/.gitignore (modified) Ignore log_* log files. Tue, 19 Mar 2013 22:46:12 GMT Chris Johns [18917ba] * rtems/.gitignore (modified) Add emacs temp files to the ignore list. Sun, 10 Mar 2013 23:58:40 GMT Chris Johns [48e1cd4] * rtems/.gitignore (modified) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-4.11-base.bset (modified) * rtems/config/rtems-binutils-patches.cfg (added) * rtems/config/rtems-gcc-patches.cfg (added) * rtems/config/rtems-gdb-patches.cfg (added) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/patches/binutils-2.20.1-rtems4.10-20100826.diff (deleted) * rtems/patches/binutils-2.22-rtems4.11-20120427.diff (deleted) * rtems/patches/binutils-2.22-rtems4.11-moxie-20130214.diff (deleted) * rtems/patches/gcc-4.5.3-strsignal-1.diff (deleted) * rtems/patches/gcc-4.7-arm-to-eabi-20120511.diff (deleted) * rtems/patches/gcc-4.7.2-rtems4.11-20121026.diff (deleted) * rtems/patches/gcc-core-4.4.7-rtems4.10-20120314.diff (deleted) * rtems/patches/gcc-core-4.6.3-rtems4.11-20120303.diff (deleted) * rtems/patches/gcc-g++-4.4.7-rtems4.10-20120314.diff (deleted) * rtems/patches/gdb-7.3.1-rtems4.10-20120918.diff (deleted) * rtems/patches/gdb-7.5-rtems4.11-20121003.diff (deleted) * rtems/patches/gdb-7.5.1-rtems4.11-moxie-20130214.diff (deleted) * rtems/patches/newlib-1.18.0-rtems4.10-20110518.diff (deleted) * rtems/patches/newlib-1.20.0-rtems4.11-20121011.diff (deleted) * rtems/patches/newlib-2.0.0-mips-memcpy-20130107.diff (deleted) * rtems/patches/newlib-2.0.0-mips-memcpy-20130219.diff (deleted) * rtems/patches/nios2-binutils-2.20-rtems-20110703.diff (deleted) * rtems/patches/nios2-gcc-4.1-rtems-20110818.diff (deleted) * rtems/patches/nios2-newlib-1.19.0-rtems-20110720.diff (deleted) Move all patches to the rtems-tools.git repo. All patches are now ... Sun, 03 Mar 2013 03:52:39 GMT Chris Johns [6ee25e5] * rtems/.gitignore (modified) * source-builder/sb/asciidoc/asciidoc.conf (added) * source-builder/sb/asciidoc/asciidoc.py (moved) * source-builder/sb/asciidoc/lang-cs.conf (added) * source-builder/sb/asciidoc/lang-de.conf (added) * source-builder/sb/asciidoc/lang-el.conf (added) * source-builder/sb/asciidoc/lang-en.conf (added) * source-builder/sb/asciidoc/lang-es.conf (added) * source-builder/sb/asciidoc/lang-fr.conf (added) * source-builder/sb/asciidoc/lang-hu.conf (added) * source-builder/sb/asciidoc/lang-it.conf (added) * source-builder/sb/asciidoc/lang-nl.conf (added) * source-builder/sb/asciidoc/lang-ro.conf (added) * source-builder/sb/asciidoc/lang-ru.conf (added) * source-builder/sb/asciidoc/lang-uk.conf (added) * source-builder/sb/asciidoc/xhtml11.conf (added) * source-builder/sb/reports.py (modified) Fix the asciidoc import. Add the missing config files. Mon, 05 Nov 2012 23:06:10 GMT Chris Johns [48e5513] * rtems/.gitignore (moved) * rtems/patches/binutils-2.20.1-rtems4.10-20100826.diff (moved) * rtems/patches/gcc-core-4.4.7-rtems4.10-20120314.diff (moved) * rtems/patches/gcc-g++-4.4.7-rtems4.10-20120314.diff (moved) * rtems/patches/gdb-7.3.1-rtems4.10-20120918.diff (moved) * rtems/patches/newlib-1.18.0-rtems4.10-20110518.diff (moved) * rtems/rtems-binutils-2.20.1-1.cfg (moved) * rtems/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (moved) * rtems/rtems-gdb-7.3.1-1.cfg (moved) * rtems/rtems-tools-4.10.bset (moved) Move RTEMS source builder configurations and patches in rtems.
