# # ChangeLog for bare in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/01/24 17:25:40 Mon, 07 Mar 2016 00:59:51 GMT Chris Johns [e645642] * bare/config/devel/qemu.bset (modified) * source-builder/sb/setbuilder.py (modified) qemu: Add a package name to create a tarball. Fri, 05 Jun 2015 07:00:21 GMT Chris Johns [68f8038] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/libtool-2.4.2-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) bare/devel: Add missing checksums. Wed, 03 Jun 2015 04:13:35 GMT Chris Johns [97aa07d] * bare/config/devel/qemu-git-1.cfg (modified) devel/qemu: Update to the current head of Qemu's git master branch. Thu, 02 Apr 2015 16:37:32 GMT Hesham ALMatary [b65c131] * bare/config/devel/qemu-git-1.cfg (modified) Apply QEMU patch for openrisc that handles halt signals Thu, 12 Mar 2015 02:11:06 GMT Chris Johns [0f6afd9] * bare/config/devel/dtc-1.4.1-1.cfg (added) * rtems/config/4.11/rtems-moxie.bset (modified) 4.11/moxie: Fix the broken dtc-1.4.1 build. Sun, 18 Jan 2015 04:34:35 GMT Chris Johns [8197b8e] * bare/config/gnu-tools-4.6.bset (modified) * bare/config/gnu-tools-4.8.2.bset (modified) * bare/config/lang/gcc491.bset (modified) * rtems/config/4.10/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-autotools-base.bset (modified) * rtems/config/4.9/rtems-autotools.bset (modified) * rtems/config/rtems-base.bset (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/or1ksim-1-1.cfg (modified) Add the host name to the package name. Adding the host name results ... Fri, 12 Dec 2014 00:21:29 GMT Chris Johns [e7cbf74] * bare/config/devel/dtc-1.2.0.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) rtems4.11: Update DTC for Moxie to it's new home path. Add a ... Sun, 16 Nov 2014 18:54:48 GMT Jiri Gaisler [3834e6a] * bare/config/devel/qemu-git-1.cfg (modified) bare/qemu: add patches for leon3 support. Wed, 05 Nov 2014 21:46:41 GMT Chris Johns [a0a5b1c] * bare/config/devel/qemu-git-1.cfg (modified) bare: Update qemu to the latest version. Add support to build on ... Sat, 06 Sep 2014 13:18:23 GMT Ben Gras [5f0e38f] * bare/config/devel/automake-1.12.6-1.cfg (modified) rename variable to defined one Thu, 28 Aug 2014 17:14:34 GMT Hesham ALMatary [183626a] * bare/config/devel/or1ksim-1.1.0.cfg (added) * bare/config/devel/or1ksim.bset (added) * source-builder/config/or1ksim-1-1.cfg (added) Add support for building bare-metal or1ksim. This patch adds ... Wed, 20 Aug 2014 05:00:41 GMT Chris Johns [05cea12] * bare/config/devel/automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (modified) rtems-4.11: Newlib 19-Aug-2014. Add the hash for automake. Wed, 13 Aug 2014 20:39:06 GMT Chris Johns [1c3547f] * bare/config/devel/autoconf-2.69-1.cfg (modified) * bare/config/devel/automake-1.12.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.10.2.cfg (modified) rtems-4.10: Add checksums. Tue, 29 Jul 2014 06:35:43 GMT Chris Johns [a083b52] * bare/config/devel/expat-2.1.0-1.cfg (modified) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (modified) * rtems/config/net/ntp-4.2.6p5-1.cfg (modified) * rtems/config/tools/rtems-autoconf-2.69-1.cfg (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7.1-1.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (modified) Add checksum support for downloaded files. File download by http, ... Fri, 25 Jul 2014 11:46:34 GMT Chris Johns [2eb764e] * bare/config/devel/binutils-2.24-1.cfg (added) * bare/config/devel/gcc-4.9-newlib-cvs-1.cfg (added) * bare/config/devel/gcc-4.9.1-newlib-2.1.0-1.cfg (added) * bare/config/lang/gcc491.bset (added) bare: Add support for building gcc-4.9.1 and newlib-2.1.0. Mon, 23 Jun 2014 09:15:51 GMT Chris Johns [cbc5332] * bare/config/devel/libusb-1.0.18-1.cfg (added) * bare/config/devel/libusb.bset (added) bare: Update libusb to 1.0.18. Add a build set file for libusb. Sun, 15 Jun 2014 05:40:34 GMT Chris Johns [0ffee19] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/libiconv-1.14-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/texane-stlink-1.cfg (modified) * rtems/config/4.11/net/ntp.bset (added) * rtems/config/net/ntp-4.2.6p5-1.cfg (added) * rtems/config/rtems-base.bset (modified) * rtems/config/rtems-bsp.cfg (added) * rtems/config/rtems-urls.bset (added) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/ntp-4-1.cfg (added) * source-builder/defaults.mc (modified) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) sb: Add support for building RTEMS 3rd party packages. Remove the ... Wed, 11 Jun 2014 06:03:56 GMT Chris Johns [cbf576e] * bare/config/devel/qemu-git-1.cfg (modified) bare: Add GSoC QEMU patches for CAN bus support. Wed, 11 Jun 2014 06:02:56 GMT Chris Johns [578405e] * bare/config/devel/libtool.bset (added) bare: Add a build set for building libtool. Wed, 14 May 2014 06:37:46 GMT Chris Johns [1b29191] * bare/config/bare-binutils-patches.cfg (deleted) * bare/config/bare-gcc-patches.cfg (deleted) * bare/config/bare-gdb-patches.cfg (deleted) * bare/config/devel/binutils-2.23.2-1.cfg (modified) * bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg (modified) * bare/config/devel/gdb-7.6.1-1.cfg (modified) * bare/config/devel/gdb-7.7-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) * bare/config/devel/texane-stlink-1.cfg (modified) * bare/config/dtc.bset (deleted) config: Mirgrate the remaining configs. Thu, 10 Apr 2014 08:27:17 GMT Chris Johns [6b7b22a] * bare/config/devel/libiconv-1.14-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) config: Use _host_os for conditional checks. Wed, 09 Apr 2014 05:07:54 GMT Chris Johns [8ac8ebf] * bare/config/devel/gdb-7.7-1.cfg (added) * rtems/config/tools/rtems-gdb-7.7-1.cfg (added) config: Add gdb-7.7 support. Tue, 08 Apr 2014 06:16:13 GMT Chris Johns [6ab2f51] * bare/config/devel/qemu-git-1.cfg (modified) config: Remove the qemu test patch for MinGW. Tue, 08 Apr 2014 06:15:35 GMT Chris Johns [34cc5a9] * bare/config/devel/libffi-3.0.13-1.cfg (modified) config: Add the libffi version to check for. Tue, 08 Apr 2014 05:11:00 GMT Chris Johns [f3b5490] * bare/config/devel/libiconv-1.14-1.cfg (added) * bare/config/devel/qemu-git-1.cfg (modified) * bare/config/devel/qemu.bset (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (added) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/mingw32-pkg-config (added) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) config,sb: Qemu build updates for FreeBSD and the start of MinG32. ... Wed, 12 Feb 2014 04:27:05 GMT Chris Johns [70cc3b0] * bare/config/devel/qemu-git-1.cfg (modified) config: Use qemu's patchworks site for patches. Wed, 12 Feb 2014 02:11:38 GMT Chris Johns [d5c7c1f] * bare/config/devel/libffi-3.0.13-1.cfg (modified) config: Fix libffi on Fedora 64bit. Tue, 11 Feb 2014 03:06:45 GMT Chris Johns [c5b5493] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * source-builder/sb/config.py (modified) config: Change pkgconfig to check. Add the extra actions: ccflags, ... Mon, 10 Feb 2014 23:38:33 GMT Chris Johns [f27f7c4] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) config: Update qemu to build on FreeBSD. Update configuration to ... Tue, 04 Feb 2014 07:38:18 GMT Chris Johns [56e8d80] * bare/config/devel/autoconf-internal-2.69-1.cfg (added) * bare/config/devel/autotools-base.bset (added) * bare/config/devel/autotools-internal.bset (added) * bare/config/devel/autotools.bset (added) * bare/config/devel/dtc.bset (added) * bare/config/devel/gettext-0.18.3.1-1.cfg (added) * bare/config/devel/glib-2.39.3-1.cfg (added) * bare/config/devel/libffi-3.0.13-1.cfg (added) * bare/config/devel/libtool-2.4.2-1.cfg (added) * bare/config/devel/pixman-0.32.4-1.cfg (added) * bare/config/devel/qemu-git-1.cfg (added) * bare/config/devel/qemu.bset (added) * source-builder/bin/pkg-config (added) * source-builder/config/gettext-0-1.cfg (added) * source-builder/config/glib-2-1.cfg (added) * source-builder/config/libffi-3-1.cfg (added) * source-builder/config/libtool-2-1.cfg (added) * source-builder/config/pixman-0-1.cfg (added) * source-builder/config/qemu-1-1.cfg (added) * source-builder/defaults.mc (modified) config: Add support to build qemu. Qemu requires gettext, glib, ... Tue, 05 Nov 2013 11:09:11 GMT Chris Johns [873016c] * bare/config/bare-binutils-patches.cfg (added) * bare/config/bare-config.cfg (added) * bare/config/bare-gcc-patches.cfg (added) * bare/config/bare-gdb-patches.cfg (added) * bare/config/devel/binutils-2.23.2-1.cfg (added) * bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg (added) * bare/config/devel/gdb-7.6.1-1.cfg (added) * bare/config/gnu-tools-4.8.2.bset (added) Add Bare support for GNU tools. Add support to build bare metal ... Tue, 05 Nov 2013 03:36:42 GMT Chris Johns [ae717cb] * bare/.gitignore (added) * bare/config/dtc.bset (added) Add a DTC build set. Wed, 15 May 2013 23:40:36 GMT Cynthia Rempel [6e583e5] * bare/config/devel/automake-1.12.6-1.cfg (added) Update the automake version to 1.12.6 as required by ... Tue, 14 May 2013 01:08:02 GMT Chris Johns [1a56a07] * bare/config/devel/autoconf-2.68-1.cfg (moved) * bare/config/devel/autoconf-2.69-1.cfg (moved) * bare/config/devel/autoconf-internal-2.68-1.cfg (moved) * bare/config/devel/automake-1.12-1.cfg (moved) * bare/config/devel/automake-1.12.2-1.cfg (moved) * bare/config/devel/automake-internal-1.12-1.cfg (moved) * bare/config/devel/binutils-2.22-1.cfg (moved) * bare/config/devel/dtc-1.2.0.cfg (moved) * bare/config/devel/expat-2.1.0-1.cfg (moved) * bare/config/devel/gcc-4.6-newlib-1.20-1.cfg (moved) * bare/config/devel/gcc-4.7-newlib-1.20-1.cfg (moved) * bare/config/devel/libusb-1.0.9-1.cfg (moved) * bare/config/devel/m4-1.4.16-1.cfg (moved) * bare/config/devel/texane-stlink-1.cfg (moved) * bare/config/gnu-tools-4.6.bset (moved) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * source-builder/defaults.mc (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/options.py (modified) Add bare/config and move the source-builder/config to it. Rework ...
