@08aa888
03/16/16 04:51:24 |
Chris Johns |
4.12/gdb-7.11: Add ERC32 patches to fix the simulator.
Updates #2644.
4.104.95
@276fdc4
03/15/16 02:25:39 |
Chris Johns |
rtems/4.12: Add hash to gdb-7.11.
4.104.95
@33308d1
03/14/16 23:55:23 |
Chris Johns |
sb: Make cvs optional.
Ignore RSB generated files to keep the git …
4.104.95
@b290154
03/14/16 07:20:21 |
Chris Johns |
rtems-kernel: Fix the --with-rtems/--without-rtems support when …
4.104.95
@8d0e377
03/14/16 06:42:51 |
Chris Johns |
sb: Fix the --without-error-report parsing of the label.
Update #2526.
4.104.95
@6e490ae
03/14/16 05:23:19 |
Chris Johns |
sb: Update download to check the config file for release URL control.
4.104.95
@e8f3519
03/14/16 04:19:29 |
Chris Johns |
sb: Fix build's --with-error-report handling.
This reflects changes …
4.104.95
@703c854
03/14/16 04:12:41 |
Chris Johns |
4.12: Update GDB to gdb-7.11.
4.104.95
@fc87573
03/11/16 19:28:37 |
joel |
4.12/rtems-moxie.bset: Update to match default RTEMS toolset
4.104.95
@8298f72
01/11/16 16:36:57 |
Goetz.Pfeiffer |
Bugfix: gdb-7.3.1 for rtems 4.10 couldn't be built with modern …
4.104.95
@a68334f
01/11/16 16:36:57 |
Goetz.Pfeiffer |
Bugfix: gcc-4.4.7 for rtems 4.10 couldn't be built with modern …
4.104.95
@4dd4e9a
01/11/16 16:36:57 |
Goetz.Pfeiffer |
Bugfix: binutils-2.20.1 for rtems 4.10 couldn't be built with modern …
4.104.95
@84238b9
03/10/16 05:48:38 |
Chris Johns |
sb: Fix --without-release-url logic.
Updates #2636.
4.104.95
@d3fa158
03/10/16 05:19:58 |
Chris Johns |
sb: Add a download option --with-release-url/--without-release-url.
4.104.95
@62f76d98
03/10/16 04:06:32 |
Chris Johns |
sb: Fix typo on the urlparse name in download.py
Updates #2619.
4.104.95
@d78a63f
03/10/16 04:00:29 |
Chris Johns |
sb: Download's urllib_parse should point to urlparse on Python2.
4.104.95
@29f23e0
03/10/16 03:52:25 |
Chris Johns |
sb: Fix configparser import on Python2 in version.py.
Updates #2619.
4.104.95
@334c22c
03/08/16 11:23:01 |
Chris Johns |
sb: Add support to GDB to select a specific Python.
Detect a suitable …
4.104.95
@9bae339
03/08/16 11:17:09 |
Chris Johns |
sb: Report platform import errors.
4.104.95
@e645642
03/07/16 00:59:51 |
Chris Johns |
qemu: Add a package name to create a tarball.
4.104.95
@3a972f6
03/07/16 00:56:02 |
Chris Johns |
sb: Update code base to support Python3 and Python2.
Fix Windows …
4.104.95
@b537e55
03/01/16 03:33:22 |
Chris Johns |
Clean up 4.9 build issues.
Add support so 4.9 builds on a recent …
4.104.95
@c46f212
02/29/16 22:45:27 |
Hasjim Williams |
Fix 4.10 and 4.9 building.
Add the 4.9 newlib 1.16.0-20090324 patch. …
4.104.95
@f337f5b5
02/29/16 06:53:57 |
Chris Johns |
4.12: Add aarch64 and x86_64 support.
4.104.95
@8dbb3a0
02/28/16 23:41:17 |
Chris Johns |
sb: Remove http query flags from the file name if present.
The query …
4.104.95
@23191a3
02/28/16 23:13:11 |
Chris Johns |
sb: bootstrap.py clearing of environ var 'ACLOCAL_PATH' on MSYS2 …
4.104.95
@4b0baed
02/28/16 22:28:37 |
Chris Johns |
config: Patch automake-1.12.6 to remove warning on newer perl …
4.104.95
@17e06f8
02/24/16 16:25:12 |
Hesham Almatary |
update newlib git revision to get <sys/select.h> RTEMS dependency
4.104.95
@056e601
02/25/16 03:29:00 |
Chris Johns |
Wrap the tar command in double quotes for Windows cmd.exe.
Windows …
4.104.95
@d897e93
02/24/16 03:18:42 |
Chris Johns |
Fix sb-bootrap to run on Windows using MSYS2.
Prepend 'sh' to the …
4.104.95
@7c0ded8
09/21/15 23:01:28 |
Chris Johns |
Fix pkgconfig for MSYS to allow QEMU to build.
4.104.95
@610ae57
02/22/16 06:37:37 |
Chris Johns |
Fix sb-build to reference the opts correctly.
4.104.95
@318e0c3
02/22/16 06:38:32 |
Chris Johns |
Fix the rtems-tools waf --destdir path on Windows.
Waf requires the …
4.104.95
@b87138a
01/28/16 07:24:45 |
Sebastian Huber |
Update RTEMS 4.12 build set for MIPS
4.104.95
@e0693f7
01/28/16 07:24:12 |
Sebastian Huber |
Use Binutils 2.26.
4.104.95
@7cdec5c
01/25/16 00:11:25 |
Patrick Gauvin |
Fix RTEMS Tools source symlink generation.
When rsb_released was not …
4.104.95
@e3b9fb6
01/25/16 07:46:35 |
Nick Withers |
Update to the GCC 6 20160124 snapshot, …
4.104.95
@14b00ff
01/24/16 19:24:19 |
joel |
source-builder/config/qemu-1-1.cfg: Add --disable-smartcard-nss
4.104.95
@075ed1c
01/19/16 06:55:06 |
Sebastian Huber |
Add hashes for RTEMS 4.12 tools
4.104.95
@342c7dc
01/18/16 12:39:27 |
Sebastian Huber |
4.104.95
@eec82cd
11/28/15 20:55:16 |
yangqiao0505 |
fix libpng version number
4.104.95
@bf05b15
11/28/15 20:55:15 |
yangqiao0505 |
add dependencies for nxlib
4.104.95
@3618353
11/28/15 20:55:14 |
yangqiao0505 |
add graphics-all bset
4.104.95
@4cef681
11/28/15 20:55:13 |
yangqiao0505 |
add dependencies for nanox
4.104.95
@7a9ec6e
11/28/15 20:55:12 |
yangqiao0505 |
fix nanox patch url
4.104.95
@3dfedc9
11/28/15 20:55:11 |
yangqiao0505 |
fix t1lib patch url
4.104.95
@3ffbfc8
12/15/15 00:15:28 |
Chris Johns |
Fix 4.11/rtems-tools so it builds from git.
4.104.95
@dc1cd68
12/14/15 05:09:27 |
Chris Johns |
Download source from RTEMS if a release.
Download source from …
4.104.95
@00b60d7
12/13/15 04:10:04 |
Chris Johns |
Fix the building of the RTEMS Tools from a tar file.
4.104.95
@e33968a
12/13/15 02:53:41 |
Chris Johns |
Remove RTEMS 4.11 unstable.
4.104.95
@9c68438
12/11/15 07:28:26 |
Chris Johns |
A VERSION file may have no hashes.
4.104.95
@7dddcc2
12/11/15 05:22:00 |
Chris Johns |
VERSION is an INI format file.
VERSION is an INI format file with 2 …
4.104.95
@0661e90
12/11/15 05:21:44 |
Chris Johns |
Return after an error as a dry-run carries on.
4.104.95
@e8ed687
12/11/15 05:21:09 |
Chris Johns |
Generate an error if there is no hash when released.
4.104.95
@a861b31
12/11/15 05:20:22 |
Chris Johns |
Use BZ2 for gdb-7.7.
4.104.95
@27a934e
12/11/15 03:21:29 |
Chris Johns |
Remove the warning when undefining an undefined macro.
4.104.95
@f9f6f6c
12/10/15 23:48:56 |
Chris Johns |
Set the RTEMS Tools and Kernel version based on a release.
4.104.95
@dfc4a4f
12/10/15 06:30:27 |
Chris Johns |
Make CVS optional. We should avoid using it.
4.104.95
@40e4222
12/10/15 05:54:40 |
Chris Johns |
Support released downloading of the RTEMS Tools and RTEMS Kernel.
Add …
4.104.95
@fb4ba79
12/08/15 01:53:30 |
Chris Johns |
Ignore generated XML files.
4.104.95
@f8ef062
12/08/15 01:53:13 |
Chris Johns |
Ignore VERSION files in the top directory.
4.104.95
@47d703fd
12/03/15 11:22:17 |
Chris Johns |
sb. Add VERSION support for releasing the RSB.
Add support to release …
4.104.95
@7164e61
11/06/15 15:18:20 |
Sebastian Huber |
Add RTEMS 4.12 build set
4.104.95
@6bef80f
11/04/15 17:58:22 |
Gedare Bloom |
doc: fix link to patch for CVS
4.104.95
@32c7d4c
10/26/15 04:41:23 |
Chris Johns |
4.11/rtems-epiphany: Use the latest newlib git head.
Move to the …
4.104.95
@824f57c
10/26/15 04:38:39 |
Chris Johns |
sb: Only use /usr/local/bin/unzip on FreeBSD.
The base package …
4.104.95
@2cd8aee
10/20/15 23:18:24 |
Joel Sherrill |
4.11/rtems-all.bset: Add epiphany and h8300
4.104.95
@d028a6f
10/20/15 23:17:53 |
Joel Sherrill |
4.11/rtems-moxie.bset: Update to binutils 2.25
closes #2254.
4.104.95
@13138bc
09/28/15 17:12:23 |
Hesham Almatary |
gcc-4.8.3: Update newlib revision to catch <sys/tree.h> include
4.104.95
@f795d62
08/18/15 13:37:04 |
Hesham Almatary |
doc: zlib1g-dev package needs to be installed on Linux Mint
4.104.95
@3a3069e
08/09/15 09:43:43 |
ragunath3252 |
lwIP configuration & build files
Patch to build lwip with RTEMS …
4.104.95
@9092cce
08/11/15 13:35:47 |
Joel Sherrill |
Revert "add t1lib patch"
This reverts commit …
4.104.95
@2dfb410
08/11/15 13:35:20 |
Joel Sherrill |
Revert "add microwindows patches"
4.104.95
@01f8d0c
08/10/15 12:48:27 |
yangqiao0505 |
fix libjpeg conf
4.104.95
@68e81c7
08/10/15 12:48:26 |
yangqiao0505 |
add nxlib bset
4.104.95
@a7d2db0
08/10/15 12:48:25 |
yangqiao0505 |
add nanoX bset
4.104.95
@457c7ec
08/10/15 12:48:24 |
yangqiao0505 |
add t1lib bset (patch url should be changed after it is merged into …
4.104.95
@d9ee8ae
08/10/15 12:48:23 |
yangqiao0505 |
add freetype2 bset
4.104.95
@d2ee14c
08/10/15 12:48:22 |
yangqiao0505 |
add tiff-4.0.2 bset
4.104.95
@c22fc6d
08/10/15 12:48:58 |
yangqiao0505 |
4.104.95
@0b80ff5
08/10/15 12:48:21 |
yangqiao0505 |
add libpng bset
4.104.95
@80f3b2b
08/10/15 12:48:57 |
yangqiao0505 |
add t1lib patch
4.104.95
@f936478
07/20/15 04:09:24 |
Chris Johns |
rtems/netsnmp: Disable SMP builds.
NetSNMP breaks building with extra …
4.104.95
@6444d58
07/20/15 03:49:42 |
Chris Johns |
Canandian Cross Compiling and RTEMS 3rd party package building Fixes.
4.104.95
@fba2549
07/07/15 07:33:30 |
Sebastian Huber |
rtems4.11: OpenMP support for ARM, PowerPC, SPARC
4.104.114.95
@8a7660c
07/06/15 13:40:32 |
Sebastian Huber |
rtems4.11: Use GCC 4.9.3
4.104.114.95
@dcc0e5c
06/22/15 00:18:49 |
Chris Johns |
Change license to BSD.
4.104.114.95
@e9dfd95
06/22/15 00:14:54 |
Chris Johns |
Revert "add basic support for OpenBSD"
4.104.114.95
@83d97da
06/19/15 10:12:16 |
Karel Gardas |
4.104.114.95
@eddfda5
06/16/15 10:58:19 |
Chris Johns |
config: Add a qemu-snapshot map to the qemu build.
4.104.114.95
@5b5d6bf
06/16/15 10:57:06 |
Chris Johns |
sb: Fix the downloader file:// URL to copy the file to the local path.
4.104.114.95
@18cea20
06/05/15 07:00:58 |
Chris Johns |
devel/qemu: Add support to build VDE if installed.
Check is the VDE …
4.104.114.95
@68f8038
06/05/15 07:00:21 |
Chris Johns |
bare/devel: Add missing checksums.
4.104.114.95
@9976801
06/05/15 06:58:29 |
Chris Johns |
sb: Expand each data line.
4.104.114.95
@97aa07d
06/03/15 04:13:35 |
Chris Johns |
devel/qemu: Update to the current head of Qemu's git master branch.
4.104.114.95
@4bd058e
05/22/15 02:20:41 |
Chris Johns |
sb: Always generate an XML report.
4.104.114.95
@d15a7f8
05/21/15 21:53:48 |
Nick Withers |
Don't let a GCC port install override base Clang for FreeBSD 10+
4.104.114.95
@be7ffbf
05/21/15 17:46:27 |
Hesham Almatary |
epiphany: fix checksum error for gcc and gdb
4.104.114.95
@b8673bf
05/21/15 17:12:28 |
Hesham Almatary |
epiphany: Fix binutils checksum
4.104.114.95
@ce60578
05/21/15 11:49:25 |
Chris Johns |
sb: Fix reporting and installing the reports when building.
Switch …
4.104.114.95
