# # ChangeLog for / in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/09/24 18:09:08 Wed, 22 Nov 2017 15:33:04 GMT Joel Sherrill [ea15753] * source-builder/sb/bootstrap.py (modified) source-builder/sb/bootstrap.py: Do not reference bsp_specs to find ... Sun, 12 Nov 2017 15:50:37 GMT Joel Sherrill [d1e6dfc] * rtems/config/5/rtems-all.bset (modified) 5/rtems-all.bset: Add missing aarch64 closes #3227. Fri, 10 Nov 2017 09:09:15 GMT Sebastian Huber [8b30eb3] * rtems/config/5/rtems-mips.bset (modified) * rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg (added) 5: Update to special MIPS GDB to 8.0.1 Fri, 10 Nov 2017 08:54:19 GMT Sebastian Huber [831bc7e] * rtems/config/tools/rtems-gdb-7.8.1-1.cfg (modified) 5: Avoid rtems-tools for epiphany GDB Close #3226. Fri, 10 Nov 2017 08:34:12 GMT Sebastian Huber [ebe0053] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gdb-7.11-2.cfg (added) 5: Use custome GDB 7.11 without for or1k Do not include aarch64 and ... Fri, 10 Nov 2017 08:33:43 GMT Sebastian Huber [d20f4df] * rtems/config/5/rtems-m32c.bset (modified) 5: Upgrade m32c to GDB 8.0.1 Close #3225. Fri, 10 Nov 2017 07:50:01 GMT Sebastian Huber [dbe55c3] * rtems/config/5/rtems-m32c.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) 5: Use Binutils 2.29 for or1k and m32c This avoids Binutils patches ... Fri, 10 Nov 2017 07:31:58 GMT Sebastian Huber [33f1deb] * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) 5: Use ticket attachment for automake patch Update #2616. Wed, 08 Nov 2017 12:19:02 GMT Sebastian Huber [089327b] * source-builder/sb/version.py (modified) Change RSB version from 4.12 to 5 Update #3220. Wed, 08 Nov 2017 08:52:12 GMT Sebastian Huber [c6b890c] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (modified) 5: Add Newlib patches Update #3185. Close #3189. Wed, 08 Nov 2017 08:31:58 GMT Sebastian Huber [637061c] * rtems/config/4.12/rtems-all.bset (deleted) * rtems/config/4.12/rtems-tier-3.bset (deleted) * rtems/config/5/rtems-aarch64.bset (moved) * rtems/config/5/rtems-all.bset (added) * rtems/config/5/rtems-arm.bset (moved) * rtems/config/5/rtems-autotools-base.bset (moved) * rtems/config/5/rtems-autotools-internal.bset (moved) * rtems/config/5/rtems-autotools.bset (moved) * rtems/config/5/rtems-bfin.bset (moved) * rtems/config/5/rtems-default.bset (moved) * rtems/config/5/rtems-epiphany.bset (moved) * rtems/config/5/rtems-i386.bset (moved) * rtems/config/5/rtems-lm32.bset (moved) * rtems/config/5/rtems-m32c.bset (moved) * rtems/config/5/rtems-m68k.bset (moved) * rtems/config/5/rtems-microblaze.bset (moved) * rtems/config/5/rtems-mips.bset (moved) * rtems/config/5/rtems-moxie.bset (moved) * rtems/config/5/rtems-nios2.bset (moved) * rtems/config/5/rtems-or1k.bset (moved) * rtems/config/5/rtems-powerpc.bset (moved) * rtems/config/5/rtems-riscv32.bset (moved) * rtems/config/5/rtems-riscv64.bset (moved) * rtems/config/5/rtems-sh.bset (moved) * rtems/config/5/rtems-sparc.bset (moved) * rtems/config/5/rtems-sparc64.bset (moved) * rtems/config/5/rtems-tier-1.bset (moved) * rtems/config/5/rtems-tier-2.bset (moved) * rtems/config/5/rtems-tier-3.bset (added) * rtems/config/5/rtems-tier-4.bset (moved) * rtems/config/5/rtems-tools.bset (moved) * rtems/config/5/rtems-v850.bset (moved) * rtems/config/5/rtems-x86_64.bset (moved) * rtems/config/rtems-version.bset (modified) * rtems/config/tools/rtems-kernel-5.cfg (moved) * rtems/config/tools/rtems-tools-5-1.cfg (moved) Change RTEMS version from 4.12 to 5 Update #3220. Tue, 31 Oct 2017 03:54:23 GMT Chris Johns [0f2cf80] * rtems/config/4.12/rtems-all.bset (modified) 4.12: Add x86_64 and RISCV64 to 4.12/rtems-all. Tue, 31 Oct 2017 00:57:21 GMT Chris Johns [4dc9bf3] * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Add platform reporting for better host reviewing in posted email ... Tue, 31 Oct 2017 00:56:23 GMT Chris Johns [4e7fdaf] * source-builder/sb/mailer.py (modified) sb: Make a to_addr comma list a Python list for sending. Sat, 28 Oct 2017 05:04:14 GMT Hesham Almatary [e274bdf] * bare/config/devel/spike-1.1.0.cfg (added) * bare/config/devel/spike.bset (added) * source-builder/config/spike-1-1.cfg (added) RSB - RISC-V: Add scripts to build RISC-V's simulator Update #3109 Fri, 27 Oct 2017 06:36:06 GMT Chris Johns [8cdc8e4] * source-builder/sb/setbuilder.py (modified) sb: Remove debug print left in by mistake. Fri, 27 Oct 2017 06:34:00 GMT Chris Johns [70e3e5e] * source-builder/defaults.mc (modified) * source-builder/sb/setbuilder.py (modified) sb: Set the to email address to build@rtems.org. - Fix a minor bug ... Fri, 27 Oct 2017 06:25:45 GMT Chris Johns [0f97375] * rtems/config/4.12/rtems-autotools.bset (modified) * source-builder/sb/setbuilder.py (modified) sb: Provide a more detail email message. Close #3210. Fri, 27 Oct 2017 06:24:50 GMT Chris Johns [910196d] * source-builder/sb/reports.py (modified) sb: Add a call to get the post processed report output. Update #3210. Fri, 27 Oct 2017 06:23:25 GMT Chris Johns [723b638] * source-builder/sb/log.py (modified) sb: Add a log capture interface to capture the console output. - ... Fri, 27 Oct 2017 06:22:12 GMT Chris Johns [9b54dd8] * source-builder/sb/macros.py (modified) sb: Add a defined check. Updates #3210. Thu, 26 Oct 2017 05:29:04 GMT Hesham Almatary [5bd4aa6] * rtems/config/4.12/rtems-riscv64.bset (added) RSB - Add support for RISC-V RV64 (64-bit) toolchain v2 Update #3109 Mon, 23 Oct 2017 17:18:37 GMT Joel Sherrill [6c60a4b] * rtems/config/4.12/rtems-epiphany.bset (modified) rtems-epiphany.bset: Add sha512sum for GCC git repository Closes #3201. Mon, 23 Oct 2017 16:17:21 GMT Joel Sherrill [5295cb8a] * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) rtems-gdb-7.11-1.cfg: Correct sha512sum on gdb-7.11-sis- ... Mon, 23 Oct 2017 04:32:12 GMT Chris Johns [34d7e0c] * source-builder/sb/darwin.py (modified) darwin: Allow xz to live anywhere. Mon, 23 Oct 2017 04:29:48 GMT Chris Johns [f723e71] * rtems/config/4.12/rtems-tier-3.bset (modified) 4.12: Fix the nios2 spelling in the tier-3 build set. Mon, 23 Oct 2017 00:56:13 GMT Chris Johns [0dae1f6] * rtems/config/4.12/rtems-tier-1.bset (added) * rtems/config/4.12/rtems-tier-2.bset (added) * rtems/config/4.12/rtems-tier-3.bset (added) * rtems/config/4.12/rtems-tier-4.bset (added) 4.12: Add tier build sets to aid regression testing. Sat, 14 Oct 2017 14:18:44 GMT Chris Johns [4021c28] * source-builder/sb/path.py (modified) sb: Fix the interface to all path function to be shell paths. - Add ... Thu, 12 Oct 2017 03:06:43 GMT Chris Johns [7c0c0ba] * source-builder/sb/options.py (modified) sb: Fix the log after breaking adding --without-log Thu, 12 Oct 2017 02:47:23 GMT Chris Johns [d94bd01] * bare/config/devel/autoconf-2.69-1.cfg (modified) * bare/config/devel/automake-1.12.6-1.cfg (modified) * bare/config/devel/dtc-1.4.1-1.cfg (modified) * bare/config/devel/expat-2.1.0-1.cfg (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.26-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.11-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.8.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.9-1.cfg (modified) 4.12: Update all MD5 hashes to SHA256. Closes #2536. Thu, 12 Oct 2017 02:45:54 GMT Chris Johns [f79eaf36] * source-builder/sb/download.py (modified) sb: Remove MD5 and SHA1 as they not secure. Updates #2536. Thu, 12 Oct 2017 02:42:40 GMT Chris Johns [7b68249] * source-builder/sb/options.py (modified) sb: Add --source-only-download to make download source simple. This ... Thu, 12 Oct 2017 02:40:12 GMT Chris Johns [6dc551c] * source-builder/sb/build.py (modified) * source-builder/sb/ereport.py (modified) sb: Move the option check for reporting errors to the error reporter. ... Wed, 11 Oct 2017 12:07:23 GMT Joel Sherrill [c4b6bf0] * rtems/config/tools/rtems-binutils-2.29-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) Enable 64-bit BFD support. Needed on 32bit hosts Closes #3157. Thu, 12 Oct 2017 02:08:05 GMT Joel Sherrill [c7f286e] * rtems/config/4.12/rtems-sh.bset (modified) rtems-sh.bset: Use default toolset specifically GCC 7 Closes #3178. Thu, 12 Oct 2017 02:06:28 GMT Joel Sherrill [53e88be] * rtems/config/4.12/rtems-moxie.bset (modified) rtems-moxie.bset: Add revision Closes #3046. Thu, 05 Oct 2017 06:19:41 GMT Sebastian Huber [76d9db3] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-riscv32.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg (added) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg (added) 4.12: Update to Newlib 2.5.0.20170922 The time_t is now a 64-bit ... Fri, 22 Sep 2017 01:54:06 GMT Chris Johns [55f2d69] * source-builder/sb/path.py (modified) sb: Allow checking if '.' exists as a path. Fri, 22 Sep 2017 01:55:10 GMT Chris Johns [1519d11] * source-builder/sb/git.py (modified) sb: Ignore untracked files or detached HEAD in the dirty repo check. ... Sat, 09 Sep 2017 22:58:34 GMT Chris Johns [e6d0a8b] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) mips: Use the FreeBSD fix for Darwin MIP tools build. Closes 3127. Fri, 08 Sep 2017 11:41:00 GMT Sebastian Huber [c395d96] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gdb-8.0.1-1.cfg (added) 4.12: Update to GDB 8.0.1 Fri, 25 Aug 2017 12:35:05 GMT Sebastian Huber [4f364ef] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) 4.12: Change clock_t to 64-bit Update #2135. Update #3111. Wed, 23 Aug 2017 05:21:05 GMT Sebastian Huber [e960835] * rtems/config/4.12/rtems-all.bset (modified) 4.12: Add riscv32 to all Update #3109. Tue, 22 Aug 2017 14:10:38 GMT Sebastian Huber [7e3ff84] * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) 4.12: Fix 64-bit PowerPC support of GCC 7.2 Update #3082. Tue, 22 Aug 2017 13:07:37 GMT Sebastian Huber [beda114] * rtems/config/4.12/rtems-riscv32.bset (added) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (modified) 4.12: Add basic RISC-V tool chain GDB is not included. This ... Tue, 22 Aug 2017 05:23:23 GMT Sebastian Huber [630e658c] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg (added) * source-builder/config/gcc-7.2-1.cfg (added) 4.12: Update to GCC 7.2 Tue, 22 Aug 2017 05:05:00 GMT Sebastian Huber [0a18a8f] * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg (added) 4.12: Update to Newlib 2.5.0.20170818 Mon, 21 Aug 2017 07:24:23 GMT Chris Johns [bb004cd] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg (added) Update to the newlib snapshot 20170818. Thu, 10 Aug 2017 08:02:51 GMT Sebastian Huber [7208ab6] * rtems/config/tools/rtems-binutils-2.29-1.cfg (modified) 4.12: Fix for Binutils PR21884 See ... Tue, 08 Aug 2017 23:29:45 GMT Chris Johns [9cf5427] * rtems/config/4.12/rtems-lm32.bset (modified) 4.12/lm32: Fix building on Windows. This patch fixes building the ... Tue, 08 Aug 2017 10:44:16 GMT Chris Johns [826e526] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) 4.12/gcc-4.8.3 Fix building with a newer version of gcc. Updates #2990. Tue, 08 Aug 2017 10:25:23 GMT Chris Johns [71c76d0] * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) gcc: Disable makeinfo cause newer versions do not build gcc-4.8 docs. ... Tue, 08 Aug 2017 10:16:03 GMT Chris Johns [4578e0a] * source-builder/sb/path.py (modified) sb: Fix long path support in copy_tree and removeall path support. ... Tue, 08 Aug 2017 05:24:05 GMT Sebastian Huber [2064f90] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg (added) 4.12: Update to Newlib 2.5.0.20170720 Sun, 06 Aug 2017 23:59:49 GMT Chris Johns [8b96e17] * LICENSE (added) * README (modified) * doc/.gitignore (deleted) * doc/host-results.csv (deleted) * doc/images/icons/README (deleted) * doc/images/icons/callouts/1.png (deleted) * doc/images/icons/callouts/10.png (deleted) * doc/images/icons/callouts/11.png (deleted) * doc/images/icons/callouts/12.png (deleted) * doc/images/icons/callouts/13.png (deleted) * doc/images/icons/callouts/14.png (deleted) * doc/images/icons/callouts/15.png (deleted) * doc/images/icons/callouts/2.png (deleted) * doc/images/icons/callouts/3.png (deleted) * doc/images/icons/callouts/4.png (deleted) * doc/images/icons/callouts/5.png (deleted) * doc/images/icons/callouts/6.png (deleted) * doc/images/icons/callouts/7.png (deleted) * doc/images/icons/callouts/8.png (deleted) * doc/images/icons/callouts/9.png (deleted) * doc/images/icons/caution.png (deleted) * doc/images/icons/example.png (deleted) * doc/images/icons/home.png (deleted) * doc/images/icons/important.png (deleted) * doc/images/icons/next.png (deleted) * doc/images/icons/note.png (deleted) * doc/images/icons/prev.png (deleted) * doc/images/icons/tip.png (deleted) * doc/images/icons/up.png (deleted) * doc/images/icons/warning.png (deleted) * doc/images/rtemswhitebg.jpg (deleted) * doc/source-builder.txt (deleted) * doc/wscript (deleted) * source-builder/sb/asciidoc/BUGS (deleted) * source-builder/sb/asciidoc/BUGS.txt (deleted) * source-builder/sb/asciidoc/CHANGELOG (deleted) * source-builder/sb/asciidoc/CHANGELOG.txt (deleted) * source-builder/sb/asciidoc/COPYING (deleted) * source-builder/sb/asciidoc/COPYRIGHT (deleted) * source-builder/sb/asciidoc/INSTALL (deleted) * source-builder/sb/asciidoc/INSTALL.txt (deleted) * source-builder/sb/asciidoc/MANIFEST (deleted) * source-builder/sb/asciidoc/Makefile.in (deleted) * source-builder/sb/asciidoc/README (deleted) * source-builder/sb/asciidoc/README.txt (deleted) * source-builder/sb/asciidoc/a2x.py (deleted) * source-builder/sb/asciidoc/asciidoc.conf (deleted) * source-builder/sb/asciidoc/asciidoc.py (deleted) * source-builder/sb/asciidoc/asciidocapi.py (deleted) * source-builder/sb/asciidoc/common.aap (deleted) * source-builder/sb/asciidoc/configure (deleted) * source-builder/sb/asciidoc/configure.ac (deleted) * source-builder/sb/asciidoc/dblatex/asciidoc-dblatex.sty (deleted) * source-builder/sb/asciidoc/dblatex/asciidoc-dblatex.xsl (deleted) * source-builder/sb/asciidoc/dblatex/dblatex-readme.txt (deleted) * source-builder/sb/asciidoc/doc/a2x.1 (deleted) * source-builder/sb/asciidoc/doc/a2x.1.txt (deleted) * source-builder/sb/asciidoc/doc/article-docinfo.xml (deleted) * source-builder/sb/asciidoc/doc/article.pdf (deleted) * source-builder/sb/asciidoc/doc/article.txt (deleted) * source-builder/sb/asciidoc/doc/asciidoc.1 (deleted) * source-builder/sb/asciidoc/doc/asciidoc.1.txt (deleted) * source-builder/sb/asciidoc/doc/asciidoc.conf (deleted) * source-builder/sb/asciidoc/doc/asciidoc.dict (deleted) * source-builder/sb/asciidoc/doc/asciidoc.txt (deleted) * source-builder/sb/asciidoc/doc/asciidocapi.txt (deleted) * source-builder/sb/asciidoc/doc/asciimathml.txt (deleted) * source-builder/sb/asciidoc/doc/book-multi.txt (deleted) * source-builder/sb/asciidoc/doc/book.epub (deleted) * source-builder/sb/asciidoc/doc/book.txt (deleted) * source-builder/sb/asciidoc/doc/customers.csv (deleted) * source-builder/sb/asciidoc/doc/epub-notes.txt (deleted) * source-builder/sb/asciidoc/doc/faq.txt (deleted) * source-builder/sb/asciidoc/doc/images/icons/README (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/1.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/10.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/11.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/12.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/13.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/14.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/15.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/2.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/3.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/4.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/5.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/6.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/7.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/8.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/callouts/9.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/caution.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/example.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/home.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/important.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/next.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/note.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/prev.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/tip.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/up.png (deleted) * source-builder/sb/asciidoc/doc/images/icons/warning.png (deleted) * source-builder/sb/asciidoc/doc/images/smallnew.png (deleted) * source-builder/sb/asciidoc/doc/images/tiger.png (deleted) * source-builder/sb/asciidoc/doc/latex-backend.txt (deleted) * source-builder/sb/asciidoc/doc/latex-bugs.txt (deleted) * source-builder/sb/asciidoc/doc/latex-filter.pdf (deleted) * source-builder/sb/asciidoc/doc/latex-filter.txt (deleted) * source-builder/sb/asciidoc/doc/latexmath.txt (deleted) * source-builder/sb/asciidoc/doc/latexmathml.txt (deleted) * source-builder/sb/asciidoc/doc/main.aap (deleted) * source-builder/sb/asciidoc/doc/music-filter.pdf (deleted) * source-builder/sb/asciidoc/doc/music-filter.txt (deleted) * source-builder/sb/asciidoc/doc/publishing-ebooks-with-asciidoc.txt (deleted) * source-builder/sb/asciidoc/doc/slidy-example.txt (deleted) * source-builder/sb/asciidoc/doc/slidy.txt (deleted) * source-builder/sb/asciidoc/doc/source-highlight-filter.pdf (deleted) * source-builder/sb/asciidoc/doc/source-highlight-filter.txt (deleted) * source-builder/sb/asciidoc/doc/testasciidoc.txt (deleted) * source-builder/sb/asciidoc/docbook-xsl/asciidoc-docbook-xsl.txt (deleted) * source-builder/sb/asciidoc/docbook-xsl/chunked.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/common.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/epub.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/fo.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/htmlhelp.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/manpage.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/text.xsl (deleted) * source-builder/sb/asciidoc/docbook-xsl/xhtml.xsl (deleted) * source-builder/sb/asciidoc/docbook45.conf (deleted) * source-builder/sb/asciidoc/examples/website/ASCIIMathML.js (deleted) * source-builder/sb/asciidoc/examples/website/CHANGELOG.txt (deleted) * source-builder/sb/asciidoc/examples/website/INSTALL.txt (deleted) * source-builder/sb/asciidoc/examples/website/LaTeXMathML.js (deleted) * source-builder/sb/asciidoc/examples/website/README-website.txt (deleted) * source-builder/sb/asciidoc/examples/website/README.txt (deleted) * source-builder/sb/asciidoc/examples/website/a2x.1.txt (deleted) * source-builder/sb/asciidoc/examples/website/asciidoc-docbook-xsl.txt (deleted) * source-builder/sb/asciidoc/examples/website/asciidoc-graphviz-sample.txt (deleted) * source-builder/sb/asciidoc/examples/website/asciidoc.css (deleted) * source-builder/sb/asciidoc/examples/website/asciidoc.js (deleted) * source-builder/sb/asciidoc/examples/website/asciidocapi.txt (deleted) * source-builder/sb/asciidoc/examples/website/asciimathml.txt (deleted) * source-builder/sb/asciidoc/examples/website/build-website.sh (deleted) * source-builder/sb/asciidoc/examples/website/customers.csv (deleted) * source-builder/sb/asciidoc/examples/website/epub-notes.txt (deleted) * source-builder/sb/asciidoc/examples/website/faq.txt (deleted) * source-builder/sb/asciidoc/examples/website/images/highlighter.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/README (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/1.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/10.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/11.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/12.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/13.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/14.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/15.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/2.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/3.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/4.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/5.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/6.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/7.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/8.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/callouts/9.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/caution.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/example.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/home.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/important.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/next.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/note.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/prev.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/tip.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/up.png (deleted) * source-builder/sb/asciidoc/examples/website/images/icons/warning.png (deleted) * source-builder/sb/asciidoc/examples/website/images/smallnew.png (deleted) * source-builder/sb/asciidoc/examples/website/images/tiger.png (deleted) * source-builder/sb/asciidoc/examples/website/index.txt (deleted) * source-builder/sb/asciidoc/examples/website/latex-backend.txt (deleted) * source-builder/sb/asciidoc/examples/website/latex-bugs.txt (deleted) * source-builder/sb/asciidoc/examples/website/latex-filter.txt (deleted) * source-builder/sb/asciidoc/examples/website/latexmathml.txt (deleted) * source-builder/sb/asciidoc/examples/website/layout1.conf (deleted) * source-builder/sb/asciidoc/examples/website/layout1.css (deleted) * source-builder/sb/asciidoc/examples/website/layout2.conf (deleted) * source-builder/sb/asciidoc/examples/website/layout2.css (deleted) * source-builder/sb/asciidoc/examples/website/main.aap (deleted) * source-builder/sb/asciidoc/examples/website/manpage.txt (deleted) * source-builder/sb/asciidoc/examples/website/music-filter.txt (deleted) * source-builder/sb/asciidoc/examples/website/newlists.txt (deleted) * source-builder/sb/asciidoc/examples/website/newtables.txt (deleted) * source-builder/sb/asciidoc/examples/website/plugins.txt (deleted) * source-builder/sb/asciidoc/examples/website/publishing-ebooks-with-asciidoc.txt (deleted) * source-builder/sb/asciidoc/examples/website/slidy-example.txt (deleted) * source-builder/sb/asciidoc/examples/website/slidy.txt (deleted) * source-builder/sb/asciidoc/examples/website/source-highlight-filter.txt (deleted) * source-builder/sb/asciidoc/examples/website/support.txt (deleted) * source-builder/sb/asciidoc/examples/website/testasciidoc.txt (deleted) * source-builder/sb/asciidoc/examples/website/userguide.txt (deleted) * source-builder/sb/asciidoc/examples/website/version83.txt (deleted) * source-builder/sb/asciidoc/examples/website/xhtml11-quirks.css (deleted) * source-builder/sb/asciidoc/filters/code/code-filter-readme.txt (deleted) * source-builder/sb/asciidoc/filters/code/code-filter-test.txt (deleted) * source-builder/sb/asciidoc/filters/code/code-filter.conf (deleted) * source-builder/sb/asciidoc/filters/code/code-filter.py (deleted) * source-builder/sb/asciidoc/filters/graphviz/asciidoc-graphviz-sample.txt (deleted) * source-builder/sb/asciidoc/filters/graphviz/graphviz-filter.conf (deleted) * source-builder/sb/asciidoc/filters/graphviz/graphviz2png.py (deleted) * source-builder/sb/asciidoc/filters/latex/latex-filter.conf (deleted) * source-builder/sb/asciidoc/filters/latex/latex2png.py (deleted) * source-builder/sb/asciidoc/filters/music/music-filter-test.txt (deleted) * source-builder/sb/asciidoc/filters/music/music-filter.conf (deleted) * source-builder/sb/asciidoc/filters/music/music2png.py (deleted) * source-builder/sb/asciidoc/filters/source/source-highlight-filter-test.txt (deleted) * source-builder/sb/asciidoc/filters/source/source-highlight-filter.conf (deleted) * source-builder/sb/asciidoc/help.conf (deleted) * source-builder/sb/asciidoc/html4.conf (deleted) * source-builder/sb/asciidoc/html5.conf (deleted) * source-builder/sb/asciidoc/images/highlighter.png (deleted) * source-builder/sb/asciidoc/images/icons/README (deleted) * source-builder/sb/asciidoc/images/icons/callouts/1.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/10.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/11.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/12.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/13.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/14.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/15.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/2.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/3.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/4.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/5.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/6.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/7.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/8.png (deleted) * source-builder/sb/asciidoc/images/icons/callouts/9.png (deleted) * source-builder/sb/asciidoc/images/icons/caution.png (deleted) * source-builder/sb/asciidoc/images/icons/example.png (deleted) * source-builder/sb/asciidoc/images/icons/home.png (deleted) * source-builder/sb/asciidoc/images/icons/important.png (deleted) * source-builder/sb/asciidoc/images/icons/next.png (deleted) * source-builder/sb/asciidoc/images/icons/note.png (deleted) * source-builder/sb/asciidoc/images/icons/prev.png (deleted) * source-builder/sb/asciidoc/images/icons/tip.png (deleted) * source-builder/sb/asciidoc/images/icons/up.png (deleted) * source-builder/sb/asciidoc/images/icons/warning.png (deleted) * source-builder/sb/asciidoc/images/smallnew.png (deleted) * source-builder/sb/asciidoc/images/tiger.png (deleted) * source-builder/sb/asciidoc/install-sh (deleted) * source-builder/sb/asciidoc/javascripts/ASCIIMathML.js (deleted) * source-builder/sb/asciidoc/javascripts/LaTeXMathML.js (deleted) * source-builder/sb/asciidoc/javascripts/asciidoc.js (deleted) * source-builder/sb/asciidoc/javascripts/slidy.js (deleted) * source-builder/sb/asciidoc/javascripts/toc.js (deleted) * source-builder/sb/asciidoc/lang-de.conf (deleted) * source-builder/sb/asciidoc/lang-el.conf (deleted) * source-builder/sb/asciidoc/lang-en.conf (deleted) * source-builder/sb/asciidoc/lang-es.conf (deleted) * source-builder/sb/asciidoc/lang-fr.conf (deleted) * source-builder/sb/asciidoc/lang-hu.conf (deleted) * source-builder/sb/asciidoc/lang-it.conf (deleted) * source-builder/sb/asciidoc/lang-nl.conf (deleted) * source-builder/sb/asciidoc/lang-pt-BR.conf (deleted) * source-builder/sb/asciidoc/lang-ru.conf (deleted) * source-builder/sb/asciidoc/lang-uk.conf (deleted) * source-builder/sb/asciidoc/latex.conf (deleted) * source-builder/sb/asciidoc/main.aap (deleted) * source-builder/sb/asciidoc/slidy.conf (deleted) * source-builder/sb/asciidoc/stylesheets/asciidoc.css (deleted) * source-builder/sb/asciidoc/stylesheets/docbook-xsl.css (deleted) * source-builder/sb/asciidoc/stylesheets/pygments.css (deleted) * source-builder/sb/asciidoc/stylesheets/slidy.css (deleted) * source-builder/sb/asciidoc/stylesheets/toc2.css (deleted) * source-builder/sb/asciidoc/stylesheets/xhtml11-quirks.css (deleted) * source-builder/sb/asciidoc/tests/asciidocapi.py (deleted) * source-builder/sb/asciidoc/tests/data/deprecated-quotes.txt (deleted) * source-builder/sb/asciidoc/tests/data/filters-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-de-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-de-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-en-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-en-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-es-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-es-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-fr-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-fr-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-hu-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-hu-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-it-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-it-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-nl-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-nl-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-pt-BR-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-pt-BR-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-ru-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-ru-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-uk-man-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/lang-uk-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/oldtables.txt (deleted) * source-builder/sb/asciidoc/tests/data/open-block-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/rcs-id-marker-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/testcases.conf (deleted) * source-builder/sb/asciidoc/tests/data/testcases.txt (deleted) * source-builder/sb/asciidoc/tests/data/utf8-bom-test.txt (deleted) * source-builder/sb/asciidoc/tests/data/utf8-examples.txt (deleted) * source-builder/sb/asciidoc/tests/testasciidoc.conf (deleted) * source-builder/sb/asciidoc/tests/testasciidoc.py (deleted) * source-builder/sb/asciidoc/text.conf (deleted) * source-builder/sb/asciidoc/themes/flask/flask.css (deleted) * source-builder/sb/asciidoc/themes/volnitsky/volnitsky.css (deleted) * source-builder/sb/asciidoc/vim/ftdetect/asciidoc_filetype.vim (deleted) * source-builder/sb/asciidoc/vim/syntax/asciidoc.vim (deleted) * source-builder/sb/asciidoc/wordpress.conf (deleted) * source-builder/sb/asciidoc/xhtml11-quirks.conf (deleted) * source-builder/sb/asciidoc/xhtml11.conf (deleted) * source-builder/sb/asciidocapi.py (deleted) * source-builder/sb/markdown/LICENSE.md (added) * source-builder/sb/markdown/README.md (added) * source-builder/sb/markdown/__init__.py (added) * source-builder/sb/markdown/__main__.py (added) * source-builder/sb/markdown/__version__.py (added) * source-builder/sb/markdown/blockparser.py (added) * source-builder/sb/markdown/blockprocessors.py (added) * source-builder/sb/markdown/extensions/__init__.py (added) * source-builder/sb/markdown/extensions/abbr.py (added) * source-builder/sb/markdown/extensions/admonition.py (added) * source-builder/sb/markdown/extensions/attr_list.py (added) * source-builder/sb/markdown/extensions/codehilite.py (added) * source-builder/sb/markdown/extensions/def_list.py (added) * source-builder/sb/markdown/extensions/extra.py (added) * source-builder/sb/markdown/extensions/fenced_code.py (added) * source-builder/sb/markdown/extensions/footnotes.py (added) * source-builder/sb/markdown/extensions/headerid.py (added) * source-builder/sb/markdown/extensions/meta.py (added) * source-builder/sb/markdown/extensions/nl2br.py (added) * source-builder/sb/markdown/extensions/sane_lists.py (added) * source-builder/sb/markdown/extensions/smart_strong.py (added) * source-builder/sb/markdown/extensions/smarty.py (added) * source-builder/sb/markdown/extensions/tables.py (added) * source-builder/sb/markdown/extensions/toc.py (added) * source-builder/sb/markdown/extensions/wikilinks.py (added) * source-builder/sb/markdown/inlinepatterns.py (added) * source-builder/sb/markdown/odict.py (added) * source-builder/sb/markdown/postprocessors.py (added) * source-builder/sb/markdown/preprocessors.py (added) * source-builder/sb/markdown/serializers.py (added) * source-builder/sb/markdown/treeprocessors.py (added) * source-builder/sb/markdown/util.py (added) * source-builder/sb/reports.py (modified) doc: Remove in source documentation and the asciidoc package The ... Mon, 31 Jul 2017 12:21:05 GMT Sebastian Huber [295c197] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) 4.12: Fix SIS patch URL Mon, 31 Jul 2017 12:15:22 GMT Jiri Gaisler [6efd9757] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) RSB: Update gdb-7.12 config to pull in latest sis patches Please ... Thu, 27 Jul 2017 11:36:33 GMT Sebastian Huber [1ceafe5] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-binutils-2.29-1.cfg (added) 4.12: Update to Binutils 2.29 Update #3082. Fri, 21 Jul 2017 16:08:07 GMT Jiri Gaisler [6347c47] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) Update gdb-7.12 config to pull in latest sis patches. This ... Mon, 17 Jul 2017 06:30:36 GMT Sebastian Huber [e2952bb] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Add LEON3FT store-store errata workaround Close #3057. Mon, 10 Jul 2017 01:44:32 GMT Chris Johns [4f3b8da] * source-builder/sb/download.py (modified) sb/download: Fix --rsb-file options with released sources. The ... Wed, 12 Jul 2017 06:14:44 GMT Sebastian Huber [8397320] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Fix bitset(9) Update #3059. Mon, 10 Jul 2017 06:15:46 GMT Sebastian Huber [fd03ba4] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Fix and update bitset(9) Update #3059. Sat, 01 Jul 2017 16:01:20 GMT Andreas Kölbl [d413d7e] * source-builder/config/gdb-7-1.cfg (modified) Fix GDB build on ArchLinux Archlinux provides both, libguile v2.0 ... Fri, 30 Jun 2017 12:56:32 GMT Sebastian Huber [5ede1c7] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (modified) 4.12: Enable global stdio streams Update #3012. Mon, 26 Jun 2017 06:13:01 GMT Sebastian Huber [78f44be] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170623 Sun, 25 Jun 2017 23:27:55 GMT Chris Johns [e02139d] * source-builder/sb/config.py (modified) sb: Fix 'bare' builds with --trace. Fri, 23 Jun 2017 05:33:06 GMT Sebastian Huber [21a9010] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) Fix GDB 7.12 build on Darwin Close #3052. Tue, 20 Jun 2017 11:25:57 GMT Sebastian Huber [34a3103] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (modified) Fix GCC 7.1 for m68k https://gcc.gnu.org/bugzilla/show_bug.cgi?id=80970 Wed, 14 Jun 2017 08:09:48 GMT Sebastian Huber [cb3fac1] * source-builder/sb/path.py (modified) sb: Make error messages unique Enable traceability from the error ... Tue, 13 Jun 2017 06:24:14 GMT Sebastian Huber [0ba8934] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg (modified) Fix for GCC 6 while building with GCC 7+ Mon, 12 Jun 2017 07:23:21 GMT Sebastian Huber [c336dc9] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (modified) 4.12: Add SMP support for Ada of GCC 7.1 Close #2289. Mon, 12 Jun 2017 06:56:44 GMT Sebastian Huber [a197dd9] * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (modified) 4.12: Add Newlib patch for Update #2833. Mon, 12 Jun 2017 11:08:39 GMT Sebastian Huber [20bc1ec] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) Fix for GDB 7.12 while building with GCC 7+ Thu, 08 Jun 2017 05:21:07 GMT Sebastian Huber [0a0d1c8] * source-builder/sb/download.py (modified) sb: Restrict file name length Thu, 08 Jun 2017 05:07:27 GMT Sebastian Huber [2c13f00] * source-builder/config/gcc-4.9-1.cfg (modified) Reduce file name length to make Windows happy Fri, 02 Jun 2017 09:17:41 GMT Sebastian Huber [6987fa5] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170519 Add POSIX header file ... Fri, 02 Jun 2017 08:40:15 GMT Sebastian Huber [b198c46] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (modified) Use default prerequisites for GCC 7.1 Use prerequisites as defined ... Tue, 06 Jun 2017 04:46:43 GMT Sebastian Huber [94083b0] * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (modified) * source-builder/config/gcc-7-1.cfg (added) Add GCC 7 base configuration Fri, 02 Jun 2017 12:07:45 GMT Sebastian Huber [7c121ca] * source-builder/config/gcc-4.9-1.cfg (modified) Fix for GCC 4.9 while building with GCC 6+ See also: ... Fri, 02 Jun 2017 12:38:13 GMT Sebastian Huber [e1257d4] * source-builder/sb/download.py (modified) sb: Create hopefully more valid file names Thu, 01 Jun 2017 03:37:18 GMT Chris Johns [6b8dbdf] * rtems/config/4.12/rtems-powerpc.bset (modified) 4.12/powerpc: Revert the PowerPC to the default and binutils-2.28. Thu, 01 Jun 2017 03:36:55 GMT Chris Johns [0066727] * rtems/config/4.12/rtems-sh.bset (modified) 4.12/sh: Fix comment. Wed, 31 May 2017 10:24:49 GMT Chris Johns [9b79c7b] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-powerpc.bset (modified) * rtems/config/4.12/rtems-sh.bset (modified) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (modified) Fixes to get a clean build with gcc-7.1.0/binutils-2.28. - SH has ... Fri, 12 May 2017 16:46:31 GMT Joel Sherrill [68d2cdd] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.28-1.cfg (added) * rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg (added) Update tools to gcc 7.1.0 and binutils 2.28 Thu, 18 May 2017 05:15:19 GMT Chris Johns [5feef65] * rtems/config/tools/rtems-gdb-7.12-1.cfg (modified) 4.12/powerpc/gdb: Fix building the simulator on FreeBSD. Thu, 18 May 2017 05:14:21 GMT Chris Johns [7ebd0e9] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg (modified) 4.12/mips: Fix building on FreeBSD. Wed, 10 May 2017 00:41:19 GMT Chris Johns [f99c37e] * source-builder/sb/bootstrap.py (modified) * source-builder/sb/options.py (modified) bootstrap: Do not create a log file by default. Thu, 13 Apr 2017 07:50:31 GMT Chris Johns [2074bd1] * rtems/config/tools/rtems-tools-common-1.cfg (modified) rtems-tools: Start a build with a distclean to clean away an old ... Tue, 11 Apr 2017 12:12:13 GMT Chris Johns [4141cca] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) Fix rtems-tools and rtems-kernel builds when released and with a ... Mon, 10 Apr 2017 07:30:06 GMT Chris Johns [44ebcc5] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-tools-1.cfg (modified) Fix the tools and kernel source URL when released to use `sources`. ... Tue, 04 Apr 2017 11:56:41 GMT Sebastian Huber [8e6ba2c] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg (modified) 4.12: Add Newlib patches for libbsd update Fri, 31 Mar 2017 07:55:08 GMT Sebastian Huber [1ad33b0] * source-builder/config/gcc-common-1.cfg (modified) Always use GCC provided zlib Always use the GCC provided zlib to ... Mon, 27 Mar 2017 06:20:00 GMT Chris Johns [b64b38e] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.12: Fix the patch URL. Mon, 27 Mar 2017 06:12:25 GMT Sebastian Huber [aa3d0fe] * rtems/config/4.12/rtems-default.bset (modified) * rtems/config/4.12/rtems-epiphany.bset (modified) * rtems/config/4.12/rtems-m32c.bset (modified) * rtems/config/4.12/rtems-or1k.bset (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg (added) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg (added) 4.12: Update to use Newlib 2.5.0.20170323 Sun, 26 Mar 2017 03:47:55 GMT Chris Johns [b47a811] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.11/arm: Fix the path to the sqrt patch. Use the upstream patch ... Tue, 21 Mar 2017 03:08:45 GMT Chris Johns [902119e] * source-builder/sb/freebsd.py (modified) freebsd: Update makeinfo and install-info paths on FreeBSD 11.0 ... Sun, 26 Mar 2017 02:19:18 GMT Chris Johns [78e7f6a] * source-builder/sb/download.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/version.py (modified) sb: Add the `release_path` key to the `version` section in the ... Thu, 23 Mar 2017 07:28:24 GMT Sebastian Huber [4e5b7fd] * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.12: ARM: Optimize IEEE-754 sqrt implementation Update #2948. Thu, 02 Mar 2017 07:49:22 GMT Sebastian Huber [10d9e2d] * rtems/config/hash.cfg (deleted) * rtems/config/rtems-base.bset (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-2.2.0-2.cfg (deleted) * rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9-newlib-2.2.0-2.cfg (deleted) * rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg (modified) * rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg (modified) 4.12: Do not use a global hash file
