# # ChangeLog for / in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/18/24 06:32:10 Thu, 18 Nov 2021 17:16:25 GMT Joel Sherrill [ad54d1d] * bare/config/devel/dtc.bset (modified) bare/.../dtc.bset: Update to 1.6.1 like other cases Sat, 13 Nov 2021 11:57:29 GMT Karel Gardas [f2a8973] * bare/config/devel/dtc-1.6.1-1.cfg (added) * bare/config/devel/qemu-couverture.bset (modified) * rtems/config/6/rtems-default.bset (modified) * rtems/config/7/rtems-default.bset (modified) RSB: update dtc 1.6.0 -> dtc 1.6.1 Fixes #4221 Note: the patch ... Sat, 13 Nov 2021 21:22:34 GMT Karel Gardas [081f8ff] * rtems/config/tools/rtems-binutils-2.37.cfg (modified) RSB: fix hash setup for binutils 2.37 Wed, 10 Nov 2021 18:27:22 GMT Karel Gardas [dbc11a8] * rtems/config/6/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-grub-2.06.cfg (added) * source-builder/config/grub2.cfg (added) RSB: add GRUB2 to the RTEMS tools and use it in 6/rtems-x86_64 build set Fri, 12 Nov 2021 14:53:59 GMT Joel Sherrill [e4f6037] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Bump hash to get fix for rtems-test Sun, 07 Nov 2021 22:15:52 GMT Joel Sherrill [6bc7cac] * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-microblaze.bset (modified) * rtems/config/6/rtems-moxie.bset (modified) * rtems/config/7/rtems-default.bset (modified) * rtems/config/7/rtems-moxie.bset (modified) config/[67]/rtems-*.bset: Move dtc to default set Sun, 07 Nov 2021 22:15:05 GMT Joel Sherrill [09498ee] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Bump rtems-tools hash Tue, 12 Oct 2021 19:01:44 GMT Ryan Long [def9347] * rtems/config/tools/rtems-kernel-6.cfg (modified) * rtems/config/tools/rtems-kernel-common.cfg (modified) * source-builder/sb/rtems-kernel-config-check (added) rtems-kernel: Implement kernel recipe using waf Closes #4145 Thu, 04 Nov 2021 19:25:42 GMT Kinsey Moore [33d8196] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) rtems-gcc-10-newlib-head: Uncomment patch lines These lines were ... Thu, 14 Oct 2021 06:44:08 GMT Alex White [e845bd5] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Bump hash to include MicroBlaze Hash: ... Wed, 13 Oct 2021 14:31:06 GMT Ryan Long [e04fddc] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.37.cfg (added) * rtems/config/tools/rtems-binutils-head.cfg (modified) rtems-binutils: Update to 2.37 and update head Update to binutils ... Thu, 07 Oct 2021 17:50:05 GMT Sebastian Huber [889cf95] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) Update newlib to fetch optimizations Close #4522. Fri, 03 Sep 2021 17:13:08 GMT Ryan Long [3950b1e] * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) rtems-gcc-head-newlib-head.cfg: Add newlib patch Adds patch to add ... Fri, 03 Sep 2021 14:20:37 GMT Ryan Long [0e54d58] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) rtems-gcc-10-newlib-head.cfg: Add newlib patch Adds patch to add ... Thu, 16 Sep 2021 19:26:23 GMT Joel Sherrill [a178eba] * rtems/config/6/rtems-autotools-base.bset (deleted) * rtems/config/6/rtems-autotools-internal.bset (deleted) * rtems/config/6/rtems-autotools.bset (deleted) * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-microblaze.bset (modified) Remove automake/autoconf from rtems 6 tools These are unneeded with ... Thu, 09 Sep 2021 08:44:50 GMT Chris Johns [7f7f00d] * rtems/config/6/rtems-tools.bset (modified) * rtems/config/tools/rtems-tools-6.cfg (modified) 6/rtems-tools: Update to rtems-test TFTP timeout fixes - Fix the ... Tue, 07 Sep 2021 16:46:32 GMT Joel Sherrill [55574f8] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Correct checksum missing in previous patch Mon, 06 Sep 2021 20:02:09 GMT Joel Sherrill [0960c26] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Bump hash to include fixes for clang Hash: ... Fri, 03 Sep 2021 00:52:28 GMT Joel Sherrill [4137b99] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) Update newlib to 9069cb9 hash This update is to include a fix for ... Mon, 30 Aug 2021 08:54:53 GMT Sebastian Huber [a1f7b3b] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) 6: Back port v5 of __gcov_info_to_gcda() to GCC 10 Update #4196. Wed, 30 Jun 2021 19:58:42 GMT Alex White [d162b7d] * bare/config/devel/qemu-xilinx-v2020.2-1.cfg (added) * bare/config/devel/qemu-xilinx.bset (added) rsb: Add Xilinx QEMU Thu, 19 Aug 2021 03:35:00 GMT Alex White [b3786d7] * rtems/config/6/rtems-microblaze.bset (modified) * rtems/config/tools/rtems-xilinx-binutils-2.36.cfg (added) * rtems/config/tools/rtems-xilinx-gcc-10-newlib-head.cfg (added) rsb: Add MicroBlaze tools Wed, 18 Aug 2021 13:13:57 GMT Joel Sherrill [31055f2] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Bump to latest hash. Latest is ... Wed, 18 Aug 2021 13:12:33 GMT Joel Sherrill [fd31a30] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) rtems-gcc-10-newlib-head.cfg: Bump to latest hash (4f81149) Mon, 09 Aug 2021 18:46:08 GMT Sebastian Huber [ec495e0] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) 6: Back port v3 of __gcov_info_to_gcda() to GCC 10 Update #4196. Mon, 09 Aug 2021 15:33:24 GMT Sebastian Huber [ca5c27d] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) 6: Back port v2 of __gcov_info_to_gcda() to GCC 10 Update #4196. Fri, 06 Aug 2021 15:27:25 GMT Sebastian Huber [6c0d7b6] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) 6: Back port __gcov_info_to_gcda() to GCC 10 Close #4196. Wed, 04 Aug 2021 16:24:54 GMT Sebastian Huber [6614beb] * bare/config/devel/sis-2-1.cfg (modified) sis: update to version 2.29 Fri, 30 Jul 2021 13:27:25 GMT Sebastian Huber [f12dee0] * bare/config/devel/sis-2-1.cfg (modified) sis: update to version 2.28 Fri, 16 Jul 2021 12:15:50 GMT Robin Mueller [c938bd7] * source-builder/sb/setbuilder.py (modified) setbuilder minor list-host option This adds a way to print the host ... Thu, 15 Jul 2021 14:13:08 GMT Jiri Gaisler [8c8c374] * bare/config/devel/sis-2-1.cfg (modified) sis: update to version 2.27 Tue, 19 Jan 2021 19:02:11 GMT Alex White [e298dc8] * bare/config/devel/qemu-couverture-git-1.cfg (modified) Add aarch64 target to qemu-couverture Wed, 30 Jun 2021 09:06:09 GMT Chris Johns [9c33ea0] * source-builder/defaults.mc (modified) defaults.mc: Remove any checks for objdump and objcopy - FreeBSD is ... Wed, 21 Apr 2021 21:58:09 GMT Alex White [4e6dc64] * source-builder/sb/mailer.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Merge mailer changes from rtems-tools This adds the improved ... Fri, 21 May 2021 16:24:10 GMT Joel Sherrill [774b5fc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) rtems-binutils-head.cfg, rtems-gdb-head.cfg: Bump to 3b2bef8 Fri, 21 May 2021 14:24:48 GMT Joel Sherrill [5e2d92f] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) Bump newlib for rtems 6 and 7 to get UTIME_NOW and UTIME_OMIT constants. Fri, 09 Apr 2021 12:48:00 GMT Sebastian Huber [4e256fc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 09 Apr 2021 12:47:52 GMT Sebastian Huber [c25e4d4] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Fri, 09 Apr 2021 12:33:29 GMT Sebastian Huber [fc6fac1] * rtems/config/tools/rtems-tools-6.cfg (modified) 6/7: Update to the latest rtems-tools Tue, 16 Mar 2021 06:38:16 GMT Sebastian Huber [62363ba] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Tue, 16 Mar 2021 06:38:09 GMT Sebastian Huber [775df1f] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Thu, 11 Mar 2021 07:32:08 GMT Ricardo Cárdenes [5e449fb] * source-builder/sb/config.py (modified) sb/config.py: Fix operator reconstruction Close #4335 Tue, 09 Mar 2021 18:24:21 GMT Vijay Kumar Banerjee [fe2d13b] * rtems/config/6/rtems-net-legacy.bset (added) * rtems/config/tools/rtems-net-legacy-6.cfg (added) * rtems/config/tools/rtems-net-legacy-common.cfg (added) Add recipe for building rtems-net-legacy Tue, 09 Mar 2021 18:10:21 GMT Vijay Kumar Banerjee [2f9a68b] * source-builder/sb/config.py (modified) sb/config.py: Fix relational operator Close #4319 Tue, 09 Mar 2021 19:03:32 GMT Sebastian Huber [47d540e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Tue, 09 Mar 2021 19:03:23 GMT Sebastian Huber [0b44794] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Mon, 08 Mar 2021 10:52:48 GMT Sebastian Huber [56cba3c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Mon, 08 Mar 2021 10:52:40 GMT Sebastian Huber [f21b9ba] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Fri, 05 Mar 2021 06:16:07 GMT Sebastian Huber [102cb1e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 05 Mar 2021 06:15:58 GMT Sebastian Huber [d156707] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Fri, 05 Feb 2021 06:49:46 GMT Sebastian Huber [61dcade] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 05 Feb 2021 06:49:36 GMT Sebastian Huber [c836943] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Mon, 25 Jan 2021 09:44:11 GMT Sebastian Huber [ade0892] * rtems/config/tools/rtems-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (modified) 6: Update tool chain Close #3937. Mon, 25 Jan 2021 09:45:30 GMT Sebastian Huber [c20cba7] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update tool chain Fri, 22 Jan 2021 12:36:56 GMT Sebastian Huber [6a0be2a] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.36.cfg (added) * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-10.cfg (added) 6: Use release branches for Binutils/GDB Thu, 21 Jan 2021 09:07:21 GMT Sebastian Huber [65abc3e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 20 Jan 2021 05:20:46 GMT Sebastian Huber [7117899] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Sun, 17 Jan 2021 18:50:34 GMT Sebastian Huber [e6f29b3] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) 6: Add FPH2 multilib for nios2 Update #4215. Sun, 17 Jan 2021 18:48:19 GMT Sebastian Huber [9c39684] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Thu, 14 Jan 2021 17:06:51 GMT Sebastian Huber [295f9e9] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 13 Jan 2021 09:51:49 GMT Sebastian Huber [3d30eca] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 04 Jan 2021 05:31:53 GMT Sebastian Huber [dd54653] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 04 Jan 2021 05:27:39 GMT Sebastian Huber [1e9c608] * rtems/config/tools/rtems-tools-6.cfg (modified) 6/7: Update to the latest rtems-tools Update #4202. Mon, 21 Dec 2020 16:12:31 GMT Sebastian Huber [d3dc0bc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 21 Dec 2020 06:13:08 GMT Sebastian Huber [1af2038] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Fri, 11 Dec 2020 06:46:46 GMT Sebastian Huber [4301130] * bare/config/devel/gmp-6.1.0.cfg (added) * rtems/config/6/rtems-default.bset (modified) * rtems/config/7/rtems-default.bset (modified) * source-builder/config/gmp.cfg (added) Add GMP as a prerequisite for GDB Mon, 21 Dec 2020 05:39:42 GMT Sebastian Huber [ea77e18] * source-builder/config/expat-2-1.cfg (modified) expat: Disable shared libraries This should ensure that GDB is ... Fri, 18 Dec 2020 21:57:31 GMT Jiri Gaisler [649beb4] * bare/config/devel/sis-2-1.cfg (modified) devel/sis: Update to 2.26 Wed, 16 Dec 2020 07:00:04 GMT Sebastian Huber [6d0bff0] * rtems/config/tools/rtems-tools-6.cfg (modified) 6/7: Update to the latest rtems-tools Fri, 11 Dec 2020 07:02:00 GMT Sebastian Huber [96c1e17] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain This update includes a ... Thu, 03 Dec 2020 18:24:52 GMT Sebastian Huber [9ef9956] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Add multilib for ARM Cortex-R52 processor Close #4198. Wed, 02 Dec 2020 09:58:12 GMT Sebastian Huber [1d9f5d0] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) 6: Add support for gcov info section Update #4196. Wed, 02 Dec 2020 09:02:24 GMT Sebastian Huber [d79b044] * rtems/config/tools/rtems-tools-6.cfg (modified) 6/7: Update to the latest rtems-tools Close #4195. Wed, 02 Dec 2020 09:05:36 GMT Sebastian Huber [675e73f] * bare/config/devel/sis-2-1.cfg (modified) devel/sis: Update to 2.25 Update #4195. Mon, 16 Nov 2020 19:00:00 GMT Sebastian Huber [c576ec2] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Close #4193. Mon, 16 Nov 2020 04:57:30 GMT Chris Johns [31dd1ab] * bare/config/devel/qemu-5.2.0-1.cfg (modified) devel/qemu: Add the hash for the QEMU 5.2.0-rc1 Thu, 12 Nov 2020 22:24:06 GMT Chris Johns [0726183] * bare/config/devel/qemu-5.2.0-1.cfg (moved) * bare/config/devel/qemu.bset (modified) * bare/config/devel/qemu4.bset (deleted) * source-builder/config/qemu-5-1.cfg (added) * source-builder/config/qemu-common-2.cfg (added) devel/qemu: Update QEMU to 5.2.0-rc1 - This version of qemu uses ... Mon, 02 Nov 2020 06:11:59 GMT Sebastian Huber [3d88829] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 28 Oct 2020 15:03:16 GMT Sebastian Huber [4c5af1f] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 26 Oct 2020 13:34:19 GMT Sebastian Huber [5f4fd63] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 12 Oct 2020 05:41:43 GMT Sebastian Huber [5237fdab] * rtems/config/6/rtems-i386.bset (modified) * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 23 Sep 2020 21:00:55 GMT Stephen Clark [ed5030b] * source-builder/sb/pkgconfig.py (modified) pkgconfig.py: Removed use of "unicode" keyword for python3 ... Sat, 19 Sep 2020 14:49:25 GMT Michael Davidsaver [1ea1c9c] * rtems/config/6/rtems-i386.bset (modified) patch gcc i386 multiarch Add patch to change from mtune to ... Fri, 18 Sep 2020 18:54:26 GMT Sebastian Huber [7595c3a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Fri, 18 Sep 2020 18:39:24 GMT Sebastian Huber [9e9334a] * rtems/config/tools/rtems-tools-6.cfg (modified) 6: Update to the latest rtems-tools Thu, 10 Sep 2020 06:56:32 GMT Jiri Gaisler [a81a237] * rtems/config/6/rtems-riscv.bset (modified) Add sis to RISC-V build Thu, 10 Sep 2020 02:05:12 GMT Chris Johns [b9d5f95] * bare/config/devel/sis-2-1.cfg (modified) devel/sis: Update to 2.22 Wed, 09 Sep 2020 08:49:52 GMT Hesham Almatary [a9ea531] * README (modified) rsb: Fix the documentation URL Mon, 07 Sep 2020 00:32:59 GMT Chris Johns [31f936a] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems: Update to the latest rtems-tools Fri, 04 Sep 2020 18:01:07 GMT Sebastian Huber [47f32b8] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Mon, 31 Aug 2020 10:11:55 GMT Sebastian Huber [2674290] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Thu, 27 Aug 2020 05:37:02 GMT Chris Johns [c51f634] * source-builder/sb-check (modified) * source-builder/sb/__init__.py (added) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/getsources.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/shell.py (modified) * source-builder/sb/simhost.py (modified) * source-builder/sb/track.py (modified) sb: Fix the imports on Python2 Updates #4037 Tue, 25 Aug 2020 11:21:50 GMT Chris Johns [650c6f9] * source-builder/pkg-config (modified) * source-builder/sb-check (modified) * source-builder/sb-defaults (modified) * source-builder/sb-get-sources (modified) * source-builder/sb-reports (modified) * source-builder/sb-rtems-config (modified) * source-builder/sb-set-builder (modified) * source-builder/sb-track (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/cmd-check.py (deleted) * source-builder/sb/cmd-defaults.py (deleted) * source-builder/sb/cmd-get-sources.py (deleted) * source-builder/sb/cmd-pkg-config.py (deleted) * source-builder/sb/cmd-reports.py (deleted) * source-builder/sb/cmd-rtems-config.py (deleted) * source-builder/sb/cmd-set-builder.py (deleted) * source-builder/sb/cmd-track.py (deleted) * source-builder/sb/config.py (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/ereport.py (modified) * source-builder/sb/execute.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/getsources.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/mailer.py (modified) * source-builder/sb/netbsd.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/path.py (modified) * source-builder/sb/pkgconfig.py (modified) * source-builder/sb/python-wrapper.sh (deleted) * source-builder/sb/reports.py (modified) * source-builder/sb/rtemsconfig.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/shell.py (modified) * source-builder/sb/simhost.py (modified) * source-builder/sb/solaris.py (modified) * source-builder/sb/sources.py (modified) * source-builder/sb/track.py (modified) * source-builder/sb/version.py (modified) * source-builder/sb/windows.py (modified) sb: Use shebang env python Closes #4037 Thu, 13 Aug 2020 01:44:23 GMT Chris Johns [40af487d] * rtems/config/5/bsps/atsamv.bset (deleted) * rtems/config/5/bsps/imx7.bset (deleted) * rtems/config/5/bsps/qoriq_e500.bset (deleted) * rtems/config/5/bsps/qoriq_e6500_32.bset (deleted) * rtems/config/5/bsps/qoriq_e6500_64.bset (deleted) * rtems/config/5/rtems-aarch64.bset (deleted) * rtems/config/5/rtems-all.bset (deleted) * rtems/config/5/rtems-arm.bset (deleted) * rtems/config/5/rtems-autotools-base.bset (deleted) * rtems/config/5/rtems-autotools-internal.bset (deleted) * rtems/config/5/rtems-autotools.bset (deleted) * rtems/config/5/rtems-bfin.bset (deleted) * rtems/config/5/rtems-default.bset (deleted) * rtems/config/5/rtems-epiphany.bset (deleted) * rtems/config/5/rtems-i386.bset (deleted) * rtems/config/5/rtems-lm32.bset (deleted) * rtems/config/5/rtems-m68k.bset (deleted) * rtems/config/5/rtems-microblaze.bset (deleted) * rtems/config/5/rtems-mips.bset (deleted) * rtems/config/5/rtems-moxie.bset (deleted) * rtems/config/5/rtems-nios2.bset (deleted) * rtems/config/5/rtems-or1k.bset (deleted) * rtems/config/5/rtems-powerpc.bset (deleted) * rtems/config/5/rtems-riscv.bset (deleted) * rtems/config/5/rtems-sh.bset (deleted) * rtems/config/5/rtems-sparc.bset (deleted) * rtems/config/5/rtems-sparc64.bset (deleted) * rtems/config/5/rtems-tier-1.bset (deleted) * rtems/config/5/rtems-tier-2.bset (deleted) * rtems/config/5/rtems-tier-3.bset (deleted) * rtems/config/5/rtems-tier-4.bset (deleted) * rtems/config/5/rtems-v850.bset (deleted) * rtems/config/5/rtems-x86_64.bset (deleted) * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-kernel.bset (moved) * rtems/config/6/rtems-libbsd.bset (moved) * rtems/config/6/rtems-llvm.bset (moved) * rtems/config/6/rtems-packages.bset (moved) * rtems/config/6/rtems-tools.bset (moved) * rtems/config/bsps/atsamv.bset (added) * rtems/config/bsps/beagleboneblack.bset (moved) * rtems/config/bsps/erc32.bset (moved) * rtems/config/bsps/gr712rc.bset (moved) * rtems/config/bsps/gr740.bset (moved) * rtems/config/bsps/imx7.bset (added) * rtems/config/bsps/pc.bset (moved) * rtems/config/bsps/qoriq_e500.bset (added) * rtems/config/bsps/qoriq_e6500_32.bset (added) * rtems/config/bsps/qoriq_e6500_64.bset (added) * rtems/config/bsps/raspberrypi2.bset (moved) * rtems/config/bsps/xilinx_zynq_zc702.bset (moved) * rtems/config/bsps/xilinx_zynq_zc706.bset (moved) * rtems/config/bsps/xilinx_zynq_zedboard.bset (moved) * rtems/config/ftp/curl.bset (modified) * rtems/config/net-mgmt/net-snmp.bset (modified) * rtems/config/tools/rtems-kernel-5.cfg (deleted) * rtems/config/tools/rtems-kernel-6.cfg (added) * rtems/config/tools/rtems-kernel-common.cfg (modified) * rtems/config/tools/rtems-libbsd-6.cfg (moved) Move 5 build sets to 6 - Move 5/bsps/* to bsps/* - Update package ... Wed, 12 Aug 2020 03:17:48 GMT Chris Johns [dc98903] * source-builder/sb/track.py (modified) sb/track: Only output unreferenced configs with the option Mon, 10 Aug 2020 06:52:27 GMT Chris Johns [a863b15] * source-builder/sb-bootstrap (deleted) * source-builder/sb/bootstrap.py (deleted) * source-builder/sb/cmd-bootstrap.py (deleted) sb/bootstrap: Remove the sb-bootstrap command Closes #4046 Mon, 10 Aug 2020 06:21:35 GMT Chris Johns [481bbd1] * source-builder/sb-builder (deleted) * source-builder/sb/cmd-builder.py (deleted) sb/builder: Remove sb-builder command Closes #4045 Mon, 10 Aug 2020 04:49:49 GMT Chris Johns [1241819] * bare/config/devel/libusb-1.0.18-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/sb-track (added) * source-builder/sb/build.py (modified) * source-builder/sb/cmd-track.py (added) * source-builder/sb/config.py (modified) * source-builder/sb/getsources.py (modified) * source-builder/sb/simhost.py (added) * source-builder/sb/track.py (added) sb/track: Add a command to track build sets. - Process a build set ... Wed, 29 Jul 2020 15:13:14 GMT Sebastian Huber [cc107b5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 29 Jul 2020 05:11:50 GMT Sebastian Huber [658af8f] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain
