# # ChangeLog for / in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/30/24 15:25:04 Mon, 10 Aug 2020 06:21:35 GMT Chris Johns [481bbd1] * source-builder/sb-builder (deleted) * source-builder/sb/cmd-builder.py (deleted) sb/builder: Remove sb-builder command Closes #4045 Mon, 10 Aug 2020 04:49:49 GMT Chris Johns [1241819] * bare/config/devel/libusb-1.0.18-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/sb-track (added) * source-builder/sb/build.py (modified) * source-builder/sb/cmd-track.py (added) * source-builder/sb/config.py (modified) * source-builder/sb/getsources.py (modified) * source-builder/sb/simhost.py (added) * source-builder/sb/track.py (added) sb/track: Add a command to track build sets. - Process a build set ... Wed, 29 Jul 2020 15:13:14 GMT Sebastian Huber [cc107b5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 29 Jul 2020 05:11:50 GMT Sebastian Huber [658af8f] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Thu, 23 Jul 2020 16:42:18 GMT Christian Mauderer [91932d0] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools: Pick up fix for modern llvm. Fri, 03 Jul 2020 05:39:26 GMT Sebastian Huber [7f79fe9] * rtems/config/6/rtems-all.bset (modified) * rtems/config/6/rtems-epiphany.bset (deleted) * rtems/config/7/rtems-all.bset (modified) 6/7: Remove support for epiphany target Update #3941. Fri, 03 Jul 2020 19:12:33 GMT Sebastian Huber [5ab61d2] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6/7: Update unstable RTEMS 6/7 tool chain Wed, 01 Jul 2020 18:13:47 GMT Sebastian Huber [abe5d1b] * rtems/config/5/rtems-moxie.bset (modified) * rtems/config/6/rtems-moxie.bset (modified) * rtems/config/7/rtems-moxie.bset (modified) moxie: Update to dtc 1.6.0 This fixes the build with a GCC 10 host ... Tue, 30 Jun 2020 07:55:53 GMT Chris Johns [8effa3e] * source-builder/sb/options.py (modified) sb/options: A Canadian Cross is a different host, build and target ... Tue, 30 Jun 2020 07:38:40 GMT Sebastian Huber [c751652] * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-epiphany.bset (modified) * rtems/config/7/rtems-default.bset (modified) * rtems/config/tools/rtems-tools-6.cfg (added) 6/7: Use RTEMS 6 tools Tue, 30 Jun 2020 07:12:39 GMT Sebastian Huber [9a7082c] * rtems/config/rtems-version.bset (modified) Make comment version independent Tue, 30 Jun 2020 07:13:42 GMT Sebastian Huber [b89e62f] * source-builder/sb/version.py (modified) Change version to RTEMS 6 Update #4020. Thu, 18 Jun 2020 05:40:54 GMT Sebastian Huber [987da96] * rtems/config/7/rtems-aarch64.bset (added) * rtems/config/7/rtems-all.bset (added) * rtems/config/7/rtems-arm.bset (added) * rtems/config/7/rtems-base.bset (added) * rtems/config/7/rtems-bfin.bset (added) * rtems/config/7/rtems-default.bset (added) * rtems/config/7/rtems-i386.bset (added) * rtems/config/7/rtems-lm32.bset (added) * rtems/config/7/rtems-m68k.bset (added) * rtems/config/7/rtems-microblaze.bset (added) * rtems/config/7/rtems-mips.bset (added) * rtems/config/7/rtems-moxie.bset (added) * rtems/config/7/rtems-nios2.bset (added) * rtems/config/7/rtems-or1k.bset (added) * rtems/config/7/rtems-powerpc.bset (added) * rtems/config/7/rtems-riscv.bset (added) * rtems/config/7/rtems-sh.bset (added) * rtems/config/7/rtems-sparc.bset (added) * rtems/config/7/rtems-sparc64.bset (added) * rtems/config/7/rtems-v850.bset (added) * rtems/config/7/rtems-x86_64.bset (added) 7: Add unstable RTEMS 7 tool chain Mon, 29 Jun 2020 07:10:46 GMT Sebastian Huber [2990781] * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-epiphany.bset (modified) * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (added) 6: Use GCC 10 branch for RTEMS 6 tool chain Mon, 29 Jun 2020 07:22:09 GMT Sebastian Huber [eb9c232] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 26 Jun 2020 01:53:57 GMT Chris Johns [907eabf] * source-builder/config/sqlite-3-1.cfg (modified) sqlite: Change to https for downloading the source package. Wed, 24 Jun 2020 23:50:16 GMT Chris Johns [9293dfd] * bare/config/devel/glib-2.48.2-1.cfg (modified) glib: Gnome has change the git version to gitlab in requested patches. Tue, 23 Jun 2020 07:32:09 GMT Chris Johns [e455fef] * rtems/config/tools/rtems-kernel-5.cfg (modified) * rtems/config/tools/rtems-libbsd-5.cfg (modified) * rtems/config/tools/rtems-tools-5-1.cfg (modified) rtems: Update kernel, libbsd and tool the master. This aligns them ... Wed, 10 Jun 2020 06:45:47 GMT Sebastian Huber [cbae90a] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Wed, 10 Jun 2020 04:57:58 GMT Chris Johns [42b7e8a] * bare/config/devel/qemu4-git-1.cfg (modified) devel/qemu4: Use release source tarball Git cannot be used for a ... Fri, 05 Jun 2020 08:00:27 GMT Sebastian Huber [fc3a57c] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 02 Jun 2020 11:01:13 GMT Sebastian Huber [0e5ef63] * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 02 Jun 2020 08:41:55 GMT Sebastian Huber [850d9b5] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 07 May 2020 05:12:45 GMT Sebastian Huber [3bd11fd] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Fri, 08 May 2020 06:05:07 GMT Chris Johns [f0abfa8] * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/qemu.bset (modified) re/pixman: Revert the accidental commit. - Move qemu to 0.40.0 so ... Fri, 08 May 2020 04:40:19 GMT Chris Johns [da3505b] * rtems/config/tools/rtems-kernel-5.cfg (modified) rtems: Update the kernel Fri, 08 May 2020 04:28:45 GMT Chris Johns [955c1c1] * bare/config/bare-config.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/config/qemu-4-1.cfg (modified) * source-builder/config/qemu-common-1.cfg (added) bare/qemu: Fixes building on FreeBSD - Move the qemu config to a ... Fri, 08 May 2020 04:28:09 GMT Chris Johns [0fd197f] * source-builder/sb/cmd-pkg-config.py (modified) sb: Disable any trace data Fri, 08 May 2020 04:28:04 GMT Chris Johns [1f972c2] * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) sb: Add git clean to the supported git commands. Thu, 07 May 2020 22:19:09 GMT Joel Sherrill [da17bda] * bare/config/devel/pixman-0.40.0-1.cfg (added) * bare/config/devel/qemu4.bset (modified) qemu4.bset: Update to pixman 0.40.0. Wed, 06 May 2020 21:05:55 GMT Chris Johns [0affb66] * rtems/config/tools/rtems-kernel-5.cfg (modified) * rtems/config/tools/rtems-tools-5-1.cfg (modified) rtems: Update the kernel and tools packages to the latest RTEMS 5 Tue, 28 Apr 2020 08:41:18 GMT Chris Johns [1011d5f] * rtems/config/tools/rtems-kernel-5.cfg (modified) rtems-kernel: Update to the latest Tue, 28 Apr 2020 08:36:41 GMT Chris Johns [846c979] * source-builder/config/dtc-1-1.cfg (modified) devel/dtc: Change the home page to www.devicetree.org Tue, 28 Apr 2020 08:34:08 GMT Chris Johns [13e4dfd] * rtems/config/rtems-bsp.cfg (modified) rtems-bsb: Use linker garbage collection for BSP based builds Close ... Tue, 28 Apr 2020 08:33:41 GMT Chris Johns [f1a3c8c] * rtems/config/tools/rtems-libbsd-common.cfg (modified) rtems-libbsd: Remove the v from the package name verision Tue, 28 Apr 2020 07:14:36 GMT Sebastian Huber [2f8bd58] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 28 Apr 2020 05:21:07 GMT Chris Johns [47880bb] * rtems/config/tools/rtems-kernel-common.cfg (modified) rtems-kernel: Fix building without the rtems test option. Updates #3956 Tue, 28 Apr 2020 01:05:20 GMT Chris Johns [d14da0a] * rtems/config/tools/rtems-kernel-common.cfg (modified) rtems-kernel: Install tests when tests are built The tests in RTEMS ... Mon, 27 Apr 2020 19:15:28 GMT Anders Montonen [d5ad667] * source-builder/config/gdb-common-1.cfg (modified) source-builder/config/gdb-common-1.cfg: Fix building with Python 3.8 ... Mon, 27 Apr 2020 19:15:27 GMT Anders Montonen [ae9faa2] * source-builder/sb/linux.py (modified) sb/linux.py: Workaround for Python >= 3.8 The platform.dist() ... Mon, 27 Apr 2020 19:15:26 GMT Anders Montonen [0c7965c] * source-builder/sb/config.py (modified) * source-builder/sb/macros.py (modified) sb: Fix Python literal comparison warnings Fixes: SyntaxWarning: ... Mon, 27 Apr 2020 04:40:00 GMT Chris Johns [a137ab8] * bare/config/devel/glib-2.48.2-1.cfg (modified) devel/glib: Fix the checksum for the patch Mon, 20 Apr 2020 07:24:55 GMT Christian Mauderer [78c6e15] * rtems/config/tools/rtems-libbsd-5.cfg (modified) 5/rtems-libbsd: Update 5-freebsd-12 Fri, 17 Apr 2020 12:47:28 GMT Christian Mauderer [6d194ca] * rtems/config/tools/rtems-libbsd-5.cfg (modified) 5/rtems-libbsd: Update 5-freebsd-12 Fri, 17 Apr 2020 11:10:36 GMT Sebastian Huber [485eec6] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 16 Apr 2020 09:08:42 GMT Christian Mauderer [9482a1b] * rtems/config/tools/rtems-libbsd-5.cfg (modified) 5/rtems-libbsd: Update 5-freebsd-12 Wed, 15 Apr 2020 16:40:31 GMT Christian Mauderer [f2f0fdf] * rtems/config/tools/rtems-kernel-5.cfg (modified) * rtems/config/tools/rtems-libbsd-5.cfg (modified) 5/rtems: Update kernel and libbsd. Thu, 09 Apr 2020 20:21:54 GMT Vijay Kumar Banerjee [190b39e] * bare/config/devel/capstone-4.0.1-1.cfg (added) * bare/config/devel/capstone.bset (added) * source-builder/config/capstone-1-1.cfg (added) source-builder: Add capstone Thu, 09 Apr 2020 20:21:53 GMT Vijay Kumar Banerjee [50916e8] * bare/config/devel/dtc-1.6.0-1.cfg (added) bare/config: Add devel/dtc-1.6.0 Thu, 09 Apr 2020 20:21:52 GMT Vijay Kumar Banerjee [bdffe46] * bare/config/devel/glib-2.48.2-1.cfg (modified) bare/glib-2.48.2: Add patches to suppress null string warning Thu, 09 Apr 2020 20:21:55 GMT Vijay Kumar Banerjee [c41e0c3] * bare/config/devel/qemu-couverture-git-1.cfg (modified) * bare/config/devel/qemu-couverture.bset (modified) qemu-couverture: update to qemu-stable-4.0.0 Thu, 09 Apr 2020 11:36:22 GMT Hesham Almatary [f3afcb5] * bare/config/devel/spike.bset (modified) rsb: Use dtc.bset for Spike Wed, 08 Apr 2020 09:58:58 GMT Hesham Almatary [9f18471] * bare/config/devel/dtc.bset (modified) rsb: Bump DTC to 1.4 version Tue, 07 Apr 2020 08:54:41 GMT Hesham Almatary [70775f9] * source-builder/config/spike-1-1.cfg (modified) rsb: Fix Spike build * There is no all$ target in Spike * There is ... Wed, 08 Apr 2020 11:34:01 GMT Sebastian Huber [f6286ff] * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Update #3937. Tue, 07 Apr 2020 07:38:33 GMT Sebastian Huber [b69f54d] * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Update #3937. Tue, 07 Apr 2020 02:08:15 GMT Gedare Bloom [e307213] * rtems/config/tools/rtems-kernel-5.cfg (modified) rtems: bump rtems-5-kernel Mon, 06 Apr 2020 07:05:37 GMT Chris Johns [8223d3b] * rtems/config/tools/rtems-libbsd-5.cfg (modified) rtems/libbsd: Update to origin/5-freebsd12 HEAD. Mon, 06 Apr 2020 07:04:13 GMT Chris Johns [b2086bd] * rtems/config/tools/rtems-kernel-5.cfg (modified) rtems/kernel: Update to origin/master HEAD. Mon, 06 Apr 2020 05:31:04 GMT Sebastian Huber [ad90540] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Thu, 02 Apr 2020 04:29:31 GMT Gedare Bloom [4727c3e] * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) sb/reports: add sanitize parameter enabled for --mail Adds a ... Thu, 02 Apr 2020 22:35:15 GMT Jonathan Brandmeyer [113c65c] * rtems/config/databases/sqlite-3.31.1-1.cfg (added) * rtems/config/databases/sqlite-3.8.8.1-1.cfg (deleted) * rtems/config/databases/sqlite.bset (modified) * source-builder/config/sqlite-3-1.cfg (modified) databases/sqlite: Update to 3.31.1 closes #3927. Thu, 02 Apr 2020 03:55:39 GMT Gedare Bloom [54e08b8] * source-builder/sb/reports.py (modified) sb/reports.py: Remove spurious error check The error path is taken ... Mon, 30 Mar 2020 00:40:36 GMT Chris Johns [26a0568] * rtems/config/tools/rtems-libbsd-5.cfg (modified) rtems/libbsd: Update to the latest 5-freebsd12 branch head. Mon, 30 Mar 2020 00:40:05 GMT Chris Johns [9fbe810] * rtems/config/tools/rtems-kernel-5.cfg (modified) rtems/kernel: Update to the latest master. Sun, 29 Mar 2020 23:47:18 GMT Chris Johns [92d8e7f] * source-builder/sha512-base64 (added) sb/sha512-base64: Add script to generate a base64 checksum. - Use ... Sun, 29 Mar 2020 23:46:38 GMT Chris Johns [fe63ad8] * source-builder/sb/execute.py (modified) sb/execute: Port fixes from rtems-tools Sun, 29 Mar 2020 23:40:40 GMT Chris Johns [097018a] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5/rtems-tools: Update to pick up rtems-test fixes for GDB Fri, 27 Mar 2020 03:39:33 GMT Chris Johns [9b7cdb7] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/glib-2.46.2-1.cfg (modified) * bare/config/devel/glib-2.48.2-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/libiconv-1.14-1.cfg (modified) * bare/config/devel/pcre-8.40-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) bare: Fix pkgconfig checks and getting source. - If the package was ... Fri, 27 Mar 2020 03:38:19 GMT Chris Johns [25386b1] * bare/config/devel/glib-2.39.3-1.cfg (added) bare/glib: Add back glib-2.39.3-1 - It was removed in ... ... Wed, 25 Mar 2020 15:21:28 GMT Joel Sherrill [71af2d9] * bare/config/devel/spike-1.1.0.cfg (modified) spike: Update to use exec that searches along PATH. Updates #3914. Mon, 23 Mar 2020 20:02:08 GMT Joel Sherrill [12e02ad] * bare/config/devel/spike-1.1.0.cfg (modified) Spike: Update to include fix for hard-coded path to dtc Closes #3914. Mon, 23 Mar 2020 05:51:47 GMT Sebastian Huber [68f90be] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5: Update rtems-tools Pick up new features for rtems-record-lttng. ... Mon, 23 Mar 2020 05:50:41 GMT Sebastian Huber [cc29f67] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Sat, 17 Nov 2018 15:22:49 GMT Martin Erik Werner [f93fcef] * bare/config/devel/glib-2.48.2-1.cfg (moved) * bare/config/devel/qemu.bset (modified) * source-builder/config/glib-2-1.cfg (modified) qemu: Update glib to build on newer gcc Update the glib version to ... Tue, 17 Mar 2020 06:50:32 GMT Sebastian Huber [96cdedc] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 6: Update unstable RTEMS 6 tool chain Tue, 17 Mar 2020 06:30:55 GMT Sebastian Huber [30725b6] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-7.5.0-newlib-7947581.cfg (added) * rtems/config/tools/rtems-gcc-9.3.0-newlib-7947581.cfg (added) 5: Update Newlib Pick up fix for crt0.c. Thu, 12 Mar 2020 20:21:14 GMT Joel Sherrill [af7f198] * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-9.3.0-newlib-c56f53a.cfg (added) Update gcc to 9.3.0 for targets using 9.2.0 Thu, 12 Mar 2020 18:46:48 GMT Joel Sherrill [d49a52e] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-7.5.0-newlib-c56f53a.cfg (added) * rtems/config/tools/rtems-gcc-9.2.0-newlib-c56f53a.cfg (added) Update newlib to c56f53a This is primarily to pick up the bug fix ... Sun, 08 Mar 2020 21:46:08 GMT Amar Takhar [0b7e871] * rtems/config/tools/rtems-tools-5-1.cfg (modified) Bump rtems-tools to get mkimage.py into the bin/ directory. Sat, 29 Feb 2020 14:01:13 GMT Jiri Gaisler [bdc674e] * bare/config/devel/sis-2-1.cfg (modified) sis simulator: update to version 2.21 * Fix incorrect ... Thu, 05 Mar 2020 11:29:49 GMT Chris Johns [bffdd1e] * rtems/config/tools/rtems-libbsd-5.cfg (modified) rtems/libbsd: Bump libbsd to pick up the libdebugger library check Wed, 04 Mar 2020 09:44:57 GMT Chris Johns [ce6b7a5] * rtems/config/5/bsps/erc32.bset (added) * rtems/config/5/bsps/pc.bset (added) rtems/bsps: Add the sparc/erc32 and i386/pc BSP build sets Thu, 05 Mar 2020 10:24:00 GMT Sebastian Huber [a89a9c0] * rtems/config/5/bsps/atsamv.bset (added) * rtems/config/5/bsps/gr712rc.bset (added) * rtems/config/5/bsps/gr740.bset (added) * rtems/config/5/bsps/imx7.bset (added) * rtems/config/5/bsps/qoriq_e500.bset (added) * rtems/config/5/bsps/qoriq_e6500_32.bset (added) * rtems/config/5/bsps/qoriq_e6500_64.bset (added) 5/bsps: Add some BSPs Thu, 05 Mar 2020 10:02:02 GMT Sebastian Huber [f55459e] * rtems/config/tools/rtems-tools-5-1.cfg (modified) 5: Update rtems-tools Pick up fixes for Debian on sparc64. Thu, 05 Mar 2020 09:36:08 GMT Sebastian Huber [e0394a5] * source-builder/sb/linux.py (modified) sb: Use multiprocessing.cpu_count() The previous implementation ... Wed, 04 Mar 2020 23:59:30 GMT Amar Takhar [08da449] * rtems/config/tools/rtems-tools-5-1.cfg (modified) Bump RSB to the latest rtems-tools to get mkimage.py Wed, 04 Mar 2020 09:32:12 GMT Chris Johns [3b0032d] * source-builder/sb/log.py (modified) * source-builder/sb/options.py (modified) sb/options: Let --source-only-download download releases - The ... Tue, 03 Mar 2020 22:56:01 GMT Chris Johns [9e49d20] * source-builder/sb/pkgconfig.py (modified) sb/pkgconfig: Fix python2 issue with caching changes Closes #3893 Tue, 03 Mar 2020 22:20:19 GMT Chris Johns [ba97e7c] * source-builder/sb/python-wrapper.sh (modified) sb/python-wrapper: Add python2.7 to aid testing Tue, 03 Mar 2020 04:38:47 GMT Chris Johns [834a0ea] * source-builder/config/protobuf-2-1.cfg (modified) protobufs: Fix the incorrectly update top level URL for the project. ... Tue, 03 Mar 2020 03:52:17 GMT Chris Johns [b9a2f8b] * rtems/config/tools/rtems-kernel-5.cfg (modified) 5/rtems-kernel: Update to the head of master to sync with libbsd Tue, 03 Mar 2020 00:11:17 GMT Chris Johns [abd98a2] * rtems/config/rtems-bsp.cfg (modified) rtems/bsps: Fix building 3rd party packages with various options - ... Tue, 03 Mar 2020 00:02:58 GMT Chris Johns [96d55ab] * source-builder/sb/pkgconfig.py (modified) sb/pkgconfig: Cache pkgconfig based on a file name not name - ... Mon, 02 Mar 2020 03:49:28 GMT Chris Johns [4295d3d] * source-builder/sb/config.py (modified) sb/config: Add paths checks to %{path ...} Updates #3893 Mon, 02 Mar 2020 03:45:29 GMT Chris Johns [175ce0b] * source-builder/sb/config.py (modified) sb/config: Expanded nested shell commands Updates #3893 Mon, 02 Mar 2020 03:40:52 GMT Chris Johns [5ec0913] * source-builder/config/protobuf-2-1.cfg (modified) protobufs: Top level project rename. Fix URL path on github. Mon, 02 Mar 2020 02:43:21 GMT Chris Johns [404d1a9] * rtems/config/tools/rtems-kernel-5.cfg (modified) 5/rtems-kernel: Update to the head of master to sync with libbsd Thu, 27 Feb 2020 18:04:30 GMT Joel Sherrill [7d56629] * rtems/config/5/rtems-default.bset (modified) * rtems/config/5/rtems-epiphany.bset (modified) * rtems/config/5/rtems-or1k.bset (modified) * rtems/config/5/rtems-riscv.bset (modified) * rtems/config/5/rtems-x86_64.bset (modified) * rtems/config/tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg (added) * rtems/config/tools/rtems-gcc-9.2.0-newlib-fbaa096.cfg (added) rtems/5 bsets: Update to newlib fbaa096 This picks up fixes for at ... Sat, 29 Feb 2020 00:07:11 GMT Chris Johns [c4abcf4] * rtems/config/tools/rtems-libbsd-5.cfg (modified) 5/rtems-libbsd: Update 5-freebsd-12
