# # ChangeLog for / in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 05/21/24 16:39:15 Fri, 25 Jul 2014 11:46:34 GMT Chris Johns [2eb764e] * bare/config/devel/binutils-2.24-1.cfg (added) * bare/config/devel/gcc-4.9-newlib-cvs-1.cfg (added) * bare/config/devel/gcc-4.9.1-newlib-2.1.0-1.cfg (added) * bare/config/lang/gcc491.bset (added) bare: Add support for building gcc-4.9.1 and newlib-2.1.0. Fri, 25 Jul 2014 11:45:01 GMT Chris Johns [712ef18] * source-builder/defaults.mc (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) sb: Add CXX flags support rather than use CFLAGS. Fri, 25 Jul 2014 11:43:50 GMT Chris Johns [fa87409] * source-builder/sb/download.py (modified) sb: Fix error handling. Fri, 25 Jul 2014 04:55:14 GMT Chris Johns [114ef08] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-or1k.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gdb-7.7.1-1.cfg (added) RTEMS 4.11 Update to gcc-4.8.3 with Newlib CVS 26-Jul-2014. ... Mon, 23 Jun 2014 09:15:51 GMT Chris Johns [cbc5332] * bare/config/devel/libusb-1.0.18-1.cfg (added) * bare/config/devel/libusb.bset (added) bare: Update libusb to 1.0.18. Add a build set file for libusb. Mon, 23 Jun 2014 00:58:56 GMT Chris Johns [df65d66] * rtems/config/4.11/net-mgmt/net-snmp.bset (added) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (added) * source-builder/config/net-snmp-5-1.cfg (added) config: Add net-snmp package for RTEMS. Mon, 16 Jun 2014 22:58:30 GMT Chris Johns [62cb647] * source-builder/sb/config.py (modified) sb: Trace relative paths for nesting configs. Mon, 16 Jun 2014 22:57:44 GMT Chris Johns [6c4aeae] * source-builder/pkg-config (modified) sb: Fix pkg-config bug with src tracking. Sun, 15 Jun 2014 09:57:11 GMT Chris Johns [a5e37e6] * rtems/config/rtems-bsp.cfg (modified) config: Fix the broken rtems-bsp.cfg. Sun, 15 Jun 2014 09:36:15 GMT Chris Johns [72aab85] * source-builder/config/ntp-4-1.cfg (modified) config: NTP build fails with too many jobs. Do not use any jobs to ... Sun, 15 Jun 2014 09:34:38 GMT Chris Johns [912596d] * rtems/config/rtems-bsp.cfg (modified) config: Use the prefix as the tools path if no --with-tools. To use ... Sun, 15 Jun 2014 05:40:34 GMT Chris Johns [0ffee19] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/libiconv-1.14-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/texane-stlink-1.cfg (modified) * rtems/config/4.11/net/ntp.bset (added) * rtems/config/net/ntp-4.2.6p5-1.cfg (added) * rtems/config/rtems-base.bset (modified) * rtems/config/rtems-bsp.cfg (added) * rtems/config/rtems-urls.bset (added) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/ntp-4-1.cfg (added) * source-builder/defaults.mc (modified) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) sb: Add support for building RTEMS 3rd party packages. Remove the ... Sun, 15 Jun 2014 05:14:16 GMT Chris Johns [339f92f] * source-builder/sb/build.py (modified) sb: Tighten the canadian cross compile detection. A canadian cross ... Sun, 15 Jun 2014 05:12:10 GMT Chris Johns [120e101] * source-builder/sb/setbuilder.py (modified) sb: Improve the error handling for setbuilder errors. If an error ... Wed, 11 Jun 2014 06:03:56 GMT Chris Johns [cbf576e] * bare/config/devel/qemu-git-1.cfg (modified) bare: Add GSoC QEMU patches for CAN bus support. Wed, 11 Jun 2014 06:02:56 GMT Chris Johns [578405e] * bare/config/devel/libtool.bset (added) bare: Add a build set for building libtool. Wed, 04 Jun 2014 09:37:18 GMT Chris Johns [c6cc169] * source-builder/sb/linux.py (modified) sb: Support Linux Mint. This support is provided by m86k-user ... Wed, 04 Jun 2014 09:17:23 GMT Chris Johns [11e7146] * source-builder/sb/freebsd.py (modified) sb: Fix FreeBSD compiler support. Only add the bracket flag if ... Mon, 02 Jun 2014 06:01:39 GMT Chris Johns [46506f1] * source-builder/config/gdb-7-1.cfg (modified) config: Fix the check to disable the gdb simulator. Check to see if ... Mon, 26 May 2014 01:40:22 GMT Hesham ALMatary [3a0e561] * rtems/config/4.11/rtems-or1k.bset (added) * source-builder/config/gdb-7-1.cfg (modified) Add support for building rtems-or1k tool-chain - fixed ... Sun, 01 Jun 2014 07:58:55 GMT Chris Johns [396db46] * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) config: Update the NIOS2 configuration for the new %source command. Sun, 01 Jun 2014 07:57:35 GMT Chris Johns [4a315d3] * source-builder/sb/build.py (modified) sb: Fix the source option string for getopts. Tue, 20 May 2014 11:55:51 GMT Chris Johns [467cace] * source-builder/sb/bootstrap.py (modified) sb: Clean up the bootstrap error handling. Mon, 19 May 2014 02:50:54 GMT Chris Johns [b09fde0] * rtems/config/4.11/rtems-sparc.bset (modified) 4.11/sparc: Update the gdb-7.7 SIS output patch. Wed, 14 May 2014 22:49:34 GMT Chris Johns [65d9457] * source-builder/sb/build.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Move error report generation to the build phase. Generate a ... Wed, 14 May 2014 06:43:40 GMT Chris Johns [83586f7] * source-builder/sb/build.py (modified) sb: Fix the formatting string. Wed, 14 May 2014 06:38:50 GMT Chris Johns [e249bd1] * doc/wscript (modified) doc: Use the internal asciidoc tool. Wed, 14 May 2014 06:38:24 GMT Chris Johns [e119c6a] * doc/source-builder.txt (modified) doc: Update the documentation for the new source and patch. Wed, 14 May 2014 06:37:46 GMT Chris Johns [1b29191] * bare/config/bare-binutils-patches.cfg (deleted) * bare/config/bare-gcc-patches.cfg (deleted) * bare/config/bare-gdb-patches.cfg (deleted) * bare/config/devel/binutils-2.23.2-1.cfg (modified) * bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg (modified) * bare/config/devel/gdb-7.6.1-1.cfg (modified) * bare/config/devel/gdb-7.7-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) * bare/config/devel/texane-stlink-1.cfg (modified) * bare/config/dtc.bset (deleted) config: Mirgrate the remaining configs. Tue, 13 May 2014 13:26:09 GMT Chris Johns [9a15c40] * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/rtems-binutils-patches.cfg (deleted) * rtems/config/rtems-gcc-patches.cfg (deleted) * rtems/config/rtems-gdb-patches.cfg (deleted) * rtems/config/tools/rtems-binutils-2.20.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.22-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.1-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (modified) * rtems/config/tools/rtems-gdb-6.8-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.3.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.5.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg (modified) * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) * rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-4.3-1.cfg (modified) * source-builder/config/gcc-4.4-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.6-1.cfg (modified) * source-builder/config/gcc-4.7-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) * source-builder/config/gcc-4.9-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-6-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libffi-3-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (modified) * source-builder/config/libtool-2-1.cfg (modified) * source-builder/config/libusb-1-1.cfg (modified) * source-builder/config/m4-1-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/download.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/setbuilder.py (modified) * source-builder/sb/sources.py (added) * source-builder/sb/version.py (modified) sb: Implement %source and %patch to manage source and patches. ... Fri, 09 May 2014 01:20:38 GMT Chris Johns [e074e75] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg (added) 4.11/rtems-lm32: Use gcc-4.9.0 and fix gdb simulator build on ... Fri, 02 May 2014 23:56:28 GMT Chris Johns [24473fa] * source-builder/config/gcc-4.9-1.cfg (added) config: Add gcc-4.9.0 configuration support. Thu, 08 May 2014 03:24:00 GMT Chris Johns [5850ac9] * source-builder/sb/freebsd.py (modified) sb: Fix the testing commit for FreeBSD. Used this to test error ... Thu, 08 May 2014 02:58:14 GMT Chris Johns [74da24c] * source-builder/sb/build.py (modified) * source-builder/sb/ereport.py (added) * source-builder/sb/freebsd.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/log.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Generate an error report on an error. Generate an error report ... Sun, 04 May 2014 06:22:46 GMT Chris Johns [2a6acc7] * source-builder/defaults.mc (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/netbsd.py (modified) config: Fix the host and build options for Canadian cross builds. ... Fri, 02 May 2014 10:48:49 GMT Chris Johns [3adcfbf] * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) rtems/4.11: Fix _host_os for building on FreeBSD. It needs to be ... Thu, 01 May 2014 05:38:09 GMT Chris Johns [43252be] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) * rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg (added) config: Update to gdb-7.7 for a range of archs. Update lm32, m32c, ... Mon, 28 Apr 2014 08:51:59 GMT Chris Johns [527515c] * source-builder/sb/freebsd.py (modified) sb:Use cc and c++ on FreeBSD 10 and higher. Mon, 28 Apr 2014 06:53:33 GMT Chris Johns [491d6b9] * rtems/config/4.11/rtems-sparc.bset (modified) 4.11/rtems: Sparc port change to gdb-7.7. Mon, 28 Apr 2014 02:18:00 GMT Chris Johns [6fe63b3] * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (modified) config: Remove the POSIX thread model patch. Switch back the RTEMS ... Wed, 16 Apr 2014 18:05:09 GMT Joel Sherrill [d812ad5] * rtems/config/4.11/rtems-m32c.bset (modified) 4.11/rtems-m32c.bset: Enable building gcc again Wed, 16 Apr 2014 04:03:35 GMT Chris Johns [9d61bc9] * rtems/config/4.11/rtems-moxie.bset (modified) rtems/4.11: moxie switch to gdb-7.7. Remove the binutils patches as ... Wed, 16 Apr 2014 03:57:44 GMT Chris Johns [3c514b2] * rtems/config/4.11/rtems-i386.bset (modified) rtems/4.11: i386 switch to gdb-7.7. Thu, 10 Apr 2014 08:27:17 GMT Chris Johns [6b7b22a] * bare/config/devel/libiconv-1.14-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) config: Use _host_os for conditional checks. Thu, 10 Apr 2014 08:26:42 GMT Chris Johns [a14171f] * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/netbsd.py (modified) * source-builder/sb/windows.py (modified) sb: Add _host_os_version to all supported hosts. Thu, 10 Apr 2014 08:23:26 GMT Chris Johns [9ea19cf] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) config: Update to gdb-7.7. for arm, avr, bfin, h8300. Thu, 10 Apr 2014 08:22:23 GMT Chris Johns [7a6d42e] * rtems/config/tools/rtems-gdb-7.7-1.cfg (modified) config: Fix for sim common code on Mavrick. Wed, 09 Apr 2014 05:07:54 GMT Chris Johns [8ac8ebf] * bare/config/devel/gdb-7.7-1.cfg (added) * rtems/config/tools/rtems-gdb-7.7-1.cfg (added) config: Add gdb-7.7 support. Wed, 09 Apr 2014 05:07:29 GMT Chris Johns [a1bba9d] * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) config: Make FreeBSD 10 port patch specific to FreeBSD. Tue, 08 Apr 2014 06:16:50 GMT Chris Johns [ecda605] * source-builder/pkg-config (modified) * source-builder/sb/pkgconfig.py (modified) sb: Fix pkg-config to handle quoted libraries. Tue, 08 Apr 2014 06:16:13 GMT Chris Johns [6ab2f51] * bare/config/devel/qemu-git-1.cfg (modified) config: Remove the qemu test patch for MinGW. Tue, 08 Apr 2014 06:15:35 GMT Chris Johns [34cc5a9] * bare/config/devel/libffi-3.0.13-1.cfg (modified) config: Add the libffi version to check for. Tue, 08 Apr 2014 05:11:00 GMT Chris Johns [f3b5490] * bare/config/devel/libiconv-1.14-1.cfg (added) * bare/config/devel/qemu-git-1.cfg (modified) * bare/config/devel/qemu.bset (modified) * source-builder/config/gettext-0-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/libiconv-1-1.cfg (added) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) * source-builder/mingw32-pkg-config (added) * source-builder/pkg-config (modified) * source-builder/sb/config.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/pkgconfig.py (modified) config,sb: Qemu build updates for FreeBSD and the start of MinG32. ... Tue, 08 Apr 2014 03:18:56 GMT Chris Johns [374ba95] * doc/source-builder.txt (modified) doc: Updated after GSoC student feedback. Wed, 26 Mar 2014 06:13:25 GMT Chris Johns [8c19df2] * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/options.py (modified) sb: Fix git to clean before updating. Wed, 26 Mar 2014 06:12:43 GMT Chris Johns [b77019a] * source-builder/config/gdb-7-1.cfg (modified) config: Build without zlib due to errors in psim. Wed, 26 Mar 2014 06:12:05 GMT Chris Johns [ed8a66a] * rtems/config/snapshots/gcc-4.8-branch.mc (added) * source-builder/config/gcc-common-1.cfg (modified) config: Add support for gcc-4.8-branch testing. Thu, 20 Mar 2014 20:47:14 GMT Joel Sherrill [40d25dc] * rtems/config/4.11/rtems-v850.bset (modified) 4.11/rtems-v850.bset: Add gcc 4.8.2 patch Thu, 20 Mar 2014 19:19:24 GMT Joel Sherrill [dac3a03] * doc/source-builder.txt (modified) source-builder.txt: Correct spelling errors Thu, 20 Mar 2014 01:39:33 GMT Chris Johns [5111acf] * doc/source-builder.txt (modified) doc: New version and date. Thu, 20 Mar 2014 01:37:59 GMT Chris Johns [1180988] * doc/source-builder.txt (modified) doc: Add patch details. Thu, 20 Mar 2014 00:06:10 GMT Chris Johns [9b1ae21] * doc/source-builder.txt (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (modified) freebsd: Add support for FreeBSD 10.0. GDB did not build out of the ... Fri, 14 Feb 2014 02:27:36 GMT Chris Johns [0f064ba] * source-builder/config/qemu-1-1.cfg (modified) config: Do not build in trace support. Fri, 14 Feb 2014 02:26:11 GMT Chris Johns [9797bd1] * source-builder/pkg-config (modified) * source-builder/sb/imports/argparse.py (added) * source-builder/sb/pkgconfig.py (modified) sb: Clean up using argparse. It is not available on CentOS. Include ... Thu, 13 Feb 2014 05:01:03 GMT Chris Johns [d9e3dae] * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) config: Set the LD/DYLD temporary path for configure and make. Both ... Wed, 12 Feb 2014 04:27:05 GMT Chris Johns [70cc3b0] * bare/config/devel/qemu-git-1.cfg (modified) config: Use qemu's patchworks site for patches. Wed, 12 Feb 2014 04:26:07 GMT Chris Johns [587aa5f] * source-builder/sb/download.py (modified) sb: Add patchworks support via the pw://... URL. Wed, 12 Feb 2014 02:13:28 GMT Chris Johns [faa3583] * source-builder/sb/pkgconfig.py (modified) sb: Fixed from Fedora testing. Wed, 12 Feb 2014 02:11:38 GMT Chris Johns [d5c7c1f] * bare/config/devel/libffi-3.0.13-1.cfg (modified) config: Fix libffi on Fedora 64bit. Wed, 12 Feb 2014 02:09:56 GMT Chris Johns [6ff0672] * source-builder/config/glib-2-1.cfg (modified) config: Set build top for pkg-config. Wed, 12 Feb 2014 02:08:07 GMT Chris Johns [7c04790] * source-builder/config/qemu-1-1.cfg (modified) config: Disable werror because recent glibs have warnings. Tue, 11 Feb 2014 03:06:45 GMT Chris Johns [c5b5493] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * source-builder/sb/config.py (modified) config: Change pkgconfig to check. Add the extra actions: ccflags, ... Tue, 11 Feb 2014 03:06:07 GMT Chris Johns [55e52f4] * source-builder/sb/pkgconfig.py (modified) sb: Do not scan for libraries by default. Tue, 11 Feb 2014 03:05:16 GMT Chris Johns [ee93200] * source-builder/pkg-config (modified) sb: Check for empty flags and only add when a str. Mon, 10 Feb 2014 23:40:32 GMT Chris Johns [dcea9e0] * source-builder/sb/darwin.py (modified) sb: Remove the extra path. Use the default. Mon, 10 Feb 2014 23:38:33 GMT Chris Johns [f27f7c4] * bare/config/devel/gettext-0.18.3.1-1.cfg (modified) * bare/config/devel/glib-2.39.3-1.cfg (modified) * bare/config/devel/libffi-3.0.13-1.cfg (modified) * bare/config/devel/pixman-0.32.4-1.cfg (modified) * bare/config/devel/qemu-git-1.cfg (modified) * source-builder/config/glib-2-1.cfg (modified) * source-builder/config/pixman-0-1.cfg (modified) * source-builder/config/qemu-1-1.cfg (modified) config: Update qemu to build on FreeBSD. Update configuration to ... Mon, 10 Feb 2014 23:18:35 GMT Chris Johns [c4fefde] * source-builder/bin/pkg-config (deleted) * source-builder/defaults.mc (modified) * source-builder/pkg-config (added) * source-builder/sb/config.py (modified) * source-builder/sb/pkgconfig.py (added) sb: Add pkg-config support. Add a pkg-config look alike command so ... Tue, 04 Feb 2014 07:38:18 GMT Chris Johns [56e8d80] * bare/config/devel/autoconf-internal-2.69-1.cfg (added) * bare/config/devel/autotools-base.bset (added) * bare/config/devel/autotools-internal.bset (added) * bare/config/devel/autotools.bset (added) * bare/config/devel/dtc.bset (added) * bare/config/devel/gettext-0.18.3.1-1.cfg (added) * bare/config/devel/glib-2.39.3-1.cfg (added) * bare/config/devel/libffi-3.0.13-1.cfg (added) * bare/config/devel/libtool-2.4.2-1.cfg (added) * bare/config/devel/pixman-0.32.4-1.cfg (added) * bare/config/devel/qemu-git-1.cfg (added) * bare/config/devel/qemu.bset (added) * source-builder/bin/pkg-config (added) * source-builder/config/gettext-0-1.cfg (added) * source-builder/config/glib-2-1.cfg (added) * source-builder/config/libffi-3-1.cfg (added) * source-builder/config/libtool-2-1.cfg (added) * source-builder/config/pixman-0-1.cfg (added) * source-builder/config/qemu-1-1.cfg (added) * source-builder/defaults.mc (modified) config: Add support to build qemu. Qemu requires gettext, glib, ... Tue, 04 Feb 2014 07:35:33 GMT Chris Johns [edf60aa] * source-builder/sb/path.py (modified) sb: Do not assume the src is valid. Tue, 04 Feb 2014 07:23:08 GMT Chris Johns [53b918e] * source-builder/sb/download.py (modified) sb: Fix downloader url parsing and add submodule git support. Split ... Tue, 04 Feb 2014 07:22:03 GMT Chris Johns [5601b9c] * source-builder/sb/git.py (modified) sb: Add submodule support to the git support. Tue, 04 Feb 2014 07:20:40 GMT Chris Johns [7c30130] * source-builder/sb/darwin.py (modified) darwin: Default to cc and c++ for Mavrick. Tue, 04 Feb 2014 07:19:19 GMT Chris Johns [00693f9] * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) config: Default _internal_autotools_path to nil when not an internal ... Tue, 04 Feb 2014 07:18:21 GMT Chris Johns [d9c1a48] * rtems/config/rtems-base.bset (modified) rtems/gcc: Clean up the RSB version message. Thu, 30 Jan 2014 03:04:42 GMT Chris Johns [04aadb6] * source-builder/sb/check.py (modified) Check the user's PATH environment variable. Tue, 21 Jan 2014 03:09:47 GMT Chris Johns [2be445d] * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg (added) 4.11/lm32: Fix the move to newlib 2.1.0. Tue, 21 Jan 2014 01:03:30 GMT Chris Johns [53141b4] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg (added) 4.11: Move to the released newlib-2.1.0. Sat, 18 Jan 2014 06:29:39 GMT Chris Johns [16e469a] * rtems/config/4.11/rtems-sparc.bset (modified) 4.11/sparc/gdb: Use SIS patch to fix gdb outout and run fail. Tue, 07 Jan 2014 11:30:41 GMT Chris Johns [1e7eb16] * source-builder/defaults.mc (modified) Fix the link path for GDB expat test. If doing a Cxc add the ld ... Mon, 06 Jan 2014 23:04:49 GMT Nick Withers [b7a13ab] * source-builder/sb/freebsd.py (modified) FreeBSD 10 and above no longer have /usr/bin/cvs - allow it to be ... Wed, 18 Dec 2013 16:10:47 GMT Alan Cudmore [44e82d8] * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) Removed check for texinfo 5.x. Binutils 2.24 and gcc 4.8.2 build with ... Sat, 14 Dec 2013 01:21:27 GMT Chris Johns [69dca93] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-binutils-2.24-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gdb-7.6.2-1.cfg (added) Update to binutils 2.24, gcc 4.8.2, newlib 11-Dec-2013 and gdb 7.6.2. ... Sat, 14 Dec 2013 01:15:14 GMT Chris Johns [8225925] * source-builder/sb/bootstrap.py (modified) Use the --jobs option. Sun, 10 Nov 2013 01:59:03 GMT Chris Johns [5b00910] * doc/source-builder.txt (modified) Add notes on building on Maverick. Sun, 10 Nov 2013 01:30:49 GMT Chris Johns [68ddf13] * doc/source-builder.txt (modified) New Configurations documentation. Sun, 10 Nov 2013 01:30:23 GMT Chris Johns [46dcbfc] * source-builder/sb/bootstrap.py (modified) Catch the OSError on the process failing. Sat, 09 Nov 2013 22:55:37 GMT Chris Johns [ce0f7a1] * source-builder/sb/setbuilder.py (modified) Add the host to the build set tar file name if no target. If ... Tue, 05 Nov 2013 11:09:11 GMT Chris Johns [873016c] * bare/config/bare-binutils-patches.cfg (added) * bare/config/bare-config.cfg (added) * bare/config/bare-gcc-patches.cfg (added) * bare/config/bare-gdb-patches.cfg (added) * bare/config/devel/binutils-2.23.2-1.cfg (added) * bare/config/devel/gcc-4.8.2-newlib-cvs-1.cfg (added) * bare/config/devel/gdb-7.6.1-1.cfg (added) * bare/config/gnu-tools-4.8.2.bset (added) Add Bare support for GNU tools. Add support to build bare metal ... Tue, 05 Nov 2013 00:23:35 GMT Chris Johns [1bae150] * doc/source-builder.txt (modified) Add Fedora 18 dependence. Tue, 05 Nov 2013 03:36:42 GMT Chris Johns [ae717cb] * bare/.gitignore (added) * bare/config/dtc.bset (added) Add a DTC build set.
