# # ChangeLog for / in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 06/02/24 15:05:18 Mon, 02 Sep 2013 22:33:08 GMT Chris Johns [18b01e8] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gdb-7.6.1-1.cfg (added) config: Update RTEMS to gdb-7.6.1. Mon, 02 Sep 2013 22:30:26 GMT Chris Johns [845e92f] * source-builder/sb/config.py (modified) sb: Fix nesting if statements. Nesting if statements did not ... Mon, 02 Sep 2013 22:29:36 GMT Chris Johns [72f89c5] * source-builder/sb/reports.py (modified) * source-builder/sb/rtemsconfig.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Output the new info message. With the set builder add nesting ... Mon, 02 Sep 2013 21:59:38 GMT Chris Johns [348e498] * source-builder/sb/options.py (modified) sb: Add options log_info. Provide a log_info method for the options ... Sat, 31 Aug 2013 22:25:56 GMT Ivan Temp [a4937d8] * source-builder/sb/netbsd.py (added) * source-builder/sb/options.py (modified) sb: Add NetBSD support. Sat, 31 Aug 2013 02:12:37 GMT Chris Johns [8dc8b26] * doc/source-builder.txt (modified) doc: Add a cross build section. Tue, 27 Aug 2013 02:21:14 GMT Chris Johns [d4fa101] * source-builder/sb/path.py (modified) sb: Fixed the errors as found by Gedare. Mon, 26 Aug 2013 22:02:54 GMT Chris Johns [174d296] * doc/source-builder.txt (modified) doc: Improve the section on reporting errors. Mon, 26 Aug 2013 21:48:10 GMT Chris Johns [5e536f8] * source-builder/sb/path.py (modified) sb: Import log for the copytree warnings. Mon, 26 Aug 2013 21:47:44 GMT Chris Johns [2f4bd55] * source-builder/config/gcc-common-1.cfg (modified) config: Fix the empty case of extra gcc options. Thu, 22 Aug 2013 03:24:14 GMT Chris Johns [f4e9035] * source-builder/config/gcc-common-1.cfg (modified) config: Fix the use of the extra options. Thu, 22 Aug 2013 01:41:10 GMT Chris Johns [51a669f] * rtems/config/4.11/rtems-m32c.bset (modified) config: Disable ICONV support for the m32c. Thu, 22 Aug 2013 01:38:44 GMT Chris Johns [85007c3] * source-builder/sb/path.py (modified) sb: Fix copy_tree coping links on Linux Overwriting symlinks did ... Thu, 22 Aug 2013 01:38:10 GMT Chris Johns [75aa2db] * source-builder/config/gcc-common-1.cfg (modified) config: Add support for extra GCC configure options. Wed, 21 Aug 2013 02:36:08 GMT Chris Johns [407f7ff] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) config: Fix the without_rtems macro. Thu, 15 Aug 2013 02:20:29 GMT Chris Johns [869b8a6] * source-builder/sb/path.py (modified) * source-builder/sb/setbuilder.py (modified) sb: Fix the copy tree. Python's distutil's copy tree code maintains ... Wed, 14 Aug 2013 04:23:10 GMT Chris Johns [7a5f268] * doc/source-builder.txt (modified) doc: Add controlling the build. Add patch to cygwin. Wed, 14 Aug 2013 04:08:06 GMT Chris Johns [eef0d0c] * doc/source-builder.txt (modified) doc: Add the patch module to cygwn. Wed, 14 Aug 2013 04:06:30 GMT Chris Johns [27d6ea0] * rtems/config/4.11/rtems-avr.bset (modified) * source-builder/config/gcc-common-1.cfg (modified) config: Add support for iconv encodings. Turn off iconv support for ... Wed, 14 Aug 2013 04:05:57 GMT Chris Johns [5118d73] * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) config: Change to use the GCC POSIX thread model. Wed, 14 Aug 2013 04:04:53 GMT Chris Johns [b830445] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) config: Support --without-rtems to not build RTEMS. The default is ... Wed, 14 Aug 2013 03:56:24 GMT Chris Johns [76d4899] * source-builder/config/checks.cfg (modified) config: Control languages from the command line --with/--without ... Wed, 14 Aug 2013 03:55:33 GMT Chris Johns [6201a0dd] * source-builder/defaults.mc (modified) config: Add the iconv encodings to the defaults. Thu, 08 Aug 2013 01:45:12 GMT Chris Johns [9e9162b] * rtems/config/4.11/rtems-all.bset (modified) config: Do not build autotools when building 4.11/rtems-all. Thu, 08 Aug 2013 01:43:52 GMT Chris Johns [ff0fc8e] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * source-builder/config/versions.cfg (modified) config: Check the path for a valid autoconf. Thu, 25 Jul 2013 12:24:53 GMT Chris Johns [84a3494] * README (added) * doc/source-builder.txt (modified) Add a README for github to show. Tue, 23 Jul 2013 12:19:34 GMT Chris Johns [9c150cf] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) config: PR 2134 - Return the missing =. Sun, 21 Jul 2013 00:22:03 GMT Chris Johns [01b2815] * source-builder/sb/setbuilder.py (modified) SB: Fix internal build and mailing. Output errors to the log. Sat, 20 Jul 2013 22:55:11 GMT Chris Johns [6d32fe7] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) CONFIG: PR 2127 - Build fails on Linux. Fix shell tests where '==' ... Fri, 19 Jul 2013 00:13:51 GMT Chris Johns [7fcbffd] * doc/source-builder.txt (modified) Update using the RTEMS path. Wed, 17 Jul 2013 20:34:07 GMT Chris Johns [1acb44a] * doc/source-builder.txt (modified) Add what is built and how to set the path. Tue, 16 Jul 2013 00:02:41 GMT Chris Johns [ebf8a1f] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools-base.bset (added) * rtems/config/4.11/rtems-autotools-internal.bset (added) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-autoconf-2.69-1.cfg (added) * rtems/config/tools/rtems-automake-1.12.6-1.cfg (added) * rtems/config/tools/rtems-kernel-4-1.cfg (modified) * rtems/config/tools/rtems-kernel-4.11.cfg (modified) * source-builder/config/autoconf-2-1.cfg (modified) * source-builder/config/automake-1-1.cfg (modified) * source-builder/config/versions.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/options.py (modified) * source-builder/sb/setbuilder.py (modified) Automtically build the Autotools to bootstrap RTEMS. This changes ... Tue, 16 Jul 2013 00:01:19 GMT Chris Johns [c2effc1] * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (modified) Move newlib to 14-Jul-2013. Build with Sebastian's pending upstream ... Tue, 16 Jul 2013 00:00:13 GMT Chris Johns [bfee78b] * rtems/.gitignore (modified) Ignore log_* log files. Sat, 13 Jul 2013 23:11:21 GMT Chris Johns [2626dba] * source-builder/config/dtc-1-1.cfg (modified) * source-builder/defaults.mc (modified) Fix the Cxc build configuration for the DTC tool. Sat, 13 Jul 2013 11:20:52 GMT Sebastian Huber [023b5df] * doc/source-builder.txt (modified) Fix link in documentation Wed, 19 Jun 2013 04:41:58 GMT Chris Johns [a06414c] * rtems/config/4.11/rtems-avr.bset (modified) Use target flags that lets the AVR tools build. Wed, 19 Jun 2013 04:37:48 GMT Chris Johns [9e0f6af] * rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg (modified) Update the NIOS tools to support Cxc. Mon, 17 Jun 2013 00:09:24 GMT Chris Johns [80d5fde] * source-builder/sb/freebsd.py (modified) Remove /usr/local from build flags. They cause problems with BFD etc. Thu, 06 Jun 2013 05:13:18 GMT Chris Johns [8113b76] * rtems/config/4.11/rtems-m32c.bset (modified) m32c: As per GCC PR 50928 use -O0 to build libgcc. Mon, 03 Jun 2013 07:28:00 GMT Dhananjay Balan [54a2a5f] * source-builder/sb/linux.py (modified) distro_ver fails on Non-LSB distros. Sun, 02 Jun 2013 01:51:37 GMT Chris Johns [dd42a94] * doc/source-builder.txt (modified) Fix formating. Sun, 02 Jun 2013 01:48:13 GMT Chris Johns [a2f4757] * doc/source-builder.txt (modified) Update doc with file searching details. Fri, 31 May 2013 23:38:54 GMT Chris Johns [c36107a] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg (added) gcc: RTEMS 4.11 uses 4.8.1 release. Fri, 31 May 2013 23:20:12 GMT Chris Johns [699a5e58] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Reset the CVS repo each run to remove any applied patches. Fri, 31 May 2013 22:49:27 GMT Chris Johns [47d7a552] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) newlib: Move to 31-May-2013. Fix the stack_t patcher. Fri, 31 May 2013 02:56:28 GMT Chris Johns [6bf5b3f] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Add Joel's stack_t patch. Fri, 31 May 2013 02:56:08 GMT Chris Johns [07aee95] * rtems/config/4.11/rtems-powerpc.bset (modified) Patch merged upstream. Wed, 22 May 2013 06:00:07 GMT Yin Yan [347e182] * rtems/config/4.10/rtems-arm.bset (modified) * rtems/config/4.10/rtems-autotools.bset (modified) * rtems/config/4.10/rtems-avr.bset (modified) * rtems/config/4.10/rtems-bfin.bset (modified) * rtems/config/4.10/rtems-h8300.bset (modified) * rtems/config/4.10/rtems-i386.bset (modified) * rtems/config/4.10/rtems-lm32.bset (modified) * rtems/config/4.10/rtems-m32c.bset (modified) * rtems/config/4.10/rtems-m32r.bset (modified) * rtems/config/4.10/rtems-m68k.bset (modified) * rtems/config/4.10/rtems-mips.bset (modified) * rtems/config/4.10/rtems-nios2.bset (modified) * rtems/config/4.10/rtems-powerpc.bset (modified) * rtems/config/4.10/rtems-sh.bset (modified) * rtems/config/4.10/rtems-sparc.bset (modified) * rtems/config/4.9/rtems-arm.bset (modified) * rtems/config/4.9/rtems-autotools.bset (modified) * rtems/config/4.9/rtems-i386.bset (modified) * rtems/config/4.9/rtems-m68k.bset (modified) * rtems/config/4.9/rtems-mips.bset (modified) * rtems/config/4.9/rtems-powerpc.bset (modified) * rtems/config/4.9/rtems-sparc.bset (modified) * rtems/config/tools/rtems-kernel-4.10.2.cfg (modified) * rtems/config/tools/rtems-kernel-4.9.6-1.cfg (modified) fix the problems for the set build of 4.9 and 4.10 1. "expat-2.1.0-1 ... Wed, 22 May 2013 06:51:27 GMT Amar Takhar [54c7330] * rtems/config/4.11/rtems-powerpc.bset (modified) Add newlib-remove-machine-powerpc-times_c.diff to powerpc build. Mon, 20 May 2013 07:19:47 GMT Chris Johns [d925ea3] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) * source-builder/config/gcc-4.5-1.cfg (modified) * source-builder/config/gcc-4.8-1.cfg (modified) Align the 4.8 and 4.5 configurations with the gcc-common. Sat, 18 May 2013 00:56:02 GMT Amar Takhar [06c0200] * rtems/config/4.11/rtems-moxie.bset (modified) Fix prepend /moxie/ to path location. Fixes downloading. Sat, 18 May 2013 00:55:28 GMT Amar Takhar [7142b8f] * rtems/config/rtems-base.bset (modified) Remove .git in rtem-tools repo after repo name cleanup. This fixes ... Fri, 17 May 2013 06:04:28 GMT Chris Johns [f28a102] * doc/source-builder.txt (modified) Update the git clone URL. Fri, 17 May 2013 02:52:22 GMT Chris Johns [54d1426] * source-builder/sb/options.py (modified) Clean the paths passed as args. Thu, 16 May 2013 23:56:30 GMT Cynthia Rempel [5172f31] * rtems/config/4.11/rtems-autotools.bset (modified) Update the buildset to use automake-1.12.6, which is required by ... Thu, 16 May 2013 08:19:54 GMT Amar Takhar [a08fcae] * rtems/config/4.11/rtems-moxie.bset (modified) Add moxie patch, this fixes the build. Thu, 16 May 2013 05:34:00 GMT Chris Johns [b83b596] * source-builder/sb/linux.py (modified) Fix the core detection on Linux. Wed, 15 May 2013 23:40:36 GMT Cynthia Rempel [6e583e5] * bare/config/devel/automake-1.12.6-1.cfg (added) Update the automake version to 1.12.6 as required by ... Wed, 15 May 2013 03:23:41 GMT Chris Johns [1b40c77] * source-builder/sb/check.py (modified) Make outputing errors optional. Wed, 15 May 2013 03:23:08 GMT Chris Johns [53027a9] * rtems/config/4.11/rtems-moxie.bset (modified) Moxie GDB patch has been merged upstream. Wed, 15 May 2013 02:15:14 GMT Chris Johns [db65c6a] * source-builder/config/binutils-2-1.cfg (modified) * source-builder/config/dtc-1-1.cfg (modified) * source-builder/config/expat-2-1.cfg (modified) * source-builder/config/gcc-common-1.cfg (modified) * source-builder/config/gdb-7-1.cfg (modified) * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/check.py (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/freebsd.py (modified) * source-builder/sb/linux.py (modified) * source-builder/sb/windows.py (modified) Support Canadian cross builds on FreeBSD (and other hosts). Set up ... Tue, 14 May 2013 01:12:54 GMT Chris Johns [8a1e7a0] * source-builder/sb/setbuilder.py (modified) Add better error messages. Tue, 14 May 2013 01:08:02 GMT Chris Johns [1a56a07] * bare/config/devel/autoconf-2.68-1.cfg (moved) * bare/config/devel/autoconf-2.69-1.cfg (moved) * bare/config/devel/autoconf-internal-2.68-1.cfg (moved) * bare/config/devel/automake-1.12-1.cfg (moved) * bare/config/devel/automake-1.12.2-1.cfg (moved) * bare/config/devel/automake-internal-1.12-1.cfg (moved) * bare/config/devel/binutils-2.22-1.cfg (moved) * bare/config/devel/dtc-1.2.0.cfg (moved) * bare/config/devel/expat-2.1.0-1.cfg (moved) * bare/config/devel/gcc-4.6-newlib-1.20-1.cfg (moved) * bare/config/devel/gcc-4.7-newlib-1.20-1.cfg (moved) * bare/config/devel/libusb-1.0.9-1.cfg (moved) * bare/config/devel/m4-1.4.16-1.cfg (moved) * bare/config/devel/texane-stlink-1.cfg (moved) * bare/config/gnu-tools-4.6.bset (moved) * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-autotools.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * source-builder/defaults.mc (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/options.py (modified) Add bare/config and move the source-builder/config to it. Rework ... Mon, 13 May 2013 04:48:31 GMT Chris Johns [df9c081] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Newlib CVS: 13-May-2013. Pick up the atexit changes. Mon, 13 May 2013 04:47:14 GMT Chris Johns [04f447f] * source-builder/sb/setbuilder.py (modified) Show a trace message on copy when with --dry-run. Mon, 13 May 2013 04:46:30 GMT Chris Johns [ca047f1e] * source-builder/sb/path.py (modified) Better error message on rmdir failure. Mon, 13 May 2013 04:44:49 GMT Chris Johns [5237f1cc] * source-builder/defaults.mc (modified) * source-builder/sb/build.py (modified) * source-builder/sb/config.py (modified) * source-builder/sb/cvs.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/options.py (modified) Fix support for Windows (MinGW) native builds using MSYS. Fix paths ... Mon, 13 May 2013 02:22:18 GMT Chris Johns [e226605] * source-builder/sb-rtems-config (added) * source-builder/sb/rtemsconfig.mk (added) * source-builder/sb/rtemsconfig.py (added) Add an RTEMS config wrapper around Makefile.inc. This is an ... Fri, 10 May 2013 08:13:38 GMT Chris Johns [e191ce8] * source-builder/sb/bootstrap.py (modified) Match output with the bootstrap script. Fri, 10 May 2013 01:10:40 GMT Chris Johns [8ee8460] * source-builder/sb/bootstrap.py (modified) Add check_output if on Python 2.6, ie CentOS. Thu, 09 May 2013 22:33:44 GMT Chris Johns [dd8534a] * rtems/config/4.11/rtems-mips.bset (modified) MIPS patches in newlib head and we are using that. Tue, 07 May 2013 23:56:59 GMT Chris Johns [bc19332] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Newlib 8-May-2013: Include Sebastian's atexit changes. Tue, 07 May 2013 23:56:16 GMT Chris Johns [0e358bf] * rtems/config/tools/rtems-kernel-4.11.cfg (modified) By default hard reset the RTEMS repo on a build. Tue, 07 May 2013 23:55:33 GMT Chris Johns [c8c60e5] * source-builder/sb/freebsd.py (modified) Add svn in /usr/local for FreeBSD. Fri, 03 May 2013 00:39:30 GMT Chris Johns [a6d6d31] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Forgot to remove the master branch from the URL. Fri, 03 May 2013 00:08:06 GMT Chris Johns [6159bfd] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Reset the repo before the pull it avoid any local changes effecting ... Thu, 02 May 2013 21:53:41 GMT Chris Johns [cd3d3ae] * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (modified) Move to the gcc-4.8 branch until 4.8.1 comes out. Wed, 01 May 2013 00:42:08 GMT Chris Johns [df56f7e] * source-builder/sb/setbuilder.py (modified) Improve the email reporter. Wed, 01 May 2013 00:08:36 GMT Chris Johns [c914e1d] * source-builder/sb/log.py (modified) * source-builder/sb/setbuilder.py (modified) Add tail support to the log. Email the log tail in a failure. Tue, 30 Apr 2013 22:34:09 GMT Chris Johns [3c69de0] * source-builder/sb/windows.py (modified) Add the missing Windows versions or MinGW. Tue, 30 Apr 2013 20:29:12 GMT Chris Johns [84924e4] * source-builder/sb/bootstrap.py (modified) * source-builder/sb/macros.py (modified) * source-builder/sb/reports.py (modified) Fix the open calls to use a host path. Tue, 30 Apr 2013 19:30:22 GMT Chris Johns [2edd4c9] * source-builder/sb/options.py (modified) Produce a better error message if the host support code does not load. Tue, 30 Apr 2013 19:17:11 GMT Chris Johns [a128418] * source-builder/sb/linux.py (modified) Use float for version number such as CentOS 6.3. Tue, 30 Apr 2013 07:55:33 GMT Chris Johns [9815f5f] * source-builder/defaults.mc (modified) CVS is required. The newlib version is based on cvs for 4.11. Tue, 30 Apr 2013 07:27:40 GMT Chris Johns [cb5fc2c] * source-builder/sb/linux.py (modified) The dist version is index 1 not 2. Tue, 30 Apr 2013 07:23:18 GMT Chris Johns [49c668c] * source-builder/sb/linux.py (modified) Fix the dist_ver bug. Covert the string to an int. Tue, 30 Apr 2013 05:09:13 GMT Chris Johns [1aade53] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) * rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg (added) rtems-4.11: binutils 2.23.2, gcc-4.8.0, newlib-cvs-30-April-2013, gdb-7.6 Tue, 30 Apr 2013 05:01:30 GMT Chris Johns [a48a478] * rtems/config/tools/rtems-binutils-2.23.2-1.cfg (added) * rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg (added) * rtems/config/tools/rtems-gdb-7.6-1.cfg (added) * source-builder/config/gcc-4.8-1.cfg (modified) Updated 4.11 tool versions. Tue, 30 Apr 2013 03:22:44 GMT Chris Johns [5a546fa] * doc/source-builder.txt (modified) Add mail and personal macros. Tue, 30 Apr 2013 03:22:28 GMT Chris Johns [fbb39e7] * source-builder/sb/options.py (modified) Add options help. Tue, 30 Apr 2013 01:20:54 GMT Chris Johns [97a685f] * source-builder/defaults.mc (modified) * source-builder/sb/git.py (modified) * source-builder/sb/mailer.py (added) * source-builder/sb/setbuilder.py (modified) Add mail support to mail reports. Tue, 30 Apr 2013 01:19:09 GMT Chris Johns [dfdc129] * source-builder/sb/options.py (modified) Add user private macro loading. Tue, 30 Apr 2013 01:18:46 GMT Chris Johns [1c44f1c] * source-builder/sb/macros.py (modified) Add a get value call for macros. Mon, 29 Apr 2013 22:19:15 GMT Joel Sherrill [c931fbe] * rtems/config/4.11/rtems-arm.bset (modified) * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) rtems/config/4.11/rtems-*.bset: Add gdb based BSPs for testing Also ... Mon, 29 Apr 2013 00:23:06 GMT Chris Johns [699a51c5] * rtems/config/tools/rtems-kernel-4-1.cfg (modified) Fix the C++ tools detection bug. Sun, 28 Apr 2013 23:01:14 GMT Chris Johns [adf0946] * source-builder/sb/reports.py (modified) * source-builder/sb/setbuilder.py (modified) Report from the setbuilder's build config. Refactor the reporter to ... Sun, 28 Apr 2013 22:59:53 GMT Chris Johns [8837860] * source-builder/sb/config.py (modified) Add a function to return the config file name. Sun, 28 Apr 2013 22:58:01 GMT Chris Johns [0ed876c] * source-builder/sb/download.py (modified) Do not run any download type functions if performing a dry-run. Sun, 28 Apr 2013 22:57:17 GMT Chris Johns [a702d9f] * rtems/config/4.11/rtems-avr.bset (modified) * rtems/config/4.11/rtems-bfin.bset (modified) * rtems/config/4.11/rtems-h8300.bset (modified) * rtems/config/4.11/rtems-i386.bset (modified) * rtems/config/4.11/rtems-lm32.bset (modified) * rtems/config/4.11/rtems-m32c.bset (modified) * rtems/config/4.11/rtems-m32r.bset (modified) * rtems/config/4.11/rtems-m68k.bset (modified) * rtems/config/4.11/rtems-microblaze.bset (modified) * rtems/config/4.11/rtems-mips.bset (modified) * rtems/config/4.11/rtems-moxie.bset (modified) * rtems/config/4.11/rtems-nios2.bset (modified) * rtems/config/4.11/rtems-powerpc.bset (modified) * rtems/config/4.11/rtems-sh.bset (modified) * rtems/config/4.11/rtems-sparc.bset (modified) * rtems/config/4.11/rtems-sparc64.bset (modified) * rtems/config/4.11/rtems-v850.bset (modified) Remove the .cfg. Not needed.
