# # ChangeLog for / in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/16/24 22:10:34 Sun, 14 Apr 2024 01:43:43 GMT Chris Johns [89172ba] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) 6/rtems-gcc: Revert to the gcc-13 release branch for MacOS fixes ... Sun, 14 Apr 2024 01:47:00 GMT Chris Johns [aa19d91] * source-builder/config/gcc-4.9-1.cfg (modified) rtems: Checksum fixes Updates #4991 Tue, 05 Mar 2024 04:16:26 GMT Kinsey Moore [a9490f6] * bare/config/devel/qemu-xilinx-v2023.2-1.cfg (added) * bare/config/devel/qemu-xilinx.bset (modified) qemu-xilinx: Update to 2023.2 The 2020.2 version of Xilinx's qemu ... Tue, 05 Mar 2024 03:23:03 GMT Kinsey Moore [f7997e2] * bare/config/devel/glib-2.56.4-1.cfg (added) * bare/config/devel/qemu-couverture.bset (modified) * bare/config/devel/qemu-xilinx.bset (modified) * bare/config/devel/qemu.bset (modified) * source-builder/config/glib-2-1.cfg (modified) glib: Update to 2.56.4 This updates glib to 2.56.4 for AArch64 ... Wed, 03 Apr 2024 04:20:11 GMT Chris Johns [c109b53] * source-builder/sb-rtems-pkg (added) * source-builder/sb/download.py (modified) * source-builder/sb/git.py (modified) * source-builder/sb/rtemspkg.py (added) sb: Add sb-rtems-pkg to update the RTEMS package hashes and checksums Wed, 03 Apr 2024 04:21:56 GMT Chris Johns [3220cd4] * rtems/config/tools/rtems-kernel-6.cfg (modified) * rtems/config/tools/rtems-libbsd-6.cfg (modified) * rtems/config/tools/rtems-tools-6.cfg (modified) rtems: Update RTEMS packages to their HEAD Wed, 13 Mar 2024 19:57:45 GMT Joel Sherrill [d24131a] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) rtems-gcc-*-newlib-head.cfg: Bump hash for newlib This was driven ... Wed, 13 Mar 2024 14:02:59 GMT Joel Sherrill [b6ae96f] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Bump hash to account for 5 months of changes In ... Tue, 20 Feb 2024 00:57:20 GMT Chris Johns [07ba8d5] * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (modified) * rtems/config/rtems-urls.bset (modified) * source-builder/config/gcc-4.9-1.cfg (modified) rtems: Checksum fixes Updates #4991 Mon, 12 Feb 2024 01:04:20 GMT Kinsey Moore [0d817c4] * bare/config/devel/qemu-xilinx-v2020.2-1.cfg (modified) devel/qemu-xilinx: Fix build on GCC 13.2.0 GCC 13.2.0 adds new ... Sun, 18 Feb 2024 23:43:35 GMT Chris Johns [ee02d32] * source-builder/config/gcc-4.9-1.cfg (modified) gcc: gcc-4.9-1.cfg Make-lang patch checksum error Updates #4991 Mon, 12 Feb 2024 01:03:21 GMT Kinsey Moore [43d029e] * bare/config/devel/autotools-base.bset (modified) * bare/config/devel/libtool-2.4.7-1.cfg (added) * bare/config/devel/libtool.bset (modified) Update libtool to 2.4.7 for AArch64 support Tue, 30 Jan 2024 20:04:36 GMT Kinsey Moore [08a7397] * source-builder/config/qemu-common-2.cfg (modified) qemu: Update CFLAGS and LDFLAGS overrides QEMU used to honor ... Tue, 30 Jan 2024 20:02:03 GMT Kinsey Moore [4dad5b3] * source-builder/aarch64-linux-gnu-pkg-config (added) * source-builder/x86_64-linux-gnu-pkg-config (added) source-builder: Handle modern pkg-config symlinks Modern versions ... Wed, 31 Jan 2024 19:29:53 GMT Kinsey Moore [5f4df1b] * bare/config/devel/qemu-5.2.0-1.cfg (modified) bare/config/qemu-5.2.0: Add gdbus-codegen patch Wed, 13 Dec 2023 03:08:28 GMT Chris Johns [052ae74] * bare/config/devel/or1ksim-1.1.0.cfg (modified) * source-builder/config/or1ksim-1-1.cfg (modified) bare/or1ksim: Fix invalid hash and fix the version Fri, 08 Dec 2023 00:37:08 GMT Chris Johns [25df680] * bare/config/print/texinfo.cfg (modified) print/texinfo: Check the version and build if too old Packages like ... Wed, 06 Dec 2023 21:13:58 GMT Chris Johns [5e4b3b9] * source-builder/sb/options.py (modified) sb: Set the uid and gid on POSIX systems This improves performance ... Wed, 06 Dec 2023 21:12:23 GMT Chris Johns [39ca297] * source-builder/sb/download.py (modified) sb: Allow _ in downloaded file names Wed, 06 Dec 2023 21:10:36 GMT Chris Johns [08a4418] * bare/config/devel/binutils-2.22-1.cfg (modified) * bare/config/devel/binutils-2.24-1.cfg (modified) * bare/config/devel/gcc-4.6-newlib-1.20-1.cfg (modified) * bare/config/devel/gcc-4.9.1-newlib-2.1.0-1.cfg (modified) * bare/config/devel/gdb-7.7-1.cfg (modified) * rtems/config/graphics/nxlib-0.47-dev-1.cfg (modified) * rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg (modified) * rtems/config/net/net-services-1.cfg (modified) * rtems/config/tools/rtems-libbsd-6.cfg (modified) * rtems/config/tools/rtems-net-legacy-6.cfg (modified) * rtems/config/tools/rtems-xilinx-binutils-2.36.cfg (modified) * rtems/config/tools/rtems-xilinx-gcc-10-newlib-head.cfg (modified) * source-builder/config/gdb-7.5-1.cfg (modified) * source-builder/config/nxlib-1.cfg (modified) * source-builder/config/swig-4-1.cfg (modified) hash: Fix missing hashes after errors if missing Wed, 29 Nov 2023 03:46:18 GMT Chris Johns [a970057] * source-builder/config/gdb-common-1.cfg (modified) gdb: Add options to control the python version The options are: ... Wed, 29 Nov 2023 20:46:48 GMT Chris Johns [5473354] * source-builder/sb/download.py (modified) sb: No hash on a package is an error Fri, 24 Nov 2023 04:32:58 GMT Chris Johns [9e57632] * bare/config/devel/gmp-6.2.1.cfg (modified) * bare/config/devel/gmp-6.3.0.cfg (added) * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg (modified) * source-builder/config/gcc-13.cfg (added) * source-builder/config/gmp.cfg (modified) 6: Fix gcc-13 support for MacOS Update #4921 Wed, 22 Nov 2023 23:23:51 GMT Chris Johns [b7bb493] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems/rtems-tools: Update with C++17 and Python 3.12 fixes Updates ... Mon, 31 Jul 2023 06:02:32 GMT Sebastian Huber [d4d0850] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.41.cfg (added) 6: Use Binutils 2.41 Prepare for RTEMS 6.1 release. Update #4921. Thu, 27 Jul 2023 11:07:52 GMT Sebastian Huber [df69080] * rtems/config/6/rtems-default.bset (modified) 6: Use GCC 13.2 Prepare for RTEMS 6.1 release. Update #4921. Tue, 21 Nov 2023 12:34:00 GMT Sebastian Huber [6e8bd42] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Keep RTEMS up to date with the ... Wed, 18 Oct 2023 12:52:57 GMT Sebastian Huber [7496264] * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) 6: Update GCC 12 and 13 Keep RTEMS up to date with the upstream ... Wed, 18 Oct 2023 12:52:06 GMT Sebastian Huber [07be298] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Pick up fixes for ARM/optimized-routines and the ... Mon, 20 Nov 2023 04:12:59 GMT Chris Johns [63396e2] * source-builder/sb/pkgconfig.py (modified) * source-builder/sb/version.py (modified) sb: Fix Python 3.12 safeConfigParser and invalid escape sequences ... Fri, 17 Nov 2023 17:37:37 GMT Joel Sherrill [ae81810] * rtems/config/tools/rtems-mipstx39-gdb-head.bset (added) rtems-mipstx39-gdb-head.bset: Add missing file This configuration ... Mon, 13 Nov 2023 22:19:56 GMT Michael South [b680d19] * source-builder/sb/linux.py (modified) sb/linux.py: More reliably recognize distribution If available, use ... Mon, 09 Oct 2023 05:48:03 GMT Sebastian Huber [633023d] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Keep RTEMS up to date with the ... Wed, 18 Oct 2023 08:09:49 GMT Sebastian Huber [33bb5fc] * rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg (added) 6: Add GCC 13.2 configuration Thu, 12 Oct 2023 23:18:19 GMT Chris Johns [bddb17c] * rtems/config/tools/rtems-net-legacy-6.cfg (modified) rtems/net-legacy: Update to latest Pick up the test printer header ... Thu, 05 Oct 2023 04:02:31 GMT Chris Johns [5a0959e] * rtems/config/net/net-services-1.cfg (modified) rtems/net-services: Update to latest - Updates for the RTEMS test ... Thu, 05 Oct 2023 04:01:16 GMT Chris Johns [028a244] * rtems/config/tools/rtems-libbsd-6.cfg (modified) rtems/libbsd: Update to latest - Pick up fixes to x86 (i368) bus ... Thu, 05 Oct 2023 03:56:52 GMT Chris Johns [206dc15] * rtems/config/tools/rtems-kernel-6.cfg (modified) rtems/kernel: Update to latest - libdl: fix TLS in base image - ... Thu, 05 Oct 2023 03:53:05 GMT Chris Johns [979dece] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems/tools: Update to latest Minor fix in rtems-test Mon, 09 Oct 2023 05:47:42 GMT Sebastian Huber [103006f] * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) 6: Update GCC 12 and 13 Keep RTEMS up to date with the upstream ... Mon, 09 Oct 2023 05:43:43 GMT Sebastian Huber [a536dfe] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Pick up latest changes from ... Fri, 06 Oct 2023 17:59:56 GMT Kinsey Moore [deba39f] * bare/config/devel/qemu-5.2.0-1.cfg (modified) * bare/config/devel/qemu-xilinx-v2020.2-1.cfg (modified) * source-builder/config/qemu-5-1.cfg (modified) qemu: Adjust cgem interrupt patch This patch is being moved to the ... Wed, 30 Aug 2023 23:27:08 GMT Chris Johns [35c7320] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems/tools: Execute use of shlex.join fix for python < 3.8 Updates ... Tue, 29 Aug 2023 02:12:22 GMT Chris Johns [9ca9576] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems/tools: Shell execute fixes Updates #4951 Mon, 21 Aug 2023 01:23:30 GMT Chris Johns [0860f99] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems/tools: Pick up the rtems-syms and rtems-test sis changes ... Sat, 05 Aug 2023 18:26:54 GMT Karel Gardas [7158819] * bare/config/textproc/gsed-4.9.cfg (added) * bare/config/textproc/gsed.cfg (modified) testproc/gsed: update from 4.8 to 4.9. Fixes #4938. Tue, 25 Jul 2023 02:57:37 GMT Chris Johns [fc4426c] * rtems/config/tools/rtems-kernel-6.cfg (modified) rtems/kernel: Update to the current kernel - Pick up the Beatnik ... Mon, 24 Jul 2023 09:23:46 GMT Sebastian Huber [96b1140] * bare/config/devel/expat-2.5.0-1.cfg (added) * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-microblaze.bset (modified) * rtems/config/7/rtems-default.bset (modified) 6: Use libexpat 2.5.0 This version contains security fixes. ... Mon, 24 Jul 2023 08:52:57 GMT Sebastian Huber [fd3ab60] * rtems/config/6/rtems-default.bset (modified) * rtems/config/6/rtems-microblaze.bset (modified) * rtems/config/tools/rtems-gdb-13.2.cfg (added) 6: Use GDB 13.2 Prepare for RTEMS 6.1 release. Update #4921. Thu, 20 Jul 2023 19:02:08 GMT Sebastian Huber [df776fb] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Keep RTEMS up to date with the ... Thu, 20 Jul 2023 19:01:36 GMT Sebastian Huber [25a073d] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) 6: Update GCC 10, 12 and 13 Keep RTEMS up to date with the upstream ... Thu, 20 Jul 2023 19:01:03 GMT Sebastian Huber [74f8773] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Keep RTEMS up to date with the upstream development. Thu, 20 Jul 2023 01:16:06 GMT Vijay Kumar Banerjee [7e0079b] * rtems/config/tools/rtems-net-legacy-6.cfg (modified) rtems-net-legacy: Update net and waf versions Mon, 26 Jun 2023 19:55:07 GMT Sebastian Huber [8e568b2] * rtems/config/tools/rtems-gcc-13-newlib-head.cfg (added) tools: Add GCC 13 configuration Keep RTEMS up to date with the ... Mon, 26 Jun 2023 19:54:59 GMT Sebastian Huber [0b87c91] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Keep RTEMS up to date with the ... Mon, 26 Jun 2023 19:54:39 GMT Sebastian Huber [903796c] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) 6: Update GCC 10 and 12 Keep RTEMS up to date with the upstream ... Mon, 26 Jun 2023 19:54:12 GMT Sebastian Huber [4a30bb4] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Keep RTEMS up to date with the upstream development. Mon, 26 Jun 2023 19:01:15 GMT Kinsey Moore [34cecb8] * source-builder/config/qemu-5-1.cfg (modified) qemu-5-1: Update to the latest CGEM patch The original version of ... Thu, 15 Jun 2023 15:51:27 GMT Kinsey Moore [ac1fee4] * source-builder/config/qemu-5-1.cfg (modified) qemu-5-1: Add patch for ZynqMP/Versal CGEMs This temporarily adds a ... Thu, 08 Jun 2023 09:28:34 GMT Chris Johns [0e09a7f] * rtems/config/net/net-services-1.cfg (modified) rtems/net-services: Add to the ntpq query an output buffer and size Mon, 05 Jun 2023 06:44:31 GMT Chris Johns [3c8c2ce3] * rtems/config/tools/rtems-kernel-6.cfg (modified) rtems/kernel: Update kernel - Zynq ARM fixes - AARCH64 MMU fix ... Mon, 05 Jun 2023 06:41:55 GMT Chris Johns [70c222d] * rtems/config/tools/rtems-net-legacy-6.cfg (modified) rtrems/net-legacy: Update rtems-net-legacy - Add getaddrinfom, ... Tue, 16 May 2023 05:25:41 GMT Chris Johns [7e52fd7] * rtems/config/net/net-services-1.cfg (added) * rtems/config/net/net-services.bset (added) * rtems/config/tools/rtems-net-services.cfg (added) rtems/net: Add net services build support Fri, 19 May 2023 14:53:13 GMT Joel Sherrill [ceed4bd] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) rtems-gcc-*-newlib-head.cfg: Update to include true long double math ... Wed, 17 May 2023 21:11:13 GMT Joel Sherrill [56161b3] * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) rtems-gcc-12-newlib-head.cfg: Update to include true long double math ... Sat, 22 Apr 2023 05:22:30 GMT Chris Johns [6f96edf] * source-builder/pkg-config (modified) sb/pkg-config: Add --cflags-only-I and --cflags-only-other option Sat, 22 Apr 2023 05:21:38 GMT Chris Johns [c85c46e] * source-builder/sb/options.py (modified) sb/option: Add the arch to the macros from the --rtems-bsp option Sat, 22 Apr 2023 05:20:34 GMT Chris Johns [9c1e5c7] * source-builder/sb/rtems-build-dep (modified) sb: Fix the library handling in rtems-build-dep Sat, 22 Apr 2023 05:05:14 GMT Chris Johns [574839d] * source-builder/sb/path.py (modified) sb/path: Handle unicode filenames in a source path The change ... Fri, 05 May 2023 14:17:10 GMT Alex White [122058e] * bare/config/devel/qemu-xilinx-v2020.2-1.cfg (modified) devel/qemu-xilinx: Fix source URL The source URL for Xilinx QEMU ... Tue, 18 Apr 2023 12:04:13 GMT Sebastian Huber [908efe4] * rtems/config/7/rtems-m68k.bset (modified) 7: Use TLS in Newlib for m68k by default Update #4560. Tue, 18 Apr 2023 09:40:21 GMT Sebastian Huber [ca04d78e] * rtems/config/tools/rtems-binutils-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) * rtems/config/tools/rtems-gdb-head.cfg (modified) 7: Update Binutils, GDB, and GCC Mon, 24 Apr 2023 06:05:24 GMT Sebastian Huber [8ae7c62] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) 6: Update GCC 10 and 12 Tue, 25 Apr 2023 17:48:20 GMT Sebastian Huber [53968aa] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Tue, 18 Apr 2023 09:39:11 GMT Sebastian Huber [630e78ef] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) 6: Update GCC 10 and 12 Tue, 18 Apr 2023 09:38:23 GMT Sebastian Huber [4cd9f0a] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Fri, 14 Apr 2023 20:43:23 GMT Chris Johns [ae00c59] * rtems/config/tools/rtems-kernel-6.cfg (modified) * rtems/config/tools/rtems-net-legacy-6.cfg (modified) * rtems/config/tools/rtems-tools-6.cfg (modified) rtems: Update tools, kernel and legacy network packages - Tools ... Fri, 14 Apr 2023 22:53:53 GMT Chris Johns [c574931] * rtems/config/tools/rtems-default-tools.bset (modified) rtems: Add back gsed that was remove by mistake - Build GNU sed for ... Tue, 11 Apr 2023 11:18:25 GMT Chris Johns [4c73a76] * bare/config/print/texinfo-7.0.3.cfg (added) * bare/config/print/texinfo-internal.bset (added) * bare/config/print/texinfo.bset (added) * bare/config/print/texinfo.cfg (added) * bare/config/textproc/gsed-internal.bset (modified) * rtems/config/tools/rtems-default-tools.bset (modified) * source-builder/config/gsed-1.cfg (modified) * source-builder/config/texinfo-1.cfg (added) * source-builder/defaults.mc (modified) print/texinfo: Add texinfo package - MacOS systems do not come with ... Tue, 11 Apr 2023 05:59:40 GMT Chris Johns [78913bc] * source-builder/config/gdb-common-1.cfg (modified) gdb-common: Fix the python-config library parsing Closes #4894 Wed, 05 Apr 2023 00:11:39 GMT Chris Johns [024db7d] * rtems/config/6/rtems-microblaze.bset (modified) rtems/microblaze: Update to GDB 13.1 Note: GCC does not build on ... Tue, 04 Apr 2023 05:17:14 GMT Chris Johns [cf447af] * rtems/config/6/rtems-mips.bset (modified) * rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb-head.cfg (deleted) * rtems/config/tools/rtems-mipstx39-gdb.bset (added) rtems/mipsstx39: Update to GDB 13.1 and stage build GMP - Use a ... Tue, 04 Apr 2023 04:39:14 GMT Chris Johns [05f6bef] * bare/config/devel/mpfr-4.2.0.cfg (added) * source-builder/config/mpfr.cfg (added) devel/mpfr: Add MPFR as a package - This is a place holder incase ... Tue, 04 Apr 2023 03:46:14 GMT Chris Johns [235c12f] * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * source-builder/config/gcc-12.cfg (modified) devel/mpfr: Update to 4.2.0 to support MacOS AARCH64 - Use base64 ... Tue, 04 Apr 2023 03:45:04 GMT Chris Johns [4358a03] * source-builder/config/gmp.cfg (modified) devel/gmp: Disable assemble builds on MacOS AARCH64 Updates #4892 Tue, 04 Apr 2023 03:43:16 GMT Chris Johns [f3c5dbd] * source-builder/config/gcc-common-1.cfg (modified) rtems/gcc: Do not build GMP in GCC, use the staged build - Do not ... Mon, 27 Mar 2023 02:49:38 GMT Chris Johns [9919f12] * rtems/config/tools/rtems-gdb-13.1.cfg (modified) * source-builder/config/gdb-common-1.cfg (modified) gdb: Use a virtual environment if present - Detect and use a ... Mon, 27 Mar 2023 02:41:19 GMT Chris Johns [344981a] * source-builder/config/dtc-1-1.cfg (modified) dtc: Disable warnings Updates #4892 Tue, 21 Mar 2023 11:05:41 GMT Chris Johns [f0e34ea] * source-builder/config/binutils-2-1.cfg (modified) binutils: Disable stack exec and RWX section warnings Binutils 2.39 ... Tue, 21 Mar 2023 18:43:53 GMT Kinsey Moore [0e55aff] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.39.cfg (added) Revert binutils to 2.39 for rtems6 Binutils 2.40 has a regression ... Sun, 19 Mar 2023 22:13:15 GMT Karel Gardas [0054104] * source-builder/config/grub2.cfg (modified) grub2.cfg: fix GRUB compilation with GCC 12. Tue, 14 Mar 2023 16:53:44 GMT Joel Sherrill [da7b5a7] * rtems/config/tools/rtems-tools-6.cfg (modified) rtems-tools-6.cfg: Update to get RISC-V bsp-builder corrections Wed, 08 Mar 2023 15:32:50 GMT Alex White [7153c2f] * rtems/config/6/rtems-microblaze.bset (modified) 6: Update MicroBlaze gdb to 12.1 GDB 11.2 fails to compile on ... Thu, 09 Mar 2023 03:28:55 GMT Chris Johns [e5abdec] * rtems/config/tools/rtems-gdb-13.1.cfg (modified) * source-builder/sb/freebsd.py (modified) 6/gdb: fix building on FreeBSD 13.1 See ... Fri, 24 Feb 2023 07:44:13 GMT Sebastian Huber [bfed514] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) 6: Update GCC 10 and 12 Fri, 24 Feb 2023 07:43:39 GMT Sebastian Huber [fd4757d] * rtems/config/tools/rtems-gcc-10-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-12-newlib-head.cfg (modified) * rtems/config/tools/rtems-gcc-head-newlib-head.cfg (modified) 6/7: Update Newlib Tue, 21 Feb 2023 15:24:37 GMT Joel Sherrill [c58857d] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-binutils-2.40.cfg (added) Update to binutils 2.40 for rtems 6 Mon, 20 Feb 2023 18:22:59 GMT Joel Sherrill [fa1936e] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-gdb-13.1.cfg (added) Update to gdb 13.1 for rtems 6 Mon, 20 Feb 2023 16:08:24 GMT Joel Sherrill [fc1b2dc] * rtems/config/tools/rtems-tools-6.cfg (modified) config/tools/rtems-tools-6.cfg: Include fix for RISC-V BSP set in ... Thu, 16 Feb 2023 22:26:27 GMT Joel Sherrill [e3f4060] * rtems/config/6/rtems-default.bset (modified) * rtems/config/tools/rtems-gdb-12.1.cfg (added) Update gdb to 12.1 including patch for hosts with readline 8.2 ...
