# # ChangeLog for .gitignore in rtems-source-builder # # Generated by Trac 1.2.1.dev0 # 04/24/24 04:57:16 Wed, 16 Mar 2016 04:56:46 GMT Chris Johns [e764974] * .gitignore (modified) * rtems/config/4.11/databases/sqlite.bset (deleted) * rtems/config/4.11/graphics/freetype2.bset (deleted) * rtems/config/4.11/graphics/graphics-all.bset (deleted) * rtems/config/4.11/graphics/libjpeg.bset (deleted) * rtems/config/4.11/graphics/libpng.bset (deleted) * rtems/config/4.11/graphics/libtiff.bset (deleted) * rtems/config/4.11/graphics/microwindows.bset (deleted) * rtems/config/4.11/graphics/nxlib.bset (deleted) * rtems/config/4.11/graphics/t1lib.bset (deleted) * rtems/config/4.11/net-mgmt/net-snmp.bset (deleted) * rtems/config/4.11/net/lwip.bset (deleted) * rtems/config/4.11/net/ntp.bset (deleted) * rtems/config/4.11/net/protobuf.bset (deleted) * rtems/config/4.11/rtems-all.bset (deleted) * rtems/config/4.11/rtems-arm.bset (deleted) * rtems/config/4.11/rtems-autotools-base.bset (deleted) * rtems/config/4.11/rtems-autotools-internal.bset (deleted) * rtems/config/4.11/rtems-autotools.bset (deleted) * rtems/config/4.11/rtems-avr.bset (deleted) * rtems/config/4.11/rtems-bfin.bset (deleted) * rtems/config/4.11/rtems-epiphany.bset (deleted) * rtems/config/4.11/rtems-h8300.bset (deleted) * rtems/config/4.11/rtems-i386.bset (deleted) * rtems/config/4.11/rtems-lm32.bset (deleted) * rtems/config/4.11/rtems-m32c.bset (deleted) * rtems/config/4.11/rtems-m32r.bset (deleted) * rtems/config/4.11/rtems-m68k.bset (deleted) * rtems/config/4.11/rtems-microblaze.bset (deleted) * rtems/config/4.11/rtems-mips.bset (deleted) * rtems/config/4.11/rtems-moxie.bset (deleted) * rtems/config/4.11/rtems-nios2.bset (deleted) * rtems/config/4.11/rtems-or1k.bset (deleted) * rtems/config/4.11/rtems-powerpc.bset (deleted) * rtems/config/4.11/rtems-sh.bset (deleted) * rtems/config/4.11/rtems-sparc.bset (deleted) * rtems/config/4.11/rtems-sparc64.bset (deleted) * rtems/config/4.11/rtems-tools.bset (deleted) * rtems/config/4.11/rtems-v850.bset (deleted) 4.11: Remove from master. Updates #2649. Mon, 14 Mar 2016 23:55:23 GMT Chris Johns [33308d1] * .gitignore (modified) * source-builder/sb/darwin.py (modified) * source-builder/sb/solaris.py (modified) * source-builder/sb/windows.py (modified) sb: Make cvs optional. Ignore RSB generated files to keep the git ... Tue, 08 Dec 2015 01:53:13 GMT Chris Johns [f8ef062] * .gitignore (added) Ignore VERSION files in the top directory. Mon, 05 Nov 2012 23:09:40 GMT Chris Johns [c80560d] * source-builder/.gitignore (moved) * source-builder/config/autoconf-2-1.cfg (moved) * source-builder/config/autoconf-2.68-1.cfg (moved) * source-builder/config/autoconf-2.69-1.cfg (moved) * source-builder/config/autoconf-internal-2.68-1.cfg (moved) * source-builder/config/automake-1-1.cfg (moved) * source-builder/config/automake-1.12-1.cfg (moved) * source-builder/config/automake-internal-1.12-1.cfg (moved) * source-builder/config/base.cfg (moved) * source-builder/config/binutils-2-1.cfg (moved) * source-builder/config/binutils-2.22-1.cfg (moved) * source-builder/config/checks.cfg (moved) * source-builder/config/expat-2-1.cfg (moved) * source-builder/config/expat-2.1.0-1.cfg (moved) * source-builder/config/gcc-4.4-1.cfg (moved) * source-builder/config/gcc-4.6-1.cfg (moved) * source-builder/config/gcc-4.6-newlib-1.20-1.cfg (moved) * source-builder/config/gdb-7-1.cfg (moved) * source-builder/config/gdb-7.5-1.cfg (moved) * source-builder/config/gnu-tools-4.6.bset (moved) * source-builder/config/libusb-1-1.cfg (moved) * source-builder/config/libusb-1.0.9-1.cfg (moved) * source-builder/config/m4-1-1.cfg (moved) * source-builder/config/m4-1.4.16-1.cfg (moved) * source-builder/config/texane-stlink-1.cfg (moved) * source-builder/doc/.gitignore (moved) * source-builder/doc/images/icons/README (moved) * source-builder/doc/images/icons/callouts/1.png (moved) * source-builder/doc/images/icons/callouts/10.png (moved) * source-builder/doc/images/icons/callouts/11.png (moved) * source-builder/doc/images/icons/callouts/12.png (moved) * source-builder/doc/images/icons/callouts/13.png (moved) * source-builder/doc/images/icons/callouts/14.png (moved) * source-builder/doc/images/icons/callouts/15.png (moved) * source-builder/doc/images/icons/callouts/2.png (moved) * source-builder/doc/images/icons/callouts/3.png (moved) * source-builder/doc/images/icons/callouts/4.png (moved) * source-builder/doc/images/icons/callouts/5.png (moved) * source-builder/doc/images/icons/callouts/6.png (moved) * source-builder/doc/images/icons/callouts/7.png (moved) * source-builder/doc/images/icons/callouts/8.png (moved) * source-builder/doc/images/icons/callouts/9.png (moved) * source-builder/doc/images/icons/caution.png (moved) * source-builder/doc/images/icons/example.png (moved) * source-builder/doc/images/icons/home.png (moved) * source-builder/doc/images/icons/important.png (moved) * source-builder/doc/images/icons/next.png (moved) * source-builder/doc/images/icons/note.png (moved) * source-builder/doc/images/icons/prev.png (moved) * source-builder/doc/images/icons/tip.png (moved) * source-builder/doc/images/icons/up.png (moved) * source-builder/doc/images/icons/warning.png (moved) * source-builder/doc/images/rtemswhitebg.jpg (moved) * source-builder/doc/source-builder.txt (moved) * source-builder/doc/wscript (moved) * source-builder/patches/texane-stlink-3494c11-1.diff (moved) * source-builder/patches/texane-stlink-3494c11-2.diff (moved) * source-builder/sb-builder (moved) * source-builder/sb-check (moved) * source-builder/sb-set-builder (moved) * source-builder/sb/build.py (moved) * source-builder/sb/check.py (moved) * source-builder/sb/config.py (moved) * source-builder/sb/darwin.py (moved) * source-builder/sb/defaults.py (moved) * source-builder/sb/error.py (moved) * source-builder/sb/execute.py (moved) * source-builder/sb/freebsd.py (moved) * source-builder/sb/linux.py (moved) * source-builder/sb/log.py (moved) * source-builder/sb/path.py (moved) * source-builder/sb/setbuilder.py (moved) * source-builder/sb/windows.py (moved) Move into the source-builder tree. Mon, 29 Oct 2012 23:37:12 GMT Chris Johns [bf13d27] * .gitignore (added) * config/base.cfg (added) * config/binutils-2-1.cfg (added) * config/binutils-2.22-1.cfg (added) * config/checks.cfg (added) * config/gcc-4.6-1.cfg (added) * config/gcc-4.6-newlib-1.20-1.cfg (added) * tb-builder (added) * tb-crossgcc (added) * tb/build.py (added) * tb/config.py (added) * tb/crossgcc.py (added) * tb/darwin.py (added) * tb/defaults.py (added) * tb/error.py (added) * tb/execute.py (added) * tb/linux.py (added) * tb/log.py (added) * tb/windows.py (added) Initial import.
