# # ChangeLog for schedsim/rtems/rtems_sched.h in rtems-schedsim # # Generated by Trac 1.2.1.dev0 # 04/25/24 06:31:18 Wed, 01 May 2013 00:41:56 GMT Joel Sherrill [a2aad55] * LICENSE (modified) * Makefile.am (modified) * README (modified) * SUPPORT (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/check-smp.m4 (modified) * aclocal/enable-rtemsdir.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) * automake/host.am (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * configure.ac (modified) * schedsim/Makefile.am (modified) * schedsim/README (modified) * schedsim/configure.ac (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/rtems/debugio.c (modified) * schedsim/rtems/interr.c (modified) * schedsim/rtems/rtems_init.c (modified) * schedsim/rtems/rtems_sched.h (modified) * schedsim/rtems/sched_cpu/cpu.c (modified) * schedsim/rtems/sched_cpu/cpu_asm.c (modified) * schedsim/rtems/sched_cpu/rtems/asm.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h (modified) * schedsim/rtems/sched_cpu/rtems/score/no_cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/types.h (modified) * schedsim/rtems/wkspace.c (modified) * schedsim/shell/Makefile.am (modified) * schedsim/shell/run_scenarios (modified) * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/printheir_executing.c (modified) * schedsim/shell/schedsim_priority/schedsim.cc (modified) * schedsim/shell/schedsim_priority/smp_stub.c (modified) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/README (modified) * schedsim/shell/schedsim_smpsimple/TODO (modified) * schedsim/shell/schedsim_smpsimple/add_commands.c (modified) * schedsim/shell/schedsim_smpsimple/config.c (modified) * schedsim/shell/schedsim_smpsimple/main_current_cpu.c (modified) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_all_cpus.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_ready_tasks.c (modified) * schedsim/shell/schedsim_smpsimple/printheir_executing.c (modified) * schedsim/shell/schedsim_smpsimple/schedsim.cc (modified) * schedsim/shell/schedsim_smpsimple/smp_stub.c (modified) * schedsim/shell/schedsim_smpsimple/wrap_thread_dispatch.c (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/include/rtems/confdefs.h (modified) * schedsim/shell/shared/include/shell.h (modified) * schedsim/shell/shared/lookup_semaphore.c (modified) * schedsim/shell/shared/lookup_task.c (modified) * schedsim/shell/shared/main_clocktick.c (modified) * schedsim/shell/shared/main_echo.c (modified) * schedsim/shell/shared/main_executing.c (modified) * schedsim/shell/shared/main_heir.c (modified) * schedsim/shell/shared/main_help.c (modified) * schedsim/shell/shared/main_rtemsinit.c (modified) * schedsim/shell/shared/main_semcreate.c (modified) * schedsim/shell/shared/main_semdelete.c (modified) * schedsim/shell/shared/main_semflush.c (modified) * schedsim/shell/shared/main_semobtain.c (modified) * schedsim/shell/shared/main_semrelease.c (modified) * schedsim/shell/shared/main_taskcreate.c (modified) * schedsim/shell/shared/main_taskdelete.c (modified) * schedsim/shell/shared/main_taskmode.c (modified) * schedsim/shell/shared/main_taskpriority.c (modified) * schedsim/shell/shared/main_taskresume.c (modified) * schedsim/shell/shared/main_tasksuspend.c (modified) * schedsim/shell/shared/main_taskwakeafter.c (modified) * schedsim/shell/shared/schedsim_shell.h (modified) * schedsim/shell/shared/shell_cmdset.c (modified) * schedsim/shell/shared/shell_makeargs.c (modified) Remove CVS $ Mon, 25 Apr 2011 15:53:10 GMT Joel Sherrill [abb18dc] * .configure.swp (added) * LICENSE (added) * Makefile.am (added) * SUPPORT (added) * VERSION (added) * acinclude.m4 (added) * aclocal/bsp-alias.m4 (added) * aclocal/canonical-target-name.m4 (added) * aclocal/check-bsps.m4 (added) * aclocal/check-custom-bsp.m4 (added) * aclocal/enable-cxx.m4 (added) * aclocal/enable-multiprocessing.m4 (added) * aclocal/enable-networking.m4 (added) * aclocal/enable-posix.m4 (added) * aclocal/enable-rtems-debug.m4 (added) * aclocal/enable-rtemsbsp.m4 (added) * aclocal/enable-rtemsdir.m4 (added) * aclocal/enable-smp.m4 (added) * aclocal/enable-tests.m4 (added) * aclocal/multilib.m4 (added) * aclocal/path-ksh.m4 (added) * aclocal/project-root.m4 (added) * aclocal/quoting.m4 (added) * aclocal/rpm.m4 (added) * aclocal/rtems-top.m4 (added) * aclocal/tool-paths.m4 (added) * aclocal/version.m4 (added) * automake/host.am (added) * automake/local.am (added) * automake/subdirs.am (added) * configure.ac (added) * schedsim/.cvsignore (added) * schedsim/ChangeLog (added) * schedsim/Makefile.am (added) * schedsim/README (added) * schedsim/configure.ac (added) * schedsim/rtems/.cvsignore (added) * schedsim/rtems/ChangeLog (added) * schedsim/rtems/Makefile.am (added) * schedsim/rtems/interr.c (added) * schedsim/rtems/rtems_init.c (added) * schedsim/rtems/rtems_sched.h (added) * schedsim/rtems/sched_cpu/cpu.c (added) * schedsim/rtems/sched_cpu/cpu_asm.c (added) * schedsim/rtems/sched_cpu/rtems/asm.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpuopts.h (added) * schedsim/rtems/sched_cpu/rtems/score/no_cpu.h (added) * schedsim/rtems/sched_cpu/rtems/score/types.h (added) * schedsim/rtems/sched_cpu/rtems/stringto.h (added) * schedsim/rtems/wkspace.c (added) * schedsim/shell/.cvsignore (added) * schedsim/shell/ChangeLog (added) * schedsim/shell/Makefile.am (added) * schedsim/shell/schedsim_priority/.cvsignore (added) * schedsim/shell/schedsim_priority/Makefile.am (added) * schedsim/shell/schedsim_priority/config.c (added) * schedsim/shell/schedsim_priority/printheir_executing.c (added) * schedsim/shell/schedsim_priority/scenarios/script01 (added) * schedsim/shell/schedsim_priority/scenarios/script02 (added) * schedsim/shell/schedsim_priority/scenarios/script03 (added) * schedsim/shell/schedsim_priority/scenarios/script04 (added) * schedsim/shell/schedsim_priority/scenarios/script05 (added) * schedsim/shell/schedsim_priority/scenarios/script06 (added) * schedsim/shell/schedsim_priority/schedsim.cc (added) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (added) * schedsim/shell/shared/.cvsignore (added) * schedsim/shell/shared/Makefile.am (added) * schedsim/shell/shared/commands.c (added) * schedsim/shell/shared/getopt.c (added) * schedsim/shell/shared/include/newlib/_ansi.h (added) * schedsim/shell/shared/include/newlib/getopt.h (added) * schedsim/shell/shared/include/shell.h (added) * schedsim/shell/shared/lookup_semaphore.c (added) * schedsim/shell/shared/lookup_task.c (added) * schedsim/shell/shared/main_clocktick.c (added) * schedsim/shell/shared/main_echo.c (added) * schedsim/shell/shared/main_executing.c (added) * schedsim/shell/shared/main_heir.c (added) * schedsim/shell/shared/main_help.c (added) * schedsim/shell/shared/main_rtemsinit.c (added) * schedsim/shell/shared/main_semcreate.c (added) * schedsim/shell/shared/main_semdelete.c (added) * schedsim/shell/shared/main_semflush.c (added) * schedsim/shell/shared/main_semobtain.c (added) * schedsim/shell/shared/main_semrelease.c (added) * schedsim/shell/shared/main_taskcreate.c (added) * schedsim/shell/shared/main_taskdelete.c (added) * schedsim/shell/shared/main_taskmode.c (added) * schedsim/shell/shared/main_taskpriority.c (added) * schedsim/shell/shared/main_taskresume.c (added) * schedsim/shell/shared/main_tasksuspend.c (added) * schedsim/shell/shared/main_taskwakeafter.c (added) * schedsim/shell/shared/schedsim_shell.h (added) * schedsim/shell/shared/shell_cmdset.c (added) * schedsim/shell/shared/shell_makeargs.c (added) Initial import.
