# # ChangeLog for / in rtems-schedsim # # Generated by Trac 1.2.1.dev0 # 03/29/24 05:08:06 Fri, 13 Jun 2014 14:24:44 GMT Jennifer Averett [ac03e9a] * schedsim/rtems/Makefile.am (modified) rtems: Add _Thread_Yield support. Wed, 04 Jun 2014 18:27:54 GMT Jennifer Averett [1f3e974] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case4.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_create_case1.expected (added) schedsim_smppriority_affinity: Resolve problem in expected files. Wed, 04 Jun 2014 15:08:33 GMT Joel Sherrill [cdf219c] * schedsim/rtems/Makefile.am (modified) schedsim/rtems/Makefile.am: Resync with RTEMS source Tue, 03 Jun 2014 12:27:33 GMT Jennifer Averett [c8d1dbb] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case3.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case3.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case3.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case3.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case4.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case4.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_create_case1.scen (added) schedsim_smppriority_affinity: New scenarios. Tue, 03 Jun 2014 12:25:24 GMT Jennifer Averett [42888e1] * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.scen (modified) schedsim_smpsimple: Add task verification per core to scenario. Tue, 03 Jun 2014 12:23:55 GMT Jennifer Averett [4be3859] * schedsim/shell/schedsim_priority/scenarios/inherit_priority.expected (added) * schedsim/shell/schedsim_priority/scenarios/inherit_priority.scen (added) schedsim_priority: Add priority inheritance scenario. Tue, 27 May 2014 15:42:54 GMT Joel Sherrill [c19f6a3] * schedsim/configure.ac (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/shell/Makefile.am (modified) * schedsim/shell/schedsim_simple/Makefile.am (added) * schedsim/shell/schedsim_simple/config.c (added) Add Simulator for Uniprocessor Simple Priority Tue, 27 May 2014 15:40:34 GMT Joel Sherrill [ea855c1] * ChangeLog (deleted) * schedsim/ChangeLog (deleted) * schedsim/rtems/ChangeLog (deleted) * schedsim/shell/ChangeLog (deleted) * schedsim/shell/schedsim_priority/ChangeLog (deleted) * schedsim/shell/schedsim_smpsimple/ChangeLog (deleted) Remove ChangeLog files Tue, 27 May 2014 15:20:40 GMT Joel Sherrill [e3c15fb] * schedsim/shell/shared/schedsim.c (modified) schedsim.c: Verify status of 0 Tue, 27 May 2014 14:52:12 GMT Jennifer Averett [ee66622] * schedsim/shell/schedsim_priority/scenarios/script03.expected (modified) schedsim_priority: Fix incorrect expected values in script03. Tue, 27 May 2014 14:46:10 GMT Jennifer Averett [d9ea4ab] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_block_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case3.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_overlap_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case3.expected (modified) schedsim_smppriority_affinity: Change expected scenaoro filenames to ... Tue, 27 May 2014 14:40:40 GMT Jennifer Averett [b68f8cd] * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_inherit_priority.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.expected (modified) schedsim_smpsimple: Change scenarios to expect verbose output. Tue, 27 May 2014 14:39:09 GMT Jennifer Averett [d1f9281] * schedsim/shell/schedsim_priority/scenarios/script01.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script02.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script03.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script04.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script05.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script06.expected (modified) schedsim_priority: Change scenario's to expect verbose output. Tue, 27 May 2014 14:15:37 GMT Jennifer Averett [f6fe059] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case1.scen (modified) schedsim_smpsimple: Remove error case from scenario file. Any error ... Tue, 27 May 2014 14:06:47 GMT Joel Sherrill [01cb6c9] * schedsim/shell/shared/schedsim.c (modified) schedsim.c: Print basename of scenarion and verbose is on by default Mon, 26 May 2014 22:24:17 GMT Joel Sherrill [d36a128] * schedsim/shell/run_scenarios (modified) * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) make check now works and reports pass/fail Mon, 26 May 2014 19:08:12 GMT Joel Sherrill [205f794] * schedsim/shell/run_scenarios (modified) * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) Add initial support for make check + Enhance run_scenario to run ... Mon, 26 May 2014 19:01:06 GMT Joel Sherrill [d8918c1] * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/getthreadexecuting.c (added) * schedsim/shell/shared/getthreadheir.c (added) * schedsim/shell/shared/lookup_task.c (modified) * schedsim/shell/shared/main_semobtain.c (modified) * schedsim/shell/shared/main_taskwakeafter.c (modified) * schedsim/shell/shared/schedsim_shell.h (modified) * schedsim/shell/shared/wrap_thread_dispatch.c (modified) Misc so more scenarios run Mon, 26 May 2014 18:26:41 GMT Joel Sherrill [e5e757b] * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (deleted) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/smp_stub.c (modified) * schedsim/shell/shared/wrap_thread_dispatch.c (moved) _Thread_Dispatch wrapper is now shared between uniprocessor and SMP ... Mon, 26 May 2014 18:15:13 GMT Joel Sherrill [968d2b2] * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/printheir_executing.c (deleted) * schedsim/shell/schedsim_priority/scenarios/script01.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script02.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script03.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script04.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script05.expected (modified) * schedsim/shell/schedsim_priority/scenarios/script06.expected (modified) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_block_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case3.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_overlap_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case3.expected (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.expected (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/printheir_executing.c (moved) Unify printing of heir and executing Mon, 26 May 2014 17:55:18 GMT Joel Sherrill [246b81f] * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/add_commands.c (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/main_dispatch.c (moved) dispatch is now a shared SMP command Mon, 26 May 2014 17:46:20 GMT Joel Sherrill [e340e96] * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/add_commands.c (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/main_currentcpu.c (moved) current_cpu is now a shared SMP command Mon, 26 May 2014 17:36:38 GMT Joel Sherrill [ebc54d0] * schedsim/configure.ac (modified) configure.ac: Generate config.h Mon, 26 May 2014 17:36:14 GMT Joel Sherrill [8f63fbe] * schedsim/shell/shared/smp_stub.c (modified) shared/smp_stub.c: Correct bug Mon, 26 May 2014 17:15:11 GMT Joel Sherrill [87c69f3] * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/smp_stub.c (deleted) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/smp_stub.c (moved) shared/smp_stub.c: Only one shared version now Mon, 26 May 2014 17:02:56 GMT Joel Sherrill [24af09a] * schedsim/shell/shared/lookup_task.c (modified) * schedsim/shell/shared/main_semobtain.c (modified) lookup*.c, main_semobtain.c: Link on uniprocessor again Fri, 23 May 2014 21:46:22 GMT Joel Sherrill [36f4cb9] * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/schedsim.cc (deleted) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/add_commands_stub.c (added) * schedsim/shell/shared/schedsim.c (moved) * schedsim/shell/shared/schedsim_shell.h (modified) Use shared main() and file processor Fri, 23 May 2014 21:28:22 GMT Joel Sherrill [1182d11] * schedsim/shell/shared/main_dump_all_cpus.c (modified) main_dump_all_cpus.c: Return error do not exit Fri, 23 May 2014 21:26:52 GMT Joel Sherrill [44cf36b] * schedsim/shell/schedsim_smpsimple/schedsim.cc (modified) schedsim.cc: Exit on bad command result Fri, 23 May 2014 21:26:28 GMT Joel Sherrill [718b2b6] * schedsim/shell/shared/main_semobtain.c (modified) main_semobtain.c: Locked access to executing Fri, 23 May 2014 19:12:52 GMT Jennifer Averett [fef4882] * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_inherit_priority.scen (added) schedsim_smpsimple: Add cpus4_inherit_priority. Fri, 23 May 2014 19:11:54 GMT Jennifer Averett [70c8ca6] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_block_case1.expected (modified) schedsim_smppriority_affinity: Add expected file for ... Fri, 23 May 2014 16:04:53 GMT Jennifer Averett [2527745] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case3.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case3.scen (added) schedsim_smppriority_affinity: Add a worst case migration scenario. Fri, 23 May 2014 18:46:31 GMT Jennifer Averett [a358713] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_block_case1.scen (moved) schedsim_smppriority_affinity: Fix typo in name. Fri, 23 May 2014 18:42:32 GMT Jennifer Averett [737c775] * schedsim/shell/shared/main_semcreate.c (modified) shared: fix print message in semaphore create. Fri, 23 May 2014 15:57:07 GMT Joel Sherrill [a6a8e11] * schedsim/shell/shared/lookup_task.c (modified) lookup_task.c: Lock around getting executing id. Fri, 23 May 2014 15:56:46 GMT Joel Sherrill [6425eb9] * schedsim/shell/shared/commands.c (modified) commands.c: Include config.h Fri, 23 May 2014 15:24:46 GMT Jennifer Averett [7851bc3] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.scen (modified) schedsim_smppriority_affinity: Change scenario thread name to 4 ... Wed, 21 May 2014 14:40:49 GMT Jennifer Averett [f965428] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.scen (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case1.scen (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case2.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case2.scen (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case3.expected (deleted) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case3.scen (deleted) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case4.expected (deleted) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case4.scen (deleted) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case1.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case1.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case2.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_migrate_case2.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case1.expected (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case1.scen (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case2.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_api_case2.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_block_case1.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_block_case1.scn (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case1.expected (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case1.scen (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case2.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_migrate_case2.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_overlap_case1.expected (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_overlap_case1.scen (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case1.expected (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case1.scen (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case2.expected (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case2.scen (moved) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case3.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_priority_case3.scen (added) schedsim_smppriority_affinity: Cleanup scenarios. Add check of ... Thu, 22 May 2014 20:22:15 GMT Jennifer Averett [b6f5266] * schedsim/shell/shared/main_dump_all_cpus.c (modified) shared: Fix bug in cpu checking of dump all cpus method. Thu, 22 May 2014 22:55:04 GMT Joel Sherrill [c172779] * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) cpu.h: Include sys/cpuset.h so RTEMS tasks.h doesn't have to be modified Thu, 22 May 2014 21:17:48 GMT Joel Sherrill [9372906] * schedsim/shell/shared/main_dump_all_cpus.c (modified) main_dump_all_cpus.c: Stop at end of args or CPUs Thu, 22 May 2014 21:17:25 GMT Joel Sherrill [ff91f4e] * schedsim/shell/shared/lookup_task.c (modified) lookup_task.c: Fix bug where only first four chars of name mattered Thu, 22 May 2014 21:16:05 GMT Joel Sherrill [be883c2] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case1.scen (modified) cpus4_affinity_case1.scen: Add error checking Thu, 22 May 2014 15:19:55 GMT Joel Sherrill [cc1a54a] * schedsim/UsingTheSchedulerSimulator.txt (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/shell/schedsim_smppriority/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/add_commands.c (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/main_dump_all_cpus.c (modified) * schedsim/shell/shared/main_taskcreate.c (modified) Enhance cpus command to do validation of executing threads. This ... Thu, 22 May 2014 15:19:24 GMT Joel Sherrill [4350081] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case1.scen (modified) * schedsim/shell/shared/main_dump_all_cpus.c (moved) cpus4_affinity_case1.scen: Specify affinity in hexadecimal Tue, 20 May 2014 17:34:38 GMT Joel Sherrill [a829f37] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_exercise_affinity_api.scen (modified) cpus4_exercise_affinity_api.scen: Reword comment Tue, 20 May 2014 17:50:18 GMT Jennifer Averett [807b593] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case1.expected (modified) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case2.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case2.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_priority_case1.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_priority_case1.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_priority_case2.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_priority_case2.scen (added) shedsim_smppriority_affinity: Add scenarios. Tue, 20 May 2014 16:41:45 GMT Jennifer Averett [49d5552] * schedsim/shell/shared/include/shell.h (modified) shared: Fix warnings. Tue, 20 May 2014 16:40:44 GMT Jennifer Averett [2ba4b25] * schedsim/shell/schedsim_smpsimple/main_current_cpu.c (modified) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (modified) schedsim_smpsimple: Fix warnings. Mon, 19 May 2014 17:57:12 GMT Jennifer Averett [b4a269a] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case1.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_affinity_case1.scen (added) schedsim_smppriority_affinity: Add overlapping affinity scenario. Fri, 16 May 2014 19:53:51 GMT Jennifer Averett [9f3c8eb] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus1_exercise_affinity_api.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case1.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case1.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case2.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case2.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case3.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case3.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case4.expected (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus2_affinity_case4.scen (added) * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_exercise_affinity_api.expected (added) Add scenarios for setting affinity before start of task. Fri, 16 May 2014 19:46:36 GMT Jennifer Averett [3200227] * schedsim/shell/shared/main_taskcreate.c (modified) schedsim: Add affinity support to task create. Fri, 16 May 2014 19:45:58 GMT Jennifer Averett [08abc0f] * schedsim/shell/shared/main_tasksetaffinity.c (modified) schedsim: Fix affinity error message. Fri, 16 May 2014 19:42:50 GMT Jennifer Averett [fa45079] * schedsim/shell/shared/main_rtemsinit.c (modified) schedsim: Add smp scenario support for a default core set. Thu, 15 May 2014 19:17:15 GMT Jennifer Averett [9d5d371] * schedsim/rtems/Makefile.am (modified) rtems: Account for rtems scheduler modifications Remove enqueue ... Wed, 14 May 2014 14:25:27 GMT Jennifer Averett [5afe319] * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.expected (modified) schedsim_smpsimple: Change scenario to match what the output. Wed, 14 May 2014 14:23:16 GMT Jennifer Averett [66f2b7f] * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_mode.expected (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_mode.scen (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case1.expected (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case1.scen (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case2.expected (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case2.scen (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_nonpreempt_case1.expected (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_nonpreempt_case1.scen (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_nopreempt.expected (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_nopreempt.scen (deleted) schedsim_smpsimple: Remove scenarios that are no longer valid. ... Wed, 14 May 2014 14:55:21 GMT Joel Sherrill [b38dbcc] * schedsim/rtems/debugio.c (modified) * schedsim/rtems/sched_cpu/cpu.c (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) * schedsim/shell/schedsim_priority/config.c (modified) * schedsim/shell/schedsim_priority/printheir_executing.c (modified) * schedsim/shell/schedsim_priority/smp_stub.c (modified) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/config.c (modified) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_all_cpus.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_ready_tasks.c (modified) * schedsim/shell/schedsim_smpsimple/printheir_executing.c (modified) * schedsim/shell/schedsim_smpsimple/smp_stub.c (modified) * schedsim/shell/schedsim_smpsimple/wrap_thread_dispatch.c (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/getopt.c (modified) * schedsim/shell/shared/include/newlib/_ansi.h (modified) * schedsim/shell/shared/include/newlib/getopt.h (modified) * schedsim/shell/shared/lookup_task.c (modified) * schedsim/shell/shared/main_clocktick.c (modified) * schedsim/shell/shared/main_semcreate.c (modified) * schedsim/shell/shared/main_semdelete.c (modified) * schedsim/shell/shared/main_semflush.c (modified) * schedsim/shell/shared/main_semobtain.c (modified) * schedsim/shell/shared/main_semrelease.c (modified) * schedsim/shell/shared/main_taskcreate.c (modified) * schedsim/shell/shared/main_taskdelete.c (modified) * schedsim/shell/shared/main_taskgetaffinity.c (modified) * schedsim/shell/shared/main_taskmode.c (modified) * schedsim/shell/shared/main_taskpriority.c (modified) * schedsim/shell/shared/main_taskresume.c (modified) * schedsim/shell/shared/main_tasksetaffinity.c (modified) * schedsim/shell/shared/main_tasksuspend.c (modified) * schedsim/shell/shared/main_taskwakeafter.c (modified) * schedsim/shell/shared/schedsim_disable_dispatch.c (modified) * schedsim/shell/shared/shell_makeargs.c (modified) Many files: rm white space at EOL and EOF Wed, 14 May 2014 14:25:25 GMT Joel Sherrill [05a8dca] * schedsim/shell/schedsim_smppriority_affinity/scenarios/cpus4_exercise_affinity_api.scen (added) cpus4_exercise_affinity_api.scen: Scenario to exercise affinity Wed, 14 May 2014 14:23:26 GMT Joel Sherrill [156cb91] * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/main_taskgetaffinity.c (added) * schedsim/shell/shared/main_tasksetaffinity.c (added) shell/shared: Add task get/set affinity Wed, 14 May 2014 14:22:08 GMT Joel Sherrill [0caea4a] * schedsim/rtems/Makefile.am (modified) rtems/Makefile.am: Add task get and set affinity Wed, 14 May 2014 13:25:08 GMT Joel Sherrill [57629d2] * schedsim/configure.ac (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/shell/Makefile.am (modified) * schedsim/shell/schedsim_smppriority_affinity/Makefile.am (added) * schedsim/shell/schedsim_smppriority_affinity/config.c (added) schedsim_smppriority_affinity: New simulator instance Wed, 14 May 2014 13:14:48 GMT Joel Sherrill [26560c4] * schedsim/configure.ac (modified) * schedsim/shell/Makefile.am (modified) * schedsim/shell/schedsim_smppriority/Makefile.am (added) * schedsim/shell/schedsim_smppriority/config.c (added) schedsim_smppriority: New simulator instance Wed, 14 May 2014 13:14:23 GMT Joel Sherrill [deadc9a] * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/config.c (modified) schedsim_smpsimple: Clean up Wed, 14 May 2014 13:24:36 GMT Joel Sherrill [3dd3ae6] * schedsim/rtems/sched_cpu/sys/cpuset.h (modified) sys/cpuset.h: CPU_COPY missing on GNU/Linux Wed, 14 May 2014 13:13:59 GMT Joel Sherrill [55b4c3e] * schedsim/rtems/Makefile.am (modified) rtems/Makefile.am: Add schedulersmpvalidstatechanges.c Wed, 14 May 2014 14:23:46 GMT Joel Sherrill [d23e0f0] * schedsim/shell/shared/main_taskpriority.c (modified) main_taskpriority.c: Fix typo Tue, 13 May 2014 15:06:47 GMT Jennifer Averett [9f8d56e] * schedsim/shell/schedsim_smpsimple/config.c (modified) schedsim_smpsimple: Add configure of smp simple scheduler. Tue, 13 May 2014 14:30:12 GMT Jennifer Averett [3ad6235] * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case1.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case2.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_nonpreempt_case1.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_nopreempt.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.scen (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.expected (modified) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.scen (modified) schedsim_smpsimple: Clean up scenarios to match changes. Dispatch ... Fri, 09 May 2014 20:06:50 GMT Joel Sherrill [30aa792] * schedsim/rtems/rtems_init.c (modified) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/wrap_thread_dispatch.c (modified) Now appears to run again Fri, 09 May 2014 16:10:05 GMT Jennifer Averett [35047a1] * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) sched_cpu: add is_executing to context. Fri, 09 May 2014 13:48:38 GMT Jennifer Averett [b552d29] * schedsim/shell/schedsim_smpsimple/smp_stub.c (modified) schedsim_smpsimple: Fix compile error. Thu, 08 May 2014 15:18:14 GMT Jennifer Averett [e4e7cbf] * schedsim/shell/schedsim_smpsimple/printheir_executing.c (modified) schedsim_smpsimple: Fix smp output. Thu, 08 May 2014 15:17:03 GMT Jennifer Averett [49fbe09] * schedsim/shell/schedsim_smpsimple/main_dump_all_cpus.c (modified) schedsim_smpsimple: Fix output of cpu dump. Thu, 08 May 2014 14:53:43 GMT Jennifer Averett [b1b31c0] * schedsim/rtems/wkspace.c (modified) schedsim: turn off workspace debug. Fri, 09 May 2014 13:35:58 GMT Jennifer Averett [2d51251] * schedsim/configure.ac (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/rtems/rtems_init.c (modified) * schedsim/rtems/sched_cpu/cpu.c (modified) * schedsim/rtems/sched_cpu/machine/_default_types.h (added) * schedsim/rtems/sched_cpu/machine/_types.h (added) * schedsim/rtems/sched_cpu/rtems/score/asm.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpuatomic.h (added) * schedsim/rtems/sched_cpu/stdatomic.h (added) * schedsim/rtems/sched_cpu/sys/_types.h (added) * schedsim/rtems/sched_cpu/sys/cpuset.h (added) * schedsim/rtems/sched_cpu/sys/features.h (added) * schedsim/rtems/sched_cpu/sys/lock.h (added) * schedsim/shell/schedsim_priority/smp_stub.c (modified) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/main_current_cpu.c (modified) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_ready_tasks.c (modified) * schedsim/shell/schedsim_smpsimple/smp_stub.c (modified) * schedsim/shell/schedsim_smpsimple/wrap_thread_dispatch.c (modified) schedsim: Add smp support. Thu, 08 May 2014 14:48:26 GMT Jennifer Averett [0745eed] * schedsim/shell/schedsim_priority/scenarios/script01.output (deleted) * schedsim/shell/schedsim_priority/scenarios/script02.output (deleted) * schedsim/shell/schedsim_priority/scenarios/script03.output (deleted) * schedsim/shell/schedsim_priority/scenarios/script04.output (deleted) * schedsim/shell/schedsim_priority/scenarios/script05.output (deleted) * schedsim/shell/schedsim_priority/scenarios/script06.output (deleted) schedsim_priority: Remove scenario output files. Wed, 30 Apr 2014 19:53:29 GMT Joel Sherrill [d13fa72] * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (modified) wrap_thread_dispatch.c: Add missed file Wed, 30 Apr 2014 19:17:04 GMT Joel Sherrill [6d31eca] * schedsim/shell/shared/schedsim_disable_dispatch.c (added) schedsim/shell/shared/schedsim_disable_dispatch.c: New file missed ... Wed, 30 Apr 2014 18:26:53 GMT Joel Sherrill [30430be] * schedsim/shell/shared/Makefile.am (modified) schedsim/shell/shared/Makefile.am: Missed in previous commit Wed, 30 Apr 2014 18:24:50 GMT Joel Sherrill [187d93c] * schedsim/shell/shared/main_semdelete.c (modified) * schedsim/shell/shared/schedsim_shell.h (modified) Allow Scheduler Simulator to "defer dispatch" until controlled This ... Mon, 14 Apr 2014 23:18:34 GMT Joel Sherrill [8703c13] * schedsim/rtems/Makefile.am (modified) * schedsim/rtems/rtems_init.c (modified) Now works uniprocessor with debug enabled Fri, 13 Dec 2013 17:01:48 GMT Joel Sherrill [726b27c] * schedsim/rtems/Makefile.am (modified) * schedsim/rtems/rtems_init.c (modified) * schedsim/rtems/sched_cpu/cpu_asm.c (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpusmplock.h (added) * schedsim/rtems/sched_cpu/rtems/score/types.h (modified) * schedsim/rtems/wkspace.c (modified) * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/smp_stub.c (modified) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_all_cpus.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_ready_tasks.c (modified) * schedsim/shell/schedsim_smpsimple/smp_stub.c (modified) * schedsim/shell/shared/main_rtemsinit.c (modified) * schedsim/shell/shared/schedsim_shell.h (modified) schedsim: Update to latest RTEMS. Works Uniprocessor Mon, 14 Apr 2014 21:50:06 GMT Joel Sherrill [9a34e3a] * .configure.swp (deleted) .configure.swp: Junk file removed from git Fri, 13 Dec 2013 16:54:32 GMT Joel Sherrill [f5f0e30] * .gitignore (modified) .gitignore: Ignore output files Sun, 05 May 2013 16:30:41 GMT Joel Sherrill [d84b7a5] * schedsim/UsingTheSchedulerSimulator.txt (added) UsingTheSchedulerSimulator.txt: New asciidoc Wed, 01 May 2013 16:09:03 GMT Joel Sherrill [4f740d3] * schedsim/shell/schedsim_smpsimple/config.c (modified) schedsim/shell/schedsim_smpsimple/config.c: Disable use of bsp.h Wed, 01 May 2013 16:08:23 GMT Joel Sherrill [dc2edbe] * schedsim/shell/shared/Makefile.am (modified) schedsim/shell/shared/Makefile.am: Add POSIX includes Wed, 01 May 2013 16:08:02 GMT Joel Sherrill [6bc3451] * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) schedsim/shell/schedsim_smpsimple/Makefile.am: Add POSIX includes Wed, 01 May 2013 16:07:47 GMT Joel Sherrill [2c73384] * schedsim/shell/schedsim_priority/Makefile.am (modified) schedsim/shell/schedsim_priority/Makefile.am: Add POSIX includes Wed, 01 May 2013 16:07:22 GMT Joel Sherrill [eeb1494] * schedsim/rtems/Makefile.am (modified) schedsim/rtems/Makefile.am: Add POSIX includes Wed, 01 May 2013 16:05:32 GMT Joel Sherrill [972ce8d] * aclocal/check-posix.m4 (modified) * aclocal/enable-posix.m4 (modified) aclocal/*posix*.m4: Change so POSIX can be Enabled The real RTEMS ... Wed, 01 May 2013 16:04:22 GMT Joel Sherrill [ec622ba] * aclocal/check-smp.m4 (modified) * aclocal/enable-smp.m4 (modified) alocal/*smp*.m4: Change so SMP can be enabled on Scheduler Simulator ... Wed, 01 May 2013 00:42:34 GMT Joel Sherrill [2c98493] * SUPPORT (modified) SUPPORT: Fix phone number Wed, 01 May 2013 00:41:56 GMT Joel Sherrill [a2aad55] * LICENSE (modified) * Makefile.am (modified) * README (modified) * SUPPORT (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/check-smp.m4 (modified) * aclocal/enable-rtemsdir.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) * automake/host.am (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * configure.ac (modified) * schedsim/Makefile.am (modified) * schedsim/README (modified) * schedsim/configure.ac (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/rtems/debugio.c (modified) * schedsim/rtems/interr.c (modified) * schedsim/rtems/rtems_init.c (modified) * schedsim/rtems/rtems_sched.h (modified) * schedsim/rtems/sched_cpu/cpu.c (modified) * schedsim/rtems/sched_cpu/cpu_asm.c (modified) * schedsim/rtems/sched_cpu/rtems/asm.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h (modified) * schedsim/rtems/sched_cpu/rtems/score/no_cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/types.h (modified) * schedsim/rtems/wkspace.c (modified) * schedsim/shell/Makefile.am (modified) * schedsim/shell/run_scenarios (modified) * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/printheir_executing.c (modified) * schedsim/shell/schedsim_priority/schedsim.cc (modified) * schedsim/shell/schedsim_priority/smp_stub.c (modified) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) * schedsim/shell/schedsim_smpsimple/README (modified) * schedsim/shell/schedsim_smpsimple/TODO (modified) * schedsim/shell/schedsim_smpsimple/add_commands.c (modified) * schedsim/shell/schedsim_smpsimple/config.c (modified) * schedsim/shell/schedsim_smpsimple/main_current_cpu.c (modified) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_all_cpus.c (modified) * schedsim/shell/schedsim_smpsimple/main_dump_ready_tasks.c (modified) * schedsim/shell/schedsim_smpsimple/printheir_executing.c (modified) * schedsim/shell/schedsim_smpsimple/schedsim.cc (modified) * schedsim/shell/schedsim_smpsimple/smp_stub.c (modified) * schedsim/shell/schedsim_smpsimple/wrap_thread_dispatch.c (modified) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/commands.c (modified) * schedsim/shell/shared/include/rtems/confdefs.h (modified) * schedsim/shell/shared/include/shell.h (modified) * schedsim/shell/shared/lookup_semaphore.c (modified) * schedsim/shell/shared/lookup_task.c (modified) * schedsim/shell/shared/main_clocktick.c (modified) * schedsim/shell/shared/main_echo.c (modified) * schedsim/shell/shared/main_executing.c (modified) * schedsim/shell/shared/main_heir.c (modified) * schedsim/shell/shared/main_help.c (modified) * schedsim/shell/shared/main_rtemsinit.c (modified) * schedsim/shell/shared/main_semcreate.c (modified) * schedsim/shell/shared/main_semdelete.c (modified) * schedsim/shell/shared/main_semflush.c (modified) * schedsim/shell/shared/main_semobtain.c (modified) * schedsim/shell/shared/main_semrelease.c (modified) * schedsim/shell/shared/main_taskcreate.c (modified) * schedsim/shell/shared/main_taskdelete.c (modified) * schedsim/shell/shared/main_taskmode.c (modified) * schedsim/shell/shared/main_taskpriority.c (modified) * schedsim/shell/shared/main_taskresume.c (modified) * schedsim/shell/shared/main_tasksuspend.c (modified) * schedsim/shell/shared/main_taskwakeafter.c (modified) * schedsim/shell/shared/schedsim_shell.h (modified) * schedsim/shell/shared/shell_cmdset.c (modified) * schedsim/shell/shared/shell_makeargs.c (modified) Remove CVS $ Wed, 01 May 2013 00:33:31 GMT Joel Sherrill [40cadee] * aclocal/bsp-alias.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rtems-debug.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-smp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/path-ksh.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) aclocal/*.m4: Update from RTEMS Wed, 01 May 2013 00:06:53 GMT Joel Sherrill [7c50462] * schedsim/shell/schedsim_priority/config.c (modified) schedsim_priority/config.c: Disable use of bsp.h Wed, 01 May 2013 00:06:22 GMT Joel Sherrill [957ce33] * schedsim/rtems/wkspace.c (modified) schedsim/rtems/wkspace.c: Update to match current prototype Wed, 01 May 2013 00:05:53 GMT Joel Sherrill [caee146] * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) schedsim/.../cpu.h: Account for new types and methods
