# # ChangeLog for / in rtems-schedsim # # Generated by Trac 1.2.1.dev0 # 03/28/24 20:14:36 Wed, 01 May 2013 00:02:44 GMT Joel Sherrill [189bbf4] * .cvsignore (deleted) * schedsim/.cvsignore (deleted) * schedsim/rtems/.cvsignore (deleted) * schedsim/shell/.cvsignore (deleted) * schedsim/shell/schedsim_priority/.cvsignore (deleted) * schedsim/shell/schedsim_smpsimple/.cvsignore (deleted) * schedsim/shell/schedsim_smpsimple/scenarios/.cvsignore (deleted) * schedsim/shell/shared/.cvsignore (deleted) .cvsignore: Remove all Wed, 01 May 2013 00:02:21 GMT Joel Sherrill [d24f2bd] * .gitignore (added) .gitignore: New file Wed, 06 Jul 2011 18:10:43 GMT Joel Sherrill [97d5402] * ChangeLog (modified) * aclocal/check-multiprocessing.m4 (added) * aclocal/check-networking.m4 (added) * aclocal/check-posix.m4 (added) * aclocal/check-smp.m4 (added) * aclocal/env-rtemscpu.m4 (added) 2011-07-06 Joel Sherrill * ... Tue, 28 Jun 2011 18:43:12 GMT Joel Sherrill [5686d7d] * schedsim/shell/ChangeLog (modified) * schedsim/shell/run_scenarios (modified) 2011-06-28 Joel Sherrill * ... Tue, 28 Jun 2011 18:42:44 GMT Joel Sherrill [1b4b1d9] * schedsim/shell/schedsim_smpsimple/ChangeLog (modified) * schedsim/shell/schedsim_smpsimple/Makefile.am (modified) 2011-06-28 Joel Sherrill * ... Tue, 28 Jun 2011 18:42:31 GMT Joel Sherrill [1cbbaef] * schedsim/shell/schedsim_priority/ChangeLog (modified) * schedsim/shell/schedsim_priority/Makefile.am (modified) 2011-06-28 Joel Sherrill * ... Thu, 23 Jun 2011 20:28:41 GMT Joel Sherrill [c552573] * schedsim/shell/ChangeLog (modified) * schedsim/shell/run_scenarios (modified) 2011-06-23 Joel Sherrill * ... Mon, 20 Jun 2011 18:51:12 GMT Joel Sherrill [891513f] * schedsim/rtems/ChangeLog (modified) * schedsim/rtems/Makefile.am (modified) 2011-06-20 Joel Sherrill * ... Tue, 17 May 2011 19:31:33 GMT Joel Sherrill [23f57af] * .cvsignore (added) * ChangeLog (modified) * aclocal/enable-smp.m4 (modified) * configure.ac (modified) 2011-05-17 Joel Sherrill * ... Tue, 17 May 2011 19:31:26 GMT Joel Sherrill [f7494ad] * schedsim/ChangeLog (modified) * schedsim/acinclude.m4 (added) * schedsim/configure.ac (modified) 2011-05-17 Joel Sherrill * ... Tue, 17 May 2011 19:31:24 GMT Joel Sherrill [aebb1ca] * schedsim/rtems/ChangeLog (modified) * schedsim/rtems/Makefile.am (modified) * schedsim/rtems/debugio.c (added) * schedsim/rtems/rtems_init.c (modified) * schedsim/rtems/sched_cpu/cpu.c (modified) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (modified) * schedsim/rtems/sched_cpu/rtems/score/cpuopts.h (deleted) 2011-05-17 Joel Sherrill * ... Tue, 17 May 2011 19:31:16 GMT Joel Sherrill [ac6e5c7] * schedsim/shell/ChangeLog (modified) * schedsim/shell/Makefile.am (modified) * schedsim/shell/run_scenarios (added) * schedsim/shell/shared/Makefile.am (modified) * schedsim/shell/shared/include/rtems/confdefs.h (added) * schedsim/shell/shared/lookup_task.c (modified) * schedsim/shell/shared/main_clocktick.c (modified) * schedsim/shell/shared/main_rtemsinit.c (modified) * schedsim/shell/shared/main_taskcreate.c (modified) * schedsim/shell/shared/main_taskmode.c (modified) 2011-05-17 Joel Sherrill * ... Tue, 17 May 2011 19:31:12 GMT Joel Sherrill [f40778b] * schedsim/shell/schedsim_smpsimple/.cvsignore (added) * schedsim/shell/schedsim_smpsimple/ChangeLog (added) * schedsim/shell/schedsim_smpsimple/Makefile.am (added) * schedsim/shell/schedsim_smpsimple/README (added) * schedsim/shell/schedsim_smpsimple/TODO (added) * schedsim/shell/schedsim_smpsimple/add_commands.c (added) * schedsim/shell/schedsim_smpsimple/config.c (added) * schedsim/shell/schedsim_smpsimple/main_current_cpu.c (added) * schedsim/shell/schedsim_smpsimple/main_dispatch.c (added) * schedsim/shell/schedsim_smpsimple/main_dump_all_cpus.c (added) * schedsim/shell/schedsim_smpsimple/main_dump_ready_tasks.c (added) * schedsim/shell/schedsim_smpsimple/printheir_executing.c (added) * schedsim/shell/schedsim_smpsimple/scenarios/.cvsignore (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_mode.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_mode.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_priority.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_resume_on_primary.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus1_suspend_on_primary.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case1.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case1.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case2.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_mode_case2.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_nonpreempt_case1.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_nonpreempt_case1.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_pick_older.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_priority.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_nopreempt.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_nopreempt.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_simple_preemption.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_all.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_primary.scen (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.expected (added) * schedsim/shell/schedsim_smpsimple/scenarios/cpus4_suspend_on_secondary.scen (added) * schedsim/shell/schedsim_smpsimple/schedsim.cc (added) * schedsim/shell/schedsim_smpsimple/smp_stub.c (added) * schedsim/shell/schedsim_smpsimple/wrap_thread_dispatch.c (added) 2011-05-17 Joel Sherrill * ... Tue, 17 May 2011 19:31:08 GMT Joel Sherrill [9077d3c] * schedsim/shell/schedsim_priority/ChangeLog (added) * schedsim/shell/schedsim_priority/Makefile.am (modified) * schedsim/shell/schedsim_priority/scenarios/script01.expected (added) * schedsim/shell/schedsim_priority/scenarios/script01.output (added) * schedsim/shell/schedsim_priority/scenarios/script01.scen (moved) * schedsim/shell/schedsim_priority/scenarios/script02.expected (added) * schedsim/shell/schedsim_priority/scenarios/script02.output (added) * schedsim/shell/schedsim_priority/scenarios/script02.scen (moved) * schedsim/shell/schedsim_priority/scenarios/script03.expected (added) * schedsim/shell/schedsim_priority/scenarios/script03.output (added) * schedsim/shell/schedsim_priority/scenarios/script03.scen (moved) * schedsim/shell/schedsim_priority/scenarios/script04.expected (added) * schedsim/shell/schedsim_priority/scenarios/script04.output (added) * schedsim/shell/schedsim_priority/scenarios/script04.scen (moved) * schedsim/shell/schedsim_priority/scenarios/script05.expected (added) * schedsim/shell/schedsim_priority/scenarios/script05.output (added) * schedsim/shell/schedsim_priority/scenarios/script05.scen (moved) * schedsim/shell/schedsim_priority/scenarios/script06.expected (added) * schedsim/shell/schedsim_priority/scenarios/script06.output (added) * schedsim/shell/schedsim_priority/scenarios/script06.scen (moved) * schedsim/shell/schedsim_priority/smp_stub.c (added) 2011-05-17 Joel Sherrill * ... Mon, 25 Apr 2011 15:56:05 GMT Joel Sherrill [5edfbf8] * ChangeLog (added) * README (added) 2011-04-25 Joel Sherrill * ... Mon, 25 Apr 2011 15:53:10 GMT Joel Sherrill [ee9e674] This commit was generated by cvs2svn to compensate for changes in r2, ... Mon, 25 Apr 2011 15:53:10 GMT Joel Sherrill [abb18dc] * .configure.swp (added) * LICENSE (added) * Makefile.am (added) * SUPPORT (added) * VERSION (added) * acinclude.m4 (added) * aclocal/bsp-alias.m4 (added) * aclocal/canonical-target-name.m4 (added) * aclocal/check-bsps.m4 (added) * aclocal/check-custom-bsp.m4 (added) * aclocal/enable-cxx.m4 (added) * aclocal/enable-multiprocessing.m4 (added) * aclocal/enable-networking.m4 (added) * aclocal/enable-posix.m4 (added) * aclocal/enable-rtems-debug.m4 (added) * aclocal/enable-rtemsbsp.m4 (added) * aclocal/enable-rtemsdir.m4 (added) * aclocal/enable-smp.m4 (added) * aclocal/enable-tests.m4 (added) * aclocal/multilib.m4 (added) * aclocal/path-ksh.m4 (added) * aclocal/project-root.m4 (added) * aclocal/quoting.m4 (added) * aclocal/rpm.m4 (added) * aclocal/rtems-top.m4 (added) * aclocal/tool-paths.m4 (added) * aclocal/version.m4 (added) * automake/host.am (added) * automake/local.am (added) * automake/subdirs.am (added) * configure.ac (added) * schedsim/.cvsignore (added) * schedsim/ChangeLog (added) * schedsim/Makefile.am (added) * schedsim/README (added) * schedsim/configure.ac (added) * schedsim/rtems/.cvsignore (added) * schedsim/rtems/ChangeLog (added) * schedsim/rtems/Makefile.am (added) * schedsim/rtems/interr.c (added) * schedsim/rtems/rtems_init.c (added) * schedsim/rtems/rtems_sched.h (added) * schedsim/rtems/sched_cpu/cpu.c (added) * schedsim/rtems/sched_cpu/cpu_asm.c (added) * schedsim/rtems/sched_cpu/rtems/asm.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpu.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h (added) * schedsim/rtems/sched_cpu/rtems/score/cpuopts.h (added) * schedsim/rtems/sched_cpu/rtems/score/no_cpu.h (added) * schedsim/rtems/sched_cpu/rtems/score/types.h (added) * schedsim/rtems/sched_cpu/rtems/stringto.h (added) * schedsim/rtems/wkspace.c (added) * schedsim/shell/.cvsignore (added) * schedsim/shell/ChangeLog (added) * schedsim/shell/Makefile.am (added) * schedsim/shell/schedsim_priority/.cvsignore (added) * schedsim/shell/schedsim_priority/Makefile.am (added) * schedsim/shell/schedsim_priority/config.c (added) * schedsim/shell/schedsim_priority/printheir_executing.c (added) * schedsim/shell/schedsim_priority/scenarios/script01 (added) * schedsim/shell/schedsim_priority/scenarios/script02 (added) * schedsim/shell/schedsim_priority/scenarios/script03 (added) * schedsim/shell/schedsim_priority/scenarios/script04 (added) * schedsim/shell/schedsim_priority/scenarios/script05 (added) * schedsim/shell/schedsim_priority/scenarios/script06 (added) * schedsim/shell/schedsim_priority/schedsim.cc (added) * schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (added) * schedsim/shell/shared/.cvsignore (added) * schedsim/shell/shared/Makefile.am (added) * schedsim/shell/shared/commands.c (added) * schedsim/shell/shared/getopt.c (added) * schedsim/shell/shared/include/newlib/_ansi.h (added) * schedsim/shell/shared/include/newlib/getopt.h (added) * schedsim/shell/shared/include/shell.h (added) * schedsim/shell/shared/lookup_semaphore.c (added) * schedsim/shell/shared/lookup_task.c (added) * schedsim/shell/shared/main_clocktick.c (added) * schedsim/shell/shared/main_echo.c (added) * schedsim/shell/shared/main_executing.c (added) * schedsim/shell/shared/main_heir.c (added) * schedsim/shell/shared/main_help.c (added) * schedsim/shell/shared/main_rtemsinit.c (added) * schedsim/shell/shared/main_semcreate.c (added) * schedsim/shell/shared/main_semdelete.c (added) * schedsim/shell/shared/main_semflush.c (added) * schedsim/shell/shared/main_semobtain.c (added) * schedsim/shell/shared/main_semrelease.c (added) * schedsim/shell/shared/main_taskcreate.c (added) * schedsim/shell/shared/main_taskdelete.c (added) * schedsim/shell/shared/main_taskmode.c (added) * schedsim/shell/shared/main_taskpriority.c (added) * schedsim/shell/shared/main_taskresume.c (added) * schedsim/shell/shared/main_tasksuspend.c (added) * schedsim/shell/shared/main_taskwakeafter.c (added) * schedsim/shell/shared/schedsim_shell.h (added) * schedsim/shell/shared/shell_cmdset.c (added) * schedsim/shell/shared/shell_makeargs.c (added) Initial import.
