# # ChangeLog for rtems-release-docs in rtems-release # # Generated by Trac 1.2.1.dev0 # 05/17/24 19:47:03 Mon, 31 Oct 2016 18:07:13 GMT Chris Johns [e375d9d] * rtems-release-docs (modified) Remove clean up, this is done at a higher level. Mon, 31 Oct 2016 18:04:18 GMT Chris Johns [59c9105] * rtems-release (modified) * rtems-release-defaults-4.10 (modified) * rtems-release-docs (modified) Build and packages docs. Sun, 04 Sep 2016 00:45:52 GMT Chris Johns [97cc04c] * .gitignore (added) * README.txt (added) * README.txt.in (added) * rtems-release (added) * rtems-release-docs (added) * rtems-release-kernel (added) * rtems-release-package (added) * rtems-release-package-end (added) * rtems-release-package-start (added) * rtems-release-rsb-hashing (added) * rtems-release-sources (added) * rtems-source-packages (added) Initial addition of the RTEMS releasing scripts.
