# # ChangeLog for waf_generator.py in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/16/24 20:33:38 Tue, 16 Jun 2015 23:55:53 GMT Chris Johns [98d7c3c] * waf_generator.py (modified) * wscript (modified) Check if RTEMS is built with POSIX. Mon, 15 Jun 2015 07:42:23 GMT Chris Johns [8440506] * Makefile (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * freebsd/contrib/libpcap/arcnet.h (added) * freebsd/contrib/libpcap/atmuni31.h (added) * freebsd/contrib/libpcap/bpf_image.c (added) * freebsd/contrib/libpcap/etherent.c (added) * freebsd/contrib/libpcap/ethertype.h (added) * freebsd/contrib/libpcap/fad-getad.c (added) * freebsd/contrib/libpcap/gencode.c (added) * freebsd/contrib/libpcap/gencode.h (added) * freebsd/contrib/libpcap/grammar.c (added) * freebsd/contrib/libpcap/grammar.y (added) * freebsd/contrib/libpcap/ieee80211.h (added) * freebsd/contrib/libpcap/inet.c (added) * freebsd/contrib/libpcap/llc.h (added) * freebsd/contrib/libpcap/nametoaddr.c (added) * freebsd/contrib/libpcap/nlpid.h (added) * freebsd/contrib/libpcap/optimize.c (added) * freebsd/contrib/libpcap/pcap-bpf.c (added) * freebsd/contrib/libpcap/pcap-common.c (added) * freebsd/contrib/libpcap/pcap-common.h (added) * freebsd/contrib/libpcap/pcap-int.h (added) * freebsd/contrib/libpcap/pcap-namedb.h (added) * freebsd/contrib/libpcap/pcap.c (added) * freebsd/contrib/libpcap/pcap.h (added) * freebsd/contrib/libpcap/pcap/ipnet.h (added) * freebsd/contrib/libpcap/pcap/namedb.h (added) * freebsd/contrib/libpcap/pcap/pcap.h (added) * freebsd/contrib/libpcap/pcap/sll.h (added) * freebsd/contrib/libpcap/pcap/usb.h (added) * freebsd/contrib/libpcap/ppp.h (added) * freebsd/contrib/libpcap/savefile.c (added) * freebsd/contrib/libpcap/scanner.c (added) * freebsd/contrib/libpcap/scanner.l (added) * freebsd/contrib/libpcap/sf-pcap-ng.c (added) * freebsd/contrib/libpcap/sf-pcap-ng.h (added) * freebsd/contrib/libpcap/sf-pcap.c (added) * freebsd/contrib/libpcap/sf-pcap.h (added) * freebsd/contrib/libpcap/sunatmpos.h (added) * freebsd/contrib/tcpdump/addrtoname.c (added) * freebsd/contrib/tcpdump/addrtoname.h (added) * freebsd/contrib/tcpdump/af.c (added) * freebsd/contrib/tcpdump/af.h (added) * freebsd/contrib/tcpdump/ah.h (added) * freebsd/contrib/tcpdump/aodv.h (added) * freebsd/contrib/tcpdump/appletalk.h (added) * freebsd/contrib/tcpdump/arcnet.h (added) * freebsd/contrib/tcpdump/atm.h (added) * freebsd/contrib/tcpdump/bgp.h (added) * freebsd/contrib/tcpdump/bootp.h (added) * freebsd/contrib/tcpdump/bpf_dump.c (added) * freebsd/contrib/tcpdump/chdlc.h (added) * freebsd/contrib/tcpdump/checksum.c (added) * freebsd/contrib/tcpdump/cpack.c (added) * freebsd/contrib/tcpdump/cpack.h (added) * freebsd/contrib/tcpdump/dccp.h (added) * freebsd/contrib/tcpdump/decnet.h (added) * freebsd/contrib/tcpdump/decode_prefix.h (added) * freebsd/contrib/tcpdump/enc.h (added) * freebsd/contrib/tcpdump/esp.h (added) * freebsd/contrib/tcpdump/ether.h (added) * freebsd/contrib/tcpdump/ethertype.h (added) * freebsd/contrib/tcpdump/extract.h (added) * freebsd/contrib/tcpdump/fddi.h (added) * freebsd/contrib/tcpdump/forces.h (added) * freebsd/contrib/tcpdump/gmpls.c (added) * freebsd/contrib/tcpdump/gmpls.h (added) * freebsd/contrib/tcpdump/gmt2local.c (added) * freebsd/contrib/tcpdump/gmt2local.h (added) * freebsd/contrib/tcpdump/icmp6.h (added) * freebsd/contrib/tcpdump/ieee802_11.h (added) * freebsd/contrib/tcpdump/ieee802_11_radio.h (added) * freebsd/contrib/tcpdump/igrp.h (added) * freebsd/contrib/tcpdump/in_cksum.c (added) * freebsd/contrib/tcpdump/interface.h (added) * freebsd/contrib/tcpdump/ip.h (added) * freebsd/contrib/tcpdump/ip6.h (added) * freebsd/contrib/tcpdump/ipfc.h (added) * freebsd/contrib/tcpdump/ipnet.h (added) * freebsd/contrib/tcpdump/ipproto.c (added) * freebsd/contrib/tcpdump/ipproto.h (added) * freebsd/contrib/tcpdump/ipsec_doi.h (added) * freebsd/contrib/tcpdump/ipx.h (added) * freebsd/contrib/tcpdump/isakmp.h (added) * freebsd/contrib/tcpdump/l2tp.h (added) * freebsd/contrib/tcpdump/l2vpn.c (added) * freebsd/contrib/tcpdump/l2vpn.h (added) * freebsd/contrib/tcpdump/lane.h (added) * freebsd/contrib/tcpdump/llc.h (added) * freebsd/contrib/tcpdump/machdep.c (added) * freebsd/contrib/tcpdump/machdep.h (added) * freebsd/contrib/tcpdump/mib.h (added) * freebsd/contrib/tcpdump/mpls.h (added) * freebsd/contrib/tcpdump/nameser.h (added) * freebsd/contrib/tcpdump/netbios.h (added) * freebsd/contrib/tcpdump/netdissect.h (added) * freebsd/contrib/tcpdump/nfs.h (added) * freebsd/contrib/tcpdump/nfsfh.h (added) * freebsd/contrib/tcpdump/nlpid.c (added) * freebsd/contrib/tcpdump/nlpid.h (added) * freebsd/contrib/tcpdump/ntp.h (added) * freebsd/contrib/tcpdump/oakley.h (added) * freebsd/contrib/tcpdump/ospf.h (added) * freebsd/contrib/tcpdump/ospf6.h (added) * freebsd/contrib/tcpdump/oui.c (added) * freebsd/contrib/tcpdump/oui.h (added) * freebsd/contrib/tcpdump/parsenfsfh.c (added) * freebsd/contrib/tcpdump/pcap-missing.h (added) * freebsd/contrib/tcpdump/pmap_prot.h (added) * freebsd/contrib/tcpdump/ppi.h (added) * freebsd/contrib/tcpdump/ppp.h (added) * freebsd/contrib/tcpdump/print-802_11.c (added) * freebsd/contrib/tcpdump/print-802_15_4.c (added) * freebsd/contrib/tcpdump/print-ah.c (added) * freebsd/contrib/tcpdump/print-aodv.c (added) * freebsd/contrib/tcpdump/print-ap1394.c (added) * freebsd/contrib/tcpdump/print-arcnet.c (added) * freebsd/contrib/tcpdump/print-arp.c (added) * freebsd/contrib/tcpdump/print-ascii.c (added) * freebsd/contrib/tcpdump/print-atalk.c (added) * freebsd/contrib/tcpdump/print-atm.c (added) * freebsd/contrib/tcpdump/print-babel.c (added) * freebsd/contrib/tcpdump/print-beep.c (added) * freebsd/contrib/tcpdump/print-bfd.c (added) * freebsd/contrib/tcpdump/print-bgp.c (added) * freebsd/contrib/tcpdump/print-bootp.c (added) * freebsd/contrib/tcpdump/print-bt.c (added) * freebsd/contrib/tcpdump/print-carp.c (added) * freebsd/contrib/tcpdump/print-cdp.c (added) * freebsd/contrib/tcpdump/print-cfm.c (added) * freebsd/contrib/tcpdump/print-chdlc.c (added) * freebsd/contrib/tcpdump/print-cip.c (added) * freebsd/contrib/tcpdump/print-cnfp.c (added) * freebsd/contrib/tcpdump/print-dccp.c (added) * freebsd/contrib/tcpdump/print-decnet.c (added) * freebsd/contrib/tcpdump/print-dhcp6.c (added) * freebsd/contrib/tcpdump/print-domain.c (added) * freebsd/contrib/tcpdump/print-dtp.c (added) * freebsd/contrib/tcpdump/print-dvmrp.c (added) * freebsd/contrib/tcpdump/print-eap.c (added) * freebsd/contrib/tcpdump/print-egp.c (added) * freebsd/contrib/tcpdump/print-eigrp.c (added) * freebsd/contrib/tcpdump/print-enc.c (added) * freebsd/contrib/tcpdump/print-esp.c (added) * freebsd/contrib/tcpdump/print-ether.c (added) * freebsd/contrib/tcpdump/print-fddi.c (added) * freebsd/contrib/tcpdump/print-forces.c (added) * freebsd/contrib/tcpdump/print-fr.c (added) * freebsd/contrib/tcpdump/print-frag6.c (added) * freebsd/contrib/tcpdump/print-gre.c (added) * freebsd/contrib/tcpdump/print-hsrp.c (added) * freebsd/contrib/tcpdump/print-icmp.c (added) * freebsd/contrib/tcpdump/print-icmp6.c (added) * freebsd/contrib/tcpdump/print-igmp.c (added) * freebsd/contrib/tcpdump/print-igrp.c (added) * freebsd/contrib/tcpdump/print-ip.c (added) * freebsd/contrib/tcpdump/print-ip6.c (added) * freebsd/contrib/tcpdump/print-ip6opts.c (added) * freebsd/contrib/tcpdump/print-ipcomp.c (added) * freebsd/contrib/tcpdump/print-ipfc.c (added) * freebsd/contrib/tcpdump/print-ipnet.c (added) * freebsd/contrib/tcpdump/print-ipx.c (added) * freebsd/contrib/tcpdump/print-isakmp.c (added) * freebsd/contrib/tcpdump/print-isoclns.c (added) * freebsd/contrib/tcpdump/print-juniper.c (added) * freebsd/contrib/tcpdump/print-krb.c (added) * freebsd/contrib/tcpdump/print-l2tp.c (added) * freebsd/contrib/tcpdump/print-lane.c (added) * freebsd/contrib/tcpdump/print-ldp.c (added) * freebsd/contrib/tcpdump/print-llc.c (added) * freebsd/contrib/tcpdump/print-lldp.c (added) * freebsd/contrib/tcpdump/print-lmp.c (added) * freebsd/contrib/tcpdump/print-lspping.c (added) * freebsd/contrib/tcpdump/print-lwapp.c (added) * freebsd/contrib/tcpdump/print-lwres.c (added) * freebsd/contrib/tcpdump/print-mobile.c (added) * freebsd/contrib/tcpdump/print-mobility.c (added) * freebsd/contrib/tcpdump/print-mpcp.c (added) * freebsd/contrib/tcpdump/print-mpls.c (added) * freebsd/contrib/tcpdump/print-msdp.c (added) * freebsd/contrib/tcpdump/print-msnlb.c (added) * freebsd/contrib/tcpdump/print-netbios.c (added) * freebsd/contrib/tcpdump/print-nfs.c (added) * freebsd/contrib/tcpdump/print-ntp.c (added) * freebsd/contrib/tcpdump/print-null.c (added) * freebsd/contrib/tcpdump/print-olsr.c (added) * freebsd/contrib/tcpdump/print-ospf.c (added) * freebsd/contrib/tcpdump/print-ospf6.c (added) * freebsd/contrib/tcpdump/print-otv.c (added) * freebsd/contrib/tcpdump/print-pflog.c (added) * freebsd/contrib/tcpdump/print-pfsync.c (added) * freebsd/contrib/tcpdump/print-pgm.c (added) * freebsd/contrib/tcpdump/print-pim.c (added) * freebsd/contrib/tcpdump/print-ppi.c (added) * freebsd/contrib/tcpdump/print-ppp.c (added) * freebsd/contrib/tcpdump/print-pppoe.c (added) * freebsd/contrib/tcpdump/print-pptp.c (added) * freebsd/contrib/tcpdump/print-radius.c (added) * freebsd/contrib/tcpdump/print-raw.c (added) * freebsd/contrib/tcpdump/print-rip.c (added) * freebsd/contrib/tcpdump/print-ripng.c (added) * freebsd/contrib/tcpdump/print-rpki-rtr.c (added) * freebsd/contrib/tcpdump/print-rrcp.c (added) * freebsd/contrib/tcpdump/print-rsvp.c (added) * freebsd/contrib/tcpdump/print-rt6.c (added) * freebsd/contrib/tcpdump/print-rx.c (added) * freebsd/contrib/tcpdump/print-sctp.c (added) * freebsd/contrib/tcpdump/print-sflow.c (added) * freebsd/contrib/tcpdump/print-sip.c (added) * freebsd/contrib/tcpdump/print-sl.c (added) * freebsd/contrib/tcpdump/print-sll.c (added) * freebsd/contrib/tcpdump/print-slow.c (added) * freebsd/contrib/tcpdump/print-smb.c (added) * freebsd/contrib/tcpdump/print-snmp.c (added) * freebsd/contrib/tcpdump/print-stp.c (added) * freebsd/contrib/tcpdump/print-sunatm.c (added) * freebsd/contrib/tcpdump/print-sunrpc.c (added) * freebsd/contrib/tcpdump/print-symantec.c (added) * freebsd/contrib/tcpdump/print-syslog.c (added) * freebsd/contrib/tcpdump/print-tcp.c (added) * freebsd/contrib/tcpdump/print-telnet.c (added) * freebsd/contrib/tcpdump/print-tftp.c (added) * freebsd/contrib/tcpdump/print-timed.c (added) * freebsd/contrib/tcpdump/print-tipc.c (added) * freebsd/contrib/tcpdump/print-token.c (added) * freebsd/contrib/tcpdump/print-udld.c (added) * freebsd/contrib/tcpdump/print-udp.c (added) * freebsd/contrib/tcpdump/print-usb.c (added) * freebsd/contrib/tcpdump/print-vjc.c (added) * freebsd/contrib/tcpdump/print-vqp.c (added) * freebsd/contrib/tcpdump/print-vrrp.c (added) * freebsd/contrib/tcpdump/print-vtp.c (added) * freebsd/contrib/tcpdump/print-vxlan.c (added) * freebsd/contrib/tcpdump/print-wb.c (added) * freebsd/contrib/tcpdump/print-zephyr.c (added) * freebsd/contrib/tcpdump/print-zeromq.c (added) * freebsd/contrib/tcpdump/route6d.h (added) * freebsd/contrib/tcpdump/rpc_auth.h (added) * freebsd/contrib/tcpdump/rpc_msg.h (added) * freebsd/contrib/tcpdump/rx.h (added) * freebsd/contrib/tcpdump/sctpConstants.h (added) * freebsd/contrib/tcpdump/sctpHeader.h (added) * freebsd/contrib/tcpdump/setsignal.c (added) * freebsd/contrib/tcpdump/setsignal.h (added) * freebsd/contrib/tcpdump/signature.c (added) * freebsd/contrib/tcpdump/signature.h (added) * freebsd/contrib/tcpdump/slcompress.h (added) * freebsd/contrib/tcpdump/slip.h (added) * freebsd/contrib/tcpdump/sll.h (added) * freebsd/contrib/tcpdump/smb.h (added) * freebsd/contrib/tcpdump/smbutil.c (added) * freebsd/contrib/tcpdump/tcp.h (added) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (added) * freebsd/contrib/tcpdump/tcpdump.c (added) * freebsd/contrib/tcpdump/telnet.h (added) * freebsd/contrib/tcpdump/tftp.h (added) * freebsd/contrib/tcpdump/timed.h (added) * freebsd/contrib/tcpdump/token.h (added) * freebsd/contrib/tcpdump/udp.h (added) * freebsd/contrib/tcpdump/util.c (added) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (added) * libbsd.py (modified) * makefile.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * waf_generator.py (modified) * wscript (modified) Add tcpdump and libpcap. - Update the file builder generator to ... Wed, 27 May 2015 00:42:28 GMT Chris Johns [1383c80] * Makefile (modified) * makefile.py (modified) * rtemsbsd/rtems/rtems-bsd-pci_bus.c (modified) * rtemsbsd/rtems/rtems-bsd-pci_cfgreg.c (modified) * waf_generator.py (modified) * wscript (modified) Add conditional support for RTEMS PCI to the waf build. Check for ... Fri, 22 May 2015 02:18:31 GMT Chris Johns [84288f4] * waf_generator.py (modified) * wscript (modified) waf: Check for dlfcn.h header is availavble. Thu, 21 May 2015 07:01:34 GMT Chris Johns [0768880] * builder.py (modified) * rtemsbsd/include/dlfcn.h (deleted) * waf_generator.py (modified) * wscript (modified) waf: Add install support. Install to the --prefix path passed to ... Wed, 20 May 2015 23:30:28 GMT Chris Johns [4963785] * waf_generator.py (modified) waf: Add network configuration support. Add support to parse the ... Wed, 20 May 2015 11:59:15 GMT Chris Johns [e9aa9537] * builder.py (modified) * waf_generator.py (modified) waf: Add warnings and auto-regen options. Wed, 20 May 2015 07:45:16 GMT Chris Johns [5ba6949] * .gitignore (modified) * .gitmodules (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * rtems_waf (added) * waf_generator.py (added) Add support to build using waf.
