# # ChangeLog for waf_generator.py in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/20/24 01:41:13 Wed, 27 May 2015 00:42:28 GMT Chris Johns [1383c80] * Makefile (modified) * makefile.py (modified) * rtemsbsd/rtems/rtems-bsd-pci_bus.c (modified) * rtemsbsd/rtems/rtems-bsd-pci_cfgreg.c (modified) * waf_generator.py (modified) * wscript (modified) Add conditional support for RTEMS PCI to the waf build. Check for ... Fri, 22 May 2015 02:18:31 GMT Chris Johns [84288f4] * waf_generator.py (modified) * wscript (modified) waf: Check for dlfcn.h header is availavble. Thu, 21 May 2015 07:01:34 GMT Chris Johns [0768880] * builder.py (modified) * rtemsbsd/include/dlfcn.h (deleted) * waf_generator.py (modified) * wscript (modified) waf: Add install support. Install to the --prefix path passed to ... Wed, 20 May 2015 23:30:28 GMT Chris Johns [4963785] * waf_generator.py (modified) waf: Add network configuration support. Add support to parse the ... Wed, 20 May 2015 11:59:15 GMT Chris Johns [e9aa9537] * builder.py (modified) * waf_generator.py (modified) waf: Add warnings and auto-regen options. Wed, 20 May 2015 07:45:16 GMT Chris Johns [5ba6949] * .gitignore (modified) * .gitmodules (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * rtems_waf (added) * waf_generator.py (added) Add support to build using waf.
