@68e4c84
07/28/12 11:40:35 |
Joel Sherrill |
testsuite/Makefile: Clean up after test name change
4.1155-freebsd-126-freebsd-12freebsd-9.3
@04ca033
07/27/12 13:14:05 |
Joel Sherrill |
loopback01: Does not include rtems specific net files
@7d69fb3
07/27/12 13:11:01 |
Joel Sherrill |
init01: Add configuration structure
@71703fec
07/27/12 12:48:22 |
Joel Sherrill |
init01: Add init.c
@4a3e489
07/26/12 13:17:53 |
Joel Sherrill |
loopback01: New test from samples/loopback
@7e7dac7
07/26/12 12:22:23 |
Joel Sherrill |
Rename link01 to init01
@e717e81
07/26/12 12:18:19 |
Joel Sherrill |
link01 - Clean up and split so initialization can be reused in other …
@19ffee0
07/17/12 18:09:58 |
Joel Sherrill |
link01: Only include fxp on pc386
@4f44b24
07/11/12 19:31:09 |
Joel Sherrill |
link01: Initialize interfaces
@9c99de7
07/09/12 19:34:08 |
Joel Sherrill |
link01: Add static_hints and make nic-sysinit.h generic
@8b588ff
06/29/12 18:10:11 |
Jennifer Averett |
Move config info into a .h file
@36ebd68
06/29/12 17:42:00 |
Jennifer Averett |
Added legacy in order to get pcib to work correctly and resoleved fxp …
@3cde755
05/30/12 16:51:35 |
Jennifer Averett |
Corrected link01 configuration and added pcib to SYSINIT.
@4bc83af
05/17/12 19:56:15 |
Joel Sherrill |
timeout - Use standard Makefile template
@596a7ea
05/16/12 15:21:12 |
Jennifer Averett |
Standardized Makefiles so that i386 would build correctly.
@4f6cf1e
05/10/12 15:03:32 |
Sebastian Huber |
Use SYSINIT reference defines
@ee6b343
05/10/12 13:06:10 |
christian.mauderer |
Provide SWI(9) and TIMEOUT(9)
@b95c989
05/09/12 18:55:00 |
Jennifer Averett |
Added subr_unit.c needed for addtional Nics.
@0ff1733
04/16/12 17:12:09 |
Jennifer Averett |
Added calls to force the linkage of RealTek? and EtherExpress? Nics.
@74109fe
04/05/12 19:02:46 |
Joel Sherrill |
link01 - Add .gitnore
@10c59c7
04/05/12 19:01:54 |
Joel Sherrill |
link01 - Produce undefined list from relocatable and link errors
This …
@aa34b6b
04/05/12 16:43:32 |
Joel Sherrill |
link01 - add undefined.txt to CLEAN_ADDITIONS
@a792664
04/05/12 13:24:45 |
Joel Sherrill |
link01 - Add list of undefined symbols
@336762e
03/27/12 22:07:19 |
Joel Sherrill |
Remove dummy symbols in link01 test
+ add symbol where needed
@334957b
03/27/12 20:00:44 |
Jennifer Averett |
Moved prison_free and prison_hold to rtems-bsd-jail.c
@d1822e5
03/27/12 09:27:55 |
Sebastian Huber |
testsuite/usb01: Support multiple BSPs
@a52104c
03/26/12 14:51:49 |
julien.delange |
e1000 driver now compiles with fewer modifications
- Change some …
@3be460f
03/23/12 18:20:57 |
Jennifer Averett |
Added comments on how to force the inclusion of the RealTek? and …
@71141b3
03/21/12 17:45:18 |
Joel Sherrill |
usb01 builds but does not link
@98c7ee3
03/20/12 14:18:33 |
Joel Sherrill |
USB test but closer to code in PR
@66e89993
03/20/12 14:13:05 |
Joel Sherrill |
Convert to UNIX CR/LF.
@c8f671a
03/20/12 14:12:27 |
Joel Sherrill |
Compiles but we are missing test.h.
Maybe it is in the PR.
@8ac749a
03/20/12 13:58:01 |
Joel Sherrill |
Add USB test from Sebastian Huber with no modifications.
@3d7f69c
03/20/12 13:14:59 |
Jennifer Averett |
Added RealTek? nic.
@6ad03bf
03/08/12 16:31:56 |
Joel Sherrill |
Remove rtems/ from includes of RTEMS specific files
@d4f439f
03/07/12 21:10:49 |
Joel Sherrill |
Add rmlock - almost links
@2e2d441
03/07/12 18:09:14 |
Joel Sherrill |
Add testsuite with single linking tests (link01)
