# # ChangeLog for services in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/20/24 02:37:44 Wed, 09 Oct 2013 20:52:54 GMT Sebastian Huber [e599318] * .gitignore (modified) * Makefile (modified) * config.inc (modified) * freebsd-to-rtems.py (modified) * freebsd-userspace/Makefile (deleted) * freebsd-userspace/README (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient-script (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient-script.8 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.8 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.conf (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.conf.5 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.leases.5 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhcp-options.5 (deleted) * freebsd-userspace/commands/sbin/ifconfig/af_ipx.c (deleted) * freebsd-userspace/commands/sbin/ifconfig/ifconfig.8 (deleted) * freebsd-userspace/commands/sbin/ifconfig/regdomain.c (deleted) * freebsd-userspace/commands/sbin/ping/ping.8 (deleted) * freebsd-userspace/commands/sbin/ping6/ping6.8 (deleted) * freebsd-userspace/commands/sbin/route/route.8 (deleted) * freebsd-userspace/commands/usr.bin/netstat/ipx.c (deleted) * freebsd-userspace/commands/usr.bin/netstat/netgraph.c (deleted) * freebsd-userspace/commands/usr.bin/netstat/netstat.1 (deleted) * freebsd-userspace/from-freebsd.sh (deleted) * freebsd-userspace/include/net/in.h (deleted) * freebsd-userspace/lib/libc/gen/err.3 (deleted) * freebsd-userspace/lib/libc/net/Makefile (deleted) * freebsd-userspace/lib/libc/net/nsparser.h (deleted) * freebsd-userspace/lib/libc/stdio/fgetln.3 (deleted) * freebsd-userspace/lib/libc/stdlib/strtonum.3 (deleted) * freebsd-userspace/lib/libc_r/uthread/uthread_kern.c (deleted) * freebsd-userspace/lib/libc_r/uthread/uthread_select.c (deleted) * freebsd-userspace/lib/libipsec/Makefile (deleted) * freebsd-userspace/lib/libipsec/ipsec_set_policy.3 (deleted) * freebsd-userspace/lib/libipsec/ipsec_strerror.3 (deleted) * freebsd-userspace/lib/libipsec/test-policy.c (deleted) * freebsd-userspace/lib/libkvm/kvm.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getcptime.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_geterr.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getfiles.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getloadavg.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getpcpu.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getprocs.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getswapinfo.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_nlist.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_open.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_read.3 (deleted) * freebsd-userspace/lib/libmemstat/libmemstat.3 (deleted) * freebsd-userspace/lib/libutil/expand_number.3 (deleted) * freebsd-userspace/lib/libutil/humanize_number.3 (deleted) * freebsd-userspace/lib/libutil/trimdomain.3 (deleted) * freebsd-userspace/local/pthread_np.h (deleted) * freebsd-userspace/rtems/include/freebsd/stdint.h (deleted) * freebsd-userspace/rtems/include/isc/app.h (deleted) * freebsd-userspace/rtems/include/isc/assertions.h (deleted) * freebsd-userspace/rtems/include/isc/boolean.h (deleted) * freebsd-userspace/rtems/include/isc/buffer.h (deleted) * freebsd-userspace/rtems/include/isc/dst.h (deleted) * freebsd-userspace/rtems/include/isc/error.h (deleted) * freebsd-userspace/rtems/include/isc/formatcheck.h (deleted) * freebsd-userspace/rtems/include/isc/int.h (deleted) * freebsd-userspace/rtems/include/isc/interfaceiter.h (deleted) * freebsd-userspace/rtems/include/isc/ipv6.h (deleted) * freebsd-userspace/rtems/include/isc/lang.h (deleted) * freebsd-userspace/rtems/include/isc/lib.h (deleted) * freebsd-userspace/rtems/include/isc/magic.h (deleted) * freebsd-userspace/rtems/include/isc/mem.h (deleted) * freebsd-userspace/rtems/include/isc/msgcat.h (deleted) * freebsd-userspace/rtems/include/isc/msgs.h (deleted) * freebsd-userspace/rtems/include/isc/mutex.h (deleted) * freebsd-userspace/rtems/include/isc/net.h (deleted) * freebsd-userspace/rtems/include/isc/netaddr.h (deleted) * freebsd-userspace/rtems/include/isc/netscope.h (deleted) * freebsd-userspace/rtems/include/isc/offset.h (deleted) * freebsd-userspace/rtems/include/isc/once.h (deleted) * freebsd-userspace/rtems/include/isc/print.h (deleted) * freebsd-userspace/rtems/include/isc/region.h (deleted) * freebsd-userspace/rtems/include/isc/result.h (deleted) * freebsd-userspace/rtems/include/isc/sockaddr.h (deleted) * freebsd-userspace/rtems/include/isc/strerror.h (deleted) * freebsd-userspace/rtems/include/isc/string.h (deleted) * freebsd-userspace/rtems/include/isc/types.h (deleted) * freebsd-userspace/rtems/include/isc/util.h (deleted) * freebsd-userspace/rtems/include/pthread_private.h (deleted) * freebsd-userspace/rtems/rtems-get_curthread.c (deleted) * freebsd-userspace/rtems/rtems-uthread_init.c (deleted) * freebsd-userspace/sys/net/ethernet.h (deleted) * freebsd/include/arpa/inet.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/db.h (modified) * freebsd/include/err.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/nsswitch.h (modified) * freebsd/include/res_update.h (modified) * freebsd/include/resolv.h (modified) * freebsd/include/rpcsvc/nis_db.h (added) * freebsd/include/rpcsvc/nis_tags.h (added) * freebsd/include/rpcsvc/nislib.h (added) * freebsd/include/rpcsvc/yp_prot.h (added) * freebsd/include/rpcsvc/ypclnt.h (added) * freebsd/kern/kern_condvar.c (deleted) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/include/isc/platform.h (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/port_before.h (modified) * freebsd/lib/libc/include/resolv_mt.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/ev_streams.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/nameser/ns_parse.c (modified) * freebsd/lib/libc/nameser/ns_print.c (modified) * freebsd/lib/libc/nameser/ns_samedomain.c (modified) * freebsd/lib/libc/net/base64.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/gai_strerror.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/if_indextoname.c (modified) * freebsd/lib/libc/net/if_nameindex.c (modified) * freebsd/lib/libc/net/if_nametoindex.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/resolv/h_errno.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/mtctxres.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_state.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libipsec/ipsec_dump_policy.c (modified) * freebsd/lib/libipsec/ipsec_get_policylen.c (modified) * freebsd/lib/libipsec/ipsec_strerror.c (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libipsec/policy_parse.y (modified) * freebsd/lib/libipsec/policy_token.l (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat.h (modified) * freebsd/lib/libmemstat/memstat_all.c (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/expand_number.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/lib/libutil/trimdomain.c (modified) * freebsd/net/ethernet.h (deleted) * freebsd/net/if.h (deleted) * freebsd/net/if_arp.h (deleted) * freebsd/net/if_dl.h (deleted) * freebsd/net/if_types.h (deleted) * freebsd/net/route.h (deleted) * freebsd/netatalk/at.h (deleted) * freebsd/netinet/icmp6.h (deleted) * freebsd/netinet/if_ether.h (deleted) * freebsd/netinet/igmp.h (deleted) * freebsd/netinet/in.h (deleted) * freebsd/netinet/in_cksum.c (deleted) * freebsd/netinet/ip.h (deleted) * freebsd/netinet/ip6.h (deleted) * freebsd/netinet/ip_icmp.h (deleted) * freebsd/netinet/tcp.h (deleted) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/ifconfig/af_atalk.c (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifcarp.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/ifconfig/regdomain.h (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/arm/arm/in_cksum.c (modified) * freebsd/sys/arm/arm/legacy.c (added) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/arm/include/machine/in_cksum.h (modified) * freebsd/sys/arm/include/machine/legacyvar.h (modified) * freebsd/sys/arm/pci/pci_bus.c (modified) * freebsd/sys/avr/avr/in_cksum.c (added) * freebsd/sys/avr/avr/legacy.c (added) * freebsd/sys/avr/include/machine/in_cksum.h (modified) * freebsd/sys/avr/include/machine/legacyvar.h (added) * freebsd/sys/avr/include/machine/pci_cfgreg.h (moved) * freebsd/sys/avr/pci/pci_bus.c (modified) * freebsd/sys/bfin/bfin/in_cksum.c (added) * freebsd/sys/bfin/bfin/legacy.c (added) * freebsd/sys/bfin/include/machine/in_cksum.h (modified) * freebsd/sys/bfin/include/machine/legacyvar.h (added) * freebsd/sys/bfin/include/machine/pci_cfgreg.h (added) * freebsd/sys/bfin/pci/pci_bus.c (added) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt_sim.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/cam/scsi/scsi_da.h (modified) * freebsd/sys/contrib/altq/altq/altq.h (modified) * freebsd/sys/contrib/altq/altq/altq_cbq.c (modified) * freebsd/sys/contrib/altq/altq/altq_cbq.h (modified) * freebsd/sys/contrib/altq/altq/altq_cdnr.c (modified) * freebsd/sys/contrib/altq/altq/altq_cdnr.h (modified) * freebsd/sys/contrib/altq/altq/altq_classq.h (modified) * freebsd/sys/contrib/altq/altq/altq_hfsc.c (modified) * freebsd/sys/contrib/altq/altq/altq_hfsc.h (modified) * freebsd/sys/contrib/altq/altq/altq_priq.c (modified) * freebsd/sys/contrib/altq/altq/altq_priq.h (modified) * freebsd/sys/contrib/altq/altq/altq_red.c (modified) * freebsd/sys/contrib/altq/altq/altq_red.h (modified) * freebsd/sys/contrib/altq/altq/altq_rio.c (modified) * freebsd/sys/contrib/altq/altq/altq_rio.h (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass.c (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass.h (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass_debug.h (modified) * freebsd/sys/contrib/altq/altq/altq_subr.c (modified) * freebsd/sys/contrib/altq/altq/altq_var.h (modified) * freebsd/sys/contrib/altq/altq/altqconf.h (modified) * freebsd/sys/contrib/altq/altq/if_altq.h (modified) * freebsd/sys/contrib/pf/net/if_pflog.c (modified) * freebsd/sys/contrib/pf/net/if_pflog.h (modified) * freebsd/sys/contrib/pf/net/if_pfsync.c (modified) * freebsd/sys/contrib/pf/net/if_pfsync.h (modified) * freebsd/sys/contrib/pf/net/pf.c (modified) * freebsd/sys/contrib/pf/net/pf_if.c (modified) * freebsd/sys/contrib/pf/net/pf_ioctl.c (modified) * freebsd/sys/contrib/pf/net/pf_mtag.h (modified) * freebsd/sys/contrib/pf/net/pf_norm.c (modified) * freebsd/sys/contrib/pf/net/pf_osfp.c (modified) * freebsd/sys/contrib/pf/net/pf_ruleset.c (modified) * freebsd/sys/contrib/pf/net/pf_subr.c (modified) * freebsd/sys/contrib/pf/net/pf_table.c (modified) * freebsd/sys/contrib/pf/net/pfvar.h (modified) * freebsd/sys/contrib/pf/netinet/in4_cksum.c (modified) * freebsd/sys/crypto/blowfish/bf_ecb.c (modified) * freebsd/sys/crypto/blowfish/bf_enc.c (modified) * freebsd/sys/crypto/blowfish/bf_skey.c (modified) * freebsd/sys/crypto/camellia/camellia-api.c (modified) * freebsd/sys/crypto/camellia/camellia.c (modified) * freebsd/sys/crypto/des/des_ecb.c (modified) * freebsd/sys/crypto/des/des_enc.c (modified) * freebsd/sys/crypto/des/des_locl.h (modified) * freebsd/sys/crypto/des/des_setkey.c (modified) * freebsd/sys/crypto/rc4/rc4.c (modified) * freebsd/sys/crypto/rc4/rc4.h (modified) * freebsd/sys/crypto/rijndael/rijndael-alg-fst.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.h (modified) * freebsd/sys/crypto/rijndael/rijndael-api.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha1.h (modified) * freebsd/sys/crypto/sha2/sha2.c (modified) * freebsd/sys/crypto/sha2/sha2.h (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bce/if_bcereg.h (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.h (modified) * freebsd/sys/dev/e1000/e1000_82540.c (modified) * freebsd/sys/dev/e1000/e1000_82541.c (modified) * freebsd/sys/dev/e1000/e1000_82541.h (modified) * freebsd/sys/dev/e1000/e1000_82542.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82543.h (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82571.h (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_api.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_manage.c (modified) * freebsd/sys/dev/e1000/e1000_manage.h (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.h (modified) * freebsd/sys/dev/e1000/e1000_nvm.c (modified) * freebsd/sys/dev/e1000/e1000_nvm.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_phy.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/e1000_vf.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_igb.c (modified) * freebsd/sys/dev/e1000/if_lem.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/brgphyreg.h (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/icsphyreg.h (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii.h (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/random/harvest.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/smc/if_smcreg.h (modified) * freebsd/sys/dev/smc/if_smcvar.h (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ehci.h (modified) * freebsd/sys/dev/usb/controller/ehcireg.h (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * freebsd/sys/dev/usb/controller/ohcireg.h (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/ufm_ioctl.h (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_busdma.h (modified) * freebsd/sys/dev/usb/usb_cdc.h (modified) * freebsd/sys/dev/usb/usb_controller.h (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_core.h (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_debug.h (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_dev.h (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_dynamic.h (modified) * freebsd/sys/dev/usb/usb_endian.h (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_freebsd.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_generic.h (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_hub.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_mbuf.h (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_msctest.h (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_process.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_request.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_transfer.h (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/usb_util.h (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/dev/usb/usbdi_util.h (modified) * freebsd/sys/dev/usb/usbhid.h (modified) * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/h8300/h8300/in_cksum.c (added) * freebsd/sys/h8300/h8300/legacy.c (added) * freebsd/sys/h8300/include/machine/in_cksum.h (modified) * freebsd/sys/h8300/include/machine/legacyvar.h (added) * freebsd/sys/h8300/include/machine/pci_cfgreg.h (added) * freebsd/sys/h8300/pci/pci_bus.c (added) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/i386/legacy.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/in_cksum.h (modified) * freebsd/sys/i386/include/machine/legacyvar.h (added) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/i386/include/machine/pci_cfgreg.h (added) * freebsd/sys/i386/include/machine/specialreg.h (modified) * freebsd/sys/i386/pci/pci_bus.c (added) * freebsd/sys/ioccom.h (deleted) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/isa/pnpvar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_descrip.c (modified) * freebsd/sys/kern/kern_environment.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_ntptime.c (modified) * freebsd/sys/kern/kern_proc.c (modified) * freebsd/sys/kern/kern_prot.c (modified) * freebsd/sys/kern/kern_resource.c (modified) * freebsd/sys/kern/kern_subr.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_tc.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_bufring.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/libkern/arc4random.c (modified) * freebsd/sys/libkern/fls.c (modified) * freebsd/sys/libkern/inet_ntoa.c (modified) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/lm32/include/machine/in_cksum.h (added) * freebsd/sys/lm32/include/machine/legacyvar.h (added) * freebsd/sys/lm32/include/machine/pci_cfgreg.h (added) * freebsd/sys/lm32/lm32/in_cksum.c (added) * freebsd/sys/lm32/lm32/legacy.c (added) * freebsd/sys/lm32/pci/pci_bus.c (added) * freebsd/sys/m32c/include/machine/in_cksum.h (added) * freebsd/sys/m32c/include/machine/legacyvar.h (added) * freebsd/sys/m32c/include/machine/pci_cfgreg.h (added) * freebsd/sys/m32c/m32c/in_cksum.c (added) * freebsd/sys/m32c/m32c/legacy.c (added) * freebsd/sys/m32c/pci/pci_bus.c (added) * freebsd/sys/m32r/include/machine/in_cksum.h (added) * freebsd/sys/m32r/include/machine/legacyvar.h (added) * freebsd/sys/m32r/include/machine/pci_cfgreg.h (added) * freebsd/sys/m32r/m32r/in_cksum.c (added) * freebsd/sys/m32r/m32r/legacy.c (added) * freebsd/sys/m32r/pci/pci_bus.c (added) * freebsd/sys/m68k/include/machine/in_cksum.h (moved) * freebsd/sys/m68k/include/machine/legacyvar.h (added) * freebsd/sys/m68k/include/machine/pci_cfgreg.h (added) * freebsd/sys/m68k/m68k/in_cksum.c (added) * freebsd/sys/m68k/m68k/legacy.c (added) * freebsd/sys/m68k/pci/pci_bus.c (added) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/mips/include/machine/in_cksum.h (added) * freebsd/sys/mips/include/machine/legacyvar.h (added) * freebsd/sys/mips/include/machine/pci_cfgreg.h (added) * freebsd/sys/mips/mips/in_cksum.c (modified) * freebsd/sys/mips/mips/legacy.c (added) * freebsd/sys/mips/pci/pci_bus.c (added) * freebsd/sys/mman.h (deleted) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_buffer.h (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/bpf_zerocopy.h (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/bridgestp.h (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/fddi.h (modified) * freebsd/sys/net/firewire.h (modified) * freebsd/sys/net/flowtable.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_atmsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_ef.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_faith.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_llc.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_mib.c (modified) * freebsd/sys/net/if_sppp.h (modified) * freebsd/sys/net/if_spppfr.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_stf.h (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tap.h (modified) * freebsd/sys/net/if_tapvar.h (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_tun.h (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iso88025.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/ppp_defs.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/radix_mpath.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_cb.h (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net/slcompress.h (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net/zlib.c (modified) * freebsd/sys/net/zlib.h (modified) * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_action.h (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.h (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_ageq.h (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_amrr.h (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto.h (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_dfs.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_hostap.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_mesh.h (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_monitor.h (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_phy.h (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_power.h (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.h (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.h (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.h (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_tdma.h (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_wds.h (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) * freebsd/sys/netatalk/aarp.c (modified) * freebsd/sys/netatalk/aarp.h (modified) * freebsd/sys/netatalk/at.h (modified) * freebsd/sys/netatalk/at_control.c (modified) * freebsd/sys/netatalk/at_extern.h (modified) * freebsd/sys/netatalk/at_proto.c (modified) * freebsd/sys/netatalk/at_rmx.c (modified) * freebsd/sys/netatalk/at_var.h (modified) * freebsd/sys/netatalk/ddp.h (modified) * freebsd/sys/netatalk/ddp_input.c (modified) * freebsd/sys/netatalk/ddp_output.c (modified) * freebsd/sys/netatalk/ddp_pcb.c (modified) * freebsd/sys/netatalk/ddp_pcb.h (modified) * freebsd/sys/netatalk/ddp_usrreq.c (modified) * freebsd/sys/netatalk/ddp_var.h (modified) * freebsd/sys/netatalk/endian.h (modified) * freebsd/sys/netatalk/phase2.h (modified) * freebsd/sys/netinet/accf_data.c (modified) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_atm.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp.h (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_gif.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_rmx.c (modified) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_divert.h (modified) * freebsd/sys/netinet/ip_ecn.c (modified) * freebsd/sys/netinet/ip_ecn.h (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_ipsec.c (modified) * freebsd/sys/netinet/ip_ipsec.h (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/ipfw/dn_heap.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_fifo.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_prio.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_qfq.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_rr.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_wf2q.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_glue.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_io.c (modified) * freebsd/sys/netinet/ipfw/ip_dummynet.c (modified) * freebsd/sys/netinet/ipfw/ip_fw2.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_log.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_table.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias.h (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_pptp.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/pim.h (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.h (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_cc_functions.h (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_crc32.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_lock_bsd.h (modified) * freebsd/sys/netinet/sctp_os.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_peeloff.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_timer.h (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_debug.h (modified) * freebsd/sys/netinet/tcp_fsm.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hostcache.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_lro.h (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_offload.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/tcpip.h (modified) * freebsd/sys/netinet/toedev.h (modified) * freebsd/sys/netinet/udp.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_gif.h (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_ifattach.h (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_ipsec.c (modified) * freebsd/sys/netinet6/ip6_ipsec.h (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_mroute.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6.h (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/raw_ip6.h (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/tcp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netipsec/ah.h (modified) * freebsd/sys/netipsec/ah_var.h (modified) * freebsd/sys/netipsec/esp.h (modified) * freebsd/sys/netipsec/esp_var.h (modified) * freebsd/sys/netipsec/ipcomp.h (modified) * freebsd/sys/netipsec/ipcomp_var.h (modified) * freebsd/sys/netipsec/ipip_var.h (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/key_var.h (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_ipip.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/nios2/include/machine/in_cksum.h (added) * freebsd/sys/nios2/include/machine/legacyvar.h (added) * freebsd/sys/nios2/include/machine/pci_cfgreg.h (added) * freebsd/sys/nios2/nios2/in_cksum.c (added) * freebsd/sys/nios2/nios2/legacy.c (added) * freebsd/sys/nios2/pci/pci_bus.c (added) * freebsd/sys/opencrypto/cast.c (modified) * freebsd/sys/opencrypto/cast.h (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/cryptosoft.h (modified) * freebsd/sys/opencrypto/deflate.c (modified) * freebsd/sys/opencrypto/deflate.h (modified) * freebsd/sys/opencrypto/rmd160.c (modified) * freebsd/sys/opencrypto/skipjack.c (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/opencrypto/xform.h (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/in_cksum.h (moved) * freebsd/sys/powerpc/include/machine/legacyvar.h (added) * freebsd/sys/powerpc/include/machine/pci_cfgreg.h (added) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/powerpc/pci/pci_bus.c (added) * freebsd/sys/powerpc/powerpc/in_cksum.c (modified) * freebsd/sys/powerpc/powerpc/legacy.c (added) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/security/mac/mac_framework.h (modified) * freebsd/sys/sh/include/machine/in_cksum.h (added) * freebsd/sys/sh/include/machine/legacyvar.h (added) * freebsd/sys/sh/include/machine/pci_cfgreg.h (added) * freebsd/sys/sh/pci/pci_bus.c (added) * freebsd/sys/sh/sh/in_cksum.c (added) * freebsd/sys/sh/sh/legacy.c (added) * freebsd/sys/socket.h (deleted) * freebsd/sys/socketvar.h (deleted) * freebsd/sys/sparc/include/machine/in_cksum.h (added) * freebsd/sys/sparc/include/machine/legacyvar.h (added) * freebsd/sys/sparc/include/machine/pci_cfgreg.h (added) * freebsd/sys/sparc/pci/pci_bus.c (added) * freebsd/sys/sparc/sparc/in_cksum.c (added) * freebsd/sys/sparc/sparc/legacy.c (added) * freebsd/sys/sparc64/include/machine/asi.h (modified) * freebsd/sys/sparc64/include/machine/cpufunc.h (modified) * freebsd/sys/sparc64/include/machine/in_cksum.h (added) * freebsd/sys/sparc64/include/machine/legacyvar.h (added) * freebsd/sys/sparc64/include/machine/pci_cfgreg.h (added) * freebsd/sys/sparc64/include/machine/pstate.h (modified) * freebsd/sys/sparc64/pci/pci_bus.c (added) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sparc64/sparc64/legacy.c (added) * freebsd/sys/sys/_bus_dma.h (modified) * freebsd/sys/sys/_lock.h (modified) * freebsd/sys/sys/_lockmgr.h (modified) * freebsd/sys/sys/_mutex.h (modified) * freebsd/sys/sys/_rmlock.h (modified) * freebsd/sys/sys/_rwlock.h (modified) * freebsd/sys/sys/_semaphore.h (modified) * freebsd/sys/sys/_sigset.h (modified) * freebsd/sys/sys/_sx.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/_timeval.h (modified) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/condvar.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/endian.h (modified) * freebsd/sys/sys/event.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/fcntl.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/filio.h (modified) * freebsd/sys/sys/hash.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/kenv.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/kthread.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/limits.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lock_profile.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/mac.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/md5.h (modified) * freebsd/sys/sys/mman.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mqueue.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/osd.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/poll.h (modified) * freebsd/sys/sys/priority.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/queue.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rman.h (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rtprio.h (modified) * freebsd/sys/sys/runq.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/select.h (modified) * freebsd/sys/sys/selinfo.h (modified) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/sigio.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockio.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sockstate.h (modified) * freebsd/sys/sys/stddef.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/timepps.h (modified) * freebsd/sys/sys/timetc.h (modified) * freebsd/sys/sys/timex.h (modified) * freebsd/sys/sys/tree.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttycom.h (modified) * freebsd/sys/sys/ttydevsw.h (modified) * freebsd/sys/sys/ttydisc.h (modified) * freebsd/sys/sys/ttyhook.h (modified) * freebsd/sys/sys/ttyqueue.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/un.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sysctl.h (deleted) * freebsd/sys/syslimits.h (deleted) * freebsd/sys/syslog.h (deleted) * freebsd/sys/uio.h (deleted) * freebsd/sys/v850/include/machine/in_cksum.h (moved) * freebsd/sys/v850/include/machine/legacyvar.h (added) * freebsd/sys/v850/include/machine/pci_cfgreg.h (added) * freebsd/sys/v850/pci/pci_bus.c (added) * freebsd/sys/v850/v850/in_cksum.c (added) * freebsd/sys/v850/v850/legacy.c (added) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/time.h (deleted) * freebsd/usr.bin/netstat/atalk.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * rtemsbsd/bfin/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/freebsd/machine/_align.h (deleted) * rtemsbsd/freebsd/machine/_stdint.h (deleted) * rtemsbsd/freebsd/machine/_types.h (deleted) * rtemsbsd/freebsd/machine/param.h (deleted) * rtemsbsd/freebsd/machine/resource.h (deleted) * rtemsbsd/freebsd/machine/rtems-bsd-select.h (deleted) * rtemsbsd/freebsd/sys/_iovec.h (deleted) * rtemsbsd/freebsd/sys/cdefs.h (deleted) * rtemsbsd/freebsd/sys/signal.h (deleted) * rtemsbsd/freebsd/sys/uio.h (deleted) * rtemsbsd/h8300/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/include/machine/_bus.h (modified) * rtemsbsd/include/machine/_limits.h (modified) * rtemsbsd/include/machine/bus.h (modified) * rtemsbsd/include/machine/bus_dma.h (modified) * rtemsbsd/include/machine/bus_space-i386.h (modified) * rtemsbsd/include/machine/elf.h (modified) * rtemsbsd/include/machine/mutex.h (modified) * rtemsbsd/include/machine/pcb.h (modified) * rtemsbsd/include/machine/resource.h (modified) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/include/machine/rtems-bsd-devicet.h (modified) * rtemsbsd/include/machine/rtems-bsd-endian.h (added) * rtemsbsd/include/machine/rtems-bsd-param.h (moved) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (added) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) * rtemsbsd/include/machine/smp.h (modified) * rtemsbsd/include/machine/vm.h (modified) * rtemsbsd/include/poll.h (modified) * rtemsbsd/include/pthread_np.h (moved) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/include/rtems/bsd/local/vnode_if.h (modified) * rtemsbsd/include/rtems/bsd/sys/_types.h (modified) * rtemsbsd/include/rtems/bsd/sys/errno.h (modified) * rtemsbsd/include/rtems/bsd/sys/lock.h (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/include/rtems/bsd/sys/resource.h (modified) * rtemsbsd/include/rtems/bsd/sys/time.h (modified) * rtemsbsd/include/rtems/bsd/sys/timespec.h (modified) * rtemsbsd/include/rtems/bsd/sys/types.h (modified) * rtemsbsd/include/rtems/bsd/sys/unistd.h (modified) * rtemsbsd/include/sys/_pthreadtypes.h (modified) * rtemsbsd/include/sys/signalvar.h (modified) * rtemsbsd/include/vm/vm_extern.h (moved) * rtemsbsd/include/vm/vm_kern.h (moved) * rtemsbsd/include/vm/vm_object.h (moved) * rtemsbsd/include/vm/vm_page.h (moved) * rtemsbsd/lm32/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/local/bus_if.c (modified) * rtemsbsd/local/cryptodev_if.c (modified) * rtemsbsd/local/device_if.c (modified) * rtemsbsd/local/miibus_if.c (modified) * rtemsbsd/local/pci_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) * rtemsbsd/local/usb_if.c (modified) * rtemsbsd/m32c/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/m32r/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/m68k/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/nios2/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/rtems/ipsec_get_policylen.c (modified) * rtemsbsd/rtems/kvm_private.h (modified) * rtemsbsd/rtems/rtems-bsd-assert.c (modified) * rtemsbsd/rtems/rtems-bsd-autoconf.c (modified) * rtemsbsd/rtems/rtems-bsd-bus-dma-mbuf.c (modified) * rtemsbsd/rtems/rtems-bsd-bus-dma.c (modified) * rtemsbsd/rtems/rtems-bsd-cam.c (modified) * rtemsbsd/rtems/rtems-bsd-condvar.c (modified) * rtemsbsd/rtems/rtems-bsd-conf.c (modified) * rtemsbsd/rtems/rtems-bsd-copyinout.c (modified) * rtemsbsd/rtems/rtems-bsd-delay.c (modified) * rtemsbsd/rtems/rtems-bsd-descrip.c (modified) * rtemsbsd/rtems/rtems-bsd-generic.c (modified) * rtemsbsd/rtems/rtems-bsd-init-with-irq.c (modified) * rtemsbsd/rtems/rtems-bsd-init.c (modified) * rtemsbsd/rtems/rtems-bsd-jail.c (modified) * rtemsbsd/rtems/rtems-bsd-lock.c (modified) * rtemsbsd/rtems/rtems-bsd-log.c (modified) * rtemsbsd/rtems/rtems-bsd-malloc.c (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-nexus.c (modified) * rtemsbsd/rtems/rtems-bsd-page.c (modified) * rtemsbsd/rtems/rtems-bsd-panic.c (modified) * rtemsbsd/rtems/rtems-bsd-pci_bus.c (added) * rtemsbsd/rtems/rtems-bsd-pci_cfgreg.c (modified) * rtemsbsd/rtems/rtems-bsd-rwlock.c (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (modified) * rtemsbsd/rtems/rtems-bsd-signal.c (modified) * rtemsbsd/rtems/rtems-bsd-smp.c (modified) * rtemsbsd/rtems/rtems-bsd-subr_param.c (modified) * rtemsbsd/rtems/rtems-bsd-support.c (modified) * rtemsbsd/rtems/rtems-bsd-sx.c (modified) * rtemsbsd/rtems/rtems-bsd-synch.c (modified) * rtemsbsd/rtems/rtems-bsd-syscall-api.c (added) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctl.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctlbyname.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctlnametomib.c (modified) * rtemsbsd/rtems/rtems-bsd-taskqueue.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) * rtemsbsd/rtems/rtems-bsd-thread0-ucred.c (modified) * rtemsbsd/rtems/rtems-bsd-timesupport.c (modified) * rtemsbsd/rtems/rtems-bsd-vm_glue.c (modified) * rtemsbsd/rtems/rtems-net-setup.c (modified) * rtemsbsd/rtems/rtems-syspoll.c (modified) * rtemsbsd/rtems/rtems-uthread_kqueue.c (modified) * rtemsbsd/rtems/syslog.c (modified) * rtemsbsd/sh/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/sparc/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc24xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (modified) * rtemsbsd/v850/include/freebsd/machine/cpufunc.h (deleted) * services/librpc/src/rpc/auth_none.c (modified) * services/librpc/src/rpc/auth_unix.c (modified) * services/librpc/src/rpc/authunix_prot.c (modified) * services/librpc/src/rpc/bindresvport.c (modified) * services/librpc/src/rpc/clnt_generic.c (modified) * services/librpc/src/rpc/clnt_perror.c (modified) * services/librpc/src/rpc/clnt_raw.c (modified) * services/librpc/src/rpc/clnt_simple.c (modified) * services/librpc/src/rpc/clnt_tcp.c (modified) * services/librpc/src/rpc/clnt_udp.c (modified) * services/librpc/src/rpc/get_myaddress.c (modified) * services/librpc/src/rpc/getrpcent.c (modified) * services/librpc/src/rpc/getrpcport.c (modified) * services/librpc/src/rpc/netname.c (modified) * services/librpc/src/rpc/netnamer.c (modified) * services/librpc/src/rpc/pmap_clnt.c (modified) * services/librpc/src/rpc/pmap_getmaps.c (modified) * services/librpc/src/rpc/pmap_getport.c (modified) * services/librpc/src/rpc/pmap_prot.c (modified) * services/librpc/src/rpc/pmap_prot2.c (modified) * services/librpc/src/rpc/rpc_callmsg.c (modified) * services/librpc/src/rpc/rpc_commondata.c (modified) * services/librpc/src/rpc/rpc_dtablesize.c (modified) * services/librpc/src/rpc/rpc_prot.c (modified) * services/librpc/src/rpc/rpcdname.c (modified) * services/librpc/src/rpc/rtems_portmapper.c (modified) * services/librpc/src/rpc/rtems_rpc.c (modified) * services/librpc/src/rpc/rtime.c (modified) * services/librpc/src/rpc/svc.c (modified) * services/librpc/src/rpc/svc_auth.c (modified) * services/librpc/src/rpc/svc_auth_unix.c (modified) * services/librpc/src/rpc/svc_raw.c (modified) * services/librpc/src/rpc/svc_run.c (modified) * services/librpc/src/rpc/svc_simple.c (modified) * services/librpc/src/rpc/svc_tcp.c (modified) * services/librpc/src/rpc/svc_udp.c (modified) * services/librpc/src/xdr/xdr.c (modified) * services/librpc/src/xdr/xdr_array.c (modified) * services/librpc/src/xdr/xdr_float.c (modified) * services/librpc/src/xdr/xdr_mem.c (modified) * services/librpc/src/xdr/xdr_rec.c (modified) * services/librpc/src/xdr/xdr_reference.c (modified) * services/librpc/src/xdr/xdr_sizeof.c (modified) * services/librpc/src/xdr/xdr_stdio.c (modified) * testsuite/Makefile (deleted) * testsuite/include/rtems/bsd/test/default-init.h (moved) * testsuite/include/rtems/bsd/test/nic-sysinit.h (modified) * testsuite/init01/.gitignore (deleted) * testsuite/init01/Makefile (deleted) * testsuite/init01/test_main.c (modified) * testsuite/loopback01/.gitignore (deleted) * testsuite/loopback01/Makefile (deleted) * testsuite/loopback01/test_main.c (modified) * testsuite/mghttpd01/.gitignore (deleted) * testsuite/mghttpd01/Makefile (deleted) * testsuite/netshell01/.gitignore (deleted) * testsuite/netshell01/Makefile (deleted) * testsuite/netshell01/test_main.c (modified) * testsuite/swi01/Makefile (deleted) * testsuite/swi01/init.c (modified) * testsuite/swi01/swi_test.c (modified) * testsuite/timeout01/Makefile (deleted) * testsuite/timeout01/init.c (modified) * testsuite/timeout01/timeout_helper.c (modified) * testsuite/timeout01/timeout_test.c (modified) * testsuite/usb01/Makefile (deleted) * testsuite/usb01/init.c (modified) * testsuite/usb01/usb-sysinit.h (modified) Update files to match FreeBSD layout Add compatibility with Newlib ... Fri, 24 Aug 2012 20:52:28 GMT Joel Sherrill [0109975] * services/librpc/include/rpcsvc/yp_prot.h (modified) yp_prot.h: Further disable bool definition Fri, 24 Aug 2012 20:38:52 GMT Joel Sherrill [5df92c3] * services/librpc/include/rpcsvc/yp_prot.h (modified) yp_prot.h: bool defined in newer code base in stdbool.h Hopefully ... Mon, 06 Aug 2012 19:56:56 GMT Joel Sherrill [725c9b9] * services/Makefile (modified) * services/librpc/include/rpc/auth.h (deleted) * services/librpc/include/rpc/rpc.h (deleted) librpc: Delete duped .h files from libc and update Makefile Mon, 06 Aug 2012 00:12:48 GMT Joel Sherrill [f01bc1f4] * services/librpc/Makefile (modified) * services/librpc/include/rpc/auth_unix.h (deleted) * services/librpc/include/rpc/clnt_soc.h (deleted) * services/librpc/include/rpc/clnt_stat.h (deleted) * services/librpc/include/rpc/pmap_clnt.h (deleted) * services/librpc/include/rpc/pmap_prot.h (deleted) * services/librpc/include/rpc/rpc_msg.h (deleted) * services/librpc/include/rpc/rpcent.h (deleted) * services/librpc/include/rpc/svc_auth.h (deleted) * services/librpc/include/rpc/svc_soc.h (deleted) * services/librpc/include/rpc/types.h (deleted) * services/librpc/include/rpc/xdr.h (deleted) librpc: Use libc versions of .h files Mon, 06 Aug 2012 00:10:35 GMT Joel Sherrill [cd450d2] * freebsd-userspace/rtems/include/rpc.h (moved) * freebsd-userspace/rtems/include/rpc/clnt.h (moved) * services/librpc/include/rpc/clnt.h (deleted) * services/librpc/include/rpc/rpc_com.h (modified) * services/librpc/include/rpc/svc.h (deleted) * services/librpc/src/rpc/auth_none.c (modified) * services/librpc/src/rpc/auth_unix.c (modified) * services/librpc/src/rpc/authunix_prot.c (modified) * services/librpc/src/rpc/bindresvport.c (modified) * services/librpc/src/rpc/clnt_generic.c (modified) * services/librpc/src/rpc/clnt_perror.c (modified) * services/librpc/src/rpc/clnt_raw.c (modified) * services/librpc/src/rpc/clnt_simple.c (modified) * services/librpc/src/rpc/clnt_tcp.c (modified) * services/librpc/src/rpc/clnt_udp.c (modified) * services/librpc/src/rpc/get_myaddress.c (modified) * services/librpc/src/rpc/getrpcent.c (modified) * services/librpc/src/rpc/getrpcport.c (modified) * services/librpc/src/rpc/netname.c (modified) * services/librpc/src/rpc/netnamer.c (modified) * services/librpc/src/rpc/pmap_clnt.c (modified) * services/librpc/src/rpc/pmap_getmaps.c (modified) * services/librpc/src/rpc/pmap_getport.c (modified) * services/librpc/src/rpc/pmap_prot.c (modified) * services/librpc/src/rpc/pmap_prot2.c (modified) * services/librpc/src/rpc/pmap_rmt.c (modified) * services/librpc/src/rpc/rpc.3 (modified) * services/librpc/src/rpc/rpc_callmsg.c (modified) * services/librpc/src/rpc/rpc_commondata.c (modified) * services/librpc/src/rpc/rpc_dtablesize.c (modified) * services/librpc/src/rpc/rpc_prot.c (modified) * services/librpc/src/rpc/rpcdname.c (modified) * services/librpc/src/rpc/rtems_portmapper.c (modified) * services/librpc/src/rpc/rtems_rpc.c (modified) * services/librpc/src/rpc/rtime.c (modified) * services/librpc/src/rpc/svc.c (modified) * services/librpc/src/rpc/svc_auth.c (modified) * services/librpc/src/rpc/svc_auth_unix.c (modified) * services/librpc/src/rpc/svc_raw.c (modified) * services/librpc/src/rpc/svc_run.c (modified) * services/librpc/src/rpc/svc_simple.c (modified) * services/librpc/src/rpc/svc_tcp.c (modified) * services/librpc/src/rpc/svc_udp.c (modified) * services/librpc/src/xdr/xdr.c (modified) * services/librpc/src/xdr/xdr_array.c (modified) * services/librpc/src/xdr/xdr_float.c (modified) * services/librpc/src/xdr/xdr_mem.c (modified) * services/librpc/src/xdr/xdr_rec.c (modified) * services/librpc/src/xdr/xdr_reference.c (modified) * services/librpc/src/xdr/xdr_sizeof.c (modified) * services/librpc/src/xdr/xdr_stdio.c (modified) librpc: now compiles Fri, 03 Aug 2012 19:21:13 GMT Joel Sherrill [8f59c0a] * services/nfsclient/ChangeLog.slac (added) * services/nfsclient/LICENSE (added) * services/nfsclient/Makefile (added) * services/nfsclient/README (added) * services/nfsclient/cexphelp.c (added) * services/nfsclient/dirutils.c (added) * services/nfsclient/include/librtemsNfs.h (added) * services/nfsclient/include/rpcio.h (added) * services/nfsclient/nfs.c (added) * services/nfsclient/nfs.modini.c (added) * services/nfsclient/nfsTest.c (added) * services/nfsclient/proto/mount_prot.h (added) * services/nfsclient/proto/mount_prot.x (added) * services/nfsclient/proto/mount_prot_xdr.c (added) * services/nfsclient/proto/nfs_prot.h (added) * services/nfsclient/proto/nfs_prot.x (added) * services/nfsclient/proto/nfs_prot_xdr.c (added) * services/nfsclient/rfc1094.txt (added) * services/nfsclient/rpcio.c (added) * services/nfsclient/rpcio.modini.c (added) * services/nfsclient/sock_mbuf.c (added) * services/nfsclient/xdr_mbuf.c (added) nfsclient: Initial addition Will not compile until librpc is available. Fri, 03 Aug 2012 19:19:49 GMT Joel Sherrill [20ec9e6] * services/librpc/Makefile (added) * services/librpc/README_RTEMS (added) * services/librpc/include/rpc/auth.h (added) * services/librpc/include/rpc/auth_unix.h (added) * services/librpc/include/rpc/clnt.h (added) * services/librpc/include/rpc/clnt_soc.h (added) * services/librpc/include/rpc/clnt_stat.h (added) * services/librpc/include/rpc/pmap_clnt.h (added) * services/librpc/include/rpc/pmap_prot.h (added) * services/librpc/include/rpc/pmap_rmt.h (added) * services/librpc/include/rpc/rpc.h (added) * services/librpc/include/rpc/rpc_com.h (added) * services/librpc/include/rpc/rpc_msg.h (added) * services/librpc/include/rpc/rpcent.h (added) * services/librpc/include/rpc/svc.h (added) * services/librpc/include/rpc/svc_auth.h (added) * services/librpc/include/rpc/svc_soc.h (added) * services/librpc/include/rpc/types.h (added) * services/librpc/include/rpc/xdr.h (added) * services/librpc/include/rpcsvc/bootparam_prot.x (added) * services/librpc/include/rpcsvc/crypt.x (added) * services/librpc/include/rpcsvc/key_prot.x (added) * services/librpc/include/rpcsvc/klm_prot.x (added) * services/librpc/include/rpcsvc/mount.x (added) * services/librpc/include/rpcsvc/nfs_prot.x (added) * services/librpc/include/rpcsvc/nis.x (added) * services/librpc/include/rpcsvc/nis_cache.x (added) * services/librpc/include/rpcsvc/nis_callback.x (added) * services/librpc/include/rpcsvc/nis_db.h (added) * services/librpc/include/rpcsvc/nis_object.x (added) * services/librpc/include/rpcsvc/nis_tags.h (added) * services/librpc/include/rpcsvc/nislib.h (added) * services/librpc/include/rpcsvc/nlm_prot.x (added) * services/librpc/include/rpcsvc/pmap_prot.x (added) * services/librpc/include/rpcsvc/rex.x (added) * services/librpc/include/rpcsvc/rnusers.x (added) * services/librpc/include/rpcsvc/rquota.x (added) * services/librpc/include/rpcsvc/rstat.x (added) * services/librpc/include/rpcsvc/rwall.x (added) * services/librpc/include/rpcsvc/sm_inter.x (added) * services/librpc/include/rpcsvc/spray.x (added) * services/librpc/include/rpcsvc/yp.x (added) * services/librpc/include/rpcsvc/yp_prot.h (added) * services/librpc/include/rpcsvc/ypclnt.h (added) * services/librpc/include/rpcsvc/yppasswd.x (added) * services/librpc/include/rpcsvc/ypupdate_prot.x (added) * services/librpc/include/rpcsvc/ypxfrd.x (added) * services/librpc/src/rpc/DISCLAIMER (added) * services/librpc/src/rpc/README (added) * services/librpc/src/rpc/auth_none.c (added) * services/librpc/src/rpc/auth_unix.c (added) * services/librpc/src/rpc/authunix_prot.c (added) * services/librpc/src/rpc/bindresvport.3 (added) * services/librpc/src/rpc/bindresvport.c (added) * services/librpc/src/rpc/clnt_generic.c (added) * services/librpc/src/rpc/clnt_perror.c (added) * services/librpc/src/rpc/clnt_raw.c (added) * services/librpc/src/rpc/clnt_simple.c (added) * services/librpc/src/rpc/clnt_tcp.c (added) * services/librpc/src/rpc/clnt_udp.c (added) * services/librpc/src/rpc/des_crypt.3 (added) * services/librpc/src/rpc/get_myaddress.c (added) * services/librpc/src/rpc/getrpcent.3 (added) * services/librpc/src/rpc/getrpcent.c (added) * services/librpc/src/rpc/getrpcport.3 (added) * services/librpc/src/rpc/getrpcport.c (added) * services/librpc/src/rpc/netname.c (added) * services/librpc/src/rpc/netnamer.c (added) * services/librpc/src/rpc/pmap_clnt.c (added) * services/librpc/src/rpc/pmap_getmaps.c (added) * services/librpc/src/rpc/pmap_getport.c (added) * services/librpc/src/rpc/pmap_prot.c (added) * services/librpc/src/rpc/pmap_prot2.c (added) * services/librpc/src/rpc/pmap_rmt.c (added) * services/librpc/src/rpc/publickey.3 (added) * services/librpc/src/rpc/publickey.5 (added) * services/librpc/src/rpc/rpc.3 (added) * services/librpc/src/rpc/rpc.5 (added) * services/librpc/src/rpc/rpc_callmsg.c (added) * services/librpc/src/rpc/rpc_commondata.c (added) * services/librpc/src/rpc/rpc_dtablesize.c (added) * services/librpc/src/rpc/rpc_prot.c (added) * services/librpc/src/rpc/rpc_secure.3 (added) * services/librpc/src/rpc/rpcdname.c (added) * services/librpc/src/rpc/rstat.1 (added) * services/librpc/src/rpc/rstat_svc.8 (added) * services/librpc/src/rpc/rtems_portmapper.c (added) * services/librpc/src/rpc/rtems_rpc.c (added) * services/librpc/src/rpc/rtime.3 (added) * services/librpc/src/rpc/rtime.c (added) * services/librpc/src/rpc/svc.c (added) * services/librpc/src/rpc/svc_auth.c (added) * services/librpc/src/rpc/svc_auth_unix.c (added) * services/librpc/src/rpc/svc_raw.c (added) * services/librpc/src/rpc/svc_run.c (added) * services/librpc/src/rpc/svc_simple.c (added) * services/librpc/src/rpc/svc_tcp.c (added) * services/librpc/src/rpc/svc_udp.c (added) * services/librpc/src/xdr/xdr.3 (added) * services/librpc/src/xdr/xdr.c (added) * services/librpc/src/xdr/xdr_array.c (added) * services/librpc/src/xdr/xdr_float.c (added) * services/librpc/src/xdr/xdr_mem.c (added) * services/librpc/src/xdr/xdr_rec.c (added) * services/librpc/src/xdr/xdr_reference.c (added) * services/librpc/src/xdr/xdr_sizeof.c (added) * services/librpc/src/xdr/xdr_stdio.c (added) librpc: Initial addition This does not currently compile. There is ... Fri, 03 Aug 2012 13:40:27 GMT Joel Sherrill [116c6cf] * freebsd-userspace/rtems/include/netdb.h (moved) * services/ftpfs/Makefile (added) * services/ftpfs/ftpfs.c (added) * services/ftpfs/include/rtems/ftpfs.h (added) ftpfs: Add to services Sat, 28 Jul 2012 12:11:15 GMT Joel Sherrill [ebf411c] * services/Makefile (modified) Makefile: Add telnetd and ftpd Sat, 28 Jul 2012 12:10:41 GMT Joel Sherrill [ff43f5d] * services/telnetd/Makefile (added) * services/telnetd/README (added) * services/telnetd/check_passwd.c (added) * services/telnetd/des.c (added) * services/telnetd/genpw.c (added) * services/telnetd/include/passwd.h (added) * services/telnetd/include/rtems/pty.h (added) * services/telnetd/include/rtems/telnetd.h (added) * services/telnetd/pty.c (added) * services/telnetd/telnetd.c (added) telnetd: Added from old stack Sat, 28 Jul 2012 12:09:54 GMT Joel Sherrill [f415cbb] * services/ftpd/Makefile (added) * services/ftpd/ftpd.c (added) * services/ftpd/ftpd.h (added) ftpd: Added from old stack Sat, 28 Jul 2012 10:58:03 GMT Joel Sherrill [a3dc1f0] * services/mghttpd/Makefile (modified) Makefile: install mongoose.h under rtems/ Fri, 27 Jul 2012 13:03:55 GMT Joel Sherrill [2cbf1af] * services/Makefile (added) * services/mghttpd/Makefile (added) * services/mghttpd/mongoose.1 (added) * services/mghttpd/mongoose.c (added) * services/mghttpd/mongoose.h (added) mghttpd: Add services directory with mghttpd as first
