@761956d
10/24/13 14:39:51 |
Sebastian Huber |
MUTEX(9): Use priority inheritance protocol
4.1155-freebsd-126-freebsd-12freebsd-9.3
@e859231
10/24/13 14:38:58 |
Sebastian Huber |
Add TODO for priority values
@2208c40
10/24/13 09:50:40 |
Sebastian Huber |
Remove includes in <machine/rtems-bsd-config.h>
@bc6daba
10/24/13 09:43:15 |
Sebastian Huber |
Delete psignal() definition
@53441c0
10/24/13 09:37:44 |
Sebastian Huber |
Move pause() define to <sys/systm.h>
@c8a0f76
10/24/13 09:36:58 |
Sebastian Huber |
Include missing header file
@46ffd72
10/24/13 09:36:40 |
Sebastian Huber |
@b3193b8
10/24/13 09:36:09 |
Sebastian Huber |
Move strdup() define to <sys/libkern.h>
@e2281af
10/24/13 09:25:33 |
Sebastian Huber |
Move integer type definitions
@150d4d6
10/24/13 09:11:32 |
Sebastian Huber |
Move content to new <machine/rtems-bsd-support.h>
@de3ef24
10/24/13 08:52:40 |
Sebastian Huber |
Move cpu_spinwait() definition
@1bc2756
10/24/13 08:51:38 |
Sebastian Huber |
Add TODO item
@12b57ad
10/24/13 08:44:22 |
Sebastian Huber |
Move malloc defines to <sys/malloc.h>
@6cdf009
10/24/13 08:39:07 |
Sebastian Huber |
Remove setenv() declaration (conficts <stdlib.h>)
@40f2158a
10/24/13 08:36:52 |
Sebastian Huber |
Remove abs() and labs() definitions
Confict with <stdlib.h>.
@99378e2
10/24/13 08:29:30 |
Sebastian Huber |
Remove gets() declaration (conflicts <stdio.h>)
@8109ef3
10/24/13 08:21:02 |
Sebastian Huber |
Remove superfluous undefs
@ea49a89
10/24/13 08:17:20 |
Sebastian Huber |
Move ticks definition
@5d288bc
10/24/13 06:55:46 |
Sebastian Huber |
Use compile-time constants for exactly one CPU
@f9c2714
10/23/13 07:47:09 |
Sebastian Huber |
SLEEP(8): New implementation
@24732b6
10/22/13 11:41:23 |
Sebastian Huber |
Rename file to reflect FreeBSD origin
@616f6000
10/22/13 08:55:49 |
Sebastian Huber |
Map <sys/md5.h> to RTEMS <md5.h>
@43148f0
10/18/13 13:56:31 |
Sebastian Huber |
IFCONFIG(8): Avoid JAIL(3)
@cdf6024
10/21/13 11:57:22 |
Sebastian Huber |
Add MAC support functions
WARNING: They are not thread-safe! This is …
@ffcd542
10/18/13 12:12:17 |
Sebastian Huber |
Move TIMEOUT(9) and ZONE(9) initialization
Delete most of virtual …
@a9be4b0
10/17/13 13:30:31 |
Sebastian Huber |
Move shell items to separate file
@d01564c
10/17/13 08:38:34 |
Sebastian Huber |
Move program control to thread structure
@c804e500
10/17/13 08:31:30 |
Sebastian Huber |
Update from latest FreeBSD version
@57f2002
10/15/13 13:36:59 |
Sebastian Huber |
Add sysctl(), etc. prototypes
@9d9bfaf
10/14/13 14:14:19 |
Sebastian Huber |
Use send/recv functions from FreeBSD
Use recvfrom(), recvmsg(), …
@ec702ab
10/14/13 12:55:04 |
Sebastian Huber |
Use socket read() and write() from FreeBSD
@8989c11
10/14/13 11:24:10 |
Sebastian Huber |
Use getsockname() from FreeBSD
@0beab1e
10/14/13 11:09:15 |
Sebastian Huber |
Use getpeername() from FreeBSD
@ac78dd2
10/14/13 10:53:43 |
Sebastian Huber |
Use getsockopt() and setsockopt() from FreeBSD
@7c2b59c
10/14/13 09:41:14 |
Sebastian Huber |
Use accept() from FreeBSD
@7c36251
10/14/13 08:04:29 |
Sebastian Huber |
Use listen() from FreeBSD
@6676de4
10/14/13 07:48:56 |
Sebastian Huber |
Use connect() from FreeBSD
@468b08e
10/11/13 14:44:48 |
Sebastian Huber |
Use bind() from FreeBSD
@6ffb9b9
10/11/13 12:48:13 |
Sebastian Huber |
Use shutdown() from FreeBSD
@609df33
10/11/13 11:20:26 |
Sebastian Huber |
Use send() and recv() from FreeBSD
@caf8ede
10/10/13 09:29:33 |
Sebastian Huber |
Import socket() implementation from FreeBSD
Add new test syscalls01.
@69b29a0
10/10/13 14:11:02 |
Sebastian Huber |
Disable user credentials and use default values
@cc5f4b2
10/10/13 13:00:20 |
Sebastian Huber |
Use default PID value for all process identifiers
@549488b
10/10/13 12:45:09 |
Sebastian Huber |
Disable alternative routing tables
@3842b81
10/10/13 12:33:05 |
Sebastian Huber |
Delete struct proc p_mtx lock
Usage of this lock is highly dangerous …
@db2e97f
10/14/13 13:01:13 |
Sebastian Huber |
Disable cold boot indicator
@c9db0f5
10/10/13 11:27:01 |
Sebastian Huber |
Use RTEMS API for file handling
@032b3b7
10/11/13 13:08:39 |
Sebastian Huber |
Use Newlib provided <sys/fcntl.h>
@ebabe9b
10/10/13 08:30:04 |
Sebastian Huber |
Import <sys/sysproto.h> from FreeBSD
@cd75897
10/10/13 09:32:42 |
Sebastian Huber |
Import <security/audit/audit.h> from FreeBSD
@3931b6e
10/10/13 11:23:44 |
Sebastian Huber |
Provide socklen_t, use size_t for socklen_t
@a434fc8
10/10/13 09:28:11 |
Sebastian Huber |
Add empty files
@ab415f9
10/09/13 06:56:49 |
Sebastian Huber |
Use extension to attach a struct thread to threads
Add test thread01.
@f3b2913
10/09/13 12:29:38 |
Sebastian Huber |
Move core system initialization references
@a9f141a
10/09/13 07:00:44 |
Sebastian Huber |
Change license to BSD
@e599318
10/09/13 20:52:54 |
Sebastian Huber |
Update files to match FreeBSD layout
Add compatibility with Newlib …
@bceabc9
10/09/13 20:42:09 |
Sebastian Huber |
Move files to match FreeBSD layout
@82800c5
09/20/13 14:30:30 |
Sebastian Huber |
Update due to header file changes
@83cb10f
09/20/13 14:08:34 |
Sebastian Huber |
There is no main thread in RTEMS
The resolv module has a questionable …
@937461c
09/20/13 13:09:10 |
Sebastian Huber |
Avoid per-CPU features
@473437c
09/20/13 13:01:27 |
Sebastian Huber |
@a3dde3e
09/20/13 10:52:44 |
Sebastian Huber |
Update due to Newlib <sys/cdefs.h> changes
@0bde19e
11/26/12 15:47:09 |
Jennifer Averett |
Switch to a version of select that is closer to bsd's version.
@9d3ac2b
11/26/12 15:24:57 |
Jennifer Averett |
Add custom limits.h and timespec.h
These will be needed for added a …
@0bc8807
11/05/12 15:15:12 |
Sebastian Huber |
CAM: Update due to API changes
@cb50354
10/24/12 20:01:23 |
Jennifer Averett |
_sx_xlock(): Added check for not in interrupt.
@8ddbc30
10/23/12 19:21:34 |
Joel Sherrill |
rtems-bsd-sx.c: Disable check for interruptible blocking until it is …
@7b43b62
10/22/12 15:55:05 |
Joel Sherrill |
rtems-bsd-symbols.h: Do not hide sysctlbyname().
@d4ceffb
10/11/12 13:32:10 |
Jennifer Averett |
rtems-bsd-symbols.h: Add _bsd_ipsec_set_policy.
@45a81cd
10/05/12 14:34:09 |
Jennifer Averett |
Added rtems specific version of _pthread_main_np()
This required …
@a4e4484
09/12/12 15:51:59 |
Jennifer Averett |
rtems-bsd-config.h.in: Added defines for O_NOFOLLOW and O_SHLOCK
@1dff51a
09/11/12 21:02:41 |
Joel Sherrill |
freebsd/bsd.h: Add include of freebsd/machine/_align.h
Multiple files …
@33c9336
09/10/12 21:45:30 |
Joel Sherrill |
rtems-bsd-sysctl.c: Formatting corrections
@b00e8b2
09/10/12 21:45:07 |
Joel Sherrill |
rtems-bsd-symbols.h: sysctl() should be a public symbol
@14d4d7a
09/06/12 18:05:53 |
Joel Sherrill |
rtems-bsd-config.h.in: Add FreeBSD macros missing in RTEMS
The …
@132ec81
09/06/12 15:33:53 |
Joel Sherrill |
rtems-bsd-config.h.in: Do not undef P or strong_reference
@ab9e6de
09/05/12 18:12:37 |
Joel Sherrill |
rtems-bsd-vm_glue.c: Add include of <freebsd/sys/types.h>
@f80f90f
09/05/12 18:03:19 |
Joel Sherrill |
rtems-bsd-rwlock.c: Do not redefine pthread_rwlock_t
@ccffd2b
09/05/12 17:55:51 |
Joel Sherrill |
rtemsbsd/freebsd/sys/uio.h: New wrapper for <sys/uio.h>
@582aa1b
09/05/12 17:55:24 |
Joel Sherrill |
rtemsbsd/freebsd/sys/signalvar.h: stub file
@b65a44a
09/05/12 17:54:49 |
Joel Sherrill |
rtemsbsd/freebsd/sys/signal.h: New wrapper for <sys/signal.h>
@336883b
09/05/12 17:54:28 |
Joel Sherrill |
rtemsbsd/freebsd/sys/cdefs.h: New wrapper for <sys/cdefs.h>
@3b4d5c4
09/05/12 17:46:28 |
Joel Sherrill |
rtems-bsd-config.h.in: Assume <sys/cdefs.h> is OK to use
This is part …
@f333955
08/31/12 23:50:17 |
Joel Sherrill |
Build System: Add option to disable IPV6 in orderly fashion
If you …
@9ae87c2
08/24/12 20:17:35 |
Joel Sherrill |
rtems-bsd-config.h: IPV6 enabled by default. Make consistent with Makefile
@659d7ad
08/24/12 20:15:04 |
Joel Sherrill |
Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd
@bb753bf
08/24/12 20:14:32 |
Joel Sherrill |
rtems-bsd-config.h: Add NEW_RTEMS_BSD until machine/param.h in …
@c2da78d
08/24/12 19:42:03 |
Jennifer Averett |
Fixed return values for jail methods.
@bd6dd6e
07/27/12 12:45:06 |
Joel Sherrill |
net-setup: Add routing and old stack's configuration
This allows the …
@2c3d8b9
07/20/12 19:17:05 |
Jennifer Averett |
Added rtems specific page tracking methods for uma page allocation.
@8fa929e
07/18/12 16:43:05 |
Jennifer Averett |
Added more initialization of FIXME_ucred elements.
@e4f2591
07/18/12 16:42:04 |
Jennifer Averett |
Fixed rtems_bsdnet_makeFdForSocket to work with file system change.
@21cc0aa
07/18/12 16:40:30 |
Jennifer Averett |
Added initilization of pcpu info for cpu0.
@325120c
07/17/12 13:20:46 |
Jennifer Averett |
Fix curthread so it returns a valid value.
@9ee8629
07/17/12 13:19:04 |
Jennifer Averett |
Restructure init and add more detailed initialization.
@db280c9
07/17/12 13:17:55 |
Jennifer Averett |
Add call to uma_startup2 so that booted gets set.
@e43b452
07/14/12 17:15:57 |
Joel Sherrill |
Makefile: Use MIPS generic in_cksum when no target specific …
@5cf6031
07/14/12 15:40:40 |
Joel Sherrill |
rtems-bsd-nexus.c: Always include rtems/irq-extension.h
@b0b2e0e
07/13/12 16:40:48 |
Joel Sherrill |
Add stub cpu_func.h files for all other RTEMS targets
@8fe603a
07/13/12 16:29:43 |
soh_cah_toa |
Readd MIPS cpu specific .h files
At least 80 files in this tree have …
