@71a0436
10/24/16 11:29:03 |
Sebastian Huber |
Add thread fences to <machine/atomic.h>
55-freebsd-126-freebsd-12freebsd-9.3
@520ab22
06/28/16 06:35:06 |
Sebastian Huber |
Modify rtems_bsd_set_vprintf_handler()
Return previous …
@6ff1baa
10/27/16 06:30:37 |
Sebastian Huber |
Add empty <machine/_kernel_lock.h>
@8b0bcb8
11/09/16 07:53:20 |
Sebastian Huber |
rtems-bsd-mutex: Optimize
Inline SMP lock acquire/release. Avoid …
@0b08247
11/03/16 10:18:27 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
@ade8f56
10/26/16 12:04:36 |
Sebastian Huber |
devfs: Fix includes
@632e278
10/21/16 09:05:29 |
Christian.Mauderer |
rtemsbsd: Add reallocf to rtems_bsd_program.
@0ba4197
10/24/16 06:07:56 |
Sebastian Huber |
Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h>
@f0aaa04
10/21/16 13:38:58 |
Sebastian Huber |
Provide CLOCK_MONOTONIC_FAST
@390e133
10/24/16 06:02:13 |
Sebastian Huber |
Make <machine/atomic.h> available to user space
Enables use of …
@f5f9e16
10/07/16 05:24:02 |
Sebastian Huber |
nexus-devices: Support arm/lpc24xx
@e11f8e3
10/07/16 05:09:48 |
Sebastian Huber |
ohci: Fixes due to USB stack update
@e3881ee
09/28/16 13:34:46 |
Sebastian Huber |
nexus-devices: Add arm/atsamv BSP section
@8eb8883
09/28/16 13:00:00 |
Sebastian Huber |
Split rtemsbsd/rtems/rtems-program.c
This improves garbage collection …
@10e9e05
09/28/16 12:46:55 |
Sebastian Huber |
Split rtems-bsd-kernel-program.c
Separate kernel and user space parts.
@d9fe061
09/28/16 11:23:16 |
Sebastian Huber |
Split rtems-bsd-shell-netcmds.c
This improves garbage collection by …
@2c563ed
09/23/16 07:54:49 |
Sebastian Huber |
if_ffec_mcf548x.c: Fix include order
@02d344f4
09/22/16 05:22:42 |
Sebastian Huber |
@2c44b51
09/22/16 05:21:54 |
Sebastian Huber |
Use _Thread_Get_priority()
@8e65e1b
08/23/16 13:51:45 |
Sebastian Huber |
usb: Update to FreeBSD trunk 2016-08-23
FreeBSD trunk, 2016-08-23, …
@0c24e06
08/23/16 12:22:26 |
Sebastian Huber |
mmc: Update to FreeBSD trunk 2016-08-23
@6634edb
08/16/16 06:52:06 |
devfs: Create path.
@ab7739a
08/12/16 03:55:37 |
Chris Johns |
rc.conf/net: Let interface option appear on a DHCP ifconfig_ line.
An …
@c83cf5c
08/12/16 02:19:48 |
Chris Johns |
nfsclient: Only parse for options when present.
@691ed15
08/11/16 07:01:42 |
Sebastian Huber |
rtems-bsd-mutex: Use _Thread_queue_Surrender()
@bc9e939
08/04/16 11:20:04 |
pf: Add configuration via rc.conf.
@61e2e1b
08/08/16 13:53:39 |
rc.conf: Use more stack for the rc worker.
Most of the tests run with …
@32a3dd1
08/04/16 06:02:24 |
pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options.
@0717607
08/05/16 10:00:47 |
if_ffec_mcf548x: Init when interface is set to UP.
Call the driver …
@2fb3a36
08/04/16 12:12:17 |
freebsd: Add constant ipv6 addresses from vars.c.
This is necessary …
@7f86f6a
07/22/16 12:49:49 |
pfctl: Add rtems_bsd_command_pfctl.
@d31a365
07/14/16 09:01:43 |
rtemsbsd: Add wrapper for open, fopen, malloc, ...
Add the following …
@3d91340
07/15/16 09:39:48 |
rtemsbsd: Add call to program with a data restore
This adds the …
@a9bd422
06/27/16 12:29:53 |
testsuite/pf01: Add test that links PF.
@9a01ebf
06/28/16 15:27:08 |
kern_conf.c: Adapt for RTEMS.
@b5db332
06/30/16 05:55:27 |
rtemsbsd/devfs: Add.
@bf7faad
06/28/16 06:32:30 |
Sebastian Huber |
@e5aa554
07/27/16 06:51:53 |
Sebastian Huber |
@9510012
07/18/16 22:12:17 |
Chris Johns |
config: Fix telnetd configuration warning.
@761ae78
06/30/16 03:32:29 |
Chris Johns |
Make the license message viewable with a verbose option.
The license …
@34f6271
07/01/16 06:43:56 |
Chris Johns |
Provide empty RTEMS_BSD_CFGDECL_.* defines if not used.
@65c65bb
07/01/16 05:49:52 |
Chris Johns |
Add telnetd as service to rc.conf.
@fc26479
06/30/16 03:35:37 |
Chris Johns |
Add ftpd initailize comment.
@f01b1f72
06/30/16 01:42:49 |
Chris Johns |
Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE.
The domain allocator …
@dc5b267
06/29/16 23:25:13 |
Chris Johns |
Fix wording and spelling.
@573b1982
06/29/16 23:19:52 |
Chris Johns |
Add DHCP support to rc.conf.
@912b685
06/29/16 23:19:06 |
Chris Johns |
Make the LibBSD PID match getpid().
@c980a04
06/29/16 23:18:21 |
Chris Johns |
Fix fomatting and C++ guard.
@45960a3
06/29/16 23:17:21 |
Chris Johns |
Add rtems_get_route to fetch a specific route from the routing tables.
@4a2b844
06/29/16 23:14:55 |
Chris Johns |
Default syslog priority to INFO. Add rtems_setlogpriority to configure …
@90873cc
06/28/16 03:32:01 |
Chris Johns |
Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up.
@c2ec5f1
06/28/16 03:31:11 |
Chris Johns |
Print the service when starting.
@f588325
06/28/16 03:30:44 |
Chris Johns |
Change the Nexus bus to defines and have the BSP declare them.
@459d67d
06/27/16 03:35:08 |
Chris Johns |
Move the Nexus bus driver decls available to users.
@55c564a
06/27/16 03:24:43 |
Chris Johns |
Refactor rc.conf processing to be services based.
@b23da31
06/27/16 03:12:06 |
Chris Johns |
Change LibBSD to use shared interrupts.
@130fa35
06/27/16 03:09:04 |
Chris Johns |
Make the domain allocation size global to allow it to set in tests.
@a0e49f9
06/27/16 03:07:54 |
Chris Johns |
Add functions used the bridge and tap interfaces.
@32fd702
06/23/16 12:06:21 |
Sebastian Huber |
Update due to RTEMS printer API changes
@58c4e1c5
06/10/16 12:11:40 |
Sebastian Huber |
nfsclient: Port to LibBSD
@4464594
06/09/16 09:31:27 |
Sebastian Huber |
nfsclient: Import from RTEMS
RTEMS Git commit …
@68d406b
06/09/16 09:19:09 |
Sebastian Huber |
ftpfs: Import from RTEMS
RTEMS Git commit …
@70d52b8
05/30/16 14:05:15 |
Sebastian Huber |
@04762cf
04/27/16 08:28:49 |
Sebastian Huber |
Directly use <machine/endian.h> provided by Newlib
@b6f6deb
04/27/16 08:26:50 |
Sebastian Huber |
Directly use <sys/_types.h> provided by Newlib
@3d1e767
04/27/16 08:25:22 |
Sebastian Huber |
Directly use <sys/types.h> provided by Newlib
@2017a6d
04/07/16 07:48:12 |
Sebastian Huber |
Directly use <sys/time.h> provided by Newlib
@f575822
05/30/16 14:00:25 |
Sebastian Huber |
rtems-bsd-rc-conf.h: Add missing include
@43a14eb
05/25/16 11:11:59 |
Sebastian Huber |
@9546d90
05/25/16 11:09:58 |
Sebastian Huber |
@d8e6b4c
05/18/16 09:03:39 |
Chris Johns |
rc.conf: Add the net directives by default.
@84665b5
05/18/16 09:03:20 |
Chris Johns |
rc.conf: Fix the wild card regex for ifconfig_
@f9fa038
05/18/16 05:21:09 |
Chris Johns |
Fix memory leak in rc.conf processing.
@05d47ae
05/18/16 05:20:36 |
Chris Johns |
Clean up whitespace.
@f5c6651
05/18/16 03:49:17 |
Chris Johns |
Add support for rc.conf(5) initialisation.
Provide user support for …
@5b4394f
05/06/16 19:40:49 |
Sebastian Huber |
Add namespace support for kvm
@5b1f20b
05/06/16 19:22:38 |
Sebastian Huber |
Rename files for kernel namespace script
This makes it easier to …
@81e5ff4
05/06/16 12:49:15 |
Sebastian Huber |
Add kernel namespace exception for mbstat
@edb5e4b
05/06/16 12:32:58 |
Sebastian Huber |
Add kernel namespace exceptions
These names correspond to sysctls.
@b8f127e
05/06/16 12:10:40 |
Sebastian Huber |
Update kernel namespace
@54a577d
05/04/16 11:04:42 |
Sebastian Huber |
subr_prf.c: Port to RTEMS
@0f5dd1c
05/06/16 05:27:25 |
Sebastian Huber |
Add script to create the kernel namespace header
@83eb07c
05/06/16 05:06:08 |
Chris Johns |
Add sbin/sysctl
@e58b898
04/28/16 08:29:55 |
Sebastian Huber |
telnetd: Use syslog() instead of printk()
@4b127e7
05/04/16 06:01:08 |
Chris Johns |
Add RealTek? Gig PHY.
@b8d1fe0
04/27/16 03:22:04 |
Chris Johns |
pc386: Add RealTek? network driver to the nexus bus.
@5784e6d
04/27/16 07:45:26 |
Sebastian Huber |
rtems/bsd/bsd.h: Documentation
@5b93cc8
04/26/16 13:00:44 |
Sebastian Huber |
Add root bus support functions
@00c8792
10/30/15 07:03:57 |
Sebastian Huber |
Initialize interrupt server early
This enables its use before the …
@c5fde49
04/18/16 12:47:49 |
Sebastian Huber |
intrmask_t: Provide dummy type definition
@ce8c7bb
04/18/16 12:47:04 |
Sebastian Huber |
kvm: Include missing header file
@982f72f
04/18/16 12:45:19 |
Sebastian Huber |
syslog: Include missing header file
@42f085d
04/06/16 13:16:18 |
Sebastian Huber |
sys/time.h: Delete superfluous declaration
Provided by RTEMS …
@58c1bf6
04/06/16 12:55:56 |
Sebastian Huber |
@c5abeb5
04/06/16 12:54:32 |
Sebastian Huber |
rtems-bsd-mutex: Fix mtx_destroy()
@652b024
03/18/16 09:35:42 |
Sebastian Huber |
ftpd: Resolve function name conflict
Visible with Newlib …
@a336c46
03/14/16 08:25:04 |
Sebastian Huber |
Update due to Watchdog Handler changes
@9f81109
01/18/16 11:17:46 |
Sebastian Huber |
Update due to chain API changes
@d5b64f2
11/17/15 13:42:28 |
Sebastian Huber |
Use RTEMS provided <sys/endian.h>
@dd96574
11/16/15 08:51:44 |
Sebastian Huber |
SOCKETPAIR(2): Port to RTEMS
