# # ChangeLog for rtems_waf in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/18/24 03:18:29 Sat, 09 Jul 2016 04:43:03 GMT Chris Johns [ac0e5bf] * rtems_waf (modified) Update to bring in the --show-commands fix. Mon, 20 Jun 2016 00:07:08 GMT Chris Johns [628512a] * rtems_waf (modified) Update rtems_waf to pick up the long command line fix. Thu, 16 Jun 2016 07:08:37 GMT Chris Johns [616be5c] * rtems_waf (modified) Pick up white space fix. Thu, 16 Jun 2016 03:32:28 GMT Chris Johns [32ceb14] * libbsd_waf.py (modified) * rtems_waf (modified) * waf_generator.py (modified) * wscript (modified) Add support for long command lines and fix some shell rules on Windows. Wed, 11 May 2016 02:22:29 GMT Chris Johns [ac7b68c] * rtems_waf (modified) Get rtems_waf fix for command expansion. Sat, 07 May 2016 05:32:44 GMT Chris Johns [44a82d0] * rtems_waf (modified) Update rtems_waf with the latest fixes. Mon, 18 Apr 2016 01:07:14 GMT Chris Johns [68bf405] * README.waf (modified) * rtems_waf (modified) Update the rtems_waf submodule. Mon, 18 Apr 2016 00:53:20 GMT Chris Johns [97c5024a] * README.waf (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtems_waf (modified) * waf_generator.py (modified) * wscript (modified) Add RTEMS version support, update all python to 2 and 3. Add ... Mon, 16 Nov 2015 06:32:51 GMT Sebastian Huber [330f9886] * rtems_waf (modified) Update rtems_waf module for msys2 support Fri, 13 Nov 2015 12:03:17 GMT Sebastian Huber [d639c30] * rtems_waf (modified) Update rtems_waf module for Python 3 compatibility Fri, 13 Nov 2015 10:19:37 GMT Sebastian Huber [7385d4a] * rtems_waf (modified) Update rtems_waf module for msys2 support Fri, 13 Nov 2015 09:58:45 GMT Sebastian Huber [a76483d] * rtems_waf (modified) * waf_generator.py (modified) * wscript (modified) Use latest rtems_waf Wed, 20 May 2015 07:45:16 GMT Chris Johns [5ba6949] * .gitignore (modified) * .gitmodules (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * rtems_waf (added) * waf_generator.py (added) Add support to build using waf.
