# # ChangeLog for mDNSResponder in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/25/24 00:40:13 Tue, 16 Oct 2018 09:24:10 GMT Sebastian Huber [91b858d] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) mDNSResponder: Fix use of uninitialized variables Tue, 02 Oct 2018 05:07:05 GMT Sebastian Huber [446f887] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) mDNSResponder: Do not use SO_RECV_ANYIF socket opt This socket ... Wed, 19 Sep 2018 06:57:22 GMT Sebastian Huber [2723609] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.h (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.30.4 The sources can be obtained via: ... Wed, 19 Sep 2018 06:56:44 GMT Sebastian Huber [1e55d820] * mDNSResponder/Clients/dnssdutil.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.20.3 The sources can be obtained via: ... Wed, 19 Sep 2018 06:56:09 GMT Sebastian Huber [4c086a2] * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnssdutil.c (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/TXT.rtf (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnsproxy.h (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec.c (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.h (modified) * mDNSResponder/mDNSMacOSX/BLE.c (modified) * mDNSResponder/mDNSMacOSX/BLE.h (modified) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (modified) * mDNSResponder/mDNSMacOSX/BonjourTop/BonjourTop.xcodeproj/project.pbxproj (added) * mDNSResponder/mDNSMacOSX/BonjourTop/BonjourTop.xcodeproj/project.xcworkspace/contents.xcworkspacedata (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1 (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CaptureFile.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CaptureFile.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CollectBy.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CollectBy.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/DNSFrame.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/DNSFrame.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/Frame.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/Frame.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/LLRBTree.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/LLRBTree.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjIPAddr.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjIPAddr.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjMACAddr.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjMACAddr.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjStringtoStringMap.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjStringtoStringMap.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjsocket.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjsocket.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjstring.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjstring.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjtypes.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/main.cpp (added) * mDNSResponder/mDNSMacOSX/D2D.c (added) * mDNSResponder/mDNSMacOSX/D2D.h (added) * mDNSResponder/mDNSMacOSX/DNS64.c (added) * mDNSResponder/mDNSMacOSX/DNS64.h (added) * mDNSResponder/mDNSMacOSX/DNS64State.h (added) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/CNDomainBrowserPathUtils.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/CNDomainBrowserPathUtils.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/_CNDomainBrowser.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/_CNDomainBrowser.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/CNDomainBrowserViewController.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/CNDomainBrowserViewController.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/DomainBrowser.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/DomainBrowser.strings (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/Info.plist (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/CNDomainBrowserView.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/CNDomainBrowserView.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/DomainBrowser.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/Info.plist (added) * mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/add_idle.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/add_pressed.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_disabled.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_idle.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_pressed.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Base.lproj/DNSServiceDiscoveryPref.nib/designable.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Base.lproj/DNSServiceDiscoveryPref.nib/keyedobjects.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefTool-Info.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefTool.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefTool.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefToolProtocol.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/entitlements.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/main.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.c (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.h (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/classes.nib (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/info.nib (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/keyedobjects.nib (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Info-PreferencePane.plist (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.h (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/BonjourPrefRemoteViewService-Info.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/BonjourPrefRemoteViewService.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/BonjourPrefRemoteViewService.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/InfoPlist.strings (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/entitlements.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/main.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ddnswriteconfig.m (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/installtool (deleted) * mDNSResponder/mDNSMacOSX/Private/dnsctl_server.c (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/Contents.json (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/UIPreferencesBlueCheck.imageset/Contents.json (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/UIPreferencesBlueCheck.imageset/UIPreferencesBlueCheck.png (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/UIPreferencesBlueCheck.imageset/UIPreferencesBlueCheck@2x.png (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourConstants.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSCStore.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSCStore.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSettingsController.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSettingsController.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/CNBrowseDomainsController.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/CNBrowseDomainsController.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/HostnameController.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/HostnameController.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Info.plist (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Localizable.strings (added) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (modified) * mDNSResponder/mDNSMacOSX/coreBLE.h (modified) * mDNSResponder/mDNSMacOSX/coreBLE.m (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSNetMonitor/mDNSNetMonitor.8 (added) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-xcodeproj-explanation.txt (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (modified) * mDNSResponder/mDNSPosix/ExampleClientApp.c (modified) * mDNSResponder/mDNSPosix/NetMonitor.c (modified) * mDNSResponder/mDNSPosix/PosixDaemon.c (modified) * mDNSResponder/mDNSPosix/ProxyResponder.c (modified) * mDNSResponder/mDNSPosix/Responder.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dns_sd_internal.h (added) * mDNSResponder/mDNSShared/dns_sd_private.h (moved) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSVxWorks/mDNSVxWorks.c (modified) * mDNSResponder/mDNSVxWorks/mDNSVxWorksIPv4Only.c (modified) * mDNSResponder/mDNSWindows/BonjourQuickLooks.sln (added) * mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj (added) * mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/Product.wxs (added) * mDNSResponder/mDNSWindows/WinVersRes.h (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) * mDNSResponder/unittests/CNameRecordTests.c (added) * mDNSResponder/unittests/CNameRecordTests.h (added) * mDNSResponder/unittests/LocalOnlyTimeoutTests.c (added) * mDNSResponder/unittests/LocalOnlyTimeoutTests.h (added) * mDNSResponder/unittests/ResourceRecordTest.c (modified) * mDNSResponder/unittests/daemon_ut.c (added) * mDNSResponder/unittests/mDNSCoreReceiveTest.c (added) * mDNSResponder/unittests/mDNSCoreReceiveTest.h (added) * mDNSResponder/unittests/main.c (modified) * mDNSResponder/unittests/mdns_macosx_ut.c (added) * mDNSResponder/unittests/mdns_ut.c (added) * mDNSResponder/unittests/uds_daemon_ut.c (added) * mDNSResponder/unittests/unittest.h (modified) * mDNSResponder/unittests/unittest_common.c (added) * mDNSResponder/unittests/unittest_common.h (added) mDNSResponder: Update to v878.1.1 The sources can be obtained via: ... Wed, 19 Sep 2018 06:55:35 GMT Sebastian Huber [a814950] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnsproxy.h (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) mDNSResponder: Update to v765.50.9 The sources can be obtained via: ... Wed, 19 Sep 2018 06:54:52 GMT Sebastian Huber [7d33d36] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSPosix/Responder.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) mDNSResponder: Update to v765.30.11 The sources can be obtained ... Wed, 19 Sep 2018 06:54:13 GMT Sebastian Huber [fc605b3] * mDNSResponder/.gitignore (added) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) mDNSResponder: Update to v765.20.4 The sources can be obtained via: ... Wed, 19 Sep 2018 06:53:26 GMT Sebastian Huber [f01edf1] * libbsd.py (modified) * mDNSResponder/Clients/ClientCommon.c (modified) * mDNSResponder/Clients/Java/nmakefile (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/52D711AF-4055-4867-A494-7E31552BB9E1.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/Screen Shot 2015-09-16 at 3.36.23 PM.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/Screen Shot 2015-09-16 at 3.46.14 PM.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/TXT.rtf (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/unknown.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/A944EB40-AEFD-4CA1-BF10-E8F52835CA8C.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/Screen Shot 2015-09-16 at 4.22.37 PM.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/TXT.rtf (added) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.h (modified) * mDNSResponder/mDNSMacOSX/BLE.c (added) * mDNSResponder/mDNSMacOSX/BLE.h (added) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryDefines.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryReply.defs (deleted) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryRequest.defs (deleted) * mDNSResponder/mDNSMacOSX/Metrics.h (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.c (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.c (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (modified) * mDNSResponder/mDNSMacOSX/Private/com.apple.mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/Private/dns_sd_private.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_xpc.h (modified) * mDNSResponder/mDNSMacOSX/Private/dnsctl_server.c (added) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.h (modified) * mDNSResponder/mDNSMacOSX/SymptomReporter.c (modified) * mDNSResponder/mDNSMacOSX/com.apple.dnsextd.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponder.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.networking.mDNSResponder (deleted) * mDNSResponder/mDNSMacOSX/coreBLE.h (added) * mDNSResponder/mDNSMacOSX/coreBLE.m (added) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/dnsctl-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/helper-error.h (deleted) * mDNSResponder/mDNSMacOSX/helper-main.c (modified) * mDNSResponder/mDNSMacOSX/helper-server.h (modified) * mDNSResponder/mDNSMacOSX/helper-stubs.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/helper.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg-types.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg.defs (deleted) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/xcshareddata/xcschemes/Build All.xcscheme (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/xcshareddata/xcschemes/mDNSResponder.xcscheme (added) * mDNSResponder/mDNSMacOSX/mDNSResponderLogging.mobileconfig (deleted) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (modified) * mDNSResponder/mDNSPosix/._ReadMe.txt (deleted) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/ReadMe.txt (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mdnsd.sh (modified) * mDNSResponder/mDNSPosix/nss_mdns.c (modified) * mDNSResponder/mDNSShared/PlatformCommon.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSWindows/ControlPanel/ConfigPropertySheet.cpp (modified) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.cpp (modified) * mDNSResponder/mDNSWindows/ControlPanel/FourthPage.cpp (modified) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.cpp (modified) * mDNSResponder/mDNSWindows/DLLX/DNSSD.cpp (modified) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/ChooserDialog.cpp (modified) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/BrowserDialog.cpp (modified) * mDNSResponder/mDNSWindows/Java/makefile (modified) * mDNSResponder/mDNSWindows/Java/makefile64 (modified) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.c (modified) * mDNSResponder/mDNSWindows/SystemService/Service.c (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.c (modified) * mDNSResponder/unittests/DNSMessageTest.c (added) * mDNSResponder/unittests/DNSMessageTest.h (added) * mDNSResponder/unittests/DomainNameTest.c (added) * mDNSResponder/unittests/DomainNameTest.h (added) * mDNSResponder/unittests/InterfaceTest.c (added) * mDNSResponder/unittests/InterfaceTest.h (added) * mDNSResponder/unittests/ResourceRecordTest.c (added) * mDNSResponder/unittests/ResourceRecordTest.h (added) * mDNSResponder/unittests/main.c (added) * mDNSResponder/unittests/unittest.c (added) * mDNSResponder/unittests/unittest.h (added) * rtemsbsd/mdns/mDNSResolveService.c (added) mDNSResponder: Update to v765.1.2 The sources can be obtained via: ... Wed, 19 Sep 2018 06:52:21 GMT Sebastian Huber [f761b29] * mDNSResponder/.DS_Store (modified) * mDNSResponder/Clients/ClientCommon.c (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/CryptoAlg.c (modified) * mDNSResponder/mDNSCore/CryptoAlg.h (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/DNSDigest.c (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/anonymous.h (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnsproxy.h (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/dnssec.h (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSDebug.h (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec.c (modified) * mDNSResponder/mDNSCore/nsec.h (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/nsec3.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOS9/Mac OS Test Responder.c (deleted) * mDNSResponder/mDNSMacOS9/Mac OS Test Searcher.c (deleted) * mDNSResponder/mDNSMacOS9/README.txt (deleted) * mDNSResponder/mDNSMacOS9/Responder.c (deleted) * mDNSResponder/mDNSMacOS9/Searcher.c (deleted) * mDNSResponder/mDNSMacOS9/ShowInitIcon.c (deleted) * mDNSResponder/mDNSMacOS9/ShowInitIcon.h (deleted) * mDNSResponder/mDNSMacOS9/SubTypeTester.c (deleted) * mDNSResponder/mDNSMacOS9/mDNS.mcp (deleted) * mDNSResponder/mDNSMacOS9/mDNSLibrary.c (deleted) * mDNSResponder/mDNSMacOS9/mDNSLibraryLoader.c (deleted) * mDNSResponder/mDNSMacOS9/mDNSLibraryResources.r (deleted) * mDNSResponder/mDNSMacOS9/mDNSMacOS9.c (deleted) * mDNSResponder/mDNSMacOS9/mDNSMacOS9.h (deleted) * mDNSResponder/mDNSMacOS9/mDNSPrefix.h (deleted) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (modified) * mDNSResponder/mDNSMacOSX/CUPolicy.c (deleted) * mDNSResponder/mDNSMacOSX/CryptoSupport.c (modified) * mDNSResponder/mDNSMacOSX/CryptoSupport.h (modified) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryDefines.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryReply.defs (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryRequest.defs (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo-Tiger.helper.plist (deleted) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo-Tiger.plist (deleted) * mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.h (moved) * mDNSResponder/mDNSMacOSX/Metrics.m (added) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.c (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/InfoPlist.strings (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/ddnswriteconfig.m (modified) * mDNSResponder/mDNSMacOSX/Private/dns_sd_private.h (added) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_xpc.h (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/SymptomReporter.c (added) * mDNSResponder/mDNSMacOSX/VPNService.c (deleted) * mDNSResponder/mDNSMacOSX/base.xcconfig (deleted) * mDNSResponder/mDNSMacOSX/com.apple.dnsextd.plist (moved) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponder.plist (moved) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (moved) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper-error.h (modified) * mDNSResponder/mDNSMacOSX/helper-main.c (modified) * mDNSResponder/mDNSMacOSX/helper-server.h (modified) * mDNSResponder/mDNSMacOSX/helper-stubs.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/helper.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg-types.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg.defs (modified) * mDNSResponder/mDNSMacOSX/ipsec_strerror.h (modified) * mDNSResponder/mDNSMacOSX/libpfkey.h (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.pbproj/project.pbxproj (deleted) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/mDNSResponderHelper.8 (modified) * mDNSResponder/mDNSMacOSX/pfkey.c (modified) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (added) * mDNSResponder/mDNSPosix/._ReadMe.txt (added) * mDNSResponder/mDNSPosix/Identify.c (modified) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/ReadMe.txt (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSPosix/mdnsd.sh (modified) * mDNSResponder/mDNSPosix/nss_mdns.c (modified) * mDNSResponder/mDNSShared/CommonServices.h (modified) * mDNSResponder/mDNSShared/DebugServices.c (modified) * mDNSResponder/mDNSShared/GenLinkedList.c (modified) * mDNSResponder/mDNSShared/PlatformCommon.c (modified) * mDNSResponder/mDNSShared/dns-sd.1 (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.8 (modified) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/dnsextd_lexer.l (modified) * mDNSResponder/mDNSShared/dnsextd_parser.y (modified) * mDNSResponder/mDNSShared/dnssd_clientlib.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) * mDNSResponder/mDNSShared/mDNSDebug.c (modified) * mDNSResponder/mDNSShared/mDNSResponder.8 (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) mDNSResponder: Update to v625.41.2 The sources can be obtained via: ... Thu, 20 Sep 2018 09:12:30 GMT Sebastian Huber [49ebc73] * mDNSResponder/Clients/.DS_Store (deleted) * mDNSResponder/Clients/._.DS_Store (deleted) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/CUPolicy.c (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.helper.plist (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.plist (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (moved) * mDNSResponder/mDNSMacOSX/VPNService.c (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) mDNSResponder: Update to v576.30.4 The sources can be obtained via: ... Wed, 19 Sep 2018 06:49:34 GMT Sebastian Huber [e36ca10] * mDNSResponder/.DS_Store (added) * mDNSResponder/._.DS_Store (added) * mDNSResponder/Clients/.DS_Store (added) * mDNSResponder/Clients/._.DS_Store (added) * mDNSResponder/Clients/Makefile (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/base.xcconfig (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/NetMonitor.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) mDNSResponder: Update to v567 The sources can be obtained via: ... Wed, 19 Sep 2018 06:43:53 GMT Sebastian Huber [111789e] * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.plist (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services_mdns.h (moved) * mDNSResponder/mDNSMacOSX/base.xcconfig (added) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) mDNSResponder: Update to v561.1.1 The sources can be obtained via: ... Thu, 20 Sep 2018 08:22:53 GMT Sebastian Huber [ed40c80] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) mDNSResponder: Fix gAllocatedEventFDs allocation Mon, 17 Sep 2018 07:47:20 GMT Sebastian Huber [4d8f9e6] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) mDNSResponder: Honour file descriptor maximum Dynamically allocate ... Tue, 04 Nov 2014 10:56:59 GMT Sebastian Huber [d496d66] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) mDNS: Avoid uninitialized memory Use calloc() instead of malloc(). Thu, 23 Jan 2014 14:28:23 GMT Sebastian Huber [0543f16] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) mDNS: Use mutex for mDNSPosix platform Thu, 23 Jan 2014 14:27:19 GMT Sebastian Huber [f7205c1] * mDNSResponder/mDNSShared/mDNSDebug.c (modified) mDNS: mDNSShared/mDNSDebug.c Avoid reference to ProgramName. Thu, 23 Jan 2014 14:09:02 GMT Sebastian Huber [7222726] * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) mDNS: mDNSShared/dnssd_clientshim.c Fix typos. Include missing ... Thu, 23 Jan 2014 13:59:37 GMT Sebastian Huber [406a2f4] * mDNSResponder/mDNSCore/anonymous.c (modified) mDNS: AnonInfoAnswersQuestion: Fix stack usage The mDNSexport is ... Thu, 30 Jan 2014 12:52:13 GMT Sebastian Huber [9449f15] * mDNSResponder/Clients/BonjourExample/BonjourExample.cpp (added) * mDNSResponder/Clients/BonjourExample/BonjourExample.sln (added) * mDNSResponder/Clients/BonjourExample/BonjourExample.vcproj (added) * mDNSResponder/Clients/BonjourExample/stdafx.cpp (added) * mDNSResponder/Clients/BonjourExample/stdafx.h (added) * mDNSResponder/Clients/ClientCommon.c (added) * mDNSResponder/Clients/ClientCommon.h (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/DNS-SD.manifest (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/DNS-SD64.manifest (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/dns-sd.rc (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/dns-sd.sdk.rc (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/dns-sd.sdk.vcproj (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/dns-sd.vcproj (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/dns-sd.vcxproj (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/dns-sd.vcxproj.filters (added) * mDNSResponder/Clients/DNS-SD.VisualStudio/resource.h (added) * mDNSResponder/Clients/DNS-SD.xcodeproj/project.pbxproj (added) * mDNSResponder/Clients/DNSServiceBrowser-Info.plist (added) * mDNSResponder/Clients/DNSServiceBrowser.NET/App.ico (added) * mDNSResponder/Clients/DNSServiceBrowser.NET/AssemblyInfo.cs (added) * mDNSResponder/Clients/DNSServiceBrowser.NET/DNSServiceBrowser.NET.csproj (added) * mDNSResponder/Clients/DNSServiceBrowser.NET/DNSServiceBrowser.cs (added) * mDNSResponder/Clients/DNSServiceBrowser.NET/DNSServiceBrowser.resx (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/DNSServiceBrowser.Designer.vb (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/DNSServiceBrowser.VB.vbproj (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/DNSServiceBrowser.resx (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/DNSServiceBrowser.vb (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/Application.Designer.vb (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/Application.myapp (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/AssemblyInfo.vb (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/Resources.Designer.vb (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/Resources.resx (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/Settings.Designer.vb (added) * mDNSResponder/Clients/DNSServiceBrowser.VB/My Project/Settings.settings (added) * mDNSResponder/Clients/DNSServiceBrowser.m (added) * mDNSResponder/Clients/DNSServiceBrowser.nib/classes.nib (added) * mDNSResponder/Clients/DNSServiceBrowser.nib/info.nib (added) * mDNSResponder/Clients/DNSServiceBrowser.nib/objects.nib (added) * mDNSResponder/Clients/DNSServiceReg-Info.plist (added) * mDNSResponder/Clients/DNSServiceReg.m (added) * mDNSResponder/Clients/DNSServiceReg.nib/classes.nib (added) * mDNSResponder/Clients/DNSServiceReg.nib/info.nib (added) * mDNSResponder/Clients/DNSServiceReg.nib/objects.nib (added) * mDNSResponder/Clients/ExplorerPlugin/About.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/About.h (added) * mDNSResponder/Clients/ExplorerPlugin/ClassFactory.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/ClassFactory.h (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerBar.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerBar.h (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerBarWindow.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerBarWindow.h (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.def (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.h (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.rc (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.vcproj (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.vcxproj (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPlugin.vcxproj.filters (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginLocRes.rc (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginLocRes.vcproj (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginLocRes.vcxproj (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginLocRes.vcxproj.filters (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginRes.rc (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginRes.vcproj (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginRes.vcxproj (added) * mDNSResponder/Clients/ExplorerPlugin/ExplorerPluginRes.vcxproj.filters (added) * mDNSResponder/Clients/ExplorerPlugin/LoginDialog.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/LoginDialog.h (added) * mDNSResponder/Clients/ExplorerPlugin/ReadMe.txt (added) * mDNSResponder/Clients/ExplorerPlugin/Resource.h (added) * mDNSResponder/Clients/ExplorerPlugin/StdAfx.cpp (added) * mDNSResponder/Clients/ExplorerPlugin/StdAfx.h (added) * mDNSResponder/Clients/ExplorerPlugin/res/ExplorerPlugin.manifest (added) * mDNSResponder/Clients/ExplorerPlugin/res/ExplorerPlugin64.manifest (added) * mDNSResponder/Clients/ExplorerPlugin/res/about.bmp (added) * mDNSResponder/Clients/ExplorerPlugin/res/button-2k.ico (added) * mDNSResponder/Clients/ExplorerPlugin/res/button-xp.ico (added) * mDNSResponder/Clients/ExplorerPlugin/res/cold.ico (added) * mDNSResponder/Clients/ExplorerPlugin/res/hot.ico (added) * mDNSResponder/Clients/ExplorerPlugin/res/logo.bmp (added) * mDNSResponder/Clients/ExplorerPlugin/resource_dll.h (added) * mDNSResponder/Clients/ExplorerPlugin/resource_loc_res.h (added) * mDNSResponder/Clients/ExplorerPlugin/resource_res.h (added) * mDNSResponder/Clients/FirefoxExtension/CDNSSDService.cpp (added) * mDNSResponder/Clients/FirefoxExtension/CDNSSDService.h (added) * mDNSResponder/Clients/FirefoxExtension/CDNSSDServiceModule.cpp (added) * mDNSResponder/Clients/FirefoxExtension/DNSSDService.sln (added) * mDNSResponder/Clients/FirefoxExtension/FirefoxExtension.rc (added) * mDNSResponder/Clients/FirefoxExtension/FirefoxExtension.vcproj (added) * mDNSResponder/Clients/FirefoxExtension/FirefoxExtension.vcxproj (added) * mDNSResponder/Clients/FirefoxExtension/FirefoxExtension.vcxproj.filters (added) * mDNSResponder/Clients/FirefoxExtension/IDNSSDService.h (added) * mDNSResponder/Clients/FirefoxExtension/IDNSSDService.idl (added) * mDNSResponder/Clients/FirefoxExtension/extension/chrome.manifest (added) * mDNSResponder/Clients/FirefoxExtension/extension/components/IDNSSDService.xpt (added) * mDNSResponder/Clients/FirefoxExtension/extension/content/_internal_bonjour4firefox.png (added) * mDNSResponder/Clients/FirefoxExtension/extension/content/_internal_listImage.png (added) * mDNSResponder/Clients/FirefoxExtension/extension/content/bonjour4firefox.css (added) * mDNSResponder/Clients/FirefoxExtension/extension/content/bonjour4firefox.xul (added) * mDNSResponder/Clients/FirefoxExtension/extension/content/browserOverlay.xul (added) * mDNSResponder/Clients/FirefoxExtension/extension/content/overlay.js (added) * mDNSResponder/Clients/FirefoxExtension/extension/defaults/preferences/bonjour4firefox.js (added) * mDNSResponder/Clients/FirefoxExtension/extension/install.rdf (added) * mDNSResponder/Clients/FirefoxExtension/extension/locale/en-US/bonjour4firefox.dtd (added) * mDNSResponder/Clients/FirefoxExtension/extension/locale/en-US/bonjour4firefox.properties (added) * mDNSResponder/Clients/FirefoxExtension/extension/readme.txt (added) * mDNSResponder/Clients/FirefoxExtension/extension/skin-darwin/_internal_toobar-button.png (added) * mDNSResponder/Clients/FirefoxExtension/extension/skin-darwin/overlay.css (added) * mDNSResponder/Clients/FirefoxExtension/extension/skin/_internal_toobar-button.png (added) * mDNSResponder/Clients/FirefoxExtension/extension/skin/overlay.css (added) * mDNSResponder/Clients/FirefoxExtension/readme.txt (added) * mDNSResponder/Clients/FirefoxExtension/resource.h (added) * mDNSResponder/Clients/Java/BrowserApp.java (added) * mDNSResponder/Clients/Java/BrowserApp.manifest (added) * mDNSResponder/Clients/Java/DNSSDUnitTest.java (added) * mDNSResponder/Clients/Java/JavaSamples.vcproj (added) * mDNSResponder/Clients/Java/JavaSamples.vcxproj (added) * mDNSResponder/Clients/Java/SimpleChat.java (added) * mDNSResponder/Clients/Java/SimpleChat.manifest (added) * mDNSResponder/Clients/Java/SwingBrowseListener.java (added) * mDNSResponder/Clients/Java/SwingDomainListener.java (added) * mDNSResponder/Clients/Java/SwingQueryListener.java (added) * mDNSResponder/Clients/Java/nmakefile (added) * mDNSResponder/Clients/Makefile (added) * mDNSResponder/Clients/PrinterSetupWizard/About.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/About.h (added) * mDNSResponder/Clients/PrinterSetupWizard/FirstPage.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/FirstPage.h (added) * mDNSResponder/Clients/PrinterSetupWizard/FourthPage.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/FourthPage.h (added) * mDNSResponder/Clients/PrinterSetupWizard/Logger.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/Logger.h (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizard.ncb (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizard.rc (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizard.vcproj (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizard.vcxproj (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizard.vcxproj.filters (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardApp.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardApp.h (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardLocRes.rc (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardLocRes.vcproj (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardLocRes.vcxproj (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardLocRes.vcxproj.filters (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardRes.rc (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardRes.vcproj (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardRes.vcxproj (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardRes.vcxproj.filters (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardSheet.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/PrinterSetupWizardSheet.h (added) * mDNSResponder/Clients/PrinterSetupWizard/ReadMe.txt (added) * mDNSResponder/Clients/PrinterSetupWizard/SecondPage.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/SecondPage.h (added) * mDNSResponder/Clients/PrinterSetupWizard/ThirdPage.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/ThirdPage.h (added) * mDNSResponder/Clients/PrinterSetupWizard/UtilTypes.h (added) * mDNSResponder/Clients/PrinterSetupWizard/res/Info.ico (added) * mDNSResponder/Clients/PrinterSetupWizard/res/NetworkPrinter.ico (added) * mDNSResponder/Clients/PrinterSetupWizard/res/Print.ico (added) * mDNSResponder/Clients/PrinterSetupWizard/res/PrinterSetupWizard.ico (added) * mDNSResponder/Clients/PrinterSetupWizard/res/PrinterSetupWizard.manifest (added) * mDNSResponder/Clients/PrinterSetupWizard/res/PrinterSetupWizard.rc2 (added) * mDNSResponder/Clients/PrinterSetupWizard/res/PrinterSetupWizard64.manifest (added) * mDNSResponder/Clients/PrinterSetupWizard/res/PrinterSetupWizardLocRes.rc2 (added) * mDNSResponder/Clients/PrinterSetupWizard/res/PrinterSetupWizardRes.rc2 (added) * mDNSResponder/Clients/PrinterSetupWizard/res/Thumbs.db (added) * mDNSResponder/Clients/PrinterSetupWizard/res/about.bmp (added) * mDNSResponder/Clients/PrinterSetupWizard/res/banner_icon.bmp (added) * mDNSResponder/Clients/PrinterSetupWizard/res/watermark.bmp (added) * mDNSResponder/Clients/PrinterSetupWizard/resource.h (added) * mDNSResponder/Clients/PrinterSetupWizard/resource_exe.h (added) * mDNSResponder/Clients/PrinterSetupWizard/resource_loc_res.h (added) * mDNSResponder/Clients/PrinterSetupWizard/resource_res.h (added) * mDNSResponder/Clients/PrinterSetupWizard/stdafx.cpp (added) * mDNSResponder/Clients/PrinterSetupWizard/stdafx.h (added) * mDNSResponder/Clients/PrinterSetupWizard/tcpxcv.h (added) * mDNSResponder/Clients/ReadMe.txt (added) * mDNSResponder/Clients/SimpleChat.NET/App.ico (added) * mDNSResponder/Clients/SimpleChat.NET/AssemblyInfo.cs (added) * mDNSResponder/Clients/SimpleChat.NET/SimpleChat.NET.csproj (added) * mDNSResponder/Clients/SimpleChat.NET/SimpleChat.cs (added) * mDNSResponder/Clients/SimpleChat.NET/SimpleChat.resx (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/Application.Designer.vb (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/Application.myapp (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/AssemblyInfo.vb (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/Resources.Designer.vb (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/Resources.resx (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/Settings.Designer.vb (added) * mDNSResponder/Clients/SimpleChat.VB/My Project/Settings.settings (added) * mDNSResponder/Clients/SimpleChat.VB/SimpleChat.Designer.vb (added) * mDNSResponder/Clients/SimpleChat.VB/SimpleChat.VB.vbproj (added) * mDNSResponder/Clients/SimpleChat.VB/SimpleChat.resx (added) * mDNSResponder/Clients/SimpleChat.VB/SimpleChat.vb (added) * mDNSResponder/Clients/dns-sd.c (added) * mDNSResponder/Clients/dnsctl.c (added) * mDNSResponder/Clients/mDNSNetMonitor.VisualStudio/mDNSNetMonitor.manifest (added) * mDNSResponder/Clients/mDNSNetMonitor.VisualStudio/mDNSNetMonitor.rc (added) * mDNSResponder/Clients/mDNSNetMonitor.VisualStudio/mDNSNetMonitor.vcproj (added) * mDNSResponder/Clients/mDNSNetMonitor.VisualStudio/mDNSNetMonitor.vcxproj (added) * mDNSResponder/Clients/mDNSNetMonitor.VisualStudio/mDNSNetMonitor.vcxproj.filters (added) * mDNSResponder/Clients/mDNSNetMonitor.VisualStudio/resource.h (added) * mDNSResponder/LICENSE (added) * mDNSResponder/Makefile (added) * mDNSResponder/PrivateDNS.txt (added) * mDNSResponder/README.txt (added) * mDNSResponder/mDNSCore/CryptoAlg.c (added) * mDNSResponder/mDNSCore/CryptoAlg.h (added) * mDNSResponder/mDNSCore/DNSCommon.c (added) * mDNSResponder/mDNSCore/DNSCommon.h (added) * mDNSResponder/mDNSCore/DNSDigest.c (added) * mDNSResponder/mDNSCore/Implementer Notes.txt (added) * mDNSResponder/mDNSCore/anonymous.c (added) * mDNSResponder/mDNSCore/anonymous.h (added) * mDNSResponder/mDNSCore/dnsproxy.c (added) * mDNSResponder/mDNSCore/dnsproxy.h (added) * mDNSResponder/mDNSCore/dnssec.c (added) * mDNSResponder/mDNSCore/dnssec.h (added) * mDNSResponder/mDNSCore/mDNS.c (added) * mDNSResponder/mDNSCore/mDNSDebug.h (added) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (added) * mDNSResponder/mDNSCore/nsec.c (added) * mDNSResponder/mDNSCore/nsec.h (added) * mDNSResponder/mDNSCore/nsec3.c (added) * mDNSResponder/mDNSCore/nsec3.h (added) * mDNSResponder/mDNSCore/uDNS.c (added) * mDNSResponder/mDNSCore/uDNS.h (added) * mDNSResponder/mDNSMacOS9/CarbonResource.r (added) * mDNSResponder/mDNSMacOS9/Mac OS Test Responder.c (added) * mDNSResponder/mDNSMacOS9/Mac OS Test Searcher.c (added) * mDNSResponder/mDNSMacOS9/README.txt (added) * mDNSResponder/mDNSMacOS9/Responder.c (added) * mDNSResponder/mDNSMacOS9/Searcher.c (added) * mDNSResponder/mDNSMacOS9/ShowInitIcon.c (added) * mDNSResponder/mDNSMacOS9/ShowInitIcon.h (added) * mDNSResponder/mDNSMacOS9/SubTypeTester.c (added) * mDNSResponder/mDNSMacOS9/mDNS.mcp (added) * mDNSResponder/mDNSMacOS9/mDNSLibrary.c (added) * mDNSResponder/mDNSMacOS9/mDNSLibraryLoader.c (added) * mDNSResponder/mDNSMacOS9/mDNSLibraryResources.r (added) * mDNSResponder/mDNSMacOS9/mDNSMacOS9.c (added) * mDNSResponder/mDNSMacOS9/mDNSMacOS9.h (added) * mDNSResponder/mDNSMacOS9/mDNSPrefix.h (added) * mDNSResponder/mDNSMacOSX/BonjourEvents-Info.plist (added) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (added) * mDNSResponder/mDNSMacOSX/CUPolicy.c (added) * mDNSResponder/mDNSMacOSX/CryptoSupport.c (added) * mDNSResponder/mDNSMacOSX/CryptoSupport.h (added) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (added) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (added) * mDNSResponder/mDNSMacOSX/DNSSECSupport.h (added) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (added) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (added) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryDefines.h (added) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryReply.defs (added) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryRequest.defs (added) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo-Tiger.helper.plist (added) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo-Tiger.plist (added) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.dnsextd.plist (added) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.helper.plist (added) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.plist (added) * mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c (added) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.c (added) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/add_idle.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/add_pressed.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/failure.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/inprogress.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_disabled.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_idle.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_pressed.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/success.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPref.icns (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPref.tiff (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.c (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationRights.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/classes.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/info.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/keyedobjects.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/InfoPlist.strings (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Info-PreferencePane.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (added) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ddnswriteconfig.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/installtool (added) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (added) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (added) * mDNSResponder/mDNSMacOSX/Private/dns_xpc.h (added) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (added) * mDNSResponder/mDNSMacOSX/Private/xpc_services.h (added) * mDNSResponder/mDNSMacOSX/README.privsep (added) * mDNSResponder/mDNSMacOSX/VPNService.c (added) * mDNSResponder/mDNSMacOSX/com.apple.networking.mDNSResponder (added) * mDNSResponder/mDNSMacOSX/daemon.c (added) * mDNSResponder/mDNSMacOSX/dnsctl-entitlements.plist (added) * mDNSResponder/mDNSMacOSX/helper-entitlements.plist (added) * mDNSResponder/mDNSMacOSX/helper-error.h (added) * mDNSResponder/mDNSMacOSX/helper-main.c (added) * mDNSResponder/mDNSMacOSX/helper-server.h (added) * mDNSResponder/mDNSMacOSX/helper-stubs.c (added) * mDNSResponder/mDNSMacOSX/helper.c (added) * mDNSResponder/mDNSMacOSX/helper.h (added) * mDNSResponder/mDNSMacOSX/helpermsg-types.h (added) * mDNSResponder/mDNSMacOSX/helpermsg.defs (added) * mDNSResponder/mDNSMacOSX/ipsec_strerror.h (added) * mDNSResponder/mDNSMacOSX/libpfkey.h (added) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (added) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (added) * mDNSResponder/mDNSMacOSX/mDNSResponder-bundle/Resources/English.lproj/Localizable.strings (added) * mDNSResponder/mDNSMacOSX/mDNSResponder-bundle/Resources/French.lproj/Localizable.strings (added) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.order (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.pbproj/project.pbxproj (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.txt (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (added) * mDNSResponder/mDNSMacOSX/mDNSResponderHelper.8 (added) * mDNSResponder/mDNSMacOSX/mDNSResponderHelper.plist (added) * mDNSResponder/mDNSMacOSX/mDNSResponderLogging.mobileconfig (added) * mDNSResponder/mDNSMacOSX/pfkey.c (added) * mDNSResponder/mDNSPosix/Client.c (added) * mDNSResponder/mDNSPosix/ExampleClientApp.c (added) * mDNSResponder/mDNSPosix/ExampleClientApp.h (added) * mDNSResponder/mDNSPosix/Identify.c (added) * mDNSResponder/mDNSPosix/Makefile (added) * mDNSResponder/mDNSPosix/NetMonitor.c (added) * mDNSResponder/mDNSPosix/PosixDaemon.c (added) * mDNSResponder/mDNSPosix/ProxyResponder.c (added) * mDNSResponder/mDNSPosix/ReadMe.txt (added) * mDNSResponder/mDNSPosix/Responder.c (added) * mDNSResponder/mDNSPosix/Services.txt (added) * mDNSResponder/mDNSPosix/libnss_mdns.8 (added) * mDNSResponder/mDNSPosix/mDNSPosix.c (added) * mDNSResponder/mDNSPosix/mDNSPosix.h (added) * mDNSResponder/mDNSPosix/mDNSUNP.c (added) * mDNSResponder/mDNSPosix/mDNSUNP.h (added) * mDNSResponder/mDNSPosix/mdnsd.sh (added) * mDNSResponder/mDNSPosix/nss_ReadMe.txt (added) * mDNSResponder/mDNSPosix/nss_mdns.c (added) * mDNSResponder/mDNSPosix/nss_mdns.conf (added) * mDNSResponder/mDNSPosix/nss_mdns.conf.5 (added) * mDNSResponder/mDNSPosix/parselog.py (added) * mDNSResponder/mDNSResponder.sln (added) * mDNSResponder/mDNSShared/CommonServices.h (added) * mDNSResponder/mDNSShared/DebugServices.c (added) * mDNSResponder/mDNSShared/DebugServices.h (added) * mDNSResponder/mDNSShared/GenLinkedList.c (added) * mDNSResponder/mDNSShared/GenLinkedList.h (added) * mDNSResponder/mDNSShared/Java/BaseListener.java (added) * mDNSResponder/mDNSShared/Java/BrowseListener.java (added) * mDNSResponder/mDNSShared/Java/DNSRecord.java (added) * mDNSResponder/mDNSShared/Java/DNSSD.java (added) * mDNSResponder/mDNSShared/Java/DNSSDException.java (added) * mDNSResponder/mDNSShared/Java/DNSSDRecordRegistrar.java (added) * mDNSResponder/mDNSShared/Java/DNSSDRegistration.java (added) * mDNSResponder/mDNSShared/Java/DNSSDService.java (added) * mDNSResponder/mDNSShared/Java/DomainListener.java (added) * mDNSResponder/mDNSShared/Java/JNISupport.c (added) * mDNSResponder/mDNSShared/Java/QueryListener.java (added) * mDNSResponder/mDNSShared/Java/RegisterListener.java (added) * mDNSResponder/mDNSShared/Java/RegisterRecordListener.java (added) * mDNSResponder/mDNSShared/Java/ResolveListener.java (added) * mDNSResponder/mDNSShared/Java/TXTRecord.java (added) * mDNSResponder/mDNSShared/PlatformCommon.c (added) * mDNSResponder/mDNSShared/PlatformCommon.h (added) * mDNSResponder/mDNSShared/dns-sd.1 (added) * mDNSResponder/mDNSShared/dns_sd.h (added) * mDNSResponder/mDNSShared/dnsextd.8 (added) * mDNSResponder/mDNSShared/dnsextd.c (added) * mDNSResponder/mDNSShared/dnsextd.conf (added) * mDNSResponder/mDNSShared/dnsextd.h (added) * mDNSResponder/mDNSShared/dnsextd_lexer.l (added) * mDNSResponder/mDNSShared/dnsextd_parser.y (added) * mDNSResponder/mDNSShared/dnssd_clientlib.c (added) * mDNSResponder/mDNSShared/dnssd_clientshim.c (added) * mDNSResponder/mDNSShared/dnssd_clientstub.c (added) * mDNSResponder/mDNSShared/dnssd_ipc.c (added) * mDNSResponder/mDNSShared/dnssd_ipc.h (added) * mDNSResponder/mDNSShared/mDNSDebug.c (added) * mDNSResponder/mDNSShared/mDNSResponder.8 (added) * mDNSResponder/mDNSShared/uds_daemon.c (added) * mDNSResponder/mDNSShared/uds_daemon.h (added) * mDNSResponder/mDNSVxWorks/README.txt (added) * mDNSResponder/mDNSVxWorks/mDNSVxWorks.c (added) * mDNSResponder/mDNSVxWorks/mDNSVxWorks.h (added) * mDNSResponder/mDNSVxWorks/mDNSVxWorksIPv4Only.c (added) * mDNSResponder/mDNSVxWorks/mDNSVxWorksIPv4Only.h (added) * mDNSResponder/mDNSWindows/ControlPanel/BrowsingPage.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/BrowsingPage.h (added) * mDNSResponder/mDNSWindows/ControlPanel/ConfigDialog.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/ConfigDialog.h (added) * mDNSResponder/mDNSWindows/ControlPanel/ConfigPropertySheet.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/ConfigPropertySheet.h (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.def (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.h (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.rc (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.vcproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.vcxproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanel.vcxproj.filters (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelDll.rc (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.h (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.rc (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.vcproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelLocRes.rc (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelLocRes.vcproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelLocRes.vcxproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelLocRes.vcxproj.filters (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelRes.rc (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelRes.vcproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelRes.vcxproj (added) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelRes.vcxproj.filters (added) * mDNSResponder/mDNSWindows/ControlPanel/FourthPage.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/FourthPage.h (added) * mDNSResponder/mDNSWindows/ControlPanel/RegistrationPage.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/RegistrationPage.h (added) * mDNSResponder/mDNSWindows/ControlPanel/SecondPage.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/SecondPage.h (added) * mDNSResponder/mDNSWindows/ControlPanel/ServicesPage.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/ServicesPage.h (added) * mDNSResponder/mDNSWindows/ControlPanel/SharedSecret.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/SharedSecret.h (added) * mDNSResponder/mDNSWindows/ControlPanel/res/ControlPanel.dll.manifest (added) * mDNSResponder/mDNSWindows/ControlPanel/res/ControlPanel.exe.manifest (added) * mDNSResponder/mDNSWindows/ControlPanel/res/ControlPanel.manifest (added) * mDNSResponder/mDNSWindows/ControlPanel/res/ControlPanel.rc2 (added) * mDNSResponder/mDNSWindows/ControlPanel/res/ControlPanel64.manifest (added) * mDNSResponder/mDNSWindows/ControlPanel/res/EnergySaver.ico (added) * mDNSResponder/mDNSWindows/ControlPanel/res/controlpanel.ico (added) * mDNSResponder/mDNSWindows/ControlPanel/res/failure.ico (added) * mDNSResponder/mDNSWindows/ControlPanel/res/success.ico (added) * mDNSResponder/mDNSWindows/ControlPanel/resource.h (added) * mDNSResponder/mDNSWindows/ControlPanel/stdafx.cpp (added) * mDNSResponder/mDNSWindows/ControlPanel/stdafx.h (added) * mDNSResponder/mDNSWindows/DLL.NET/AssemblyInfo.cpp (added) * mDNSResponder/mDNSWindows/DLL.NET/PString.h (added) * mDNSResponder/mDNSWindows/DLL.NET/Stdafx.cpp (added) * mDNSResponder/mDNSWindows/DLL.NET/Stdafx.h (added) * mDNSResponder/mDNSWindows/DLL.NET/dnssd_NET.cpp (added) * mDNSResponder/mDNSWindows/DLL.NET/dnssd_NET.h (added) * mDNSResponder/mDNSWindows/DLL.NET/dnssd_NET.ico (added) * mDNSResponder/mDNSWindows/DLL.NET/dnssd_NET.rc (added) * mDNSResponder/mDNSWindows/DLL.NET/dnssd_NET.vcproj (added) * mDNSResponder/mDNSWindows/DLL.NET/resource.h (added) * mDNSResponder/mDNSWindows/DLL/dll.aps (added) * mDNSResponder/mDNSWindows/DLL/dll.rc (added) * mDNSResponder/mDNSWindows/DLL/dllmain.c (added) * mDNSResponder/mDNSWindows/DLL/dnssd.def (added) * mDNSResponder/mDNSWindows/DLL/dnssd.vcproj (added) * mDNSResponder/mDNSWindows/DLL/dnssd.vcxproj (added) * mDNSResponder/mDNSWindows/DLL/dnssd.vcxproj.filters (added) * mDNSResponder/mDNSWindows/DLL/resource.h (added) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.cpp (added) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.h (added) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.vcproj (added) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.vcxproj (added) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.vcxproj.filters (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.cpp (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.def (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.idl (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.rc (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.rgs (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.vcproj (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.vcxproj (added) * mDNSResponder/mDNSWindows/DLLX/DLLX.vcxproj.filters (added) * mDNSResponder/mDNSWindows/DLLX/DNSSD.cpp (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDEventManager.cpp (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDEventManager.h (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDEventManager.rgs (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDRecord.cpp (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDRecord.h (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDRecord.rgs (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDService.cpp (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDService.h (added) * mDNSResponder/mDNSWindows/DLLX/DNSSDService.rgs (added) * mDNSResponder/mDNSWindows/DLLX/StringServices.cpp (added) * mDNSResponder/mDNSWindows/DLLX/StringServices.h (added) * mDNSResponder/mDNSWindows/DLLX/TXTRecord.cpp (added) * mDNSResponder/mDNSWindows/DLLX/TXTRecord.h (added) * mDNSResponder/mDNSWindows/DLLX/TXTRecord.rgs (added) * mDNSResponder/mDNSWindows/DLLX/_IDNSSDEvents_CP.h (added) * mDNSResponder/mDNSWindows/DLLX/dlldatax.c (added) * mDNSResponder/mDNSWindows/DLLX/dlldatax.h (added) * mDNSResponder/mDNSWindows/DLLX/resource.h (added) * mDNSResponder/mDNSWindows/DLLX/stdafx.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/ApplicationVS2002.sln (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/ApplicationVS2002.vcproj (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/ApplicationVS2003.sln (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/ApplicationVS2003.vcproj (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Resources/Application.ico (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Resources/Application.rc (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Resources/Application.rc2 (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Resources/Resource.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/AboutDialog.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/AboutDialog.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/Application.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/Application.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/ChooserDialog.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/ChooserDialog.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/LoginDialog.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/LoginDialog.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/StdAfx.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/StdAfx.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Application.vcc (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Application.vcp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Application.vcw (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Resources/Application.ico (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Resources/Application.rc (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Resources/Application.rc2 (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Resources/newres.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Resources/resource.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/Application.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/Application.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/BrowserDialog.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/BrowserDialog.h (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/StdAfx.cpp (added) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/StdAfx.h (added) * mDNSResponder/mDNSWindows/Java/Java.vcproj (added) * mDNSResponder/mDNSWindows/Java/Java.vcxproj (added) * mDNSResponder/mDNSWindows/Java/jdns_sd.rc (added) * mDNSResponder/mDNSWindows/Java/makefile (added) * mDNSResponder/mDNSWindows/Java/makefile64 (added) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.aps (added) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.c (added) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.rc (added) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.vcproj (added) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.vcxproj (added) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.vcxproj.filters (added) * mDNSResponder/mDNSWindows/NSPTool/Prefix.h (added) * mDNSResponder/mDNSWindows/NSPTool/resource.h (added) * mDNSResponder/mDNSWindows/Poll.c (added) * mDNSResponder/mDNSWindows/Poll.h (added) * mDNSResponder/mDNSWindows/PosixCompat.c (added) * mDNSResponder/mDNSWindows/PosixCompat.h (added) * mDNSResponder/mDNSWindows/README.txt (added) * mDNSResponder/mDNSWindows/RegNames.h (added) * mDNSResponder/mDNSWindows/Secret.c (added) * mDNSResponder/mDNSWindows/Secret.h (added) * mDNSResponder/mDNSWindows/SystemService/EventLog.mc (added) * mDNSResponder/mDNSWindows/SystemService/EventLogMessages.bin (added) * mDNSResponder/mDNSWindows/SystemService/Firewall.cpp (added) * mDNSResponder/mDNSWindows/SystemService/Firewall.h (added) * mDNSResponder/mDNSWindows/SystemService/Prefix.h (added) * mDNSResponder/mDNSWindows/SystemService/Service.aps (added) * mDNSResponder/mDNSWindows/SystemService/Service.c (added) * mDNSResponder/mDNSWindows/SystemService/Service.h (added) * mDNSResponder/mDNSWindows/SystemService/Service.mcp (added) * mDNSResponder/mDNSWindows/SystemService/Service.rc (added) * mDNSResponder/mDNSWindows/SystemService/Service.vcproj (added) * mDNSResponder/mDNSWindows/SystemService/Service.vcxproj (added) * mDNSResponder/mDNSWindows/SystemService/Service.vcxproj.filters (added) * mDNSResponder/mDNSWindows/SystemService/main.c (added) * mDNSResponder/mDNSWindows/SystemService/res/mDNSResponder.manifest (added) * mDNSResponder/mDNSWindows/SystemService/res/mDNSResponder64.manifest (added) * mDNSResponder/mDNSWindows/SystemService/resource.h (added) * mDNSResponder/mDNSWindows/SystemService/resrc1.h (added) * mDNSResponder/mDNSWindows/VPCDetect.cpp (added) * mDNSResponder/mDNSWindows/VPCDetect.h (added) * mDNSResponder/mDNSWindows/WinServices.cpp (added) * mDNSResponder/mDNSWindows/WinServices.h (added) * mDNSResponder/mDNSWindows/WinVersRes.h (added) * mDNSResponder/mDNSWindows/isocode.h (added) * mDNSResponder/mDNSWindows/loclibrary.c (added) * mDNSResponder/mDNSWindows/loclibrary.h (added) * mDNSResponder/mDNSWindows/mDNSWin32.c (added) * mDNSResponder/mDNSWindows/mDNSWin32.h (added) * mDNSResponder/mDNSWindows/mdnsNSP/ReadMe.txt (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.aps (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.c (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.def (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.rc (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.vcproj (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.vcxproj (added) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.vcxproj.filters (added) * mDNSResponder/mDNSWindows/mdnsNSP/resource.h (added) mDNS: Import The sources can be obtained via: ...
