# # ChangeLog for libbsd.py in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/24/24 02:48:09 Mon, 30 Jan 2017 16:58:16 GMT Kevin Kirspel [9f2205a] * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (added) * rtemsbsd/sys/dev/usb/usb_otg_transceiver.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Port LPC32XX Ethernet and USB OHCI to RTEMS Fri, 09 Dec 2016 10:51:50 GMT Christian Mauderer [ecda181] * builder.py (modified) * freebsd/tools/tools/net80211/wlanstats/main.c (modified) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-data.h (added) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-main-data.h (added) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-namespace.h (added) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-wlanstats-data.h (added) * freebsd/tools/tools/net80211/wlanstats/wlanstats.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-wlanstats.c (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) freebsd/wlanstats: Port to FreeBSD. Wed, 30 Nov 2016 15:41:12 GMT Christian Mauderer [d686d7b] * Makefile.todo (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_usb.h (modified) * rtemsbsd/local/runfw.c (added) wlan/run: Add firmware. Fri, 18 Nov 2016 10:13:11 GMT Christian Mauderer [edf32f2] * Makefile.todo (modified) * freebsd/sys/dev/rtwn/if_rtwn_task.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_rtwn.h (moved) * rtemsbsd/local/rtwn-rtl8192cfwT.c (added) rtwn: Port to RTEMS Mon, 12 Dec 2016 09:51:42 GMT Christian Mauderer [9bc41d0] * Makefile.todo (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-regdomain.h (added) * rtemsbsd/rtems/rtems-bsd-regdomain.c (added) lib80211/regdomain: Port to RTEMS. Wed, 16 Nov 2016 15:29:17 GMT Christian Mauderer [5c3223f] * builder.py (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifieee80211-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-namespace.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsdxml.h (added) ifconfig/wlan, expat, lib80211: Port to RTEMS. Mon, 12 Dec 2016 11:23:40 GMT Christian Mauderer [59338de] * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_urtwn.h (added) Port USB and USB WLAN. Mon, 12 Dec 2016 12:09:09 GMT Christian Mauderer [66eb143] * freebsd/sys/kern/subr_firmware.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) firmware: Port to RTEMS. Mon, 12 Dec 2016 11:31:33 GMT Christian Mauderer [efc782b] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_platform.h (added) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) Port IEEE 802.11. Thu, 12 Jan 2017 13:56:23 GMT Sebastian Huber [172f2ac] * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/sys/proc.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (deleted) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) * testsuite/thread01/test_main.c (modified) Use thread name support Update #2858. Tue, 10 Jan 2017 07:04:58 GMT Sebastian Huber [64c663c] * freebsd/usr.sbin/arp/arp.c (modified) * freebsd/usr.sbin/arp/rtems-bsd-arp-arp-data.h (added) * freebsd/usr.sbin/arp/rtems-bsd-arp-data.h (added) * freebsd/usr.sbin/arp/rtems-bsd-arp-namespace.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-arp.c (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) * testsuite/netshell01/shellconfig.c (modified) ARP(8): Port to RTEMS Mon, 09 Jan 2017 13:47:04 GMT Sebastian Huber [0577772] * freebsd-org (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/lib/libipsec/policy_parse.c (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/route/keywords.h (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/cam/scsi/scsi_da.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.h (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (added) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/counter.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-route-data.h (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD head 2017-01-09 Git mirror commit ... Thu, 10 Nov 2016 12:52:08 GMT Sebastian Huber [c4e89a9] * freebsd/usr.bin/vmstat/vmstat.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/devstat.h (added) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-vmstat.c (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) * testsuite/netshell01/shellconfig.c (modified) VMSTAT(8): Port to RTEMS Fri, 07 Oct 2016 13:10:20 GMT Sebastian Huber [c40e45b] * Makefile.todo (modified) * builder.py (modified) * create-kernel-namespace.sh (modified) * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (added) * freebsd/contrib/libxo/libxo/xo.h (added) * freebsd/contrib/libxo/libxo/xo_buf.h (added) * freebsd/contrib/libxo/libxo/xo_config.h (added) * freebsd/contrib/libxo/libxo/xo_encoder.c (added) * freebsd/contrib/libxo/libxo/xo_encoder.h (added) * freebsd/contrib/libxo/libxo/xo_humanize.h (added) * freebsd/contrib/libxo/libxo/xo_wcwidth.h (added) * freebsd/contrib/pf/pfctl/pfctl-data.h (deleted) * freebsd/contrib/pf/pfctl/pfctl_optimize-data.h (deleted) * freebsd/contrib/pf/pfctl/pfctl_radix-data.h (deleted) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/gssapi/gssapi.h (modified) * freebsd/include/ifaddrs.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/resolv.h (modified) * freebsd/include/rpc/rpcent.h (modified) * freebsd/include/rpc/svc.h (modified) * freebsd/include/rpc/xdr.h (modified) * freebsd/include/rpcsvc/nis.x (modified) * freebsd/include/rpcsvc/nis_tags.h (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/feature_present.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/port_before.h (modified) * freebsd/lib/libc/include/reentrant.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/ev_timers.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/nameser/ns_samedomain.c (modified) * freebsd/lib/libc/net/base64.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getproto.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/if_indextoname.c (modified) * freebsd/lib/libc/net/if_nameindex.c (modified) * freebsd/lib/libc/net/if_nametoindex.c (modified) * freebsd/lib/libc/net/ip6opt.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/netdb_private.h (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/nslexer.l (modified) * freebsd/lib/libc/net/nsparser.y (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/res_config.h (modified) * freebsd/lib/libc/net/rthdr.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/posix1e/mac.c (modified) * freebsd/lib/libc/resolv/h_errno.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/mtctxres.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_private.h (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_state.c (modified) * freebsd/lib/libc/rpc/auth_des.c (modified) * freebsd/lib/libc/rpc/auth_none.c (modified) * freebsd/lib/libc/rpc/auth_time.c (modified) * freebsd/lib/libc/rpc/auth_unix.c (modified) * freebsd/lib/libc/rpc/authdes_prot.c (modified) * freebsd/lib/libc/rpc/authunix_prot.c (modified) * freebsd/lib/libc/rpc/bindresvport.c (modified) * freebsd/lib/libc/rpc/clnt_bcast.c (modified) * freebsd/lib/libc/rpc/clnt_dg.c (modified) * freebsd/lib/libc/rpc/clnt_generic.c (modified) * freebsd/lib/libc/rpc/clnt_perror.c (modified) * freebsd/lib/libc/rpc/clnt_raw.c (modified) * freebsd/lib/libc/rpc/clnt_simple.c (modified) * freebsd/lib/libc/rpc/clnt_vc.c (modified) * freebsd/lib/libc/rpc/crypt_client.c (modified) * freebsd/lib/libc/rpc/des_crypt.c (modified) * freebsd/lib/libc/rpc/des_soft.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/rpc/getnetpath.c (modified) * freebsd/lib/libc/rpc/getpublickey.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libc/rpc/getrpcport.c (modified) * freebsd/lib/libc/rpc/key_call.c (modified) * freebsd/lib/libc/rpc/mt_misc.c (modified) * freebsd/lib/libc/rpc/netname.c (modified) * freebsd/lib/libc/rpc/netnamer.c (modified) * freebsd/lib/libc/rpc/pmap_getmaps.c (modified) * freebsd/lib/libc/rpc/pmap_getport.c (modified) * freebsd/lib/libc/rpc/pmap_prot.c (modified) * freebsd/lib/libc/rpc/pmap_prot2.c (modified) * freebsd/lib/libc/rpc/pmap_rmt.c (modified) * freebsd/lib/libc/rpc/rpc_callmsg.c (modified) * freebsd/lib/libc/rpc/rpc_com.h (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpc_prot.c (modified) * freebsd/lib/libc/rpc/rpc_soc.c (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/lib/libc/rpc/rpcb_prot.c (modified) * freebsd/lib/libc/rpc/rpcb_st_xdr.c (modified) * freebsd/lib/libc/rpc/rpcdname.c (modified) * freebsd/lib/libc/rpc/rtime.c (modified) * freebsd/lib/libc/rpc/svc.c (modified) * freebsd/lib/libc/rpc/svc_auth.c (modified) * freebsd/lib/libc/rpc/svc_auth_des.c (modified) * freebsd/lib/libc/rpc/svc_auth_unix.c (modified) * freebsd/lib/libc/rpc/svc_dg.c (modified) * freebsd/lib/libc/rpc/svc_generic.c (modified) * freebsd/lib/libc/rpc/svc_raw.c (modified) * freebsd/lib/libc/rpc/svc_run.c (modified) * freebsd/lib/libc/rpc/svc_simple.c (modified) * freebsd/lib/libc/rpc/svc_vc.c (modified) * freebsd/lib/libc/stdio/fgetln.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libc/stdlib/strtoimax.c (modified) * freebsd/lib/libc/stdlib/strtonum.c (modified) * freebsd/lib/libc/stdlib/strtoumax.c (modified) * freebsd/lib/libc/string/strsep.c (modified) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/lib/libc/xdr/xdr_array.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libc/xdr/xdr_mem.c (modified) * freebsd/lib/libc/xdr/xdr_rec.c (modified) * freebsd/lib/libc/xdr/xdr_reference.c (modified) * freebsd/lib/libc/xdr/xdr_sizeof.c (modified) * freebsd/lib/libc/xdr/xdr_stdio.c (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libipsec/policy_parse.y (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat.h (modified) * freebsd/lib/libmemstat/memstat_internal.h (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/expand_number.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/packet.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifcarp.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet6-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_link-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_nd6-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifbridge-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifclone-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifconfig-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgif-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgre-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgroup-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-iflagg-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmac-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmedia-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifpfsync-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifvlan-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-namespace.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-sfp-data.h (added) * freebsd/sbin/ifconfig/sfp.c (added) * freebsd/sbin/pfctl/parse.c (moved) * freebsd/sbin/pfctl/parse.h (added) * freebsd/sbin/pfctl/parse.y (moved) * freebsd/sbin/pfctl/pf_print_state.c (moved) * freebsd/sbin/pfctl/pfctl.c (moved) * freebsd/sbin/pfctl/pfctl.h (moved) * freebsd/sbin/pfctl/pfctl_altq.c (moved) * freebsd/sbin/pfctl/pfctl_optimize.c (moved) * freebsd/sbin/pfctl/pfctl_osfp.c (moved) * freebsd/sbin/pfctl/pfctl_parser.c (moved) * freebsd/sbin/pfctl/pfctl_parser.h (moved) * freebsd/sbin/pfctl/pfctl_qstats.c (moved) * freebsd/sbin/pfctl/pfctl_radix.c (moved) * freebsd/sbin/pfctl/pfctl_table.c (moved) * freebsd/sbin/pfctl/rtems-bsd-pfctl-data.h (added) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (added) * freebsd/sbin/pfctl/rtems-bsd-pfctl-parse-data.h (moved) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pf_print_state-data.h (added) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl-data.h (added) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_altq-data.h (moved) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_optimize-data.h (added) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_osfp-data.h (moved) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_parser-data.h (moved) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_qstats-data.h (moved) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_radix-data.h (added) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_table-data.h (added) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping/rtems-bsd-ping-data.h (added) * freebsd/sbin/ping/rtems-bsd-ping-namespace.h (added) * freebsd/sbin/ping/rtems-bsd-ping-ping-data.h (added) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-data.h (added) * freebsd/sbin/ping6/rtems-bsd-ping6-namespace.h (added) * freebsd/sbin/ping6/rtems-bsd-ping6-ping6-data.h (added) * freebsd/sbin/route/keywords (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/route/rtems-bsd-route-data.h (added) * freebsd/sbin/route/rtems-bsd-route-namespace.h (added) * freebsd/sbin/route/rtems-bsd-route-route-data.h (added) * freebsd/sbin/sysctl/rtems-bsd-sysctl-data.h (added) * freebsd/sbin/sysctl/rtems-bsd-sysctl-namespace.h (added) * freebsd/sbin/sysctl/rtems-bsd-sysctl-sysctl-data.h (added) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/arm/include/machine/in_cksum.h (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.h (modified) * freebsd/sys/avr/include/machine/in_cksum.h (modified) * freebsd/sys/bfin/include/machine/in_cksum.h (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_sim.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/cam_xpt_sim.h (modified) * freebsd/sys/cam/nvme/nvme_all.h (added) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/cam/scsi/scsi_da.h (modified) * freebsd/sys/contrib/altq/altq/altqconf.h (deleted) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.h (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha1.h (modified) * freebsd/sys/crypto/sha2/sha256.h (added) * freebsd/sys/crypto/sha2/sha256c.c (added) * freebsd/sys/crypto/sha2/sha384.h (added) * freebsd/sys/crypto/sha2/sha512.h (added) * freebsd/sys/crypto/sha2/sha512c.c (added) * freebsd/sys/crypto/sha2/sha512t.h (added) * freebsd/sys/crypto/siphash/siphash.c (added) * freebsd/sys/crypto/siphash/siphash.h (added) * freebsd/sys/crypto/skein/skein.c (added) * freebsd/sys/crypto/skein/skein.h (added) * freebsd/sys/crypto/skein/skein_block.c (added) * freebsd/sys/crypto/skein/skein_debug.h (added) * freebsd/sys/crypto/skein/skein_freebsd.h (added) * freebsd/sys/crypto/skein/skein_iv.h (added) * freebsd/sys/crypto/skein/skein_port.h (added) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bce/if_bcereg.h (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/bge/if_bgereg.h (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/dwc/if_dwc.h (modified) * freebsd/sys/dev/dwc/if_dwcvar.h (added) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.h (modified) * freebsd/sys/dev/e1000/e1000_82540.c (modified) * freebsd/sys/dev/e1000/e1000_82541.c (modified) * freebsd/sys/dev/e1000/e1000_82541.h (modified) * freebsd/sys/dev/e1000/e1000_82542.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82543.h (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82571.h (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_api.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_i210.c (modified) * freebsd/sys/dev/e1000/e1000_i210.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_manage.c (modified) * freebsd/sys/dev/e1000/e1000_manage.h (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.h (modified) * freebsd/sys/dev/e1000/e1000_nvm.c (modified) * freebsd/sys/dev/e1000/e1000_nvm.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_phy.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/e1000_vf.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/e1000/if_igb.c (modified) * freebsd/sys/dev/e1000/if_igb.h (modified) * freebsd/sys/dev/e1000/if_lem.c (modified) * freebsd/sys/dev/e1000/if_lem.h (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/fxp/if_fxpreg.h (modified) * freebsd/sys/dev/fxp/if_fxpvar.h (modified) * freebsd/sys/dev/fxp/rcvbundl.h (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/e1000phy.c (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii.h (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/mii/rgephy.c (modified) * freebsd/sys/dev/mii/rgephyreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (added) * freebsd/sys/dev/ofw/openfirm.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/random/harvest.c (deleted) * freebsd/sys/dev/random/randomdev_soft.h (deleted) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rl/if_rlreg.h (moved) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec.h (modified) * freebsd/sys/dev/tsec/if_tsecreg.h (modified) * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/h8300/include/machine/in_cksum.h (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/in_cksum.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/i386/include/machine/specialreg.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_hhook.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (added) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (added) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (added) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_mbufhash.c (added) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/arc4random.c (deleted) * freebsd/sys/libkern/jenkins_hash.c (added) * freebsd/sys/libkern/murmur3_32.c (added) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/lm32/include/machine/in_cksum.h (modified) * freebsd/sys/m32c/include/machine/in_cksum.h (modified) * freebsd/sys/m32r/include/machine/in_cksum.h (modified) * freebsd/sys/m68k/include/machine/in_cksum.h (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/mips/include/machine/in_cksum.h (modified) * freebsd/sys/net/altq/altq.h (moved) * freebsd/sys/net/altq/altq_cbq.c (moved) * freebsd/sys/net/altq/altq_cbq.h (moved) * freebsd/sys/net/altq/altq_cdnr.c (moved) * freebsd/sys/net/altq/altq_cdnr.h (moved) * freebsd/sys/net/altq/altq_classq.h (moved) * freebsd/sys/net/altq/altq_codel.c (added) * freebsd/sys/net/altq/altq_codel.h (added) * freebsd/sys/net/altq/altq_fairq.c (added) * freebsd/sys/net/altq/altq_fairq.h (added) * freebsd/sys/net/altq/altq_hfsc.c (moved) * freebsd/sys/net/altq/altq_hfsc.h (moved) * freebsd/sys/net/altq/altq_priq.c (moved) * freebsd/sys/net/altq/altq_priq.h (moved) * freebsd/sys/net/altq/altq_red.c (moved) * freebsd/sys/net/altq/altq_red.h (moved) * freebsd/sys/net/altq/altq_rio.c (moved) * freebsd/sys/net/altq/altq_rio.h (moved) * freebsd/sys/net/altq/altq_rmclass.c (moved) * freebsd/sys/net/altq/altq_rmclass.h (moved) * freebsd/sys/net/altq/altq_rmclass_debug.h (moved) * freebsd/sys/net/altq/altq_subr.c (moved) * freebsd/sys/net/altq/altq_var.h (moved) * freebsd/sys/net/altq/if_altq.h (moved) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/flowtable.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_atm.h (modified) * freebsd/sys/net/if_atmsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_ef.c (deleted) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_enc.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_faith.c (deleted) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_mib.c (modified) * freebsd/sys/net/if_pflog.h (added) * freebsd/sys/net/if_pfsync.h (added) * freebsd/sys/net/if_sppp.h (modified) * freebsd/sys/net/if_spppfr.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_tun.h (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/ifq.h (added) * freebsd/sys/net/iso88025.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/pfvar.h (added) * freebsd/sys/net/ppp_defs.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/radix_mpath.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/route_var.h (added) * freebsd/sys/net/rss_config.h (added) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/sff8436.h (added) * freebsd/sys/net/sff8472.h (added) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/netgraph/ng_socket.h (added) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc.h (moved) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_atm.c (modified) * freebsd/sys/netinet/if_atm.h (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (modified) * freebsd/sys/netinet/in_fib.c (added) * freebsd/sys/netinet/in_fib.h (added) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_kdtrace.h (added) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_rmx.c (modified) * freebsd/sys/netinet/in_rss.h (added) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_dummynet.h (modified) * freebsd/sys/netinet/ip_ecn.h (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_ipsec.h (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (added) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_pptp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_dtrace_declare.h (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_lock_bsd.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_timer.h (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hostcache.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_lro.h (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet/udplite.h (moved) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_fib.c (added) * freebsd/sys/netinet6/in6_fib.h (added) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_ifattach.h (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_rss.h (added) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_ipsec.h (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_mroute.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/ip_fw_nat64.h (added) * freebsd/sys/netinet6/ip_fw_nptv6.h (added) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/raw_ip6.h (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netpfil/ipfw/dn_aqm.h (added) * freebsd/sys/netpfil/ipfw/dn_aqm_codel.h (added) * freebsd/sys/netpfil/ipfw/dn_aqm_pie.h (added) * freebsd/sys/netpfil/ipfw/dn_heap.c (deleted) * freebsd/sys/netpfil/ipfw/dn_heap.h (modified) * freebsd/sys/netpfil/ipfw/dn_sched.h (modified) * freebsd/sys/netpfil/ipfw/dn_sched_fifo.c (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel.h (added) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel_helper.h (added) * freebsd/sys/netpfil/ipfw/dn_sched_prio.c (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_qfq.c (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_rr.c (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_wf2q.c (deleted) * freebsd/sys/netpfil/ipfw/ip_dn_glue.c (deleted) * freebsd/sys/netpfil/ipfw/ip_dn_io.c (deleted) * freebsd/sys/netpfil/ipfw/ip_dn_private.h (modified) * freebsd/sys/netpfil/ipfw/ip_dummynet.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (added) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (added) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (added) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (added) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.h (added) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (added) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (added) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (added) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.h (added) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (added) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.h (added) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (added) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.h (added) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (added) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (added) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.h (added) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (added) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (added) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (added) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.h (added) * freebsd/sys/netpfil/pf/if_pflog.c (added) * freebsd/sys/netpfil/pf/if_pfsync.c (added) * freebsd/sys/netpfil/pf/in4_cksum.c (added) * freebsd/sys/netpfil/pf/pf.c (added) * freebsd/sys/netpfil/pf/pf.h (added) * freebsd/sys/netpfil/pf/pf_altq.h (added) * freebsd/sys/netpfil/pf/pf_if.c (added) * freebsd/sys/netpfil/pf/pf_ioctl.c (added) * freebsd/sys/netpfil/pf/pf_lb.c (added) * freebsd/sys/netpfil/pf/pf_mtag.h (added) * freebsd/sys/netpfil/pf/pf_norm.c (added) * freebsd/sys/netpfil/pf/pf_osfp.c (added) * freebsd/sys/netpfil/pf/pf_ruleset.c (added) * freebsd/sys/netpfil/pf/pf_table.c (added) * freebsd/sys/nios2/include/machine/in_cksum.h (modified) * freebsd/sys/opencrypto/cast.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodeflate.c (added) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/deflate.h (modified) * freebsd/sys/opencrypto/gfmult.c (added) * freebsd/sys/opencrypto/gfmult.h (added) * freebsd/sys/opencrypto/gmac.c (added) * freebsd/sys/opencrypto/gmac.h (added) * freebsd/sys/opencrypto/skipjack.h (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/opencrypto/xform.h (modified) * freebsd/sys/opencrypto/xform_aes_icm.c (added) * freebsd/sys/opencrypto/xform_aes_xts.c (added) * freebsd/sys/opencrypto/xform_auth.h (added) * freebsd/sys/opencrypto/xform_blf.c (added) * freebsd/sys/opencrypto/xform_cast5.c (added) * freebsd/sys/opencrypto/xform_cml.c (added) * freebsd/sys/opencrypto/xform_comp.h (added) * freebsd/sys/opencrypto/xform_deflate.c (added) * freebsd/sys/opencrypto/xform_des1.c (added) * freebsd/sys/opencrypto/xform_des3.c (added) * freebsd/sys/opencrypto/xform_enc.h (added) * freebsd/sys/opencrypto/xform_gmac.c (added) * freebsd/sys/opencrypto/xform_md5.c (added) * freebsd/sys/opencrypto/xform_null.c (added) * freebsd/sys/opencrypto/xform_rijndael.c (added) * freebsd/sys/opencrypto/xform_rmd160.c (added) * freebsd/sys/opencrypto/xform_sha1.c (added) * freebsd/sys/opencrypto/xform_sha2.c (added) * freebsd/sys/opencrypto/xform_skipjack.c (added) * freebsd/sys/opencrypto/xform_userland.h (added) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/in_cksum.h (modified) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/security/mac/mac_framework.h (modified) * freebsd/sys/sh/include/machine/in_cksum.h (modified) * freebsd/sys/sparc/include/machine/in_cksum.h (modified) * freebsd/sys/sparc64/include/machine/in_cksum.h (modified) * freebsd/sys/sys/_bitset.h (added) * freebsd/sys/sys/_callout.h (modified) * freebsd/sys/sys/_cpuset.h (added) * freebsd/sys/sys/_mutex.h (modified) * freebsd/sys/sys/_pctrie.h (added) * freebsd/sys/sys/_rmlock.h (modified) * freebsd/sys/sys/_rwlock.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/_unrhdr.h (added) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bitset.h (added) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/caprights.h (added) * freebsd/sys/sys/capsicum.h (added) * freebsd/sys/sys/condvar.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/counter.h (added) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/fail.h (added) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/fnv_hash.h (modified) * freebsd/sys/sys/gpio.h (added) * freebsd/sys/sys/hash.h (modified) * freebsd/sys/sys/hhook.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/khelp.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/kthread.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/ktr_class.h (added) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/loginclass.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nlist_aout.h (modified) * freebsd/sys/sys/osd.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/pipe.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/racct.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rman.h (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/sdt.h (modified) * freebsd/sys/sys/seq.h (added) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/signalvar.h (added) * freebsd/sys/sys/sleepqueue.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/tree.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttydevsw.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/uuid.h (added) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/v850/include/machine/in_cksum.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * freebsd/sys/vm/uma_dbg.h (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/include/machine/bus.h (modified) * freebsd/sys/x86/include/machine/pci_cfgreg.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/flowtable.c (added) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/nl_defs.h (added) * freebsd/usr.bin/netstat/nl_symbols.c (added) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-bpf-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-flowtable-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-if-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-inet-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-inet6-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-ipsec-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-main-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-mbuf-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-mroute-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-mroute6-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-namespace.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-nl_symbols-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-pfkey-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-route-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-sctp-data.h (added) * freebsd/usr.bin/netstat/rtems-bsd-netstat-unix-data.h (added) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/ddb/ddb.h (modified) * rtemsbsd/include/machine/counter.h (added) * rtemsbsd/include/machine/pcpu.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/rtems/bsd/local/bus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/device_if.h (modified) * rtemsbsd/include/rtems/bsd/local/gpio_if.h (added) * rtemsbsd/include/rtems/bsd/local/if_dwc_if.h (added) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_callout_profiling.h (added) * rtemsbsd/include/rtems/bsd/local/opt_em.h (added) * rtemsbsd/include/rtems/bsd/local/opt_ifmedia.h (added) * rtemsbsd/include/rtems/bsd/local/opt_kld.h (added) * rtemsbsd/include/rtems/bsd/local/opt_kqueue.h (added) * rtemsbsd/include/rtems/bsd/local/opt_kstack_usage_prof.h (added) * rtemsbsd/include/rtems/bsd/local/opt_pci.h (added) * rtemsbsd/include/rtems/bsd/local/opt_rss.h (added) * rtemsbsd/include/rtems/bsd/local/opt_stack.h (added) * rtemsbsd/include/rtems/bsd/local/opt_timer.h (added) * rtemsbsd/include/rtems/bsd/local/opt_verbose_sysinit.h (added) * rtemsbsd/include/rtems/bsd/local/opt_vm.h (added) * rtemsbsd/include/rtems/bsd/local/pci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/pcib_if.h (modified) * rtemsbsd/include/rtems/bsd/sys/cpuset.h (modified) * rtemsbsd/include/rtems/bsd/sys/lock.h (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/include/sys/_vm_domain.h (added) * rtemsbsd/include/sys/fail.h (deleted) * rtemsbsd/include/sys/signalvar.h (deleted) * rtemsbsd/include/sys/stack.h (added) * rtemsbsd/include/sys/stdatomic.h (added) * rtemsbsd/include/sys/zlib.h (added) * rtemsbsd/include/vm/memguard.h (added) * rtemsbsd/include/vm/vm_domain.h (added) * rtemsbsd/include/vm/vm_map.h (modified) * rtemsbsd/local/bus_if.c (modified) * rtemsbsd/local/device_if.c (modified) * rtemsbsd/local/gpio_if.c (added) * rtemsbsd/local/if_dwc_if.c (added) * rtemsbsd/local/miibus_if.c (modified) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/mmcbus_if.c (modified) * rtemsbsd/local/pci_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) * rtemsbsd/local/usb_if.c (modified) * rtemsbsd/rtems/generate_kvm_symbols (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-irqs.c (modified) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/rtems/rtems-kernel-malloc.c (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) * rtemsbsd/rtems/rtems-kernel-page.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) * rtemsbsd/rtems/rtems-legacy-rtrequest.c (modified) * rtemsbsd/sys/dev/ffec/if_ffec_mcf548x.c (modified) * rtemsbsd/sys/dev/tsec/if_tsec_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) * rtemsbsd/sys/net/if_ppp.c (modified) * rtemsbsd/sys/net/if_pppvar.h (modified) * rtemsbsd/sys/net/ppp_tty.c (modified) * testsuite/netshell01/shellconfig.c (modified) Update to FreeBSD head 2016-08-23 Git mirror commit ... Wed, 21 Dec 2016 19:01:28 GMT Kevin Kirspel [b1580fb] * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/sys/pipe.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) * testsuite/selectpollkqueue01/test_main.c (modified) PIPE(2): Port to RTEMS Mon, 28 Nov 2016 03:23:15 GMT Chris Johns [f7a4107] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/debugger/rtems-debugger-remote-tcp.c (added) * rtemsbsd/include/rtems/rtems-debugger-remote-tcp.h (added) * testsuite/debugger01/test_main.c (added) * waf_generator.py (modified) Add a RTEMS Debugger TCP remote transport. The patch also adds ... Wed, 09 Nov 2016 09:26:17 GMT Sebastian Huber [6254bf4] * freebsd/sys/dev/sdhci/sdhci.c (deleted) * freebsd/sys/dev/sdhci/sdhci.h (deleted) * libbsd.py (modified) * libbsd_waf.py (modified) SDHCI(4): Delete Delete heavily modified SDHCI(4) support. It must ... Fri, 07 Oct 2016 05:24:30 GMT Sebastian Huber [a9d38f5] * builder.py (modified) * freebsd/sbin/ifconfig/af_atalk.c (deleted) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/netatalk/aarp.c (deleted) * freebsd/sys/netatalk/aarp.h (deleted) * freebsd/sys/netatalk/at.h (deleted) * freebsd/sys/netatalk/at_control.c (deleted) * freebsd/sys/netatalk/at_extern.h (deleted) * freebsd/sys/netatalk/at_proto.c (deleted) * freebsd/sys/netatalk/at_rmx.c (deleted) * freebsd/sys/netatalk/at_var.h (deleted) * freebsd/sys/netatalk/ddp.h (deleted) * freebsd/sys/netatalk/ddp_input.c (deleted) * freebsd/sys/netatalk/ddp_output.c (deleted) * freebsd/sys/netatalk/ddp_pcb.c (deleted) * freebsd/sys/netatalk/ddp_pcb.h (deleted) * freebsd/sys/netatalk/ddp_usrreq.c (deleted) * freebsd/sys/netatalk/ddp_var.h (deleted) * freebsd/sys/netatalk/endian.h (deleted) * freebsd/sys/netatalk/phase2.h (deleted) * freebsd/usr.bin/netstat/atalk.c (deleted) * libbsd.py (modified) * libbsd_waf.py (modified) Remove AppleTalk support Prepare update to FreeBSD 11. Wed, 28 Sep 2016 13:33:50 GMT Sebastian Huber [ec5b97b] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/usb01/README (deleted) * testsuite/usb01/demo-shell-block-devices.h (deleted) * testsuite/usb01/demo-shell-minimal.h (deleted) * testsuite/usb01/demo-shell.h (deleted) * testsuite/usb01/init.c (modified) * testsuite/usb01/test-file-system.c (deleted) * testsuite/usb01/test.h (deleted) * testsuite/usb01/usb-sysinit.h (deleted) usb01: Simplify test program Wed, 28 Sep 2016 13:00:00 GMT Sebastian Huber [8eb8883] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/rtems-program-socket.c (added) * rtemsbsd/rtems/rtems-program.c (modified) Split rtemsbsd/rtems/rtems-program.c This improves garbage ... Wed, 28 Sep 2016 12:46:55 GMT Sebastian Huber [10e9e05] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/program-internal.h (added) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * rtemsbsd/rtems/rtems-program.c (added) Split rtems-bsd-kernel-program.c Separate kernel and user space parts. Wed, 28 Sep 2016 12:39:32 GMT Sebastian Huber [299d4ba] * libbsd.py (modified) * libbsd_waf.py (modified) Build rtems-bsd-shell-pfctl.c Wed, 28 Sep 2016 11:23:16 GMT Sebastian Huber [d9fe061] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/rtems-bsd-shell-ifconfig.c (added) * rtemsbsd/rtems/rtems-bsd-shell-netcmds.c (deleted) * rtemsbsd/rtems/rtems-bsd-shell-netstat.c (added) * rtemsbsd/rtems/rtems-bsd-shell-pfctl.c (added) * rtemsbsd/rtems/rtems-bsd-shell-ping.c (added) * rtemsbsd/rtems/rtems-bsd-shell-route.c (added) * rtemsbsd/rtems/rtems-bsd-shell-sysctl.c (added) * rtemsbsd/rtems/rtems-bsd-shell-tcpdump.c (added) Split rtems-bsd-shell-netcmds.c This improves garbage collection by ... Wed, 07 Sep 2016 13:43:44 GMT Sebastian Huber [7f75b56] * freebsd/lib/libc/gen/getdomainname.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) Port getdomainname() to RTEMS Thu, 04 Aug 2016 11:20:04 GMT Christian Mauderer [bc9e939] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c (added) * testsuite/rcconf02/test_main.c (modified) pf: Add configuration via rc.conf. Thu, 04 Aug 2016 12:12:17 GMT Christian Mauderer [2fb3a36] * create-kernel-namespace.sh (modified) * freebsd/lib/libc/net/vars.c (modified) * freebsd/sys/netinet6/in6.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) freebsd: Add constant ipv6 addresses from vars.c. This is necessary ... Wed, 03 Aug 2016 11:27:11 GMT Christian Mauderer [7aaa9a1] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/pf02/test_main.c (added) testsuite/pf02: Add interactive pf test. Tue, 05 Jul 2016 14:08:38 GMT Christian Mauderer [c79290a] * libbsd.py (modified) * libbsd_waf.py (modified) pfctl: build files. Thu, 14 Jul 2016 13:34:13 GMT Christian Mauderer [fa43d6a] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/program01/test_main.c (added) * testsuite/syscalls01/test_main.c (modified) testsuite/syscalls01: Split out program01 part. This allows to use ... Mon, 27 Jun 2016 12:29:53 GMT Christian Mauderer [a9bd422] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) * testsuite/pf01/test_main.c (added) testsuite/pf01: Add test that links PF. Tue, 28 Jun 2016 13:13:09 GMT Christian Mauderer [8dacfe4] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/cdev01/test_cdev.c (added) * testsuite/cdev01/test_cdev01.h (added) * testsuite/cdev01/test_main.c (added) testsuite/cdev01: Add test for cdev functions. Tue, 28 Jun 2016 15:27:08 GMT Christian Mauderer [9a01ebf] * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/sys/conf.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/rtems-kernel-conf.c (deleted) kern_conf.c: Adapt for RTEMS. Thu, 30 Jun 2016 05:55:27 GMT Christian Mauderer [b5db332] * freebsd/sys/sys/conf.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/sys/fs/devfs/devfs_devs.c (added) rtemsbsd/devfs: Add. Fri, 01 Jul 2016 05:49:52 GMT Chris Johns [65c65bb] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/telnetd.h (modified) * rtemsbsd/telnetd/telnetd-init.c (added) * rtemsbsd/telnetd/telnetd-service.c (added) * rtemsbsd/telnetd/telnetd.c (modified) * testsuite/rcconf02/test_main.c (modified) Add telnetd as service to rc.conf. Thu, 30 Jun 2016 01:42:49 GMT Chris Johns [f01b1f72] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-allocator-domain-size.c (added) * rtemsbsd/rtems/rtems-bsd-get-allocator-domain-size.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. The domain allocator ... Wed, 29 Jun 2016 23:17:21 GMT Chris Johns [45960a3] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/rtems-routes.h (added) * rtemsbsd/rtems/rtems-routes.c (added) Add rtems_get_route to fetch a specific route from the routing tables. Tue, 28 Jun 2016 03:32:01 GMT Chris Johns [90873cc] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/ftpd/ftpd-init.c (added) * rtemsbsd/ftpd/ftpd-service.c (added) * rtemsbsd/ftpd/ftpd.c (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (added) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/ftpd.h (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/rcconf02/test_main.c (modified) Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. Mon, 27 Jun 2016 03:25:48 GMT Chris Johns [7439724] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/rcconf02/test_main.c (added) Add a services base test. Fri, 10 Jun 2016 12:11:40 GMT Sebastian Huber [58c4e1c5] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/nfsclient/nfs.c (modified) * rtemsbsd/nfsclient/rpcio.c (modified) * testsuite/nfs01/test_main.c (added) nfsclient: Port to LibBSD Thu, 09 Jun 2016 09:48:16 GMT Sebastian Huber [a037da6] * freebsd/lib/libc/xdr/rpc_com.h (added) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libc/xdr/xdr_rec.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) XDR(3): Port to RTEMS Thu, 09 Jun 2016 08:48:05 GMT Sebastian Huber [9880635] * freebsd/include/rpc/clnt_stat.h (modified) * freebsd/include/rpc/rpc_msg.h (modified) * freebsd/include/rpc/svc.h (modified) * freebsd/include/rpcsvc/nis_db.h (modified) * freebsd/include/rpcsvc/yp_prot.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) RPC(3): Port to RTEMS Thu, 09 Jun 2016 09:19:09 GMT Sebastian Huber [68d406b] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/ftpfs/ftpfs.c (added) * rtemsbsd/include/rtems/ftpfs.h (added) * testsuite/ftpd02/test_main.c (added) ftpfs: Import from RTEMS RTEMS Git commit ... Wed, 18 May 2016 03:49:17 GMT Chris Johns [f5c6651] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-directives.h (added) * rtemsbsd/include/machine/rtems-bsd-rc-conf.h (added) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (added) * rtemsbsd/rtems/rtems-bsd-rc-conf.c (added) * testsuite/rcconf01/test_main.c (added) Add support for rc.conf(5) initialisation. Provide user support for ... Fri, 06 May 2016 19:40:49 GMT Sebastian Huber [5b4394f] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/generate_kvm_symbols (modified) * rtemsbsd/rtems/kvm_private.h (modified) * rtemsbsd/rtems/rtems-kvm.c (modified) Add namespace support for kvm Fri, 06 May 2016 19:22:38 GMT Sebastian Huber [5b1f20b] * create-kernel-namespace.sh (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/rtems-kernel-assert.c (moved) * rtemsbsd/rtems/rtems-kernel-autoconf.c (moved) * rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c (moved) * rtemsbsd/rtems/rtems-kernel-bus-dma.c (moved) * rtemsbsd/rtems/rtems-kernel-bus-root.c (moved) * rtemsbsd/rtems/rtems-kernel-cam.c (moved) * rtemsbsd/rtems/rtems-kernel-chunk.c (moved) * rtemsbsd/rtems/rtems-kernel-conf.c (moved) * rtemsbsd/rtems/rtems-kernel-configintrhook.c (moved) * rtemsbsd/rtems/rtems-kernel-delay.c (moved) * rtemsbsd/rtems/rtems-kernel-get-file.c (moved) * rtemsbsd/rtems/rtems-kernel-init.c (moved) * rtemsbsd/rtems/rtems-kernel-irqs.c (moved) * rtemsbsd/rtems/rtems-kernel-jail.c (moved) * rtemsbsd/rtems/rtems-kernel-malloc.c (moved) * rtemsbsd/rtems/rtems-kernel-mbuf.c (moved) * rtemsbsd/rtems/rtems-kernel-mutex.c (moved) * rtemsbsd/rtems/rtems-kernel-muteximpl.c (moved) * rtemsbsd/rtems/rtems-kernel-nexus.c (moved) * rtemsbsd/rtems/rtems-kernel-page.c (moved) * rtemsbsd/rtems/rtems-kernel-panic.c (moved) * rtemsbsd/rtems/rtems-kernel-pci_bus.c (moved) * rtemsbsd/rtems/rtems-kernel-pci_cfgreg.c (moved) * rtemsbsd/rtems/rtems-kernel-program.c (moved) * rtemsbsd/rtems/rtems-kernel-rwlock.c (moved) * rtemsbsd/rtems/rtems-kernel-signal.c (moved) * rtemsbsd/rtems/rtems-kernel-sx.c (moved) * rtemsbsd/rtems/rtems-kernel-sysctl.c (moved) * rtemsbsd/rtems/rtems-kernel-sysctlbyname.c (moved) * rtemsbsd/rtems/rtems-kernel-sysctlnametomib.c (moved) * rtemsbsd/rtems/rtems-kernel-thread.c (moved) * rtemsbsd/rtems/rtems-kernel-timesupport.c (moved) * rtemsbsd/rtems/rtems-kernel-vprintf.c (moved) * rtemsbsd/rtems/rtems-legacy-mii.c (moved) * rtemsbsd/rtems/rtems-legacy-newproc.c (moved) * rtemsbsd/rtems/rtems-legacy-rtrequest.c (moved) Rename files for kernel namespace script This makes it easier to ... Wed, 04 May 2016 11:04:42 GMT Sebastian Huber [54a577d] * freebsd/sys/kern/subr_prf.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-log.c (deleted) * rtemsbsd/rtems/rtems-bsd-vprintf.c (added) * rtemsbsd/rtems/rtems-syslog-initialize.c (deleted) * rtemsbsd/rtems/syslog.c (modified) * testsuite/log01/test_main.c (added) subr_prf.c: Port to RTEMS Fri, 06 May 2016 05:06:08 GMT Chris Johns [83eb07c] * freebsd/lib/libc/stdlib/strtoimax.c (added) * freebsd/lib/libc/stdlib/strtoumax.c (added) * freebsd/sbin/sysctl/sysctl.c (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-netcmds.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Add sbin/sysctl Wed, 04 May 2016 06:01:08 GMT Chris Johns [4b127e7] * freebsd/sys/dev/mii/rgephy.c (added) * freebsd/sys/dev/mii/rgephyreg.h (added) * freebsd/sys/rpc/netconfig.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) Add RealTek Gig PHY. Wed, 27 Apr 2016 02:11:31 GMT Chris Johns [3c7fdb2] * libbsd.py (modified) libbsd: Remove sys/select.h and sys/_sigset.h. Tue, 26 Apr 2016 13:00:44 GMT Sebastian Huber [5b93cc8] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-bus-root.c (added) Add root bus support functions Fri, 30 Oct 2015 07:03:57 GMT Sebastian Huber [00c8792] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/rtems-bsd-irqs.c (added) * rtemsbsd/rtems/rtems-bsd-nexus.c (modified) Initialize interrupt server early This enables its use before the ... Mon, 18 Apr 2016 00:53:20 GMT Chris Johns [97c5024a] * README.waf (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtems_waf (modified) * waf_generator.py (modified) * wscript (modified) Add RTEMS version support, update all python to 2 and 3. Add ... Tue, 17 Nov 2015 14:28:06 GMT Sebastian Huber [33d8f3c7] * freebsd/sys/sys/priority.h (deleted) * libbsd.py (modified) Use RTEMS provided Tue, 17 Nov 2015 14:24:49 GMT Sebastian Huber [39ac918] * freebsd/sys/sys/ttycom.h (deleted) * libbsd.py (modified) Use RTEMS provided Tue, 17 Nov 2015 14:13:44 GMT Sebastian Huber [2dd7b49] * freebsd/sys/sys/sockio.h (deleted) * libbsd.py (modified) Use RTEMS provided Tue, 17 Nov 2015 14:04:54 GMT Sebastian Huber [25ce3e8] * freebsd/sys/sys/mman.h (deleted) * libbsd.py (modified) Use RTEMS provided Tue, 17 Nov 2015 13:42:28 GMT Sebastian Huber [d5b64f2] * freebsd/sys/sys/endian.h (deleted) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-endian.h (modified) Use RTEMS provided Thu, 12 Nov 2015 12:01:32 GMT Sebastian Huber [ba44613] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (added) * wscript (modified) dwc_otg: Port to RTEMS Tue, 29 Sep 2015 09:00:58 GMT Sebastian Huber [b168f69] * freebsd/sys/i386/include/machine/_bus.h (added) * freebsd/sys/x86/include/machine/bus.h (moved) * libbsd.py (modified) * rtemsbsd/include/machine/bus.h (modified) * rtemsbsd/include/machine/bus_space-simple_memory.h (deleted) BUS_SPACE(9): Use FreeBSD files for i386 arch Tue, 29 Sep 2015 08:44:04 GMT Sebastian Huber [4cf8982] * freebsd/sys/x86/include/machine/pci_cfgreg.h (moved) * libbsd.py (modified) Avoid pci_cfgreg.h rename Fri, 25 Sep 2015 12:14:04 GMT Sebastian Huber [40f7d5c] * builder.py (modified) * libbsd.py (modified) * wscript (modified) builder.py: addTargetSourceCPUDependentSourceFiles Avoid and delete ... Fri, 25 Sep 2015 12:05:58 GMT Sebastian Huber [7d460ce] * freebsd/sys/x86/pci/pci_bus.c (moved) * libbsd.py (modified) * wscript (modified) Avoid pci_bus.c file rename Tue, 01 Sep 2015 05:51:31 GMT Sebastian Huber [986f7dd] * freebsd/sys/arm/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/avr/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/bfin/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/h8300/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/lm32/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/m32c/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/m32r/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/m68k/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/mips/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/nios2/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/powerpc/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/sh/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/sparc/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/sparc64/include/machine/pci_cfgreg.h (deleted) * freebsd/sys/v850/include/machine/pci_cfgreg.h (deleted) * libbsd.py (modified) Delete superfluous pci_cfgreg.h files Tue, 01 Sep 2015 05:48:34 GMT Sebastian Huber [89050cc] * freebsd/sys/arm/include/machine/legacyvar.h (deleted) * freebsd/sys/avr/include/machine/legacyvar.h (deleted) * freebsd/sys/bfin/include/machine/legacyvar.h (deleted) * freebsd/sys/h8300/include/machine/legacyvar.h (deleted) * freebsd/sys/lm32/include/machine/legacyvar.h (deleted) * freebsd/sys/m32c/include/machine/legacyvar.h (deleted) * freebsd/sys/m32r/include/machine/legacyvar.h (deleted) * freebsd/sys/m68k/include/machine/legacyvar.h (deleted) * freebsd/sys/mips/include/machine/legacyvar.h (deleted) * freebsd/sys/nios2/include/machine/legacyvar.h (deleted) * freebsd/sys/powerpc/include/machine/legacyvar.h (deleted) * freebsd/sys/sh/include/machine/legacyvar.h (deleted) * freebsd/sys/sparc/include/machine/legacyvar.h (deleted) * freebsd/sys/sparc64/include/machine/legacyvar.h (deleted) * freebsd/sys/v850/include/machine/legacyvar.h (deleted) * libbsd.py (modified) Delete superfluous legacyvar.h files Tue, 01 Sep 2015 05:44:48 GMT Sebastian Huber [5e62c73] * freebsd/sys/arm/pci/pci_bus.c (deleted) * freebsd/sys/avr/pci/pci_bus.c (deleted) * freebsd/sys/bfin/pci/pci_bus.c (deleted) * freebsd/sys/h8300/pci/pci_bus.c (deleted) * freebsd/sys/lm32/pci/pci_bus.c (deleted) * freebsd/sys/m32c/pci/pci_bus.c (deleted) * freebsd/sys/m32r/pci/pci_bus.c (deleted) * freebsd/sys/m68k/pci/pci_bus.c (deleted) * freebsd/sys/mips/pci/pci_bus.c (deleted) * freebsd/sys/nios2/pci/pci_bus.c (deleted) * freebsd/sys/powerpc/pci/pci_bus.c (deleted) * freebsd/sys/sh/pci/pci_bus.c (deleted) * freebsd/sys/sparc/pci/pci_bus.c (deleted) * freebsd/sys/sparc64/pci/pci_bus.c (deleted) * freebsd/sys/v850/pci/pci_bus.c (deleted) * freebsd/sys/x86/pci/pci_bus.c (deleted) * libbsd.py (modified) * wscript (modified) Delete superfluous pci_bus.c files Tue, 01 Sep 2015 05:38:49 GMT Sebastian Huber [3fece79] * freebsd/sys/arm/arm/legacy.c (deleted) * freebsd/sys/avr/avr/legacy.c (deleted) * freebsd/sys/bfin/bfin/legacy.c (deleted) * freebsd/sys/h8300/h8300/legacy.c (deleted) * freebsd/sys/lm32/lm32/legacy.c (deleted) * freebsd/sys/m32c/m32c/legacy.c (deleted) * freebsd/sys/m32r/m32r/legacy.c (deleted) * freebsd/sys/m68k/m68k/legacy.c (deleted) * freebsd/sys/mips/mips/legacy.c (deleted) * freebsd/sys/nios2/nios2/legacy.c (deleted) * freebsd/sys/powerpc/powerpc/legacy.c (deleted) * freebsd/sys/sh/sh/legacy.c (deleted) * freebsd/sys/sparc/sparc/legacy.c (deleted) * freebsd/sys/sparc64/sparc64/legacy.c (deleted) * freebsd/sys/v850/v850/legacy.c (deleted) * libbsd.py (modified) * wscript (modified) Delete superfluous legacy.c files Fri, 31 Jul 2015 09:54:27 GMT Sebastian Huber [a3ef8e6] * freebsd/sys/dev/e1000/e1000_i210.c (added) * libbsd.py (modified) * wscript (modified) e1000: Add missing file Tue, 16 Jun 2015 03:19:32 GMT Chris Johns [06cd120] * Makefile (modified) * libbsd.py (modified) * wscript (modified) TCPDUMP and PCAP fixes to defines. Mon, 15 Jun 2015 07:42:23 GMT Chris Johns [8440506] * Makefile (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * freebsd/contrib/libpcap/arcnet.h (added) * freebsd/contrib/libpcap/atmuni31.h (added) * freebsd/contrib/libpcap/bpf_image.c (added) * freebsd/contrib/libpcap/etherent.c (added) * freebsd/contrib/libpcap/ethertype.h (added) * freebsd/contrib/libpcap/fad-getad.c (added) * freebsd/contrib/libpcap/gencode.c (added) * freebsd/contrib/libpcap/gencode.h (added) * freebsd/contrib/libpcap/grammar.c (added) * freebsd/contrib/libpcap/grammar.y (added) * freebsd/contrib/libpcap/ieee80211.h (added) * freebsd/contrib/libpcap/inet.c (added) * freebsd/contrib/libpcap/llc.h (added) * freebsd/contrib/libpcap/nametoaddr.c (added) * freebsd/contrib/libpcap/nlpid.h (added) * freebsd/contrib/libpcap/optimize.c (added) * freebsd/contrib/libpcap/pcap-bpf.c (added) * freebsd/contrib/libpcap/pcap-common.c (added) * freebsd/contrib/libpcap/pcap-common.h (added) * freebsd/contrib/libpcap/pcap-int.h (added) * freebsd/contrib/libpcap/pcap-namedb.h (added) * freebsd/contrib/libpcap/pcap.c (added) * freebsd/contrib/libpcap/pcap.h (added) * freebsd/contrib/libpcap/pcap/ipnet.h (added) * freebsd/contrib/libpcap/pcap/namedb.h (added) * freebsd/contrib/libpcap/pcap/pcap.h (added) * freebsd/contrib/libpcap/pcap/sll.h (added) * freebsd/contrib/libpcap/pcap/usb.h (added) * freebsd/contrib/libpcap/ppp.h (added) * freebsd/contrib/libpcap/savefile.c (added) * freebsd/contrib/libpcap/scanner.c (added) * freebsd/contrib/libpcap/scanner.l (added) * freebsd/contrib/libpcap/sf-pcap-ng.c (added) * freebsd/contrib/libpcap/sf-pcap-ng.h (added) * freebsd/contrib/libpcap/sf-pcap.c (added) * freebsd/contrib/libpcap/sf-pcap.h (added) * freebsd/contrib/libpcap/sunatmpos.h (added) * freebsd/contrib/tcpdump/addrtoname.c (added) * freebsd/contrib/tcpdump/addrtoname.h (added) * freebsd/contrib/tcpdump/af.c (added) * freebsd/contrib/tcpdump/af.h (added) * freebsd/contrib/tcpdump/ah.h (added) * freebsd/contrib/tcpdump/aodv.h (added) * freebsd/contrib/tcpdump/appletalk.h (added) * freebsd/contrib/tcpdump/arcnet.h (added) * freebsd/contrib/tcpdump/atm.h (added) * freebsd/contrib/tcpdump/bgp.h (added) * freebsd/contrib/tcpdump/bootp.h (added) * freebsd/contrib/tcpdump/bpf_dump.c (added) * freebsd/contrib/tcpdump/chdlc.h (added) * freebsd/contrib/tcpdump/checksum.c (added) * freebsd/contrib/tcpdump/cpack.c (added) * freebsd/contrib/tcpdump/cpack.h (added) * freebsd/contrib/tcpdump/dccp.h (added) * freebsd/contrib/tcpdump/decnet.h (added) * freebsd/contrib/tcpdump/decode_prefix.h (added) * freebsd/contrib/tcpdump/enc.h (added) * freebsd/contrib/tcpdump/esp.h (added) * freebsd/contrib/tcpdump/ether.h (added) * freebsd/contrib/tcpdump/ethertype.h (added) * freebsd/contrib/tcpdump/extract.h (added) * freebsd/contrib/tcpdump/fddi.h (added) * freebsd/contrib/tcpdump/forces.h (added) * freebsd/contrib/tcpdump/gmpls.c (added) * freebsd/contrib/tcpdump/gmpls.h (added) * freebsd/contrib/tcpdump/gmt2local.c (added) * freebsd/contrib/tcpdump/gmt2local.h (added) * freebsd/contrib/tcpdump/icmp6.h (added) * freebsd/contrib/tcpdump/ieee802_11.h (added) * freebsd/contrib/tcpdump/ieee802_11_radio.h (added) * freebsd/contrib/tcpdump/igrp.h (added) * freebsd/contrib/tcpdump/in_cksum.c (added) * freebsd/contrib/tcpdump/interface.h (added) * freebsd/contrib/tcpdump/ip.h (added) * freebsd/contrib/tcpdump/ip6.h (added) * freebsd/contrib/tcpdump/ipfc.h (added) * freebsd/contrib/tcpdump/ipnet.h (added) * freebsd/contrib/tcpdump/ipproto.c (added) * freebsd/contrib/tcpdump/ipproto.h (added) * freebsd/contrib/tcpdump/ipsec_doi.h (added) * freebsd/contrib/tcpdump/ipx.h (added) * freebsd/contrib/tcpdump/isakmp.h (added) * freebsd/contrib/tcpdump/l2tp.h (added) * freebsd/contrib/tcpdump/l2vpn.c (added) * freebsd/contrib/tcpdump/l2vpn.h (added) * freebsd/contrib/tcpdump/lane.h (added) * freebsd/contrib/tcpdump/llc.h (added) * freebsd/contrib/tcpdump/machdep.c (added) * freebsd/contrib/tcpdump/machdep.h (added) * freebsd/contrib/tcpdump/mib.h (added) * freebsd/contrib/tcpdump/mpls.h (added) * freebsd/contrib/tcpdump/nameser.h (added) * freebsd/contrib/tcpdump/netbios.h (added) * freebsd/contrib/tcpdump/netdissect.h (added) * freebsd/contrib/tcpdump/nfs.h (added) * freebsd/contrib/tcpdump/nfsfh.h (added) * freebsd/contrib/tcpdump/nlpid.c (added) * freebsd/contrib/tcpdump/nlpid.h (added) * freebsd/contrib/tcpdump/ntp.h (added) * freebsd/contrib/tcpdump/oakley.h (added) * freebsd/contrib/tcpdump/ospf.h (added) * freebsd/contrib/tcpdump/ospf6.h (added) * freebsd/contrib/tcpdump/oui.c (added) * freebsd/contrib/tcpdump/oui.h (added) * freebsd/contrib/tcpdump/parsenfsfh.c (added) * freebsd/contrib/tcpdump/pcap-missing.h (added) * freebsd/contrib/tcpdump/pmap_prot.h (added) * freebsd/contrib/tcpdump/ppi.h (added) * freebsd/contrib/tcpdump/ppp.h (added) * freebsd/contrib/tcpdump/print-802_11.c (added) * freebsd/contrib/tcpdump/print-802_15_4.c (added) * freebsd/contrib/tcpdump/print-ah.c (added) * freebsd/contrib/tcpdump/print-aodv.c (added) * freebsd/contrib/tcpdump/print-ap1394.c (added) * freebsd/contrib/tcpdump/print-arcnet.c (added) * freebsd/contrib/tcpdump/print-arp.c (added) * freebsd/contrib/tcpdump/print-ascii.c (added) * freebsd/contrib/tcpdump/print-atalk.c (added) * freebsd/contrib/tcpdump/print-atm.c (added) * freebsd/contrib/tcpdump/print-babel.c (added) * freebsd/contrib/tcpdump/print-beep.c (added) * freebsd/contrib/tcpdump/print-bfd.c (added) * freebsd/contrib/tcpdump/print-bgp.c (added) * freebsd/contrib/tcpdump/print-bootp.c (added) * freebsd/contrib/tcpdump/print-bt.c (added) * freebsd/contrib/tcpdump/print-carp.c (added) * freebsd/contrib/tcpdump/print-cdp.c (added) * freebsd/contrib/tcpdump/print-cfm.c (added) * freebsd/contrib/tcpdump/print-chdlc.c (added) * freebsd/contrib/tcpdump/print-cip.c (added) * freebsd/contrib/tcpdump/print-cnfp.c (added) * freebsd/contrib/tcpdump/print-dccp.c (added) * freebsd/contrib/tcpdump/print-decnet.c (added) * freebsd/contrib/tcpdump/print-dhcp6.c (added) * freebsd/contrib/tcpdump/print-domain.c (added) * freebsd/contrib/tcpdump/print-dtp.c (added) * freebsd/contrib/tcpdump/print-dvmrp.c (added) * freebsd/contrib/tcpdump/print-eap.c (added) * freebsd/contrib/tcpdump/print-egp.c (added) * freebsd/contrib/tcpdump/print-eigrp.c (added) * freebsd/contrib/tcpdump/print-enc.c (added) * freebsd/contrib/tcpdump/print-esp.c (added) * freebsd/contrib/tcpdump/print-ether.c (added) * freebsd/contrib/tcpdump/print-fddi.c (added) * freebsd/contrib/tcpdump/print-forces.c (added) * freebsd/contrib/tcpdump/print-fr.c (added) * freebsd/contrib/tcpdump/print-frag6.c (added) * freebsd/contrib/tcpdump/print-gre.c (added) * freebsd/contrib/tcpdump/print-hsrp.c (added) * freebsd/contrib/tcpdump/print-icmp.c (added) * freebsd/contrib/tcpdump/print-icmp6.c (added) * freebsd/contrib/tcpdump/print-igmp.c (added) * freebsd/contrib/tcpdump/print-igrp.c (added) * freebsd/contrib/tcpdump/print-ip.c (added) * freebsd/contrib/tcpdump/print-ip6.c (added) * freebsd/contrib/tcpdump/print-ip6opts.c (added) * freebsd/contrib/tcpdump/print-ipcomp.c (added) * freebsd/contrib/tcpdump/print-ipfc.c (added) * freebsd/contrib/tcpdump/print-ipnet.c (added) * freebsd/contrib/tcpdump/print-ipx.c (added) * freebsd/contrib/tcpdump/print-isakmp.c (added) * freebsd/contrib/tcpdump/print-isoclns.c (added) * freebsd/contrib/tcpdump/print-juniper.c (added) * freebsd/contrib/tcpdump/print-krb.c (added) * freebsd/contrib/tcpdump/print-l2tp.c (added) * freebsd/contrib/tcpdump/print-lane.c (added) * freebsd/contrib/tcpdump/print-ldp.c (added) * freebsd/contrib/tcpdump/print-llc.c (added) * freebsd/contrib/tcpdump/print-lldp.c (added) * freebsd/contrib/tcpdump/print-lmp.c (added) * freebsd/contrib/tcpdump/print-lspping.c (added) * freebsd/contrib/tcpdump/print-lwapp.c (added) * freebsd/contrib/tcpdump/print-lwres.c (added) * freebsd/contrib/tcpdump/print-mobile.c (added) * freebsd/contrib/tcpdump/print-mobility.c (added) * freebsd/contrib/tcpdump/print-mpcp.c (added) * freebsd/contrib/tcpdump/print-mpls.c (added) * freebsd/contrib/tcpdump/print-msdp.c (added) * freebsd/contrib/tcpdump/print-msnlb.c (added) * freebsd/contrib/tcpdump/print-netbios.c (added) * freebsd/contrib/tcpdump/print-nfs.c (added) * freebsd/contrib/tcpdump/print-ntp.c (added) * freebsd/contrib/tcpdump/print-null.c (added) * freebsd/contrib/tcpdump/print-olsr.c (added) * freebsd/contrib/tcpdump/print-ospf.c (added) * freebsd/contrib/tcpdump/print-ospf6.c (added) * freebsd/contrib/tcpdump/print-otv.c (added) * freebsd/contrib/tcpdump/print-pflog.c (added) * freebsd/contrib/tcpdump/print-pfsync.c (added) * freebsd/contrib/tcpdump/print-pgm.c (added) * freebsd/contrib/tcpdump/print-pim.c (added) * freebsd/contrib/tcpdump/print-ppi.c (added) * freebsd/contrib/tcpdump/print-ppp.c (added) * freebsd/contrib/tcpdump/print-pppoe.c (added) * freebsd/contrib/tcpdump/print-pptp.c (added) * freebsd/contrib/tcpdump/print-radius.c (added) * freebsd/contrib/tcpdump/print-raw.c (added) * freebsd/contrib/tcpdump/print-rip.c (added) * freebsd/contrib/tcpdump/print-ripng.c (added) * freebsd/contrib/tcpdump/print-rpki-rtr.c (added) * freebsd/contrib/tcpdump/print-rrcp.c (added) * freebsd/contrib/tcpdump/print-rsvp.c (added) * freebsd/contrib/tcpdump/print-rt6.c (added) * freebsd/contrib/tcpdump/print-rx.c (added) * freebsd/contrib/tcpdump/print-sctp.c (added) * freebsd/contrib/tcpdump/print-sflow.c (added) * freebsd/contrib/tcpdump/print-sip.c (added) * freebsd/contrib/tcpdump/print-sl.c (added) * freebsd/contrib/tcpdump/print-sll.c (added) * freebsd/contrib/tcpdump/print-slow.c (added) * freebsd/contrib/tcpdump/print-smb.c (added) * freebsd/contrib/tcpdump/print-snmp.c (added) * freebsd/contrib/tcpdump/print-stp.c (added) * freebsd/contrib/tcpdump/print-sunatm.c (added) * freebsd/contrib/tcpdump/print-sunrpc.c (added) * freebsd/contrib/tcpdump/print-symantec.c (added) * freebsd/contrib/tcpdump/print-syslog.c (added) * freebsd/contrib/tcpdump/print-tcp.c (added) * freebsd/contrib/tcpdump/print-telnet.c (added) * freebsd/contrib/tcpdump/print-tftp.c (added) * freebsd/contrib/tcpdump/print-timed.c (added) * freebsd/contrib/tcpdump/print-tipc.c (added) * freebsd/contrib/tcpdump/print-token.c (added) * freebsd/contrib/tcpdump/print-udld.c (added) * freebsd/contrib/tcpdump/print-udp.c (added) * freebsd/contrib/tcpdump/print-usb.c (added) * freebsd/contrib/tcpdump/print-vjc.c (added) * freebsd/contrib/tcpdump/print-vqp.c (added) * freebsd/contrib/tcpdump/print-vrrp.c (added) * freebsd/contrib/tcpdump/print-vtp.c (added) * freebsd/contrib/tcpdump/print-vxlan.c (added) * freebsd/contrib/tcpdump/print-wb.c (added) * freebsd/contrib/tcpdump/print-zephyr.c (added) * freebsd/contrib/tcpdump/print-zeromq.c (added) * freebsd/contrib/tcpdump/route6d.h (added) * freebsd/contrib/tcpdump/rpc_auth.h (added) * freebsd/contrib/tcpdump/rpc_msg.h (added) * freebsd/contrib/tcpdump/rx.h (added) * freebsd/contrib/tcpdump/sctpConstants.h (added) * freebsd/contrib/tcpdump/sctpHeader.h (added) * freebsd/contrib/tcpdump/setsignal.c (added) * freebsd/contrib/tcpdump/setsignal.h (added) * freebsd/contrib/tcpdump/signature.c (added) * freebsd/contrib/tcpdump/signature.h (added) * freebsd/contrib/tcpdump/slcompress.h (added) * freebsd/contrib/tcpdump/slip.h (added) * freebsd/contrib/tcpdump/sll.h (added) * freebsd/contrib/tcpdump/smb.h (added) * freebsd/contrib/tcpdump/smbutil.c (added) * freebsd/contrib/tcpdump/tcp.h (added) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (added) * freebsd/contrib/tcpdump/tcpdump.c (added) * freebsd/contrib/tcpdump/telnet.h (added) * freebsd/contrib/tcpdump/tftp.h (added) * freebsd/contrib/tcpdump/timed.h (added) * freebsd/contrib/tcpdump/token.h (added) * freebsd/contrib/tcpdump/udp.h (added) * freebsd/contrib/tcpdump/util.c (added) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (added) * libbsd.py (modified) * makefile.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * waf_generator.py (modified) * wscript (modified) Add tcpdump and libpcap. - Update the file builder generator to ... Wed, 20 May 2015 11:49:05 GMT Sebastian Huber [595b333] * Makefile (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/vm/uma_dbg.c (added) * libbsd.py (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-page.c (modified) * rtemsbsd/rtems/rtems-bsd-rwlock.c (modified) * rtemsbsd/rtems/rtems-bsd-sx.c (modified) * wscript (modified) Add INVARIANTS support Fri, 15 May 2015 12:29:57 GMT Sebastian Huber [8eaa39f] * freebsd/sys/sys/timepps.h (deleted) * freebsd/sys/sys/timetc.h (deleted) * freebsd/sys/sys/timex.h (deleted) * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/sys/time.h (modified) * rtemsbsd/rtems/rtems-bsd-init.c (modified) * rtemsbsd/rtems/rtems-bsd-timesupport.c (modified) Update due to API changes (timecounters) Mon, 16 Mar 2015 20:39:14 GMT Sebastian Huber [278bc93] * Makefile (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ehci.h (modified) * libbsd.py (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (added) * rtemsbsd/sys/dev/usb/controller/ohci_lpc24xx.c (deleted) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (deleted) * rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver.c (added) * rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver_dump.c (added) * rtemsbsd/sys/dev/usb/usb_otg_transceiver.h (added) usb: Import USB support from libusb Fri, 15 May 2015 13:39:34 GMT Sebastian Huber [0799761] * libbsd.py (modified) Disable IEEE 802.11 module Fri, 01 May 2015 06:02:22 GMT Chris Johns [314be23] * .gitignore (modified) * builder.py (added) * freebsd-to-rtems.py (modified) * libbsd.py (added) * makefile.py (added) freebsd-to-rtems: Refactor the conversion support to allow multiples ...
