# # ChangeLog for libbsd.py in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/17/24 12:33:03 Thu, 09 Jun 2022 08:10:06 GMT Sebastian Huber [2722615] * libbsd.py (modified) * rtemsbsd/sys/arm/lpc/if_lpe.c (modified) * rtemsbsd/sys/arm/lpc/if_lpereg.h (deleted) if_lpe.c: Import legacy LPC Ethernet driver The standard FreeBSD ... Tue, 10 May 2022 12:01:44 GMT Sebastian Huber [a4c3d74] * libbsd.py (modified) * testsuite/tcpdump01/test_main.c (added) tcpdump01: New test Update #4650. Fri, 08 Apr 2022 14:05:23 GMT Frank Kühndel [d63f9cd] * libbsd.py (modified) * testsuite/media01/test_main.c (modified) libbsd: Add TFTP filesystem to test media01 How test media01 can be ... Mon, 07 Feb 2022 03:12:31 GMT Alex White [40b9c6c] * buildset/default.ini (modified) * freebsd/sys/dev/xdma/xdma.c (modified) * freebsd/sys/dev/xdma/xdma.h (modified) * freebsd/sys/dev/xdma/xdma_sg.c (modified) * freebsd/sys/dev/xilinx/axidma.c (modified) * freebsd/sys/dev/xilinx/if_xae.c (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/rtems/bsd/local/xdma_if.h (added) * rtemsbsd/local/xdma_if.c (added) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) if_xae: Port to RTEMS Mon, 07 Feb 2022 03:11:10 GMT Jennifer Averett [d10228d] * freebsd/sys/microblaze/include/machine/in_cksum.h (added) * libbsd.py (modified) Add MicroBlaze support Sun, 06 Mar 2022 17:01:30 GMT Heinz Junkes [de0badf] * buildset/default.ini (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/mv643xx_eth.h (added) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/dev/mve/if_mve.c (added) * rtemsbsd/sys/dev/mve/if_mve_nexus.c (added) if_mve: Add MV643XX Ethernet driver Update #4345. Wed, 20 Oct 2021 03:15:28 GMT Chris Johns [25a8832] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/arm64/xilinx/versal_slcr.c (added) * rtemsbsd/sys/arm64/xilinx/versal_slcr.h (added) Add support for Xilinx Versal APAC Thu, 29 Jul 2021 05:49:52 GMT Chris Johns [882425f] * buildset/default.ini (modified) * buildset/nfsv2.ini (added) * config.inc (modified) * freebsd/sys/fs/nfs/nfs_commonacl.c (modified) * freebsd/sys/fs/nfs/nfs_commonkrpc.c (modified) * freebsd/sys/fs/nfs/nfs_commonport.c (modified) * freebsd/sys/fs/nfs/nfs_commonsubs.c (modified) * freebsd/sys/fs/nfs/nfsport.h (modified) * freebsd/sys/fs/nfsclient/nfs.h (modified) * freebsd/sys/fs/nfsclient/nfs_clbio.c (modified) * freebsd/sys/fs/nfsclient/nfs_clcomsubs.c (modified) * freebsd/sys/fs/nfsclient/nfs_clkdtrace.c (modified) * freebsd/sys/fs/nfsclient/nfs_clkrpc.c (modified) * freebsd/sys/fs/nfsclient/nfs_clnfsiod.c (modified) * freebsd/sys/fs/nfsclient/nfs_clnode.c (modified) * freebsd/sys/fs/nfsclient/nfs_clport.c (modified) * freebsd/sys/fs/nfsclient/nfs_clrpcops.c (modified) * freebsd/sys/fs/nfsclient/nfs_clstate.c (modified) * freebsd/sys/fs/nfsclient/nfs_clsubs.c (modified) * freebsd/sys/fs/nfsclient/nfs_clvfsops.c (modified) * freebsd/sys/fs/nfsclient/nfs_clvnops.c (modified) * freebsd/sys/nfs/bootp_subr.c (modified) * freebsd/sys/nfs/krpc_subr.c (modified) * freebsd/sys/nfs/nfs_fha.c (modified) * freebsd/sys/nfs/nfs_lock.c (modified) * freebsd/sys/nfs/nfs_nfssvc.c (modified) * freebsd/sys/nfsclient/nfs.h (modified) * freebsd/sys/nfsclient/nfsnode.h (modified) * libbsd.py (modified) * rtemsbsd/fs/nfsclient/nfs.c (added) * rtemsbsd/include/rtems/bsd/local/opt_kgssapi.h (added) * rtemsbsd/include/rtems/bsd/local/opt_nfs.h (added) * rtemsbsd/include/rtems/bsd/local/opt_nfsroot.h (added) * rtemsbsd/include/rtems/bsd/local/opt_rootdevname.h (added) * rtemsbsd/include/rtems/bsd/local/opt_ufs.h (added) * rtemsbsd/rtems/rtems-bsd-libio.c (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) * testsuite/nfs01/test_main.c (modified) * waf_libbsd.py (modified) kern/sys: Add NFSv4 client Update #4475 Thu, 29 Jul 2021 03:24:49 GMT Chris Johns [c6dbc96] * buildset/default.ini (modified) * freebsd/sys/rpc/auth_none.c (modified) * freebsd/sys/rpc/auth_unix.c (modified) * freebsd/sys/rpc/authunix_prot.c (modified) * freebsd/sys/rpc/clnt_bck.c (modified) * freebsd/sys/rpc/clnt_dg.c (modified) * freebsd/sys/rpc/clnt_rc.c (modified) * freebsd/sys/rpc/clnt_vc.c (modified) * freebsd/sys/rpc/getnetconfig.c (modified) * freebsd/sys/rpc/replay.c (modified) * freebsd/sys/rpc/rpc_callmsg.c (modified) * freebsd/sys/rpc/rpc_com.h (modified) * freebsd/sys/rpc/rpc_generic.c (modified) * freebsd/sys/rpc/rpc_prot.c (modified) * freebsd/sys/rpc/rpcb_clnt.c (modified) * freebsd/sys/rpc/rpcb_prot.c (modified) * freebsd/sys/rpc/svc.c (modified) * freebsd/sys/rpc/svc_auth.c (modified) * freebsd/sys/rpc/svc_auth_unix.c (modified) * freebsd/sys/rpc/svc_dg.c (modified) * freebsd/sys/rpc/svc_generic.c (modified) * freebsd/sys/rpc/svc_vc.c (modified) * freebsd/sys/xdr/xdr.c (modified) * freebsd/sys/xdr/xdr_array.c (modified) * freebsd/sys/xdr/xdr_mbuf.c (modified) * freebsd/sys/xdr/xdr_mem.c (modified) * freebsd/sys/xdr/xdr_reference.c (modified) * freebsd/sys/xdr/xdr_sizeof.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) kern/sys: Add the kernel RPC and XDR support Updates #4475 Mon, 02 Aug 2021 05:09:41 GMT Chris Johns [6514d56] * .clang-format (modified) * README.md (modified) * freebsd/sys/fs/deadfs/dead_vnops.c (modified) * freebsd/sys/fs/pseudofs/pseudofs.c (modified) * freebsd/sys/fs/pseudofs/pseudofs.h (modified) * freebsd/sys/fs/pseudofs/pseudofs_fileno.c (modified) * freebsd/sys/fs/pseudofs/pseudofs_vncache.c (modified) * freebsd/sys/fs/pseudofs/pseudofs_vnops.c (modified) * freebsd/sys/kern/kern_descrip.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_pctrie.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/kern/vfs_acl.c (modified) * freebsd/sys/kern/vfs_aio.c (modified) * freebsd/sys/kern/vfs_bio.c (modified) * freebsd/sys/kern/vfs_cache.c (modified) * freebsd/sys/kern/vfs_cluster.c (modified) * freebsd/sys/kern/vfs_default.c (modified) * freebsd/sys/kern/vfs_export.c (modified) * freebsd/sys/kern/vfs_extattr.c (modified) * freebsd/sys/kern/vfs_hash.c (modified) * freebsd/sys/kern/vfs_init.c (modified) * freebsd/sys/kern/vfs_lookup.c (modified) * freebsd/sys/kern/vfs_mount.c (modified) * freebsd/sys/kern/vfs_subr.c (modified) * freebsd/sys/kern/vfs_syscalls.c (modified) * freebsd/sys/kern/vfs_vnops.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/sys/bio.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysent.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/vm/vm_meter.c (modified) * libbsd.py (modified) * rtemsbsd/fs/rootfs/rootfs.c (added) * rtemsbsd/include/machine/atomic.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/machine/rtems-bsd-libio.h (added) * rtemsbsd/include/machine/rtems-bsd-page.h (modified) * rtemsbsd/include/machine/rtems-bsd-vfs.h (added) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_pseudofs.h (added) * rtemsbsd/include/rtems/bsd/local/opt_swap.h (added) * rtemsbsd/include/rtems/bsd/local/opt_watchdog.h (added) * rtemsbsd/include/rtems/bsd/local/vnode_if.h (added) * rtemsbsd/include/rtems/bsd/local/vnode_if_newproto.h (added) * rtemsbsd/include/rtems/bsd/local/vnode_if_typedef.h (added) * rtemsbsd/include/rtems/bsd/rootfs.h (added) * rtemsbsd/include/sys/bio.h (deleted) * rtemsbsd/include/sys/namei.h (deleted) * rtemsbsd/include/sys/sysent.h (deleted) * rtemsbsd/include/vm/vm_object.h (modified) * rtemsbsd/include/vm/vm_pager.h (modified) * rtemsbsd/rtems/rtems-bsd-allocator-domain-size.c (modified) * rtemsbsd/rtems/rtems-bsd-get-allocator-domain-size.c (modified) * rtemsbsd/rtems/rtems-bsd-libio.c (added) * rtemsbsd/rtems/rtems-bsd-mountroot.c (added) * rtemsbsd/rtems/rtems-bsd-syscall-api.c (modified) * rtemsbsd/rtems/rtems-kernel-capability.c (added) * rtemsbsd/rtems/rtems-kernel-dev.c (added) * rtemsbsd/rtems/rtems-kernel-dirent.c (added) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-pager.c (added) * rtemsbsd/rtems/rtems-kernel-param.c (added) * rtemsbsd/rtems/rtems-kernel-vfs.c (added) * rtemsbsd/rtems/rtems-kernel-vmem.c (added) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) * rtemsbsd/sys/kern/vnode_if.c (added) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/swi01/init.c (modified) * testsuite/syscalls01/test_main.c (modified) * testsuite/thread01/test_main.c (modified) * testsuite/timeout01/init.c (modified) * wscript (modified) sys/kern: Add VFS support - Refactor the libio interface - Move ... Sat, 24 Jul 2021 00:31:12 GMT Chris Johns [ac4db4c] * libbsd.py (modified) * rtemsbsd/rtems/rtems-bsd-init-dhcp.c (deleted) rtemsbsd: Remove DHCP init wrapper - Object files cannot config ... Wed, 21 Jul 2021 07:59:40 GMT Chris Johns [e56b5cb] * README.md (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_ktr.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/vm/uma_core.c (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_alq.h (added) * rtemsbsd/include/rtems/bsd/local/opt_ktr.h (added) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) kern: Add kernel trace support (KTR) Update #4475 Wed, 21 Jul 2021 03:46:45 GMT Chris Johns [c7427fc] * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_prot.c (modified) * freebsd/sys/kern/kern_resource.c (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/ucred.h (modified) * libbsd.py (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) kern: Add a proc0 - Provides the thread's proc pointer and with ... Tue, 27 Jul 2021 07:41:52 GMT Chris Johns [f700edc] * libbsd.py (modified) waf: Fix clashing symbols in the user land symbols Update #4475 Sun, 08 Aug 2021 06:32:38 GMT Chris Johns [45ff774] * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/iface.h (added) * rtemsbsd/rtems/rtems-bsd-iface.c (added) rtemsbsd: Add interface support routines - Add the ability to check ... Wed, 02 Jun 2021 16:41:33 GMT Stephen Clark [8dfea31] * libbsd.py (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/ttcpshell01/test_main.c (added) rtemsbsd: Added a test for the TTCP command. Added a new test for ... Wed, 02 Jun 2021 14:59:51 GMT Stephen Clark [6cc63cb] * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-ttcp.c (added) * rtemsbsd/ttcp/README (modified) * rtemsbsd/ttcp/ttcp.c (modified) rtemsbsd: Made TTCP command build for RTEMS Updated ttcp.c to build ... Wed, 09 Jun 2021 16:46:27 GMT Jan Sommer [1ca0dc7] * libbsd.py (modified) * waf_libbsd.py (modified) waf_libbsd.py: Apply path-mappings to header-paths Wed, 10 Feb 2021 16:09:00 GMT Christian Mauderer [e0fcb31] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/bsp/st-sdmmc-config.h (added) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/mmc/st-sdmmc-config.c (added) * rtemsbsd/sys/dev/mmc/st-sdmmc.c (added) STM32H7: Add SDMMC driver Update #4372 Tue, 16 Mar 2021 13:47:03 GMT Christian Mauderer [2caeaaf] * libbsd.py (modified) * testsuite/media01/pattern-test.c (added) * testsuite/media01/pattern-test.h (added) * testsuite/media01/test_main.c (modified) testsuite/media01: Add pattern test Update #4372 Tue, 09 Feb 2021 13:14:11 GMT Kinsey Moore [e256668] * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.c (added) * rtemsbsd/sys/arm64/xilinx/zynqmp_slcr.h (added) nexus: Add ZynqMP SLCR driver Add a System Level Control Register ... Mon, 22 Feb 2021 07:53:48 GMT Moyano, Gabriel [5b50a51] * libbsd.py (modified) ehci_pci: Add to build system Closes #4264 Mon, 21 Dec 2020 21:26:18 GMT Kinsey Moore [68e79b6] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/sdhci/arasan_sdhci.c (added) zynq: Add support for SDHCI devices Tue, 10 Nov 2020 23:21:32 GMT Kinsey Moore [19d98d3a] * freebsd/sys/arm64/arm64/in_cksum.c (added) * freebsd/sys/arm64/include/machine/armreg.h (added) * freebsd/sys/arm64/include/machine/cpu.h (added) * freebsd/sys/arm64/include/machine/cpufunc.h (added) * freebsd/sys/arm64/include/machine/in_cksum.h (added) * freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_llsc.h (added) * freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_lse.h (added) * libbsd.py (modified) * rtemsbsd/include/machine/frame.h (added) Update arm64/aarch64 support Tue, 31 Mar 2020 08:20:04 GMT Sebastian Huber [0e7108f] * freebsd/sys/dev/usb/controller/dwc_otg.h (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (added) * rtemsbsd/sys/dev/usb/controller/dwc_otg_stm32h7.c (added) dwc_otg: Add support for nexus bus Update #3910. Mon, 23 Mar 2020 13:26:20 GMT Sebastian Huber [1189f71] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/dev/stmac/if_stmac.c (added) if_stmac: Add driver for STM32H7 ethernet module Update #3910. Tue, 20 Oct 2020 01:35:22 GMT Chris Johns [c99a1ab] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/powerpc/include/machine/legacyvar.h (added) * rtemsbsd/powerpc/include/machine/pci_cfgreg.h (added) powerpc/nexus: Add legacy PCI support to PowerPC Motorola Shared BSP ... Wed, 30 Sep 2020 05:31:23 GMT Chris Johns [7027254] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Fix test module dependency check Wed, 23 Sep 2020 06:06:51 GMT Sebastian Huber [a0556e1] * freebsd/sys/moxie/include/machine/in_cksum.h (added) * libbsd.py (modified) Add moxie support Tue, 22 Sep 2020 15:43:50 GMT Sebastian Huber [cb1faf6] * freebsd/sys/or1k/include/machine/in_cksum.h (added) * libbsd.py (modified) Add or1k support Tue, 15 Sep 2020 01:20:44 GMT Chris Johns [089780d] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Implement module dependency checking in the build system - Do ... Wed, 02 Sep 2020 23:54:27 GMT Chris Johns [025af7c] * builder.py (modified) * buildset/default.ini (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) * wscript (modified) build: Separate the kernel and user land include paths - Provide ... Mon, 07 Sep 2020 15:44:17 GMT Sebastian Huber [2abb02eb] * libbsd.py (modified) * testsuite/mcast01/test_main.c (added) mcast01: Add test program Mon, 07 Sep 2020 08:03:31 GMT Sebastian Huber [272d5f5] * Makefile.todo (modified) * freebsd/usr.sbin/ifmcstat/ifmcstat.c (modified) * freebsd/usr.sbin/ifmcstat/printb.c (modified) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-data.h (added) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-ifmcstat-data.h (added) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-namespace.h (added) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-printb-data.h (added) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-ifmcstat.c (added) * testsuite/media01/test_main.c (modified) ifmcstat: Port to RTEMS Wed, 20 May 2020 08:50:06 GMT Christian Mauderer [1398d93] * freebsd/sys/arm/freescale/imx/imx_gpio.c (deleted) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/arm/freescale/imx/imx_rtems_gpio.c (added) imx: Use RTEMS GPIO driver instead of FreeBSD one Update 3869 Tue, 12 May 2020 06:45:29 GMT Christian Mauderer [4c762de] * freebsd/sys/dev/gpio/gpioregulator.c (deleted) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) gpioregulator: Remove. There is a bug in the #ifdef regarding FDT ... Fri, 17 Apr 2020 08:24:04 GMT Jan Sommer [079bdd3] * libbsd.py (modified) i386: Add missing files to build system - Update FreeBSD files in ... Fri, 17 Apr 2020 08:24:03 GMT Jan Sommer [dbf72c2] * libbsd.py (modified) * waf_libbsd.py (modified) waf: Add path-mappings feature - path-mappings allow to fix ... Thu, 02 Apr 2020 15:47:43 GMT Christian Mauderer [c5455b0] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) ehci_imx: Add to build. Thu, 13 Feb 2020 09:56:26 GMT Christian Mauderer [24806ee] * Makefile.todo (modified) * buildset/default.ini (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/rtems/bsd/local/regdev_if.h (added) * rtemsbsd/include/rtems/bsd/local/regnode_if.h (added) * rtemsbsd/local/regdev_if.c (added) * rtemsbsd/local/regnode_if.c (added) regulator: Add to build. Update #3869. Thu, 02 Apr 2020 15:43:10 GMT Christian Mauderer [3a1d48c] * buildset/default.ini (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) imx6_ccm: Add and build module. Update #3869. Thu, 05 Mar 2020 10:18:05 GMT Chris Johns [3cc039c] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Change the test configure check for libdebugger to it's lib - ... Mon, 10 Feb 2020 14:34:55 GMT Sebastian Huber [46b3858] * freebsd-org (modified) * freebsd/contrib/expat/lib/ascii.h (modified) * freebsd/contrib/expat/lib/asciitab.h (modified) * freebsd/contrib/expat/lib/expat.h (modified) * freebsd/contrib/expat/lib/expat_external.h (modified) * freebsd/contrib/expat/lib/iasciitab.h (modified) * freebsd/contrib/expat/lib/internal.h (modified) * freebsd/contrib/expat/lib/latin1tab.h (modified) * freebsd/contrib/expat/lib/nametab.h (modified) * freebsd/contrib/expat/lib/utf8tab.h (modified) * freebsd/contrib/expat/lib/xmlparse.c (modified) * freebsd/contrib/expat/lib/xmlrole.c (modified) * freebsd/contrib/expat/lib/xmlrole.h (modified) * freebsd/contrib/expat/lib/xmltok.c (modified) * freebsd/contrib/expat/lib/xmltok.h (modified) * freebsd/contrib/expat/lib/xmltok_impl.c (modified) * freebsd/contrib/expat/lib/xmltok_impl.h (modified) * freebsd/contrib/expat/lib/xmltok_ns.c (modified) * freebsd/contrib/libpcap/diag-control.h (modified) * freebsd/contrib/libpcap/fmtutils.c (modified) * freebsd/contrib/libpcap/fmtutils.h (modified) * freebsd/contrib/libpcap/ftmacros.h (modified) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/gencode.h (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/contrib/libpcap/grammar.h (modified) * freebsd/contrib/libpcap/grammar.y (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/optimize.c (modified) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-common.c (modified) * freebsd/contrib/libpcap/pcap-common.h (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libpcap/pcap.c (modified) * freebsd/contrib/libpcap/pcap/compiler-tests.h (modified) * freebsd/contrib/libpcap/pcap/funcattrs.h (modified) * freebsd/contrib/libpcap/pcap/nflog.h (modified) * freebsd/contrib/libpcap/pcap/pcap-inttypes.h (modified) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/libpcap/pcap/sll.h (modified) * freebsd/contrib/libpcap/pcap/socket.h (added) * freebsd/contrib/libpcap/portability.h (modified) * freebsd/contrib/libpcap/savefile.c (modified) * freebsd/contrib/libpcap/scanner.c (modified) * freebsd/contrib/libpcap/scanner.h (modified) * freebsd/contrib/libpcap/scanner.l (modified) * freebsd/contrib/libpcap/sf-pcap.c (modified) * freebsd/contrib/libpcap/sf-pcap.h (modified) * freebsd/contrib/libpcap/sf-pcapng.c (modified) * freebsd/contrib/libpcap/sf-pcapng.h (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/netdissect.h (modified) * freebsd/contrib/tcpdump/print-802_11.c (modified) * freebsd/contrib/tcpdump/print-aoe.c (modified) * freebsd/contrib/tcpdump/print-babel.c (modified) * freebsd/contrib/tcpdump/print-bfd.c (modified) * freebsd/contrib/tcpdump/print-bgp.c (modified) * freebsd/contrib/tcpdump/print-bootp.c (modified) * freebsd/contrib/tcpdump/print-dccp.c (modified) * freebsd/contrib/tcpdump/print-decnet.c (modified) * freebsd/contrib/tcpdump/print-domain.c (modified) * freebsd/contrib/tcpdump/print-dvmrp.c (modified) * freebsd/contrib/tcpdump/print-eigrp.c (modified) * freebsd/contrib/tcpdump/print-esp.c (modified) * freebsd/contrib/tcpdump/print-fr.c (modified) * freebsd/contrib/tcpdump/print-hncp.c (modified) * freebsd/contrib/tcpdump/print-icmp.c (modified) * freebsd/contrib/tcpdump/print-icmp6.c (modified) * freebsd/contrib/tcpdump/print-ipnet.c (modified) * freebsd/contrib/tcpdump/print-isakmp.c (modified) * freebsd/contrib/tcpdump/print-juniper.c (modified) * freebsd/contrib/tcpdump/print-l2tp.c (modified) * freebsd/contrib/tcpdump/print-ldp.c (modified) * freebsd/contrib/tcpdump/print-lmp.c (modified) * freebsd/contrib/tcpdump/print-nfs.c (modified) * freebsd/contrib/tcpdump/print-openflow.c (modified) * freebsd/contrib/tcpdump/print-ospf.c (modified) * freebsd/contrib/tcpdump/print-ospf6.c (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/contrib/tcpdump/print-ppi.c (modified) * freebsd/contrib/tcpdump/print-rsvp.c (modified) * freebsd/contrib/tcpdump/print-rx.c (modified) * freebsd/contrib/tcpdump/print-sflow.c (modified) * freebsd/contrib/tcpdump/print-sl.c (modified) * freebsd/contrib/tcpdump/print-sll.c (modified) * freebsd/contrib/tcpdump/print-smb.c (modified) * freebsd/contrib/tcpdump/print-tcp.c (modified) * freebsd/contrib/tcpdump/print-udp.c (modified) * freebsd/contrib/tcpdump/print-vrrp.c (modified) * freebsd/contrib/tcpdump/print-vtp.c (modified) * freebsd/contrib/tcpdump/print-wb.c (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-namespace.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dvmrp-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pim-data.h (modified) * freebsd/contrib/tcpdump/signature.c (modified) * freebsd/contrib/tcpdump/smbutil.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/tcpdump/util-print.c (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/sfp.c (modified) * freebsd/sbin/nvmecontrol/comnd.c (modified) * freebsd/sbin/nvmecontrol/identify.c (modified) * freebsd/sbin/nvmecontrol/identify_ext.c (modified) * freebsd/sbin/nvmecontrol/logpage.c (modified) * freebsd/sbin/nvmecontrol/modules/wdc/wdc.c (modified) * freebsd/sbin/nvmecontrol/nc_util.c (modified) * freebsd/sbin/nvmecontrol/ns.c (modified) * freebsd/sbin/nvmecontrol/nvmecontrol_ext.h (modified) * freebsd/sbin/nvmecontrol/power.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sys/arm/freescale/imx/imx_gpio.c (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/gpio/gpiobus.c (modified) * freebsd/sys/dev/gpio/gpiobusvar.h (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/kbd/kbdreg.h (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/nvme/nvme.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/nvme/nvme_ctrlr.c (modified) * freebsd/sys/dev/nvme/nvme_ctrlr_cmd.c (modified) * freebsd/sys/dev/nvme/nvme_pci.c (modified) * freebsd/sys/dev/nvme/nvme_private.h (modified) * freebsd/sys/dev/nvme/nvme_qpair.c (modified) * freebsd/sys/dev/nvme/nvme_sysctl.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/dlt.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_tap.c (deleted) * freebsd/sys/net/if_tap.h (modified) * freebsd/sys/net/if_tapvar.h (deleted) * freebsd/sys/net/if_tun.c (deleted) * freebsd/sys/net/if_tuntap.c (added) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/sff8472.h (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (deleted) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/pcpu_aux.h (added) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD stable/12 2020-02-10 Git mirror commit ... Thu, 19 Dec 2019 09:50:12 GMT Sebastian Huber [a8f29d6] * freebsd/lib/libc/net/sockatmark.c (added) * libbsd.py (modified) * testsuite/syscalls01/test_main.c (modified) SOCKATMARK(3): Import from FreeBSD Close #3798. Fri, 20 Sep 2019 05:57:01 GMT Sebastian Huber [afaeccc] * freebsd/sbin/nvmecontrol/comnd.c (modified) * freebsd/sbin/nvmecontrol/comnd.h (modified) * freebsd/sbin/nvmecontrol/devlist.c (modified) * freebsd/sbin/nvmecontrol/firmware.c (modified) * freebsd/sbin/nvmecontrol/format.c (modified) * freebsd/sbin/nvmecontrol/identify.c (modified) * freebsd/sbin/nvmecontrol/identify_ext.c (modified) * freebsd/sbin/nvmecontrol/logpage.c (modified) * freebsd/sbin/nvmecontrol/modules/intel/intel.c (modified) * freebsd/sbin/nvmecontrol/modules/wdc/wdc.c (modified) * freebsd/sbin/nvmecontrol/nc_util.c (modified) * freebsd/sbin/nvmecontrol/ns.c (modified) * freebsd/sbin/nvmecontrol/nsid.c (modified) * freebsd/sbin/nvmecontrol/nvmecontrol.c (modified) * freebsd/sbin/nvmecontrol/nvmecontrol.h (modified) * freebsd/sbin/nvmecontrol/passthru.c (modified) * freebsd/sbin/nvmecontrol/perftest.c (modified) * freebsd/sbin/nvmecontrol/power.c (modified) * freebsd/sbin/nvmecontrol/reset.c (modified) * freebsd/sbin/nvmecontrol/resv.c (modified) * freebsd/sbin/nvmecontrol/sanitize.c (modified) * freebsd/sbin/nvmecontrol/wdc.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-nvmecontrol.c (added) NVMECONTROL(8): Port to RTEMS Update #3821. Tue, 24 Sep 2019 07:40:00 GMT Sebastian Huber [380ef17] * libbsd.py (modified) NVMECONTROL(8): Add to build Update #3821. Wed, 11 Sep 2019 09:10:21 GMT Sebastian Huber [e7291f7] * libbsd.py (modified) * rtemsbsd/sys/dev/nvd/nvd.c (added) NVD(4): Add RTEMS-specific NVMe disk driver Update #3821. Fri, 20 Sep 2019 11:53:06 GMT Sebastian Huber [eb4dcdf] * libbsd.py (modified) NVME(4): Install header files Update #3821. Tue, 09 Jul 2019 07:00:11 GMT Sebastian Huber [fed6e9b] * libbsd.py (modified) NVME(4): Add build module Update #3821. Tue, 24 Sep 2019 12:20:08 GMT Sebastian Huber [f105680] * freebsd/sys/sys/syslog.h (deleted) * libbsd.py (modified) * rtemsbsd/include/syslog.h (deleted) Remove obsolete header files Tue, 24 Sep 2019 12:02:40 GMT Sebastian Huber [4a6660c] * freebsd/sys/sys/signalvar.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/rtems/rtems-kernel-signal.c (deleted) Fix pgsigio() warnings Mon, 23 Sep 2019 10:49:10 GMT Sebastian Huber [37323bb] * freebsd-org (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/wpa/src/ap/ap_config.h (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.c (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.h (modified) * freebsd/contrib/wpa/src/ap/hostapd.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11.h (modified) * freebsd/contrib/wpa/src/ap/sta_info.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (modified) * freebsd/contrib/wpa/src/common/dpp.h (modified) * freebsd/contrib/wpa/src/common/hw_features_common.c (modified) * freebsd/contrib/wpa/src/common/hw_features_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.c (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_defs.h (modified) * freebsd/contrib/wpa/src/common/qca-vendor.h (modified) * freebsd/contrib/wpa/src/common/sae.h (modified) * freebsd/contrib/wpa/src/common/version.h (modified) * freebsd/contrib/wpa/src/common/wpa_common.c (modified) * freebsd/contrib/wpa/src/common/wpa_ctrl.h (modified) * freebsd/contrib/wpa/src/crypto/crypto.h (modified) * freebsd/contrib/wpa/src/crypto/crypto_openssl.c (modified) * freebsd/contrib/wpa/src/crypto/sha1-prf.c (modified) * freebsd/contrib/wpa/src/crypto/sha1.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-prf.c (modified) * freebsd/contrib/wpa/src/crypto/sha256.h (modified) * freebsd/contrib/wpa/src/crypto/tls.h (modified) * freebsd/contrib/wpa/src/drivers/driver.h (modified) * freebsd/contrib/wpa/src/drivers/driver_bsd.c (modified) * freebsd/contrib/wpa/src/drivers/driver_common.c (modified) * freebsd/contrib/wpa/src/drivers/driver_ndis.c (modified) * freebsd/contrib/wpa/src/drivers/driver_nl80211.h (modified) * freebsd/contrib/wpa/src/eap_common/eap_defs.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_config.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_leap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_methods.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_peap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h (modified) * freebsd/contrib/wpa/src/eap_server/eap_methods.h (modified) * freebsd/contrib/wpa/src/eapol_auth/eapol_auth_sm.h (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (modified) * freebsd/contrib/wpa/src/utils/common.c (modified) * freebsd/contrib/wpa/src/utils/common.h (modified) * freebsd/contrib/wpa/src/utils/wpa_debug.c (modified) * freebsd/contrib/wpa/src/wps/wps.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ap.h (modified) * freebsd/contrib/wpa/wpa_supplicant/bss.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config_file.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config_ssid.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (modified) * freebsd/contrib/wpa/wpa_supplicant/dpp_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/driver_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/eap_register.c (modified) * freebsd/contrib/wpa/wpa_supplicant/events.c (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.h (modified) * freebsd/contrib/wpa/wpa_supplicant/op_classes.c (modified) * freebsd/contrib/wpa/wpa_supplicant/rrm.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c (modified) * freebsd/crypto/openssl/apps/apps.c (modified) * freebsd/crypto/openssl/apps/apps.h (modified) * freebsd/crypto/openssl/apps/ca.c (modified) * freebsd/crypto/openssl/apps/dgst.c (modified) * freebsd/crypto/openssl/apps/enc.c (modified) * freebsd/crypto/openssl/apps/ocsp.c (modified) * freebsd/crypto/openssl/apps/openssl.c (modified) * freebsd/crypto/openssl/apps/pkcs12.c (modified) * freebsd/crypto/openssl/apps/req.c (modified) * freebsd/crypto/openssl/apps/s_apps.h (modified) * freebsd/crypto/openssl/apps/s_cb.c (modified) * freebsd/crypto/openssl/apps/s_client.c (modified) * freebsd/crypto/openssl/apps/speed.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_type.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_bignum.c (modified) * freebsd/crypto/openssl/crypto/bio/b_addr.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_dgram.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_div.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lcl.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_rand.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_sqrt.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_att.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_env.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_err.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_lcl.h (modified) * freebsd/crypto/openssl/crypto/cms/cms_sd.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_smime.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_sap.c (modified) * freebsd/crypto/openssl/crypto/ctype.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_check.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_gen.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_lib.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_err.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_asn1.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_curve.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lcl.h (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdh_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistputil.c (modified) * freebsd/crypto/openssl/crypto/ec/ecx_meth.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_devcrypto.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_openssl.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_ok.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aria.c (modified) * freebsd/crypto/openssl/crypto/evp/e_chacha20_poly1305.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_err.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_lib.c (modified) * freebsd/crypto/openssl/crypto/evp/m_sha3.c (modified) * freebsd/crypto/openssl/crypto/include/internal/ctype.h (modified) * freebsd/crypto/openssl/crypto/include/internal/rand_int.h (modified) * freebsd/crypto/openssl/crypto/include/internal/sm2err.h (modified) * freebsd/crypto/openssl/crypto/init.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/o_str.c (modified) * freebsd/crypto/openssl/crypto/pem/pvkfmt.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c (modified) * freebsd/crypto/openssl/crypto/rand/drbg_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_err.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_lcl.h (modified) * freebsd/crypto/openssl/crypto/rand/rand_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_err.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_lib.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/sm2/sm2_sign.c (modified) * freebsd/crypto/openssl/crypto/store/loader_file.c (modified) * freebsd/crypto/openssl/crypto/store/store_lib.c (modified) * freebsd/crypto/openssl/crypto/threads_none.c (modified) * freebsd/crypto/openssl/crypto/threads_pthread.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/uid.c (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_block.c (modified) * freebsd/crypto/openssl/crypto/x509/by_dir.c (modified) * freebsd/crypto/openssl/crypto/x509/t_req.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_att.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_cmp.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_err.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/e_os.h (modified) * freebsd/crypto/openssl/include/internal/constant_time_locl.h (modified) * freebsd/crypto/openssl/include/internal/cryptlib.h (modified) * freebsd/crypto/openssl/include/internal/dsoerr.h (modified) * freebsd/crypto/openssl/include/internal/refcount.h (modified) * freebsd/crypto/openssl/include/internal/thread_once.h (modified) * freebsd/crypto/openssl/include/internal/tsan_assist.h (modified) * freebsd/crypto/openssl/include/openssl/asn1err.h (modified) * freebsd/crypto/openssl/include/openssl/asyncerr.h (modified) * freebsd/crypto/openssl/include/openssl/bio.h (modified) * freebsd/crypto/openssl/include/openssl/bioerr.h (modified) * freebsd/crypto/openssl/include/openssl/bnerr.h (modified) * freebsd/crypto/openssl/include/openssl/buffererr.h (modified) * freebsd/crypto/openssl/include/openssl/cms.h (modified) * freebsd/crypto/openssl/include/openssl/cmserr.h (modified) * freebsd/crypto/openssl/include/openssl/comperr.h (modified) * freebsd/crypto/openssl/include/openssl/conferr.h (modified) * freebsd/crypto/openssl/include/openssl/cryptoerr.h (modified) * freebsd/crypto/openssl/include/openssl/cterr.h (modified) * freebsd/crypto/openssl/include/openssl/dherr.h (modified) * freebsd/crypto/openssl/include/openssl/dsaerr.h (modified) * freebsd/crypto/openssl/include/openssl/ec.h (modified) * freebsd/crypto/openssl/include/openssl/ecerr.h (modified) * freebsd/crypto/openssl/include/openssl/engineerr.h (modified) * freebsd/crypto/openssl/include/openssl/evp.h (modified) * freebsd/crypto/openssl/include/openssl/evperr.h (modified) * freebsd/crypto/openssl/include/openssl/kdferr.h (modified) * freebsd/crypto/openssl/include/openssl/objectserr.h (modified) * freebsd/crypto/openssl/include/openssl/ocsperr.h (modified) * freebsd/crypto/openssl/include/openssl/opensslv.h (modified) * freebsd/crypto/openssl/include/openssl/pemerr.h (modified) * freebsd/crypto/openssl/include/openssl/pkcs12err.h (modified) * freebsd/crypto/openssl/include/openssl/pkcs7err.h (modified) * freebsd/crypto/openssl/include/openssl/randerr.h (modified) * freebsd/crypto/openssl/include/openssl/rsaerr.h (modified) * freebsd/crypto/openssl/include/openssl/ssl.h (modified) * freebsd/crypto/openssl/include/openssl/sslerr.h (modified) * freebsd/crypto/openssl/include/openssl/store.h (modified) * freebsd/crypto/openssl/include/openssl/storeerr.h (modified) * freebsd/crypto/openssl/include/openssl/tls1.h (modified) * freebsd/crypto/openssl/include/openssl/tserr.h (modified) * freebsd/crypto/openssl/include/openssl/uierr.h (modified) * freebsd/crypto/openssl/include/openssl/x509err.h (modified) * freebsd/crypto/openssl/include/openssl/x509v3.h (modified) * freebsd/crypto/openssl/include/openssl/x509v3err.h (modified) * freebsd/crypto/openssl/ssl/d1_msg.c (modified) * freebsd/crypto/openssl/ssl/record/rec_layer_s3.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_srvr.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_lib.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_srvr.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/tls13_enc.c (modified) * freebsd/include/rpcsvc/yp_prot.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libcapsicum/capsicum_helpers.h (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping/rtems-bsd-ping-data.h (modified) * freebsd/sbin/ping/rtems-bsd-ping-namespace.h (modified) * freebsd/sbin/ping/rtems-bsd-ping-utils-data.h (added) * freebsd/sbin/ping/utils.c (added) * freebsd/sbin/ping/utils.h (added) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-data.h (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-namespace.h (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-ping6-data.h (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_hpts.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_log_buf.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/vnode.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD stable/12 2019-09-23 Git mirror commit ... Fri, 20 Sep 2019 05:51:19 GMT Sebastian Huber [54ded22] * freebsd/sys/dev/pci/pcib_support.c (added) * libbsd.py (modified) PCI(4): Import missing file Thu, 18 Jul 2019 08:24:06 GMT Sebastian Huber [76aee94] * libbsd.py (modified) PCI(4): Install header files Fri, 20 Sep 2019 06:37:54 GMT Sebastian Huber [017b09f] * libbsd.py (modified) Add to build module Tue, 27 Aug 2019 07:55:43 GMT Sebastian Huber [e897a83] * freebsd/sys/kern/subr_module.c (deleted) * freebsd/sys/opencrypto/crypto.c (modified) * libbsd.py (modified) Remove superfluous support for preloaded modules Fri, 28 Jun 2019 06:49:50 GMT Sebastian Huber [bbd07d1] * freebsd/sys/dev/usb/usb_fdt_support.h (added) * libbsd.py (modified) Import missing header file Wed, 05 Jun 2019 09:35:39 GMT Sebastian Huber [705e362] * freebsd-org (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/wpa/src/ap/ap_config.h (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.c (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.h (modified) * freebsd/contrib/wpa/src/ap/hostapd.h (modified) * freebsd/contrib/wpa/src/ap/hs20.c (modified) * freebsd/contrib/wpa/src/ap/hs20.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11_auth.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11_shared.c (modified) * freebsd/contrib/wpa/src/ap/pmksa_cache_auth.h (modified) * freebsd/contrib/wpa/src/ap/sta_info.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_i.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ie.h (modified) * freebsd/contrib/wpa/src/common/ctrl_iface_common.c (modified) * freebsd/contrib/wpa/src/common/ctrl_iface_common.h (modified) * freebsd/contrib/wpa/src/common/defs.h (modified) * freebsd/contrib/wpa/src/common/dpp.h (added) * freebsd/contrib/wpa/src/common/gas.c (modified) * freebsd/contrib/wpa/src/common/gas.h (modified) * freebsd/contrib/wpa/src/common/gas_server.h (added) * freebsd/contrib/wpa/src/common/hw_features_common.c (modified) * freebsd/contrib/wpa/src/common/hw_features_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.c (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_defs.h (modified) * freebsd/contrib/wpa/src/common/ieee802_1x_defs.h (added) * freebsd/contrib/wpa/src/common/ocv.h (added) * freebsd/contrib/wpa/src/common/qca-vendor.h (modified) * freebsd/contrib/wpa/src/common/sae.h (modified) * freebsd/contrib/wpa/src/common/version.h (modified) * freebsd/contrib/wpa/src/common/wpa_common.c (modified) * freebsd/contrib/wpa/src/common/wpa_common.h (modified) * freebsd/contrib/wpa/src/common/wpa_ctrl.h (modified) * freebsd/contrib/wpa/src/crypto/aes-ctr.c (modified) * freebsd/contrib/wpa/src/crypto/aes.h (modified) * freebsd/contrib/wpa/src/crypto/aes_siv.h (added) * freebsd/contrib/wpa/src/crypto/aes_wrap.h (modified) * freebsd/contrib/wpa/src/crypto/crypto.h (modified) * freebsd/contrib/wpa/src/crypto/crypto_openssl.c (modified) * freebsd/contrib/wpa/src/crypto/ms_funcs.c (modified) * freebsd/contrib/wpa/src/crypto/ms_funcs.h (modified) * freebsd/contrib/wpa/src/crypto/random.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-internal.c (modified) * freebsd/contrib/wpa/src/crypto/sha384.h (modified) * freebsd/contrib/wpa/src/crypto/sha512.h (added) * freebsd/contrib/wpa/src/crypto/tls.h (modified) * freebsd/contrib/wpa/src/crypto/tls_internal.c (modified) * freebsd/contrib/wpa/src/drivers/driver.h (modified) * freebsd/contrib/wpa/src/drivers/driver_bsd.c (modified) * freebsd/contrib/wpa/src/drivers/driver_common.c (modified) * freebsd/contrib/wpa/src/drivers/driver_ndis.c (modified) * freebsd/contrib/wpa/src/drivers/driver_nl80211.h (modified) * freebsd/contrib/wpa/src/drivers/driver_wired.c (modified) * freebsd/contrib/wpa/src/drivers/driver_wired_common.c (added) * freebsd/contrib/wpa/src/drivers/driver_wired_common.h (added) * freebsd/contrib/wpa/src/drivers/drivers.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_config.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_i.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_leap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_peap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_proxy.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_psk.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_ttls.c (modified) * freebsd/contrib/wpa/src/eapol_auth/eapol_auth_sm.h (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h (modified) * freebsd/contrib/wpa/src/fst/fst.h (modified) * freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h (modified) * freebsd/contrib/wpa/src/l2_packet/l2_packet.h (modified) * freebsd/contrib/wpa/src/p2p/p2p.h (modified) * freebsd/contrib/wpa/src/radius/radius.h (modified) * freebsd/contrib/wpa/src/rsn_supp/peerkey.c (deleted) * freebsd/contrib/wpa/src/rsn_supp/peerkey.h (deleted) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c (modified) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h (modified) * freebsd/contrib/wpa/src/rsn_supp/preauth.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h (modified) * freebsd/contrib/wpa/src/tls/tlsv1_client.h (modified) * freebsd/contrib/wpa/src/tls/tlsv1_server.h (modified) * freebsd/contrib/wpa/src/utils/base64.c (modified) * freebsd/contrib/wpa/src/utils/base64.h (modified) * freebsd/contrib/wpa/src/utils/bitfield.c (added) * freebsd/contrib/wpa/src/utils/common.c (modified) * freebsd/contrib/wpa/src/utils/common.h (modified) * freebsd/contrib/wpa/src/utils/const_time.h (added) * freebsd/contrib/wpa/src/utils/eloop.c (modified) * freebsd/contrib/wpa/src/utils/eloop.h (modified) * freebsd/contrib/wpa/src/utils/list.h (modified) * freebsd/contrib/wpa/src/utils/os.h (modified) * freebsd/contrib/wpa/src/utils/os_unix.c (modified) * freebsd/contrib/wpa/src/utils/uuid.c (modified) * freebsd/contrib/wpa/src/utils/uuid.h (modified) * freebsd/contrib/wpa/src/utils/wpa_debug.c (modified) * freebsd/contrib/wpa/src/utils/wpa_debug.h (modified) * freebsd/contrib/wpa/src/utils/wpabuf.c (modified) * freebsd/contrib/wpa/src/wps/wps.c (modified) * freebsd/contrib/wpa/src/wps/wps.h (modified) * freebsd/contrib/wpa/src/wps/wps_attr_build.c (modified) * freebsd/contrib/wpa/src/wps/wps_attr_parse.c (modified) * freebsd/contrib/wpa/src/wps/wps_attr_parse.h (modified) * freebsd/contrib/wpa/src/wps/wps_common.c (modified) * freebsd/contrib/wpa/src/wps/wps_defs.h (modified) * freebsd/contrib/wpa/src/wps/wps_dev_attr.c (modified) * freebsd/contrib/wpa/src/wps/wps_dev_attr.h (modified) * freebsd/contrib/wpa/src/wps/wps_enrollee.c (modified) * freebsd/contrib/wpa/src/wps/wps_i.h (modified) * freebsd/contrib/wpa/src/wps/wps_registrar.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp.c (modified) * freebsd/contrib/wpa/wpa_supplicant/ap.h (modified) * freebsd/contrib/wpa/wpa_supplicant/bss.c (modified) * freebsd/contrib/wpa/wpa_supplicant/bss.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config_file.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config_ssid.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface_unix.c (modified) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_new.h (modified) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_old.h (deleted) * freebsd/contrib/wpa/wpa_supplicant/dpp_supplicant.h (added) * freebsd/contrib/wpa/wpa_supplicant/driver_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/events.c (modified) * freebsd/contrib/wpa/wpa_supplicant/gas_query.c (modified) * freebsd/contrib/wpa/wpa_supplicant/gas_query.h (modified) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.c (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.h (modified) * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.h (modified) * freebsd/contrib/wpa/wpa_supplicant/offchannel.c (modified) * freebsd/contrib/wpa/wpa_supplicant/op_classes.c (added) * freebsd/contrib/wpa/wpa_supplicant/p2p_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/rrm.c (added) * freebsd/contrib/wpa/wpa_supplicant/scan.c (modified) * freebsd/contrib/wpa/wpa_supplicant/sme.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wmm_ac.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpas_kay.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.h (modified) * freebsd/crypto/openssl/apps/asn1pars.c (modified) * freebsd/crypto/openssl/apps/cms.c (modified) * freebsd/crypto/openssl/apps/enc.c (modified) * freebsd/crypto/openssl/apps/ocsp.c (modified) * freebsd/crypto/openssl/apps/s_cb.c (modified) * freebsd/crypto/openssl/apps/s_client.c (modified) * freebsd/crypto/openssl/apps/speed.c (modified) * freebsd/crypto/openssl/crypto/bio/b_addr.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (modified) * freebsd/crypto/openssl/crypto/blake2/blake2b.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_ctx.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_sap.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_check.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_gen.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ec/curve25519.c (modified) * freebsd/crypto/openssl/crypto/ec/curve448/curve448.c (modified) * freebsd/crypto/openssl/crypto/ec/curve448/curve448_tables.c (modified) * freebsd/crypto/openssl/crypto/ec/curve448/curve448utils.h (modified) * freebsd/crypto/openssl/crypto/ec/curve448/f_generic.c (modified) * freebsd/crypto/openssl/crypto/ec/curve448/scalar.c (modified) * freebsd/crypto/openssl/crypto/ec/ec2_oct.c (modified) * freebsd/crypto/openssl/crypto/ec/ec2_smpl.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdh_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_smpl.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/evp/digest.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aria.c (modified) * freebsd/crypto/openssl/crypto/evp/e_chacha20_poly1305.c (modified) * freebsd/crypto/openssl/crypto/evp/p_lib.c (modified) * freebsd/crypto/openssl/crypto/evp/p_open.c (modified) * freebsd/crypto/openssl/crypto/hmac/hmac.c (modified) * freebsd/crypto/openssl/crypto/include/internal/dso_conf.h (modified) * freebsd/crypto/openssl/crypto/init.c (modified) * freebsd/crypto/openssl/crypto/mips_arch.h (modified) * freebsd/crypto/openssl/crypto/modes/ccm128.c (modified) * freebsd/crypto/openssl/crypto/o_str.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_dat.h (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_ext.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_lib.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_sign.c (modified) * freebsd/crypto/openssl/crypto/rand/drbg_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rand/randfile.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ssl.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_x931g.c (modified) * freebsd/crypto/openssl/crypto/sha/keccak1600.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_genn.c (modified) * freebsd/crypto/openssl/e_os.h (modified) * freebsd/crypto/openssl/engines/e_padlock.c (modified) * freebsd/crypto/openssl/include/internal/dsoerr.h (modified) * freebsd/crypto/openssl/include/internal/refcount.h (modified) * freebsd/crypto/openssl/include/internal/tsan_assist.h (modified) * freebsd/crypto/openssl/include/openssl/err.h (modified) * freebsd/crypto/openssl/include/openssl/evp.h (modified) * freebsd/crypto/openssl/include/openssl/obj_mac.h (modified) * freebsd/crypto/openssl/include/openssl/ocsp.h (modified) * freebsd/crypto/openssl/include/openssl/opensslv.h (modified) * freebsd/crypto/openssl/include/openssl/ssl.h (modified) * freebsd/crypto/openssl/include/openssl/x509v3.h (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/statem/extensions.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_srvr.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_srvr.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/pfctl/pfctl_optimize.c (modified) * freebsd/sys/arm/ti/cpsw/if_cpsw.c (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwnvar.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_urereg.h (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_rsureg.h (modified) * freebsd/sys/dev/usb/wlan/if_rumvar.h (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_runvar.h (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_uathvar.h (modified) * freebsd/sys/dev/usb/wlan/if_upgtvar.h (modified) * freebsd/sys/dev/usb/wlan/if_uralvar.h (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_urtwvar.h (modified) * freebsd/sys/dev/usb/wlan/if_zydreg.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/ieee_oui.h (added) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/cbc_mac.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/slicer.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/x86/include/machine/bus.h (modified) * freebsd/sys/x86/include/machine/pci_cfgreg.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/bus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/local/bus_if.c (modified) Update to FreeBSD stable/12 2019-06-05 Git mirror commit ... Thu, 23 May 2019 05:59:52 GMT Sebastian Huber [5cb01f2] * freebsd/sys/riscv/include/machine/in_cksum.h (added) * libbsd.py (modified) Add riscv support Thu, 28 Mar 2019 06:57:49 GMT Sebastian Huber [481397f] * freebsd-org (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_init.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/opencrypto/cbc_mac.c (added) * freebsd/sys/opencrypto/cbc_mac.h (added) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/xform_aes_icm.c (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_cbc_mac.c (added) * freebsd/sys/opencrypto/xform_enc.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/user.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD stable/12 2019-03-27 Git mirror commit ... Thu, 28 Mar 2019 06:36:44 GMT Sebastian Huber [2334ebf] * libbsd.py (modified) build: Add RTEMS test library Update #3199. Tue, 26 Mar 2019 10:08:47 GMT Christian Mauderer [9ed6c971] * buildset/default.ini (modified) * buildset/minimal.ini (modified) * freebsd/crypto/openssl/apps/app_rand.c (modified) * freebsd/crypto/openssl/apps/apps.c (modified) * freebsd/crypto/openssl/apps/asn1pars.c (modified) * freebsd/crypto/openssl/apps/bf_prefix.c (modified) * freebsd/crypto/openssl/apps/ca.c (modified) * freebsd/crypto/openssl/apps/ciphers.c (modified) * freebsd/crypto/openssl/apps/cms.c (modified) * freebsd/crypto/openssl/apps/crl.c (modified) * freebsd/crypto/openssl/apps/crl2p7.c (modified) * freebsd/crypto/openssl/apps/dgst.c (modified) * freebsd/crypto/openssl/apps/dhparam.c (modified) * freebsd/crypto/openssl/apps/dsa.c (modified) * freebsd/crypto/openssl/apps/dsaparam.c (modified) * freebsd/crypto/openssl/apps/ec.c (modified) * freebsd/crypto/openssl/apps/ecparam.c (modified) * freebsd/crypto/openssl/apps/enc.c (modified) * freebsd/crypto/openssl/apps/engine.c (modified) * freebsd/crypto/openssl/apps/errstr.c (modified) * freebsd/crypto/openssl/apps/gendsa.c (modified) * freebsd/crypto/openssl/apps/genpkey.c (modified) * freebsd/crypto/openssl/apps/genrsa.c (modified) * freebsd/crypto/openssl/apps/nseq.c (modified) * freebsd/crypto/openssl/apps/ocsp.c (modified) * freebsd/crypto/openssl/apps/openssl.c (modified) * freebsd/crypto/openssl/apps/opt.c (modified) * freebsd/crypto/openssl/apps/passwd.c (modified) * freebsd/crypto/openssl/apps/pkcs12.c (modified) * freebsd/crypto/openssl/apps/pkcs7.c (modified) * freebsd/crypto/openssl/apps/pkcs8.c (modified) * freebsd/crypto/openssl/apps/pkey.c (modified) * freebsd/crypto/openssl/apps/pkeyparam.c (modified) * freebsd/crypto/openssl/apps/pkeyutl.c (modified) * freebsd/crypto/openssl/apps/prime.c (modified) * freebsd/crypto/openssl/apps/progs.h (modified) * freebsd/crypto/openssl/apps/rand.c (modified) * freebsd/crypto/openssl/apps/rehash.c (modified) * freebsd/crypto/openssl/apps/req.c (modified) * freebsd/crypto/openssl/apps/rsa.c (modified) * freebsd/crypto/openssl/apps/rsautl.c (modified) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-app_rand-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-apps-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-asn1pars-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-bf_prefix-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-ca-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-ciphers-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-cms-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-crl-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-crl2p7-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-dgst-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-dhparam-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-dsa-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-dsaparam-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-ec-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-ecparam-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-enc-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-engine-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-errstr-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-gendsa-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-genpkey-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-genrsa-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-namespace.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-nseq-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-ocsp-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-openssl-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-opt-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-passwd-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-pkcs12-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-pkcs7-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-pkcs8-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-pkey-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-pkeyparam-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-pkeyutl-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-prime-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-rand-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-rehash-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-req-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-rsa-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-rsautl-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-s_cb-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-s_client-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-s_server-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-s_socket-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-s_time-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-sess_id-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-smime-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-speed-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-spkac-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-srp-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-ts-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-verify-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-version-data.h (added) * freebsd/crypto/openssl/apps/rtems-bsd-openssl-x509-data.h (added) * freebsd/crypto/openssl/apps/s_cb.c (modified) * freebsd/crypto/openssl/apps/s_client.c (modified) * freebsd/crypto/openssl/apps/s_server.c (modified) * freebsd/crypto/openssl/apps/s_socket.c (modified) * freebsd/crypto/openssl/apps/s_time.c (modified) * freebsd/crypto/openssl/apps/sess_id.c (modified) * freebsd/crypto/openssl/apps/smime.c (modified) * freebsd/crypto/openssl/apps/speed.c (modified) * freebsd/crypto/openssl/apps/spkac.c (modified) * freebsd/crypto/openssl/apps/srp.c (modified) * freebsd/crypto/openssl/apps/ts.c (modified) * freebsd/crypto/openssl/apps/verify.c (modified) * freebsd/crypto/openssl/apps/version.c (modified) * freebsd/crypto/openssl/apps/x509.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-openssl.c (added) * testsuite/openssl02/test_main.c (added) bin/openssl: Port to RTEMS. Mon, 18 Feb 2019 09:05:32 GMT Sebastian Huber [3e483fb] * libbsd.py (modified) * rtemsbsd/rtems/rtems-bsd-cxx.cc (modified) Build C++ kernel-space compatibility file Tue, 12 Feb 2019 13:15:39 GMT Sebastian Huber [180ff44] * buildset/default.ini (modified) * libbsd.py (modified) * rtemsbsd/mghttpd/mongoose.c (deleted) * rtemsbsd/mghttpd/mongoose.h (deleted) mghttpd: Remove The mghttpd is already provided by RTEMS. Mon, 11 Feb 2019 14:26:17 GMT Sebastian Huber [556ec29] * freebsd-org (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_rsureg.h (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_runreg.h (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_upgt.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/dev/usb/wlan/if_zydreg.h (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_wps.h (added) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/vm/uma_core.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/bus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/gpiobus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ifdi_if.h (modified) * rtemsbsd/include/rtems/bsd/local/miibus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbr_if.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ofw_bus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ofw_if.h (modified) * rtemsbsd/include/rtems/bsd/local/pcib_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usb_if.h (modified) * rtemsbsd/local/bus_if.c (modified) Update to FreeBSD stable/12 2019-02-11 Git mirror commit ... Mon, 21 Jan 2019 08:45:46 GMT Sebastian Huber [aec8db0] * freebsd-org (modified) * freebsd/contrib/expat/lib/ascii.h (modified) * freebsd/contrib/expat/lib/asciitab.h (modified) * freebsd/contrib/expat/lib/expat.h (modified) * freebsd/contrib/expat/lib/expat_external.h (modified) * freebsd/contrib/expat/lib/iasciitab.h (modified) * freebsd/contrib/expat/lib/internal.h (modified) * freebsd/contrib/expat/lib/latin1tab.h (modified) * freebsd/contrib/expat/lib/nametab.h (modified) * freebsd/contrib/expat/lib/utf8tab.h (modified) * freebsd/contrib/expat/lib/xmlparse.c (modified) * freebsd/contrib/expat/lib/xmlrole.c (modified) * freebsd/contrib/expat/lib/xmlrole.h (modified) * freebsd/contrib/expat/lib/xmltok.c (modified) * freebsd/contrib/expat/lib/xmltok.h (modified) * freebsd/contrib/expat/lib/xmltok_impl.c (modified) * freebsd/contrib/expat/lib/xmltok_impl.h (modified) * freebsd/contrib/expat/lib/xmltok_ns.c (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * freebsd/crypto/openssl/crypto/LPdir_unix.c (modified) * freebsd/crypto/openssl/crypto/async/arch/async_posix.h (modified) * freebsd/crypto/openssl/crypto/bio/b_sock2.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_lib.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_log.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_api.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_mod.c (modified) * freebsd/crypto/openssl/crypto/cryptlib.c (modified) * freebsd/crypto/openssl/crypto/ct/ct_log.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdh_kdf.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_devcrypto.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_list.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_rc2.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (modified) * freebsd/crypto/openssl/crypto/getenv.c (added) * freebsd/crypto/openssl/crypto/include/internal/ec_int.h (modified) * freebsd/crypto/openssl/crypto/include/internal/rand_int.h (modified) * freebsd/crypto/openssl/crypto/kdf/hkdf.c (modified) * freebsd/crypto/openssl/crypto/mem_sec.c (modified) * freebsd/crypto/openssl/crypto/o_fopen.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_mutl.c (modified) * freebsd/crypto/openssl/crypto/rand/drbg_ctr.c (modified) * freebsd/crypto/openssl/crypto/rand/drbg_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_err.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_lcl.h (modified) * freebsd/crypto/openssl/crypto/rand/rand_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rand/randfile.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_lib.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_meth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/siphash/siphash.c (modified) * freebsd/crypto/openssl/crypto/sm2/sm2_crypt.c (modified) * freebsd/crypto/openssl/crypto/sm2/sm2_sign.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/x509/by_dir.c (modified) * freebsd/crypto/openssl/crypto/x509/by_file.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (modified) * freebsd/crypto/openssl/e_os.h (modified) * freebsd/crypto/openssl/include/internal/cryptlib.h (modified) * freebsd/crypto/openssl/include/internal/tsan_assist.h (modified) * freebsd/crypto/openssl/include/openssl/cryptoerr.h (modified) * freebsd/crypto/openssl/include/openssl/ec.h (modified) * freebsd/crypto/openssl/include/openssl/ocsp.h (modified) * freebsd/crypto/openssl/include/openssl/opensslv.h (modified) * freebsd/crypto/openssl/include/openssl/rand_drbg.h (modified) * freebsd/crypto/openssl/include/openssl/randerr.h (modified) * freebsd/crypto/openssl/include/openssl/rsa.h (modified) * freebsd/crypto/openssl/include/openssl/ssl.h (modified) * freebsd/crypto/openssl/include/openssl/symhacks.h (modified) * freebsd/crypto/openssl/include/openssl/tls1.h (modified) * freebsd/crypto/openssl/ssl/d1_lib.c (modified) * freebsd/crypto/openssl/ssl/record/rec_layer_d1.c (modified) * freebsd/crypto/openssl/ssl/record/record.h (modified) * freebsd/crypto/openssl/ssl/record/record_locl.h (modified) * freebsd/crypto/openssl/ssl/record/ssl3_record.c (modified) * freebsd/crypto/openssl/ssl/s3_cbc.c (modified) * freebsd/crypto/openssl/ssl/s3_enc.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/statem/extensions.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/statem.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_lib.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_locl.h (modified) * freebsd/crypto/openssl/ssl/statem/statem_srvr.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/tls13_enc.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libcapsicum/capsicum_helpers.h (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sys/contrib/ck/include/gcc/sparcv9/ck_pr.h (modified) * freebsd/sys/crypto/chacha20/chacha.c (modified) * freebsd/sys/crypto/chacha20/chacha.h (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/fxp/if_fxpreg.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_var.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_priv.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom_image.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_var.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/altq/altq_cbq.h (modified) * freebsd/sys/net/altq/altq_rmclass.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/netinet/cc/cc.h (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sys/cons.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD stable/12 2019-01-16 Git mirror commit ... Wed, 19 Dec 2018 21:53:54 GMT Christian Mauderer [8ae22c4] * freebsd/sys/arm/ti/cpsw/if_cpsw.c (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_cpsw.h (added) freebsd/if_cpsw: Port. Tue, 06 Nov 2018 14:42:44 GMT Sebastian Huber [e0b4edbd] * Makefile.todo (modified) * freebsd-org (modified) * freebsd/contrib/expat/lib/ascii.h (modified) * freebsd/contrib/expat/lib/asciitab.h (modified) * freebsd/contrib/expat/lib/expat.h (modified) * freebsd/contrib/expat/lib/expat_external.h (modified) * freebsd/contrib/expat/lib/iasciitab.h (modified) * freebsd/contrib/expat/lib/internal.h (modified) * freebsd/contrib/expat/lib/latin1tab.h (modified) * freebsd/contrib/expat/lib/nametab.h (modified) * freebsd/contrib/expat/lib/siphash.h (added) * freebsd/contrib/expat/lib/utf8tab.h (modified) * freebsd/contrib/expat/lib/xmlparse.c (modified) * freebsd/contrib/expat/lib/xmlrole.c (modified) * freebsd/contrib/expat/lib/xmlrole.h (modified) * freebsd/contrib/expat/lib/xmltok.c (modified) * freebsd/contrib/expat/lib/xmltok.h (modified) * freebsd/contrib/expat/lib/xmltok_impl.c (modified) * freebsd/contrib/expat/lib/xmltok_impl.h (modified) * freebsd/contrib/expat/lib/xmltok_ns.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/crypto/openssl/include/openssl/opensslv.h (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libcapsicum/capsicum_helpers.h (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/igb_txrx.c (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev_private.h (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sys/_domainset.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/domainset.h (modified) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/vm/vm_domainset.h (added) * rtemsbsd/rtems/rtems-bsd-regdomain.c (modified) Update to FreeBSD head 2018-11-15 Git mirror commit ... Thu, 25 Oct 2018 06:39:13 GMT Sebastian Huber [a707913] * libbsd.py (modified) * testsuite/openssl01/test_main.c (added) openssl01: New test Tue, 23 Oct 2018 06:22:44 GMT Sebastian Huber [b3169c2] * Makefile.todo (modified) * freebsd-org (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/crypto/openssl/crypto/LPdir_unix.c (modified) * freebsd/crypto/openssl/crypto/aes/aes.h (deleted) * freebsd/crypto/openssl/crypto/aes/aes_cbc.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_cfb.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_core.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_ctr.c (deleted) * freebsd/crypto/openssl/crypto/aes/aes_ecb.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_ige.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_locl.h (modified) * freebsd/crypto/openssl/crypto/aes/aes_misc.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_ofb.c (modified) * freebsd/crypto/openssl/crypto/aes/aes_wrap.c (modified) * freebsd/crypto/openssl/crypto/aria/aria.c (added) * freebsd/crypto/openssl/crypto/arm_arch.h (modified) * freebsd/crypto/openssl/crypto/armcap.c (deleted) * freebsd/crypto/openssl/crypto/asn1/a_bitstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_bool.c (deleted) * freebsd/crypto/openssl/crypto/asn1/a_bytes.c (deleted) * freebsd/crypto/openssl/crypto/asn1/a_d2i_fp.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_digest.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_dup.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_enum.c (deleted) * freebsd/crypto/openssl/crypto/asn1/a_gentm.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_i2d_fp.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_int.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_mbstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_object.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_octet.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_print.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_set.c (deleted) * freebsd/crypto/openssl/crypto/asn1/a_sign.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strex.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strnid.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_type.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_utctm.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_utf8.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_verify.c (modified) * freebsd/crypto/openssl/crypto/asn1/ameth_lib.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1.h (deleted) * freebsd/crypto/openssl/crypto/asn1/asn1_err.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_gen.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_int.h (deleted) * freebsd/crypto/openssl/crypto/asn1/asn1_item_list.c (added) * freebsd/crypto/openssl/crypto/asn1/asn1_item_list.h (added) * freebsd/crypto/openssl/crypto/asn1/asn1_lib.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_locl.h (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_mac.h (deleted) * freebsd/crypto/openssl/crypto/asn1/asn1_par.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn_mime.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn_moid.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn_mstbl.c (added) * freebsd/crypto/openssl/crypto/asn1/asn_pack.c (modified) * freebsd/crypto/openssl/crypto/asn1/bio_asn1.c (modified) * freebsd/crypto/openssl/crypto/asn1/bio_ndef.c (modified) * freebsd/crypto/openssl/crypto/asn1/charmap.h (modified) * freebsd/crypto/openssl/crypto/asn1/d2i_pr.c (modified) * freebsd/crypto/openssl/crypto/asn1/d2i_pu.c (modified) * freebsd/crypto/openssl/crypto/asn1/evp_asn1.c (modified) * freebsd/crypto/openssl/crypto/asn1/f_enum.c (deleted) * freebsd/crypto/openssl/crypto/asn1/f_int.c (modified) * freebsd/crypto/openssl/crypto/asn1/f_string.c (modified) * freebsd/crypto/openssl/crypto/asn1/i2d_pr.c (modified) * freebsd/crypto/openssl/crypto/asn1/i2d_pu.c (modified) * freebsd/crypto/openssl/crypto/asn1/n_pkey.c (modified) * freebsd/crypto/openssl/crypto/asn1/nsseq.c (modified) * freebsd/crypto/openssl/crypto/asn1/p5_pbe.c (modified) * freebsd/crypto/openssl/crypto/asn1/p5_pbev2.c (modified) * freebsd/crypto/openssl/crypto/asn1/p5_scrypt.c (added) * freebsd/crypto/openssl/crypto/asn1/p8_pkey.c (modified) * freebsd/crypto/openssl/crypto/asn1/standard_methods.h (added) * freebsd/crypto/openssl/crypto/asn1/t_bitst.c (modified) * freebsd/crypto/openssl/crypto/asn1/t_crl.c (deleted) * freebsd/crypto/openssl/crypto/asn1/t_pkey.c (modified) * freebsd/crypto/openssl/crypto/asn1/t_req.c (deleted) * freebsd/crypto/openssl/crypto/asn1/t_spki.c (modified) * freebsd/crypto/openssl/crypto/asn1/t_x509.c (deleted) * freebsd/crypto/openssl/crypto/asn1/t_x509a.c (deleted) * freebsd/crypto/openssl/crypto/asn1/tasn_dec.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_enc.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_fre.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_new.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_prn.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_scn.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_typ.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_utl.c (modified) * freebsd/crypto/openssl/crypto/asn1/tbl_standard.h (added) * freebsd/crypto/openssl/crypto/asn1/x_algor.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_attrib.c (deleted) * freebsd/crypto/openssl/crypto/asn1/x_bignum.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_exten.c (deleted) * freebsd/crypto/openssl/crypto/asn1/x_info.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_int64.c (added) * freebsd/crypto/openssl/crypto/asn1/x_long.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_nx509.c (deleted) * freebsd/crypto/openssl/crypto/asn1/x_pkey.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_req.c (deleted) * freebsd/crypto/openssl/crypto/asn1/x_sig.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_spki.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_val.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_x509a.c (deleted) * freebsd/crypto/openssl/crypto/async/arch/async_null.c (added) * freebsd/crypto/openssl/crypto/async/arch/async_null.h (added) * freebsd/crypto/openssl/crypto/async/arch/async_posix.c (added) * freebsd/crypto/openssl/crypto/async/arch/async_posix.h (added) * freebsd/crypto/openssl/crypto/async/arch/async_win.h (added) * freebsd/crypto/openssl/crypto/async/async.c (added) * freebsd/crypto/openssl/crypto/async/async_err.c (added) * freebsd/crypto/openssl/crypto/async/async_locl.h (added) * freebsd/crypto/openssl/crypto/async/async_wait.c (added) * freebsd/crypto/openssl/crypto/bf/bf_cfb64.c (modified) * freebsd/crypto/openssl/crypto/bf/bf_ecb.c (modified) * freebsd/crypto/openssl/crypto/bf/bf_enc.c (modified) * freebsd/crypto/openssl/crypto/bf/bf_locl.h (modified) * freebsd/crypto/openssl/crypto/bf/bf_ofb64.c (modified) * freebsd/crypto/openssl/crypto/bf/bf_opts.c (deleted) * freebsd/crypto/openssl/crypto/bf/bf_pi.h (modified) * freebsd/crypto/openssl/crypto/bf/bf_skey.c (modified) * freebsd/crypto/openssl/crypto/bf/bfspeed.c (deleted) * freebsd/crypto/openssl/crypto/bf/bftest.c (deleted) * freebsd/crypto/openssl/crypto/bf/blowfish.h (deleted) * freebsd/crypto/openssl/crypto/bio/b_addr.c (added) * freebsd/crypto/openssl/crypto/bio/b_dump.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bio/b_sock.c (modified) * freebsd/crypto/openssl/crypto/bio/b_sock2.c (added) * freebsd/crypto/openssl/crypto/bio/bf_buff.c (modified) * freebsd/crypto/openssl/crypto/bio/bf_lbuf.c (modified) * freebsd/crypto/openssl/crypto/bio/bf_nbio.c (modified) * freebsd/crypto/openssl/crypto/bio/bf_null.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_cb.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_err.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_lcl.h (modified) * freebsd/crypto/openssl/crypto/bio/bio_lib.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_meth.c (added) * freebsd/crypto/openssl/crypto/bio/bss_acpt.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_bio.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_conn.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_dgram.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_fd.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_log.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_null.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_sock.c (modified) * freebsd/crypto/openssl/crypto/blake2/blake2_impl.h (added) * freebsd/crypto/openssl/crypto/blake2/blake2_locl.h (added) * freebsd/crypto/openssl/crypto/blake2/blake2b.c (added) * freebsd/crypto/openssl/crypto/blake2/blake2s.c (added) * freebsd/crypto/openssl/crypto/blake2/m_blake2b.c (added) * freebsd/crypto/openssl/crypto/blake2/m_blake2s.c (added) * freebsd/crypto/openssl/crypto/bn/asm/x86_64-gcc.c (added) * freebsd/crypto/openssl/crypto/bn/bn.h (deleted) * freebsd/crypto/openssl/crypto/bn/bn_add.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_asm.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_blind.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_const.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_ctx.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_depr.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_dh.c (added) * freebsd/crypto/openssl/crypto/bn/bn_div.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_err.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp2.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_gcd.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_gf2m.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_intern.c (added) * freebsd/crypto/openssl/crypto/bn/bn_kron.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lcl.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mod.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mpi.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mul.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_nist.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_print.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_rand.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_recp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_shift.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_sqr.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_sqrt.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_srp.c (moved) * freebsd/crypto/openssl/crypto/bn/bn_word.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_x931p.c (modified) * freebsd/crypto/openssl/crypto/bn/bnspeed.c (deleted) * freebsd/crypto/openssl/crypto/bn/bntest.c (deleted) * freebsd/crypto/openssl/crypto/bn/divtest.c (deleted) * freebsd/crypto/openssl/crypto/bn/expspeed.c (deleted) * freebsd/crypto/openssl/crypto/bn/exptest.c (deleted) * freebsd/crypto/openssl/crypto/bn/rsaz_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/rsaz_exp.h (modified) * freebsd/crypto/openssl/crypto/bn_int.h (deleted) * freebsd/crypto/openssl/crypto/buffer/buf_err.c (modified) * freebsd/crypto/openssl/crypto/buffer/buf_str.c (deleted) * freebsd/crypto/openssl/crypto/buffer/buffer.c (modified) * freebsd/crypto/openssl/crypto/buffer/buffer.h (deleted) * freebsd/crypto/openssl/crypto/buildinf.h (added) * freebsd/crypto/openssl/crypto/camellia/camellia.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_cbc.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_cfb.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_ctr.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_ecb.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_locl.h (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_misc.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_ofb.c (modified) * freebsd/crypto/openssl/crypto/camellia/cmll_utl.c (deleted) * freebsd/crypto/openssl/crypto/cast/c_cfb64.c (modified) * freebsd/crypto/openssl/crypto/cast/c_ecb.c (modified) * freebsd/crypto/openssl/crypto/cast/c_enc.c (modified) * freebsd/crypto/openssl/crypto/cast/c_ofb64.c (modified) * freebsd/crypto/openssl/crypto/cast/c_skey.c (modified) * freebsd/crypto/openssl/crypto/cast/cast.h (deleted) * freebsd/crypto/openssl/crypto/cast/cast_lcl.h (modified) * freebsd/crypto/openssl/crypto/cast/cast_s.h (modified) * freebsd/crypto/openssl/crypto/cast/cast_spd.c (deleted) * freebsd/crypto/openssl/crypto/cast/castopts.c (deleted) * freebsd/crypto/openssl/crypto/cast/casttest.c (deleted) * freebsd/crypto/openssl/crypto/chacha/chacha_enc.c (added) * freebsd/crypto/openssl/crypto/cmac/cm_ameth.c (modified) * freebsd/crypto/openssl/crypto/cmac/cm_pmeth.c (modified) * freebsd/crypto/openssl/crypto/cmac/cmac.c (modified) * freebsd/crypto/openssl/crypto/cmac/cmac.h (deleted) * freebsd/crypto/openssl/crypto/cms/cms_asn1.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_att.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_cd.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_dd.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_enc.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_env.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_err.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_ess.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_io.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_kari.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_lcl.h (modified) * freebsd/crypto/openssl/crypto/cms/cms_lib.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_pwri.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_sd.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_smime.c (modified) * freebsd/crypto/openssl/crypto/comp/c_rle.c (deleted) * freebsd/crypto/openssl/crypto/comp/c_zlib.c (modified) * freebsd/crypto/openssl/crypto/comp/comp.h (deleted) * freebsd/crypto/openssl/crypto/comp/comp_err.c (modified) * freebsd/crypto/openssl/crypto/comp/comp_lcl.h (added) * freebsd/crypto/openssl/crypto/comp/comp_lib.c (modified) * freebsd/crypto/openssl/crypto/conf/conf.h (deleted) * freebsd/crypto/openssl/crypto/conf/conf_api.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_api.h (deleted) * freebsd/crypto/openssl/crypto/conf/conf_def.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_def.h (modified) * freebsd/crypto/openssl/crypto/conf/conf_err.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_lcl.h (added) * freebsd/crypto/openssl/crypto/conf/conf_lib.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_mall.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_mod.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_sap.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_ssl.c (added) * freebsd/crypto/openssl/crypto/constant_time_locl.h (deleted) * freebsd/crypto/openssl/crypto/constant_time_test.c (deleted) * freebsd/crypto/openssl/crypto/cpt_err.c (modified) * freebsd/crypto/openssl/crypto/cryptlib.c (modified) * freebsd/crypto/openssl/crypto/cryptlib.h (deleted) * freebsd/crypto/openssl/crypto/crypto.h (deleted) * freebsd/crypto/openssl/crypto/ct/ct_b64.c (added) * freebsd/crypto/openssl/crypto/ct/ct_err.c (added) * freebsd/crypto/openssl/crypto/ct/ct_locl.h (added) * freebsd/crypto/openssl/crypto/ct/ct_log.c (added) * freebsd/crypto/openssl/crypto/ct/ct_oct.c (added) * freebsd/crypto/openssl/crypto/ct/ct_policy.c (added) * freebsd/crypto/openssl/crypto/ct/ct_prn.c (added) * freebsd/crypto/openssl/crypto/ct/ct_sct.c (added) * freebsd/crypto/openssl/crypto/ct/ct_sct_ctx.c (added) * freebsd/crypto/openssl/crypto/ct/ct_vfy.c (added) * freebsd/crypto/openssl/crypto/ct/ct_x509v3.c (added) * freebsd/crypto/openssl/crypto/ctype.c (added) * freebsd/crypto/openssl/crypto/cversion.c (modified) * freebsd/crypto/openssl/crypto/des/cbc3_enc.c (deleted) * freebsd/crypto/openssl/crypto/des/cbc_cksm.c (modified) * freebsd/crypto/openssl/crypto/des/cbc_enc.c (modified) * freebsd/crypto/openssl/crypto/des/cfb64ede.c (modified) * freebsd/crypto/openssl/crypto/des/cfb64enc.c (modified) * freebsd/crypto/openssl/crypto/des/cfb_enc.c (modified) * freebsd/crypto/openssl/crypto/des/des.c (deleted) * freebsd/crypto/openssl/crypto/des/des_enc.c (modified) * freebsd/crypto/openssl/crypto/des/des_locl.h (modified) * freebsd/crypto/openssl/crypto/des/des_old.h (deleted) * freebsd/crypto/openssl/crypto/des/des_old2.c (deleted) * freebsd/crypto/openssl/crypto/des/des_ver.h (deleted) * freebsd/crypto/openssl/crypto/des/ecb3_enc.c (modified) * freebsd/crypto/openssl/crypto/des/ecb_enc.c (modified) * freebsd/crypto/openssl/crypto/des/ede_cbcm_enc.c (deleted) * freebsd/crypto/openssl/crypto/des/enc_read.c (deleted) * freebsd/crypto/openssl/crypto/des/enc_writ.c (deleted) * freebsd/crypto/openssl/crypto/des/fcrypt.c (modified) * freebsd/crypto/openssl/crypto/des/fcrypt_b.c (modified) * freebsd/crypto/openssl/crypto/des/ncbc_enc.c (modified) * freebsd/crypto/openssl/crypto/des/ofb64ede.c (modified) * freebsd/crypto/openssl/crypto/des/ofb64enc.c (modified) * freebsd/crypto/openssl/crypto/des/ofb_enc.c (modified) * freebsd/crypto/openssl/crypto/des/pcbc_enc.c (modified) * freebsd/crypto/openssl/crypto/des/qud_cksm.c (modified) * freebsd/crypto/openssl/crypto/des/rand_key.c (modified) * freebsd/crypto/openssl/crypto/des/read2pwd.c (deleted) * freebsd/crypto/openssl/crypto/des/read_pwd.c (deleted) * freebsd/crypto/openssl/crypto/des/rpc_des.h (deleted) * freebsd/crypto/openssl/crypto/des/rpc_enc.c (deleted) * freebsd/crypto/openssl/crypto/des/rpw.c (deleted) * freebsd/crypto/openssl/crypto/des/set_key.c (modified) * freebsd/crypto/openssl/crypto/des/speed.c (deleted) * freebsd/crypto/openssl/crypto/des/spr.h (modified) * freebsd/crypto/openssl/crypto/des/str2key.c (modified) * freebsd/crypto/openssl/crypto/des/xcbc_enc.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_ameth.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_asn1.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_check.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_depr.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_err.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_gen.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_kdf.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_lib.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_locl.h (added) * freebsd/crypto/openssl/crypto/dh/dh_meth.c (added) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_prn.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_rfc5114.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_rfc7919.c (added) * freebsd/crypto/openssl/crypto/dh/dhtest.c (deleted) * freebsd/crypto/openssl/crypto/dh/p1024.c (deleted) * freebsd/crypto/openssl/crypto/dh/p192.c (deleted) * freebsd/crypto/openssl/crypto/dh/p512.c (deleted) * freebsd/crypto/openssl/crypto/dllmain.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa.h (deleted) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_asn1.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_depr.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_err.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_key.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_lib.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_locl.h (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_meth.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_prn.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_sign.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_vrf.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsagen.c (deleted) * freebsd/crypto/openssl/crypto/dsa/dsatest.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso.h (deleted) * freebsd/crypto/openssl/crypto/dso/dso_beos.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso_dl.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso_dlfcn.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso_err.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso_lib.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso_locl.h (added) * freebsd/crypto/openssl/crypto/dso/dso_null.c (deleted) * freebsd/crypto/openssl/crypto/dso/dso_openssl.c (deleted) * freebsd/crypto/openssl/crypto/ebcdic.c (modified) * freebsd/crypto/openssl/crypto/ec/curve25519.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/arch_32/arch_intrinsics.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/arch_32/f_impl.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/arch_32/f_impl.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/curve448.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/curve448_lcl.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/curve448_tables.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/curve448utils.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/ed448.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/eddsa.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/f_generic.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/field.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/point_448.h (added) * freebsd/crypto/openssl/crypto/ec/curve448/scalar.c (added) * freebsd/crypto/openssl/crypto/ec/curve448/word.h (added) * freebsd/crypto/openssl/crypto/ec/ec2_mult.c (deleted) * freebsd/crypto/openssl/crypto/ec/ec2_oct.c (modified) * freebsd/crypto/openssl/crypto/ec/ec2_smpl.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_asn1.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_check.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_curve.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_cvt.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_err.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_key.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_kmeth.c (added) * freebsd/crypto/openssl/crypto/ec/ec_lcl.h (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_oct.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_print.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdh_kdf.c (added) * freebsd/crypto/openssl/crypto/ec/ecdh_ossl.c (added) * freebsd/crypto/openssl/crypto/ec/ecdsa_ossl.c (added) * freebsd/crypto/openssl/crypto/ec/ecdsa_sign.c (added) * freebsd/crypto/openssl/crypto/ec/ecdsa_vrf.c (added) * freebsd/crypto/openssl/crypto/ec/eck_prn.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_mont.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nist.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistputil.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256_table.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_oct.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_smpl.c (modified) * freebsd/crypto/openssl/crypto/ec/ectest.c (deleted) * freebsd/crypto/openssl/crypto/ec/ecx_meth.c (added) * freebsd/crypto/openssl/crypto/ecdh/ecdh.h (deleted) * freebsd/crypto/openssl/crypto/ecdh/ecdhtest.c (deleted) * freebsd/crypto/openssl/crypto/ecdh/ech_err.c (deleted) * freebsd/crypto/openssl/crypto/ecdh/ech_kdf.c (deleted) * freebsd/crypto/openssl/crypto/ecdh/ech_key.c (deleted) * freebsd/crypto/openssl/crypto/ecdh/ech_lib.c (deleted) * freebsd/crypto/openssl/crypto/ecdh/ech_locl.h (deleted) * freebsd/crypto/openssl/crypto/ecdh/ech_ossl.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecdsa.h (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecdsatest.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_asn1.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_err.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_lib.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_locl.h (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_sign.c (deleted) * freebsd/crypto/openssl/crypto/ecdsa/ecs_vrf.c (deleted) * freebsd/crypto/openssl/crypto/engine/eng_all.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_cnf.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c (deleted) * freebsd/crypto/openssl/crypto/engine/eng_ctrl.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_devcrypto.c (added) * freebsd/crypto/openssl/crypto/engine/eng_dyn.c (deleted) * freebsd/crypto/openssl/crypto/engine/eng_err.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_fat.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_init.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_int.h (modified) * freebsd/crypto/openssl/crypto/engine/eng_lib.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_list.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_openssl.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_pkey.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_rdrand.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_table.c (modified) * freebsd/crypto/openssl/crypto/engine/enginetest.c (deleted) * freebsd/crypto/openssl/crypto/engine/tb_asnmth.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_cipher.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_dh.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_digest.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_dsa.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_ecdh.c (deleted) * freebsd/crypto/openssl/crypto/engine/tb_ecdsa.c (deleted) * freebsd/crypto/openssl/crypto/engine/tb_eckey.c (added) * freebsd/crypto/openssl/crypto/engine/tb_pkmeth.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_rand.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_rsa.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_store.c (deleted) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/err/err.h (deleted) * freebsd/crypto/openssl/crypto/err/err_all.c (modified) * freebsd/crypto/openssl/crypto/err/err_prn.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_b64.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_md.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_ok.c (modified) * freebsd/crypto/openssl/crypto/evp/c_all.c (deleted) * freebsd/crypto/openssl/crypto/evp/c_allc.c (modified) * freebsd/crypto/openssl/crypto/evp/c_alld.c (modified) * freebsd/crypto/openssl/crypto/evp/cmeth_lib.c (added) * freebsd/crypto/openssl/crypto/evp/digest.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aria.c (added) * freebsd/crypto/openssl/crypto/evp/e_bf.c (modified) * freebsd/crypto/openssl/crypto/evp/e_camellia.c (modified) * freebsd/crypto/openssl/crypto/evp/e_cast.c (modified) * freebsd/crypto/openssl/crypto/evp/e_chacha20_poly1305.c (added) * freebsd/crypto/openssl/crypto/evp/e_des.c (modified) * freebsd/crypto/openssl/crypto/evp/e_des3.c (modified) * freebsd/crypto/openssl/crypto/evp/e_idea.c (modified) * freebsd/crypto/openssl/crypto/evp/e_null.c (modified) * freebsd/crypto/openssl/crypto/evp/e_old.c (modified) * freebsd/crypto/openssl/crypto/evp/e_rc2.c (modified) * freebsd/crypto/openssl/crypto/evp/e_rc4.c (modified) * freebsd/crypto/openssl/crypto/evp/e_rc4_hmac_md5.c (modified) * freebsd/crypto/openssl/crypto/evp/e_rc5.c (deleted) * freebsd/crypto/openssl/crypto/evp/e_seed.c (modified) * freebsd/crypto/openssl/crypto/evp/e_sm4.c (added) * freebsd/crypto/openssl/crypto/evp/e_xcbc_d.c (modified) * freebsd/crypto/openssl/crypto/evp/encode.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_acnf.c (deleted) * freebsd/crypto/openssl/crypto/evp/evp_cnf.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_err.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_extra_test.c (deleted) * freebsd/crypto/openssl/crypto/evp/evp_key.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_lib.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_locl.h (modified) * freebsd/crypto/openssl/crypto/evp/evp_pbe.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_pkey.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_test.c (deleted) * freebsd/crypto/openssl/crypto/evp/m_dss.c (deleted) * freebsd/crypto/openssl/crypto/evp/m_dss1.c (deleted) * freebsd/crypto/openssl/crypto/evp/m_ecdsa.c (deleted) * freebsd/crypto/openssl/crypto/evp/m_md2.c (modified) * freebsd/crypto/openssl/crypto/evp/m_md4.c (modified) * freebsd/crypto/openssl/crypto/evp/m_md5.c (modified) * freebsd/crypto/openssl/crypto/evp/m_md5_sha1.c (added) * freebsd/crypto/openssl/crypto/evp/m_mdc2.c (modified) * freebsd/crypto/openssl/crypto/evp/m_null.c (modified) * freebsd/crypto/openssl/crypto/evp/m_ripemd.c (modified) * freebsd/crypto/openssl/crypto/evp/m_sha.c (deleted) * freebsd/crypto/openssl/crypto/evp/m_sha1.c (modified) * freebsd/crypto/openssl/crypto/evp/m_sha3.c (added) * freebsd/crypto/openssl/crypto/evp/m_sigver.c (modified) * freebsd/crypto/openssl/crypto/evp/m_wp.c (modified) * freebsd/crypto/openssl/crypto/evp/names.c (modified) * freebsd/crypto/openssl/crypto/evp/openbsd_hw.c (deleted) * freebsd/crypto/openssl/crypto/evp/p5_crpt.c (modified) * freebsd/crypto/openssl/crypto/evp/p5_crpt2.c (modified) * freebsd/crypto/openssl/crypto/evp/p_dec.c (modified) * freebsd/crypto/openssl/crypto/evp/p_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/p_lib.c (modified) * freebsd/crypto/openssl/crypto/evp/p_open.c (modified) * freebsd/crypto/openssl/crypto/evp/p_seal.c (modified) * freebsd/crypto/openssl/crypto/evp/p_sign.c (modified) * freebsd/crypto/openssl/crypto/evp/p_verify.c (modified) * freebsd/crypto/openssl/crypto/evp/pbe_scrypt.c (added) * freebsd/crypto/openssl/crypto/evp/pmeth_fn.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_gn.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (modified) * freebsd/crypto/openssl/crypto/ex_data.c (modified) * freebsd/crypto/openssl/crypto/fips_err.h (deleted) * freebsd/crypto/openssl/crypto/fips_ers.c (deleted) * freebsd/crypto/openssl/crypto/hmac/hm_ameth.c (modified) * freebsd/crypto/openssl/crypto/hmac/hm_pmeth.c (modified) * freebsd/crypto/openssl/crypto/hmac/hmac.c (modified) * freebsd/crypto/openssl/crypto/hmac/hmac.h (deleted) * freebsd/crypto/openssl/crypto/hmac/hmac_lcl.h (added) * freebsd/crypto/openssl/crypto/hmac/hmactest.c (deleted) * freebsd/crypto/openssl/crypto/idea/i_cbc.c (modified) * freebsd/crypto/openssl/crypto/idea/i_cfb64.c (modified) * freebsd/crypto/openssl/crypto/idea/i_ecb.c (modified) * freebsd/crypto/openssl/crypto/idea/i_ofb64.c (modified) * freebsd/crypto/openssl/crypto/idea/i_skey.c (modified) * freebsd/crypto/openssl/crypto/idea/idea.h (deleted) * freebsd/crypto/openssl/crypto/idea/idea_lcl.h (modified) * freebsd/crypto/openssl/crypto/idea/idea_spd.c (deleted) * freebsd/crypto/openssl/crypto/idea/ideatest.c (deleted) * freebsd/crypto/openssl/crypto/include/internal/aria.h (added) * freebsd/crypto/openssl/crypto/include/internal/asn1_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/async.h (added) * freebsd/crypto/openssl/crypto/include/internal/bn_conf.h (added) * freebsd/crypto/openssl/crypto/include/internal/bn_dh.h (added) * freebsd/crypto/openssl/crypto/include/internal/bn_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/bn_srp.h (added) * freebsd/crypto/openssl/crypto/include/internal/chacha.h (added) * freebsd/crypto/openssl/crypto/include/internal/cryptlib_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/ctype.h (added) * freebsd/crypto/openssl/crypto/include/internal/dso_conf.h (added) * freebsd/crypto/openssl/crypto/include/internal/ec_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/engine.h (added) * freebsd/crypto/openssl/crypto/include/internal/err_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/evp_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/lhash.h (added) * freebsd/crypto/openssl/crypto/include/internal/md32_common.h (added) * freebsd/crypto/openssl/crypto/include/internal/objects.h (added) * freebsd/crypto/openssl/crypto/include/internal/poly1305.h (added) * freebsd/crypto/openssl/crypto/include/internal/rand_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/sha.h (added) * freebsd/crypto/openssl/crypto/include/internal/siphash.h (added) * freebsd/crypto/openssl/crypto/include/internal/sm2.h (added) * freebsd/crypto/openssl/crypto/include/internal/sm2err.h (added) * freebsd/crypto/openssl/crypto/include/internal/sm3.h (added) * freebsd/crypto/openssl/crypto/include/internal/sm4.h (added) * freebsd/crypto/openssl/crypto/include/internal/store.h (added) * freebsd/crypto/openssl/crypto/include/internal/store_int.h (added) * freebsd/crypto/openssl/crypto/include/internal/x509_int.h (added) * freebsd/crypto/openssl/crypto/init.c (added) * freebsd/crypto/openssl/crypto/kdf/hkdf.c (added) * freebsd/crypto/openssl/crypto/kdf/kdf_err.c (added) * freebsd/crypto/openssl/crypto/kdf/scrypt.c (added) * freebsd/crypto/openssl/crypto/kdf/tls1_prf.c (added) * freebsd/crypto/openssl/crypto/krb5/krb5_asn.c (deleted) * freebsd/crypto/openssl/crypto/krb5/krb5_asn.h (deleted) * freebsd/crypto/openssl/crypto/lhash/lh_stats.c (added) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.h (deleted) * freebsd/crypto/openssl/crypto/lhash/lhash_lcl.h (added) * freebsd/crypto/openssl/crypto/md32_common.h (deleted) * freebsd/crypto/openssl/crypto/md4/md4.c (deleted) * freebsd/crypto/openssl/crypto/md4/md4.h (deleted) * freebsd/crypto/openssl/crypto/md4/md4_dgst.c (modified) * freebsd/crypto/openssl/crypto/md4/md4_locl.h (modified) * freebsd/crypto/openssl/crypto/md4/md4_one.c (modified) * freebsd/crypto/openssl/crypto/md4/md4test.c (deleted) * freebsd/crypto/openssl/crypto/md5/md5.c (deleted) * freebsd/crypto/openssl/crypto/md5/md5.h (deleted) * freebsd/crypto/openssl/crypto/md5/md5_dgst.c (modified) * freebsd/crypto/openssl/crypto/md5/md5_locl.h (modified) * freebsd/crypto/openssl/crypto/md5/md5_one.c (modified) * freebsd/crypto/openssl/crypto/md5/md5test.c (deleted) * freebsd/crypto/openssl/crypto/mdc2/mdc2.h (deleted) * freebsd/crypto/openssl/crypto/mdc2/mdc2_one.c (modified) * freebsd/crypto/openssl/crypto/mdc2/mdc2dgst.c (modified) * freebsd/crypto/openssl/crypto/mdc2/mdc2test.c (deleted) * freebsd/crypto/openssl/crypto/mem.c (modified) * freebsd/crypto/openssl/crypto/mem_clr.c (modified) * freebsd/crypto/openssl/crypto/mem_dbg.c (modified) * freebsd/crypto/openssl/crypto/mem_sec.c (added) * freebsd/crypto/openssl/crypto/mips_arch.h (added) * freebsd/crypto/openssl/crypto/modes/cbc128.c (modified) * freebsd/crypto/openssl/crypto/modes/ccm128.c (modified) * freebsd/crypto/openssl/crypto/modes/cfb128.c (modified) * freebsd/crypto/openssl/crypto/modes/ctr128.c (modified) * freebsd/crypto/openssl/crypto/modes/cts128.c (modified) * freebsd/crypto/openssl/crypto/modes/gcm128.c (modified) * freebsd/crypto/openssl/crypto/modes/modes_lcl.h (modified) * freebsd/crypto/openssl/crypto/modes/ocb128.c (added) * freebsd/crypto/openssl/crypto/modes/ofb128.c (modified) * freebsd/crypto/openssl/crypto/modes/wrap128.c (modified) * freebsd/crypto/openssl/crypto/modes/xts128.c (modified) * freebsd/crypto/openssl/crypto/o_dir.c (modified) * freebsd/crypto/openssl/crypto/o_dir_test.c (deleted) * freebsd/crypto/openssl/crypto/o_fips.c (modified) * freebsd/crypto/openssl/crypto/o_fopen.c (added) * freebsd/crypto/openssl/crypto/o_init.c (modified) * freebsd/crypto/openssl/crypto/o_str.c (modified) * freebsd/crypto/openssl/crypto/o_str.h (deleted) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/o_time.h (deleted) * freebsd/crypto/openssl/crypto/objects/o_names.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_dat.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_dat.h (modified) * freebsd/crypto/openssl/crypto/objects/obj_err.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_lcl.h (added) * freebsd/crypto/openssl/crypto/objects/obj_lib.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_xref.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_xref.h (modified) * freebsd/crypto/openssl/crypto/objects/objects.h (deleted) * freebsd/crypto/openssl/crypto/ocsp/ocsp.h (deleted) * freebsd/crypto/openssl/crypto/ocsp/ocsp_asn.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_cl.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_err.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_ext.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_ht.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_lcl.h (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_lib.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_prn.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_srv.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_vfy.c (modified) * freebsd/crypto/openssl/crypto/ocsp/v3_ocsp.c (moved) * freebsd/crypto/openssl/crypto/opensslconf.h (deleted) * freebsd/crypto/openssl/crypto/pem/pem2.h (deleted) * freebsd/crypto/openssl/crypto/pem/pem_all.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_err.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_info.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_oth.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pk8.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pkey.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_seal.c (deleted) * freebsd/crypto/openssl/crypto/pem/pem_sign.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_x509.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_xaux.c (modified) * freebsd/crypto/openssl/crypto/pem/pvkfmt.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_add.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_asn.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_attr.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_crpt.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_crt.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_decr.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_init.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_key.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_kiss.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_lcl.h (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_mutl.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_npas.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_p8d.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_p8e.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_sbag.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_utl.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/pk12err.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/pkcs12.h (deleted) * freebsd/crypto/openssl/crypto/pkcs7/bio_pk7.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_asn1.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_attr.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_dgst.c (deleted) * freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_lib.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_mime.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_smime.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pkcs7err.c (modified) * freebsd/crypto/openssl/crypto/poly1305/poly1305.c (added) * freebsd/crypto/openssl/crypto/poly1305/poly1305_ameth.c (added) * freebsd/crypto/openssl/crypto/poly1305/poly1305_local.h (added) * freebsd/crypto/openssl/crypto/poly1305/poly1305_pmeth.c (added) * freebsd/crypto/openssl/crypto/ppc_arch.h (modified) * freebsd/crypto/openssl/crypto/ppccap.c (deleted) * freebsd/crypto/openssl/crypto/pqueue/pq_test.c (deleted) * freebsd/crypto/openssl/crypto/pqueue/pqueue.c (deleted) * freebsd/crypto/openssl/crypto/pqueue/pqueue.h (deleted) * freebsd/crypto/openssl/crypto/rand/drbg_ctr.c (added) * freebsd/crypto/openssl/crypto/rand/drbg_lib.c (added) * freebsd/crypto/openssl/crypto/rand/md_rand.c (deleted) * freebsd/crypto/openssl/crypto/rand/rand.h (deleted) * freebsd/crypto/openssl/crypto/rand/rand_egd.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_err.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_lcl.h (modified) * freebsd/crypto/openssl/crypto/rand/rand_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rand/randfile.c (modified) * freebsd/crypto/openssl/crypto/rand/randtest.c (deleted) * freebsd/crypto/openssl/crypto/rc2/rc2.h (deleted) * freebsd/crypto/openssl/crypto/rc2/rc2_cbc.c (modified) * freebsd/crypto/openssl/crypto/rc2/rc2_ecb.c (modified) * freebsd/crypto/openssl/crypto/rc2/rc2_locl.h (modified) * freebsd/crypto/openssl/crypto/rc2/rc2_skey.c (modified) * freebsd/crypto/openssl/crypto/rc2/rc2cfb64.c (modified) * freebsd/crypto/openssl/crypto/rc2/rc2ofb64.c (modified) * freebsd/crypto/openssl/crypto/rc2/rc2speed.c (deleted) * freebsd/crypto/openssl/crypto/rc2/rc2test.c (deleted) * freebsd/crypto/openssl/crypto/rc2/tab.c (deleted) * freebsd/crypto/openssl/crypto/rc4/rc4.h (deleted) * freebsd/crypto/openssl/crypto/rc4/rc4_enc.c (modified) * freebsd/crypto/openssl/crypto/rc4/rc4_locl.h (modified) * freebsd/crypto/openssl/crypto/rc4/rc4_skey.c (modified) * freebsd/crypto/openssl/crypto/rc4/rc4_utl.c (deleted) * freebsd/crypto/openssl/crypto/rc4/rc4speed.c (deleted) * freebsd/crypto/openssl/crypto/rc4/rc4test.c (deleted) * freebsd/crypto/openssl/crypto/ripemd/ripemd.h (deleted) * freebsd/crypto/openssl/crypto/ripemd/rmd160.c (deleted) * freebsd/crypto/openssl/crypto/ripemd/rmd_dgst.c (modified) * freebsd/crypto/openssl/crypto/ripemd/rmd_locl.h (modified) * freebsd/crypto/openssl/crypto/ripemd/rmd_one.c (modified) * freebsd/crypto/openssl/crypto/ripemd/rmdconst.h (modified) * freebsd/crypto/openssl/crypto/ripemd/rmdtest.c (deleted) * freebsd/crypto/openssl/crypto/rsa/rsa.h (deleted) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_asn1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_chk.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_crpt.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_depr.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_eay.c (deleted) * freebsd/crypto/openssl/crypto/rsa/rsa_err.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_lib.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_locl.h (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_meth.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_mp.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_none.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_null.c (deleted) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ossl.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_prn.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pss.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_saos.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_sign.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ssl.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_test.c (deleted) * freebsd/crypto/openssl/crypto/rsa/rsa_x931.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_x931g.c (added) * freebsd/crypto/openssl/crypto/s390x_arch.h (added) * freebsd/crypto/openssl/crypto/s390xcap.c (deleted) * freebsd/crypto/openssl/crypto/seed/seed.c (modified) * freebsd/crypto/openssl/crypto/seed/seed_cbc.c (modified) * freebsd/crypto/openssl/crypto/seed/seed_cfb.c (modified) * freebsd/crypto/openssl/crypto/seed/seed_ecb.c (modified) * freebsd/crypto/openssl/crypto/seed/seed_locl.h (modified) * freebsd/crypto/openssl/crypto/seed/seed_ofb.c (modified) * freebsd/crypto/openssl/crypto/sha/keccak1600.c (added) * freebsd/crypto/openssl/crypto/sha/sha.c (deleted) * freebsd/crypto/openssl/crypto/sha/sha.h (deleted) * freebsd/crypto/openssl/crypto/sha/sha1.c (deleted) * freebsd/crypto/openssl/crypto/sha/sha1_one.c (modified) * freebsd/crypto/openssl/crypto/sha/sha1dgst.c (modified) * freebsd/crypto/openssl/crypto/sha/sha1test.c (deleted) * freebsd/crypto/openssl/crypto/sha/sha256.c (modified) * freebsd/crypto/openssl/crypto/sha/sha256t.c (deleted) * freebsd/crypto/openssl/crypto/sha/sha512.c (modified) * freebsd/crypto/openssl/crypto/sha/sha512t.c (deleted) * freebsd/crypto/openssl/crypto/sha/sha_dgst.c (deleted) * freebsd/crypto/openssl/crypto/sha/sha_locl.h (modified) * freebsd/crypto/openssl/crypto/sha/sha_one.c (deleted) * freebsd/crypto/openssl/crypto/sha/shatest.c (deleted) * freebsd/crypto/openssl/crypto/siphash/siphash.c (added) * freebsd/crypto/openssl/crypto/siphash/siphash_ameth.c (added) * freebsd/crypto/openssl/crypto/siphash/siphash_local.h (added) * freebsd/crypto/openssl/crypto/siphash/siphash_pmeth.c (added) * freebsd/crypto/openssl/crypto/sm2/sm2_crypt.c (added) * freebsd/crypto/openssl/crypto/sm2/sm2_err.c (added) * freebsd/crypto/openssl/crypto/sm2/sm2_pmeth.c (added) * freebsd/crypto/openssl/crypto/sm2/sm2_sign.c (added) * freebsd/crypto/openssl/crypto/sm3/m_sm3.c (added) * freebsd/crypto/openssl/crypto/sm3/sm3.c (added) * freebsd/crypto/openssl/crypto/sm3/sm3_locl.h (added) * freebsd/crypto/openssl/crypto/sm4/sm4.c (added) * freebsd/crypto/openssl/crypto/sparc_arch.h (modified) * freebsd/crypto/openssl/crypto/sparcv9cap.c (deleted) * freebsd/crypto/openssl/crypto/srp/srp.h (deleted) * freebsd/crypto/openssl/crypto/srp/srp_lcl.h (deleted) * freebsd/crypto/openssl/crypto/srp/srp_lib.c (modified) * freebsd/crypto/openssl/crypto/srp/srp_vfy.c (modified) * freebsd/crypto/openssl/crypto/srp/srptest.c (deleted) * freebsd/crypto/openssl/crypto/stack/safestack.h (deleted) * freebsd/crypto/openssl/crypto/stack/stack.c (modified) * freebsd/crypto/openssl/crypto/stack/stack.h (deleted) * freebsd/crypto/openssl/crypto/store/loader_file.c (added) * freebsd/crypto/openssl/crypto/store/store_err.c (added) * freebsd/crypto/openssl/crypto/store/store_init.c (added) * freebsd/crypto/openssl/crypto/store/store_lib.c (added) * freebsd/crypto/openssl/crypto/store/store_locl.h (added) * freebsd/crypto/openssl/crypto/store/store_register.c (added) * freebsd/crypto/openssl/crypto/store/store_strings.c (added) * freebsd/crypto/openssl/crypto/symhacks.h (deleted) * freebsd/crypto/openssl/crypto/threads/mttest.c (deleted) * freebsd/crypto/openssl/crypto/threads/th-lock.c (deleted) * freebsd/crypto/openssl/crypto/threads_none.c (added) * freebsd/crypto/openssl/crypto/threads_pthread.c (added) * freebsd/crypto/openssl/crypto/ts/ts_asn1.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_conf.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_err.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_lcl.h (added) * freebsd/crypto/openssl/crypto/ts/ts_lib.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_req_print.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_req_utils.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_rsp_print.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_rsp_sign.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_rsp_utils.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_rsp_verify.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_verify_ctx.c (modified) * freebsd/crypto/openssl/crypto/txt_db/txt_db.c (modified) * freebsd/crypto/openssl/crypto/txt_db/txt_db.h (deleted) * freebsd/crypto/openssl/crypto/ui/ui_compat.c (deleted) * freebsd/crypto/openssl/crypto/ui/ui_compat.h (deleted) * freebsd/crypto/openssl/crypto/ui/ui_err.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_locl.h (modified) * freebsd/crypto/openssl/crypto/ui/ui_null.c (added) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_util.c (modified) * freebsd/crypto/openssl/crypto/uid.c (modified) * freebsd/crypto/openssl/crypto/vms_rms.h (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_block.c (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_dgst.c (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_locl.h (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_test.c (deleted) * freebsd/crypto/openssl/crypto/x509/by_dir.c (modified) * freebsd/crypto/openssl/crypto/x509/by_file.c (modified) * freebsd/crypto/openssl/crypto/x509/t_crl.c (added) * freebsd/crypto/openssl/crypto/x509/t_req.c (added) * freebsd/crypto/openssl/crypto/x509/t_x509.c (added) * freebsd/crypto/openssl/crypto/x509/verify_extra_test.c (deleted) * freebsd/crypto/openssl/crypto/x509/vpm_int.h (deleted) * freebsd/crypto/openssl/crypto/x509/x509_att.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_cmp.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_d2.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_def.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_err.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_ext.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lcl.h (added) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_meth.c (added) * freebsd/crypto/openssl/crypto/x509/x509_obj.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_r2x.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_req.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_set.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_trs.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_txt.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_v3.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vpm.c (modified) * freebsd/crypto/openssl/crypto/x509/x509cset.c (modified) * freebsd/crypto/openssl/crypto/x509/x509name.c (modified) * freebsd/crypto/openssl/crypto/x509/x509rset.c (modified) * freebsd/crypto/openssl/crypto/x509/x509spki.c (modified) * freebsd/crypto/openssl/crypto/x509/x509type.c (modified) * freebsd/crypto/openssl/crypto/x509/x_all.c (modified) * freebsd/crypto/openssl/crypto/x509/x_attrib.c (added) * freebsd/crypto/openssl/crypto/x509/x_crl.c (moved) * freebsd/crypto/openssl/crypto/x509/x_exten.c (added) * freebsd/crypto/openssl/crypto/x509/x_name.c (moved) * freebsd/crypto/openssl/crypto/x509/x_pubkey.c (moved) * freebsd/crypto/openssl/crypto/x509/x_req.c (added) * freebsd/crypto/openssl/crypto/x509/x_x509.c (moved) * freebsd/crypto/openssl/crypto/x509/x_x509a.c (added) * freebsd/crypto/openssl/crypto/x509v3/ext_dat.h (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_cache.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_data.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_int.h (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_lib.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_map.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_node.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_tree.c (modified) * freebsd/crypto/openssl/crypto/x509v3/standard_exts.h (added) * freebsd/crypto/openssl/crypto/x509v3/tabtest.c (deleted) * freebsd/crypto/openssl/crypto/x509v3/v3_addr.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_admis.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_admis.h (added) * freebsd/crypto/openssl/crypto/x509v3/v3_akey.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_akeya.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_asid.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_bcons.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_bitst.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_conf.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_cpols.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_crld.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_enum.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_extku.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_genn.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_ia5.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_info.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_int.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_lib.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_ncons.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_pci.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_pcia.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_pcons.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_pku.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_pmaps.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_prn.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_scts.c (deleted) * freebsd/crypto/openssl/crypto/x509v3/v3_skey.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_sxnet.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_tlsf.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_utl.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3err.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3nametest.c (deleted) * freebsd/crypto/openssl/crypto/x509v3/v3prin.c (deleted) * freebsd/crypto/openssl/e_os.h (modified) * freebsd/crypto/openssl/e_os2.h (deleted) * freebsd/crypto/openssl/engines/ccgost/e_gost_err.c (deleted) * freebsd/crypto/openssl/engines/ccgost/e_gost_err.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gost2001.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost2001_keyx.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost2001_keyx.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gost89.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost89.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gost94_keyx.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_ameth.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_asn1.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_crypt.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_ctl.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_eng.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_keywrap.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_keywrap.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_lcl.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_md.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_params.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_params.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_pmeth.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gost_sign.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gosthash.c (deleted) * freebsd/crypto/openssl/engines/ccgost/gosthash.h (deleted) * freebsd/crypto/openssl/engines/ccgost/gostsum.c (deleted) * freebsd/crypto/openssl/engines/e_4758cca.c (deleted) * freebsd/crypto/openssl/engines/e_4758cca_err.c (deleted) * freebsd/crypto/openssl/engines/e_4758cca_err.h (deleted) * freebsd/crypto/openssl/engines/e_aep.c (deleted) * freebsd/crypto/openssl/engines/e_aep_err.c (deleted) * freebsd/crypto/openssl/engines/e_aep_err.h (deleted) * freebsd/crypto/openssl/engines/e_afalg.c (added) * freebsd/crypto/openssl/engines/e_afalg.h (added) * freebsd/crypto/openssl/engines/e_afalg_err.c (added) * freebsd/crypto/openssl/engines/e_afalg_err.h (added) * freebsd/crypto/openssl/engines/e_atalla.c (deleted) * freebsd/crypto/openssl/engines/e_atalla_err.c (deleted) * freebsd/crypto/openssl/engines/e_atalla_err.h (deleted) * freebsd/crypto/openssl/engines/e_capi.c (modified) * freebsd/crypto/openssl/engines/e_capi_err.c (modified) * freebsd/crypto/openssl/engines/e_capi_err.h (modified) * freebsd/crypto/openssl/engines/e_chil.c (deleted) * freebsd/crypto/openssl/engines/e_chil_err.c (deleted) * freebsd/crypto/openssl/engines/e_chil_err.h (deleted) * freebsd/crypto/openssl/engines/e_cswift.c (deleted) * freebsd/crypto/openssl/engines/e_cswift_err.c (deleted) * freebsd/crypto/openssl/engines/e_cswift_err.h (deleted) * freebsd/crypto/openssl/engines/e_dasync.c (added) * freebsd/crypto/openssl/engines/e_dasync_err.c (added) * freebsd/crypto/openssl/engines/e_dasync_err.h (added) * freebsd/crypto/openssl/engines/e_gmp.c (deleted) * freebsd/crypto/openssl/engines/e_gmp_err.c (deleted) * freebsd/crypto/openssl/engines/e_gmp_err.h (deleted) * freebsd/crypto/openssl/engines/e_nuron.c (deleted) * freebsd/crypto/openssl/engines/e_nuron_err.c (deleted) * freebsd/crypto/openssl/engines/e_nuron_err.h (deleted) * freebsd/crypto/openssl/engines/e_ossltest.c (added) * freebsd/crypto/openssl/engines/e_ossltest_err.c (added) * freebsd/crypto/openssl/engines/e_ossltest_err.h (added) * freebsd/crypto/openssl/engines/e_padlock.c (modified) * freebsd/crypto/openssl/engines/e_sureware.c (deleted) * freebsd/crypto/openssl/engines/e_sureware_err.c (deleted) * freebsd/crypto/openssl/engines/e_sureware_err.h (deleted) * freebsd/crypto/openssl/engines/e_ubsec.c (deleted) * freebsd/crypto/openssl/engines/e_ubsec_err.c (deleted) * freebsd/crypto/openssl/engines/e_ubsec_err.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/aep.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/atalla.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/cswift.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/hw_4758_cca.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/hw_ubsec.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/hwcryptohook.h (deleted) * freebsd/crypto/openssl/engines/vendor_defns/sureware.h (deleted) * freebsd/crypto/openssl/include/internal/bio.h (added) * freebsd/crypto/openssl/include/internal/comp.h (added) * freebsd/crypto/openssl/include/internal/conf.h (added) * freebsd/crypto/openssl/include/internal/constant_time_locl.h (added) * freebsd/crypto/openssl/include/internal/cryptlib.h (added) * freebsd/crypto/openssl/include/internal/dane.h (added) * freebsd/crypto/openssl/include/internal/dso.h (added) * freebsd/crypto/openssl/include/internal/dsoerr.h (added) * freebsd/crypto/openssl/include/internal/err.h (added) * freebsd/crypto/openssl/include/internal/nelem.h (added) * freebsd/crypto/openssl/include/internal/numbers.h (added) * freebsd/crypto/openssl/include/internal/o_dir.h (moved) * freebsd/crypto/openssl/include/internal/o_str.h (added) * freebsd/crypto/openssl/include/internal/refcount.h (added) * freebsd/crypto/openssl/include/internal/sockets.h (added) * freebsd/crypto/openssl/include/internal/sslconf.h (added) * freebsd/crypto/openssl/include/internal/thread_once.h (added) * freebsd/crypto/openssl/include/internal/tsan_assist.h (added) * freebsd/crypto/openssl/include/openssl/aes.h (added) * freebsd/crypto/openssl/include/openssl/asn1.h (added) * freebsd/crypto/openssl/include/openssl/asn1_mac.h (added) * freebsd/crypto/openssl/include/openssl/asn1err.h (added) * freebsd/crypto/openssl/include/openssl/asn1t.h (moved) * freebsd/crypto/openssl/include/openssl/async.h (added) * freebsd/crypto/openssl/include/openssl/asyncerr.h (added) * freebsd/crypto/openssl/include/openssl/bio.h (moved) * freebsd/crypto/openssl/include/openssl/bioerr.h (added) * freebsd/crypto/openssl/include/openssl/blowfish.h (added) * freebsd/crypto/openssl/include/openssl/bn.h (added) * freebsd/crypto/openssl/include/openssl/bnerr.h (added) * freebsd/crypto/openssl/include/openssl/buffer.h (added) * freebsd/crypto/openssl/include/openssl/buffererr.h (added) * freebsd/crypto/openssl/include/openssl/camellia.h (moved) * freebsd/crypto/openssl/include/openssl/cast.h (added) * freebsd/crypto/openssl/include/openssl/cmac.h (added) * freebsd/crypto/openssl/include/openssl/cms.h (moved) * freebsd/crypto/openssl/include/openssl/cmserr.h (added) * freebsd/crypto/openssl/include/openssl/comp.h (added) * freebsd/crypto/openssl/include/openssl/comperr.h (added) * freebsd/crypto/openssl/include/openssl/conf.h (added) * freebsd/crypto/openssl/include/openssl/conf_api.h (added) * freebsd/crypto/openssl/include/openssl/conferr.h (added) * freebsd/crypto/openssl/include/openssl/crypto.h (added) * freebsd/crypto/openssl/include/openssl/cryptoerr.h (added) * freebsd/crypto/openssl/include/openssl/ct.h (added) * freebsd/crypto/openssl/include/openssl/cterr.h (added) * freebsd/crypto/openssl/include/openssl/des.h (moved) * freebsd/crypto/openssl/include/openssl/dh.h (moved) * freebsd/crypto/openssl/include/openssl/dherr.h (added) * freebsd/crypto/openssl/include/openssl/dsa.h (added) * freebsd/crypto/openssl/include/openssl/dsaerr.h (added) * freebsd/crypto/openssl/include/openssl/dtls1.h (added) * freebsd/crypto/openssl/include/openssl/e_os2.h (added) * freebsd/crypto/openssl/include/openssl/ebcdic.h (moved) * freebsd/crypto/openssl/include/openssl/ec.h (moved) * freebsd/crypto/openssl/include/openssl/ecdh.h (added) * freebsd/crypto/openssl/include/openssl/ecdsa.h (added) * freebsd/crypto/openssl/include/openssl/ecerr.h (added) * freebsd/crypto/openssl/include/openssl/engine.h (moved) * freebsd/crypto/openssl/include/openssl/engineerr.h (added) * freebsd/crypto/openssl/include/openssl/err.h (added) * freebsd/crypto/openssl/include/openssl/evp.h (moved) * freebsd/crypto/openssl/include/openssl/evperr.h (added) * freebsd/crypto/openssl/include/openssl/hmac.h (added) * freebsd/crypto/openssl/include/openssl/idea.h (added) * freebsd/crypto/openssl/include/openssl/kdf.h (added) * freebsd/crypto/openssl/include/openssl/kdferr.h (added) * freebsd/crypto/openssl/include/openssl/lhash.h (added) * freebsd/crypto/openssl/include/openssl/md2.h (added) * freebsd/crypto/openssl/include/openssl/md4.h (added) * freebsd/crypto/openssl/include/openssl/md5.h (added) * freebsd/crypto/openssl/include/openssl/mdc2.h (added) * freebsd/crypto/openssl/include/openssl/modes.h (moved) * freebsd/crypto/openssl/include/openssl/obj_mac.h (moved) * freebsd/crypto/openssl/include/openssl/objects.h (added) * freebsd/crypto/openssl/include/openssl/objectserr.h (added) * freebsd/crypto/openssl/include/openssl/ocsp.h (added) * freebsd/crypto/openssl/include/openssl/ocsperr.h (added) * freebsd/crypto/openssl/include/openssl/opensslconf.h (added) * freebsd/crypto/openssl/include/openssl/opensslv.h (moved) * freebsd/crypto/openssl/include/openssl/ossl_typ.h (moved) * freebsd/crypto/openssl/include/openssl/pem.h (moved) * freebsd/crypto/openssl/include/openssl/pem2.h (added) * freebsd/crypto/openssl/include/openssl/pemerr.h (added) * freebsd/crypto/openssl/include/openssl/pkcs12.h (added) * freebsd/crypto/openssl/include/openssl/pkcs12err.h (added) * freebsd/crypto/openssl/include/openssl/pkcs7.h (moved) * freebsd/crypto/openssl/include/openssl/pkcs7err.h (added) * freebsd/crypto/openssl/include/openssl/rand.h (added) * freebsd/crypto/openssl/include/openssl/rand_drbg.h (added) * freebsd/crypto/openssl/include/openssl/randerr.h (added) * freebsd/crypto/openssl/include/openssl/rc2.h (added) * freebsd/crypto/openssl/include/openssl/rc4.h (added) * freebsd/crypto/openssl/include/openssl/rc5.h (added) * freebsd/crypto/openssl/include/openssl/ripemd.h (added) * freebsd/crypto/openssl/include/openssl/rsa.h (added) * freebsd/crypto/openssl/include/openssl/rsaerr.h (added) * freebsd/crypto/openssl/include/openssl/safestack.h (added) * freebsd/crypto/openssl/include/openssl/seed.h (moved) * freebsd/crypto/openssl/include/openssl/sha.h (added) * freebsd/crypto/openssl/include/openssl/srp.h (added) * freebsd/crypto/openssl/include/openssl/srtp.h (added) * freebsd/crypto/openssl/include/openssl/ssl.h (added) * freebsd/crypto/openssl/include/openssl/ssl2.h (added) * freebsd/crypto/openssl/include/openssl/ssl3.h (added) * freebsd/crypto/openssl/include/openssl/sslerr.h (added) * freebsd/crypto/openssl/include/openssl/stack.h (added) * freebsd/crypto/openssl/include/openssl/store.h (added) * freebsd/crypto/openssl/include/openssl/storeerr.h (added) * freebsd/crypto/openssl/include/openssl/symhacks.h (added) * freebsd/crypto/openssl/include/openssl/tls1.h (added) * freebsd/crypto/openssl/include/openssl/ts.h (moved) * freebsd/crypto/openssl/include/openssl/tserr.h (added) * freebsd/crypto/openssl/include/openssl/txt_db.h (added) * freebsd/crypto/openssl/include/openssl/ui.h (moved) * freebsd/crypto/openssl/include/openssl/uierr.h (added) * freebsd/crypto/openssl/include/openssl/whrlpool.h (moved) * freebsd/crypto/openssl/include/openssl/x509.h (moved) * freebsd/crypto/openssl/include/openssl/x509_vfy.h (moved) * freebsd/crypto/openssl/include/openssl/x509err.h (added) * freebsd/crypto/openssl/include/openssl/x509v3.h (moved) * freebsd/crypto/openssl/include/openssl/x509v3err.h (added) * freebsd/crypto/openssl/ssl/bad_dtls_test.c (deleted) * freebsd/crypto/openssl/ssl/bio_ssl.c (modified) * freebsd/crypto/openssl/ssl/clienthellotest.c (deleted) * freebsd/crypto/openssl/ssl/d1_clnt.c (deleted) * freebsd/crypto/openssl/ssl/d1_lib.c (modified) * freebsd/crypto/openssl/ssl/d1_meth.c (deleted) * freebsd/crypto/openssl/ssl/d1_msg.c (added) * freebsd/crypto/openssl/ssl/d1_pkt.c (deleted) * freebsd/crypto/openssl/ssl/d1_srtp.c (modified) * freebsd/crypto/openssl/ssl/d1_srvr.c (deleted) * freebsd/crypto/openssl/ssl/dtls1.h (deleted) * freebsd/crypto/openssl/ssl/kssl.c (deleted) * freebsd/crypto/openssl/ssl/kssl.h (deleted) * freebsd/crypto/openssl/ssl/kssl_lcl.h (deleted) * freebsd/crypto/openssl/ssl/methods.c (added) * freebsd/crypto/openssl/ssl/packet.c (added) * freebsd/crypto/openssl/ssl/packet_locl.h (added) * freebsd/crypto/openssl/ssl/pqueue.c (added) * freebsd/crypto/openssl/ssl/record/dtls1_bitmap.c (added) * freebsd/crypto/openssl/ssl/record/rec_layer_d1.c (added) * freebsd/crypto/openssl/ssl/record/rec_layer_s3.c (added) * freebsd/crypto/openssl/ssl/record/record.h (added) * freebsd/crypto/openssl/ssl/record/record_locl.h (added) * freebsd/crypto/openssl/ssl/record/ssl3_buffer.c (added) * freebsd/crypto/openssl/ssl/record/ssl3_record.c (added) * freebsd/crypto/openssl/ssl/record/ssl3_record_tls13.c (added) * freebsd/crypto/openssl/ssl/s23_clnt.c (deleted) * freebsd/crypto/openssl/ssl/s23_lib.c (deleted) * freebsd/crypto/openssl/ssl/s23_meth.c (deleted) * freebsd/crypto/openssl/ssl/s23_pkt.c (deleted) * freebsd/crypto/openssl/ssl/s23_srvr.c (deleted) * freebsd/crypto/openssl/ssl/s2_clnt.c (deleted) * freebsd/crypto/openssl/ssl/s2_enc.c (deleted) * freebsd/crypto/openssl/ssl/s2_lib.c (deleted) * freebsd/crypto/openssl/ssl/s2_meth.c (deleted) * freebsd/crypto/openssl/ssl/s2_pkt.c (deleted) * freebsd/crypto/openssl/ssl/s2_srvr.c (deleted) * freebsd/crypto/openssl/ssl/s3_both.c (deleted) * freebsd/crypto/openssl/ssl/s3_cbc.c (modified) * freebsd/crypto/openssl/ssl/s3_clnt.c (deleted) * freebsd/crypto/openssl/ssl/s3_enc.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_meth.c (deleted) * freebsd/crypto/openssl/ssl/s3_msg.c (added) * freebsd/crypto/openssl/ssl/s3_pkt.c (deleted) * freebsd/crypto/openssl/ssl/s3_srvr.c (deleted) * freebsd/crypto/openssl/ssl/srtp.h (deleted) * freebsd/crypto/openssl/ssl/ssl.h (deleted) * freebsd/crypto/openssl/ssl/ssl2.h (deleted) * freebsd/crypto/openssl/ssl/ssl23.h (deleted) * freebsd/crypto/openssl/ssl/ssl3.h (deleted) * freebsd/crypto/openssl/ssl/ssl_algs.c (deleted) * freebsd/crypto/openssl/ssl/ssl_asn1.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert_table.h (added) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_conf.c (modified) * freebsd/crypto/openssl/ssl/ssl_err.c (modified) * freebsd/crypto/openssl/ssl/ssl_err2.c (deleted) * freebsd/crypto/openssl/ssl/ssl_init.c (added) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/ssl_mcnf.c (added) * freebsd/crypto/openssl/ssl/ssl_rsa.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssl_stat.c (modified) * freebsd/crypto/openssl/ssl/ssl_txt.c (modified) * freebsd/crypto/openssl/ssl/ssl_utst.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (deleted) * freebsd/crypto/openssl/ssl/sslv2conftest.c (deleted) * freebsd/crypto/openssl/ssl/statem/extensions.c (added) * freebsd/crypto/openssl/ssl/statem/extensions_clnt.c (added) * freebsd/crypto/openssl/ssl/statem/extensions_cust.c (added) * freebsd/crypto/openssl/ssl/statem/extensions_srvr.c (added) * freebsd/crypto/openssl/ssl/statem/statem.c (added) * freebsd/crypto/openssl/ssl/statem/statem.h (added) * freebsd/crypto/openssl/ssl/statem/statem_clnt.c (added) * freebsd/crypto/openssl/ssl/statem/statem_dtls.c (moved) * freebsd/crypto/openssl/ssl/statem/statem_lib.c (added) * freebsd/crypto/openssl/ssl/statem/statem_locl.h (added) * freebsd/crypto/openssl/ssl/statem/statem_srvr.c (added) * freebsd/crypto/openssl/ssl/t1_clnt.c (deleted) * freebsd/crypto/openssl/ssl/t1_enc.c (modified) * freebsd/crypto/openssl/ssl/t1_ext.c (deleted) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/t1_meth.c (deleted) * freebsd/crypto/openssl/ssl/t1_reneg.c (deleted) * freebsd/crypto/openssl/ssl/t1_srvr.c (deleted) * freebsd/crypto/openssl/ssl/t1_trce.c (modified) * freebsd/crypto/openssl/ssl/tls1.h (deleted) * freebsd/crypto/openssl/ssl/tls13_enc.c (added) * freebsd/crypto/openssl/ssl/tls_srp.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/nslexer.l (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sys/contrib/ck/src/ck_epoch.c (modified) * freebsd/sys/crypto/chacha20/_chacha.h (added) * freebsd/sys/crypto/chacha20/chacha.c (modified) * freebsd/sys/crypto/chacha20/chacha.h (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/e1000/igb_txrx.c (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/subr_ipsec.c (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/cryptosoft.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sys/_domainset.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/cons.h (modified) * freebsd/sys/sys/domainset.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/racct.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma_core.c (modified) * ipsec-tools/src/config.h (modified) * ipsec-tools/src/racoon/crypto_openssl.c (modified) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.c (deleted) * ipsec-tools/src/racoon/prsa_par_wrapper.c (modified) * ipsec-tools/src/racoon/rsalist.c (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-algorithm-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-cfparse_wrapper-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-cftoken_wrapper-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-handler-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-ipsec_doi-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-localconf-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-main-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-namespace.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-plog-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_tok_wrapper-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-strnames-data.h (modified) * ipsec-tools/src/setkey/rtems-bsd-setkey-data.h (modified) * ipsec-tools/src/setkey/rtems-bsd-setkey-namespace.h (modified) * ipsec-tools/src/setkey/rtems-bsd-setkey-parse_wrapper-data.h (modified) * ipsec-tools/src/setkey/rtems-bsd-setkey-setkey-data.h (modified) * ipsec-tools/src/setkey/rtems-bsd-setkey-token_wrapper-data.h (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/vm/vm_pagequeue.h (added) Update to FreeBSD head 2018-10-23 Git mirror commit ... Thu, 20 Sep 2018 12:27:17 GMT Christian Mauderer [61575f5] * libbsd.py (modified) * rtemsbsd/sys/dev/mii/ksz8091rnb_50MHz.c (added) Add PHY-driver for KSZ8091RNB with 50MHz. This adds a driver for ... Wed, 19 Sep 2018 06:22:14 GMT Sebastian Huber [b382502] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) fsl_sdhci.c: Port to RTEMS Update #3525. Mon, 24 Sep 2018 11:45:52 GMT Sebastian Huber [06dd40e] * freebsd/sys/arm/freescale/imx/imx_gpio.c (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) imx/imx_gpio.c: Port to RTEMS Update #3525. Tue, 25 Sep 2018 07:27:50 GMT Sebastian Huber [b42dea9] * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_autoconf.c (added) * libbsd.py (modified) * rtemsbsd/rtems/rtems-kernel-configintrhook.c (deleted) CONFIG_INTRHOOK(9): Port to RTEMS Some device drivers (e.g. MMC) ... Mon, 24 Sep 2018 06:01:19 GMT Sebastian Huber [7aba2a4] * libbsd.py (modified) ck: Install header files Update #3472. Wed, 12 Sep 2018 13:15:12 GMT Sebastian Huber [457b4fc] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/dev/ffec/if_ffec_mpc8xx.c (modified) if_ffec_mpc8xx: Port driver to libbsd Update #3523. Wed, 22 Aug 2018 12:59:50 GMT Sebastian Huber [3489e3b] * Makefile.todo (modified) * freebsd-org (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/wpa/src/ap/ap_config.h (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.c (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.h (modified) * freebsd/contrib/wpa/src/ap/hostapd.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11_auth.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11_shared.c (modified) * freebsd/contrib/wpa/src/ap/pmksa_cache_auth.h (modified) * freebsd/contrib/wpa/src/ap/sta_info.h (modified) * freebsd/contrib/wpa/src/ap/vlan.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_i.h (modified) * freebsd/contrib/wpa/src/common/ctrl_iface_common.c (added) * freebsd/contrib/wpa/src/common/ctrl_iface_common.h (added) * freebsd/contrib/wpa/src/common/defs.h (modified) * freebsd/contrib/wpa/src/common/eapol_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.c (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_defs.h (modified) * freebsd/contrib/wpa/src/common/qca-vendor.h (modified) * freebsd/contrib/wpa/src/common/sae.h (modified) * freebsd/contrib/wpa/src/common/version.h (modified) * freebsd/contrib/wpa/src/common/wpa_common.c (modified) * freebsd/contrib/wpa/src/common/wpa_common.h (modified) * freebsd/contrib/wpa/src/common/wpa_ctrl.h (modified) * freebsd/contrib/wpa/src/crypto/aes-omac1.c (modified) * freebsd/contrib/wpa/src/crypto/crypto.h (modified) * freebsd/contrib/wpa/src/crypto/crypto_openssl.c (modified) * freebsd/contrib/wpa/src/crypto/ms_funcs.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-internal.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-prf.c (modified) * freebsd/contrib/wpa/src/crypto/sha256.h (modified) * freebsd/contrib/wpa/src/crypto/tls.h (modified) * freebsd/contrib/wpa/src/crypto/tls_internal.c (modified) * freebsd/contrib/wpa/src/drivers/driver.h (modified) * freebsd/contrib/wpa/src/drivers/driver_bsd.c (modified) * freebsd/contrib/wpa/src/drivers/driver_common.c (modified) * freebsd/contrib/wpa/src/drivers/driver_ndis.c (modified) * freebsd/contrib/wpa/src/drivers/driver_nl80211.h (modified) * freebsd/contrib/wpa/src/drivers/driver_wired.c (modified) * freebsd/contrib/wpa/src/drivers/drivers.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_config.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_gtc.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_i.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_leap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_md5.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_methods.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_methods.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_otp.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_peap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_psk.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_ttls.c (modified) * freebsd/contrib/wpa/src/eap_server/eap_methods.h (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c (modified) * freebsd/contrib/wpa/src/p2p/p2p.h (modified) * freebsd/contrib/wpa/src/radius/radius.h (modified) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c (modified) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h (modified) * freebsd/contrib/wpa/src/rsn_supp/preauth.c (modified) * freebsd/contrib/wpa/src/rsn_supp/preauth.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c (modified) * freebsd/contrib/wpa/src/tls/tlsv1_client.h (modified) * freebsd/contrib/wpa/src/tls/tlsv1_cred.h (modified) * freebsd/contrib/wpa/src/utils/common.c (modified) * freebsd/contrib/wpa/src/utils/common.h (modified) * freebsd/contrib/wpa/src/utils/eloop.c (modified) * freebsd/contrib/wpa/src/utils/eloop.h (modified) * freebsd/contrib/wpa/src/utils/module_tests.h (added) * freebsd/contrib/wpa/src/utils/os.h (modified) * freebsd/contrib/wpa/src/utils/os_unix.c (modified) * freebsd/contrib/wpa/src/utils/platform.h (modified) * freebsd/contrib/wpa/src/utils/trace.h (modified) * freebsd/contrib/wpa/src/utils/wpa_debug.c (modified) * freebsd/contrib/wpa/src/utils/wpabuf.c (modified) * freebsd/contrib/wpa/src/utils/wpabuf.h (modified) * freebsd/contrib/wpa/src/wps/wps.c (modified) * freebsd/contrib/wpa/src/wps/wps.h (modified) * freebsd/contrib/wpa/src/wps/wps_attr_build.c (modified) * freebsd/contrib/wpa/src/wps/wps_attr_parse.c (modified) * freebsd/contrib/wpa/src/wps/wps_attr_process.c (modified) * freebsd/contrib/wpa/src/wps/wps_common.c (modified) * freebsd/contrib/wpa/src/wps/wps_defs.h (modified) * freebsd/contrib/wpa/src/wps/wps_enrollee.c (modified) * freebsd/contrib/wpa/src/wps/wps_i.h (modified) * freebsd/contrib/wpa/src/wps/wps_registrar.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp.h (modified) * freebsd/contrib/wpa/src/wps/wps_upnp_i.h (modified) * freebsd/contrib/wpa/src/wps/wps_upnp_ssdp.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp_web.c (modified) * freebsd/contrib/wpa/wpa_supplicant/ap.h (modified) * freebsd/contrib/wpa/wpa_supplicant/autoscan.h (modified) * freebsd/contrib/wpa/wpa_supplicant/bgscan.h (modified) * freebsd/contrib/wpa/wpa_supplicant/binder/binder.h (added) * freebsd/contrib/wpa/wpa_supplicant/bss.c (modified) * freebsd/contrib/wpa/wpa_supplicant/bss.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config_file.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config_ssid.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface_unix.c (modified) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_new.h (modified) * freebsd/contrib/wpa/wpa_supplicant/driver_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/events.c (modified) * freebsd/contrib/wpa/wpa_supplicant/gas_query.c (modified) * freebsd/contrib/wpa/wpa_supplicant/gas_query.h (modified) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ibss_rsn.h (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.c (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.h (modified) * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * freebsd/contrib/wpa/wpa_supplicant/mesh.h (modified) * freebsd/contrib/wpa/wpa_supplicant/mesh_mpm.h (modified) * freebsd/contrib/wpa/wpa_supplicant/mesh_rsn.h (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.h (modified) * freebsd/contrib/wpa/wpa_supplicant/offchannel.c (modified) * freebsd/contrib/wpa/wpa_supplicant/p2p_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/scan.c (modified) * freebsd/contrib/wpa/wpa_supplicant/scan.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wmm_ac.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.h (modified) * freebsd/crypto/openssl/crypto/asn1/a_bool.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_object.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strex.c (modified) * freebsd/crypto/openssl/crypto/asn1/ameth_lib.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1.h (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_err.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_enc.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_log.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (modified) * freebsd/crypto/openssl/crypto/bn/bn.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_div.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_gf2m.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lcl.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mod.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_sqr.c (modified) * freebsd/crypto/openssl/crypto/bn_int.h (added) * freebsd/crypto/openssl/crypto/conf/conf_api.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa.h (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_err.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecdsatest.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_lib.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_asnmth.c (modified) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pem/pem.h (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pk8.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pkey.c (modified) * freebsd/crypto/openssl/crypto/pem/pvkfmt.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_asn.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_eay.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_sign.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ssl.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_cmp.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/ssl/d1_both.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl.h (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/t1_trce.c (modified) * freebsd/include/nl_types.h (added) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libcapsicum/capsicum_helpers.h (added) * freebsd/lib/libcasper/libcasper/libcasper.h (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.h (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl_altq.c (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/pfctl/pfctl_parser.h (modified) * freebsd/sbin/pfctl/pfctl_qstats.c (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-parse-data.h (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/mmc/mmc.h (modified) * freebsd/sys/contrib/ck/include/ck_pr.h (modified) * freebsd/sys/contrib/ck/include/ck_queue.h (modified) * freebsd/sys/contrib/ck/include/gcc/ppc/ck_pr.h (modified) * freebsd/sys/contrib/ck/include/gcc/x86/ck_pr.h (modified) * freebsd/sys/contrib/ck/include/gcc/x86_64/ck_pr.h (modified) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna32.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_verify/sodium/verify.c (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_onetimeauth_poly1305.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_verify_16.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_verify_32.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_verify_64.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/export.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/private/common.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/private/implementations.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/randombytes.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/runtime.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/utils.h (added) * freebsd/sys/crypto/chacha20/chacha.c (modified) * freebsd/sys/crypto/chacha20/chacha.h (modified) * freebsd/sys/crypto/libsodium/utils.c (added) * freebsd/sys/crypto/sha2/sha224.h (added) * freebsd/sys/crypto/sha2/sha256c.c (modified) * freebsd/sys/crypto/sha2/sha512c.c (modified) * freebsd/sys/crypto/skein/skein.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev.h (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/evdev/input-event-codes.h (modified) * freebsd/sys/dev/evdev/input.h (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/kbd/kbdreg.h (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_subr.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au.h (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/net/altq/altq.h (modified) * freebsd/sys/net/altq/altq_cbq.c (modified) * freebsd/sys/net/altq/altq_cbq.h (modified) * freebsd/sys/net/altq/altq_codel.c (modified) * freebsd/sys/net/altq/altq_codel.h (modified) * freebsd/sys/net/altq/altq_fairq.c (modified) * freebsd/sys/net/altq/altq_fairq.h (modified) * freebsd/sys/net/altq/altq_hfsc.c (modified) * freebsd/sys/net/altq/altq_hfsc.h (modified) * freebsd/sys/net/altq/altq_priq.c (modified) * freebsd/sys/net/altq/altq_priq.h (modified) * freebsd/sys/net/altq/altq_subr.c (modified) * freebsd/sys/net/altq/altq_var.h (modified) * freebsd/sys/net/altq/if_altq.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/route_var.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_gif.h (deleted) * freebsd/sys/netinet/in_kdtrace.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hpts.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_log_buf.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udplite.h (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/pf/if_pflog.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_altq.h (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/_cryptodev.h (added) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/cryptosoft.h (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_md5.c (modified) * freebsd/sys/opencrypto/xform_poly1305.c (added) * freebsd/sys/opencrypto/xform_poly1305.h (added) * freebsd/sys/opencrypto/xform_rmd160.c (modified) * freebsd/sys/opencrypto/xform_sha1.c (modified) * freebsd/sys/opencrypto/xform_sha2.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nv.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/sglist.h (added) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/cryptodev_if.h (modified) * rtemsbsd/include/rtems/bsd/local/sdhci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/sys/boot.h (added) * rtemsbsd/include/sys/epoch.h (modified) * rtemsbsd/include/sys/kpilite.h (added) * rtemsbsd/include/vm/vm_pager.h (added) * rtemsbsd/local/cryptodev_if.c (modified) * rtemsbsd/local/ifdi_if.c (modified) * rtemsbsd/local/sdhci_if.c (modified) * rtemsbsd/rtems/rtems-kernel-epoch.c (modified) * rtemsbsd/sys/arm/at91/at91_mci.c (moved) * rtemsbsd/sys/arm/at91/at91_mcireg.h (moved) * rtemsbsd/sys/arm/at91/at91_pdcreg.h (moved) * rtemsbsd/sys/arm/at91/at91reg.h (moved) * rtemsbsd/sys/arm/at91/at91var.h (moved) * testsuite/epoch01/test_main.c (modified) Update to FreeBSD head 2018-09-17 Git mirror commit ... Tue, 21 Aug 2018 11:47:02 GMT Sebastian Huber [bcdce02] * freebsd-org (modified) * freebsd/contrib/libpcap/bpf_image.c (modified) * freebsd/contrib/libpcap/diag-control.h (added) * freebsd/contrib/libpcap/etherent.c (modified) * freebsd/contrib/libpcap/extract.h (modified) * freebsd/contrib/libpcap/fad-getad.c (modified) * freebsd/contrib/libpcap/fad-helpers.c (deleted) * freebsd/contrib/libpcap/fmtutils.c (added) * freebsd/contrib/libpcap/fmtutils.h (added) * freebsd/contrib/libpcap/ftmacros.h (added) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/gencode.h (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/contrib/libpcap/grammar.y (modified) * freebsd/contrib/libpcap/ieee80211.h (modified) * freebsd/contrib/libpcap/inet.c (deleted) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/optimize.c (modified) * freebsd/contrib/libpcap/optimize.h (added) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-common.c (modified) * freebsd/contrib/libpcap/pcap-common.h (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libpcap/pcap-types.h (added) * freebsd/contrib/libpcap/pcap.c (modified) * freebsd/contrib/libpcap/pcap/can_socketcan.h (modified) * freebsd/contrib/libpcap/pcap/compiler-tests.h (added) * freebsd/contrib/libpcap/pcap/export-defs.h (deleted) * freebsd/contrib/libpcap/pcap/funcattrs.h (added) * freebsd/contrib/libpcap/pcap/namedb.h (modified) * freebsd/contrib/libpcap/pcap/nflog.h (modified) * freebsd/contrib/libpcap/pcap/pcap-inttypes.h (added) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/libpcap/pcap/sll.h (modified) * freebsd/contrib/libpcap/pcap/usb.h (modified) * freebsd/contrib/libpcap/portability.h (modified) * freebsd/contrib/libpcap/savefile.c (modified) * freebsd/contrib/libpcap/scanner.c (modified) * freebsd/contrib/libpcap/scanner.h (modified) * freebsd/contrib/libpcap/scanner.l (modified) * freebsd/contrib/libpcap/sf-pcap.c (modified) * freebsd/contrib/libpcap/sf-pcapng.c (moved) * freebsd/contrib/libpcap/sf-pcapng.h (moved) * freebsd/contrib/libpcap/varattrs.h (added) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/lib/libc/db/mpool/mpool-compat.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmedia-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-namespace.h (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl-data.h (modified) * freebsd/sys/arm/at91/at91_mci.c (modified) * freebsd/sys/arm/at91/at91_mcireg.h (modified) * freebsd/sys/arm/at91/at91_pdcreg.h (modified) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/ti_hwmods.c (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/contrib/ck/include/ck_backoff.h (added) * freebsd/sys/contrib/ck/include/ck_cc.h (added) * freebsd/sys/contrib/ck/include/ck_epoch.h (added) * freebsd/sys/contrib/ck/include/ck_limits.h (added) * freebsd/sys/contrib/ck/include/ck_md.h (added) * freebsd/sys/contrib/ck/include/ck_pr.h (added) * freebsd/sys/contrib/ck/include/ck_queue.h (added) * freebsd/sys/contrib/ck/include/ck_stack.h (added) * freebsd/sys/contrib/ck/include/ck_stdbool.h (added) * freebsd/sys/contrib/ck/include/ck_stddef.h (added) * freebsd/sys/contrib/ck/include/ck_stdint.h (added) * freebsd/sys/contrib/ck/include/ck_string.h (added) * freebsd/sys/contrib/ck/include/gcc/aarch64/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/arm/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/arm/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ck_cc.h (added) * freebsd/sys/contrib/ck/include/gcc/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc64/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc64/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/sparcv9/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/sparcv9/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86_64/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86_64/ck_pr.h (added) * freebsd/sys/contrib/ck/src/ck_epoch.c (added) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_i210.c (modified) * freebsd/sys/dev/e1000/e1000_i210.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/igb_txrx.c (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/evdev/uinput.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/fdt/fdt_common.h (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/ofw/openfirm.h (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/usb_rdesc.h (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.h (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.h (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (added) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/net/altq/altq_subr.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/dlt.h (modified) * freebsd/sys/net/fddi.h (deleted) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_arc.h (deleted) * freebsd/sys/net/if_arcsubr.c (deleted) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (deleted) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/netdump/netdump.h (added) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_hpts.h (added) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_offload.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/toecore.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/ck.h (added) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/cons.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * libbsd.py (modified) * linux/drivers/net/ethernet/freescale/fman/mac.c (modified) * rtemsbsd/include/machine/atomic.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/sys/disk_zone.h (added) * rtemsbsd/include/sys/epoch.h (added) * rtemsbsd/rtems/rtems-kernel-epoch.c (added) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/sys/arm/lpc/if_lpe.c (modified) * testsuite/epoch01/epoch01.py (added) * testsuite/epoch01/epoch01.scn (added) * testsuite/epoch01/test_main.c (added) Update to FreeBSD head 2018-06-01 Git mirror commit ... Tue, 21 Aug 2018 07:39:55 GMT Sebastian Huber [2df56db] * freebsd-org (modified) * freebsd/crypto/openssl/crypto/asn1/a_gentm.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_mbstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_object.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strex.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_utctm.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1.h (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_err.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_lib.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_par.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn_mime.c (modified) * freebsd/crypto/openssl/crypto/asn1/t_x509a.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_dec.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_prn.c (modified) * freebsd/crypto/openssl/crypto/bf/bftest.c (modified) * freebsd/crypto/openssl/crypto/bio/b_dump.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_cb.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_bio.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_conn.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_print.c (modified) * freebsd/crypto/openssl/crypto/bn/bntest.c (modified) * freebsd/crypto/openssl/crypto/bn/expspeed.c (modified) * freebsd/crypto/openssl/crypto/bn/exptest.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_def.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_mod.c (modified) * freebsd/crypto/openssl/crypto/des/ecb_enc.c (modified) * freebsd/crypto/openssl/crypto/des/fcrypt.c (modified) * freebsd/crypto/openssl/crypto/des/read_pwd.c (modified) * freebsd/crypto/openssl/crypto/des/set_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dhtest.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsatest.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_smpl.c (modified) * freebsd/crypto/openssl/crypto/ec/ectest.c (modified) * freebsd/crypto/openssl/crypto/ecdh/ecdhtest.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_table.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/err/err_prn.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_b64.c (modified) * freebsd/crypto/openssl/crypto/evp/digest.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_camellia.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_locl.h (modified) * freebsd/crypto/openssl/crypto/evp/evp_pbe.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_test.c (modified) * freebsd/crypto/openssl/crypto/evp/openbsd_hw.c (modified) * freebsd/crypto/openssl/crypto/evp/p5_crpt2.c (modified) * freebsd/crypto/openssl/crypto/hmac/hmac.c (modified) * freebsd/crypto/openssl/crypto/md4/md4.c (modified) * freebsd/crypto/openssl/crypto/mem_dbg.c (modified) * freebsd/crypto/openssl/crypto/o_init.c (modified) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/objects/o_names.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_dat.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pem/pem_info.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c (modified) * freebsd/crypto/openssl/crypto/rand/md_rand.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_egd.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_crpt.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pss.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_test.c (modified) * freebsd/crypto/openssl/crypto/srp/srp_grps.h (modified) * freebsd/crypto/openssl/crypto/threads/mttest.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_rsp_sign.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_txt.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_v3.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vpm.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_conf.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_info.c (modified) * freebsd/crypto/openssl/engines/ccgost/gost_eng.c (modified) * freebsd/crypto/openssl/engines/e_atalla.c (modified) * freebsd/crypto/openssl/ssl/bad_dtls_test.c (modified) * freebsd/crypto/openssl/ssl/d1_lib.c (modified) * freebsd/crypto/openssl/ssl/d1_pkt.c (modified) * freebsd/crypto/openssl/ssl/kssl.c (modified) * freebsd/crypto/openssl/ssl/s23_srvr.c (modified) * freebsd/crypto/openssl/ssl/s2_clnt.c (modified) * freebsd/crypto/openssl/ssl/s2_enc.c (modified) * freebsd/crypto/openssl/ssl/s2_lib.c (modified) * freebsd/crypto/openssl/ssl/s2_srvr.c (modified) * freebsd/crypto/openssl/ssl/s3_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/t1_enc.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/t1_trce.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/rpc/svc_dg.c (modified) * freebsd/lib/libcasper/libcasper/libcasper.h (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/errwarn.c (modified) * freebsd/sbin/dhclient/hash.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/dhclient/tables.c (modified) * freebsd/sbin/dhclient/tree.h (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/contrib/libb2/blake2-impl.h (added) * freebsd/sys/contrib/libb2/blake2.h (added) * freebsd/sys/contrib/libb2/blake2b-ref.c (added) * freebsd/sys/contrib/libb2/blake2s-ref.c (added) * freebsd/sys/crypto/blake2/blake2-sw.c (added) * freebsd/sys/crypto/chacha20/chacha-sw.c (added) * freebsd/sys/crypto/chacha20/chacha.c (added) * freebsd/sys/crypto/chacha20/chacha.h (added) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/gpio/gpiobusvar.h (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_subr.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_ridx.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/usb/controller/musb_otg.c (modified) * freebsd/sys/dev/usb/controller/musb_otg.h (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_upgt.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_iso88025subr.c (deleted) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/iso88025.h (deleted) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc.h (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/cc/cc_newreno.h (added) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/tcp_fastopen.h (added) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_log_buf.h (added) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf.h (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_enc.h (modified) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/disk.h (added) * freebsd/sys/sys/domainset.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/ktr_class.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-namespace.h (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/pci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/sys/kerneldump.h (added) * rtemsbsd/local/pci_if.c (modified) Update to FreeBSD head 2018-04-01 Git mirror commit ... Mon, 20 Aug 2018 13:53:03 GMT Sebastian Huber [18fa92c] * freebsd-org (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/addrtoname.h (modified) * freebsd/contrib/tcpdump/addrtostr.c (modified) * freebsd/contrib/tcpdump/af.c (modified) * freebsd/contrib/tcpdump/af.h (modified) * freebsd/contrib/tcpdump/checksum.c (modified) * freebsd/contrib/tcpdump/extract.h (modified) * freebsd/contrib/tcpdump/funcattrs.h (added) * freebsd/contrib/tcpdump/gmpls.c (modified) * freebsd/contrib/tcpdump/gmpls.h (modified) * freebsd/contrib/tcpdump/ip6.h (modified) * freebsd/contrib/tcpdump/ipproto.c (modified) * freebsd/contrib/tcpdump/ipproto.h (modified) * freebsd/contrib/tcpdump/l2vpn.c (modified) * freebsd/contrib/tcpdump/l2vpn.h (modified) * freebsd/contrib/tcpdump/netdissect-stdinc.h (modified) * freebsd/contrib/tcpdump/netdissect.h (modified) * freebsd/contrib/tcpdump/nlpid.c (modified) * freebsd/contrib/tcpdump/nlpid.h (modified) * freebsd/contrib/tcpdump/oui.c (modified) * freebsd/contrib/tcpdump/oui.h (modified) * freebsd/contrib/tcpdump/print-802_11.c (modified) * freebsd/contrib/tcpdump/print-802_15_4.c (modified) * freebsd/contrib/tcpdump/print-aodv.c (modified) * freebsd/contrib/tcpdump/print-arp.c (modified) * freebsd/contrib/tcpdump/print-atm.c (modified) * freebsd/contrib/tcpdump/print-beep.c (modified) * freebsd/contrib/tcpdump/print-bfd.c (modified) * freebsd/contrib/tcpdump/print-bgp.c (modified) * freebsd/contrib/tcpdump/print-bootp.c (modified) * freebsd/contrib/tcpdump/print-cfm.c (modified) * freebsd/contrib/tcpdump/print-chdlc.c (modified) * freebsd/contrib/tcpdump/print-cnfp.c (modified) * freebsd/contrib/tcpdump/print-decnet.c (modified) * freebsd/contrib/tcpdump/print-dhcp6.c (modified) * freebsd/contrib/tcpdump/print-domain.c (modified) * freebsd/contrib/tcpdump/print-eap.c (modified) * freebsd/contrib/tcpdump/print-eigrp.c (modified) * freebsd/contrib/tcpdump/print-esp.c (modified) * freebsd/contrib/tcpdump/print-ether.c (modified) * freebsd/contrib/tcpdump/print-fr.c (modified) * freebsd/contrib/tcpdump/print-frag6.c (modified) * freebsd/contrib/tcpdump/print-gre.c (modified) * freebsd/contrib/tcpdump/print-hncp.c (modified) * freebsd/contrib/tcpdump/print-icmp.c (modified) * freebsd/contrib/tcpdump/print-icmp6.c (modified) * freebsd/contrib/tcpdump/print-ip.c (modified) * freebsd/contrib/tcpdump/print-ip6.c (modified) * freebsd/contrib/tcpdump/print-ip6opts.c (modified) * freebsd/contrib/tcpdump/print-isakmp.c (modified) * freebsd/contrib/tcpdump/print-isoclns.c (modified) * freebsd/contrib/tcpdump/print-juniper.c (modified) * freebsd/contrib/tcpdump/print-l2tp.c (modified) * freebsd/contrib/tcpdump/print-ldp.c (modified) * freebsd/contrib/tcpdump/print-llc.c (modified) * freebsd/contrib/tcpdump/print-lldp.c (modified) * freebsd/contrib/tcpdump/print-lmp.c (modified) * freebsd/contrib/tcpdump/print-lspping.c (modified) * freebsd/contrib/tcpdump/print-m3ua.c (modified) * freebsd/contrib/tcpdump/print-mobility.c (modified) * freebsd/contrib/tcpdump/print-mpcp.c (modified) * freebsd/contrib/tcpdump/print-mpls.c (modified) * freebsd/contrib/tcpdump/print-mptcp.c (modified) * freebsd/contrib/tcpdump/print-nfs.c (modified) * freebsd/contrib/tcpdump/print-null.c (modified) * freebsd/contrib/tcpdump/print-olsr.c (modified) * freebsd/contrib/tcpdump/print-ospf6.c (modified) * freebsd/contrib/tcpdump/print-pgm.c (modified) * freebsd/contrib/tcpdump/print-pim.c (modified) * freebsd/contrib/tcpdump/print-pktap.c (modified) * freebsd/contrib/tcpdump/print-ppp.c (modified) * freebsd/contrib/tcpdump/print-radius.c (modified) * freebsd/contrib/tcpdump/print-resp.c (modified) * freebsd/contrib/tcpdump/print-ripng.c (modified) * freebsd/contrib/tcpdump/print-rpki-rtr.c (modified) * freebsd/contrib/tcpdump/print-rsvp.c (modified) * freebsd/contrib/tcpdump/print-rt6.c (modified) * freebsd/contrib/tcpdump/print-rx.c (modified) * freebsd/contrib/tcpdump/print-sip.c (modified) * freebsd/contrib/tcpdump/print-sl.c (modified) * freebsd/contrib/tcpdump/print-slow.c (modified) * freebsd/contrib/tcpdump/print-stp.c (modified) * freebsd/contrib/tcpdump/print-syslog.c (modified) * freebsd/contrib/tcpdump/print-telnet.c (modified) * freebsd/contrib/tcpdump/print-tftp.c (modified) * freebsd/contrib/tcpdump/print-vqp.c (modified) * freebsd/contrib/tcpdump/print-vtp.c (modified) * freebsd/contrib/tcpdump/print-wb.c (modified) * freebsd/contrib/tcpdump/print-zephyr.c (modified) * freebsd/contrib/tcpdump/print.c (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-addrtoname-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-namespace.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-tcpdump-data.h (modified) * freebsd/contrib/tcpdump/signature.c (modified) * freebsd/contrib/tcpdump/signature.h (modified) * freebsd/contrib/tcpdump/smbutil.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/tcpdump/util-print.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_i2d_fp.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_fat.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/symhacks.h (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_lib.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_scts.c (modified) * freebsd/crypto/openssl/ssl/bad_dtls_test.c (modified) * freebsd/crypto/openssl/ssl/s23_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/srtp.h (modified) * freebsd/crypto/openssl/ssl/ssl.h (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/err.h (modified) * freebsd/include/ifaddrs.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/res_update.h (modified) * freebsd/include/resolv.h (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/include/isc/list.h (modified) * freebsd/lib/libc/include/isc/platform.h (modified) * freebsd/lib/libc/include/reentrant.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/ev_streams.c (modified) * freebsd/lib/libc/isc/ev_timers.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/nameser/ns_netint.c (modified) * freebsd/lib/libc/nameser/ns_parse.c (modified) * freebsd/lib/libc/nameser/ns_print.c (modified) * freebsd/lib/libc/nameser/ns_samedomain.c (modified) * freebsd/lib/libc/nameser/ns_ttl.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/if_indextoname.c (modified) * freebsd/lib/libc/net/if_nameindex.c (modified) * freebsd/lib/libc/net/if_nametoindex.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_debug.h (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/lib/libcasper/libcasper/libcasper.h (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/inet.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/packet.c (modified) * freebsd/sbin/dhclient/parse.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/tree.c (modified) * freebsd/sbin/ifconfig/sfp.c (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl_optimize.c (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/mmc/mmc.h (modified) * freebsd/sys/cam/mmc/mmc_all.h (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/e1000/igb_txrx.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/altq/altq_hfsc.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/sff8472.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_crc32.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netpfil/pf/if_pflog.c (modified) * freebsd/sys/netpfil/pf/in4_cksum.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf.h (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/xform_userland.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/_domainset.h (added) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/domainset.h (added) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/nv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/rman.h (modified) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/tslog.h (added) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/watchdog.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/include/machine/bus.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/_limits.h (modified) * rtemsbsd/include/machine/atomic.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/rtems/bsd/local/device_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ifdi_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/vm/vm_phys.h (added) * rtemsbsd/rtems/rtems-kernel-malloc.c (modified) * rtemsbsd/sys/arm/lpc/if_lpe.c (moved) * rtemsbsd/sys/arm/lpc/if_lpereg.h (moved) * rtemsbsd/sys/arm/lpc/lpc_pwr.c (moved) * rtemsbsd/sys/arm/lpc/lpcreg.h (moved) * rtemsbsd/sys/arm/lpc/lpcvar.h (moved) Update to FreeBSD head 2018-02-01 Git mirror commit ... Thu, 09 Aug 2018 12:02:09 GMT Sebastian Huber [bb80d9d] * freebsd-org (modified) * freebsd/bin/hostname/hostname.c (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_bitstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_int.h (added) * freebsd/crypto/openssl/crypto/asn1/tasn_fre.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_new.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_name.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_pkey.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mul.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_x931p.c (modified) * freebsd/crypto/openssl/crypto/cryptlib.c (modified) * freebsd/crypto/openssl/crypto/dh/dh.h (modified) * freebsd/crypto/openssl/crypto/dh/dh_kdf.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_mont.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ecdh/ech_lib.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecs_lib.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c (modified) * freebsd/crypto/openssl/crypto/evp/evp.h (modified) * freebsd/crypto/openssl/crypto/evp/evp_key.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (modified) * freebsd/crypto/openssl/crypto/ex_data.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_vfy.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pk8.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pkey.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_kiss.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_dgst.c (modified) * freebsd/crypto/openssl/crypto/x509/by_dir.c (modified) * freebsd/crypto/openssl/crypto/x509/by_file.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_tree.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_addr.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_genn.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_ncons.c (modified) * freebsd/crypto/openssl/ssl/s23_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/tls1.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/db.h (modified) * freebsd/include/err.h (modified) * freebsd/include/mpool.h (modified) * freebsd/include/netconfig.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/nlist.h (modified) * freebsd/include/nsswitch.h (modified) * freebsd/include/resolv.h (modified) * freebsd/include/rpc/auth.h (modified) * freebsd/include/rpc/auth_des.h (modified) * freebsd/include/rpc/auth_kerb.h (modified) * freebsd/include/rpc/auth_unix.h (modified) * freebsd/include/rpc/clnt.h (modified) * freebsd/include/rpc/clnt_soc.h (modified) * freebsd/include/rpc/des.h (modified) * freebsd/include/rpc/des_crypt.h (modified) * freebsd/include/rpc/nettype.h (modified) * freebsd/include/rpc/pmap_clnt.h (modified) * freebsd/include/rpc/pmap_prot.h (modified) * freebsd/include/rpc/pmap_rmt.h (modified) * freebsd/include/rpc/raw.h (modified) * freebsd/include/rpc/rpc.h (modified) * freebsd/include/rpc/rpc_com.h (modified) * freebsd/include/rpc/rpc_msg.h (modified) * freebsd/include/rpc/rpcb_clnt.h (modified) * freebsd/include/rpc/rpcent.h (modified) * freebsd/include/rpc/rpcsec_gss.h (modified) * freebsd/include/rpc/svc.h (modified) * freebsd/include/rpc/svc_auth.h (modified) * freebsd/include/rpc/svc_dg.h (modified) * freebsd/include/rpc/svc_soc.h (modified) * freebsd/include/rpc/xdr.h (modified) * freebsd/include/rpcsvc/nis_tags.h (modified) * freebsd/include/rpcsvc/yp_prot.h (modified) * freebsd/include/rpcsvc/ypclnt.h (modified) * freebsd/include/sysexits.h (modified) * freebsd/lib/libbsdstat/bsdstat.c (modified) * freebsd/lib/libbsdstat/bsdstat.h (modified) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/btree/btree.h (modified) * freebsd/lib/libc/db/btree/extern.h (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/mpool/mpool-compat.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/extern.h (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/db/recno/recno.h (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/feature_present.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/nss_tls.h (modified) * freebsd/lib/libc/include/reentrant.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/gai_strerror.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getproto.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getprotoname.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/ip6opt.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/netdb_private.h (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nslexer.l (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/lib/libc/net/nsparser.y (modified) * freebsd/lib/libc/net/nss_backends.h (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/rthdr.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/net/vars.c (modified) * freebsd/lib/libc/posix1e/mac.c (modified) * freebsd/lib/libc/resolv/h_errno.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_state.c (modified) * freebsd/lib/libc/rpc/auth_des.c (modified) * freebsd/lib/libc/rpc/auth_none.c (modified) * freebsd/lib/libc/rpc/auth_unix.c (modified) * freebsd/lib/libc/rpc/authdes_prot.c (modified) * freebsd/lib/libc/rpc/authunix_prot.c (modified) * freebsd/lib/libc/rpc/bindresvport.c (modified) * freebsd/lib/libc/rpc/clnt_bcast.c (modified) * freebsd/lib/libc/rpc/clnt_dg.c (modified) * freebsd/lib/libc/rpc/clnt_generic.c (modified) * freebsd/lib/libc/rpc/clnt_perror.c (modified) * freebsd/lib/libc/rpc/clnt_raw.c (modified) * freebsd/lib/libc/rpc/clnt_simple.c (modified) * freebsd/lib/libc/rpc/clnt_vc.c (modified) * freebsd/lib/libc/rpc/crypt_client.c (modified) * freebsd/lib/libc/rpc/des_crypt.c (modified) * freebsd/lib/libc/rpc/des_soft.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/rpc/getnetpath.c (modified) * freebsd/lib/libc/rpc/getpublickey.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libc/rpc/getrpcport.c (modified) * freebsd/lib/libc/rpc/key_call.c (modified) * freebsd/lib/libc/rpc/key_prot_xdr.c (modified) * freebsd/lib/libc/rpc/mt_misc.h (modified) * freebsd/lib/libc/rpc/netname.c (modified) * freebsd/lib/libc/rpc/netnamer.c (modified) * freebsd/lib/libc/rpc/pmap_clnt.c (modified) * freebsd/lib/libc/rpc/pmap_getmaps.c (modified) * freebsd/lib/libc/rpc/pmap_getport.c (modified) * freebsd/lib/libc/rpc/pmap_prot.c (modified) * freebsd/lib/libc/rpc/pmap_prot2.c (modified) * freebsd/lib/libc/rpc/pmap_rmt.c (modified) * freebsd/lib/libc/rpc/rpc_callmsg.c (modified) * freebsd/lib/libc/rpc/rpc_com.h (modified) * freebsd/lib/libc/rpc/rpc_commondata.c (modified) * freebsd/lib/libc/rpc/rpc_dtablesize.c (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpc_prot.c (modified) * freebsd/lib/libc/rpc/rpc_soc.c (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/lib/libc/rpc/rpcb_prot.c (modified) * freebsd/lib/libc/rpc/rpcb_st_xdr.c (modified) * freebsd/lib/libc/rpc/rpcdname.c (modified) * freebsd/lib/libc/rpc/rpcsec_gss_stub.c (modified) * freebsd/lib/libc/rpc/rtime.c (modified) * freebsd/lib/libc/rpc/svc.c (modified) * freebsd/lib/libc/rpc/svc_auth.c (modified) * freebsd/lib/libc/rpc/svc_auth_des.c (modified) * freebsd/lib/libc/rpc/svc_auth_unix.c (modified) * freebsd/lib/libc/rpc/svc_dg.c (modified) * freebsd/lib/libc/rpc/svc_generic.c (modified) * freebsd/lib/libc/rpc/svc_raw.c (modified) * freebsd/lib/libc/rpc/svc_run.c (modified) * freebsd/lib/libc/rpc/svc_simple.c (modified) * freebsd/lib/libc/rpc/svc_vc.c (modified) * freebsd/lib/libc/stdio/fgetln.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libc/string/strsep.c (modified) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/lib/libc/xdr/xdr_array.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libc/xdr/xdr_mem.c (modified) * freebsd/lib/libc/xdr/xdr_rec.c (modified) * freebsd/lib/libc/xdr/xdr_reference.c (modified) * freebsd/lib/libc/xdr/xdr_sizeof.c (modified) * freebsd/lib/libc/xdr/xdr_stdio.c (modified) * freebsd/lib/libcasper/libcasper/libcasper.h (added) * freebsd/lib/libcasper/services/cap_dns/cap_dns.h (added) * freebsd/lib/libcasper/services/cap_syslog/cap_syslog.h (added) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat.h (modified) * freebsd/lib/libmemstat/memstat_all.c (modified) * freebsd/lib/libmemstat/memstat_internal.h (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/expand_number.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/lib/libutil/trimdomain.c (modified) * freebsd/sbin/dhclient/alloc.c (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/convert.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcp.h (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dhctoken.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/errwarn.c (modified) * freebsd/sbin/dhclient/hash.c (modified) * freebsd/sbin/dhclient/inet.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/packet.c (modified) * freebsd/sbin/dhclient/parse.c (modified) * freebsd/sbin/dhclient/tables.c (modified) * freebsd/sbin/dhclient/tree.c (modified) * freebsd/sbin/dhclient/tree.h (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/pf_print_state.c (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl.h (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/pfctl/pfctl_parser.h (modified) * freebsd/sbin/pfctl/pfctl_radix.c (modified) * freebsd/sbin/pfctl/pfctl_table.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/at91/at91_mci.c (modified) * freebsd/sys/arm/at91/at91_mcireg.h (modified) * freebsd/sys/arm/at91/at91_pdcreg.h (modified) * freebsd/sys/arm/at91/at91reg.h (modified) * freebsd/sys/arm/at91/at91var.h (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/arm/include/machine/in_cksum.h (modified) * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/if_lpereg.h (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/arm/lpc/lpcreg.h (modified) * freebsd/sys/arm/lpc/lpcvar.h (modified) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/am335x/am335x_scm.h (modified) * freebsd/sys/arm/ti/am335x/am335x_usbss.c (modified) * freebsd/sys/arm/ti/ti_cpuid.h (modified) * freebsd/sys/arm/ti/ti_prcm.c (modified) * freebsd/sys/arm/ti/ti_prcm.h (modified) * freebsd/sys/arm/ti/ti_scm.c (modified) * freebsd/sys/arm/ti/ti_scm.h (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/arm/ti/tivar.h (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.h (modified) * freebsd/sys/avr/include/machine/in_cksum.h (modified) * freebsd/sys/bfin/include/machine/in_cksum.h (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_debug.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_sim.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/cam_xpt_sim.h (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha1.h (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bce/if_bcefw.h (modified) * freebsd/sys/dev/bce/if_bcereg.h (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bfe/if_bfereg.h (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/bge/if_bgereg.h (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/cadence/if_cgem_hw.h (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/if_dcreg.h (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.h (modified) * freebsd/sys/dev/e1000/e1000_82540.c (modified) * freebsd/sys/dev/e1000/e1000_82541.c (modified) * freebsd/sys/dev/e1000/e1000_82541.h (modified) * freebsd/sys/dev/e1000/e1000_82542.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82543.h (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82571.h (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_api.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_i210.c (modified) * freebsd/sys/dev/e1000/e1000_i210.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_manage.c (modified) * freebsd/sys/dev/e1000/e1000_manage.h (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.h (modified) * freebsd/sys/dev/e1000/e1000_nvm.c (modified) * freebsd/sys/dev/e1000/e1000_nvm.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_phy.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/e1000_vf.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev.h (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/fdt/fdt_common.h (modified) * freebsd/sys/dev/fdt/simplebus.c (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/ffec/if_ffecreg.h (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/fxp/if_fxpreg.h (modified) * freebsd/sys/dev/fxp/if_fxpvar.h (modified) * freebsd/sys/dev/fxp/rcvbundl.h (modified) * freebsd/sys/dev/gpio/gpiobus.c (modified) * freebsd/sys/dev/gpio/gpiobusvar.h (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/kbd/kbdreg.h (modified) * freebsd/sys/dev/kbd/kbdtables.h (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/brgphyreg.h (modified) * freebsd/sys/dev/mii/e1000phy.c (modified) * freebsd/sys/dev/mii/e1000phyreg.h (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/icsphyreg.h (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii.h (modified) * freebsd/sys/dev/mii/mii_bitbang.c (modified) * freebsd/sys/dev/mii/mii_bitbang.h (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/mii/rgephy.c (modified) * freebsd/sys/dev/mii/rgephyreg.h (modified) * freebsd/sys/dev/mii/ukphy.c (modified) * freebsd/sys/dev/mii/ukphy_subr.c (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/mmc/mmcvar.h (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_pci.h (modified) * freebsd/sys/dev/ofw/ofwvar.h (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/ofw/openfirm.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/smc/if_smcreg.h (modified) * freebsd/sys/dev/smc/if_smcvar.h (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec.h (modified) * freebsd/sys/dev/tsec/if_tsec_fdt.c (modified) * freebsd/sys/dev/tsec/if_tsecreg.h (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.h (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) * freebsd/sys/dev/usb/controller/dwc_otgreg.h (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ehci.h (modified) * freebsd/sys/dev/usb/controller/ehcireg.h (modified) * freebsd/sys/dev/usb/controller/musb_otg.c (modified) * freebsd/sys/dev/usb/controller/musb_otg.h (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * freebsd/sys/dev/usb/controller/ohcireg.h (modified) * freebsd/sys/dev/usb/controller/uhcireg.h (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/controller/xhcireg.h (modified) * freebsd/sys/dev/usb/input/atp.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/input/usb_rdesc.h (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_auereg.h (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axereg.h (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_axgereg.h (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_cdcereg.h (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_cuereg.h (modified) * freebsd/sys/dev/usb/net/if_ipheth.c (modified) * freebsd/sys/dev/usb/net/if_iphethvar.h (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_kuefw.h (modified) * freebsd/sys/dev/usb/net/if_kuereg.h (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_mosreg.h (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_ruereg.h (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_smscreg.h (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_udavreg.h (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/ruephy.c (modified) * freebsd/sys/dev/usb/net/ruephyreg.h (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/ubsa.c (modified) * freebsd/sys/dev/usb/serial/ubser.c (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/ucycom.c (modified) * freebsd/sys/dev/usb/serial/ufoma.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/ugensa.c (modified) * freebsd/sys/dev/usb/serial/uipaq.c (modified) * freebsd/sys/dev/usb/serial/ulpt.c (modified) * freebsd/sys/dev/usb/serial/umcs.c (modified) * freebsd/sys/dev/usb/serial/umcs.h (modified) * freebsd/sys/dev/usb/serial/umct.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.h (modified) * freebsd/sys/dev/usb/serial/uvisor.c (modified) * freebsd/sys/dev/usb/serial/uvscom.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/ufm_ioctl.h (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_busdma.h (modified) * freebsd/sys/dev/usb/usb_cdc.h (modified) * freebsd/sys/dev/usb/usb_controller.h (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_core.h (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_debug.h (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_dev.h (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_dynamic.h (modified) * freebsd/sys/dev/usb/usb_endian.h (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_freebsd.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_generic.h (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_hub.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_mbuf.h (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_msctest.h (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_pf.h (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_process.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_request.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_transfer.h (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/usb_util.h (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/dev/usb/usbdi_util.h (modified) * freebsd/sys/dev/usb/usbhid.h (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_zydfw.h (modified) * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/h8300/include/machine/in_cksum.h (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/include/machine/_bus.h (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/in_cksum.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/isa/pnpvar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_hhook.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_khelp.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_bufring.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/lm32/include/machine/in_cksum.h (modified) * freebsd/sys/m32c/include/machine/in_cksum.h (modified) * freebsd/sys/m32r/include/machine/in_cksum.h (modified) * freebsd/sys/m68k/include/machine/in_cksum.h (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/mips/include/machine/in_cksum.h (modified) * freebsd/sys/mips/mips/in_cksum.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_buffer.h (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/bpf_zerocopy.h (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/bridgestp.h (modified) * freebsd/sys/net/fddi.h (modified) * freebsd/sys/net/firewire.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_enc.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_llc.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_pflog.h (modified) * freebsd/sys/net/if_pfsync.h (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tap.h (modified) * freebsd/sys/net/if_tapvar.h (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/ifq.h (modified) * freebsd/sys/net/iso88025.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/netisr_internal.h (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/radix_mpath.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_cb.h (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rss_config.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/sff8472.h (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net/slcompress.h (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_action.h (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.h (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_ageq.h (modified) * freebsd/sys/net80211/ieee80211_alq.h (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto.h (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_dfs.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_hostap.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_mesh.h (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_monitor.h (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_phy.h (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_power.h (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl.h (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.h (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.h (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.h (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_tdma.h (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_wds.h (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) * freebsd/sys/netinet/accf_data.c (modified) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc_module.h (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp.h (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_kdtrace.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_divert.h (modified) * freebsd/sys/netinet/ip_dummynet.h (modified) * freebsd/sys/netinet/ip_ecn.c (modified) * freebsd/sys/netinet/ip_ecn.h (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias.h (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/pim.h (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.h (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_crc32.h (modified) * freebsd/sys/netinet/sctp_dtrace_declare.h (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_lock_bsd.h (modified) * freebsd/sys/netinet/sctp_os.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_peeloff.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_timer.h (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_debug.h (modified) * freebsd/sys/netinet/tcp_fsm.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hostcache.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_lro.h (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_offload.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/tcpip.h (modified) * freebsd/sys/netinet/toecore.h (modified) * freebsd/sys/netinet/udp.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_ifattach.h (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_ecn.h (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_mroute.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6.h (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6.h (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/raw_ip6.h (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/send.h (modified) * freebsd/sys/netinet6/tcp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netipsec/ah.h (modified) * freebsd/sys/netipsec/esp.h (modified) * freebsd/sys/netipsec/ipcomp.h (modified) * freebsd/sys/netipsec/ipcomp_var.h (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/key_var.h (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/in4_cksum.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf.h (modified) * freebsd/sys/netpfil/pf/pf_altq.h (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_mtag.h (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_ruleset.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/nios2/include/machine/in_cksum.h (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/in_cksum.h (modified) * freebsd/sys/powerpc/include/machine/intr_machdep.h (modified) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/powerpc/powerpc/in_cksum.c (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sh/include/machine/in_cksum.h (modified) * freebsd/sys/sparc/include/machine/in_cksum.h (modified) * freebsd/sys/sparc64/include/machine/asi.h (modified) * freebsd/sys/sparc64/include/machine/cpufunc.h (modified) * freebsd/sys/sparc64/include/machine/in_cksum.h (modified) * freebsd/sys/sparc64/include/machine/pstate.h (modified) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sys/_bus_dma.h (modified) * freebsd/sys/sys/_callout.h (modified) * freebsd/sys/sys/_lock.h (modified) * freebsd/sys/sys/_lockmgr.h (modified) * freebsd/sys/sys/_mutex.h (modified) * freebsd/sys/sys/_null.h (modified) * freebsd/sys/sys/_pctrie.h (modified) * freebsd/sys/sys/_rmlock.h (modified) * freebsd/sys/sys/_rwlock.h (modified) * freebsd/sys/sys/_semaphore.h (modified) * freebsd/sys/sys/_sx.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/_unrhdr.h (modified) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/caprights.h (modified) * freebsd/sys/sys/condvar.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/cons.h (modified) * freebsd/sys/sys/counter.h (modified) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/fail.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/firmware.h (modified) * freebsd/sys/sys/gpio.h (modified) * freebsd/sys/sys/hash.h (modified) * freebsd/sys/sys/hhook.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/kenv.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/khelp.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/kthread.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/ktr_class.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/limits.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lock_profile.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/loginclass.h (modified) * freebsd/sys/sys/mac.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/module_khelp.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mqueue.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nlist_aout.h (modified) * freebsd/sys/sys/osd.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/racct.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rtprio.h (modified) * freebsd/sys/sys/runq.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/sdt.h (modified) * freebsd/sys/sys/selinfo.h (modified) * freebsd/sys/sys/serial.h (modified) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/sigio.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/sleepqueue.h (modified) * freebsd/sys/sys/slicer.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/stddef.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/timeet.h (modified) * freebsd/sys/sys/tree.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttydevsw.h (modified) * freebsd/sys/sys/ttydisc.h (modified) * freebsd/sys/sys/ttyhook.h (modified) * freebsd/sys/sys/ttyqueue.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/un.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/uuid.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/sys/watchdog.h (modified) * freebsd/sys/v850/include/machine/in_cksum.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * freebsd/sys/vm/uma_dbg.h (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/include/machine/bus.h (modified) * freebsd/sys/x86/include/machine/pci_cfgreg.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (modified) * freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.c (modified) * freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.h (modified) * libbsd.py (modified) * rtemsbsd/include/casper/cap_dns.h (added) * rtemsbsd/include/casper/cap_syslog.h (added) * rtemsbsd/include/libcasper.h (added) * rtemsbsd/include/machine/_kernel_lock.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) Update to FreeBSD head 2017-12-01 Git mirror commit ... Thu, 09 Aug 2018 11:04:41 GMT Sebastian Huber [e4a8065] * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/ti_cpuid.h (modified) * freebsd/sys/arm/ti/ti_scm.c (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/mmc/mmc.h (modified) * freebsd/sys/cam/mmc/mmc_sdio.h (deleted) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmc_subr.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/mmc/mmcvar.h (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_ridx.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_priv.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_var.h (modified) * freebsd/sys/dev/rtwn/rtl8192e/r92e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usbhid.h (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/crc32.c (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/udpencap.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/xform_aes_icm.c (modified) * freebsd/sys/opencrypto/xform_aes_xts.c (modified) * freebsd/sys/opencrypto/xform_blf.c (modified) * freebsd/sys/opencrypto/xform_cast5.c (modified) * freebsd/sys/opencrypto/xform_cml.c (modified) * freebsd/sys/opencrypto/xform_deflate.c (modified) * freebsd/sys/opencrypto/xform_des1.c (modified) * freebsd/sys/opencrypto/xform_des3.c (modified) * freebsd/sys/opencrypto/xform_gmac.c (modified) * freebsd/sys/opencrypto/xform_md5.c (modified) * freebsd/sys/opencrypto/xform_null.c (modified) * freebsd/sys/opencrypto/xform_rijndael.c (modified) * freebsd/sys/opencrypto/xform_rmd160.c (modified) * freebsd/sys/opencrypto/xform_sha1.c (modified) * freebsd/sys/opencrypto/xform_sha2.c (modified) * freebsd/sys/opencrypto/xform_skipjack.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/gpio.h (modified) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD head 2017-10-01 Git mirror commit ... Tue, 07 Aug 2018 12:56:50 GMT Sebastian Huber [c37f9fb] * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/libxo/libxo/xo.h (modified) * freebsd/contrib/libxo/libxo/xo_buf.h (modified) * freebsd/contrib/libxo/libxo/xo_encoder.c (modified) * freebsd/contrib/libxo/libxo/xo_encoder.h (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/lib/libc/rpc/rpcb_prot.c (modified) * freebsd/lib/libc/rpc/rpcb_st_xdr.c (modified) * freebsd/lib/libc/stdio/fgetln.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/mmc/mmc.h (added) * freebsd/sys/cam/mmc/mmc_all.h (added) * freebsd/sys/cam/mmc/mmc_bus.h (added) * freebsd/sys/cam/mmc/mmc_sdio.h (added) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev_mt.c (modified) * freebsd/sys/dev/evdev/evdev_private.h (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/evdev/input-event-codes.h (modified) * freebsd/sys/dev/evdev/input.h (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/evdev/uinput.h (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/mii/mii_fdt.c (added) * freebsd/sys/dev/mii/mii_fdt.h (added) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_ioctl.h (modified) * freebsd/sys/dev/mmc/mmc_private.h (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwnreg.h (modified) * freebsd/sys/dev/rtwn/if_rtwnvar.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_var.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_priv.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom_defs.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom_image.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_var.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/usb/controller/saf1761_otg.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_enc.h (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/sys/_pctrie.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/uuid.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/usr.bin/netstat/flowtable.c (deleted) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-namespace.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbr_if.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_mmccam.h (added) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/mmcbus_if.c (modified) * rtemsbsd/rtems/rtems-kernel-bus-dma.c (modified) Update to FreeBSD head 2017-08-01 Git mirror commit ... Tue, 07 Aug 2018 10:12:37 GMT Sebastian Huber [de261e0] * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/libxo/libxo/xo.h (modified) * freebsd/contrib/libxo/libxo/xo_buf.h (modified) * freebsd/contrib/libxo/libxo/xo_encoder.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/crypto/openssl/crypto/armcap.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_bitstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_digest.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_gentm.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strnid.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_utctm.c (modified) * freebsd/crypto/openssl/crypto/asn1/f_enum.c (modified) * freebsd/crypto/openssl/crypto/asn1/f_int.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_dec.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_new.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_long.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_name.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_cb.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_print.c (modified) * freebsd/crypto/openssl/crypto/comp/c_rle.c (modified) * freebsd/crypto/openssl/crypto/conf/conf.h (modified) * freebsd/crypto/openssl/crypto/conf/conf_def.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_err.c (modified) * freebsd/crypto/openssl/crypto/des/set_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh.h (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_asn1.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/eck_prn.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/err/err.h (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c (modified) * freebsd/crypto/openssl/crypto/evp/e_des3.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (modified) * freebsd/crypto/openssl/crypto/ex_data.c (modified) * freebsd/crypto/openssl/crypto/hmac/hm_pmeth.c (modified) * freebsd/crypto/openssl/crypto/mem.c (modified) * freebsd/crypto/openssl/crypto/o_dir.c (modified) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_mutl.c (modified) * freebsd/crypto/openssl/crypto/ppccap.c (modified) * freebsd/crypto/openssl/crypto/rand/md_rand.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pss.c (modified) * freebsd/crypto/openssl/crypto/srp/srp_vfy.c (modified) * freebsd/crypto/openssl/crypto/txt_db/txt_db.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_cpols.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_info.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/ssl/d1_both.c (modified) * freebsd/crypto/openssl/ssl/d1_clnt.c (modified) * freebsd/crypto/openssl/ssl/d1_pkt.c (modified) * freebsd/crypto/openssl/ssl/d1_srvr.c (modified) * freebsd/crypto/openssl/ssl/s23_clnt.c (modified) * freebsd/crypto/openssl/ssl/s23_srvr.c (modified) * freebsd/crypto/openssl/ssl/s3_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_enc.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/ssl_rsa.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/t1_ext.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/rpc/svc.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/parse.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/crypto/des/des_enc.c (modified) * freebsd/sys/crypto/des/des_setkey.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/libkern/crc32.c (modified) * freebsd/sys/net/altq/altq_rio.c (modified) * freebsd/sys/net/altq/altq_rmclass.h (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_kdtrace.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) Update to FreeBSD head 2017-06-01 Git mirror commit ... Wed, 19 Sep 2018 06:53:26 GMT Sebastian Huber [f01edf1] * libbsd.py (modified) * mDNSResponder/Clients/ClientCommon.c (modified) * mDNSResponder/Clients/Java/nmakefile (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/52D711AF-4055-4867-A494-7E31552BB9E1.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/Screen Shot 2015-09-16 at 3.36.23 PM.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/Screen Shot 2015-09-16 at 3.46.14 PM.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/TXT.rtf (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/unknown.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/A944EB40-AEFD-4CA1-BF10-E8F52835CA8C.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/Screen Shot 2015-09-16 at 4.22.37 PM.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/TXT.rtf (added) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.h (modified) * mDNSResponder/mDNSMacOSX/BLE.c (added) * mDNSResponder/mDNSMacOSX/BLE.h (added) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryDefines.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryReply.defs (deleted) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryRequest.defs (deleted) * mDNSResponder/mDNSMacOSX/Metrics.h (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.c (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.c (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (modified) * mDNSResponder/mDNSMacOSX/Private/com.apple.mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/Private/dns_sd_private.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_xpc.h (modified) * mDNSResponder/mDNSMacOSX/Private/dnsctl_server.c (added) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.h (modified) * mDNSResponder/mDNSMacOSX/SymptomReporter.c (modified) * mDNSResponder/mDNSMacOSX/com.apple.dnsextd.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponder.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.networking.mDNSResponder (deleted) * mDNSResponder/mDNSMacOSX/coreBLE.h (added) * mDNSResponder/mDNSMacOSX/coreBLE.m (added) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/dnsctl-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/helper-error.h (deleted) * mDNSResponder/mDNSMacOSX/helper-main.c (modified) * mDNSResponder/mDNSMacOSX/helper-server.h (modified) * mDNSResponder/mDNSMacOSX/helper-stubs.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/helper.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg-types.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg.defs (deleted) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/xcshareddata/xcschemes/Build All.xcscheme (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/xcshareddata/xcschemes/mDNSResponder.xcscheme (added) * mDNSResponder/mDNSMacOSX/mDNSResponderLogging.mobileconfig (deleted) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (modified) * mDNSResponder/mDNSPosix/._ReadMe.txt (deleted) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/ReadMe.txt (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mdnsd.sh (modified) * mDNSResponder/mDNSPosix/nss_mdns.c (modified) * mDNSResponder/mDNSShared/PlatformCommon.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSWindows/ControlPanel/ConfigPropertySheet.cpp (modified) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.cpp (modified) * mDNSResponder/mDNSWindows/ControlPanel/FourthPage.cpp (modified) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.cpp (modified) * mDNSResponder/mDNSWindows/DLLX/DNSSD.cpp (modified) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/ChooserDialog.cpp (modified) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/BrowserDialog.cpp (modified) * mDNSResponder/mDNSWindows/Java/makefile (modified) * mDNSResponder/mDNSWindows/Java/makefile64 (modified) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.c (modified) * mDNSResponder/mDNSWindows/SystemService/Service.c (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.c (modified) * mDNSResponder/unittests/DNSMessageTest.c (added) * mDNSResponder/unittests/DNSMessageTest.h (added) * mDNSResponder/unittests/DomainNameTest.c (added) * mDNSResponder/unittests/DomainNameTest.h (added) * mDNSResponder/unittests/InterfaceTest.c (added) * mDNSResponder/unittests/InterfaceTest.h (added) * mDNSResponder/unittests/ResourceRecordTest.c (added) * mDNSResponder/unittests/ResourceRecordTest.h (added) * mDNSResponder/unittests/main.c (added) * mDNSResponder/unittests/unittest.c (added) * mDNSResponder/unittests/unittest.h (added) * rtemsbsd/mdns/mDNSResolveService.c (added) mDNSResponder: Update to v765.1.2 The sources can be obtained via: ... Thu, 06 Sep 2018 08:50:03 GMT Sebastian Huber [6e5b088] * libbsd.py (modified) * rtemsbsd/rtems/rtems-kernel-mtxpool.c (added) Move dynamic mutex pool to separate file This avoids false ... Thu, 23 Aug 2018 06:38:20 GMT Sebastian Huber [ee738dd] * freebsd/contrib/wpa/src/rsn_supp/tdls.c (deleted) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (deleted) * libbsd.py (modified) WPA_SUPPLICANT(8): Remove unused files Remove unused files which ... Tue, 21 Aug 2018 08:42:25 GMT Sebastian Huber [63084c1] * buildset/default.ini (modified) * freebsd/sys/netinet6/ip_fw_nat64.h (deleted) * freebsd/sys/netinet6/ip_fw_nptv6.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm_codel.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm_pie.h (deleted) * freebsd/sys/netpfil/ipfw/dn_heap.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel_helper.h (deleted) * freebsd/sys/netpfil/ipfw/ip_dn_private.h (deleted) * freebsd/sys/netpfil/ipfw/ip_fw2.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table.h (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.h (deleted) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) IPFW(4): Remove FreeBSD import This firewall was not ported to ... Thu, 02 Aug 2018 08:22:11 GMT Christian Mauderer [baffbf3] * libbsd.py (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) * testsuite/ipsec01/README (added) * testsuite/ipsec01/setup_FreeBSD_as_communication_partner.sh (added) * testsuite/ipsec01/test_main.c (added) testsuite/ipsec01: Add. Mon, 30 Jul 2018 15:02:59 GMT Christian Mauderer [1b467ad] * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/ipsec.h (added) * rtemsbsd/rtems/rtems-bsd-racoon.c (added) * rtemsbsd/rtems/rtems-bsd-rc-conf-ipsec.c (added) Add ipsec to rc.conf. Thu, 03 May 2018 12:15:11 GMT Christian Mauderer [b376ae1] * freebsd/lib/libipsec/ipsec_dump_policy.c (deleted) * freebsd/lib/libipsec/ipsec_strerror.c (deleted) * freebsd/lib/libipsec/ipsec_strerror.h (deleted) * freebsd/lib/libipsec/libpfkey.h (deleted) * freebsd/lib/libipsec/pfkey.c (deleted) * freebsd/lib/libipsec/pfkey_dump.c (deleted) * freebsd/lib/libipsec/policy_parse.c (deleted) * freebsd/lib/libipsec/policy_parse.y (deleted) * freebsd/lib/libipsec/policy_token.c (deleted) * freebsd/lib/libipsec/policy_token.l (deleted) * freebsd/lib/libipsec/y.tab.h (deleted) * ipsec-tools/src/config.h (added) * ipsec-tools/src/libipsec/config.h (added) * ipsec-tools/src/libipsec/ipsec_dump_policy.c (modified) * ipsec-tools/src/libipsec/ipsec_get_policylen.c (modified) * ipsec-tools/src/libipsec/ipsec_strerror.c (modified) * ipsec-tools/src/libipsec/key_debug.c (modified) * ipsec-tools/src/libipsec/libpfkey.h (modified) * ipsec-tools/src/libipsec/pfkey.c (modified) * ipsec-tools/src/libipsec/pfkey_dump.c (modified) * ipsec-tools/src/libipsec/policy_parse.c (modified) * ipsec-tools/src/libipsec/policy_parse.h (modified) * ipsec-tools/src/libipsec/policy_parse.y (modified) * ipsec-tools/src/libipsec/policy_token.c (modified) * ipsec-tools/src/libipsec/policy_token.l (modified) * ipsec-tools/src/libipsec/test-policy.c (modified) * ipsec-tools/src/racoon/admin.c (modified) * ipsec-tools/src/racoon/algorithm.c (modified) * ipsec-tools/src/racoon/algorithm.h (modified) * ipsec-tools/src/racoon/backupsa.c (modified) * ipsec-tools/src/racoon/cfparse.c (modified) * ipsec-tools/src/racoon/cfparse.h (modified) * ipsec-tools/src/racoon/cfparse_wrapper.c (added) * ipsec-tools/src/racoon/cftoken.c (modified) * ipsec-tools/src/racoon/cftoken_proto.h (modified) * ipsec-tools/src/racoon/cftoken_wrapper.c (added) * ipsec-tools/src/racoon/config.h (added) * ipsec-tools/src/racoon/crypto_openssl.c (modified) * ipsec-tools/src/racoon/dnssec.c (modified) * ipsec-tools/src/racoon/eaytest.c (modified) * ipsec-tools/src/racoon/evt.c (modified) * ipsec-tools/src/racoon/genlist.c (modified) * ipsec-tools/src/racoon/getcertsbyname.c (modified) * ipsec-tools/src/racoon/grabmyaddr.c (modified) * ipsec-tools/src/racoon/gssapi.c (modified) * ipsec-tools/src/racoon/handler.c (modified) * ipsec-tools/src/racoon/ipsec_doi.c (modified) * ipsec-tools/src/racoon/isakmp.c (modified) * ipsec-tools/src/racoon/isakmp_agg.c (modified) * ipsec-tools/src/racoon/isakmp_base.c (modified) * ipsec-tools/src/racoon/isakmp_cfg.c (modified) * ipsec-tools/src/racoon/isakmp_frag.c (modified) * ipsec-tools/src/racoon/isakmp_ident.c (modified) * ipsec-tools/src/racoon/isakmp_inf.c (modified) * ipsec-tools/src/racoon/isakmp_newg.c (modified) * ipsec-tools/src/racoon/isakmp_quick.c (modified) * ipsec-tools/src/racoon/isakmp_unity.c (modified) * ipsec-tools/src/racoon/isakmp_xauth.c (modified) * ipsec-tools/src/racoon/kmpstat.c (modified) * ipsec-tools/src/racoon/localconf.c (modified) * ipsec-tools/src/racoon/logger.c (modified) * ipsec-tools/src/racoon/main.c (modified) * ipsec-tools/src/racoon/misc.c (modified) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.c (modified) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.c (modified) * ipsec-tools/src/racoon/missing/crypto/sha2/config.h (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.c (modified) * ipsec-tools/src/racoon/nattraversal.c (modified) * ipsec-tools/src/racoon/oakley.c (modified) * ipsec-tools/src/racoon/package_version.h (added) * ipsec-tools/src/racoon/pfkey.c (modified) * ipsec-tools/src/racoon/plainrsa-gen.c (modified) * ipsec-tools/src/racoon/plog.c (modified) * ipsec-tools/src/racoon/policy.c (modified) * ipsec-tools/src/racoon/privsep.c (modified) * ipsec-tools/src/racoon/proposal.c (modified) * ipsec-tools/src/racoon/prsa_par.c (modified) * ipsec-tools/src/racoon/prsa_par.h (modified) * ipsec-tools/src/racoon/prsa_par.y (modified) * ipsec-tools/src/racoon/prsa_par_wrapper.c (added) * ipsec-tools/src/racoon/prsa_tok.c (modified) * ipsec-tools/src/racoon/prsa_tok.l (modified) * ipsec-tools/src/racoon/prsa_tok_wrapper.c (added) * ipsec-tools/src/racoon/racoonctl.c (modified) * ipsec-tools/src/racoon/remoteconf.c (modified) * ipsec-tools/src/racoon/rsalist.c (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-admin-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-algorithm-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-backupsa-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-cfparse_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-cftoken_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-crypto_openssl-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-dnssec-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-evt-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-genlist-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-getcertsbyname-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-grabmyaddr-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-gssapi-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-handler-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-ipsec_doi-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_agg-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_base-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_frag-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_ident-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_inf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_newg-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_quick-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-localconf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-logger-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-main-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-misc-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-namespace.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-nattraversal-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-oakley-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-pfkey-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-plog-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-policy-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-privsep-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-proposal-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_par_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_tok_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-remoteconf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-rsalist-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-safefile-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sainfo-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-schedule-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sha2-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sockmisc-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-str2val-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-strnames-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-vendorid-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-vmbuf-data.h (added) * ipsec-tools/src/racoon/safefile.c (modified) * ipsec-tools/src/racoon/sainfo.c (modified) * ipsec-tools/src/racoon/schedule.c (modified) * ipsec-tools/src/racoon/security.c (modified) * ipsec-tools/src/racoon/session.c (modified) * ipsec-tools/src/racoon/sockmisc.c (modified) * ipsec-tools/src/racoon/sockmisc.h (modified) * ipsec-tools/src/racoon/str2val.c (modified) * ipsec-tools/src/racoon/strnames.c (modified) * ipsec-tools/src/racoon/throttle.c (modified) * ipsec-tools/src/racoon/vendorid.c (modified) * ipsec-tools/src/racoon/vmbuf.c (modified) * ipsec-tools/src/setkey/config.h (added) * ipsec-tools/src/setkey/package_version.h (added) * ipsec-tools/src/setkey/parse.c (modified) * ipsec-tools/src/setkey/parse.h (modified) * ipsec-tools/src/setkey/parse.y (modified) * ipsec-tools/src/setkey/parse_wrapper.c (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-namespace.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-parse_wrapper-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-setkey-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-token_wrapper-data.h (added) * ipsec-tools/src/setkey/setkey.c (modified) * ipsec-tools/src/setkey/token.c (modified) * ipsec-tools/src/setkey/token_wrapper.c (added) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/machine/rtems-bsd-racoon.h (moved) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-racoon.c (added) * rtemsbsd/rtems/rtems-bsd-shell-setkey.c (added) * rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c (modified) * rtemsbsd/rtems/rtems-racoon-mutex.c (added) * testsuite/media01/test_main.c (modified) ipsec-tools: Port libipsec, setkey and racoon. Note that this ... Fri, 27 Apr 2018 12:57:20 GMT Christian Mauderer [6215813] * buildset/default.ini (modified) * buildset/everything.ini (modified) * freebsd/sys/net/if_ipsec.c (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_ipsec.h (modified) if_ipsec: Port and add to everything-buildset. This ports the ... Wed, 02 May 2018 07:01:32 GMT Sebastian Huber [b2eb48c] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * dhcpcd/script.c (modified) * dhcpcd/script.h (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/dhcpcd.h (modified) * testsuite/dhcpcd01/test_main.c (modified) dhcpcd: Add hooks Wed, 02 May 2018 09:25:18 GMT Christian Mauderer [dd35ec5] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Allow to add libs per test. Update #3419. Wed, 25 Apr 2018 14:28:00 GMT Christian Mauderer [338f300] * builder.py (modified) * buildset/default.ini (modified) * buildset/everything.ini (added) * buildset/minimal.ini (added) * buildset/sample.ini (deleted) * dhcpcd/config.h (modified) * dhcpcd/dhcp6.c (modified) * dhcpcd/ipv6.c (modified) * dhcpcd/ipv6.h (modified) * dhcpcd/ipv6nd.c (modified) * dhcpcd/platform.h (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_inet6.h (modified) * testsuite/commands01/test_main.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) buildset: Add minimal and everything config. This adds two new ... Mon, 30 Apr 2018 09:07:05 GMT Sebastian Huber [443a058] * freebsd/include/arpa/ftp.h (deleted) * libbsd.py (modified) * rtemsbsd/ftpd/ftpd-init.c (deleted) * rtemsbsd/ftpd/ftpd.c (deleted) * rtemsbsd/ftpfs/ftpfs.c (deleted) * rtemsbsd/include/rtems/ftpd.h (deleted) * rtemsbsd/include/rtems/ftpfs.h (deleted) * rtemsbsd/include/rtems/telnetd.h (deleted) * rtemsbsd/telnetd/check_passwd.c (deleted) * rtemsbsd/telnetd/des.c (deleted) * rtemsbsd/telnetd/passwd.h (deleted) * rtemsbsd/telnetd/pty.c (deleted) * rtemsbsd/telnetd/telnetd-init.c (deleted) * rtemsbsd/telnetd/telnetd.c (deleted) * waf_libbsd.py (modified) Use network services from RTEMS Close #3419. Fri, 06 Apr 2018 08:35:42 GMT Christian Mauderer [854427b] * CONTRIBUTING.md (modified) * README.waf (modified) * builder.py (modified) * buildset/default.ini (added) * buildset/sample.ini (added) * libbsd.py (modified) * rtems_waf (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Add configurations with different modules. Update #3351 Fri, 06 Apr 2018 07:42:29 GMT Christian Mauderer [494b156] * libbsd.py (modified) waf: Remove module without sources. There are no imported sources ... Mon, 26 Mar 2018 04:14:53 GMT Chris Johns [d797c5d] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Refactor libbsd.py to support per module generation. This ... Mon, 26 Mar 2018 04:14:52 GMT Chris Johns [f7a09b5] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (deleted) * waf_generator.py (deleted) * waf_libbsd.py (added) * wscript (modified) waf: Support building from libbsd.py directly from waf. Remove the ...
