@817cbf7
05/12/17 12:16:27 |
kevin-kirspel |
devfs: Fix some issues
Fix issue with cdev private data usage with …
55-freebsd-126-freebsd-12
@5040ee5
05/12/17 12:16:24 |
kevin-kirspel |
Update USB Serial Driver for use with RTEMS
@746d74b
05/12/17 12:16:23 |
kevin-kirspel |
Add USB headers to support USB Serial drivers
@286c391
05/12/17 12:16:22 |
kevin-kirspel |
Adding FREEBSD USB Serial Drivers
@4a8f953
05/04/17 12:27:58 |
kevin-kirspel |
Updating FREEBSD for tty support
@567cce1
05/04/17 12:27:57 |
kevin-kirspel |
Updating STTY command for use in RTEMS shell
@f6c52e0
05/04/17 12:27:56 |
kevin-kirspel |
Adding tty support files from FREEBSD tree
@67cd18e
05/04/17 12:27:55 |
kevin-kirspel |
Adding stty command files from FREEBSD tree
@de8a76d
04/04/17 07:36:57 |
Sebastian Huber |
Update to FreeBSD head 2017-04-04
Git mirror commit …
@0732183
03/14/17 06:15:34 |
Sebastian Huber |
Fix SOCK_CLOEXEC with socket() and socketpair()
Remove SOCK_CLOEXEC …
@5f3722a
03/08/17 08:05:05 |
Sebastian Huber |
if_tsec: Enable FDT support
@c1205ee
03/02/17 15:29:11 |
Sebastian Huber |
FDT(4): Port to RTEMS
@f0dd0c5
03/02/17 15:28:14 |
Sebastian Huber |
FDT(4): Import from FreeBSD
@18a623e
03/06/17 11:07:32 |
Sebastian Huber |
Provide strtoq() and strtouq()
@08f4881
03/06/17 11:07:13 |
Sebastian Huber |
NETSTAT(1): Disable unused functions
@6bc5190
03/06/17 11:06:38 |
Sebastian Huber |
Disable unused pfil_try_rlock()
@5268338
03/06/17 11:06:19 |
Sebastian Huber |
Provide sbuf_hexdump()
@57ba8ad
03/06/17 11:05:54 |
Sebastian Huber |
Avoid kern_unsetenv()
@5e093a5
02/22/17 10:49:33 |
Sebastian Huber |
SLEEPQUEUE(9): Fix absolute timeouts
The FreeBSD kernel timeouts are …
@a739190
02/14/17 10:55:18 |
Sebastian Huber |
SYSCTL(8): Fix command line option processing
@9f2205a
01/30/17 16:58:16 |
kevin-kirspel |
Port LPC32XX Ethernet and USB OHCI to RTEMS
@803a495
01/30/17 16:58:15 |
kevin-kirspel |
Adding LPC32XX ethernet driver support
@ea395a7
01/30/17 16:58:18 |
kevin-kirspel |
Add ordered Nexus devices
Add support for ordering the initialization …
@1fd5083
01/31/17 08:50:45 |
Sebastian Huber |
SLEEPQUEUE(9): Add wmesg to thread wait info
@ee94f8a
01/31/17 08:49:49 |
Sebastian Huber |
rtems-bsd-mutex: Use thread queue name
@c6b85e8
01/17/17 10:01:44 |
Christian.Mauderer |
userspace tools: Regenerate headers.
@ecda181
12/09/16 10:51:50 |
freebsd/wlanstats: Port to FreeBSD.
@d415406
12/09/16 08:15:24 |
freebsd/wlanstats: Import from FreeBSD.
@edf32f2
11/18/16 10:13:11 |
rtwn: Port to RTEMS
@0cbb715
11/22/16 09:41:47 |
rtwn: Import from FreeBSD.
@9bc41d0
12/12/16 09:51:42 |
lib80211/regdomain: Port to RTEMS.
@bce3e5e
11/18/16 13:59:56 |
lib80211/regdomain: Import from FreeBSD.
@5c3223f
11/16/16 15:29:17 |
ifconfig/wlan, expat, lib80211: Port to RTEMS.
@2389539
11/16/16 14:02:20 |
ifconfig/wlan, expat, lib80211: Import from FreeBSD.
@59338de
12/12/16 11:23:40 |
Port USB and USB WLAN.
@d145449
11/14/16 12:30:48 |
Import USB and USB WLAN from FreeBSD.
@66eb143
12/12/16 12:09:09 |
firmware: Port to RTEMS.
@2e8dd24
11/16/16 12:20:05 |
firmware: Import from FreeBSD.
@a241ea8
11/14/16 12:46:13 |
Import IEEE 802.11 from FreeBSD.
@172f2ac
01/12/17 13:56:23 |
Sebastian Huber |
Use thread name support
Update #2858.
@fb288fa
01/11/17 13:15:31 |
Sebastian Huber |
ROUTE(8): Disable routing socket timeout support
FIXME: This reverts …
@9e8ce9ae
01/10/17 13:41:23 |
Sebastian Huber |
pf: Some fixes after the update
@3dff21a
01/10/17 13:00:20 |
Sebastian Huber |
Remove obsolete PF files
@64c663c
01/10/17 07:04:58 |
Sebastian Huber |
ARP(8): Port to RTEMS
@246b61e
01/10/17 06:58:50 |
Sebastian Huber |
ARP(8): Import from FreeBSD
@0577772
01/09/17 13:47:04 |
Sebastian Huber |
Update to FreeBSD head 2017-01-09
Git mirror commit …
@75b706f
12/09/16 13:19:03 |
Sebastian Huber |
Update to FreeBSD head 2016-12-10
Git mirror commit …
@c4e89a9
11/10/16 12:52:08 |
Sebastian Huber |
VMSTAT(8): Port to RTEMS
@dba2dfc
11/10/16 12:25:27 |
Sebastian Huber |
VMSTAT(8): Import from FreeBSD
@2360b08
09/07/15 06:33:16 |
Sebastian Huber |
if_dwc: Invalidate read buffer again
This may prevent problems in …
@3ef41be
01/10/17 08:16:17 |
Sebastian Huber |
if_dwc: Use explicit cache operations
@0436d64
01/09/17 10:43:40 |
Sebastian Huber |
if_dwc: Reduce DMA descriptor count
@88dad3b
01/09/17 10:41:24 |
Sebastian Huber |
if_dwc: Use rtems_bsd_get_mac_address()
@f8ed8cd
03/26/15 14:21:07 |
Sebastian Huber |
if_dwc: Add nexus device support
@c07da01
09/07/15 06:34:34 |
Sebastian Huber |
if_dwc: Fix a possible interrupt starvation
@051b634
04/07/15 11:54:23 |
Sebastian Huber |
if_dwc: Avoid mbuf use after free
@b99c023
03/30/15 12:30:04 |
Sebastian Huber |
if_dwc: Checksum offload
@5deeb69
03/27/15 13:16:40 |
Sebastian Huber |
if_dwc: Avoid tx defrag if possible
Drop packets in case of resource …
@d9ff828
03/30/15 09:51:36 |
Sebastian Huber |
if_dwc: Simplify tx desc setup
@9410212
03/30/15 07:51:18 |
Sebastian Huber |
if_dwc: Fix transmit starvation
@6cd057d
01/10/17 07:52:14 |
Sebastian Huber |
if_dwc: Fix IFCOUNTER_IPACKETS statistics
Input packets are counted …
@ec2e4b1
01/09/17 12:24:33 |
Sebastian Huber |
if_dwc: Fix IFCOUNTER_OPACKETS statistics
Output packets are counted …
@e392c989
03/27/15 10:14:44 |
Sebastian Huber |
if_dwc: Move interrupt handler install
@46f0b8b
01/09/17 08:41:29 |
Sebastian Huber |
Enable multi-cast routing support
@95a3ba8
01/09/17 07:50:55 |
Sebastian Huber |
NETSTAT(1): Fix name list initialization
@b86b097
10/24/16 11:30:37 |
Sebastian Huber |
Fix warings in <sys/seq.h>
@11750f1
10/24/16 11:14:35 |
Sebastian Huber |
Fix warnings in <sys/refcount.h>
@2956924
10/24/16 10:00:55 |
Sebastian Huber |
Fix atomic ops in <sys/buf_ring.h>
@c40e45b
10/07/16 13:10:20 |
Sebastian Huber |
Update to FreeBSD head 2016-08-23
Git mirror commit …
@750b2d4
01/09/17 13:54:21 |
Sebastian Huber |
Workaround for <sys/event.h> update
55-freebsd-126-freebsd-12freebsd-9.3
@b1580fb
12/21/16 19:01:28 |
kevin-kirspel |
PIPE(2): Port to RTEMS
@6959fac
12/21/16 19:01:26 |
kevin-kirspel |
PIPE(2): Import from FreeBSD
@e3dac66
12/07/16 06:15:02 |
Sebastian Huber |
pfctl: Update due to linker set API changes
@cfec446
11/23/16 13:17:25 |
Sebastian Huber |
SLEEPQUEUE(9): Properly remove timeout timer
@616ffa96
11/23/16 13:16:05 |
Sebastian Huber |
Use _Thread_Dispatch_direct()
@c418b7a
11/10/16 13:58:58 |
Sebastian Huber |
Fix mbuf_jumbo_alloc()
@6254bf4
11/09/16 09:26:17 |
Sebastian Huber |
SDHCI(4): Delete
Delete heavily modified SDHCI(4) support. It must …
@cc8f00d
11/09/16 08:56:01 |
Sebastian Huber |
Fix warnings for linker sets
@617dc0f
11/09/16 07:15:22 |
Sebastian Huber |
Really robust linker sets
The previous attempt to fix this issue …
@ed499fa
10/26/16 12:38:23 |
Sebastian Huber |
More robust linker sets
See also:
@cf88298
10/26/16 12:14:05 |
Sebastian Huber |
Prepare copyiniov() for FreeBSD update
@0ba4197
10/24/16 06:07:56 |
Sebastian Huber |
Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h>
@7eb064c
10/24/16 06:06:27 |
Sebastian Huber |
Make <sys/proc.h> self-sufficient
@a9d38f5
10/07/16 05:24:30 |
Sebastian Huber |
Remove AppleTalk? support
Prepare update to FreeBSD 11.
@40f202da
10/13/16 05:21:48 |
Sebastian Huber |
@e11f8e3
10/07/16 05:09:48 |
Sebastian Huber |
ohci: Fixes due to USB stack update
@2c44b51
09/22/16 05:21:54 |
Sebastian Huber |
Use _Thread_Get_priority()
@7f75b56
09/07/16 13:43:44 |
Sebastian Huber |
Port getdomainname() to RTEMS
@a439410
09/07/16 13:42:36 |
Sebastian Huber |
Import getdomainname()
@8e65e1b
08/23/16 13:51:45 |
Sebastian Huber |
usb: Update to FreeBSD trunk 2016-08-23
FreeBSD trunk, 2016-08-23, …
@0c24e06
08/23/16 12:22:26 |
Sebastian Huber |
mmc: Update to FreeBSD trunk 2016-08-23
@26a8cee
08/11/16 07:41:49 |
Chris Johns |
e1000phy: Provide local support for Marvell's 88E1512 PHY.
This PHY …
@9907ae4
08/04/16 12:13:20 |
netstat: Don't init vars if they are not defined.
The variables are …
@2fb3a36
08/04/16 12:12:17 |
freebsd: Add constant ipv6 addresses from vars.c.
This is necessary …
@09ce54e
07/22/16 12:36:19 |
pfctl: Add yacc generated file.
@d79524e
07/05/16 14:31:43 |
pfctl: Adapt for RTEMS.
@686583c
07/29/16 14:04:42 |
pfctl: Use static where possible.
@c70221c
07/06/16 07:50:51 |
pfctl: Add const and move static variables.
Note: This should be …
@b6252fb
07/05/16 14:31:43 |
pfctl: Match prototype.
Note: This should be upstreamed into BSD.
@6e9a8ea
07/05/16 14:07:37 |
pfctl: Import sources from FreeBSD.
