Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems-libbsd/freebsd
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @59338de   12/12/16 11:23:40 Christian.Mauderer Port USB and USB WLAN. 55-freebsd-126-freebsd-12
(edit) @d145449   11/14/16 12:30:48 Christian.Mauderer Import USB and USB WLAN from FreeBSD. 55-freebsd-126-freebsd-12
(edit) @66eb143   12/12/16 12:09:09 Christian.Mauderer firmware: Port to RTEMS. 55-freebsd-126-freebsd-12
(edit) @2e8dd24   11/16/16 12:20:05 Christian.Mauderer firmware: Import from FreeBSD. 55-freebsd-126-freebsd-12
(edit) @a241ea8   11/14/16 12:46:13 Christian.Mauderer Import IEEE 802.11 from FreeBSD. 55-freebsd-126-freebsd-12
(edit) @172f2ac   01/12/17 13:56:23 Sebastian Huber Use thread name support Update #2858. 55-freebsd-126-freebsd-12
(edit) @fb288fa   01/11/17 13:15:31 Sebastian Huber ROUTE(8): Disable routing socket timeout support FIXME: This reverts … 55-freebsd-126-freebsd-12
(edit) @9e8ce9ae   01/10/17 13:41:23 Sebastian Huber pf: Some fixes after the update 55-freebsd-126-freebsd-12
(edit) @3dff21a   01/10/17 13:00:20 Sebastian Huber Remove obsolete PF files 55-freebsd-126-freebsd-12
(edit) @64c663c   01/10/17 07:04:58 Sebastian Huber ARP(8): Port to RTEMS 55-freebsd-126-freebsd-12
(edit) @246b61e   01/10/17 06:58:50 Sebastian Huber ARP(8): Import from FreeBSD 55-freebsd-126-freebsd-12
(edit) @0577772   01/09/17 13:47:04 Sebastian Huber Update to FreeBSD head 2017-01-09 Git mirror commit … 55-freebsd-126-freebsd-12
(edit) @75b706f   12/09/16 13:19:03 Sebastian Huber Update to FreeBSD head 2016-12-10 Git mirror commit … 55-freebsd-126-freebsd-12
(edit) @c4e89a9   11/10/16 12:52:08 Sebastian Huber VMSTAT(8): Port to RTEMS 55-freebsd-126-freebsd-12
(edit) @dba2dfc   11/10/16 12:25:27 Sebastian Huber VMSTAT(8): Import from FreeBSD 55-freebsd-126-freebsd-12
(edit) @2360b08   09/07/15 06:33:16 Sebastian Huber if_dwc: Invalidate read buffer again This may prevent problems in … 55-freebsd-126-freebsd-12
(edit) @3ef41be   01/10/17 08:16:17 Sebastian Huber if_dwc: Use explicit cache operations 55-freebsd-126-freebsd-12
(edit) @0436d64   01/09/17 10:43:40 Sebastian Huber if_dwc: Reduce DMA descriptor count 55-freebsd-126-freebsd-12
(edit) @88dad3b   01/09/17 10:41:24 Sebastian Huber if_dwc: Use rtems_bsd_get_mac_address() 55-freebsd-126-freebsd-12
(edit) @f8ed8cd   03/26/15 14:21:07 Sebastian Huber if_dwc: Add nexus device support 55-freebsd-126-freebsd-12
(edit) @c07da01   09/07/15 06:34:34 Sebastian Huber if_dwc: Fix a possible interrupt starvation 55-freebsd-126-freebsd-12
(edit) @051b634   04/07/15 11:54:23 Sebastian Huber if_dwc: Avoid mbuf use after free 55-freebsd-126-freebsd-12
(edit) @b99c023   03/30/15 12:30:04 Sebastian Huber if_dwc: Checksum offload 55-freebsd-126-freebsd-12
(edit) @5deeb69   03/27/15 13:16:40 Sebastian Huber if_dwc: Avoid tx defrag if possible Drop packets in case of resource … 55-freebsd-126-freebsd-12
(edit) @d9ff828   03/30/15 09:51:36 Sebastian Huber if_dwc: Simplify tx desc setup 55-freebsd-126-freebsd-12
(edit) @9410212   03/30/15 07:51:18 Sebastian Huber if_dwc: Fix transmit starvation 55-freebsd-126-freebsd-12
(edit) @6cd057d   01/10/17 07:52:14 Sebastian Huber if_dwc: Fix IFCOUNTER_IPACKETS statistics Input packets are counted … 55-freebsd-126-freebsd-12
(edit) @ec2e4b1   01/09/17 12:24:33 Sebastian Huber if_dwc: Fix IFCOUNTER_OPACKETS statistics Output packets are counted … 55-freebsd-126-freebsd-12
(edit) @e392c989   03/27/15 10:14:44 Sebastian Huber if_dwc: Move interrupt handler install 55-freebsd-126-freebsd-12
(edit) @46f0b8b   01/09/17 08:41:29 Sebastian Huber Enable multi-cast routing support 55-freebsd-126-freebsd-12
(edit) @95a3ba8   01/09/17 07:50:55 Sebastian Huber NETSTAT(1): Fix name list initialization 55-freebsd-126-freebsd-12
(edit) @b86b097   10/24/16 11:30:37 Sebastian Huber Fix warings in <sys/seq.h> 55-freebsd-126-freebsd-12
(edit) @11750f1   10/24/16 11:14:35 Sebastian Huber Fix warnings in <sys/refcount.h> 55-freebsd-126-freebsd-12
(edit) @2956924   10/24/16 10:00:55 Sebastian Huber Fix atomic ops in <sys/buf_ring.h> 55-freebsd-126-freebsd-12
(edit) @c40e45b   10/07/16 13:10:20 Sebastian Huber Update to FreeBSD head 2016-08-23 Git mirror commit … 55-freebsd-126-freebsd-12
(edit) @750b2d4   01/09/17 13:54:21 Sebastian Huber Workaround for <sys/event.h> update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b1580fb   12/21/16 19:01:28 kevin-kirspel PIPE(2): Port to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6959fac   12/21/16 19:01:26 kevin-kirspel PIPE(2): Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e3dac66   12/07/16 06:15:02 Sebastian Huber pfctl: Update due to linker set API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @cfec446   11/23/16 13:17:25 Sebastian Huber SLEEPQUEUE(9): Properly remove timeout timer 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @616ffa96   11/23/16 13:16:05 Sebastian Huber Use _Thread_Dispatch_direct() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c418b7a   11/10/16 13:58:58 Sebastian Huber Fix mbuf_jumbo_alloc() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6254bf4   11/09/16 09:26:17 Sebastian Huber SDHCI(4): Delete Delete heavily modified SDHCI(4) support. It must … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @cc8f00d   11/09/16 08:56:01 Sebastian Huber Fix warnings for linker sets 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @617dc0f   11/09/16 07:15:22 Sebastian Huber Really robust linker sets The previous attempt to fix this issue … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ed499fa   10/26/16 12:38:23 Sebastian Huber More robust linker sets See also: … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @cf88298   10/26/16 12:14:05 Sebastian Huber Prepare copyiniov() for FreeBSD update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0ba4197   10/24/16 06:07:56 Sebastian Huber Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h> 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7eb064c   10/24/16 06:06:27 Sebastian Huber Make <sys/proc.h> self-sufficient 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a9d38f5   10/07/16 05:24:30 Sebastian Huber Remove AppleTalk? support Prepare update to FreeBSD 11. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @40f202da   10/13/16 05:21:48 Sebastian Huber pfctl: Update due to linker set API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e11f8e3   10/07/16 05:09:48 Sebastian Huber ohci: Fixes due to USB stack update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2c44b51   09/22/16 05:21:54 Sebastian Huber Use _Thread_Get_priority() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7f75b56   09/07/16 13:43:44 Sebastian Huber Port getdomainname() to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a439410   09/07/16 13:42:36 Sebastian Huber Import getdomainname() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8e65e1b   08/23/16 13:51:45 Sebastian Huber usb: Update to FreeBSD trunk 2016-08-23 FreeBSD trunk, 2016-08-23, … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0c24e06   08/23/16 12:22:26 Sebastian Huber mmc: Update to FreeBSD trunk 2016-08-23 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @26a8cee   08/11/16 07:41:49 Chris Johns e1000phy: Provide local support for Marvell's 88E1512 PHY. This PHY … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9907ae4   08/04/16 12:13:20 Christian.Mauderer netstat: Don't init vars if they are not defined. The variables are … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2fb3a36   08/04/16 12:12:17 Christian.Mauderer freebsd: Add constant ipv6 addresses from vars.c. This is necessary … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @09ce54e   07/22/16 12:36:19 Christian.Mauderer pfctl: Add yacc generated file. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d79524e   07/05/16 14:31:43 Christian.Mauderer pfctl: Adapt for RTEMS. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @686583c   07/29/16 14:04:42 Christian.Mauderer pfctl: Use static where possible. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c70221c   07/06/16 07:50:51 Christian.Mauderer pfctl: Add const and move static variables. Note: This should be … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b6252fb   07/05/16 14:31:43 Christian.Mauderer pfctl: Match prototype. Note: This should be upstreamed into BSD. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6e9a8ea   07/05/16 14:07:37 Christian.Mauderer pfctl: Import sources from FreeBSD. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @21abaef   07/15/16 05:32:56 Christian.Mauderer freebsd: Don't use new wrappers for old ports. Some of the commands … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9a01ebf   06/28/16 15:27:08 Christian.Mauderer kern_conf.c: Adapt for RTEMS. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6c0cfc2   06/29/16 08:22:03 Christian.Mauderer kern_conf.c: Import from FreeBSD. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b5db332   06/30/16 05:55:27 Christian.Mauderer rtemsbsd/devfs: Add. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b6c170f   07/28/16 02:19:01 Chris Johns kern/sleepqueue: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a0ea5f8   07/28/16 02:17:08 Chris Johns Revert "kern/sleepqueue: Update due to API changes" This reverts … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @1bf6529   07/28/16 02:16:09 Chris Johns kern/sleepqueue: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ace5fb6   06/27/16 11:31:03 Chris Johns Enable the Cadence cgem device syctls. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @591bd2d   06/27/16 11:27:01 Chris Johns Revert "Enable the Cadence cgem device syctls." This reverts commit … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9362e76   06/27/16 11:25:38 Chris Johns Enable the Cadence cgem device syctls. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9835790   06/27/16 11:24:03 Chris Johns Enable device sysctl. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @32fd702   06/23/16 12:06:21 Sebastian Huber Update due to RTEMS printer API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @5851034   06/15/16 05:49:24 Sebastian Huber reentrant.h: There is no main thread in RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a037da6   06/09/16 09:48:16 Sebastian Huber XDR(3): Port to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f41a394   06/09/16 09:46:09 Sebastian Huber XDR(3): Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9880635   06/09/16 08:48:05 Sebastian Huber RPC(3): Port to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @60b1d40   06/09/16 08:23:57 Sebastian Huber RPC(3): Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @17232fe   06/09/16 12:38:31 Sebastian Huber Remove unused files Files moved in FreeBSD to "sys/netpfil/ipfw". 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b367591   04/18/16 12:46:03 Sebastian Huber Adjust <sys/stdint.h> for latest Newlib 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @04762cf   04/27/16 08:28:49 Sebastian Huber Directly use <machine/endian.h> provided by Newlib 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b6f6deb   04/27/16 08:26:50 Sebastian Huber Directly use <sys/_types.h> provided by Newlib 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @3d1e767   04/27/16 08:25:22 Sebastian Huber Directly use <sys/types.h> provided by Newlib 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2017a6d   04/07/16 07:48:12 Sebastian Huber Directly use <sys/time.h> provided by Newlib 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @43a14eb   05/25/16 11:11:59 Sebastian Huber Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @356f59c   05/06/16 10:16:19 Sebastian Huber kvprintf: Add support for %m 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @54a577d   05/04/16 11:04:42 Sebastian Huber subr_prf.c: Port to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d4402dd   05/04/16 11:20:45 Sebastian Huber bcd.c: Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @469db42   05/04/16 10:51:55 Sebastian Huber subr_prf.c: Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @542c981   05/06/16 05:57:46 Sebastian Huber ZONE(9): Fix mp_maxid definition 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @83eb07c   05/06/16 05:06:08 Chris Johns Add sbin/sysctl 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c60deba   05/06/16 05:00:32 Chris Johns Fix sysctl support. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7a79eec   05/06/16 04:40:12 Chris Johns The maxid is not the number of cpus. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @4b127e7   05/04/16 06:01:08 Chris Johns Add RealTek? Gig PHY. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7b8f336   04/27/16 03:21:20 Chris Johns Remove debug output. 55-freebsd-126-freebsd-12freebsd-9.3
