# # ChangeLog for freebsd in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/13/24 01:36:52 Fri, 07 Sep 2012 16:41:09 GMT Jennifer Averett [af4b6f2] * freebsd-to-rtems.py (modified) * freebsd/sys/mman.h (added) Added mman.h This will be needed when the ifconfig command is added. Thu, 06 Sep 2012 14:17:47 GMT Jennifer Averett [6d7f488] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/netatalk/aarp.c (added) * freebsd/netatalk/aarp.h (added) * freebsd/netatalk/at.h (added) * freebsd/netatalk/at_control.c (added) * freebsd/netatalk/at_extern.h (added) * freebsd/netatalk/at_proto.c (added) * freebsd/netatalk/at_rmx.c (added) * freebsd/netatalk/at_var.h (added) * freebsd/netatalk/ddp.h (added) * freebsd/netatalk/ddp_input.c (added) * freebsd/netatalk/ddp_output.c (added) * freebsd/netatalk/ddp_pcb.c (added) * freebsd/netatalk/ddp_pcb.h (added) * freebsd/netatalk/ddp_usrreq.c (added) * freebsd/netatalk/ddp_var.h (added) * freebsd/netatalk/endian.h (added) * freebsd/netatalk/phase2.h (added) Added netatalk files This is part of a larger patch where network ... Wed, 05 Sep 2012 18:11:21 GMT Joel Sherrill [fa3526a] * freebsd/sys/signalvar.h (deleted) freebsd/sys/signalvar.h: Use empty file from previous commit Wed, 05 Sep 2012 17:52:06 GMT Joel Sherrill [734ccda] * freebsd/net/radix_mpath.c (modified) freebsd/net/radix_mpath.c: Fix prototype/body mismatch The routines ... Wed, 05 Sep 2012 17:50:34 GMT Joel Sherrill [4c0dbd3] * freebsd/sys/signal.h (deleted) freebsd/sys/signal.h: use standard This patch ... Wed, 05 Sep 2012 17:49:23 GMT Joel Sherrill [1c6a8e8] * freebsd/sys/cdefs.h (deleted) freebsd/sys/cdefs.h: use standard This patch assumes ... Wed, 05 Sep 2012 17:48:38 GMT Joel Sherrill [25ed473] * freebsd/sys/aio.h (modified) aio.h: Disable unused field Wed, 05 Sep 2012 17:43:37 GMT Joel Sherrill [816b85c] * freebsd/i386/pci/pci_bus.c (modified) pci_bus.c: Fix prototype/body mismatch Sat, 01 Sep 2012 14:24:33 GMT Joel Sherrill [21e0e4e] * freebsd/sys/_iovec.h (modified) _iovec.h: Improve comments Sat, 01 Sep 2012 00:21:34 GMT Joel Sherrill [b4cf93e] * freebsd/sys/_iovec.h (modified) _iovec.h: Ensure only one definition of struct iovec Fri, 20 Jul 2012 19:17:05 GMT Jennifer Averett [2c3d8b9] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/vm/uma_core.c (modified) * rtemsbsd/src/rtems-bsd-page.c (added) Added rtems specific page tracking methods for uma page allocation. Tue, 17 Jul 2012 13:58:15 GMT Jennifer Averett [e1e0a6a] * freebsd/vm/uma_core.c (modified) Remove debug that got turned on. Tue, 17 Jul 2012 13:20:46 GMT Jennifer Averett [325120c] * freebsd/sys/pcpu.h (modified) * rtemsbsd/src/rtems-bsd-syscalls.c (modified) Fix curthread so it returns a valid value. Tue, 17 Jul 2012 13:13:57 GMT Jennifer Averett [19288d6] * freebsd/vm/uma_core.c (modified) Add back in code to set booted. Tue, 17 Jul 2012 13:12:42 GMT Jennifer Averett [fbdd6b6] * freebsd/sys/priv.h (modified) Fix priv_check methods to return passing value. Fri, 13 Jul 2012 16:38:40 GMT Joel Sherrill [a8030171] * freebsd-to-rtems.py (modified) * freebsd/arm/include/freebsd/machine/cpufunc.h (added) * freebsd/powerpc/include/freebsd/machine/cpufunc.h (added) * freebsd/powerpc/include/freebsd/machine/psl.h (added) * freebsd/powerpc/include/freebsd/machine/spr.h (added) * freebsd/sparc64/include/freebsd/machine/asi.h (added) * freebsd/sparc64/include/freebsd/machine/cpufunc.h (added) * freebsd/sparc64/include/freebsd/machine/pstate.h (added) Add ARM, PowerPC, and SPARC64 cpufunc.h files from FreeBSD Fri, 13 Jul 2012 16:29:43 GMT Kevin Polulak [8fe603a] * freebsd/mips/include/freebsd/machine/cpufunc.h (added) * freebsd/mips/include/freebsd/machine/cpuregs.h (added) * rtemsbsd/mips/include/freebsd/machine/cpufunc.h (deleted) Readd MIPS cpu specific .h files At least 80 files in this tree ... Fri, 13 Jul 2012 15:40:11 GMT Joel Sherrill [e78d6ab] * freebsd-to-rtems.py (modified) * freebsd/mips/include/freebsd/machine/cpufunc.h (deleted) * freebsd/mips/include/freebsd/machine/cpuregs.h (deleted) * rtemsbsd/mips/include/freebsd/machine/cpufunc.h (added) MIPS: Remove code with advertising clause At this point, we are ... Fri, 13 Jul 2012 13:57:28 GMT Kevin Polulak [8db44c6] * freebsd/mips/include/freebsd/machine/cpufunc.h (added) * freebsd/mips/include/freebsd/machine/cpuregs.h (added) Add MIPS cpu specific .h files Wed, 11 Jul 2012 18:10:31 GMT Kevin Polulak [9fc8b41] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/arm/arm/in_cksum_arm.S (deleted) Removed in_cksum_arm.S file. Mon, 09 Jul 2012 19:33:02 GMT Joel Sherrill [7a1309a] * freebsd/kern/subr_hints.c (modified) subr_hints.c: For RTEMS use static_hints The user MUST provide a ... Mon, 09 Jul 2012 19:32:34 GMT Joel Sherrill [4f8495e] * freebsd/dev/fxp/if_fxp.c (modified) FXP: Remove hack and use hint provided by application Mon, 09 Jul 2012 15:17:03 GMT Jennifer Averett [c537dc2] * freebsd/dev/fxp/if_fxp.c (modified) Hack to the fxp driver to force i386 to be io based. Fri, 06 Jul 2012 17:23:37 GMT Joel Sherrill [0d23ec9] * freebsd/i386/include/freebsd/machine/cpufunc.h (modified) Disable conflicts with RTEMS Fri, 06 Jul 2012 15:57:12 GMT Joel Sherrill [dbda808] * freebsd-to-rtems.py (modified) * freebsd/i386/include/freebsd/machine/cpufunc.h (added) * rtemsbsd/freebsd/machine/bus.h (modified) * rtemsbsd/freebsd/machine/bus_space-i386.h (added) * rtemsbsd/freebsd/machine/bus_space-simple_memory.h (added) * rtemsbsd/freebsd/machine/cpufunc.h (deleted) Put CPU specific bus_space routines into separate files The code in ... Tue, 03 Jul 2012 15:06:05 GMT Jennifer Averett [4d28b93] * freebsd/net/netisr.c (modified) Added back in a couple of methods. Mon, 02 Jul 2012 15:01:29 GMT Jennifer Averett [48a1927] * freebsd/isa/isavar.h (added) * freebsd/isa/pnpvar.h (added) Added isa header files for Nic. Fri, 29 Jun 2012 20:06:34 GMT Jennifer Averett [348f0a0] * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pcib_private.h (added) Added missing header file. Fri, 29 Jun 2012 17:42:00 GMT Jennifer Averett [36ebd68] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pci_pci.c (modified) * freebsd/i386/i386/legacy.c (added) * freebsd/i386/pci/pci_bus.c (modified) * rtemsbsd/freebsd/machine/rtems-bsd-sysinit.h (modified) * rtemsbsd/src/rtems-bsd-pci_bus.c (added) * rtemsbsd/src/rtems-bsd-pci_cfgreg.c (added) * testsuite/link01/test.c (modified) Added legacy in order to get pcib to work correctly and resoleved fxp ... Mon, 11 Jun 2012 14:42:08 GMT Jennifer Averett [58ea5ee] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pci_pci.c (added) * freebsd/i386/include/freebsd/machine/legacyvar.h (added) * freebsd/i386/include/freebsd/machine/pci_cfgreg.h (added) * freebsd/i386/pci/pci_bus.c (added) Added pcib. Fri, 01 Jun 2012 18:57:50 GMT Jennifer Averett [7345c71] * freebsd/kern/uipc_domain.c (modified) Added rtems specific size for max_linkhdr Note: This was needed for ... Fri, 01 Jun 2012 18:56:20 GMT Jennifer Averett [1e88db13] * freebsd/kern/subr_pcpu.c (modified) * freebsd/net/netisr.c (modified) Added initialization needed for Nics back in. Fri, 01 Jun 2012 18:54:16 GMT Jennifer Averett [19955e7] * freebsd/vm/uma_core.c (modified) Restored debug off state for uma_core.c Thu, 31 May 2012 19:49:12 GMT Jennifer Averett [b049b40] * freebsd/vm/uma_core.c (modified) Added initialization needed by Nics into uma_core.c Thu, 31 May 2012 13:02:50 GMT Jennifer Averett [569ce65] * freebsd/kern/init_main.c (modified) Remove define VERBOSE_SYSINIT which was added by mistake. Wed, 30 May 2012 16:49:04 GMT Jennifer Averett [20b5ca1] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/init_main.c (modified) * freebsd/kern/kern_proc.c (added) Added support for initialization of uihashinit(). Wed, 23 May 2012 19:53:12 GMT Jennifer Averett [fb4c8a9] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pci.c (modified) * freebsd/dev/pci/pci_user.c (added) * freebsd/dev/pci/pcivar.h (modified) * freebsd/i386/include/freebsd/machine/intr_machdep.h (added) * freebsd/kern/kern_prot.c (modified) * freebsd/kern/subr_bus.c (modified) * freebsd/kern/subr_module.c (added) * libbsd.txt (modified) * rtemsbsd/src/rtems-bsd-conf.c (added) * rtemsbsd/src/rtems-bsd-subr_param.c (added) Added pcib for Nics. Wed, 23 May 2012 19:36:24 GMT Jennifer Averett [ae53d9e] * freebsd/sys/conf.h (modified) Commented out elements of the cdev struct which were unused This was ... Thu, 17 May 2012 13:37:48 GMT Jennifer Averett [2f18089] * contrib/altq/freebsd/altq/altq_subr.c (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pci.c (modified) * freebsd/i386/include/freebsd/machine/md_var.h (added) * freebsd/i386/include/freebsd/machine/specialreg.h (added) * freebsd/opencrypto/crypto.c (modified) Resolved issues with pc386 build. Thu, 10 May 2012 13:06:10 GMT Christian Mauderer [ee6b343] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_intr.c (modified) * freebsd/kern/kern_timeout.c (added) * freebsd/sys/callout.h (modified) * freebsd/sys/mutex.h (modified) * freebsd/sys/sleepqueue.h (added) * rtemsbsd/freebsd/machine/rtems-bsd-symbols.h (modified) * rtemsbsd/src/rtems-bsd-callout.c (deleted) * rtemsbsd/src/rtems-bsd-shell.c (modified) * rtemsbsd/src/rtems-bsd-timeout.c (deleted) * testsuite/swi01/Makefile (added) * testsuite/swi01/init.c (added) * testsuite/swi01/swi_test.c (added) * testsuite/swi01/swi_test.h (added) * testsuite/timeout01/Makefile (added) * testsuite/timeout01/init.c (added) * testsuite/timeout01/timeout_helper.c (added) * testsuite/timeout01/timeout_helper.h (added) * testsuite/timeout01/timeout_test.c (added) * testsuite/timeout01/timeout_test.h (added) Provide SWI(9) and TIMEOUT(9) Thu, 10 May 2012 13:51:10 GMT Sebastian Huber [a4d8e19] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/init_main.c (modified) * rtemsbsd/src/rtems-bsd-thread0-ucred.c (added) Move rtems_bsd_thread0_ucred Wed, 09 May 2012 18:55:00 GMT Jennifer Averett [b95c989] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/subr_unit.c (added) * testsuite/link01/test.c (modified) Added subr_unit.c needed for addtional Nics. Wed, 09 May 2012 17:28:53 GMT Jennifer Averett [2dbdc7c] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/led/led.c (added) * freebsd/dev/pci/pci_private.h (added) * freebsd/kern/subr_bufring.c (added) Added EtherExpress, tulip, and Broadcom Nics. BCM570x, E1000, and ... Tue, 01 May 2012 18:52:03 GMT Jennifer Averett [73a8881] * freebsd/kern/init_main.c (modified) * freebsd/netinet/tcp_syncache.c (modified) * freebsd/sys/proc.h (modified) Added rtems_bsd_thread0_ucred as a single global ucred. Tue, 01 May 2012 18:12:00 GMT Jennifer Averett [c1dd641] * freebsd/sys/systm.h (modified) Added a define of 0 for bootverbose. Tue, 01 May 2012 18:10:10 GMT Jennifer Averett [a51d36d2] * freebsd/kern/subr_hints.c (modified) Added globals for hints and hintmode. Thu, 26 Apr 2012 20:12:45 GMT Jennifer Averett [f59bd57] * freebsd/kern/kern_event.c (modified) Added back in kqueue_schedtask() and kqueue_wakeup() Thu, 26 Apr 2012 13:05:52 GMT Sebastian Huber [4c0c5fd] * freebsd-to-rtems.py (modified) * freebsd/kern/init_main.c (modified) * freebsd/sys/proc.h (modified) * freebsd/sys/vmmeter.h (added) * freebsd/vm/vm_map.h (added) * freebsd/vm/vm_param.h (added) * rtemsbsd/src/rtems-bsd-mutex.c (modified) * rtemsbsd/src/rtems-bsd-synch.c (modified) * rtemsbsd/src/rtems-bsd-thread.c (modified) Remove proc0 creation Thu, 26 Apr 2012 13:47:49 GMT Christian Mauderer [9ee7689] * freebsd/kern/uipc_socket.c (modified) * freebsd/netinet/sctp_output.c (modified) * freebsd/sys/proc.h (modified) Remove rusage dependencies Thu, 19 Apr 2012 19:10:20 GMT Jennifer Averett [cb6ffcd] * freebsd/vm/uma_core.c (modified) * freebsd/vm/uma_int.h (modified) Added in uma_find_refcnt() and vtoslab() The vtoslab returns NULL ... Thu, 19 Apr 2012 18:25:28 GMT Jennifer Averett [74587c3] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/vm/uma_core.c (moved) Merged rtems-bsd-uma.c back into uma_core.c The majority of this ... Thu, 19 Apr 2012 10:11:24 GMT Sebastian Huber [f2eb2bd] * freebsd/kern/kern_linker.c (added) * freebsd/local/linker_if.h (added) Add missing files Thu, 19 Apr 2012 10:05:05 GMT Sebastian Huber [50af4dc] * freebsd/dev/usb/usb_process.c (modified) Hide unused section Since "cold" is defined to 0 this code ... Wed, 18 Apr 2012 19:10:44 GMT Jennifer Averett [a2ec332] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_resource.c (modified) * rtemsbsd/src/rtems-bsd-resource.c (deleted) Merged the rtems version of resource back to kern_resource and added ... Wed, 18 Apr 2012 17:35:01 GMT Jennifer Averett [31230c0] * freebsd/net/netisr.c (modified) Commented out calls to pin and unpin. Wed, 18 Apr 2012 15:02:17 GMT Sebastian Huber [1e3e818] * freebsd/kern/subr_bus.c (modified) Hide device sysctl and resource functions Wed, 18 Apr 2012 15:22:44 GMT Sebastian Huber [e2b2fc6] * freebsd/kern/kern_subr.c (modified) Remove superfluous include, format Wed, 18 Apr 2012 15:14:02 GMT Sebastian Huber [2f52893] * freebsd/sys/endian.h (modified) * rtemsbsd/freebsd/machine/endian.h (modified) Move __bswap64() Add copyright notice of FreeBSD ... Wed, 18 Apr 2012 15:03:59 GMT Jennifer Averett [0287267] * freebsd/kern/kern_subr.c (modified) * rtemsbsd/src/rtems-bsd-subr.c (deleted) Moved uio_yield implementation into bsd file. Wed, 18 Apr 2012 14:48:49 GMT Joel Sherrill [f084ec7] * freebsd/sys/endian.h (modified) Add generic implementation of __bswap64 Wed, 18 Apr 2012 14:46:21 GMT Jennifer Averett [d8c5df7] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/machine/cpu.h (deleted) * rtemsbsd/freebsd/machine/cpu.h (moved) Moved rtems-bsd-cyclecount.c to cpu.h Wed, 18 Apr 2012 12:55:02 GMT Sebastian Huber [60ed795] * freebsd/sys/errno.h (modified) Hide most error number definitions Wed, 18 Apr 2012 12:00:54 GMT Sebastian Huber [e3501b5] * freebsd/kern/kern_mib.c (modified) * freebsd/kern/kern_prot.c (modified) Add parts of the UCRED(9) implementation Tue, 17 Apr 2012 19:31:21 GMT Jennifer Averett [b6c71ea] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_resource.c (added) Added chgsbsize() method. Tue, 17 Apr 2012 18:32:56 GMT Jennifer Averett [785af86] * freebsd/net/netisr.c (modified) Added back in a couple of methods. Tue, 17 Apr 2012 18:16:36 GMT Jennifer Averett [90cdcae] * freebsd/net/netisr.c (modified) Commented out unused methods to resolve linker errors. Tue, 17 Apr 2012 15:19:30 GMT Sebastian Huber [508747e] * freebsd/sys/kenv.h (added) Add missing header file Tue, 17 Apr 2012 14:54:29 GMT Sebastian Huber [837df26] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/local/pci_if.c (added) * freebsd/local/pci_if.h (modified) * freebsd/local/pcib_if.c (added) * freebsd/local/pcib_if.h (added) Add PCI and PCIB interface files Tue, 17 Apr 2012 14:07:34 GMT Sebastian Huber [68df607] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/mips/mips/in_cksum.c (modified) Use MIPS in_cksum.c for SPARC Tue, 17 Apr 2012 14:39:46 GMT Jennifer Averett [c57eebb] * freebsd/dev/pci/pcivar.h (modified) Added method to help resolve linker issue. Tue, 17 Apr 2012 14:38:54 GMT Jennifer Averett [d558a43] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_intr.c (added) Added methods to resolve linker errors. Tue, 17 Apr 2012 14:00:18 GMT Jennifer Averett [30e98a2] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_environment.c (added) Added variables from kern_environment to remove linker errors. Mon, 16 Apr 2012 18:22:45 GMT Jennifer Averett [e4b9989] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/subr_hints.c (added) Addded resource_XXX methods to resolve linker issues. Mon, 16 Apr 2012 17:04:31 GMT Jennifer Averett [6053efd] * freebsd/kern/init_main.c (modified) Added thread0 variable to resolve linker error. Mon, 16 Apr 2012 16:00:02 GMT Joel Sherrill [c4117bb] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/libkern/fls.c (added) Add libkern/fls.c for fls() - Find last bit set Mon, 16 Apr 2012 14:10:35 GMT Jennifer Averett [459afb1] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_ntptime.c (added) * freebsd/sys/_rmlock.h (modified) * freebsd/sys/rmlock.h (modified) * rtemsbsd/src/rtems-bsd-lock.c (modified) * rtemsbsd/src/rtems-bsd-rmlock.c (deleted) * rtemsbsd/src/rtems-bsd-timeout.c (added) Implemented a version of rmlock using rwlock. Fri, 06 Apr 2012 17:29:02 GMT Jennifer Averett [63a3476] * freebsd/kern/kern_event.c (modified) Added in knote_enqueue. Thu, 05 Apr 2012 20:24:27 GMT Jennifer Averett [251480e] * freebsd-to-rtems.py (modified) * freebsd/kern/kern_event.c (modified) * freebsd/sys/eventvar.h (added) Added in a header file and some defines to resolve linker errors. Thu, 05 Apr 2012 20:07:16 GMT Jennifer Averett [e664034] * freebsd/dev/pci/pcivar.h (modified) Comment out unused methods that were generating linker errors. Thu, 05 Apr 2012 19:13:24 GMT Jennifer Averett [508e3df] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/uipc_accf.c (added) Added uipc_XXx methods. Thu, 05 Apr 2012 18:42:26 GMT Jennifer Averett [c613894] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pci.c (added) * freebsd/sys/pciio.h (added) Added pci_XXX methods. Thu, 05 Apr 2012 18:04:52 GMT Jennifer Averett [39292ce] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/netinet/tcp_hostcache.c (added) Added tcp_hc_XXX methods. Thu, 05 Apr 2012 17:49:15 GMT Jennifer Averett [2385258] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/subr_rman.c (added) Added rmon_XXX methods. Thu, 05 Apr 2012 17:42:40 GMT Jennifer Averett [7730088] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/subr_sbuf.c (added) Added sbuf_XXX methods. Thu, 05 Apr 2012 15:55:30 GMT Jennifer Averett [3c05977] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_event.c (added) Added knlist_XXX and knote_XXX methods. Thu, 05 Apr 2012 15:00:36 GMT Jennifer Averett [b2e05ef] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_time.c (added) Added ratecheck methods as part of RealTek Nic integration. Wed, 04 Apr 2012 22:47:18 GMT Joel Sherrill [772d929] * freebsd/sys/param.h (modified) Add _ALIGN macro based on one in libmisc/shell/fts.c Wed, 04 Apr 2012 21:31:00 GMT Joel Sherrill [ed3790d] * freebsd/kern/kern_subr.c (modified) Enable copyinuio Wed, 04 Apr 2012 20:07:21 GMT Joel Sherrill [00ded52] * freebsd/kern/kern_subr.c (modified) kern_subr.c - Enable uiomove for rtems Wed, 04 Apr 2012 19:08:31 GMT Jennifer Averett [d75b748] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_prot.c (added) Added cr_XXX methods to resolve linker errors with RealTek Nic. Mon, 02 Apr 2012 17:13:22 GMT Jennifer Averett [8960780] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/libkern/inet_ntoa.c (added) Add methods to reaolve linker issues. Mon, 02 Apr 2012 14:30:23 GMT Jennifer Averett [ce0b530] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/subr_pcpu.c (added) Add globals to resolve linker conflicts. Fri, 30 Mar 2012 16:49:26 GMT Joel Sherrill [e3f2b51] * freebsd-to-rtems.py (modified) * freebsd/machine/elf.h (added) Add freebsd/machine/elf.h as empty. Improve message for empty file. Fri, 30 Mar 2012 16:36:33 GMT Jennifer Averett [d195d2d] * freebsd/kern/kern_sysctl.c (modified) Added methods back in to resolve link issues. Fri, 30 Mar 2012 15:04:36 GMT Jennifer Averett [777b87c] * freebsd/libkern/arc4random.c (added) Resolve linker error with RealTek Nic (forgot file arc4random) Fri, 30 Mar 2012 14:32:07 GMT Jennifer Averett [393a859] * freebsd/kern/kern_mib.c (modified) Add methods back in that were needed to link with RealTek Nic. Tue, 27 Mar 2012 18:58:38 GMT Jennifer Averett [27ae2dfc] * freebsd-to-rtems.py (modified) * freebsd/kern/kern_mib.c (added) Added kern_mib.c to resolve linker error when pulling in RealTek Nic. Tue, 27 Mar 2012 18:42:16 GMT Jennifer Averett [9fe8c97] * freebsd/kern/kern_subr.c (modified) Commented out methods to prevent linker errors. Removed methods ... Tue, 27 Mar 2012 14:21:04 GMT Joel Sherrill [c976506] * freebsd/kern/init_main.c (modified) * rtemsbsd/freebsd/machine/rtems-bsd-symbols.h (modified) Add bootverbose Tue, 27 Mar 2012 13:53:56 GMT Joel Sherrill [4854583] * freebsd/dev/e1000/if_igb.c (modified) * freebsd/machine/elf.h (deleted) Address prototype mismatch in FreeBSD code. Need to report upstream.
